Part Number: MSP430FR5970
Other Parts Discussed in Thread: MSP-FET
Hi Team,
I'm designing a VPX board that consists of the MSP430FR5970 MCU. I'm using MCU for the entire board power control and monitoring. And also for toggling some control signals that relate to VPX. By referring to hardware tools User's guide: I've created a schematic design. Attached the design PDF along with this. Kindly go through it, and please let me know if any modification is required for the mentioned usage. And on the software side, please provide a high-level brief on how the MCU can be programmed. What will be the current state of GPIOs once the MCU is powered up? Is there any internal pull-up or pull-down we can set? Also, is it possible to configure the IO as an open drain or push-pull (input/output)? and the IO level of all the pins. I believe it is 3.3V since I'm providing 3.3V to AVCC and DVCC. Please provide your guidance on the above matter at the earliest possible.
Anoop
