EVM430-FR6043: EVM430-FR6043: ERROR DToF - Shift value was greater than maxSampleShift
Part Number: EVM430-FR6043
Dear Team,
                  We are currently working with 200 kHz transducers using the MSP430-FR6043 EVM, and testing is being conducted on the Ultrasonic Sensing Design Center software (version 02_30_00_03).
                  We are attempting to measure air flow at 60 m/s, but we are encountering the following error: "Error 135: DToF shift value was greater than maxSampleShift."
I was follow this link also:
https://e2e.ti.com/support/microcontrollers/msp-low-power-microcontrollers-group/msp430/f/msp-low-power-microcontroller-forum/1159885/evm430-fr6043-getting-error-for-300khz-transducer-dtof---shift-value-was-greater-than-maxsampleshift
Please Check Setting Bellow:
    Find the USS_ALG_MAX_SAMPLE_SHIFT value in the project. Then change it to a higher value like 40, 60, 80. Then you can avoid this issue.
    Cash Hao
     I have changed USS_ALG_MAX_SAMPLE_SHIFT to 80. now this error is gone but still performance is not getting as required. Please Check Code snap.
    #ifndef _USERCONFIG_H_
    #define _USERCONFIG_H_
    //! \file ussSwLib_userConfig.h
    //! \brief USS SW Library configuration file
    // Group: MSP
    // Target Device: MSP430FR604x
    // (C) Copyright 2019, Texas Instruments, Inc.
    // TI Release: USSLib_02_30_00_03
    // Release Date: February 04, 2020
    // includes
    #include <msp430.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "ussSwLib.h"
    #include "USS_Lib_HAL.h"
    #include "IQmathLib.h"
    #include "ussSwLibCalibration.h"
    //! \addtogroup ussSwLib_userConfig
    #ifdef __cplusplus
    extern "C"
    #endif
    * The following macros allows user to select tone generation type
    #define USS_PULSE_MODE_SINGLE_TONE 0
    #define USS_PULSE_MODE_DUAL_TONE 1
    #define USS_PULSE_MODE_MULTI_TONE 2
    * The following macros allows user to select default
    * Absolute time of flight computation option
    * To switch between computation option update
    * USS_ALG_ABS_TOF_COMPUTATION_MODE macro with the desired computation option
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE 0
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT 1
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE_WIDE 2
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT_WIDE 3
    * DtoF computation option
    * USS_ALG_DTOF_COMPUTATION_MODE macro with the desired computation
    * option
    #define USS_ALG_DTOF_COMPUTATION_OPTION_WATER 0
    #define USS_ALG_DTOF_COMPUTATION_OPTION_ESTIMATE 1
    * DToF estimate windowing options
    * USS_ALG_DTOF_WINDOWING_MODE macro with the desired computation option
    * when USS_ALG_DTOF_COMPUTATION_MODE = USS_ALG_DTOF_COMPUTATION_OPTION_ESTIMATE
    #define USS_ALG_DTOF_EST_WINDOW_OPTION_DISABLED 0
    #define USS_ALG_DTOF_EST_WINDOW_OPTION_ESTIMATE 1
    #define USS_ALG_DTOF_EST_WINDOW_OPTION_DYNAMIC 2
    #define USS_ALG_DTOF_EST_WINDOW_OPTION_STATIC 3
    * when USS_ALG_DTOF_COMPUTATION_MODE = USS_ALG_DTOF_COMPUTATION_OPTION_WATER
    #define USS_ALG_DTOF_WATER_WINDOW_OPTION_DISABLED 0
    #define USS_ALG_DTOF_WATER_WINDOW_OPTION_ENABLED 1
    * volume flow calibration options
    * USS_ALG_VFR_CALIB_MODE macro with the desired computation option
    #define USS_ALG_VFR_CALIB_OPTION_DISABLED 0
    #define USS_ALG_VFR_CALIB_OPTION_FLOW 1
    #define USS_ALG_VFR_CALIB_OPTION_FLOW_TEMPERATURE 2
    * Volume computation option
    * USS_ALG_VOLUME_RATE_COMPUTATION_MODE macro with the desired computation
    * option
    #define USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_WATER 0
    #define USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_GENERIC 1
    #define USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_GAS USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_GENERIC
    // defines
    * USS PULSE GENERATION CONFIGURATION
    * The following parameters configures the ultrasonic pulse generation
    #ifndef USS_PULSE_MODE
    #define USS_PULSE_MODE USS_PULSE_MODE_MULTI_TONE
    #endif
    #if (USS_PULSE_MODE == USS_PULSE_MODE_SINGLE_TONE)
    #define USS_NUM_OF_EXCITATION_PULSES_F1 24
    #define USS_F1_FREQ 170000
    #define USS_PULSE_DUTYPERCENT_F1 50
    #define USS_NUM_OF_EXCITATION_PULSES USS_NUM_OF_EXCITATION_PULSES_F1
    #elif defined(__MSP430_HAS_SAPH_A__)
    #if (USS_PULSE_MODE == USS_PULSE_MODE_DUAL_TONE)
    #define USS_NUM_OF_EXCITATION_PULSES_F2 0
    #define USS_F2_FREQ 240000
    #define USS_PULSE_DUTYPERCENT_F2 50
    #define USS_NUM_OF_EXCITATION_PULSES (USS_NUM_OF_EXCITATION_PULSES_F1 + USS_NUM_OF_EXCITATION_PULSES_F2)
    #elif (USS_PULSE_MODE == USS_PULSE_MODE_MULTI_TONE)
    #define USS_NUM_OF_TRILL_PULSES 12
    #define USS_NUM_OF_EXCITATION_PULSES ((2*(USS_NUM_OF_TRILL_PULSES + USS_NUM_OF_ADDTL_TRILL_PULSES)))
    #endif
    #endif
    #if (USS_PULSE_MODE == USS_PULSE_MODE_MULTI_TONE)
    #define USS_NUM_OF_ADDTL_TRILL_PULSES 0
    #endif
    #define USS_ADDTL_BIN_PATTERN_SIZE 0
    #define USS_NUM_OF_STOP_PULSES 0
    * LIBRARY MEMORY OPTIMIZATION CONFIGURATION
    * The following parameters allows to user to reduce capture buffer size and
    * temporary LEA and FRAM buffers.
    #if defined(__MSP430_HAS_SAPH_A__)
    #define USS_SW_LIB_APP_MAX_CAPTURE_SIZE 500
    #define USS_NUM_OF_MAX_TRILL_PULSES 20
    #define USS_NUM_OF_MAX_ADDTL_TRILL_PULSES 10
    #endif
    #else
    #define USS_SW_LIB_APP_MAX_CAPTURE_SIZE 330
    #endif
    #define USS_SW_LIB_APP_MAX_FILTER_LENGTH 20
    #define USS_SW_LIB_APP_MAX_FILTER_OPTIONS 5
    #define USS_SW_LIB_APP_MAX_HILBERT_FILTER_OPTIONS 2
    #define USS_SW_LIB_APP_MAX_HILBERT_FILTER_LENGTH 12
    #define USS_BINARY_ARRAY_MAX_SIZE 400
    #else
    #define USS_BINARY_ARRAY_MAX_SIZE 200
    #endif
    * LIBRARY CAPTURE ACCUMULATION CONFIGURATION
    * The following parameters allows to enable/disable capture accumulation
    * options. WARNING: Enabling accumulation will increase LEA RAM requirements
    * USS_SW_LIB_ENABLE_ACCUMULATION valid options:
    * -true
    * -false
    * USS_ALG_DTOF_INTERVAL valid options:
    * -USS_dtof_volume_flow_calculation_interval_1 (default)
    * -USS_dtof_volume_flow_calculation_interval_2
    * -USS_dtof_volume_flow_calculation_interval_4
    * -USS_dtof_volume_flow_calculation_interval_8
    * The following definitions are used to initialize the following library
    * parameter:
    * -USS_Capture_Configuration.isCapAccumulationEnabled
    * -USS_Algorithms_User_Configuration.dtofVolInterval
    #define USS_SW_LIB_ENABLE_ACCUMULATION false
    #if (USS_SW_LIB_ENABLE_ACCUMULATION == false)
    #define USS_ALG_DTOF_INTERVAL USS_dtof_volume_flow_calculation_interval_1
    #else
    #warning "Update to desired calculation interval"
    #define USS_ALG_DTOF_INTERVAL USS_dtof_volume_flow_calculation_interval_4
    #endif
    * LIBRARY CLOCK DEFINITION
    * IMPORTANT: The following defines only specify MCLK and LFXT frequencies at
    * which the application is configured to run. The library DOES NOT configure
    * MCLK, SMCLK or LFXT.
    * This parameter are also using in the derived parameter section to calculate
    * HSPLL counts and LFXT counts.
    * USS_MCLK_FREQ_IN_HZ valid options:
    * - Valid device specific MCLK frequency options
    * USS_LFXT_FREQ_IN_HZ valid options:
    * USS_SYS_MEASUREMENT_PERIOD (in LFXT cycles) valid range:
    * -min: 655 (20 milliseconds)
    * -max: 65535 (2 seconds)
    #define USS_MCLK_FREQ_IN_HZ 16000000
    #else
    #define USS_MCLK_FREQ_IN_HZ 8000000
    #endif
    #define USS_SMCLK_FREQ_IN_HZ 8000000
    #define USS_LFXT_FREQ_IN_HZ 32768
    #define USS_SYS_MEASUREMENT_PERIOD 32768
    * LIBRARY DIAGNOSTIC CONFIGURATION
    * The following configuration allows the application to obtain additional debug
    * message codes during the application process.
    * USS_DIAGNOSTIC_MODE valid options:
    * - USS_diagnostics_mode_2 (default)
    * - USS_diagnostics_mode_0
    #define USS_DIAGNOSTIC_MODE USS_diagnostics_mode_2
    * LIBRARY METER CONFIGURATION
    * The following configuration allows the application to configure meter
    * specific parameter
    * USS_ACOUSTIC_LENGTH (Acoustic length in us at room temperature)
    * USS_VOLUME_SCALE_FACTOR
    #define USS_ACOUSTIC_LENGTH 70
    #if (USS_PULSE_MODE != USS_PULSE_MODE_SINGLE_TONE)
    #define USS_VOLUME_SCALE_FACTOR 61.00f
    #else
    #define USS_VOLUME_SCALE_FACTOR 1.2742e7f
    #endif
    // The following #define must be set to 1.0f or larger
    #define USS_VFR_LARGE_PIPE_ADDL_SF 1.000000f
    // The following #define must be :
    // Set to false if USS_VFR_LARGE_PIPE_ADDL_SF == 1.0f
    // Set to true if USS_VFR_LARGE_PIPE_ADDL_SF > 1.0f)
    #define USS_VFR_LARGE_PIPE_ADDL_SF_ENABLE false
    * LIBRARY BASIC ULTRASONIC FIRING/CAPTURE CONFIGURATION
    * The library basic configuration section has been split in the following
    * sections:
    * -USS FREQUENCY CONFIGURATION PARAMETERS
    * -USS CAPTURE SEQUENCE CONFIGURATION
    * -USS PULSE GENERATION CONFIGURATION
    * -USS CALIBRATION CONFIGURATION
    * USS FREQUENCY CONFIGURATION PARAMETERS
    * USS_HSPLL_FREQ_IN_MHZ valid parameters:
    * - 80 (default), 79, 78, 77, 76, 75, 74, 73, 72, 71, 70, 69, 68
    * USS_HSPLL_INPUT_CLK_TYPE valid parameters:
    * - USS_HSPLL_input_clock_type_ceramic_resonator (default)
    * - USS_HSPLL_input_clock_type_crystal
    * USS_OVER_SAMPLE_RATE valid parameters:
    * -10
    * -20 (default)
    * -40
    * -80
    * -160
    * USS_PLL_XTAL_IN_MHZ valid parameters:
    * -USS_HSPLL_input_clock_freq_8_MHz
    * -USS_HSPLL_input_clock_freq_4_MHz
    * USS_OUTPUT_PLL_XTAL valid parameters:
    * -false (default)
    * -true
    #define USS_HSPLL_FREQ_IN_MHZ 80
    #define USS_HSPLL_INPUT_CLK_TYPE USS_HSPLL_input_clock_type_ceramic_resonator
    #define USS_SDHS_OVER_SAMPLE_RATE 20
    #else
    #define USS_SDHS_OVER_SAMPLE_RATE 80
    #endif
    #define USS_PLL_XTAL_IN_MHZ USS_HSPLL_input_clock_freq_8_MHz
    #define USS_OUTPUT_PLL_XTAL false
    #define USS_HSPLL_TOLERANCE_PERCENT 0.5
    * USS CAPTURE SEQUENCE CONFIGURATION
    * USS_SEQUENCE_SELECTION valid parameters:
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH0
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH1
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH0_CH0
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH0_CH1 (default)
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH1_CH0
    * - USS_CAPTURE_SEQUENCE_SELECTION_CH1_CH1
    * USS_CAPTURE_DURATION_USEC vaild range:
    * -min: 1 usec
    * -max: Varies depending on USS_SW_LIB_APP_MAX_CAPTURE_SIZE,
    * USS_SDHS_OVER_SAMPLE_RATE and USS_HSPLL_FREQ_IN_MHZ
    * For further details regarding min and max values for the following parameter
    * please refer the USS Library API Guide.
    * USS_GAIN_RANGE
    * USS_START_CAPTURE_SEC
    * USS_ADC_SAMP_COUNT_SEC
    * USS_RESTART_CAP_COUNT_SEC
    #define USS_SEQUENCE_SELECTION USS_CAPTURE_SEQUENCE_SELECTION_CH0_CH1
    #define USS_CAPTURE_DURATION_USEC 300
    #define USS_GAIN_RANGE USS_Capture_Gain_Range_1_0
    #define USS_START_CAPTURE_SEC 2.0E-4
    #define USS_ADC_SAMP_COUNT_SEC 4.3000001E-4
    #else
    #define USS_GAIN_RANGE USS_Capture_Gain_Range_1_9
    #endif
    #define USS_RESTART_CAP_COUNT_SEC 8.000E-3
    #if (USSSWLIB_ENABLE_EXTERNAL_CIRCUITRY_CONTROL == true)
    #define USS_MEASUREMENT_TURN_ON_EXTERNAL_AMP_SEC 1.0E-5
    #define USS_MEASUREMENT_ASQTRIGGER_DELAY_SEC 100e-6f
    #endif
    * USS CALIBRATION CONFIGURATION
    * The following parameters configures the ultrasonic:
    * -Automatic Gain Calibration Constant
    * For further details regarding the following parameter please refer the USS
    * Library API Guide.
    * USS_AGC_CONSTANT
    * USS_ALG_CALIBRATED_UPS_DC_OFFSET
    * USS_ALG_CALIBRATED_DNS_DC_OFFSET
    #define USS_AGC_CONSTANT 60
    #define USS_ALG_CALIBRATED_UPS_DC_OFFSET 0
    #define USS_ALG_CALIBRATED_DNS_DC_OFFSET 0
    * LIBRARY BASIC ALGORITHM CONFIGURATION
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT_WIDE
    #else
    #define USS_ALG_ABS_TOF_COMPUTATION_MODE USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE
    #endif
    #define USS_ALG_DTOF_COMPUTATION_MODE USS_ALG_DTOF_COMPUTATION_OPTION_ESTIMATE
    #define USS_ALG_VOLUME_RATE_COMPUTATION_MODE USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_GAS
    #else
    #define USS_ALG_VOLUME_RATE_COMPUTATION_MODE USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_WATER
    #endif
    #define USS_ALG_ABS_TOF_INTERVAL 1
    #define USS_ALG_DTOF_WINDOWING_MODE USS_ALG_DTOF_EST_WINDOW_OPTION_DISABLED
    #else
    #if (USS_ALG_DTOF_COMPUTATION_MODE == USS_ALG_DTOF_COMPUTATION_OPTION_WATER)
    #define USS_ALG_DTOF_WINDOWING_MODE USS_ALG_DTOF_WATER_WINDOW_OPTION_ENABLED
    #elif (USS_ALG_DTOF_COMPUTATION_MODE == USS_ALG_DTOF_COMPUTATION_OPTION_ESTIMATE)
    #define USS_ALG_DTOF_WINDOWING_MODE USS_ALG_DTOF_EST_WINDOW_OPTION_ESTIMATE
    #endif
    #endif
    #define USS_ALG_FILT_IS_FILTER_ENABLED false
    #define USS_ENABLE_ABSTOF_LOBE_OFFSET_CORRECTION false
    #define USS_ALG_VFR_CALIB_MODE USS_ALG_VFR_CALIB_OPTION_DISABLED
    #define USS_ALG_ENABLE_ESTIMATE_TEMPERATURE false
    #define USS_ALG_ADC_ADDITIONAL_CAP_DLY 0.0e-6
    #define USS_ALG_DCOFFSET 0.0e-12
    #define USS_ALG_CLOCK_RELATIVERROR _IQ27(0.0)
    #define USS_ALG_ABS_TOF_HILB_USE_CUSTOM_COEFF false
    #if(USS_ALG_DTOF_WINDOWING_MODE != USS_ALG_DTOF_EST_WINDOW_OPTION_DISABLED)
    #define USS_ALG_WIN_START_INDEX_BACK_OFF_NUM_CYCLES 2
    #define USS_ALG_WIN_TRAP_RAMP_NUM_CYCLES 4
    #define USS_ALG_WIN_NUM_CYCLES_DELTA 3
    #define USS_ALG_WIN_PEAK_INDEX_2_EDGES_NUM_CYLES 0
    #define USS_ALG_WIN_NUM_CYCLES (USS_NUM_OF_EXCITATION_PULSES + \
    USS_ALG_WIN_NUM_CYCLES_DELTA)
    #endif
    * LIBRARY ADVANCED ALGORITHM CONFIGURATION
    * For more information regarding the following parameter please refer to the
    * USS API Library Guide
    #if (USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE)
    #define USS_ALG_RATIO_OF_TRACK_LOBE 0.5
    #define USS_ALG_NUM_PULS_BEFORE_THRSH 1
    #define USS_ALG_SEARCH_LOBE_SAMP 1
    #define USS_ALG_MAX_RATIO_PEAK_2_PEAK_VAR 0.2
    #define USS_ALG_CORR_VAL_THRSH_CHK_FACT 0.05
    #define USS_ALG_SIGN_VAL_THRSH_CHK 100
    #elif (USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT)
    #define USS_ALG_ABS_TOF_SEARCH_RANGE 20
    #define USS_ALG_ABS_TOF_POS_SEARCH_RANGE USS_ALG_ABS_TOF_SEARCH_RANGE
    #define USS_ALG_ABS_TOF_NEG_SEARCH_RANGE -(USS_NUM_OF_EXCITATION_PULSES + USS_ALG_ABS_TOF_SEARCH_RANGE)
    #define USS_ALG_ABS_TOF_HILB_CROSS_THRESHOLD 50.0
    #elif (USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_LOBE_WIDE)
    #define USS_ALG_MAX_RATIO_PEAK_2_PEAK_VAR 0.5
    #elif (USS_ALG_ABS_TOF_COMPUTATION_MODE == USS_ALG_ABS_TOF_COMPUTATION_MODE_HILBERT_WIDE)
    #else
    #error "Invalid Absolute ToF Algorithm Option"
    #endif
    #define USS_ALG_NUM_CYCLES_SEARCH_CORR 2
    #define USS_ALG_HIGH_FLOW_OPTION (USS_highFlow_option_disabled)
    #define USS_ALG_CYCLESLIPTHRESHOLD 1.1
    #define USS_ALG_THRESHOLDX1X3 2000000
    #define USS_ALG_MAX_SAMPLE_SHIFT 80
    #else
    #error "Invalid Delta ToF Algorithm Option"
    #endif
    * LIBRARY ALGORITHM BAND-PASS AND HILBERT COEFFICIENT
    #define USS_SW_LIB_APP_FILTER_COEFFICIENTS \
    /* USS_filterCoeffs_3400000Hz */ \
    { 0xFEEA, 0xFFDA, 0xF4E6, 0xFBA5, \
    0xFFBB, 0x03BC, 0x155D, 0xDE0E, \
    0xF5A0, 0x2E9C, 0xF5A0, 0xDE0E, \
    0x155D, 0x03BC, 0xFFBB, 0xFBA5, \
    0xF4E6, 0xFFDA, 0xFEEA, 0x0000 \
    /* USS_filterCoeffs_3600000Hz */ \
    { 0x002B, 0xFF01, 0xF563, 0x050D, \
    0xFE4C, 0x0F1B, 0x0FDC, 0xE05C, \
    0xFAC9, 0x302A, 0xFAC9, 0xE05C, \
    0x0FDC, 0x0F1B, 0xFE4C, 0x050D, \
    0xF563, 0xFF01, 0x002B, 0x0000 \
    /* USS_filterCoeffs_3800000Hz */ \
    { 0x0120, 0xFAD8, 0xFA10, 0x06E7, \
    0xFE1E, 0x14A0, 0x0848, 0xE00B, \
    0xFE43, 0x2DAF, 0xFE43, 0xE00B, \
    0x0848, 0x14A0, 0xFE1E, 0x06E7, \
    0xFA10, 0xFAD8, 0x0120, 0x0000 \
    /* USS_filterCoeffs_4000000Hz */ \
    { 0x0000, 0xF68E, 0x0000, 0x037C, \
    0x0000, 0x1714, 0x0000, 0xE229, \
    0x0000, 0x2D64, 0x0000, 0xE229, \
    0x0000, 0x1714, 0x0000, 0x037C, \
    0x0000, 0xF68E, 0x0000, 0x0000 \
    /* USS_filterCoeffs_Custom */ \
    {0}, \
    #define USS_SW_LIB_APP_HILB_FILTER_COEFFICIENTS \
    /* Predefined Hilbert transform coefficients */ \
    { 0xFD84, 0x0000, 0xF11F, 0x0000, \
    0xB38F, 0x0000, 0x4C71, 0x0000, \
    0x0EE1, 0x0000, 0x027C, 0x0000 \
    /* USS Hilbert Coeffs Custom */ \
    {0}, \
    * LIBRARY ADVANCED ULTRASONIC FIRING/CAPTURE CONFIGURATION
    #define USS_EOF_SEQUENCE_SELECTION USS_measurement_end_of_sequence_state_power_off
    #define USS_CH0_DRIVE_STRENGHT USS_measurement_drive_strength_pre_trimmed_drive
    #define USS_CH1_DRIVE_STRENGHT USS_measurement_drive_strength_pre_trimmed_drive
    #define USS_PAUSE_STATE USS_measurement_pause_state_low
    #define USS_PULSE_POLARITY USS_measurement_pulse_polarity_excitation_starts_on_high_pulse
    #define USS_PGA_IN_BIAS_COUNT_SEC 5e-6
    #define USS_TURN_ON_ADC_COUNT_SEC 5e-6
    #else
    #define USS_PGA_IN_BIAS_COUNT_SEC 2.0E-4
    #define USS_TURN_ON_ADC_COUNT_SEC 2.0E-5
    #endif
    #define USS_TIME_OUT_COUNT_SEC 3000e-6
    #define USS_HSPLL_USSXTAL_SETTLING_USEC 120
    #define USS_ENABLE_UUPSPREQIGINTERRUPT false
    #define USS_ENABLE_SAPH_PING_TRANSMIT false
    #define USS_ENABLE_WINDOW_HI_COMP false
    #define USS_ENABLE_WINDOW_LO_COMP false
    #define USS_WINDOW_HIGH_THRESHOLD (1040)
    #define USS_WINDOW_LOW_THRESHOLD (-1040)
    #define USS_TRIGGER_CONFIG USS_Triger_Configuration_Software_Trigger
    #define USS_ULP_BIAS_DELAY USS_measurement_ULP_bias_delay_no_delay
    #define USS_BIAS_IMPEDANCE USS_measurement_bias_impedance_2800_Ohms
    #define USS_MUX_CHARGE_PUMP_MODE USS_measurement_mux_charge_pump_always_off
    * LIBRARY DERIVED PARAMETER SECTION
    * The following section performs additional library configuration based on the
    * parameter selection above.
    * It is highly recommended to not modify the following sections
    #endif
    #endif
    #define USS_ALG_ABS_TOF_COMPUTATION (USS_Alg_AbsToF_Calculation_Option_lobe)
    #define USS_ALG_ABS_TOF_COMPUTATION (USS_Alg_AbsToF_Calculation_Option_hilbert)
    #define USS_ALG_ABS_TOF_COMPUTATION (USS_Alg_AbsToF_Calculation_Option_lobeWide)
    #define USS_ALG_ABS_TOF_COMPUTATION ( \
    USS_Alg_AbsToF_Calculation_Option_hilbertWide)
    #else
    #error "Invalid Abs ToF computation option"
    #endif
    #define USS_ALG_DELTA_TOF_COMPUTATION_OPTION (USS_Alg_dToF_Calculation_Option_water)
    #define USS_ALG_DELTA_TOF_COMPUTATION_OPTION (USS_Alg_dToF_Calculation_Option_estimate)
    #else
    #error "Invalid Delta ToF computation option"
    #endif
    #if (USS_ALG_VOLUME_RATE_COMPUTATION_MODE == USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_WATER)
    #define USS_ALG_VOLUME_RATE_COMPUTATION_OPTION (USS_Alg_volume_flow_Calculation_Option_water)
    #elif (USS_ALG_VOLUME_RATE_COMPUTATION_MODE == USS_ALG_VOLUME_RATE_COMPUTATION_OPTION_GENERIC)
    #define USS_ALG_VOLUME_RATE_COMPUTATION_OPTION (USS_Alg_volume_flow_Calculation_Option_generic)
    #else
    #error "Invalid volume flow rate computation option"
    #endif
    #define USS_ALG_IS_INIT_ALGORITHMS false
    #if (USS_PULSE_MODE > 2)
    #error \
    "Pulse mode not supported. Please modify USS_PULSE_MODE to a valid configuration."
    #endif
    #if (USS_NUM_OF_ADDTL_TRILL_PULSES > 0)
    #warning \
    "User must provide additional pulse configuration by defining xtraepulse, xtraxpulse, xtraxhper, xtraxlper, xtrahper, xtralper in variables in USS_userConfig.c"
    #if (USS_ADDTL_BIN_PATTERN_SIZE == 0)
    #error "USS_ADDTL_BIN_PATTERN_SIZE cannot be set to 0 when USS_NUM_OF_ADDTL_TRILL_PULSES > 0"
    #endif
    #elif (USS_NUM_OF_ADDTL_TRILL_PULSES < 0)
    #error "Invalid number of USS_NUM_OF_ADDTL_TRILL_PULSES"
    #endif
    #endif
    #if (USS_HSPLL_FREQ_IN_MHZ == 80)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_80_MHz
    #define USS_PLL_FREQ 80e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 79)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_79_MHz
    #define USS_PLL_FREQ 79e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 78)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_78_MHz
    #define USS_PLL_FREQ 78e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 77)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_77_MHz
    #define USS_PLL_FREQ 77e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 76)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_76_MHz
    #define USS_PLL_FREQ 76e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 75)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_75_MHz
    #define USS_PLL_FREQ 75e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 74)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_74_MHz
    #define USS_PLL_FREQ 74e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 73)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_73_MHz
    #define USS_PLL_FREQ 73e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 72)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_72_MHz
    #define USS_PLL_FREQ 72e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 71)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_71_MHz
    #define USS_PLL_FREQ 71e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 70)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_70_MHz
    #define USS_PLL_FREQ 70e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 69)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_69_MHz
    #define USS_PLL_FREQ 69e6
    #elif (USS_HSPLL_FREQ_IN_MHZ == 68)
    #define USS_HSPLL_FREQ USS_HSPLL_output_clk_freq_68_MHz
    #define USS_PLL_FREQ 68e6
    #else
    #endif
    #define USS_START_PPG_COUNT ((USS_PLL_FREQ * USS_START_CAPTURE_SEC) / 16)
    #define USS_TURN_ON_ADC_COUNT ((USS_PLL_FREQ * USS_TURN_ON_ADC_COUNT_SEC) / 16)
    #define USS_PGA_IN_BIAS_COUNT ((USS_PLL_FREQ * USS_PGA_IN_BIAS_COUNT_SEC) / 16)
    #define USS_ADC_SAMP_COUNT ((USS_PLL_FREQ * USS_ADC_SAMP_COUNT_SEC) / 16)
    #define USS_RESTART_CAP_COUNT ((USS_PLL_FREQ * USS_RESTART_CAP_COUNT_SEC / \
    16) / 16)
    #define USS_TIME_OUT_COUNT ((USS_PLL_FREQ * USS_TIME_OUT_COUNT_SEC / \
    4) / 16)
    #define USS_LOW_POWER_RESTART_CAP_COUNT (USS_LFXT_FREQ_IN_HZ * \
    USS_RESTART_CAP_COUNT_SEC)
    #define USS_HSPLL_TEMP ((USS_PLL_FREQ) / 1600)
    #define USS_HSPLL_TEMP2 ((USS_HSPLL_TEMP) * (USS_HSPLL_TOLERANCE_PERCENT))
    #define USS_HSPLL_TOLERANCE (USS_HSPLL_TEMP2*RESONATOR_CALIB_MONITORING_ACLK/(USS_LFXT_FREQ_IN_HZ))
    // Macros used to place variables in LEA RAM memory section
    #if defined(__TI_COMPILER_VERSION__)
    #define _PRAGMA(x) _Pragma (# x)
    #define USS_LEA_DATA(var,align) _PRAGMA(DATA_SECTION(var,".leaRAM")) \
    _PRAGMA(DATA_ALIGN(var,(align)))
    #elif defined(__IAR_SYSTEMS_ICC__)
    #define USS_LEA_DATA(var,align) _PRAGMA(location = "LEARAM") \
    _PRAGMA(data_alignment = align)
    #elif defined(__GNUC__)
    #define USS_LEA_DATA(var,align) __attribute__((section(".leaRAM"))) \
    __attribute__((aligned(align)))
    #else
    #endif
    // This section of the header checks if the application maximum capture size
    // is below the supported USS SW library capture size
    #if (USS_SW_LIB_ENABLE_ACCUMULATION == true)
    #if (USS_SW_LIB_APP_MAX_CAPTURE_SIZE > 372)
    #error \
    "USS_SW_LIB_APP_MAX_CAPTURE_SIZE in USS_userConfig.h file must be less than 372"
    #else
    #define USS_SW_LIB_APP_MAX_ACC_BLOCK (2 * USS_SW_LIB_APP_MAX_CAPTURE_SIZE)
    #endif
    #else
    #if (USS_SW_LIB_APP_MAX_CAPTURE_SIZE > 620)
    #error \
    "USS_SW_LIB_APP_MAX_CAPTURE_SIZE in USS_userConfig.h file must be less than 620"
    #else
    #define USS_SW_LIB_APP_MAX_ACC_BLOCK 0
    #endif
    #endif
    #define ROUND_UP(N, S) ((((N) + (S) - 1) / (S)) * (S))
    #define TEMP_SETL (USS_HSPLL_USSXTAL_SETTLING_USEC * USS_LFXT_FREQ_IN_HZ)
    #define USS_HSPLL_USSXTAL_SETTLING_COUNT_TEMP ROUND_UP((TEMP_SETL/100000),10)
    #define USS_HSPLL_USSXTAL_SETTLING_COUNT (USS_HSPLL_USSXTAL_SETTLING_COUNT_TEMP \
    / 10)
    #define DIV_ROUND(N, D) (((N) + ((D)/2)) / (D))
    #define USS_SW_LIB_APP_MAX_WINDOW_RAMP_SIZE (USS_SW_LIB_APP_MAX_CAPTURE_SIZE + USS_SW_LIB_APP_MAX_FILTER_LENGTH)
    #define WINDOW_RAMP_TEMP_NUMERATOR (USS_ALG_WIN_TRAP_RAMP_NUM_CYCLES * USS_PLL_FREQ)
    #define WINDOW_RAMP_TEMP_DENOMINATOR (USS_F1_FREQ * USS_SDHS_OVER_SAMPLE_RATE)
    #define USS_SW_LIB_APP_MAX_WINDOW_RAMP_TMP DIV_ROUND(WINDOW_RAMP_TEMP_NUMERATOR,WINDOW_RAMP_TEMP_DENOMINATOR)
    #define USS_SW_LIB_APP_MAX_WINDOW_RAMP_SIZE ((int)USS_SW_LIB_APP_MAX_WINDOW_RAMP_TMP + 2)
    #endif
    #endif
    #if (USS_ALG_FILT_IS_FILTER_ENABLED == true)
    #if (USS_SDHS_OVER_SAMPLE_RATE == 20)
    #define USS_ALG_FILT_OPTION 3
    #define USS_ALG_FILT_OPTION 2
    #define USS_ALG_FILT_OPTION 1
    #define USS_ALG_FILT_OPTION 0
    #else
    #warning "No predefined band-pass filter is available for the selected USS_OVER_SAMPLE_RATE and USS_HSPLL_FREQ frequency. User is responsible of defining USS_filterCoeffs_Custom entry below"
    #define USS_ALG_FILT_OPTION 4
    #endif
    #else
    #endif
    #endif
    #if (USS_ALG_ABS_TOF_HILB_USE_CUSTOM_COEFF == false)
    #define USS_HILB_ALG_FILT_OPTION 0
    #else
    #warning \
    "Detected custom hilbert coefficient configuration. Please confirm USS_filterCoeffs_Custom has a valid coefficient configuration"
    #define USS_HILB_ALG_FILT_OPTION 1
    #endif
    #if (USS_SDHS_OVER_SAMPLE_RATE == 10)
    #define USS_OVER_SAMPLE_RATE \
    USS_Capture_Over_Sample_Rate_10
    #elif (USS_SDHS_OVER_SAMPLE_RATE == 20)
    USS_Capture_Over_Sample_Rate_20
    #elif (USS_SDHS_OVER_SAMPLE_RATE == 40)
    USS_Capture_Over_Sample_Rate_40
    #elif (USS_SDHS_OVER_SAMPLE_RATE == 80)
    USS_Capture_Over_Sample_Rate_80
    #elif (USS_SDHS_OVER_SAMPLE_RATE == 160)
    USS_Capture_Over_Sample_Rate_160
    #else
    #error "Invalid USS_SDHS_OVER_SAMPLE_RATE configuration"
    #endif
    #define USS_USER_CONFIG_NUMBER_OF_SAMPLES_PER_CAPTURE \
    ((USS_CAPTURE_DURATION_USEC*USS_HSPLL_FREQ_IN_MHZ)/USS_SDHS_OVER_SAMPLE_RATE)
    #if (USS_USER_CONFIG_NUMBER_OF_SAMPLES_PER_CAPTURE > \
    #error \
    "USS_USER_CONFIG_NUMBER_OF_SAMPLES_PER_CAPTURE exceeds USS_SW_LIB_APP_MAX_CAPTURE_SIZE"
    #endif
    #ifdef __MSP430_HAS_SAPH__
    #error \
    "Dual or Multi-Tone configuration is not supported on MSP430 devices without SAPH_A module"
    #endif
    #endif
    #define USS_MEASUREMENT_TURN_ON_EXTERNAL_AMP_COUNT (USS_SMCLK_FREQ_IN_HZ * \
    USS_MEASUREMENT_TURN_ON_EXTERNAL_AMP_SEC)
    #define USS_MEASUREMENT_ASQTRIGGER_DELAY_CYCLES \
    (USS_MEASUREMENT_ASQTRIGGER_DELAY_SEC*USS_SMCLK_FREQ_IN_HZ)
    #endif
    #define USS_Alg_dToF_Calculation_Option_water 1
    #define USS_Alg_dToF_Calculation_Option_estimate 0
    #define USS_highFlow_option_disabled 0
    #define USS_highFlow_option_version1 1
    #define USS_highFlow_option_version2 2
    #if (USS_ALG_DELTA_TOF_COMPUTATION_OPTION == USS_Alg_dToF_Calculation_Option_water)
    #if (USS_ALG_HIGH_FLOW_OPTION != USS_highFlow_option_disabled)
    #warning "USS_highFlow_option_version1 and USS_highFlow_option_version2 are \
    discourage for new development. It is highly recommended to switch to \
    USS_ALG_DELTA_TOF_COMPUTATION_OPTION = USS_Alg_dToF_Calculation_Option_estimate.\
    When using USS_Alg_dToF_Calculation_Option_estimate, USS_ALG_HIGH_FLOW_OPTION \
    is a don't care."
    #endif
    #endif
    // typedefs
    // globals
    //! \brief global ultrasonic library configuration
    extern USS_SW_Library_configuration gUssSWConfig;
    extern USS_Pulse_Single_Dual_Tone_Configuration singDualToneConfig;
    extern USS_Pulse_Multitone_Configuration multiToneConfig;
    extern USS_Pulse_Additional_End_of_Sequence_Configuration ussEndOfSeq;
    // the function prototypes
    #ifdef __cplusplus
    #endif // extern "C"
    //@} // ingroup
    #endif // end of _USERCONFIG_H_ definition
    What do you mean by the performance is not getting as required? Any test data you can provide here?
    Cash Hao
    For your kind reference, we are attaching the details of the configurations and tests we have tried so far.
    It looks like there is no valid receive signal captured by the ADC. There is just noise. What is the ADC capture looks like when there is no flow.
    Cash Hao
     Please Find attached pic this is taken from no air flow or normal setup. And for your information that noise is (previous pic) come after air speed exceed 30m/s.
    Well, there is a signal captured. But I still not consider it as a good receive signal. The amplitude of the receive signal is just around 30 ADC codes. It would cause issues with such low amplitude.
    Some thoughts on my side would relate to how you design your flow tube. On a common residential gas meter tube, the receive signal amplitude will easily achieve to around 600 to 800 ADC codes.
    TI FAE is also reaching me to arrange a meeting with you in this week. We can discuss more details on the meeting then.
    Cash Hao
        Thanks, As of  now PFA link which we are flowing same as show in mechanical 3D Setup, Pizos and MSP430-FR6043 EVM kit Configuration structure.
    But the amplitude of ADC capture signal can reach out to 800 ADC codes in that app note. There must be something wrong on the hardware side which cause the signal being weak.
    Cash Hao
  • hi,
        Yes, we will discuss on meeting for this.
