Part Number: MSP430FR6045
Please let me know if jitter what am seeing is it ok.
And how much will my accuracy will be impact
I have sourced clock from pin 95 of my controller
How much jitter is acceptable which would not impact by flow accuracy
Hi David,
I am talking about STD dev which can be seen the picture
According to me that is the way we can measure jitter
As explained my keysight jitter measurement video
Using Clock Tie option in DSO
Hi Harsh,
We do not have related data of the impact of clock jitter on the final measurement results, but if you use the similar crystal as EVM430-FR6047, generally you will get the accuracy which stated in the https://www.ti.com/lit/an/slaa837a/slaa837a.pdf chapter 1.2 if have proper settings.
Peter
Hi Peter
Resonator is used in EVM430fr6047 not crystal
So from your statement can i conclude if i use same resonator than i can achieve the accuracy which you mentioned.
And can you specify the accuracy
Hi Harsh,
Sorry for the typo, it is resonator.
Since the water flow measurement is a systematic project, it hard to directly give a final accuracy because except the measurement, also need to consider your meter design, transducer, calibration, etc. However, in our device part, we have provided some important spec in the datasheet like <25ps dTOF accuracy which directly affects flow calculation.
I believe this thread MSP430FR6043: High precision water meter has given a good explanation of the accuracy, you can refer to that.
Peter
