MSP430-txt output file padding
Hi All,
I require to pad the MSP430-txt output file to 16byte a line (ie 0xFF). Ive found Fill unused code memory setting (Options->Linker->Checksum) but his hasnt work for all the sections generated in the MSP430-txt output file. Is there any way that the MSP430-txt padd and fill all sections as I cant find anything in the xlink document.
Kind regards
Des
  • Des,
    Please post your xcl file here. Use the "Post Code" button [</>] when doing so.
    It might be a problem with how you have your segments and memory defined.
  • Hi All,
    Ive found the solution to this, Looks like in the *xcl the INTVEC segment wasnt defined to a fixed address which meant the Compiler randomly placed it in the output txt file.
    Many Thanks
    Des
