Part Number: MSP430G2553
I try to read Data from an ADXL345. Unfortunatelly my read function gets stuck at forst usage. Does anyone have an idea why and how to solve the problem?
void print(const unsigned char Data){
UCB0TXBUF = Data;
__bis_SR_register(LPM3_bits + GIE);
void printS(char data){
UCB0CTL1 = UCSWRST;
UCB0CTL0 = UCMODE_3 + UCMST + UCSYNC; // I2C master mode
UCB0CTL1 = UCSSEL_2 + UCSWRST; // Use SMCLK, keep SW reset
//UCB0BR0 = 0xA0; // 100 kHz at 16 MHz
UCB0BR0 = 0x28; // 400 kHz at 16 MHz
//UCB0BR0 = 0x1B; // 400 kHz + 50 % at 16 MHz
//UCB0BR0 = 0x14; // 400 kHz + 100 % at 16 MHz
//UCB0BR0 = 0x08; // 2 MHz (400 kHz + 400 %) at 16 MHz
//UCB0BR0 = 0x08; // 4 MHz at 16 MHz
//UCB0BR0 = 0x02; // 8 MHz at 16 MHz
UCB0I2CSA = data; // address
UCB0CTL1 &= ~UCSWRST;
IE2 |= UCB0TXIE; // Enable TX ready interrupt
__disable_interrupt();
UCB0CTL1 |= UCTR + UCTXSTT; // I2C TX, start condition
__bis_SR_register(LPM3_bits + GIE);;
void printE(void){
UCB0CTL1 |= UCTR + UCTXSTP;
IE2 &= ~UCB0TXIE;
void readS(char address, char reg){
UCB0CTL1 = UCSWRST;
UCB0BR0 = 0x28; // < 400 kHz
UCB0I2CSA = address; // address
//go to register
UCB0CTL1 = UCSSEL_2 + UCTR + UCTXSTT; // I2C RX, start condition
UCB0TXBUF = reg;
UCB0CTL1 = UCSSEL_2 + UCTXSTT; // I2C RX, start condition
char read(void){
char output;
output = UCB0RXBUF;
return output;
void adxl(void){
unsigned int hold;
printS(0x53);
print(0x32);
hold = read();
Grav[0] = (read()<<3) + (hold>>5);
hold = read();
Grav[1] = (read()<<3) + (hold>>5);
hold = read();
Grav[2] = (read()<<3) + (hold>>5);
UCB0CTL1 = UCSSEL_2 + UCTXSTP;
while (UCB0CTL1 & UCTXSTP);
void initadxl(void){
printS(0x53);
print(0x2C);
print(0x07);
print(0x08);
printE();
printS(0x53);
print(0x31);
print(0x0D);
printE();
printS(0x53);
print(0x1E);
print(0xFE);
print(0xFD);
print(0x0C);
printE();
void main(void){
WDTCTL = WDTPW + WDTHOLD;
DCOCTL = CALDCO_16MHZ; //DCO setting = 8MHz
BCSCTL1 = CALBC1_16MHZ; //DCO setting = 8MHz
// Configure Pins for I2C
P1SEL |= BIT6 + BIT7; // Pin init
P1SEL2 |= BIT6 + BIT7; // Pin init
__delay_cycles(8000000);
initadxl();
adxl();
// USCI_B0 Data ISR
#pragma vector = USCIAB0TX_VECTOR
__interrupt void USCIAB0TX_ISR(void){
IFG2 &= ~UCB0TXIFG;
__bic_SR_register_on_exit(LPM3_bits); // Wakeup main code
