When switching between projects in Captivate design center (1.50.00.00, Windows), I cannot open any project any more.
In the CaptivateDesignCenter.log I see a NullPointerException:
Exception in thread "AWT-EventQueue-0"
java.lang.NullPointerException
at com.ti.msp430.DesignCenter.ProjectFileSystemView.isTraversable(ProjectFileSystemView.java:92)
at javax.swing.JFileChooser.isTraversable(Unknown Source)
at javax.swing.JFileChooser.setCurrentDirectory(Unknown Source)
at javax.swing.JFileChooser.setSelectedFile(Unknown Source)
at javax.swing.plaf.basic.BasicFileChooserUI$ApproveSelectionAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at javax.swing.JFileChooser.showDialog(Unknown Source)
at com.ti.msp430.DesignCenter.DesignCenter.onFileLocalImport(DesignCenter.java:432)
at com.ti.msp430.captivate.Cdc.CdcDesignCenter.onFileLocalImport(CdcDesignCenter.java:279)
at com.ti.msp430.DesignCenter.DesignCenter.onWorkspaceOpen(DesignCenter.java:396)
at com.ti.msp430.DesignCenter.DesignCenter$12.actionPerformed(DesignCenter.java:1116)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
After removing project folder CapTIvateDesignCenter_1_50_00_00, and restarting Captivate design center, I can open a project once again. But switching between project still doens't work.
Hello Jace,
Thank you for your reply.
I'm using Windows 10, Java 8 update 151 (64-bit) right now.
Here is a screenshot of the situation. Every time I click 'select', the npe appears in the log, and this pop-up window does not close.
Here is the log with some additional info before the npe:
10.30 09:54:27 Disconnected from HID device Vid: 8263 Pid 2405 Interface 0
10.30 09:54:27 Disconnected from HID device Vid: 8263 Pid 2405 Interface 1
10.30 09:55:01 Importing C:\Users\wouter.baks\CapTIvateDesignCenter_1_50_00_00\CapTIvateDesignCenterWorkspace\CAPTIVATE-PHONE\CaptivateDesignCenter.ser
10.30 09:55:02 Disconnected from HID device Vid: 8263 Pid 2405 Interface 0
10.30 09:55:02 Disconnected from HID device Vid: 8263 Pid 2405 Interface 1
10.30 09:55:41 Workspace set to C:\Users\wouter.baks\CapTIvateDesignCenter_1_50_00_00\CapTIvateDesignCenterWorkspace\CAPTIVATE-METAL
10.30 09:55:41 Disconnected from HID device Vid: 8263 Pid 2405 Interface 0
10.30 09:55:41 Disconnected from HID device Vid: 8263 Pid 2405 Interface 1
As you see, I'm using the default example project location.
Moving the workspace does not fix it:
10.30 10:19:30 Workspace set to C:\ti\CAPTIVATE-PHONE
10.30 10:19:30 Disconnected from HID device Vid: 8263 Pid 2405 Interface 0
10.30 10:19:30 Disconnected from HID device Vid: 8263 Pid 2405 Interface 1
Thank you again for your quick response.
Well, I was not trying to create a new project, but just opening different (existing) example projects. Now I get it: I have to select a workspace one folder level higher than the project I want to open. After selecting the correct workspace folder (in this case CapTIvateDesignCenterWorkspace), I can open the different example projects.
