Part Number: MSP430F6731
MSP430F6731 will reset when normal operation, and it was found by the test that the reset pin output spike pulse
Attached is the schematic
Hi Hank,
It sounds strange for your issue. But could you give me more information about your issue to help to analyze the root cause.
1. what is the failure rate about your issue? which stage of the production occurs the issue, design stage/PP/MP or released to end user for some duration?
2. Did you check the VCC power supply of MSP430 device to check whether the power is stable when the issue occurs?
3. The issue occurs always or sometimes? Did some event trigger this issue or some event could let the issue go away?
4. Did you disassemble the MSP430 device from issue board and assemble it to a good board and check if the issue goes with MSP430 or the board? This could be called A-B-A test.
5. Did you check the SYSRSTIV register after an reset occurs to confirm the reset source. The value of this register could be found on Table 6-11. System Module Interrupt Vector Registers of the Device Datasheet.
6. I took a quick look at your schematic and found the circuit of RST/NMI pin didn't follow the device User's Guide, which should be a 47-kΩ pullup resistor and 2.2 nF pulldown capacitor. You could find this on the Table 1-3. Connection of Unused Pins of the device User's Guide.
Hi Hank,
I haven’t heard from you for several days, so I’m assuming you were able to resolve your issue. If this isn’t the case, please click the "This did NOT resolve my issue" button and reply to this thread with more information. If this thread locks, please click the "Ask a related question" button and in the new thread describe the current status of your issue and any additional details you may have to assist us in helping to solve your issues.
