MSP432P401R: Measuring current consumption of MSP432 launchpad by measuring resistance between its two terminal.
Part Number: MSP432P401R
Other Parts Discussed in Thread: ENERGYTRACE
I am using msp432 microcontroller for an application, the current consumption of the microcontroller is around 80mA, I think that a lot of current.
Incidentally, I have MSP432 red launchad with me, and I measured the resistance between Vcc and ground (image shown below), multimeter is showing 33 ohm. If we calculate the current from this it is 3.3V/33ohm  = 103mA. It this the correct way of measuring resistance and inferring current from it.
  • For measuring current consumption, I would instead recommend removing the jumper from the 3V3 (at the dotted silkscreen line) and using a multi-meter between the 2 terminals. That should directly give you current consumption, without the need of any further calculations.
  • Tapas,
     Measuring the resistance in this way is not the correct way of measuring current . To measure current, you should either use EnergyTrace+ from within Code Composer, or pull the jumper on J101 that connects the 3.3v supply to the MSP432 and connect the top and bottom pins to a multimeter as shown below. You should use a multimeter capable of measuring microAmps (μA range shown on the multimeter in the picture).
     If after setting up your measurement this way, you still find that you are reading 50mA+ of current, then this indicates your board may have suffered damage due to some kind of electrical overstress. (i.e. if you had accidentally connected 5V to the 3.3v supply). I would suggest comparing your measurements with another LaunchPad running the same code to confirm this.
      Bob L.
