I measured the Current on ISENA pin of DRV8300Q1 EVM, why it doesn't show negative half current. (the blue waveform is ISENA )
Hi Nimesh,
What do you have jumper J8 configured as?
the results you are getting may be unexpected due to what you have configured on your board.
Yara
The AREF jumper position on 1:2 previously, in both configuration the the negative half current is not getting sense can you explain me why it is happening please find the below attached waveform with both configurations.
Hi Nimesh,
Are you measuring voltage or current? I noticed the scale on the scope is voltage and not current?
Can you point out on your schematic where you are taking these measurements? Can you send waveforms from ISENA, ISENB, ISENC, and the phase current?
Can you please send waveforms from ISENA, ISENB, ISENC, and the phase current so I can better direct you to a resolution?
Yara
Hi Nimesh,
Have you solved your issue or are you able to provide the requested waveforms?
Yara
Hi Nimesh,
I am closing this thread. If you are still experiencing issues, please post your question with the requested waveforms.
Yara
