I'm a little confused on the DRV8436P data sheet.
Assume for the moment we have the xDECAY input driven low (smart tune enabled).
I'm assuming for DRV8436E that, at all times, smart tune chooses the optimal decay mode based on xEN duty cycle and xVREF (correct me if I'm wrong).
Furthermore, I'm assuming for DRV8436P if your driving either xIN1 or xIN2 high, smart tune again is choosing the optimal decay mode. So, this is essentially identical to the enable/phase control scheme with exception of 2x the required PWM inputs (again, correct me if I'm wrong).
Now, like most drivers with PWM control inputs, the truth table claims you can explicitly put the H-bridge in slow decay by driving both inputs high.
So, in this case, which takes precedent? If the user specifies slow decay by driving xIN1 and xIN2 high at the same duty cycle, does this override smart tune's choice of decay mode?
