Other Parts Discussed in Thread: TPS560430, LMR16006, LMR16006Y-Q1
We have a design which is using the TPS560430X3FDBVR voltage regulator and we need to do a production run of this design as soon as possible.
However this part number has a lead time of several months - which we cannot wait for.
Therefore we are planning create a variant of this design which will allow us to get this production run going whilst getting the same results.
Following discussions with the Chat support from TI, I found the LMR16006YQ3DDCRQ1 IC which seems to be pin compatible and outputs the same fixed voltage.
Therefore may I get a confirmation for the following:
- The TPS560430X3FDBVR and LMR16006YQ3DDCRQ1 are actually pin compatible with one another
- What changes are required to the surrounding passives if any. I have also attached the current PSU design with the TPS560430X3FDBVR IC
Please note that given the timeframes we are bound with we will not have enough time to prototype this modification which is why I'm asking for your help to ensure that we get this right first time.
