Other Parts Discussed in Thread: UC3856, UC2856
I would like to be able to disable the PWM comparator without discharging the soft start capacitor. I would like to implement this by pulling the COMP pin low in the same manner as current limit/soft start function is implemented as is shown in the block diagram. Is this acceptable? If so, are there any special considerations/caveats on how the COMP pin is pulled low - like minimum voltage limitations, etc.? I am planning on using the open collector output of a comparator (without a pull-up resistor) to perform this function.
Thank you very much for your time and help,
Bob Callanan
