Other Parts Discussed in Thread: LM337L
The output voltage of uA723 will drift with time, some chips become larger, some chips become smaller, and there will be small jitter when changing(Note: The width of the time axis is 12 hours, and the voltage changes between 200mV~300mV).
In addition, have confirmed that the board temperature is stable, and the voltage change is not caused by temperature.
At the same time, when the output voltage changes, the Vref voltage of uA723 is indeed changed.
The circuit is designed with reference to Figure 8. Negative Floating Regulator of uA723 datasheet
