Other Parts Discussed in Thread: TPS386040,
Hello Guys,
Good day.
Our customer found that the datasheet for the tps386000 has a bug. In the datasheet, Figure 31. TPS386040 Block Diagram has inverters at the four nRESET outputs. According to him, this is not correct as indicated by Tables 1-4. There should be no inverters there. For example, according to Table 2, when SENSE2 < V_ITN, the nRESET2 output is Low. However the block diagram indicates it should be High in this case, due to the inverter. So Tables 1-4 and Figure 31 contradict one another, and he believe it is Tables 1-4 that are correct.
Could you help to confirm this?
Thanks and regards,
Art
