Hi Sir,
may we know which operating temperature is the main one? because we measure the top side temperature up to 107 deg. any risk?
Hi Sir,
Hi Tommy,
The absolute maximum ratings are there to show that the device may fail if these values are exceeded.
The recommended operating junction temperature range is -40 to 105C and that is where our electrical characteristics are guaranteed:
To determine how hot the actual junction temperature is, You would need to use ψJT. The equation you would use is:
TJUNCTION=TCASE+ψJT.*Power
Where
TCASE is the temperature you measured
ψJT is from the thermal information:
And power is the total power dissipation within the IC.
Since you are measuring 107C, you are already running above the recommended operating temperature,
I hope this helps to answer your question.
