BQ78350-R1: TC bit not tripping even through valid charge termination conditions are met on one of two eval boards
Part Number: BQ78350-R1
I have two eval boards with identical GG files loaded, each with cells from the same manufacturer and lot.
On one of them, if I apply a charge voltage and meet the conditions for VCT as specified in the TRM, the Battery Status bits that are supposed to trip do trip.
On the other, achieving the same conditions, the TC bit will not trip and the battery keeps charging and won't update RSOC.
Both packs report charge currents under the taper current limit.
The only difference between the two is that the first pack's minimum cell voltage exceeds the charge termination voltage as well as its maximum cell voltage, while the second pack only has the maximum cell voltage above the threshold.
The TRM states that the maximum cell voltage is the one that matters.
Why is charge not terminating for the second pack?
  • Hi Greg,
    You are correct, the device should reach valid charge termination based on the highest cell. Can you share your device settings (click Export in the Data Memory screen of BQStudio) and capture a log file of this behavior (click on the Start Log button on the Registers screen).
    Matt
  • * Texas Instruments Data Flash File
    * File created Thu Jun 17 16:21:33 2021
    * Device Number 1E9B
    * Firmware Version 1.03
    * Build Number 22
    * Order Number 0
    * bqz Device Number 1E9B
    * bqz Firmware Version 1.03
    * bqz Build Number 22
    * Field Order: Class name, Subclass name, Parameter name, Parameter Value, Display Units
    "Calibration","Current","CC Gain","1.983","mOhm"
    "Calibration","Current","Capacity Gain","1.983","mOhm"
    "Calibration","Voltage","Cell1 Offset","9","mV"
    "Calibration","Voltage","Cell2 Offset","1","mV"
    "Calibration","Voltage","Cell3 Offset","4","mV"
    "Calibration","Voltage","Cell4 Offset","7","mV"
    "Calibration","Voltage","Cell5 Offset","6","mV"
    "Calibration","Voltage","Cell6 Offset","3","mV"
    "Calibration","Voltage","Cell7 Offset","10","mV"
    "Calibration","Voltage","Cell8 Offset","0","mV"
    "Calibration","Voltage","Cell9 Offset","0","mV"
    "Calibration","Voltage","Cell10 Offset","0","mV"
    "Calibration","Voltage","Cell11 Offset","0","mV"
    "Calibration","Voltage","Cell12 Offset","0","mV"
    "Calibration","Voltage","Cell13 Offset","0","mV"
    "Calibration","Voltage","Cell14 Offset","0","mV"
    "Calibration","Voltage","Cell15 Offset","0","mV"
    "Calibration","Current Offset","CC Offset","0","-"
    "Calibration","Current Offset","Coulomb Counter Offset Samples","64","-"
    "Calibration","Temperature","T1 Temp Offset","0","degC"
    "Calibration","Temperature","T2 Temp Offset","0","degC"
    "Calibration","Temperature","T3 Temp Offset","0","degC"
    "Calibration","Temperature","Gauge Internal Temp Offset","0","degC"
    "Calibration","Ext Cell Voltage","Ext Cell Divider Gain","5000","-"
    "Calibration","VAux Voltage","VAux Gain","5000","-"
    "Calibration","Cell Temperature Model","Coeff a1","-11130","-"
    "Calibration","Cell Temperature Model","Coeff a2","19142","-"
    "Calibration","Cell Temperature Model","Coeff a3","-19262","-"
    "Calibration","Cell Temperature Model","Coeff a4","28203","-"
    "Calibration","Cell Temperature Model","Coeff a5","892","-"
    "Calibration","Cell Temperature Model","Coeff b1","328","-"
    "Calibration","Cell Temperature Model","Coeff b2","-605","-"
    "Calibration","Cell Temperature Model","Coeff b3","-2443","-"
    "Calibration","Cell Temperature Model","Coeff b4","4696","-"
    "Calibration","Cell Temperature Model","Rc0","11703","-"
    "Calibration","Cell Temperature Model","Adc0","11703","-"
    "Calibration","Fet Temperature Model","Coeff a1","-11130","-"
    "Calibration","Fet Temperature Model","Coeff a2","19142","-"
    "Calibration","Fet Temperature Model","Coeff a3","-19262","-"
    "Calibration","Fet Temperature Model","Coeff a4","28203","-"
    "Calibration","Fet Temperature Model","Coeff a5","892","-"
    "Calibration","Fet Temperature Model","Coeff b1","328","-"
    "Calibration","Fet Temperature Model","Coeff b2","-605","-"
    "Calibration","Fet Temperature Model","Coeff b3","-2443","-"
    "Calibration","Fet Temperature Model","Coeff b4","4696","-"
    "Calibration","Fet Temperature Model","Rc0","11703","-"
    "Calibration","Fet Temperature Model","Adc0","11703","-"
    "Calibration","Fet Temperature Model","Rpad","0","-"
    "Calibration","Fet Temperature Model","Rint","18000","-"
    "Calibration","Current Deadband","Deadband","3","mA"
    "Calibration","Current Deadband","Coulomb Counter Deadband","38","264nV"
    "Settings","Protection","Protection Configuration","20","hex"
    "Settings","Protection","Enabled Protections A","ff","hex"
    "Settings","Protection","Enabled Protections B","7f","hex"
    "Settings","Protection","Enabled Protections C","15","hex"
    "Settings","Protection","Enabled Removal Recovery A","00","hex"
    "Settings","Protection","Enabled Removal Recovery B","00","hex"
    "Settings","Permanent Failure","Enabled PF A","00","hex"
    "Settings","Permanent Failure","Enabled PF B","00","hex"
    "Settings","Configuration","Temperature Enable","0b","hex"
    "Settings","Configuration","Temperature Mode","00","hex"
    "Settings","Configuration","DA Configuration","13","hex"
    "Settings","Configuration","AFE Cell Map","0277","hex"
    "Settings","Configuration","FET Options","003d","hex"
    "Settings","Configuration","Sbs Gauging Configuration","02","hex"
    "Settings","Configuration","Smb Configuration","a0","hex"
    "Settings","Configuration","Power Config","01","hex"
    "Settings","Configuration","LED Configuration","20","hex"
    "Settings","Configuration","SOC Flag Config","02fb","hex"
    "Settings","Configuration","Balancing Configuration","01","hex"
    "Settings","Configuration","CEDV Gauging Configuration","0092","hex"
    "Settings","Fuse","PF SAFE A","00","hex"
    "Settings","Fuse","PF SAFE B","00","hex"
    "Settings","Fuse","PF SAFE C","00","hex"
    "Settings","Fuse","Fuse Blow Timeout","30","s"
    "Settings","Aux SMB Address","Addr Reads","3","-"
    "Settings","Aux SMB Address","SMBTAR_ADDR0","20","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR1","22","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR2","24","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR3","25","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR4","26","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR5","28","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR6","2a","hex"
    "Settings","Aux SMB Address","SMBTAR_ADDR7","2c","hex"
    "Settings","SMB Master Mode","Host Address","10","hex"
    "Settings","SMB Master Mode","Charger Address","12","hex"
    "Settings","SMB Master Mode","Alarm Timer","10","s"
    "Settings","SMB Master Mode","Charger Request Timer","50","s"
    "Settings","Manufacturing","Mfg Status init","0030","hex"
    "Protections","CUV","Threshold","2500","mV"
    "Protections","CUV","Delay","2","s"
    "Protections","CUV","Recovery","2700","mV"
    "Protections","COV","Threshold","4300","mV"
    "Protections","COV","Delay","2","s"
    "Protections","COV","Recovery","4100","mV"
    "Protections","OCC","Threshold","1250","mA"
    "Protections","OCC","Delay","6","s"
    "Protections","OCC","Recovery Threshold","-100","mA"
    "Protections","OCC","Recovery Delay","5","s"
    "Protections","OCD","Threshold","-2500","mA"
    "Protections","OCD","Delay","6","s"
    "Protections","OCD","Recovery Threshold","100","mA"
    "Protections","OCD","Recovery Delay","5","s"
    "Protections","OCDL","Latch Limit","5","-"
    "Protections","OCDL","Counter Dec Delay","10","s"
    "Protections","OCDL","Reset","15","s"
    "Protections","AOLD","Latch Limit","0","-"
    "Protections","AOLD","Counter Dec Delay","10","s"
    "Protections","AOLD","Recovery","5","s"
    "Protections","AOLD","Reset","15","s"
    "Protections","AOLD","Threshold and Delay","00","hex"
    "Protections","ASCD","Latch Limit","0","-"
    "Protections","ASCD","Counter Dec Delay","10","s"
    "Protections","ASCD","Recovery","5","s"
    "Protections","ASCD","Reset","15","s"
    "Protections","ASCD","Threshold and Delay","00","hex"
    "Protections","OTC","Threshold","55.0","1degC"
    "Protections","OTC","Delay","2","s"
    "Protections","OTC","Recovery","50.0","1degC"
    "Protections","OTD","Threshold","60.0","1degC"
    "Protections","OTD","Delay","2","s"
    "Protections","OTD","Recovery","55.0","1degC"
    "Protections","OTF","Threshold","80.0","1degC"
    "Protections","OTF","Delay","2","s"
    "Protections","OTF","Recovery","65.0","1degC"
    "Protections","UTC","Threshold","0","1degC"
    "Protections","UTC","Delay","2","s"
    "Protections","UTC","Recovery","5.0","1degC"
    "Protections","UTD","Threshold","0","1degC"
    "Protections","UTD","Delay","2","s"
    "Protections","UTD","Recovery","5.0","1degC"
    "Protections","AFE External Override","Delay","5","s"
    "Protections","AFE External Override","Recovery","2","s"
    "Protections","PTO","Charge Threshold","500","mA"
    "Protections","PTO","Suspend Threshold","400","mA"
    "Protections","PTO","Delay","1800","s"
    "Protections","PTO","Reset","1","mAh"
    "Protections","CTO","Charge Threshold","1125","mA"
    "Protections","CTO","Suspend Threshold","1000","mA"
    "Protections","CTO","Delay","54000","s"
    "Protections","CTO","Reset","1","mAh"
    "Protections","OC","Threshold","150","mAh"
    "Protections","OC","Recovery","1","mAh"
    "Protections","OC","RSOC Recovery","90","%"
    "Permanent Fail","SOCC","Threshold","5000","mA"
    "Permanent Fail","SOCC","Delay","5","s"
    "Permanent Fail","SOCD","Threshold","-5000","mA"
    "Permanent Fail","SOCD","Delay","5","s"
    "Permanent Fail","SOT","Threshold","65.0","1degC"
    "Permanent Fail","SOT","Delay","5","s"
    "Permanent Fail","SOTF","Threshold","100.0","1degC"
    "Permanent Fail","SOTF","Delay","5","s"
    "Permanent Fail","Open Thermistor","Threshold","-50.0","1degC"
    "Permanent Fail","Open Thermistor","Delay","5","s"
    "Permanent Fail","VIMR","Check Voltage","3500","mV"
    "Permanent Fail","VIMR","Check Current","5","mA"
    "Permanent Fail","VIMR","Delta Threshold","500","mV"
    "Permanent Fail","VIMR","Delta Delay","5","s"
    "Permanent Fail","VIMR","Duration","100","s"
    "Permanent Fail","CFET","OFF Threshold","3","mA"
    "Permanent Fail","CFET","OFF Delay","5","s"
    "Permanent Fail","DFET","OFF Threshold","-3","mA"
    "Permanent Fail","DFET","OFF Delay","5","s"
    "Permanent Fail","AFER","Threshold","100","-"
    "Permanent Fail","AFER","Delay Period","2","s"
    "Permanent Fail","AFER","Compare Period","5","s"
    "Permanent Fail","AFEC","Threshold","100","-"
    "Permanent Fail","AFEC","Delay Period","5","s"
    "Permanent Fail","AFE XREADY","Threshold","100","-"
    "Permanent Fail","AFE XREADY","Delay Period","5","s"
    "Permanent Fail","AFE External Override","Delay","20","s"
    "Permanent Fail","AFE SOV / AFE SUV","SOV and SUV Delay","50","hex"
    "Permanent Fail","AFE SOV","Threshold","4350","mV"
    "Permanent Fail","AFE SUV","Threshold","1750","mV"
    "Charge Algorithm","Temperature Ranges","Charge Inhibit/Suspend Low Temp","0","degC"
    "Charge Algorithm","Temperature Ranges","Precharge Temp","12","degC"
    "Charge Algorithm","Temperature Ranges","Charge Inhibit High Temp","45","degC"
    "Charge Algorithm","Temperature Ranges","Charge Suspsend High Temp","55","degC"
    "Charge Algorithm","Temperature Ranges","Hysteresis Temp","3","degC"
    "Charge Algorithm","Fast Charging","Voltage","4125","mV"
    "Charge Algorithm","Fast Charging","Current","1000","mA"
    "Charge Algorithm","Pre-Charging","Current","50","mA"
    "Charge Algorithm","Pre-Charging","Start Voltage","2500","mV"
    "Charge Algorithm","Pre-Charging","Recovery Voltage","2900","mV"
    "Charge Algorithm","Termination Config","Charge Term Taper Current","25","mA"
    "Charge Algorithm","Termination Config","Charge Term Voltage","75","mV"
    "Charge Algorithm","Cell Balancing Config","Cell Balance Threshold","3800","mV"
    "Charge Algorithm","Cell Balancing Config","Cell Balance Window","100","mV"
    "Charge Algorithm","Cell Balancing Config","Cell Balance Min","40","mV"
    "Charge Algorithm","Cell Balancing Config","Cell Balance Interval","20","s"
    "Fuel Gauging","Current Thresholds","Dsg Current Threshold","50","mA"
    "Fuel Gauging","Current Thresholds","Chg Current Threshold","10","mA"
    "Fuel Gauging","Current Thresholds","Quit Current","5","mA"
    "Fuel Gauging","Current Thresholds","Dsg Relax Time","1","s"
    "Fuel Gauging","Current Thresholds","Chg Relax Time","120","s"
    "Fuel Gauging","Design","Design Capacity mAh","1667","mAh"
    "Fuel Gauging","Design","Design Capacity cWh","32767","cWh"
    "Fuel Gauging","Design","Design Voltage","3600","mV"
    "Fuel Gauging","Cycle","Cycle Count Percentage","90","%"
    "Fuel Gauging","FD","Set % RSOC Threshold","0","%"
    "Fuel Gauging","FD","Clear % RSOC Threshold","5","%"
    "Fuel Gauging","FC","Set % RSOC Threshold","100","%"
    "Fuel Gauging","FC","Clear % RSOC Threshold","95","%"
    "Fuel Gauging","TD","Set % RSOC Threshold","6","%"
    "Fuel Gauging","TD","Clear % RSOC Threshold","8","%"
    "Fuel Gauging","TC","Set % RSOC Threshold","100","%"
    "Fuel Gauging","TC","Clear % RSOC Threshold","95","%"
    "Fuel Gauging","State","Cycle Count","4100","-"
    "Fuel Gauging","State","Learned Full Charge Capacity","2480","mAh"
    "Fuel Gauging","State","Dod at EDV2","9667","-"
    "Fuel Gauging","CEDV cfg","EMF","3850","-"
    "Fuel Gauging","CEDV cfg","C0","235","-"
    "Fuel Gauging","CEDV cfg","R0","1783","-"
    "Fuel Gauging","CEDV cfg","T0","4475","-"
    "Fuel Gauging","CEDV cfg","R1","250","-"
    "Fuel Gauging","CEDV cfg","TC","3","-"
    "Fuel Gauging","CEDV cfg","C1","0","-"
    "Fuel Gauging","CEDV cfg","Age Factor","0","-"
    "Fuel Gauging","CEDV cfg","Fixed EDV 0","2552","-"
    "Fuel Gauging","CEDV cfg","EDV 0 Hold Time","1","s"
    "Fuel Gauging","CEDV cfg","Fixed EDV 1","2856","-"
    "Fuel Gauging","CEDV cfg","EDV 1 Hold Time","1","s"
    "Fuel Gauging","CEDV cfg","Fixed EDV 2","3057","-"
    "Fuel Gauging","CEDV cfg","EDV 2 Hold Time","1","s"
    "Fuel Gauging","CEDV cfg","Battery Low %","7.00","%"
    "Fuel Gauging","CEDV cfg","Min Delta V Filter","10","mV"
    "Fuel Gauging","CEDV cfg","FCC Learn Up","256","mAh"
    "Fuel Gauging","CEDV cfg","FCC Learn Down","128","mAh"
    "Fuel Gauging","CEDV cfg","Learning Low Temp","119","0.1degC"
    "Fuel Gauging","CEDV cfg","Requested Learning cycle count","20","num"
    "Fuel Gauging","CEDV cfg","OverLoad Current","2500","mA"
    "Fuel Gauging","CEDV cfg","Self Discharge Rate","20","0.01%/day"
    "Fuel Gauging","CEDV cfg","Electronics Load","0","3uA"
    "Fuel Gauging","CEDV cfg","Near Full","100","mAh"
    "Fuel Gauging","CEDV cfg","Reserve Capacity","0","mAh"
    "Fuel Gauging","CEDV cfg","RemCap Init Percent","100","%"
    "Power","Power","Valid Update Voltage","3500","mV"
    "Power","Shutdown","Shutdown Voltage","1750","mV"
    "Power","Shutdown","Shutdown Time","10","s"
    "Power","Shutdown","PF Shutdown Voltage","1750","mV"
    "Power","Shutdown","PF Shutdown Time","10","s"
    "Power","Shutdown","Charger Present Threshold","3000","mV"
    "Power","Sleep","Sleep Current","5","mA"
    "Power","Sleep","Bus Timeout","5","s"
    "Power","Sleep","Voltage Time","5","s"
    "Power","Sleep","Current Time","20","s"
    "Power","Ship","FET Off Time","10","s"
    "Power","Ship","Delay","20","s"
    "Power","Ship","Auto Ship Time","1440","min"
    "Power","KEYIN","Time","2","s"
    "PF Status","Device Status Data","Safety Alert A","00","hex"
    "PF Status","Device Status Data","Safety Status A","00","hex"
    "PF Status","Device Status Data","Safety Alert B","00","hex"
    "PF Status","Device Status Data","Safety Status B","00","hex"
    "PF Status","Device Status Data","Safety Alert C","00","hex"
    "PF Status","Device Status Data","Safety Status C","00","hex"
    "PF Status","Device Status Data","PF Alert A","00","hex"
    "PF Status","Device Status Data","PF Status A","00","hex"
    "PF Status","Device Status Data","PF Alert B","00","hex"
    "PF Status","Device Status Data","PF Status B","00","hex"
    "PF Status","Device Status Data","PF Alert C","00","hex"
    "PF Status","Device Status Data","PF Status C","00","hex"
    "PF Status","Device Status Data","Fuse Flag","0000","hex"
    "PF Status","Device Status Data","Operation Status A","0000","hex"
    "PF Status","Device Status Data","Operation Status B","0000","hex"
    "PF Status","Device Status Data","Temp Range","00","hex"
    "PF Status","Device Status Data","Charging Status","00","hex"
    "PF Status","Device Status Data","Gauging Status","00","hex"
    "PF Status","Device Status Data","CEDV Status","00","hex"
    "PF Status","Device Voltage Data","Cell 1 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 2 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 3 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 4 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 5 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 6 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 7 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 8 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 9 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 10 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 11 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 12 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 13 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 14 Voltage","0","mV"
    "PF Status","Device Voltage Data","Cell 15 Voltage","0","mV"
    "PF Status","Device Voltage Data","Battery Direct Voltage","0","mV"
    "PF Status","Device Current Data","Current","0","mA"
    "PF Status","Device Temperature Data","TS1 Temperature","-273.2","degC"
    "PF Status","Device Temperature Data","TS2 Temperature","-273.2","degC"
    "PF Status","Device Temperature Data","TS3 Temperature","-273.2","degC"
    "PF Status","Device Temperature Data","Gauge Internal Temperature","-273.2","degC"
    "PF Status","AFE Regs","AFE SYS Stat","00","hex"
    "PF Status","AFE Regs","AFE Cell Balance1","00","hex"
    "PF Status","AFE Regs","AFE Cell Balance2","00","hex"
    "PF Status","AFE Regs","AFE Cell Balance3","00","hex"
    "PF Status","AFE Regs","AFE Sys Control1","00","hex"
    "PF Status","AFE Regs","AFE Sys Control2","00","hex"
    "PF Status","AFE Regs","AFE Protection1","00","hex"
    "PF Status","AFE Regs","AFE Protection2","00","hex"
    "PF Status","AFE Regs","AFE Protection3","00","hex"
    "PF Status","AFE Regs","AFE OV Trip","00","hex"
    "PF Status","AFE Regs","AFE UV Trip","00","hex"
    "Black Box","Safety Status","1st Status Status A","00","hex"
    "Black Box","Safety Status","1st Status Status B","00","hex"
    "Black Box","Safety Status","1st Safety Status C","00","hex"
    "Black Box","Safety Status","1st Time to Next Event","0","s"
    "Black Box","Safety Status","2nd Status Status A","00","hex"
    "Black Box","Safety Status","2nd Status Status B","00","hex"
    "Black Box","Safety Status","2nd Safety Status C","00","hex"
    "Black Box","Safety Status","2nd Time to Next Event","0","s"
    "Black Box","Safety Status","3rd Status Status A","00","hex"
    "Black Box","Safety Status","3rd Status Status B","00","hex"
    "Black Box","Safety Status","3rd Safety Status C","00","hex"
    "Black Box","Safety Status","3rd Time to Next Event","0","s"
    "Black Box","PF Status","1st PF Status A","00","hex"
    "Black Box","PF Status","1st PF Status B","00","hex"
    "Black Box","PF Status","1st PF Status C","00","hex"
    "Black Box","PF Status","1st Time to Next Event","0","s"
    "Black Box","PF Status","2nd PF Status A","00","hex"
    "Black Box","PF Status","2nd PF Status B","00","hex"
    "Black Box","PF Status","2nd PF Status C","00","hex"
    "Black Box","PF Status","2nd Time to Next Event","0","s"
    "Black Box","PF Status","3rd PF Status A","00","hex"
    "Black Box","PF Status","3rd PF Status B","00","hex"
    "Black Box","PF Status","3rd PF Status C","00","hex"
    "Black Box","PF Status","3rd Time to Next Event","0","s"
    "System Data","Manufacturer Data","Manufacturer Info A Length","32","-"
    "System Data","Manufacturer Data","Manufacturer Info Block A01","61","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A02","62","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A03","63","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A04","64","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A05","65","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A06","66","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A07","67","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A08","68","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A09","69","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A10","6a","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A11","6b","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A12","6c","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A13","6d","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A14","6e","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A15","6f","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A16","70","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A17","71","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A18","72","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A19","73","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A20","74","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A21","75","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A22","76","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A23","77","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A24","7a","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A25","78","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A26","79","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A27","30","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A28","31","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A29","32","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A30","33","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A31","34","Hex"
    "System Data","Manufacturer Data","Manufacturer Info Block A32","35","Hex"
    "SBS Configuration","Data","Remaining AH Cap. Alarm","150","mAh"
    "SBS Configuration","Data","Remaining WH Cap. Alarm","217","cWh"
    "SBS Configuration","Data","Remaining Time Alarm","10","min"
    "SBS Configuration","Data","Initial Battery Mode","0081","hex"
    "SBS Configuration","Data","Specification Information","0031","hex"
    "SBS Configuration","Data","Manufacture Date","1980-1-1","date"
    "SBS Configuration","Data","Serial Number","0001","hex"
    "SBS Configuration","Data","Manufacturer Name","Texas Instruments","-"
    "SBS Configuration","Data","Device Name","bq78350","-"
    "SBS Configuration","Data","Device Chemistry","LION","-"
    "LED Support","LED Config","LED Flash Period","512","488us"
    "LED Support","LED Config","LED Blink Period","1024","488us"
    "LED Support","LED Config","LED Delay","100","488us"
    "LED Support","LED Config","LED Hold Time","4","s"
    "LED Support","LED Config","LED Flash Alarm","10","%"
    "LED Support","LED Config","LED Thresh 1","0","%"
    "LED Support","LED Config","LED Thresh 2","20","%"
    "LED Support","LED Config","LED Thresh 3","40","%"
    "LED Support","LED Config","LED Thresh 4","60","%"
    "LED Support","LED Config","LED Thresh 5","80","%"
    "LED Support","LED Config","LCD Refresh Rate","35","Hz"
    "Lifetimes","Voltage","Cell 1 Max Voltage","4221","mV"
    "Lifetimes","Voltage","Cell 2 Max Voltage","4221","mV"
    "Lifetimes","Voltage","Cell 3 Max Voltage","4222","mV"
    "Lifetimes","Voltage","Cell 4 Max Voltage","4224","mV"
    "Lifetimes","Voltage","Cell 5 Max Voltage","4219","mV"
    "Lifetimes","Voltage","Cell 6 Max Voltage","4231","mV"
    "Lifetimes","Voltage","Cell 7 Max Voltage","4228","mV"
    "Lifetimes","Voltage","Cell 8 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 9 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 10 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 11 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 12 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 13 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 14 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 15 Max Voltage","0","mV"
    "Lifetimes","Voltage","Cell 1 Min Voltage","913","mV"
    "Lifetimes","Voltage","Cell 2 Min Voltage","500","mV"
    "Lifetimes","Voltage","Cell 3 Min Voltage","911","mV"
    "Lifetimes","Voltage","Cell 4 Min Voltage","914","mV"
    "Lifetimes","Voltage","Cell 5 Min Voltage","1214","mV"
    "Lifetimes","Voltage","Cell 6 Min Voltage","1056","mV"
    "Lifetimes","Voltage","Cell 7 Min Voltage","344","mV"
    "Lifetimes","Voltage","Cell 8 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 9 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 10 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 11 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 12 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 13 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 14 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Cell 15 Min Voltage","32767","mV"
    "Lifetimes","Voltage","Max Delta Cell Voltage","1102","mV"
    "Lifetimes","Current","Max Charge Current","1089","mA"
    "Lifetimes","Current","Max Discharge Current","-1003","mA"
    "Lifetimes","Current","Max Avg Dsg Current","-1000","mA"
    "Lifetimes","Current","Max Avg Dsg Power","-2814","cW"
    "Lifetimes","Temperature","Max Temp Cell","127","degC"
    "Lifetimes","Temperature","Min Temp Cell","20","degC"
    "Lifetimes","Temperature","Max Delta Cell Temp","127","degC"
    "Lifetimes","Temperature","Max Temp Fet","-128","degC"
    "Lifetimes","Gauge Temperature","Max Temp Int Sensor","35","degC"
    "Lifetimes","Gauge Temperature","Min Temp Int Sensor","-47","degC"
    "Lifetimes","Safety Events","No Of COV Events","0","events"
    "Lifetimes","Safety Events","Last COV Event","0","cycles"
    "Lifetimes","Safety Events","No Of CUV Events","26","events"
    "Lifetimes","Safety Events","Last CUV Event","4099","cycles"
    "Lifetimes","Safety Events","No Of OCD Events","0","events"
    "Lifetimes","Safety Events","Last OCD Event","0","cycles"
    "Lifetimes","Safety Events","No Of OCC Events","0","events"
    "Lifetimes","Safety Events","Last OCC Event","0","cycles"
    "Lifetimes","Safety Events","No Of AOLD Events","0","events"
    "Lifetimes","Safety Events","Last AOLD Event","0","cycles"
    "Lifetimes","Safety Events","No Of ASCD Events","0","events"
    "Lifetimes","Safety Events","Last ASCD Event","0","cycles"
    "Lifetimes","Safety Events","No Of OTC Events","0","events"
    "Lifetimes","Safety Events","Last OTC Event","0","cycles"
    "Lifetimes","Safety Events","No Of OTD Events","0","events"
    "Lifetimes","Safety Events","Last OTD Event","0","cycles"
    "Lifetimes","Safety Events","No Of OTF Events","0","events"
    "Lifetimes","Safety Events","Last OTF Event","0","cycles"
    "Lifetimes","Charging Events","No Valid Charge Term","3","events"
    "Lifetimes","Charging Events","Last Valid Charge Term","4098","cycles"
    "Lifetimes","Gauging Events","No of FCC Updates","4","events"
    "Lifetimes","Gauging Events","Last FCC Update","4099","cycles"
    "Lifetimes","Power Events","No Of Shutdowns","18","events"
    "Lifetimes","Cell Balancing","Cb Time Cell 1","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 2","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 3","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 4","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 5","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 6","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 7","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 8","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 9","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 10","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 11","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 12","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 13","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 14","0","h"
    "Lifetimes","Cell Balancing","Cb Time Cell 15","0","h"
    "Lifetimes","Time","Total Fw Runtime","340","h"
    "Lifetimes","Time","Time Spent In UT","0","h"
    "Lifetimes","Time","Time Spent In LT","0","h"
    "Lifetimes","Time","Time Spent In ST","340","h"
    "Lifetimes","Time","Time Spent In HT","0","h"
    "Lifetimes","Time","Time Spent In OT","0","h"
    "Lifetimes","Time","Time Since Last Charge","0","h"
    "GPIO","GPIO Config","GPIO Configuration","00","hex"
    "GPIO","GPIO Config","GPIO Ouput Enable","00","hex"
    "GPIO","GPIO Config","GPIO Default Ouput Enable","00","hex"
    "GPIO","GPIO Config","GPIO Type","c0","hex"
    Our log files are in a proprietary format that I can't share, but have I have included the GG file.
    I also have confirmation that the second pack will terminate charge if the minimum cell voltage is above (fast charging voltage) plus (charge term voltage) but not if only the max cell voltage is above that threshold.
  • Hi Greg,
    I understand about the log files. Is there a way you can collect the standard BQStudio log file during the end of charge? It is a little difficult to analyze without seeing the behavior along with the details of the different registers. Is it possible it looks like the minimum cell voltage is the trigger based on the delay time (it takes 2 consecutive 40s windows where the conditions are met to get valid charge termination).
    This other thread might be helpful too. This user observe some delays in the charge detection: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/721301/bq78350-r1-valid-charge-termination---which-are-exactly-the-conditions-to-met-it
    Matt
  • I have a standard log that terminated properly, but no standard log of the failing test, unfortunately.
    Thu Jul 01 16:06:42 EDT 2021
    Device Name = bq78350_R1
    Firmware Version = V1_03_BLD0022
    Design Capacity = 1667
    Design Voltage = 3600
    Specification Info = 0x0031
    Manufacturer Date = 1980-1-1
    Serial Number = 0x0001
    Manufacturer Name = Texas Instruments
    Device Chemistry = LION
    Sample,DateTime,ElapsedTime,ManufAccess,RemCapAlarm,RemTimeAlarm,BattMode,@Rate(@),@TimeFull,@TimeEmpty,@RateOK,Temperature,Voltage,Current,AvgCurr,MaxErr,RSOC,ASOC,RemCap,FullChgCap,RunTimeEmty,RunTimeEmty,AvgTimeFull,ChgCurr,ChgVolt,BattStat,CycleCnt,PendingEdv,SoH,OpStatA,OpStatB,TempRange,ChgStat,GaugeStat,MfgStat,SafetyAlertAB,SafetyStatAB,SafetyAlertCD,SafetyStatCD,PFAlertAB,PFStatAB,PFStatAB,CellVolt1,CellVolt2,CellVolt3,CellVolt4,CellVolt5,CellVolt6,CellVolt7,CellVolt8,CellVolt9,CellVolt10,CellVolt11,CellVolt12,CellVolt13,CellVolt14,CellVolt15,ExtAvgCellVolt,TS1 Temp,TS2 Temp,TS3 Temp,CellTemp,FetTemp,GaugeInternalTemp,LogRowTime(ms),LogStatus
    1,2021-07-01 16:06:47,4.005,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21599,514,433,8,1,1,3,2352,65535,65535,396,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3089,3089,3071,3090,3077,3091,3104,0,0,0,0,0,0,0,0,2385,23.5,23.7,-273.2,23.7,-273.2,32.9,997,SUCCESS
    2,2021-07-01 16:06:51,8.013,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21663,514,452,8,1,1,4,2352,65535,65535,382,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3099,3098,3080,3099,3086,3099,3112,0,0,0,0,0,0,0,0,2395,23.5,23.7,-273.2,23.7,-273.2,32.8,1057,SUCCESS
    3,2021-07-01 16:06:55,12.028,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21720,514,467,8,1,1,4,2352,65535,65535,373,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3108,3106,3089,3106,3095,3107,3121,0,0,0,0,0,0,0,0,2400,23.5,23.7,-273.2,23.7,-273.2,32.8,1021,SUCCESS
    4,2021-07-01 16:06:59,16.032,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21776,515,478,8,1,1,5,2352,65535,65535,366,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3116,3114,3097,3114,3103,3115,3129,0,0,0,0,0,0,0,0,2405,23.5,23.7,-273.2,23.7,-273.2,32.9,1054,SUCCESS
    5,2021-07-01 16:07:03,20.041,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21832,514,487,8,1,1,5,2352,65535,65535,360,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3124,3121,3104,3121,3111,3122,3136,0,0,0,0,0,0,0,0,2410,23.5,23.7,-273.2,23.7,-273.2,32.9,992,SUCCESS
    6,2021-07-01 16:07:07,24.055,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21882,514,493,8,1,1,6,2352,65535,65535,357,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3131,3128,3112,3128,3118,3130,3143,0,0,0,0,0,0,0,0,2415,23.5,23.7,-273.2,23.7,-273.2,32.8,1032,SUCCESS
    7,2021-07-01 16:07:11,28.068,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21930,514,498,8,1,1,7,2352,65535,65535,354,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3137,3135,3120,3135,3125,3136,3149,0,0,0,0,0,0,0,0,2425,23.5,23.7,-273.2,23.7,-273.2,32.9,1044,SUCCESS
    8,2021-07-01 16:07:15,32.076,0x0701,150,10,0x6001,0,65535,65535,1,23.7,21978,514,502,8,1,1,7,2352,65535,65535,352,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3145,3142,3127,3141,3132,3142,3156,0,0,0,0,0,0,0,0,2429,23.5,23.7,-273.2,23.7,-273.2,32.9,990,SUCCESS
    9,2021-07-01 16:07:19,36.087,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22020,514,505,8,1,1,8,2352,65535,65535,350,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3151,3148,3134,3148,3138,3148,3162,0,0,0,0,0,0,0,0,2434,23.5,23.7,-273.2,23.7,-273.2,32.9,1041,SUCCESS
    10,2021-07-01 16:07:23,40.094,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22064,514,507,8,1,1,8,2352,65535,65535,349,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3157,3154,3139,3154,3145,3154,3168,0,0,0,0,0,0,0,0,2435,23.5,23.7,-273.2,23.7,-273.2,32.8,1038,SUCCESS
    11,2021-07-01 16:07:27,44.107,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22102,514,509,8,1,1,9,2352,65535,65535,348,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3163,3159,3145,3159,3150,3161,3174,0,0,0,0,0,0,0,0,2440,23.5,23.7,-273.2,23.7,-273.2,32.9,1004,SUCCESS
    12,2021-07-01 16:07:31,48.118,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22143,514,510,8,1,1,9,2352,65535,65535,347,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3168,3165,3151,3165,3156,3166,3180,0,0,0,0,0,0,0,0,2445,23.6,23.7,-273.2,23.7,-273.2,32.8,1030,SUCCESS
    13,2021-07-01 16:07:35,52.132,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22183,514,511,8,1,1,10,2352,65535,65535,346,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3174,3171,3157,3170,3161,3171,3185,0,0,0,0,0,0,0,0,2450,23.6,23.7,-273.2,23.7,-273.2,32.8,994,SUCCESS
    14,2021-07-01 16:07:39,56.135,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22220,514,512,8,1,1,11,2352,65535,65535,346,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3180,3176,3162,3175,3167,3177,3190,0,0,0,0,0,0,0,0,2455,23.6,23.7,-273.2,23.7,-273.2,32.9,1044,SUCCESS
    15,2021-07-01 16:07:43,60.147,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22258,514,512,8,1,1,11,2352,65535,65535,346,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3185,3181,3167,3180,3171,3182,3194,0,0,0,0,0,0,0,0,2460,23.6,23.7,-273.2,23.7,-273.2,32.8,996,SUCCESS
    16,2021-07-01 16:07:47,64.161,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22292,514,513,8,1,1,12,2352,65535,65535,345,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3190,3186,3172,3185,3176,3186,3200,0,0,0,0,0,0,0,0,2460,23.6,23.7,-273.2,23.7,-273.2,32.8,1015,SUCCESS
    17,2021-07-01 16:07:51,68.171,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22323,514,513,8,1,1,12,2352,65535,65535,345,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3195,3191,3178,3191,3182,3191,3204,0,0,0,0,0,0,0,0,2465,23.6,23.7,-273.2,23.7,-273.2,32.9,1101,SUCCESS
    18,2021-07-01 16:07:55,72.177,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22356,514,513,8,1,1,13,2352,65535,65535,345,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3200,3195,3182,3195,3186,3196,3208,0,0,0,0,0,0,0,0,2470,23.6,23.7,-273.2,23.7,-273.2,32.9,981,SUCCESS
    19,2021-07-01 16:07:59,76.180,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22389,513,513,8,1,1,14,2352,65535,65535,345,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3205,3200,3188,3198,3191,3200,3213,0,0,0,0,0,0,0,0,2475,23.6,23.7,-273.2,23.7,-273.2,32.4,1046,SUCCESS
    20,2021-07-01 16:08:03,80.182,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22419,514,513,8,1,1,14,2352,65535,65535,345,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3209,3203,3191,3203,3195,3204,3218,0,0,0,0,0,0,0,0,2475,23.6,23.7,-273.2,23.7,-273.2,32.9,977,SUCCESS
    21,2021-07-01 16:08:07,84.194,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22448,514,514,8,1,1,15,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3214,3208,3195,3207,3200,3208,3222,0,0,0,0,0,0,0,0,2480,23.6,23.7,-273.2,23.7,-273.2,32.9,1091,SUCCESS
    22,2021-07-01 16:08:11,88.205,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22476,514,514,8,1,1,15,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3217,3212,3200,3213,3204,3213,3225,0,0,0,0,0,0,0,0,2485,23.6,23.7,-273.2,23.7,-273.2,32.8,1084,SUCCESS
    23,2021-07-01 16:08:15,92.216,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22503,513,514,8,1,1,16,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3221,3216,3204,3215,3207,3216,3228,0,0,0,0,0,0,0,0,2489,23.6,23.7,-273.2,23.7,-273.2,32.8,1113,SUCCESS
    24,2021-07-01 16:08:19,96.231,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22531,514,514,8,1,1,16,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3225,3222,3208,3219,3212,3220,3233,0,0,0,0,0,0,0,0,2490,23.6,23.7,-273.2,23.7,-273.2,32.9,1037,SUCCESS
    25,2021-07-01 16:08:23,100.234,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22558,514,514,8,1,2,17,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3229,3223,3212,3223,3216,3224,3237,0,0,0,0,0,0,0,0,2490,23.6,23.7,-273.2,23.7,-273.2,33.0,946,SUCCESS
    26,2021-07-01 16:08:27,104.238,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22587,513,514,8,1,2,18,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3233,3227,3215,3227,3220,3227,3240,0,0,0,0,0,0,0,0,2495,23.6,23.7,-273.2,23.7,-273.2,32.9,1097,SUCCESS
    27,2021-07-01 16:08:31,108.247,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22612,514,514,8,1,2,18,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3236,3231,3219,3230,3223,3231,3244,0,0,0,0,0,0,0,0,2500,23.6,23.7,-273.2,23.7,-273.2,32.9,1082,SUCCESS
    28,2021-07-01 16:08:35,112.262,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22637,514,514,8,1,2,19,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3240,3234,3223,3234,3226,3235,3248,0,0,0,0,0,0,0,0,2500,23.6,23.7,-273.2,23.7,-273.2,32.9,989,SUCCESS
    29,2021-07-01 16:08:39,116.264,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22661,514,514,8,1,2,19,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3244,3238,3227,3237,3231,3238,3251,0,0,0,0,0,0,0,0,2505,23.6,23.7,-273.2,23.7,-273.2,32.9,1005,SUCCESS
    30,2021-07-01 16:08:43,120.276,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22686,514,514,8,1,2,20,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3247,3241,3230,3241,3234,3242,3255,0,0,0,0,0,0,0,0,2505,23.6,23.7,-273.2,23.7,-273.2,32.9,1021,SUCCESS
    31,2021-07-01 16:08:47,124.280,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22711,513,514,8,1,2,20,2352,65535,65535,344,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3251,3245,3234,3244,3237,3245,3258,0,0,0,0,0,0,0,0,2510,23.6,23.7,-273.2,23.7,-273.2,33.0,1086,SUCCESS
    32,2021-07-01 16:08:51,128.298,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22735,514,514,8,1,2,21,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3254,3248,3237,3248,3240,3249,3261,0,0,0,0,0,0,0,0,2510,23.6,23.7,-273.2,23.7,-273.2,32.9,1017,SUCCESS
    33,2021-07-01 16:08:55,132.298,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22757,514,514,8,1,2,22,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3258,3252,3241,3251,3244,3252,3265,0,0,0,0,0,0,0,0,2515,23.6,23.7,-273.2,23.7,-273.2,33.0,1046,SUCCESS
    34,2021-07-01 16:08:59,136.302,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22779,513,514,8,1,2,22,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3261,3255,3244,3254,3247,3255,3268,0,0,0,0,0,0,0,0,2515,23.6,23.7,-273.2,23.7,-273.2,32.9,1013,SUCCESS
    35,2021-07-01 16:09:03,140.304,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22804,513,514,8,1,2,23,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3265,3258,3248,3258,3250,3259,3272,0,0,0,0,0,0,0,0,2520,23.6,23.7,-273.2,23.7,-273.2,32.7,1031,SUCCESS
    36,2021-07-01 16:09:07,144.304,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22825,513,514,8,1,2,23,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3268,3261,3251,3261,3253,3262,3274,0,0,0,0,0,0,0,0,2520,23.6,23.7,-273.2,23.7,-273.2,32.8,999,SUCCESS
    37,2021-07-01 16:09:11,148.306,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22847,513,514,8,2,2,24,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3271,3264,3254,3264,3256,3265,3277,0,0,0,0,0,0,0,0,2525,23.6,23.7,-273.2,23.7,-273.2,33.0,1061,SUCCESS
    38,2021-07-01 16:09:15,152.320,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22869,514,514,8,2,2,24,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3274,3267,3257,3267,3260,3268,3281,0,0,0,0,0,0,0,0,2525,23.6,23.7,-273.2,23.7,-273.2,32.9,969,SUCCESS
    39,2021-07-01 16:09:19,156.334,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22891,514,514,8,2,2,25,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3277,3270,3260,3270,3263,3270,3284,0,0,0,0,0,0,0,0,2530,23.6,23.7,-273.2,23.7,-273.2,32.9,1058,SUCCESS
    40,2021-07-01 16:09:23,160.340,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22912,514,514,8,2,2,26,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3280,3273,3263,3273,3266,3273,3287,0,0,0,0,0,0,0,0,2530,23.6,23.7,-273.2,23.7,-273.2,32.7,992,SUCCESS
    41,2021-07-01 16:09:27,164.346,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22932,514,514,8,2,2,26,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3283,3276,3266,3276,3269,3276,3289,0,0,0,0,0,0,0,0,2534,23.6,23.7,-273.2,23.7,-273.2,32.9,1047,SUCCESS
    42,2021-07-01 16:09:31,168.348,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22952,514,514,8,2,2,27,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3286,3279,3269,3278,3271,3279,3292,0,0,0,0,0,0,0,0,2535,23.6,23.7,-273.2,23.7,-273.2,32.9,1044,SUCCESS
    43,2021-07-01 16:09:35,172.352,0x0701,150,10,0x6001,0,65535,65535,1,23.7,22973,514,514,8,2,2,27,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3288,3282,3272,3281,3274,3282,3295,0,0,0,0,0,0,0,0,2535,23.6,23.8,-273.2,23.7,-273.2,32.9,1062,SUCCESS
    44,2021-07-01 16:09:39,176.359,0x0701,150,10,0x6001,0,65535,65535,1,23.8,22992,514,514,8,2,2,28,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3292,3285,3275,3284,3277,3285,3298,0,0,0,0,0,0,0,0,2540,23.6,23.8,-273.2,23.8,-273.2,32.9,1050,SUCCESS
    45,2021-07-01 16:09:43,180.364,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23012,514,514,8,2,2,28,2352,65535,65535,343,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3294,3287,3278,3287,3280,3288,3301,0,0,0,0,0,0,0,0,2540,23.6,23.8,-273.2,23.8,-273.2,32.4,1114,SUCCESS
    46,2021-07-01 16:09:47,184.379,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23031,515,514,8,2,2,29,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3297,3290,3281,3290,3283,3290,3303,0,0,0,0,0,0,0,0,2545,23.6,23.8,-273.2,23.8,-273.2,32.9,1123,SUCCESS
    47,2021-07-01 16:09:51,188.393,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23049,515,514,8,2,2,29,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3300,3293,3284,3292,3285,3293,3305,0,0,0,0,0,0,0,0,2545,23.6,23.8,-273.2,23.8,-273.2,32.9,1095,SUCCESS
    48,2021-07-01 16:09:55,192.396,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23068,514,514,8,2,2,30,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3303,3295,3287,3295,3288,3295,3309,0,0,0,0,0,0,0,0,2545,23.6,23.8,-273.2,23.8,-273.2,33.0,1000,SUCCESS
    49,2021-07-01 16:09:59,196.401,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23085,515,514,8,2,2,31,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3305,3298,3289,3297,3291,3298,3311,0,0,0,0,0,0,0,0,2550,23.6,23.8,-273.2,23.8,-273.2,33.0,1007,SUCCESS
    50,2021-07-01 16:10:03,200.416,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23104,514,514,8,2,2,31,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3308,3301,3292,3300,3294,3301,3314,0,0,0,0,0,0,0,0,2550,23.6,23.8,-273.2,23.8,-273.2,32.6,1013,SUCCESS
    51,2021-07-01 16:10:07,204.424,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23123,514,514,8,2,2,32,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3311,3303,3294,3302,3296,3303,3316,0,0,0,0,0,0,0,0,2555,23.6,23.8,-273.2,23.8,-273.2,33.0,1018,SUCCESS
    52,2021-07-01 16:10:11,208.437,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23139,513,514,8,2,2,32,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3313,3305,3297,3305,3298,3306,3318,0,0,0,0,0,0,0,0,2555,23.6,23.8,-273.2,23.8,-273.2,33.0,987,SUCCESS
    53,2021-07-01 16:10:15,212.446,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23156,514,514,8,2,2,33,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3315,3308,3299,3307,3301,3308,3321,0,0,0,0,0,0,0,0,2555,23.6,23.8,-273.2,23.8,-273.2,33.0,1151,SUCCESS
    54,2021-07-01 16:10:19,216.457,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23174,514,514,8,2,2,33,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3318,3310,3302,3309,3303,3310,3323,0,0,0,0,0,0,0,0,2560,23.6,23.8,-273.2,23.8,-273.2,32.9,1018,SUCCESS
    55,2021-07-01 16:10:23,220.466,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23190,514,514,8,2,3,34,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3320,3312,3304,3312,3306,3313,3325,0,0,0,0,0,0,0,0,2560,23.6,23.8,-273.2,23.8,-273.2,33.0,1022,SUCCESS
    56,2021-07-01 16:10:27,224.480,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23208,514,514,8,2,3,35,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3323,3315,3307,3314,3308,3315,3328,0,0,0,0,0,0,0,0,2560,23.6,23.8,-273.2,23.8,-273.2,33.0,974,SUCCESS
    57,2021-07-01 16:10:31,228.496,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23222,514,514,8,2,3,35,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3325,3318,3309,3317,3311,3317,3330,0,0,0,0,0,0,0,0,2565,23.6,23.8,-273.2,23.8,-273.2,33.0,1023,SUCCESS
    58,2021-07-01 16:10:35,232.495,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23236,515,514,8,2,3,36,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3327,3319,3312,3319,3313,3320,3332,0,0,0,0,0,0,0,0,2565,23.6,23.8,-273.2,23.8,-273.2,32.9,963,SUCCESS
    59,2021-07-01 16:10:39,236.510,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23251,514,514,8,2,3,36,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3329,3322,3314,3321,3315,3322,3335,0,0,0,0,0,0,0,0,2570,23.6,23.8,-273.2,23.8,-273.2,33.0,991,SUCCESS
    60,2021-07-01 16:10:43,240.512,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23272,512,514,8,2,3,37,2352,65535,65535,342,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3332,3324,3316,3323,3317,3325,3337,0,0,0,0,0,0,0,0,2570,23.6,23.8,-273.2,23.8,-273.2,33.0,1006,SUCCESS
    61,2021-07-01 16:10:47,244.523,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23286,514,514,8,2,3,38,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3334,3326,3319,3325,3320,3326,3339,0,0,0,0,0,0,0,0,2570,23.7,23.8,-273.2,23.8,-273.2,33.0,968,SUCCESS
    62,2021-07-01 16:10:51,248.530,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23301,515,514,8,2,3,38,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3336,3328,3321,3328,3322,3329,3341,0,0,0,0,0,0,0,0,2575,23.7,23.8,-273.2,23.8,-273.2,33.1,1010,SUCCESS
    63,2021-07-01 16:10:55,252.534,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23316,515,514,8,2,3,39,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3338,3330,3323,3330,3324,3331,3342,0,0,0,0,0,0,0,0,2575,23.7,23.8,-273.2,23.8,-273.2,33.0,1025,SUCCESS
    64,2021-07-01 16:10:59,256.551,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23333,514,514,8,2,3,39,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3340,3332,3325,3332,3326,3333,3345,0,0,0,0,0,0,0,0,2575,23.7,23.8,-273.2,23.8,-273.2,32.9,1082,SUCCESS
    65,2021-07-01 16:11:03,260.550,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23349,514,514,8,2,3,40,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3343,3335,3327,3334,3328,3335,3347,0,0,0,0,0,0,0,0,2580,23.7,23.8,-273.2,23.8,-273.2,33.0,1077,SUCCESS
    66,2021-07-01 16:11:07,264.560,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23364,515,514,8,2,3,40,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3345,3337,3329,3336,3330,3337,3349,0,0,0,0,0,0,0,0,2580,23.7,23.8,-273.2,23.8,-273.2,33.0,1037,SUCCESS
    67,2021-07-01 16:11:11,268.571,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23377,513,514,8,2,3,41,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3347,3339,3331,3337,3332,3339,3351,0,0,0,0,0,0,0,0,2580,23.7,23.8,-273.2,23.8,-273.2,33.0,964,SUCCESS
    68,2021-07-01 16:11:15,272.583,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23387,513,514,8,2,3,42,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3349,3341,3333,3340,3334,3341,3353,0,0,0,0,0,0,0,0,2580,23.7,23.8,-273.2,23.8,-273.2,32.9,1036,SUCCESS
    69,2021-07-01 16:11:19,276.588,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23401,514,514,8,2,3,42,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3351,3342,3335,3342,3337,3342,3355,0,0,0,0,0,0,0,0,2585,23.7,23.8,-273.2,23.8,-273.2,33.0,977,SUCCESS
    70,2021-07-01 16:11:23,280.596,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23415,514,514,8,2,3,43,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3353,3344,3337,3344,3338,3344,3357,0,0,0,0,0,0,0,0,2585,23.7,23.8,-273.2,23.8,-273.2,33.0,1045,SUCCESS
    71,2021-07-01 16:11:27,284.607,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23429,514,514,8,2,3,43,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3355,3346,3339,3345,3340,3346,3359,0,0,0,0,0,0,0,0,2585,23.7,23.8,-273.2,23.8,-273.2,32.9,1006,SUCCESS
    72,2021-07-01 16:11:31,288.609,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23443,514,514,8,2,3,44,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3357,3348,3341,3347,3343,3348,3361,0,0,0,0,0,0,0,0,2590,23.7,23.8,-273.2,23.8,-273.2,33.1,1133,SUCCESS
    73,2021-07-01 16:11:35,292.620,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23453,514,514,8,2,3,44,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3358,3350,3343,3349,3344,3350,3362,0,0,0,0,0,0,0,0,2590,23.7,23.8,-273.2,23.8,-273.2,33.1,1009,SUCCESS
    74,2021-07-01 16:11:39,296.620,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23470,513,514,8,2,3,45,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3360,3352,3345,3351,3346,3352,3364,0,0,0,0,0,0,0,0,2590,23.7,23.8,-273.2,23.8,-273.2,33.0,966,SUCCESS
    75,2021-07-01 16:11:43,300.620,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23480,515,514,8,2,3,46,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3362,3353,3347,3352,3348,3354,3366,0,0,0,0,0,0,0,0,2595,23.7,23.8,-273.2,23.8,-273.2,33.0,944,SUCCESS
    76,2021-07-01 16:11:47,304.630,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23493,513,514,8,2,3,46,2352,65535,65535,341,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3364,3356,3349,3355,3350,3356,3368,0,0,0,0,0,0,0,0,2595,23.7,23.8,-273.2,23.8,-273.2,32.6,1034,SUCCESS
    77,2021-07-01 16:11:51,308.645,0x0701,150,10,0x6001,0,65535,65535,1,23.8,23506,513,514,8,2,3,47,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3366,3357,3350,3356,3352,3358,3370,0,0,0,0,0,0,0,0,2595,23.7,23.8,-273.2,23.8,-273.2,33.0,1059,SUCCESS
    78,2021-07-01 16:11:55,312.660,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23517,514,514,8,2,3,47,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3367,3359,3352,3358,3354,3359,3371,0,0,0,0,0,0,0,0,2595,23.7,23.9,-273.2,23.9,-273.2,33.1,1145,SUCCESS
    79,2021-07-01 16:11:59,316.667,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23530,514,514,8,3,3,48,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3369,3360,3354,3360,3355,3361,3373,0,0,0,0,0,0,0,0,2600,23.7,23.9,-273.2,23.9,-273.2,33.0,992,SUCCESS
    80,2021-07-01 16:12:03,320.670,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23541,515,514,8,3,3,48,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3371,3362,3356,3361,3357,3363,3374,0,0,0,0,0,0,0,0,2600,23.7,23.9,-273.2,23.9,-273.2,33.1,1050,SUCCESS
    81,2021-07-01 16:12:07,324.672,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23550,514,514,8,3,3,49,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3372,3364,3358,3363,3358,3364,3374,0,0,0,0,0,0,0,0,2600,23.7,23.9,-273.2,23.9,-273.2,33.1,1050,SUCCESS
    82,2021-07-01 16:12:11,328.677,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23563,515,514,8,3,3,50,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3374,3365,3359,3365,3360,3366,3374,0,0,0,0,0,0,0,0,2600,23.7,23.9,-273.2,23.9,-273.2,33.1,1029,SUCCESS
    83,2021-07-01 16:12:15,332.685,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23576,514,514,8,3,3,50,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3376,3367,3362,3367,3362,3367,3377,0,0,0,0,0,0,0,0,2605,23.7,23.9,-273.2,23.9,-273.2,33.0,1021,SUCCESS
    84,2021-07-01 16:12:19,336.687,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23587,514,514,8,3,4,51,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3378,3369,3362,3369,3364,3369,3379,0,0,0,0,0,0,0,0,2605,23.7,23.9,-273.2,23.9,-273.2,33.0,1016,SUCCESS
    85,2021-07-01 16:12:23,340.701,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23597,515,514,8,3,4,51,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3379,3370,3362,3370,3364,3371,3381,0,0,0,0,0,0,0,0,2605,23.7,23.9,-273.2,23.9,-273.2,33.0,989,SUCCESS
    86,2021-07-01 16:12:27,344.714,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23605,515,514,8,3,4,52,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3381,3372,3362,3370,3367,3373,3382,0,0,0,0,0,0,0,0,2605,23.7,23.9,-273.2,23.9,-273.2,33.0,1023,SUCCESS
    87,2021-07-01 16:12:31,348.725,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23616,514,514,8,3,4,52,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3383,3373,3365,3370,3367,3375,3384,0,0,0,0,0,0,0,0,2610,23.7,23.9,-273.2,23.9,-273.2,33.0,1059,SUCCESS
    88,2021-07-01 16:12:35,352.736,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23627,514,514,8,3,4,53,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3384,3375,3368,3371,3370,3375,3386,0,0,0,0,0,0,0,0,2610,23.7,23.9,-273.2,23.9,-273.2,33.0,984,SUCCESS
    89,2021-07-01 16:12:39,356.752,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23638,514,514,8,3,4,54,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3386,3377,3370,3374,3371,3375,3387,0,0,0,0,0,0,0,0,2610,23.7,23.9,-273.2,23.9,-273.2,33.1,1053,SUCCESS
    90,2021-07-01 16:12:43,360.766,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23648,514,514,8,3,4,54,2352,65535,65535,340,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3387,3379,3371,3376,3373,3375,3389,0,0,0,0,0,0,0,0,2610,23.7,23.9,-273.2,23.9,-273.2,33.1,1003,SUCCESS
    91,2021-07-01 16:12:47,364.766,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23657,514,514,8,3,4,55,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3390,3379,3373,3378,3375,3375,3390,0,0,0,0,0,0,0,0,2614,23.7,23.9,-273.2,23.9,-273.2,33.0,1078,SUCCESS
    92,2021-07-01 16:12:51,368.778,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23667,513,514,8,3,4,55,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3390,3379,3374,3379,3375,3377,3391,0,0,0,0,0,0,0,0,2615,23.7,23.9,-273.2,23.9,-273.2,33.1,988,SUCCESS
    93,2021-07-01 16:12:55,372.788,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23676,514,514,8,3,4,56,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3390,3379,3375,3381,3377,3379,3393,0,0,0,0,0,0,0,0,2615,23.7,23.9,-273.2,23.9,-273.2,33.1,997,SUCCESS
    94,2021-07-01 16:12:59,376.792,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23683,513,514,8,3,4,56,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3390,3381,3377,3382,3378,3383,3394,0,0,0,0,0,0,0,0,2615,23.7,23.9,-273.2,23.9,-273.2,33.1,1070,SUCCESS
    95,2021-07-01 16:13:03,380.803,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23693,515,514,8,3,4,57,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3391,3383,3379,3383,3380,3385,3395,0,0,0,0,0,0,0,0,2615,23.7,23.9,-273.2,23.9,-273.2,33.1,965,SUCCESS
    96,2021-07-01 16:13:07,384.809,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23704,515,514,8,3,4,58,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3394,3385,3380,3384,3381,3387,3397,0,0,0,0,0,0,0,0,2620,23.7,23.9,-273.2,23.9,-273.2,33.1,1084,SUCCESS
    97,2021-07-01 16:13:11,388.817,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23714,513,514,8,3,4,58,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3396,3386,3382,3386,3383,3389,3398,0,0,0,0,0,0,0,0,2620,23.7,23.9,-273.2,23.9,-273.2,33.1,1105,SUCCESS
    98,2021-07-01 16:13:15,392.823,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23724,514,514,8,3,4,59,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3397,3387,3382,3387,3384,3392,3399,0,0,0,0,0,0,0,0,2620,23.8,23.9,-273.2,23.9,-273.2,33.2,1030,SUCCESS
    99,2021-07-01 16:13:19,396.835,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23732,514,514,8,3,4,59,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3399,3389,3384,3389,3385,3394,3401,0,0,0,0,0,0,0,0,2620,23.8,23.9,-273.2,23.9,-273.2,33.1,1027,SUCCESS
    100,2021-07-01 16:13:23,400.839,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23741,515,514,8,3,4,60,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3400,3390,3385,3389,3386,3390,3401,0,0,0,0,0,0,0,0,2620,23.8,23.9,-273.2,23.9,-273.2,33.0,1074,SUCCESS
    101,2021-07-01 16:13:27,404.851,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23749,514,514,8,3,4,61,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3401,3391,3386,3390,3388,3392,3402,0,0,0,0,0,0,0,0,2625,23.8,23.9,-273.2,23.9,-273.2,33.1,1088,SUCCESS
    102,2021-07-01 16:13:31,408.855,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23759,515,514,8,3,4,61,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3403,3393,3388,3392,3389,3393,3404,0,0,0,0,0,0,0,0,2625,23.8,23.9,-273.2,23.9,-273.2,33.1,1070,SUCCESS
    103,2021-07-01 16:13:35,412.857,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23766,514,514,8,3,4,62,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3404,3394,3389,3393,3390,3394,3405,0,0,0,0,0,0,0,0,2625,23.8,23.9,-273.2,23.9,-273.2,33.1,1037,SUCCESS
    104,2021-07-01 16:13:39,416.860,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23774,513,514,8,3,4,62,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3405,3395,3389,3394,3391,3395,3406,0,0,0,0,0,0,0,0,2625,23.8,23.9,-273.2,23.9,-273.2,33.0,1095,SUCCESS
    105,2021-07-01 16:13:43,420.861,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23784,514,514,8,3,4,63,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3406,3396,3391,3396,3393,3396,3407,0,0,0,0,0,0,0,0,2625,23.8,23.9,-273.2,23.9,-273.2,33.1,1046,SUCCESS
    106,2021-07-01 16:13:48,424.872,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23791,514,514,8,3,4,63,2352,65535,65535,339,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3407,3397,3393,3396,3394,3397,3408,0,0,0,0,0,0,0,0,2626,23.8,23.9,-273.2,23.9,-273.2,33.0,1005,SUCCESS
    107,2021-07-01 16:13:52,428.874,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23798,515,514,8,3,4,64,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3409,3398,3393,3397,3395,3398,3409,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,32.5,1056,SUCCESS
    108,2021-07-01 16:13:56,432.895,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23806,514,514,8,3,4,65,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3410,3399,3394,3399,3396,3400,3410,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,33.1,1061,SUCCESS
    109,2021-07-01 16:14:00,436.909,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23814,514,514,8,3,4,65,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3410,3400,3396,3400,3398,3401,3411,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,33.1,1031,SUCCESS
    110,2021-07-01 16:14:04,440.916,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23821,514,514,8,3,4,66,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3411,3401,3397,3401,3398,3402,3412,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,33.2,1030,SUCCESS
    111,2021-07-01 16:14:08,444.928,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23827,514,514,8,3,4,66,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3412,3402,3398,3402,3398,3402,3413,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,33.1,1029,SUCCESS
    112,2021-07-01 16:14:12,448.943,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23832,515,514,8,3,5,67,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3413,3403,3399,3403,3398,3403,3414,0,0,0,0,0,0,0,0,2630,23.8,23.9,-273.2,23.9,-273.2,33.1,980,SUCCESS
    113,2021-07-01 16:14:16,452.956,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23839,514,514,8,3,5,67,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3415,3404,3400,3404,3398,3404,3415,0,0,0,0,0,0,0,0,2634,23.8,23.9,-273.2,23.9,-273.2,33.2,1077,SUCCESS
    114,2021-07-01 16:14:20,456.967,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23845,514,514,8,3,5,68,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3416,3405,3401,3405,3399,3405,3416,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.2,1035,SUCCESS
    115,2021-07-01 16:14:24,460.978,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23852,515,514,8,3,5,69,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3416,3405,3402,3406,3401,3406,3417,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.2,1070,SUCCESS
    116,2021-07-01 16:14:28,464.993,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23859,514,514,8,3,5,69,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3417,3406,3404,3407,3403,3407,3417,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.1,1008,SUCCESS
    117,2021-07-01 16:14:32,469.003,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23866,514,514,8,3,5,70,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3418,3407,3404,3408,3403,3408,3419,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.2,1030,SUCCESS
    118,2021-07-01 16:14:36,473.018,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23871,514,514,8,3,5,70,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3419,3408,3404,3409,3405,3409,3419,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.2,1046,SUCCESS
    119,2021-07-01 16:14:40,477.032,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23878,515,514,8,4,5,71,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3420,3409,3405,3410,3406,3409,3420,0,0,0,0,0,0,0,0,2635,23.8,23.9,-273.2,23.9,-273.2,33.1,1065,SUCCESS
    120,2021-07-01 16:14:44,481.035,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23885,515,514,8,4,5,71,2352,65535,65535,338,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3421,3410,3406,3411,3407,3410,3421,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.1,1092,SUCCESS
    121,2021-07-01 16:14:48,485.045,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23890,515,514,8,4,5,72,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3421,3411,3407,3411,3407,3411,3422,0,0,0,0,0,0,0,0,2640,23.8,23.9,-273.2,23.9,-273.2,33.1,1019,SUCCESS
    122,2021-07-01 16:14:52,489.050,0x0701,150,10,0x6001,0,65535,65535,1,23.9,23895,515,514,8,4,5,73,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3422,3412,3408,3411,3408,3412,3423,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.1,1033,SUCCESS
    123,2021-07-01 16:14:56,493.057,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23900,514,514,8,4,5,73,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3423,3413,3408,3412,3409,3413,3423,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.2,991,SUCCESS
    124,2021-07-01 16:15:00,497.067,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23905,513,514,8,4,5,74,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3424,3413,3409,3413,3410,3414,3424,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.2,1030,SUCCESS
    125,2021-07-01 16:15:04,501.074,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23914,514,514,8,4,5,74,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3425,3414,3410,3414,3411,3415,3425,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.2,991,SUCCESS
    126,2021-07-01 16:15:08,505.081,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23920,515,514,8,4,5,75,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3426,3415,3411,3415,3412,3415,3425,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.1,1092,SUCCESS
    127,2021-07-01 16:15:12,509.087,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23924,513,514,8,4,5,75,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3427,3416,3412,3416,3412,3416,3426,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.2,990,SUCCESS
    128,2021-07-01 16:15:16,513.089,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23929,514,514,8,4,5,76,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3427,3416,3413,3416,3413,3417,3427,0,0,0,0,0,0,0,0,2640,23.8,24.0,-273.2,24.0,-273.2,33.2,1007,SUCCESS
    129,2021-07-01 16:15:20,517.099,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23935,513,514,8,4,5,77,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3428,3417,3413,3417,3414,3417,3428,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1026,SUCCESS
    130,2021-07-01 16:15:24,521.112,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23940,514,514,8,4,5,77,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3429,3419,3414,3418,3415,3418,3429,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1062,SUCCESS
    131,2021-07-01 16:15:28,525.117,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23947,515,514,8,4,5,78,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3430,3420,3414,3419,3416,3419,3430,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.1,998,SUCCESS
    132,2021-07-01 16:15:32,529.124,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23952,515,514,8,4,5,78,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3432,3420,3416,3419,3416,3420,3430,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1021,SUCCESS
    133,2021-07-01 16:15:36,533.124,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23956,514,514,8,4,5,79,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3432,3420,3416,3420,3418,3420,3431,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1068,SUCCESS
    134,2021-07-01 16:15:40,537.125,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23959,514,514,8,4,5,79,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3432,3420,3417,3420,3418,3421,3432,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1033,SUCCESS
    135,2021-07-01 16:15:44,541.138,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23963,513,514,8,4,5,80,2352,65535,65535,337,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3432,3421,3418,3421,3418,3422,3432,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1051,SUCCESS
    136,2021-07-01 16:15:48,545.153,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23968,514,514,8,4,5,81,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3433,3422,3419,3422,3419,3422,3432,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.1,1051,SUCCESS
    137,2021-07-01 16:15:52,549.166,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23972,515,514,8,4,5,81,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3433,3422,3419,3423,3419,3423,3433,0,0,0,0,0,0,0,0,2645,23.8,24.0,-273.2,24.0,-273.2,33.2,1024,SUCCESS
    138,2021-07-01 16:15:56,553.177,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23978,515,514,8,4,5,82,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3434,3423,3420,3424,3420,3424,3434,0,0,0,0,0,0,0,0,2650,23.8,24.0,-273.2,24.0,-273.2,33.2,1074,SUCCESS
    139,2021-07-01 16:16:00,557.179,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23982,514,514,8,4,5,82,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3435,3424,3420,3424,3421,3424,3434,0,0,0,0,0,0,0,0,2650,23.8,24.0,-273.2,24.0,-273.2,33.2,995,SUCCESS
    140,2021-07-01 16:16:04,561.183,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23986,514,514,8,4,5,83,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3435,3425,3420,3425,3422,3426,3435,0,0,0,0,0,0,0,0,2650,23.8,24.0,-273.2,24.0,-273.2,33.1,1054,SUCCESS
    141,2021-07-01 16:16:08,565.184,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23993,514,514,8,4,5,83,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3436,3425,3421,3426,3423,3426,3436,0,0,0,0,0,0,0,0,2650,23.8,24.0,-273.2,24.0,-273.2,33.1,957,SUCCESS
    142,2021-07-01 16:16:12,569.192,0x0701,150,10,0x6001,0,65535,65535,1,24.0,23998,514,514,8,4,6,84,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3437,3426,3422,3427,3423,3427,3436,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.1,1067,SUCCESS
    143,2021-07-01 16:16:16,573.194,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24002,515,514,8,4,6,85,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3438,3427,3422,3427,3424,3427,3437,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.2,1010,SUCCESS
    144,2021-07-01 16:16:20,577.204,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24004,514,514,8,4,6,85,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3438,3427,3423,3427,3425,3428,3438,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.2,1063,SUCCESS
    145,2021-07-01 16:16:24,581.216,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24009,514,514,8,4,6,86,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3439,3428,3424,3427,3425,3429,3439,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.2,1084,SUCCESS
    146,2021-07-01 16:16:28,585.229,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24013,514,514,8,4,6,86,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3439,3429,3425,3428,3425,3429,3439,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.1,1071,SUCCESS
    147,2021-07-01 16:16:32,589.239,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24020,515,514,8,4,6,87,2352,65535,65535,336,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3440,3430,3425,3429,3426,3430,3440,0,0,0,0,0,0,0,0,2650,23.9,24.0,-273.2,24.0,-273.2,33.1,1046,SUCCESS
    148,2021-07-01 16:16:36,593.254,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24024,515,515,8,4,6,88,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3441,3430,3426,3430,3427,3430,3440,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,1014,SUCCESS
    149,2021-07-01 16:16:40,597.264,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24026,514,515,8,4,6,88,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3441,3430,3426,3430,3428,3431,3441,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.1,1049,SUCCESS
    150,2021-07-01 16:16:44,601.276,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24033,515,515,8,4,6,89,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3442,3431,3427,3431,3429,3432,3442,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.1,1040,SUCCESS
    151,2021-07-01 16:16:48,605.286,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24038,515,515,8,4,6,89,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3442,3432,3428,3432,3429,3433,3442,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,1027,SUCCESS
    152,2021-07-01 16:16:52,609.301,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24041,515,515,8,4,6,90,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3443,3433,3428,3432,3430,3433,3443,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,1013,SUCCESS
    153,2021-07-01 16:16:56,613.305,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24045,516,515,8,4,6,90,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3444,3433,3429,3433,3430,3433,3444,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.1,946,SUCCESS
    154,2021-07-01 16:17:00,617.320,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24050,515,515,8,4,6,91,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3445,3434,3430,3434,3431,3434,3445,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,963,SUCCESS
    155,2021-07-01 16:17:04,621.324,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24055,514,515,8,4,6,92,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3445,3434,3430,3434,3432,3434,3445,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,972,SUCCESS
    156,2021-07-01 16:17:08,625.338,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24061,515,515,8,4,6,92,2352,65535,65535,335,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3446,3435,3431,3435,3432,3435,3446,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,993,SUCCESS
    157,2021-07-01 16:17:12,629.345,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24065,514,515,8,4,6,93,2352,65535,65535,334,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3447,3436,3431,3436,3433,3436,3446,0,0,0,0,0,0,0,0,2655,23.9,24.0,-273.2,24.0,-273.2,33.2,1064,SUCCESS
    158,2021-07-01 16:17:16,633.361,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24068,515,515,8,4,6,93,2352,65535,65535,334,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3448,3437,3432,3436,3433,3436,3446,0,0,0,0,0,0,0,0,2660,23.9,24.0,-273.2,24.0,-273.2,32.9,1179,SUCCESS
    159,2021-07-01 16:17:20,637.367,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24073,515,515,8,4,6,94,2352,65535,65535,334,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3448,3437,3433,3437,3434,3438,3447,0,0,0,0,0,0,0,0,2660,23.9,24.0,-273.2,24.0,-273.2,33.1,1015,SUCCESS
    160,2021-07-01 16:17:24,641.370,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24076,515,515,8,4,6,94,2352,65535,65535,334,1000,28875,0x0890,4103,2552,100,0x0107,0x0000,0x04,0x02,0x415,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3448,3436,3434,3437,3435,3438,3448,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,33.2,1053,SUCCESS
    161,2021-07-01 16:17:28,645.378,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24079,514,515,8,5,6,95,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3448,3437,3434,3438,3435,3438,3449,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,33.2,1014,SUCCESS
    162,2021-07-01 16:17:32,649.391,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24084,515,515,8,5,6,96,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3449,3438,3434,3439,3436,3439,3450,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,33.2,1034,SUCCESS
    163,2021-07-01 16:17:36,653.393,0x0701,150,10,0x6001,0,65535,65535,1,24.0,24088,516,515,8,5,6,96,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3450,3439,3435,3439,3437,3439,3450,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,32.6,1054,SUCCESS
    164,2021-07-01 16:17:40,657.392,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24091,514,515,8,5,6,97,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3450,3439,3436,3440,3438,3440,3450,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,33.0,1024,SUCCESS
    165,2021-07-01 16:17:44,661.394,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24097,515,515,8,5,6,97,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3451,3440,3436,3441,3438,3441,3451,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,33.1,1082,SUCCESS
    166,2021-07-01 16:17:48,665.406,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24101,516,515,8,5,6,98,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3452,3441,3437,3441,3438,3441,3452,0,0,0,0,0,0,0,0,2660,23.9,24.0,-273.2,24.1,-273.2,33.3,1040,SUCCESS
    167,2021-07-01 16:17:52,669.406,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24103,515,515,8,5,6,98,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3452,3442,3438,3441,3439,3442,3452,0,0,0,0,0,0,0,0,2664,23.9,24.1,-273.2,24.1,-273.2,33.2,1055,SUCCESS
    168,2021-07-01 16:17:56,673.413,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24109,515,515,8,5,6,99,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3453,3442,3438,3442,3440,3443,3453,0,0,0,0,0,0,0,0,2660,23.9,24.1,-273.2,24.1,-273.2,32.5,1077,SUCCESS
    169,2021-07-01 16:18:00,677.415,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24113,515,515,8,5,6,100,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3453,3442,3439,3443,3440,3443,3454,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.3,1027,SUCCESS
    170,2021-07-01 16:18:04,681.423,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24118,513,515,8,5,6,100,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3454,3443,3440,3443,3441,3444,3454,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.2,1065,SUCCESS
    171,2021-07-01 16:18:08,685.423,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24121,515,515,8,5,7,101,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3455,3444,3440,3444,3441,3444,3455,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.3,1083,SUCCESS
    172,2021-07-01 16:18:12,689.432,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24125,514,515,8,5,7,101,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3455,3444,3440,3444,3442,3445,3455,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.3,960,SUCCESS
    173,2021-07-01 16:18:16,693.436,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24130,515,515,8,5,7,102,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3456,3445,3441,3445,3443,3445,3455,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,32.7,1041,SUCCESS
    174,2021-07-01 16:18:20,697.452,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24134,514,514,8,5,7,102,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3456,3446,3442,3446,3443,3446,3456,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.2,1145,SUCCESS
    175,2021-07-01 16:18:24,701.465,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24139,515,514,8,5,7,103,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3457,3446,3442,3446,3444,3447,3457,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.2,1024,SUCCESS
    176,2021-07-01 16:18:28,705.467,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24141,515,514,8,5,7,104,2352,65535,65535,334,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3457,3447,3443,3447,3444,3447,3458,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.2,1053,SUCCESS
    177,2021-07-01 16:18:32,709.478,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24146,515,515,8,5,7,104,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3458,3447,3444,3447,3445,3447,3458,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.3,1085,SUCCESS
    178,2021-07-01 16:18:36,713.479,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24151,515,515,8,5,7,105,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3459,3448,3444,3448,3445,3448,3459,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,32.5,1045,SUCCESS
    179,2021-07-01 16:18:40,717.484,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24154,515,515,8,5,7,105,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3459,3448,3445,3448,3446,3449,3459,0,0,0,0,0,0,0,0,2665,23.9,24.1,-273.2,24.1,-273.2,33.3,1033,SUCCESS
    180,2021-07-01 16:18:44,721.489,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24158,515,515,8,5,7,106,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3460,3449,3445,3449,3447,3449,3460,0,0,0,0,0,0,0,0,2670,23.9,24.1,-273.2,24.1,-273.2,33.3,1013,SUCCESS
    181,2021-07-01 16:18:48,725.490,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24162,515,515,8,5,7,106,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3461,3450,3446,3450,3447,3449,3460,0,0,0,0,0,0,0,0,2670,23.9,24.1,-273.2,24.1,-273.2,33.2,1059,SUCCESS
    182,2021-07-01 16:18:52,729.494,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24166,515,515,8,5,7,107,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3461,3450,3447,3450,3447,3450,3461,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.3,978,SUCCESS
    183,2021-07-01 16:18:56,733.504,0x0701,150,10,0x6001,0,65535,65535,1,24.1,24172,515,515,8,5,7,108,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3462,3451,3447,3451,3448,3451,3462,0,0,0,0,0,0,0,0,2670,23.9,24.1,-273.2,24.1,-273.2,33.0,1020,SUCCESS
    184,2021-07-01 16:19:00,737.508,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24175,515,515,8,5,7,108,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3462,3451,3448,3451,3449,3452,3462,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,962,SUCCESS
    185,2021-07-01 16:19:04,741.518,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24176,515,515,8,5,7,109,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3462,3451,3448,3451,3449,3452,3463,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,972,SUCCESS
    186,2021-07-01 16:19:08,745.519,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24180,515,515,8,5,7,109,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3463,3452,3449,3453,3449,3452,3463,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,1029,SUCCESS
    187,2021-07-01 16:19:12,749.521,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24185,515,515,8,5,7,110,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3464,3453,3450,3453,3450,3453,3464,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.3,949,SUCCESS
    188,2021-07-01 16:19:16,753.531,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24188,515,515,8,5,7,110,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3464,3453,3450,3453,3451,3453,3465,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,1017,SUCCESS
    189,2021-07-01 16:19:20,757.533,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24193,515,515,8,5,7,111,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3465,3453,3451,3454,3451,3454,3466,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,1048,SUCCESS
    190,2021-07-01 16:19:24,761.534,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24196,515,515,8,5,7,112,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3465,3454,3452,3454,3452,3454,3466,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,1093,SUCCESS
    191,2021-07-01 16:19:28,765.541,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24199,514,515,8,5,7,112,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3466,3454,3452,3455,3452,3455,3467,0,0,0,0,0,0,0,0,2670,23.9,24.2,-273.2,24.2,-273.2,33.2,1012,SUCCESS
    192,2021-07-01 16:19:32,769.554,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24204,514,515,8,5,7,113,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3466,3454,3453,3455,3453,3455,3468,0,0,0,0,0,0,0,0,2670,24.0,24.2,-273.2,24.2,-273.2,33.3,1092,SUCCESS
    193,2021-07-01 16:19:36,773.564,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24209,515,514,8,5,7,113,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3466,3455,3453,3456,3453,3456,3469,0,0,0,0,0,0,0,0,2671,24.0,24.2,-273.2,24.2,-273.2,33.3,1063,SUCCESS
    194,2021-07-01 16:19:40,777.571,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24211,515,514,8,5,7,114,2352,65535,65535,333,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3467,3455,3454,3456,3453,3456,3469,0,0,0,0,0,0,0,0,2675,23.9,24.2,-273.2,24.2,-273.2,33.3,1026,SUCCESS
    195,2021-07-01 16:19:44,781.577,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24215,515,514,8,5,7,115,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3468,3456,3455,3457,3454,3456,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,972,SUCCESS
    196,2021-07-01 16:19:48,785.585,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24218,515,514,8,5,7,115,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3468,3456,3457,3457,3455,3456,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1057,SUCCESS
    197,2021-07-01 16:19:52,789.597,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24220,515,514,8,5,7,116,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3468,3457,3457,3457,3456,3457,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,998,SUCCESS
    198,2021-07-01 16:19:56,793.600,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24223,515,514,8,5,7,116,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3468,3457,3457,3458,3456,3458,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,997,SUCCESS
    199,2021-07-01 16:20:00,797.613,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24225,514,514,8,5,8,117,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3469,3457,3457,3459,3456,3458,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1030,SUCCESS
    200,2021-07-01 16:20:04,801.618,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24226,515,514,8,5,8,117,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3470,3457,3457,3459,3456,3458,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,994,SUCCESS
    201,2021-07-01 16:20:08,805.624,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24228,515,515,8,6,8,118,2352,65535,65535,332,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3470,3458,3457,3459,3456,3459,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.2,961,SUCCESS
    202,2021-07-01 16:20:12,809.634,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24229,515,515,8,6,8,119,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3470,3459,3457,3460,3456,3459,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1025,SUCCESS
    203,2021-07-01 16:20:16,813.644,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24231,514,515,8,6,8,119,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3471,3459,3457,3460,3456,3460,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.2,998,SUCCESS
    204,2021-07-01 16:20:20,817.655,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24235,515,515,8,6,8,120,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3472,3459,3457,3461,3457,3460,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.2,1050,SUCCESS
    205,2021-07-01 16:20:24,821.659,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24238,515,515,8,6,8,120,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3472,3460,3457,3462,3458,3460,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1000,SUCCESS
    206,2021-07-01 16:20:28,825.674,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24239,515,515,8,6,8,121,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3472,3460,3457,3462,3458,3461,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1047,SUCCESS
    207,2021-07-01 16:20:32,829.675,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24240,514,515,8,6,8,121,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3472,3460,3457,3463,3458,3461,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.1,1177,SUCCESS
    208,2021-07-01 16:20:36,833.679,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24241,514,515,8,6,8,122,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3473,3460,3457,3463,3459,3462,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,1011,SUCCESS
    209,2021-07-01 16:20:40,837.693,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24245,514,515,8,6,8,123,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3473,3461,3457,3464,3459,3462,3469,0,0,0,0,0,0,0,0,2675,24.0,24.2,-273.2,24.2,-273.2,33.3,995,SUCCESS
    210,2021-07-01 16:20:44,841.693,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24245,515,515,8,6,8,123,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3473,3461,3457,3464,3459,3462,3469,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,980,SUCCESS
    211,2021-07-01 16:20:48,845.694,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24245,516,515,8,6,8,124,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3474,3461,3457,3464,3459,3462,3469,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,980,SUCCESS
    212,2021-07-01 16:20:52,849.705,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24246,515,515,8,6,8,124,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3474,3462,3457,3464,3460,3462,3469,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.2,1069,SUCCESS
    213,2021-07-01 16:20:56,853.710,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24247,515,515,8,6,8,125,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3475,3462,3457,3464,3460,3463,3469,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,964,SUCCESS
    214,2021-07-01 16:21:00,857.724,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24252,515,515,8,6,8,126,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3475,3463,3458,3464,3461,3464,3469,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.0,1003,SUCCESS
    215,2021-07-01 16:21:04,861.727,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24254,515,515,8,6,8,126,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3475,3463,3458,3464,3461,3464,3470,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.2,963,SUCCESS
    216,2021-07-01 16:21:08,865.741,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24256,514,515,8,6,8,127,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3476,3463,3459,3464,3461,3464,3471,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1047,SUCCESS
    217,2021-07-01 16:21:12,869.748,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24260,515,515,8,6,8,127,2352,65535,65535,331,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3476,3463,3459,3464,3462,3465,3471,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1067,SUCCESS
    218,2021-07-01 16:21:16,873.754,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24264,515,515,8,6,8,128,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3476,3464,3460,3464,3462,3465,3471,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1060,SUCCESS
    219,2021-07-01 16:21:20,877.755,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24266,515,515,8,6,8,128,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3477,3464,3460,3464,3462,3465,3472,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,32.6,1002,SUCCESS
    220,2021-07-01 16:21:24,881.766,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24268,515,515,8,6,8,129,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3477,3464,3460,3464,3462,3466,3472,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1120,SUCCESS
    221,2021-07-01 16:21:28,885.769,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24271,514,515,8,6,8,130,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3477,3464,3461,3464,3462,3466,3472,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1016,SUCCESS
    222,2021-07-01 16:21:32,889.772,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24270,515,515,8,6,8,130,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3478,3465,3461,3464,3463,3466,3473,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1122,SUCCESS
    223,2021-07-01 16:21:36,893.785,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24271,514,515,8,6,8,131,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3478,3465,3462,3464,3463,3467,3473,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.2,1036,SUCCESS
    224,2021-07-01 16:21:40,897.789,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24273,514,515,8,6,8,131,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3478,3466,3462,3464,3464,3467,3474,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,32.5,1140,SUCCESS
    225,2021-07-01 16:21:44,901.789,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24276,515,515,8,6,8,132,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3479,3466,3462,3464,3464,3467,3474,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1027,SUCCESS
    226,2021-07-01 16:21:48,905.796,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24278,514,515,8,6,8,132,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3479,3466,3462,3464,3464,3467,3474,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,972,SUCCESS
    227,2021-07-01 16:21:52,909.798,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24279,514,515,8,6,8,133,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3479,3466,3463,3464,3465,3468,3474,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,987,SUCCESS
    228,2021-07-01 16:21:56,913.802,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24281,515,515,8,6,9,134,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3479,3467,3463,3464,3465,3470,3475,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.4,1047,SUCCESS
    229,2021-07-01 16:22:00,917.813,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24285,514,515,8,6,9,134,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3480,3467,3463,3464,3465,3471,3475,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,986,SUCCESS
    230,2021-07-01 16:22:04,921.824,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24285,514,515,8,6,9,135,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3480,3467,3463,3464,3465,3471,3475,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1022,SUCCESS
    231,2021-07-01 16:22:08,925.837,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24288,514,515,8,6,9,135,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3481,3468,3464,3464,3465,3471,3476,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,977,SUCCESS
    232,2021-07-01 16:22:12,929.845,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24289,515,515,8,6,9,136,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3481,3468,3464,3464,3465,3471,3476,0,0,0,0,0,0,0,0,2680,24.0,24.2,-273.2,24.2,-273.2,33.3,1079,SUCCESS
    233,2021-07-01 16:22:16,933.847,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24290,515,515,8,6,9,137,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3481,3468,3465,3464,3466,3471,3476,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1093,SUCCESS
    234,2021-07-01 16:22:20,937.851,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24292,514,515,8,6,9,137,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3482,3469,3465,3464,3466,3471,3476,0,0,0,0,0,0,0,0,2684,24.0,24.2,-273.2,24.2,-273.2,33.3,1025,SUCCESS
    235,2021-07-01 16:22:24,941.861,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24295,515,515,8,6,9,138,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3482,3469,3465,3466,3466,3471,3477,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1032,SUCCESS
    236,2021-07-01 16:22:29,945.868,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24297,514,515,8,6,9,138,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3482,3469,3465,3466,3467,3471,3477,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,994,SUCCESS
    237,2021-07-01 16:22:33,949.874,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24299,514,515,8,6,9,139,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3482,3470,3466,3466,3467,3471,3477,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1114,SUCCESS
    238,2021-07-01 16:22:37,953.889,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24300,514,515,8,6,9,139,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3483,3470,3466,3466,3467,3471,3477,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1003,SUCCESS
    239,2021-07-01 16:22:41,957.887,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24303,513,514,8,6,9,140,2352,65535,65535,330,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3484,3471,3466,3467,3467,3471,3478,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1082,SUCCESS
    240,2021-07-01 16:22:45,961.899,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24306,514,514,8,6,9,141,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3471,3467,3467,3468,3470,3478,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1039,SUCCESS
    241,2021-07-01 16:22:49,965.904,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24309,515,514,8,6,9,141,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3471,3467,3468,3468,3470,3479,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1119,SUCCESS
    242,2021-07-01 16:22:53,969.910,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24311,515,514,8,7,9,142,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3472,3467,3468,3469,3471,3479,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,981,SUCCESS
    243,2021-07-01 16:22:57,973.918,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24312,515,514,8,7,9,142,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3472,3467,3468,3469,3469,3479,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1037,SUCCESS
    244,2021-07-01 16:23:01,977.923,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24314,515,515,8,7,9,143,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3468,3468,3470,3468,3479,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1046,SUCCESS
    245,2021-07-01 16:23:05,981.924,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24315,515,515,8,7,9,143,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3468,3469,3469,3471,3479,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1031,SUCCESS
    246,2021-07-01 16:23:09,985.924,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24317,515,515,8,7,9,144,2352,65535,65535,329,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3468,3469,3470,3471,3480,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1062,SUCCESS
    247,2021-07-01 16:23:13,989.925,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24318,515,515,8,7,9,145,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3468,3470,3470,3472,3480,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1046,SUCCESS
    248,2021-07-01 16:23:17,993.930,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24319,515,515,8,7,9,145,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3469,3470,3470,3471,3480,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,978,SUCCESS
    249,2021-07-01 16:23:21,997.933,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24319,515,515,8,7,9,146,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3469,3470,3470,3471,3480,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1007,SUCCESS
    250,2021-07-01 16:23:25,1001.934,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24320,514,515,8,7,9,146,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3469,3471,3470,3471,3481,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1005,SUCCESS
    251,2021-07-01 16:23:29,1005.935,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24322,514,515,8,7,9,147,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3470,3471,3470,3471,3481,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1020,SUCCESS
    252,2021-07-01 16:23:33,1009.947,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24323,515,515,8,7,9,147,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3470,3471,3471,3471,3481,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,959,SUCCESS
    253,2021-07-01 16:23:37,1013.962,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24324,514,515,8,7,9,148,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3470,3471,3471,3471,3482,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,960,SUCCESS
    254,2021-07-01 16:23:41,1017.974,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24325,515,514,8,7,9,149,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3470,3472,3472,3471,3482,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1105,SUCCESS
    255,2021-07-01 16:23:45,1021.974,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24327,514,514,8,7,9,149,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3471,3472,3472,3471,3482,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,966,SUCCESS
    256,2021-07-01 16:23:49,1025.978,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24327,514,514,8,7,9,150,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3471,3472,3472,3471,3483,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.4,1040,SUCCESS
    257,2021-07-01 16:23:53,1029.985,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24330,513,514,8,7,9,150,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3471,3472,3472,3472,3483,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,1094,SUCCESS
    258,2021-07-01 16:23:57,1033.996,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24331,513,514,8,7,10,151,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3471,3473,3473,3472,3483,0,0,0,0,0,0,0,0,2685,24.0,24.2,-273.2,24.2,-273.2,33.3,977,SUCCESS
    259,2021-07-01 16:24:01,1038.000,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24331,514,514,8,7,10,151,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3471,3473,3473,3472,3483,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.4,1065,SUCCESS
    260,2021-07-01 16:24:05,1042.004,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24332,514,514,8,7,10,152,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3472,3473,3473,3473,3483,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.3,1076,SUCCESS
    261,2021-07-01 16:24:09,1046.019,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24335,513,514,8,7,10,153,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3472,3473,3474,3473,3484,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.4,982,SUCCESS
    262,2021-07-01 16:24:13,1050.020,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24337,514,514,8,7,10,153,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3473,3474,3474,3473,3484,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.2,1063,SUCCESS
    263,2021-07-01 16:24:17,1054.035,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24338,514,514,8,7,10,154,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3473,3474,3474,3473,3485,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.3,1029,SUCCESS
    264,2021-07-01 16:24:21,1058.036,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24339,513,514,8,7,10,154,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3473,3474,3474,3474,3485,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1066,SUCCESS
    265,2021-07-01 16:24:25,1062.039,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24339,514,514,8,7,10,155,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3473,3475,3474,3474,3485,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1009,SUCCESS
    266,2021-07-01 16:24:29,1066.043,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24343,514,514,8,7,10,155,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3473,3475,3475,3475,3485,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.3,1052,SUCCESS
    267,2021-07-01 16:24:33,1070.052,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24342,514,514,8,7,10,156,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3474,3475,3475,3475,3486,0,0,0,0,0,0,0,0,2690,24.0,24.2,-273.2,24.2,-273.2,33.3,984,SUCCESS
    268,2021-07-01 16:24:37,1074.051,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24346,514,514,8,7,10,157,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3486,3474,3474,3476,3475,3475,3486,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.4,1077,SUCCESS
    269,2021-07-01 16:24:41,1078.060,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24347,515,514,8,7,10,157,2352,65535,65535,328,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3485,3474,3474,3476,3476,3475,3486,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,974,SUCCESS
    270,2021-07-01 16:24:45,1082.066,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24348,514,514,8,7,10,158,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3487,3474,3474,3476,3476,3476,3486,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1093,SUCCESS
    271,2021-07-01 16:24:49,1086.069,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24350,514,514,8,7,10,158,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3487,3474,3475,3476,3476,3476,3487,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,966,SUCCESS
    272,2021-07-01 16:24:53,1090.084,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24352,514,514,8,7,10,159,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3487,3475,3475,3477,3476,3476,3487,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,965,SUCCESS
    273,2021-07-01 16:24:57,1094.092,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24355,515,514,8,7,10,159,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3488,3476,3476,3477,3477,3478,3487,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1037,SUCCESS
    274,2021-07-01 16:25:01,1098.096,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24359,514,514,8,7,10,160,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3488,3476,3476,3477,3477,3478,3487,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1031,SUCCESS
    275,2021-07-01 16:25:05,1102.111,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24360,514,514,8,7,10,161,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3488,3476,3476,3477,3477,3477,3488,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1094,SUCCESS
    276,2021-07-01 16:25:09,1106.126,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24362,513,514,8,7,10,161,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3489,3477,3476,3477,3478,3478,3488,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1048,SUCCESS
    277,2021-07-01 16:25:13,1110.133,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24364,515,514,8,7,10,162,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3489,3477,3476,3478,3478,3478,3488,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,994,SUCCESS
    278,2021-07-01 16:25:17,1114.142,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24365,515,514,8,7,10,162,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3489,3477,3477,3478,3478,3478,3489,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1006,SUCCESS
    279,2021-07-01 16:25:21,1118.157,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24370,514,514,8,7,10,163,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3490,3477,3477,3478,3478,3478,3489,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1093,SUCCESS
    280,2021-07-01 16:25:25,1122.161,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24371,513,514,8,7,10,164,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3490,3478,3477,3479,3479,3479,3489,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.4,1049,SUCCESS
    281,2021-07-01 16:25:29,1126.172,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24371,514,514,8,7,10,164,2352,65535,65535,327,1000,28875,0x0880,4103,2552,100,0x0107,0x0000,0x04,0x02,0x414,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3490,3478,3477,3479,3479,3479,3489,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1048,SUCCESS
    282,2021-07-01 16:25:33,1130.173,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24374,514,514,8,8,10,165,2352,65535,65535,327,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3491,3479,3478,3479,3479,3479,3490,0,0,0,0,0,0,0,0,2690,24.1,24.2,-273.2,24.2,-273.2,33.3,1047,SUCCESS
    283,2021-07-01 16:25:37,1134.178,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24375,514,514,8,8,10,165,2352,65535,65535,327,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3491,3479,3478,3479,3479,3479,3490,0,0,0,0,0,0,0,0,2694,24.1,24.2,-273.2,24.2,-273.2,33.3,965,SUCCESS
    284,2021-07-01 16:25:41,1138.180,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24377,514,514,8,8,10,166,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3491,3479,3478,3479,3480,3480,3490,0,0,0,0,0,0,0,0,2694,24.1,24.2,-273.2,24.2,-273.2,33.3,1007,SUCCESS
    285,2021-07-01 16:25:45,1142.195,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24379,514,514,8,8,10,166,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3491,3479,3478,3480,3480,3480,3491,0,0,0,0,0,0,0,0,2695,24.1,24.2,-273.2,24.2,-273.2,33.4,1009,SUCCESS
    286,2021-07-01 16:25:49,1146.211,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24382,513,514,8,8,11,167,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3492,3480,3479,3480,3480,3481,3491,0,0,0,0,0,0,0,0,2695,24.1,24.2,-273.2,24.2,-273.2,33.4,1011,SUCCESS
    287,2021-07-01 16:25:53,1150.222,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24384,514,514,8,8,11,168,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3492,3480,3479,3480,3481,3481,3491,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1031,SUCCESS
    288,2021-07-01 16:25:57,1154.236,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24385,514,514,8,8,11,168,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3492,3480,3479,3481,3481,3481,3491,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1006,SUCCESS
    289,2021-07-01 16:26:01,1158.244,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24388,514,514,8,8,11,169,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3493,3481,3479,3481,3481,3481,3491,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,992,SUCCESS
    290,2021-07-01 16:26:05,1162.259,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24389,513,514,8,8,11,169,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3493,3481,3480,3481,3482,3482,3491,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1008,SUCCESS
    291,2021-07-01 16:26:09,1166.264,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24392,513,514,8,8,11,170,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3493,3481,3480,3482,3482,3482,3492,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1034,SUCCESS
    292,2021-07-01 16:26:13,1170.271,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24393,515,514,8,8,11,170,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3494,3482,3480,3482,3482,3482,3492,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1057,SUCCESS
    293,2021-07-01 16:26:17,1174.276,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24395,514,514,8,8,11,171,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3494,3482,3480,3482,3482,3482,3492,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1022,SUCCESS
    294,2021-07-01 16:26:21,1178.287,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24394,514,514,8,8,11,172,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3494,3482,3481,3482,3482,3483,3493,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1028,SUCCESS
    295,2021-07-01 16:26:25,1182.295,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24400,514,514,8,8,11,172,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3495,3482,3481,3483,3483,3483,3493,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1006,SUCCESS
    296,2021-07-01 16:26:29,1186.309,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24402,513,514,8,8,11,173,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3495,3483,3481,3483,3483,3483,3494,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,973,SUCCESS
    297,2021-07-01 16:26:33,1190.318,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24404,514,514,8,8,11,173,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3495,3483,3482,3483,3484,3484,3494,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1013,SUCCESS
    298,2021-07-01 16:26:37,1194.329,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24404,514,514,8,8,11,174,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3495,3483,3482,3483,3484,3483,3494,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1062,SUCCESS
    299,2021-07-01 16:26:41,1198.342,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24405,514,514,8,8,11,174,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3495,3483,3482,3483,3484,3484,3494,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1002,SUCCESS
    300,2021-07-01 16:26:45,1202.358,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24407,515,514,8,8,11,175,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3496,3484,3483,3484,3484,3484,3495,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1003,SUCCESS
    301,2021-07-01 16:26:49,1206.352,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24411,513,514,8,8,11,176,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3496,3484,3483,3484,3485,3484,3495,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1071,SUCCESS
    302,2021-07-01 16:26:53,1210.353,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24413,514,514,8,8,11,176,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3496,3485,3483,3485,3485,3484,3495,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1024,SUCCESS
    303,2021-07-01 16:26:57,1214.357,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24415,513,514,8,8,11,177,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3497,3485,3483,3485,3485,3485,3495,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,1020,SUCCESS
    304,2021-07-01 16:27:01,1218.362,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24416,514,514,8,8,11,177,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3497,3485,3483,3485,3486,3485,3496,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.3,1046,SUCCESS
    305,2021-07-01 16:27:05,1222.375,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24420,514,514,8,8,11,178,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3497,3485,3484,3486,3486,3486,3496,0,0,0,0,0,0,0,0,2695,24.2,24.2,-273.2,24.2,-273.2,33.4,986,SUCCESS
    306,2021-07-01 16:27:09,1226.388,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24422,515,514,8,8,11,178,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3498,3486,3484,3486,3486,3486,3496,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1162,SUCCESS
    307,2021-07-01 16:27:13,1230.396,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24424,514,514,8,8,11,179,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3498,3486,3484,3486,3487,3487,3496,0,0,0,0,0,0,0,0,2696,24.2,24.2,-273.2,24.2,-273.2,33.3,1108,SUCCESS
    308,2021-07-01 16:27:17,1234.411,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24427,514,514,8,8,11,179,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3498,3487,3485,3486,3487,3487,3497,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1029,SUCCESS
    309,2021-07-01 16:27:21,1238.412,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24427,514,514,8,8,11,180,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3498,3487,3485,3486,3487,3487,3497,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,996,SUCCESS
    310,2021-07-01 16:27:25,1242.427,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24428,514,514,8,8,11,181,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3499,3487,3485,3486,3488,3487,3497,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1013,SUCCESS
    311,2021-07-01 16:27:29,1246.442,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24430,514,514,8,8,11,181,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3499,3487,3485,3487,3488,3488,3497,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,980,SUCCESS
    312,2021-07-01 16:27:33,1250.457,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24433,515,514,8,8,11,182,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3499,3487,3485,3487,3488,3488,3498,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1029,SUCCESS
    313,2021-07-01 16:27:37,1254.463,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24436,515,514,8,8,11,182,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3499,3488,3486,3487,3489,3488,3498,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,962,SUCCESS
    314,2021-07-01 16:27:41,1258.471,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24436,514,514,8,8,11,183,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3499,3488,3486,3488,3489,3488,3498,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1031,SUCCESS
    315,2021-07-01 16:27:45,1262.477,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24440,513,514,8,8,11,183,2352,65535,65535,325,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3500,3488,3486,3488,3490,3489,3499,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1010,SUCCESS
    316,2021-07-01 16:27:49,1266.481,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24440,514,514,8,8,12,184,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3500,3488,3486,3488,3490,3489,3499,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1022,SUCCESS
    317,2021-07-01 16:27:53,1270.488,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24443,515,514,8,8,12,185,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3501,3489,3487,3489,3490,3489,3499,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1046,SUCCESS
    318,2021-07-01 16:27:57,1274.504,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24446,514,514,8,8,12,185,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3501,3489,3487,3489,3492,3489,3499,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1032,SUCCESS
    319,2021-07-01 16:28:01,1278.510,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24449,514,514,8,8,12,186,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3501,3490,3488,3489,3492,3490,3500,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1009,SUCCESS
    320,2021-07-01 16:28:05,1282.512,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24451,514,514,8,8,12,186,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3501,3490,3488,3490,3493,3490,3499,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1053,SUCCESS
    321,2021-07-01 16:28:09,1286.519,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24453,514,514,8,8,12,187,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3501,3490,3488,3490,3493,3490,3500,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1032,SUCCESS
    322,2021-07-01 16:28:13,1290.519,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24455,514,514,8,8,12,188,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3502,3490,3488,3490,3493,3491,3500,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1017,SUCCESS
    323,2021-07-01 16:28:17,1294.521,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24457,513,514,8,8,12,188,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3502,3491,3489,3490,3493,3491,3501,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1061,SUCCESS
    324,2021-07-01 16:28:21,1298.526,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24458,513,514,8,9,12,189,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3502,3491,3489,3490,3493,3492,3501,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,993,SUCCESS
    325,2021-07-01 16:28:25,1302.528,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24460,514,514,8,9,12,189,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3503,3491,3489,3491,3493,3492,3502,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.5,1073,SUCCESS
    326,2021-07-01 16:28:29,1306.532,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24463,514,514,8,9,12,190,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3503,3492,3490,3491,3493,3492,3502,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1034,SUCCESS
    327,2021-07-01 16:28:33,1310.542,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24464,514,514,8,9,12,190,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3504,3492,3490,3491,3493,3492,3502,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1037,SUCCESS
    328,2021-07-01 16:28:37,1314.550,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24464,515,514,8,9,12,191,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3504,3492,3490,3491,3493,3492,3502,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.3,1069,SUCCESS
    329,2021-07-01 16:28:41,1318.564,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24465,514,514,8,9,12,192,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3504,3493,3490,3492,3493,3492,3503,0,0,0,0,0,0,0,0,2700,24.2,24.2,-273.2,24.2,-273.2,33.4,1017,SUCCESS
    330,2021-07-01 16:28:45,1322.569,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24469,514,514,8,9,12,192,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3504,3493,3491,3492,3493,3493,3503,0,0,0,0,0,0,0,0,2701,24.2,24.2,-273.2,24.2,-273.2,33.4,999,SUCCESS
    331,2021-07-01 16:28:49,1326.572,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24469,514,514,8,9,12,193,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3504,3493,3491,3493,3493,3493,3503,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1010,SUCCESS
    332,2021-07-01 16:28:53,1330.583,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24472,513,514,8,9,12,193,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3505,3493,3491,3493,3493,3493,3503,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.5,967,SUCCESS
    333,2021-07-01 16:28:57,1334.596,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24473,515,514,8,9,12,194,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3505,3494,3491,3493,3493,3494,3503,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.3,1016,SUCCESS
    334,2021-07-01 16:29:01,1338.601,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24474,514,514,8,9,12,194,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3505,3494,3492,3493,3493,3494,3504,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1024,SUCCESS
    335,2021-07-01 16:29:05,1342.611,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24475,513,514,8,9,12,195,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3505,3494,3492,3493,3493,3495,3504,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.3,1095,SUCCESS
    336,2021-07-01 16:29:09,1346.626,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24476,514,514,8,9,12,196,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3506,3494,3492,3494,3493,3495,3504,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.3,1062,SUCCESS
    337,2021-07-01 16:29:13,1350.630,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24479,514,514,8,9,12,196,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3506,3494,3492,3494,3493,3495,3505,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,1014,SUCCESS
    338,2021-07-01 16:29:17,1354.639,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24481,514,514,8,9,12,197,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3495,3493,3494,3493,3495,3505,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,973,SUCCESS
    339,2021-07-01 16:29:21,1358.643,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24482,514,514,8,9,12,197,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3495,3493,3494,3493,3495,3505,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,1082,SUCCESS
    340,2021-07-01 16:29:25,1362.654,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24484,514,514,8,9,12,198,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3495,3493,3495,3493,3496,3505,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,988,SUCCESS
    341,2021-07-01 16:29:29,1366.670,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24486,514,514,8,9,12,198,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3496,3494,3495,3493,3496,3506,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,988,SUCCESS
    342,2021-07-01 16:29:33,1370.685,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24487,514,514,8,9,12,199,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3496,3494,3495,3493,3496,3506,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,989,SUCCESS
    343,2021-07-01 16:29:37,1374.681,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24488,514,514,8,9,12,200,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3507,3496,3494,3496,3493,3496,3506,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1008,SUCCESS
    344,2021-07-01 16:29:41,1378.691,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24492,514,514,8,9,12,200,2352,65535,65535,323,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3508,3496,3494,3496,3493,3497,3507,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1032,SUCCESS
    345,2021-07-01 16:29:45,1382.705,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24492,514,514,8,9,13,201,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3508,3497,3495,3496,3493,3497,3507,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,1017,SUCCESS
    346,2021-07-01 16:29:49,1386.708,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24495,515,514,8,9,13,201,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3508,3497,3495,3497,3493,3498,3507,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1012,SUCCESS
    347,2021-07-01 16:29:53,1390.720,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24497,514,514,8,9,13,202,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3509,3497,3495,3497,3495,3498,3507,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1050,SUCCESS
    348,2021-07-01 16:29:57,1394.728,0x0701,150,10,0x6001,0,65535,65535,1,24.2,24498,514,514,8,9,13,202,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3509,3498,3496,3497,3495,3498,3507,0,0,0,0,0,0,0,0,2705,24.2,24.2,-273.2,24.2,-273.2,33.4,1009,SUCCESS
    349,2021-07-01 16:30:01,1398.733,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24501,513,514,8,9,13,203,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3509,3498,3496,3497,3495,3498,3508,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,989,SUCCESS
    350,2021-07-01 16:30:05,1402.742,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24503,514,514,8,9,13,204,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3510,3498,3496,3497,3495,3498,3508,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.5,1016,SUCCESS
    351,2021-07-01 16:30:09,1406.753,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24506,514,514,8,9,13,204,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3510,3499,3496,3498,3496,3499,3509,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,1029,SUCCESS
    352,2021-07-01 16:30:13,1410.762,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24509,514,514,8,9,13,205,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3499,3497,3498,3496,3499,3509,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.3,1059,SUCCESS
    353,2021-07-01 16:30:17,1414.776,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24511,514,514,8,9,13,205,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3497,3499,3496,3499,3509,0,0,0,0,0,0,0,0,2705,24.2,24.3,-273.2,24.3,-273.2,33.4,1054,SUCCESS
    354,2021-07-01 16:30:21,1418.779,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24512,514,514,8,9,13,206,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3497,3499,3497,3500,3509,0,0,0,0,0,0,0,0,2709,24.2,24.3,-273.2,24.3,-273.2,33.5,989,SUCCESS
    355,2021-07-01 16:30:25,1422.793,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24513,514,514,8,9,13,207,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3497,3499,3498,3500,3510,0,0,0,0,0,0,0,0,2710,24.2,24.2,-273.2,24.2,-273.2,33.4,1070,SUCCESS
    356,2021-07-01 16:30:29,1426.797,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24515,514,514,8,9,13,207,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3498,3499,3498,3500,3510,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1050,SUCCESS
    357,2021-07-01 16:30:33,1430.811,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24517,514,514,8,9,13,208,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3498,3500,3498,3500,3510,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1050,SUCCESS
    358,2021-07-01 16:30:37,1434.826,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24519,514,514,8,9,13,208,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3511,3500,3498,3500,3498,3501,3511,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1035,SUCCESS
    359,2021-07-01 16:30:41,1438.833,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24521,515,514,8,9,13,209,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3512,3501,3499,3500,3499,3501,3511,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1060,SUCCESS
    360,2021-07-01 16:30:45,1442.845,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24523,514,514,8,9,13,209,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3512,3501,3499,3500,3499,3502,3511,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,969,SUCCESS
    361,2021-07-01 16:30:49,1446.848,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24526,515,514,8,9,13,210,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3513,3501,3499,3501,3499,3502,3511,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1030,SUCCESS
    362,2021-07-01 16:30:53,1450.858,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24529,514,514,8,9,13,211,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3513,3502,3499,3501,3500,3502,3512,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,989,SUCCESS
    363,2021-07-01 16:30:57,1454.865,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24530,514,514,8,9,13,211,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3513,3502,3500,3501,3500,3502,3512,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,999,SUCCESS
    364,2021-07-01 16:31:02,1458.874,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24534,514,514,8,10,13,212,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3513,3502,3500,3502,3501,3503,3513,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1064,SUCCESS
    365,2021-07-01 16:31:06,1462.880,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24536,514,514,8,10,13,212,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3514,3502,3500,3502,3501,3503,3513,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,967,SUCCESS
    366,2021-07-01 16:31:10,1466.888,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24538,514,514,8,10,13,213,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3514,3503,3501,3502,3501,3503,3513,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1068,SUCCESS
    367,2021-07-01 16:31:14,1470.901,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24539,513,514,8,10,13,213,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3514,3503,3501,3502,3501,3504,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1041,SUCCESS
    368,2021-07-01 16:31:18,1474.902,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24541,514,514,8,10,13,214,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3514,3503,3501,3503,3501,3504,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,993,SUCCESS
    369,2021-07-01 16:31:22,1478.904,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24542,515,514,8,10,13,215,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3515,3503,3502,3503,3502,3504,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1082,SUCCESS
    370,2021-07-01 16:31:26,1482.911,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24544,514,514,8,10,13,215,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3515,3504,3502,3503,3502,3504,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,997,SUCCESS
    371,2021-07-01 16:31:30,1486.915,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24544,514,514,8,10,13,216,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3515,3504,3502,3503,3502,3504,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1043,SUCCESS
    372,2021-07-01 16:31:34,1490.925,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24548,515,514,8,10,13,216,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3516,3505,3502,3504,3503,3505,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1063,SUCCESS
    373,2021-07-01 16:31:38,1494.937,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24549,514,514,8,10,14,217,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3516,3505,3502,3504,3503,3505,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,940,SUCCESS
    374,2021-07-01 16:31:42,1498.941,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24551,514,514,8,10,14,217,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3516,3505,3502,3504,3504,3505,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.5,1093,SUCCESS
    375,2021-07-01 16:31:46,1502.941,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24552,514,514,8,10,14,218,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3517,3505,3502,3505,3504,3505,3514,0,0,0,0,0,0,0,0,2710,24.2,24.3,-273.2,24.3,-273.2,33.4,1029,SUCCESS
    376,2021-07-01 16:31:50,1506.944,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24554,514,514,8,10,14,219,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3517,3506,3502,3505,3504,3506,3514,0,0,0,0,0,0,0,0,2711,24.2,24.3,-273.2,24.3,-273.2,33.4,1090,SUCCESS
    377,2021-07-01 16:31:54,1510.959,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24556,514,514,8,10,14,219,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3517,3506,3502,3505,3504,3507,3515,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1027,SUCCESS
    378,2021-07-01 16:31:58,1514.969,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24558,514,514,8,10,14,220,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3517,3506,3503,3506,3505,3507,3515,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,987,SUCCESS
    379,2021-07-01 16:32:02,1518.977,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24559,514,514,8,10,14,220,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3517,3507,3503,3506,3505,3507,3516,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1025,SUCCESS
    380,2021-07-01 16:32:06,1522.988,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24561,514,514,8,10,14,221,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3518,3507,3503,3506,3505,3507,3516,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1077,SUCCESS
    381,2021-07-01 16:32:10,1526.995,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24565,514,514,8,10,14,221,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3518,3507,3505,3506,3505,3507,3517,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1007,SUCCESS
    382,2021-07-01 16:32:14,1531.006,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24568,514,514,8,10,14,222,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3519,3508,3505,3507,3505,3508,3517,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1014,SUCCESS
    383,2021-07-01 16:32:18,1535.010,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24570,513,514,8,10,14,223,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3519,3508,3505,3507,3506,3508,3517,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1007,SUCCESS
    384,2021-07-01 16:32:22,1539.025,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24571,514,514,8,10,14,223,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3519,3508,3505,3508,3506,3508,3517,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.1,1028,SUCCESS
    385,2021-07-01 16:32:26,1543.032,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24575,514,514,8,10,14,224,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3520,3508,3506,3508,3507,3508,3518,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.5,1054,SUCCESS
    386,2021-07-01 16:32:30,1547.035,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24576,514,514,8,10,14,224,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3520,3509,3506,3508,3507,3507,3518,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.5,1029,SUCCESS
    387,2021-07-01 16:32:34,1551.038,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24578,513,514,8,10,14,225,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3520,3509,3506,3509,3507,3506,3518,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.5,962,SUCCESS
    388,2021-07-01 16:32:38,1555.042,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24580,514,514,8,10,14,225,2352,65535,65535,320,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3521,3509,3506,3509,3508,3509,3519,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1022,SUCCESS
    389,2021-07-01 16:32:42,1559.053,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24583,514,514,8,10,14,226,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3521,3510,3507,3509,3508,3510,3519,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.0,985,SUCCESS
    390,2021-07-01 16:32:46,1563.064,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24584,514,514,8,10,14,227,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3521,3510,3507,3509,3508,3510,3519,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1033,SUCCESS
    391,2021-07-01 16:32:50,1567.066,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24586,514,514,8,10,14,227,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3521,3510,3508,3509,3508,3511,3520,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1078,SUCCESS
    392,2021-07-01 16:32:54,1571.069,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24588,514,514,8,10,14,228,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3521,3511,3508,3509,3509,3512,3520,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1028,SUCCESS
    393,2021-07-01 16:32:58,1575.072,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24590,514,514,8,10,14,228,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3522,3511,3508,3509,3509,3515,3520,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1008,SUCCESS
    394,2021-07-01 16:33:02,1579.076,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24591,513,514,8,10,14,229,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3522,3511,3508,3509,3510,3516,3520,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.1,1010,SUCCESS
    395,2021-07-01 16:33:06,1583.082,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24593,514,514,8,10,14,230,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3522,3511,3508,3509,3510,3513,3521,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.5,1066,SUCCESS
    396,2021-07-01 16:33:10,1587.083,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24596,514,514,8,10,14,230,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3523,3511,3509,3509,3510,3512,3521,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.4,1028,SUCCESS
    397,2021-07-01 16:33:14,1591.097,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24598,514,514,8,10,14,231,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3523,3512,3509,3510,3510,3512,3522,0,0,0,0,0,0,0,0,2715,24.2,24.3,-273.2,24.3,-273.2,33.5,1185,SUCCESS
    398,2021-07-01 16:33:18,1595.108,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24603,514,514,8,10,14,231,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3524,3512,3509,3511,3511,3513,3522,0,0,0,0,0,0,0,0,2716,24.2,24.3,-273.2,24.3,-273.2,33.3,1024,SUCCESS
    399,2021-07-01 16:33:22,1599.118,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24604,514,514,8,10,14,232,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3524,3513,3510,3511,3511,3513,3522,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.3,976,SUCCESS
    400,2021-07-01 16:33:26,1603.119,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24604,515,514,8,10,14,232,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3524,3513,3510,3512,3511,3513,3522,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,962,SUCCESS
    401,2021-07-01 16:33:30,1607.123,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24607,514,514,8,10,14,233,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3524,3513,3511,3512,3512,3514,3523,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1068,SUCCESS
    402,2021-07-01 16:33:34,1611.134,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24611,514,514,8,10,15,234,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3524,3514,3511,3512,3512,3514,3523,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1008,SUCCESS
    403,2021-07-01 16:33:38,1615.136,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24612,514,514,8,10,15,234,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3525,3514,3511,3512,3512,3515,3524,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,990,SUCCESS
    404,2021-07-01 16:33:42,1619.146,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24614,513,514,8,10,15,235,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3525,3514,3511,3513,3512,3515,3524,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.2,1050,SUCCESS
    405,2021-07-01 16:33:46,1623.157,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24615,513,514,8,10,15,235,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3525,3514,3512,3514,3513,3515,3524,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1110,SUCCESS
    406,2021-07-01 16:33:50,1627.159,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24619,513,514,8,11,15,236,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3525,3514,3512,3514,3513,3516,3525,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1062,SUCCESS
    407,2021-07-01 16:33:54,1631.167,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24621,514,514,8,11,15,236,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3526,3515,3512,3514,3513,3516,3525,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1101,SUCCESS
    408,2021-07-01 16:33:58,1635.171,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24622,514,514,8,11,15,237,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3526,3515,3512,3514,3514,3516,3525,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,955,SUCCESS
    409,2021-07-01 16:34:02,1639.186,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24624,514,514,8,11,15,238,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3527,3516,3513,3514,3514,3516,3525,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.3,1040,SUCCESS
    410,2021-07-01 16:34:06,1643.194,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24628,514,514,8,11,15,238,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3527,3516,3513,3515,3515,3516,3526,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1043,SUCCESS
    411,2021-07-01 16:34:10,1647.203,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24629,514,514,8,11,15,239,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3527,3516,3514,3515,3515,3516,3526,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1017,SUCCESS
    412,2021-07-01 16:34:14,1651.205,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24630,514,514,8,11,15,239,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3527,3517,3514,3515,3515,3516,3526,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1047,SUCCESS
    413,2021-07-01 16:34:18,1655.218,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24632,515,514,8,11,15,240,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3528,3517,3514,3516,3515,3516,3527,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1050,SUCCESS
    414,2021-07-01 16:34:22,1659.226,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24633,514,514,8,11,15,240,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3528,3517,3514,3516,3516,3516,3527,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.3,1026,SUCCESS
    415,2021-07-01 16:34:26,1663.226,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24637,514,514,8,11,15,241,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3529,3518,3515,3517,3516,3516,3528,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,994,SUCCESS
    416,2021-07-01 16:34:30,1667.228,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24641,514,514,8,11,15,242,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3529,3518,3515,3517,3516,3517,3528,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1101,SUCCESS
    417,2021-07-01 16:34:34,1671.239,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24643,514,514,8,11,15,242,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3529,3519,3516,3517,3516,3518,3528,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.5,1029,SUCCESS
    418,2021-07-01 16:34:38,1675.253,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24646,514,514,8,11,15,243,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3516,3517,3517,3519,3528,0,0,0,0,0,0,0,0,2720,24.2,24.3,-273.2,24.3,-273.2,33.4,1109,SUCCESS
    419,2021-07-01 16:34:42,1679.257,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24647,514,514,8,11,15,243,2352,65535,65535,318,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3516,3518,3517,3519,3528,0,0,0,0,0,0,0,0,2724,24.2,24.3,-273.2,24.3,-273.2,33.5,1058,SUCCESS
    420,2021-07-01 16:34:46,1683.264,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24649,515,514,8,11,15,244,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3516,3518,3517,3519,3529,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1083,SUCCESS
    421,2021-07-01 16:34:50,1687.274,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24651,515,514,8,11,15,244,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3517,3519,3518,3519,3529,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1058,SUCCESS
    422,2021-07-01 16:34:54,1691.278,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24652,514,514,8,11,15,245,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3517,3519,3518,3520,3529,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.4,974,SUCCESS
    423,2021-07-01 16:34:58,1695.279,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24653,514,514,8,11,15,246,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3517,3519,3519,3520,3530,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,991,SUCCESS
    424,2021-07-01 16:35:02,1699.290,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24656,514,514,8,11,15,246,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3518,3519,3519,3520,3530,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1103,SUCCESS
    425,2021-07-01 16:35:06,1703.296,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24659,513,514,8,11,15,247,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3519,3518,3520,3519,3521,3531,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1002,SUCCESS
    426,2021-07-01 16:35:10,1707.311,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24659,515,514,8,11,15,247,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3530,3520,3518,3520,3519,3521,3531,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.4,1067,SUCCESS
    427,2021-07-01 16:35:14,1711.311,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24661,515,514,8,11,15,248,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3531,3520,3519,3521,3519,3522,3531,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1052,SUCCESS
    428,2021-07-01 16:35:18,1715.325,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24666,514,514,8,11,15,248,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3531,3521,3519,3521,3520,3522,3532,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1038,SUCCESS
    429,2021-07-01 16:35:22,1719.334,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24667,515,514,8,11,15,249,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3532,3522,3520,3521,3520,3522,3532,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,996,SUCCESS
    430,2021-07-01 16:35:26,1723.344,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24672,514,514,8,11,15,250,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3533,3522,3520,3522,3521,3522,3532,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1067,SUCCESS
    431,2021-07-01 16:35:30,1727.348,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24673,513,514,8,11,15,250,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3533,3522,3520,3522,3521,3523,3532,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1062,SUCCESS
    432,2021-07-01 16:35:34,1731.360,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24674,515,514,8,11,16,251,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3533,3523,3520,3522,3521,3523,3533,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.4,1095,SUCCESS
    433,2021-07-01 16:35:38,1735.373,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24678,514,514,8,11,16,251,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3534,3523,3521,3522,3522,3524,3533,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1003,SUCCESS
    434,2021-07-01 16:35:42,1739.385,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24680,515,514,8,11,16,252,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3534,3523,3521,3523,3522,3524,3534,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,961,SUCCESS
    435,2021-07-01 16:35:46,1743.396,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24681,514,514,8,11,16,253,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3534,3524,3521,3523,3522,3524,3534,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.3,1049,SUCCESS
    436,2021-07-01 16:35:50,1747.404,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24687,514,514,8,11,16,253,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3535,3524,3522,3524,3523,3525,3535,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1021,SUCCESS
    437,2021-07-01 16:35:54,1751.409,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24688,514,514,8,11,16,254,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3535,3525,3522,3524,3523,3525,3535,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.4,984,SUCCESS
    438,2021-07-01 16:35:58,1755.413,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24691,514,514,8,11,16,254,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3536,3525,3523,3524,3524,3525,3535,0,0,0,0,0,0,0,0,2725,24.2,24.3,-273.2,24.3,-273.2,33.5,1102,SUCCESS
    439,2021-07-01 16:36:02,1759.425,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24693,514,514,8,11,16,255,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3536,3525,3523,3525,3524,3526,3536,0,0,0,0,0,0,0,0,2729,24.2,24.3,-273.2,24.3,-273.2,33.4,1062,SUCCESS
    440,2021-07-01 16:36:06,1763.433,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24694,515,514,8,11,16,255,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3536,3525,3523,3525,3524,3526,3536,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1038,SUCCESS
    441,2021-07-01 16:36:10,1767.436,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24697,514,514,8,11,16,256,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3537,3526,3523,3525,3524,3526,3537,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1082,SUCCESS
    442,2021-07-01 16:36:14,1771.436,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24700,514,514,8,11,16,257,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3537,3526,3524,3526,3525,3527,3537,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.4,956,SUCCESS
    443,2021-07-01 16:36:18,1775.448,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24702,514,514,8,11,16,257,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3537,3526,3525,3526,3525,3527,3538,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1039,SUCCESS
    444,2021-07-01 16:36:22,1779.454,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24703,515,515,8,11,16,258,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3537,3527,3525,3526,3525,3527,3538,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,987,SUCCESS
    445,2021-07-01 16:36:26,1783.463,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24707,515,515,8,11,16,258,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3538,3527,3525,3527,3526,3528,3538,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.4,1087,SUCCESS
    446,2021-07-01 16:36:30,1787.468,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24709,516,515,8,12,16,259,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3538,3528,3526,3527,3527,3528,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.4,1020,SUCCESS
    447,2021-07-01 16:36:34,1791.468,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24711,514,514,8,12,16,259,2352,65535,65535,316,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3539,3528,3526,3527,3527,3530,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1097,SUCCESS
    448,2021-07-01 16:36:38,1795.482,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24719,514,515,8,12,16,260,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3539,3528,3527,3528,3527,3529,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.4,1083,SUCCESS
    449,2021-07-01 16:36:42,1799.488,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24720,515,515,8,12,16,261,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3539,3528,3528,3528,3527,3530,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1108,SUCCESS
    450,2021-07-01 16:36:46,1803.496,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24723,515,515,8,12,16,261,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3539,3529,3528,3528,3528,3530,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1017,SUCCESS
    451,2021-07-01 16:36:50,1807.509,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24725,514,515,8,12,16,262,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3540,3529,3528,3529,3528,3530,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,977,SUCCESS
    452,2021-07-01 16:36:54,1811.510,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24729,514,515,8,12,16,262,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3540,3529,3528,3529,3528,3530,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,993,SUCCESS
    453,2021-07-01 16:36:58,1815.522,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24726,514,515,8,12,16,263,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3540,3530,3528,3530,3529,3531,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1017,SUCCESS
    454,2021-07-01 16:37:02,1819.528,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24729,514,515,8,12,16,263,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3541,3531,3528,3530,3529,3531,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,972,SUCCESS
    455,2021-07-01 16:37:06,1823.537,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24730,514,515,8,12,16,264,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3542,3531,3528,3530,3529,3531,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,998,SUCCESS
    456,2021-07-01 16:37:10,1827.551,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24733,514,514,8,12,16,265,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3542,3531,3528,3531,3530,3531,3540,0,0,0,0,0,0,0,0,2730,24.2,24.3,-273.2,24.3,-273.2,33.5,1028,SUCCESS
    457,2021-07-01 16:37:14,1831.561,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24735,513,514,8,12,16,265,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3542,3532,3528,3531,3530,3532,3540,0,0,0,0,0,0,0,0,2734,24.2,24.3,-273.2,24.3,-273.2,33.5,1112,SUCCESS
    458,2021-07-01 16:37:18,1835.571,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24737,514,514,8,12,16,266,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3543,3532,3528,3532,3530,3532,3541,0,0,0,0,0,0,0,0,2734,24.2,24.3,-273.2,24.3,-273.2,33.3,1108,SUCCESS
    459,2021-07-01 16:37:22,1839.571,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24740,514,514,8,12,16,266,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3543,3532,3528,3532,3531,3533,3541,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,963,SUCCESS
    460,2021-07-01 16:37:26,1843.576,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24740,513,514,8,12,17,267,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3544,3532,3529,3532,3531,3533,3541,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.5,990,SUCCESS
    461,2021-07-01 16:37:30,1847.578,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24746,514,514,8,12,17,267,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3543,3533,3529,3533,3531,3534,3542,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,1065,SUCCESS
    462,2021-07-01 16:37:34,1851.583,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24749,515,514,8,12,17,268,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3544,3534,3529,3534,3532,3534,3542,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.5,997,SUCCESS
    463,2021-07-01 16:37:38,1855.593,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24753,514,514,8,12,17,269,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3545,3534,3530,3535,3532,3534,3543,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.0,1073,SUCCESS
    464,2021-07-01 16:37:42,1859.600,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24754,515,514,8,12,17,269,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3545,3534,3530,3535,3532,3535,3543,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,996,SUCCESS
    465,2021-07-01 16:37:46,1863.615,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24757,515,514,8,12,17,270,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3545,3534,3531,3535,3533,3535,3544,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.6,1048,SUCCESS
    466,2021-07-01 16:37:50,1867.622,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24759,515,515,8,12,17,270,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3545,3535,3531,3535,3533,3536,3545,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.6,990,SUCCESS
    467,2021-07-01 16:37:54,1871.623,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24762,515,515,8,12,17,271,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3545,3535,3532,3535,3534,3536,3544,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,973,SUCCESS
    468,2021-07-01 16:37:58,1875.627,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24763,514,515,8,12,17,271,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3546,3536,3532,3535,3534,3536,3545,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.4,1068,SUCCESS
    469,2021-07-01 16:38:02,1879.628,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24765,514,515,8,12,17,272,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3547,3536,3532,3535,3534,3536,3546,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,1045,SUCCESS
    470,2021-07-01 16:38:06,1883.643,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24768,514,515,8,12,17,273,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3547,3536,3533,3535,3535,3537,3546,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.5,1032,SUCCESS
    471,2021-07-01 16:38:10,1887.655,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24771,515,515,8,12,17,273,2352,65535,65535,314,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3547,3537,3533,3535,3535,3537,3546,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.4,1050,SUCCESS
    472,2021-07-01 16:38:14,1891.661,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24774,516,515,8,12,17,274,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3548,3537,3534,3535,3536,3537,3546,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.5,1029,SUCCESS
    473,2021-07-01 16:38:18,1895.664,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24775,515,515,8,12,17,274,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3548,3537,3534,3535,3536,3536,3546,0,0,0,0,0,0,0,0,2735,24.2,24.4,-273.2,24.4,-273.2,33.5,993,SUCCESS
    474,2021-07-01 16:38:22,1899.679,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24777,514,515,8,12,17,275,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3548,3538,3534,3535,3536,3539,3547,0,0,0,0,0,0,0,0,2735,24.2,24.3,-273.2,24.3,-273.2,33.5,1013,SUCCESS
    475,2021-07-01 16:38:26,1903.680,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24783,515,515,8,12,17,276,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3549,3538,3535,3536,3536,3540,3547,0,0,0,0,0,0,0,0,2739,24.2,24.3,-273.2,24.3,-273.2,33.4,997,SUCCESS
    476,2021-07-01 16:38:30,1907.682,0x0701,150,10,0x6001,0,65535,65535,1,24.3,24786,514,515,8,12,17,276,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3549,3539,3535,3537,3537,3541,3548,0,0,0,0,0,0,0,0,2740,24.2,24.3,-273.2,24.3,-273.2,33.5,1008,SUCCESS
    477,2021-07-01 16:38:34,1911.691,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24787,515,515,8,12,17,277,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3550,3539,3535,3537,3537,3542,3548,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1060,SUCCESS
    478,2021-07-01 16:38:38,1915.705,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24792,515,515,8,12,17,277,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3550,3539,3536,3538,3538,3542,3549,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1031,SUCCESS
    479,2021-07-01 16:38:42,1919.718,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24795,515,515,8,12,17,278,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3550,3540,3536,3538,3539,3542,3549,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1032,SUCCESS
    480,2021-07-01 16:38:46,1923.721,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24796,516,515,8,12,17,278,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3551,3540,3537,3538,3539,3542,3549,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1109,SUCCESS
    481,2021-07-01 16:38:50,1927.737,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24798,514,515,8,12,17,279,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3551,3540,3537,3539,3539,3544,3550,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1094,SUCCESS
    482,2021-07-01 16:38:54,1931.739,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24800,514,515,8,12,17,280,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3551,3541,3537,3539,3539,3542,3550,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1061,SUCCESS
    483,2021-07-01 16:38:58,1935.749,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24804,515,515,8,12,17,280,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3552,3542,3538,3540,3539,3542,3551,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1067,SUCCESS
    484,2021-07-01 16:39:02,1939.754,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24805,515,515,8,12,17,281,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3552,3542,3538,3540,3539,3542,3551,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.6,1114,SUCCESS
    485,2021-07-01 16:39:06,1943.755,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24806,515,515,8,12,17,281,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3553,3542,3539,3541,3539,3542,3551,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1011,SUCCESS
    486,2021-07-01 16:39:10,1947.764,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24809,515,515,8,12,17,282,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3553,3543,3539,3541,3539,3542,3552,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1018,SUCCESS
    487,2021-07-01 16:39:14,1951.777,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24812,515,515,8,12,17,282,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3554,3544,3539,3541,3540,3542,3552,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.6,1008,SUCCESS
    488,2021-07-01 16:39:18,1955.776,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24815,516,515,8,13,17,283,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3554,3545,3540,3542,3541,3542,3552,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1022,SUCCESS
    489,2021-07-01 16:39:22,1959.785,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24818,515,515,8,13,18,284,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3555,3545,3540,3542,3541,3543,3553,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1077,SUCCESS
    490,2021-07-01 16:39:26,1963.795,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24823,515,515,8,13,18,284,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3556,3545,3540,3542,3542,3544,3553,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,989,SUCCESS
    491,2021-07-01 16:39:30,1967.795,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24825,515,515,8,13,18,285,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3541,3543,3542,3544,3554,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1019,SUCCESS
    492,2021-07-01 16:39:34,1971.800,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24826,515,515,8,13,18,285,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3541,3543,3542,3544,3554,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,1063,SUCCESS
    493,2021-07-01 16:39:38,1975.802,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24829,514,515,8,13,18,286,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3541,3543,3543,3545,3554,0,0,0,0,0,0,0,0,2740,24.2,24.4,-273.2,24.4,-273.2,33.5,996,SUCCESS
    494,2021-07-01 16:39:42,1979.810,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24831,514,515,8,13,18,286,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3542,3544,3544,3545,3555,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1066,SUCCESS
    495,2021-07-01 16:39:46,1983.812,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24832,515,515,8,13,18,287,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3542,3544,3544,3546,3555,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.6,979,SUCCESS
    496,2021-07-01 16:39:50,1987.818,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24836,515,515,8,13,18,288,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3543,3545,3544,3546,3556,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.6,1028,SUCCESS
    497,2021-07-01 16:39:54,1991.831,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24837,515,515,8,13,18,288,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3543,3545,3545,3546,3556,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1125,SUCCESS
    498,2021-07-01 16:39:58,1995.832,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24839,514,515,8,13,18,289,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3543,3546,3545,3547,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1092,SUCCESS
    499,2021-07-01 16:40:02,1999.838,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24841,515,515,8,13,18,289,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3545,3544,3546,3545,3547,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,959,SUCCESS
    500,2021-07-01 16:40:06,2003.841,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24842,514,515,8,13,18,290,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3546,3544,3546,3546,3548,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1036,SUCCESS
    501,2021-07-01 16:40:10,2007.847,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24846,514,515,8,13,18,290,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3546,3545,3546,3546,3548,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1017,SUCCESS
    502,2021-07-01 16:40:14,2011.861,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24848,515,515,8,13,18,291,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3557,3547,3545,3547,3546,3548,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.6,1111,SUCCESS
    503,2021-07-01 16:40:18,2015.862,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24851,515,515,8,13,18,292,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3558,3548,3545,3548,3547,3549,3557,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1062,SUCCESS
    504,2021-07-01 16:40:23,2019.874,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24853,515,515,8,13,18,292,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3558,3548,3545,3548,3547,3550,3558,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,940,SUCCESS
    505,2021-07-01 16:40:27,2023.882,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24856,515,515,8,13,18,293,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3559,3548,3545,3548,3548,3550,3558,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,1059,SUCCESS
    506,2021-07-01 16:40:31,2027.889,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24860,514,515,8,13,18,293,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3559,3549,3546,3548,3548,3550,3559,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.5,974,SUCCESS
    507,2021-07-01 16:40:35,2031.898,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24861,515,515,8,13,18,294,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3560,3549,3546,3549,3548,3550,3559,0,0,0,0,0,0,0,0,2745,24.2,24.4,-273.2,24.4,-273.2,33.6,1041,SUCCESS
    508,2021-07-01 16:40:39,2035.907,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24865,515,515,8,13,18,294,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3560,3549,3547,3549,3549,3551,3560,0,0,0,0,0,0,0,0,2745,24.3,24.5,-273.2,24.4,-273.2,33.6,1103,SUCCESS
    509,2021-07-01 16:40:43,2039.913,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24867,515,515,8,13,18,295,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3560,3550,3547,3550,3549,3551,3560,0,0,0,0,0,0,0,0,2745,24.3,24.4,-273.2,24.4,-273.2,33.5,1073,SUCCESS
    510,2021-07-01 16:40:47,2043.913,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24871,515,515,8,13,18,296,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3561,3550,3548,3550,3550,3552,3561,0,0,0,0,0,0,0,0,2749,24.3,24.4,-273.2,24.4,-273.2,33.5,974,SUCCESS
    511,2021-07-01 16:40:51,2047.928,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24873,515,515,8,13,18,296,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3561,3551,3548,3550,3550,3552,3561,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1042,SUCCESS
    512,2021-07-01 16:40:55,2051.941,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24877,515,515,8,13,18,297,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3562,3551,3548,3551,3551,3552,3562,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1077,SUCCESS
    513,2021-07-01 16:40:59,2055.953,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24879,514,515,8,13,18,297,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3562,3551,3549,3551,3551,3553,3562,0,0,0,0,0,0,0,0,2750,24.2,24.4,-273.2,24.4,-273.2,33.5,1036,SUCCESS
    514,2021-07-01 16:41:03,2059.953,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24881,516,515,8,13,18,298,2352,65535,65535,311,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3563,3552,3549,3552,3551,3553,3563,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1063,SUCCESS
    515,2021-07-01 16:41:07,2063.957,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24884,516,515,8,13,18,298,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3563,3552,3549,3552,3552,3553,3563,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1078,SUCCESS
    516,2021-07-01 16:41:11,2067.972,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24886,515,515,8,13,18,299,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3563,3552,3550,3552,3552,3554,3563,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1082,SUCCESS
    517,2021-07-01 16:41:15,2071.982,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24890,515,515,8,13,18,300,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3563,3553,3551,3552,3553,3554,3564,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.0,1040,SUCCESS
    518,2021-07-01 16:41:19,2075.985,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24892,515,515,8,13,18,300,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3564,3553,3551,3552,3553,3555,3564,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1064,SUCCESS
    519,2021-07-01 16:41:23,2079.992,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24894,514,515,8,13,19,301,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3565,3554,3551,3553,3553,3555,3564,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1026,SUCCESS
    520,2021-07-01 16:41:27,2083.999,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24897,515,515,8,13,19,301,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3565,3554,3552,3554,3553,3555,3565,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1018,SUCCESS
    521,2021-07-01 16:41:31,2088.008,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24900,515,515,8,13,19,302,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3565,3554,3552,3554,3554,3556,3565,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,945,SUCCESS
    522,2021-07-01 16:41:35,2092.023,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24902,515,515,8,13,19,303,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3566,3555,3552,3554,3554,3556,3566,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,1027,SUCCESS
    523,2021-07-01 16:41:39,2096.029,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24904,515,515,8,13,19,303,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3566,3555,3553,3555,3554,3556,3566,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1053,SUCCESS
    524,2021-07-01 16:41:43,2100.034,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24907,515,515,8,13,19,304,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3567,3555,3553,3555,3555,3557,3566,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1062,SUCCESS
    525,2021-07-01 16:41:47,2104.040,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24912,515,515,8,13,19,304,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3567,3556,3554,3555,3556,3557,3567,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.5,963,SUCCESS
    526,2021-07-01 16:41:51,2108.050,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24914,515,515,8,13,19,305,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3567,3556,3554,3556,3556,3558,3568,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1108,SUCCESS
    527,2021-07-01 16:41:55,2112.061,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24917,514,515,8,14,19,306,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3568,3557,3554,3556,3556,3558,3568,0,0,0,0,0,0,0,0,2750,24.3,24.4,-273.2,24.4,-273.2,33.6,1032,SUCCESS
    528,2021-07-01 16:41:59,2116.076,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24919,515,515,8,14,19,306,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3568,3557,3555,3557,3556,3558,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.6,1099,SUCCESS
    529,2021-07-01 16:42:03,2120.082,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24922,515,515,8,14,19,307,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3568,3557,3555,3557,3557,3558,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.5,1031,SUCCESS
    530,2021-07-01 16:42:07,2124.091,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24925,515,515,8,14,19,307,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3569,3558,3556,3557,3557,3558,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.6,975,SUCCESS
    531,2021-07-01 16:42:11,2128.100,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24927,516,515,8,14,19,308,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3569,3558,3556,3558,3557,3559,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.5,1061,SUCCESS
    532,2021-07-01 16:42:15,2132.115,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24930,516,515,8,14,19,308,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3570,3559,3557,3558,3558,3559,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.6,1047,SUCCESS
    533,2021-07-01 16:42:19,2136.120,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24931,516,515,8,14,19,309,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3570,3559,3557,3559,3559,3560,3569,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.6,1024,SUCCESS
    534,2021-07-01 16:42:23,2140.123,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24934,515,515,8,14,19,310,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3570,3559,3557,3559,3559,3561,3569,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.6,1035,SUCCESS
    535,2021-07-01 16:42:27,2144.138,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24936,514,515,8,14,19,310,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3571,3560,3557,3559,3559,3562,3569,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.5,1006,SUCCESS
    536,2021-07-01 16:42:31,2148.145,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24936,515,515,8,14,19,311,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3571,3560,3557,3559,3560,3561,3570,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.6,982,SUCCESS
    537,2021-07-01 16:42:35,2152.156,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24940,515,515,8,14,19,311,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3571,3560,3557,3560,3560,3561,3570,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.6,1080,SUCCESS
    538,2021-07-01 16:42:39,2156.167,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24942,516,515,8,14,19,312,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3572,3560,3557,3560,3560,3562,3571,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.5,975,SUCCESS
    539,2021-07-01 16:42:43,2160.176,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24945,515,515,8,14,19,312,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3572,3561,3557,3561,3561,3562,3571,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.6,1094,SUCCESS
    540,2021-07-01 16:42:47,2164.175,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24948,515,515,8,14,19,313,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3572,3562,3558,3561,3562,3562,3571,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.5,968,SUCCESS
    541,2021-07-01 16:42:51,2168.176,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24951,516,515,8,14,19,314,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3573,3562,3558,3561,3562,3563,3572,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.5,1044,SUCCESS
    542,2021-07-01 16:42:55,2172.179,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24953,516,515,8,14,19,314,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3573,3562,3558,3562,3562,3564,3572,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.6,979,SUCCESS
    543,2021-07-01 16:42:59,2176.187,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24957,514,515,8,14,19,315,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3563,3559,3563,3563,3564,3572,0,0,0,0,0,0,0,0,2755,24.3,24.4,-273.2,24.4,-273.2,33.6,1096,SUCCESS
    544,2021-07-01 16:43:03,2180.199,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24961,516,515,8,14,19,315,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3563,3560,3563,3564,3564,3573,0,0,0,0,0,0,0,0,2755,24.3,24.5,-273.2,24.5,-273.2,33.5,993,SUCCESS
    545,2021-07-01 16:43:07,2184.203,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24962,515,515,8,14,19,316,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3563,3560,3564,3565,3564,3573,0,0,0,0,0,0,0,0,2759,24.3,24.4,-273.2,24.4,-273.2,33.6,1094,SUCCESS
    546,2021-07-01 16:43:11,2188.214,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24965,517,515,8,14,19,316,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3563,3560,3565,3565,3565,3574,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1084,SUCCESS
    547,2021-07-01 16:43:15,2192.223,0x0701,150,10,0x6001,0,65535,65535,1,24.4,24967,516,515,8,14,20,317,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3563,3561,3565,3565,3565,3574,0,0,0,0,0,0,0,0,2760,24.3,24.4,-273.2,24.4,-273.2,33.6,1078,SUCCESS
    548,2021-07-01 16:43:19,2196.230,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24968,516,515,8,14,20,318,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3574,3564,3561,3565,3565,3565,3574,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1085,SUCCESS
    549,2021-07-01 16:43:23,2200.244,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24972,516,515,8,14,20,318,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3575,3565,3562,3565,3565,3566,3575,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1007,SUCCESS
    550,2021-07-01 16:43:27,2204.254,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24975,515,515,8,14,20,319,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3576,3565,3562,3565,3565,3566,3575,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,32.9,1050,SUCCESS
    551,2021-07-01 16:43:31,2208.258,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24975,516,515,8,14,20,319,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3576,3565,3562,3565,3565,3566,3577,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,1044,SUCCESS
    552,2021-07-01 16:43:35,2212.272,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24978,515,515,8,14,20,320,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3577,3565,3563,3565,3565,3567,3576,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,980,SUCCESS
    553,2021-07-01 16:43:39,2216.270,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24979,516,515,8,14,20,321,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3577,3566,3563,3565,3565,3567,3576,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1030,SUCCESS
    554,2021-07-01 16:43:43,2220.284,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24979,516,515,8,14,20,321,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3577,3566,3563,3565,3565,3568,3576,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1059,SUCCESS
    555,2021-07-01 16:43:47,2224.295,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24984,515,515,8,14,20,322,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3578,3567,3564,3566,3565,3569,3577,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,1068,SUCCESS
    556,2021-07-01 16:43:51,2228.309,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24986,515,515,8,14,20,322,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3578,3567,3564,3566,3565,3569,3577,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,974,SUCCESS
    557,2021-07-01 16:43:55,2232.311,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24990,516,515,8,14,20,323,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3579,3567,3565,3567,3565,3570,3578,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1035,SUCCESS
    558,2021-07-01 16:43:59,2236.322,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24993,517,515,8,14,20,323,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3579,3568,3565,3567,3566,3570,3578,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,994,SUCCESS
    559,2021-07-01 16:44:03,2240.324,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24995,515,515,8,14,20,324,2352,65535,65535,308,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3579,3568,3565,3567,3567,3571,3578,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1037,SUCCESS
    560,2021-07-01 16:44:07,2244.333,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24998,516,515,8,14,20,325,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3580,3569,3566,3568,3567,3571,3578,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1043,SUCCESS
    561,2021-07-01 16:44:11,2248.342,0x0701,150,10,0x6001,0,65535,65535,1,24.5,24999,515,515,8,14,20,325,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3580,3569,3566,3568,3567,3571,3578,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,1035,SUCCESS
    562,2021-07-01 16:44:15,2252.349,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25002,515,515,8,14,20,326,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3580,3569,3566,3569,3568,3571,3579,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.5,1029,SUCCESS
    563,2021-07-01 16:44:19,2256.355,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25003,515,515,8,14,20,326,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3580,3569,3566,3569,3568,3571,3580,0,0,0,0,0,0,0,0,2760,24.3,24.5,-273.2,24.5,-273.2,33.6,1039,SUCCESS
    564,2021-07-01 16:44:23,2260.355,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25006,515,515,8,14,20,327,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3581,3570,3567,3569,3569,3571,3580,0,0,0,0,0,0,0,0,2764,24.3,24.5,-273.2,24.5,-273.2,33.7,1012,SUCCESS
    565,2021-07-01 16:44:27,2264.366,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25008,514,515,8,14,20,327,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3581,3570,3567,3570,3569,3571,3580,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1028,SUCCESS
    566,2021-07-01 16:44:31,2268.369,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25011,515,515,8,14,20,328,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3582,3571,3568,3570,3569,3571,3581,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.5,1041,SUCCESS
    567,2021-07-01 16:44:35,2272.370,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25014,513,515,8,14,20,329,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3582,3571,3568,3571,3570,3571,3581,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.5,1006,SUCCESS
    568,2021-07-01 16:44:39,2276.384,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25014,514,515,8,14,20,329,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3582,3571,3568,3571,3570,3571,3581,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,979,SUCCESS
    569,2021-07-01 16:44:43,2280.387,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25018,514,515,8,15,20,330,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3583,3572,3569,3571,3571,3573,3581,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,32.8,994,SUCCESS
    570,2021-07-01 16:44:47,2284.395,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25022,515,515,8,15,20,330,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3583,3572,3569,3572,3571,3573,3582,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1041,SUCCESS
    571,2021-07-01 16:44:51,2288.397,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25025,515,515,8,15,20,331,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3584,3573,3569,3572,3571,3573,3582,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1090,SUCCESS
    572,2021-07-01 16:44:55,2292.403,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25028,516,515,8,15,20,331,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3584,3574,3570,3572,3571,3573,3583,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,991,SUCCESS
    573,2021-07-01 16:44:59,2296.413,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25031,514,515,8,15,20,332,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3585,3575,3570,3573,3572,3574,3583,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1044,SUCCESS
    574,2021-07-01 16:45:03,2300.416,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25034,516,515,8,15,20,333,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3585,3575,3571,3573,3572,3574,3584,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1024,SUCCESS
    575,2021-07-01 16:45:07,2304.428,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25037,515,515,8,15,20,333,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3571,3574,3573,3575,3584,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.5,1018,SUCCESS
    576,2021-07-01 16:45:11,2308.435,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25040,514,515,8,15,21,334,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3572,3574,3573,3575,3584,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,988,SUCCESS
    577,2021-07-01 16:45:15,2312.436,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25040,515,515,8,15,21,334,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3572,3574,3573,3575,3585,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1050,SUCCESS
    578,2021-07-01 16:45:19,2316.452,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25042,514,515,8,15,21,335,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3573,3574,3573,3576,3585,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1068,SUCCESS
    579,2021-07-01 16:45:23,2320.461,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25044,515,514,8,15,21,335,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3573,3575,3574,3576,3585,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,996,SUCCESS
    580,2021-07-01 16:45:27,2324.475,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25045,516,515,8,15,21,336,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3573,3575,3574,3577,3585,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,985,SUCCESS
    581,2021-07-01 16:45:31,2328.483,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25047,515,515,8,15,21,337,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3573,3575,3575,3577,3586,0,0,0,0,0,0,0,0,2765,24.3,24.5,-273.2,24.5,-273.2,33.6,1069,SUCCESS
    582,2021-07-01 16:45:35,2332.495,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25047,516,515,8,15,21,337,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3575,3573,3576,3575,3577,3586,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1055,SUCCESS
    583,2021-07-01 16:45:39,2336.503,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25051,514,515,8,15,21,338,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3586,3576,3573,3576,3576,3578,3586,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,32.7,1019,SUCCESS
    584,2021-07-01 16:45:43,2340.509,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25052,514,515,8,15,21,338,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3587,3576,3573,3577,3576,3579,3586,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.7,1031,SUCCESS
    585,2021-07-01 16:45:47,2344.508,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25057,515,514,8,15,21,339,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3588,3577,3574,3577,3576,3578,3586,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.7,1027,SUCCESS
    586,2021-07-01 16:45:51,2348.515,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25059,514,514,8,15,21,339,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3588,3577,3574,3577,3577,3579,3587,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1051,SUCCESS
    587,2021-07-01 16:45:55,2352.523,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25060,514,514,8,15,21,340,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3588,3577,3575,3577,3577,3579,3587,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,982,SUCCESS
    588,2021-07-01 16:45:59,2356.535,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25065,514,514,8,15,21,341,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3589,3578,3575,3578,3577,3579,3588,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1045,SUCCESS
    589,2021-07-01 16:46:03,2360.542,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25066,514,514,8,15,21,341,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3589,3578,3575,3578,3578,3580,3588,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1085,SUCCESS
    590,2021-07-01 16:46:07,2364.550,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25069,515,514,8,15,21,342,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3590,3578,3576,3579,3577,3580,3588,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1048,SUCCESS
    591,2021-07-01 16:46:11,2368.550,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25072,514,514,8,15,21,342,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3590,3579,3576,3580,3578,3580,3589,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.5,1051,SUCCESS
    592,2021-07-01 16:46:15,2372.565,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25073,514,514,8,15,21,343,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3590,3579,3577,3580,3579,3580,3589,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,984,SUCCESS
    593,2021-07-01 16:46:19,2376.573,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25077,514,514,8,15,21,344,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3591,3580,3577,3581,3579,3580,3589,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1008,SUCCESS
    594,2021-07-01 16:46:23,2380.585,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25079,514,514,8,15,21,344,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3591,3580,3577,3581,3579,3581,3590,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,979,SUCCESS
    595,2021-07-01 16:46:27,2384.593,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25082,514,514,8,15,21,345,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3591,3580,3578,3581,3580,3581,3590,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,971,SUCCESS
    596,2021-07-01 16:46:31,2388.591,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25085,514,514,8,15,21,345,2352,65535,65535,306,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3592,3581,3578,3581,3580,3582,3591,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,974,SUCCESS
    597,2021-07-01 16:46:35,2392.593,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25086,514,514,8,15,21,346,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3592,3581,3578,3581,3580,3582,3591,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.7,978,SUCCESS
    598,2021-07-01 16:46:39,2396.606,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25089,515,514,8,15,21,346,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3593,3582,3579,3581,3581,3583,3591,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.5,1073,SUCCESS
    599,2021-07-01 16:46:43,2400.620,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25090,514,514,8,15,21,347,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3593,3582,3579,3581,3581,3583,3591,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,958,SUCCESS
    600,2021-07-01 16:46:47,2404.632,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25092,514,514,8,15,21,348,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3593,3582,3579,3582,3582,3584,3592,0,0,0,0,0,0,0,0,2770,24.3,24.5,-273.2,24.5,-273.2,33.6,1025,SUCCESS
    601,2021-07-01 16:46:51,2408.641,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25097,514,514,8,15,21,348,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3582,3580,3582,3582,3584,3592,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1016,SUCCESS
    602,2021-07-01 16:46:55,2412.645,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25097,514,514,8,15,21,349,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3583,3580,3583,3582,3584,3593,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.7,1029,SUCCESS
    603,2021-07-01 16:46:59,2416.657,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25100,514,514,8,15,21,349,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3594,3584,3580,3583,3582,3585,3593,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1015,SUCCESS
    604,2021-07-01 16:47:03,2420.670,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25103,514,514,8,15,21,350,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3584,3581,3583,3582,3585,3593,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.7,1082,SUCCESS
    605,2021-07-01 16:47:07,2424.685,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25105,514,514,8,15,21,350,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3584,3581,3584,3582,3585,3594,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1020,SUCCESS
    606,2021-07-01 16:47:11,2428.685,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25107,513,514,8,15,22,351,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3584,3582,3584,3583,3586,3594,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1004,SUCCESS
    607,2021-07-01 16:47:15,2432.686,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25112,515,514,8,15,22,352,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3595,3585,3582,3584,3583,3587,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1067,SUCCESS
    608,2021-07-01 16:47:19,2436.702,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25114,515,514,8,15,22,352,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3585,3583,3585,3584,3585,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,973,SUCCESS
    609,2021-07-01 16:47:23,2440.712,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25115,514,514,8,16,22,353,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3585,3583,3585,3585,3586,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1039,SUCCESS
    610,2021-07-01 16:47:27,2444.711,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25117,514,514,8,16,22,353,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3596,3586,3583,3585,3585,3587,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,978,SUCCESS
    611,2021-07-01 16:47:31,2448.724,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25119,515,514,8,16,22,354,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3586,3583,3586,3585,3587,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.7,1020,SUCCESS
    612,2021-07-01 16:47:35,2452.731,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25120,516,514,8,16,22,354,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3597,3586,3583,3586,3585,3587,3595,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.7,1055,SUCCESS
    613,2021-07-01 16:47:39,2456.736,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25124,514,514,8,16,22,355,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3598,3587,3583,3586,3586,3588,3596,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1096,SUCCESS
    614,2021-07-01 16:47:43,2460.745,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25126,514,514,8,16,22,356,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3598,3587,3584,3587,3586,3589,3597,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,961,SUCCESS
    615,2021-07-01 16:47:47,2464.745,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25132,515,514,8,16,22,356,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3599,3588,3585,3587,3587,3593,3597,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1040,SUCCESS
    616,2021-07-01 16:47:51,2468.746,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25134,514,514,8,16,22,357,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3599,3588,3585,3587,3587,3594,3598,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,959,SUCCESS
    617,2021-07-01 16:47:55,2472.760,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25134,515,514,8,16,22,357,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3599,3588,3585,3588,3587,3590,3598,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.7,1039,SUCCESS
    618,2021-07-01 16:47:59,2476.767,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25137,514,514,8,16,22,358,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3600,3589,3586,3588,3587,3590,3598,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,1048,SUCCESS
    619,2021-07-01 16:48:03,2480.780,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25140,514,514,8,16,22,358,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3600,3589,3586,3589,3588,3590,3598,0,0,0,0,0,0,0,0,2775,24.3,24.5,-273.2,24.5,-273.2,33.6,971,SUCCESS
    620,2021-07-01 16:48:07,2484.782,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25142,514,514,8,16,22,359,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3601,3590,3586,3589,3588,3590,3599,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.6,1021,SUCCESS
    621,2021-07-01 16:48:11,2488.786,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25146,514,514,8,16,22,360,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3586,3589,3588,3590,3599,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.1,1003,SUCCESS
    622,2021-07-01 16:48:15,2492.794,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25148,514,514,8,16,22,360,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3587,3590,3589,3591,3600,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.7,1004,SUCCESS
    623,2021-07-01 16:48:19,2496.795,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25151,514,514,8,16,22,361,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3587,3591,3589,3591,3600,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1036,SUCCESS
    624,2021-07-01 16:48:23,2500.809,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25154,514,514,8,16,22,361,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3588,3591,3590,3592,3600,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1023,SUCCESS
    625,2021-07-01 16:48:27,2504.811,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25154,515,514,8,16,22,362,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3588,3591,3590,3592,3600,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.7,988,SUCCESS
    626,2021-07-01 16:48:31,2508.810,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25156,514,514,8,16,22,362,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3588,3591,3590,3593,3601,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1052,SUCCESS
    627,2021-07-01 16:48:35,2512.825,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25158,514,514,8,16,22,363,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3589,3591,3591,3593,3601,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1022,SUCCESS
    628,2021-07-01 16:48:39,2516.825,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25158,515,514,8,16,22,364,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3602,3591,3589,3592,3591,3593,3601,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,973,SUCCESS
    629,2021-07-01 16:48:43,2520.839,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25162,515,514,8,16,22,364,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3603,3592,3590,3592,3591,3593,3602,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.6,1055,SUCCESS
    630,2021-07-01 16:48:47,2524.845,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25164,515,514,8,16,22,365,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3603,3592,3590,3592,3592,3593,3602,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.7,1032,SUCCESS
    631,2021-07-01 16:48:51,2528.845,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25167,514,514,8,16,22,365,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3604,3593,3590,3593,3593,3594,3602,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.7,1156,SUCCESS
    632,2021-07-01 16:48:55,2532.855,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25170,514,514,8,16,22,366,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3604,3593,3590,3593,3593,3594,3603,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.6,1180,SUCCESS
    633,2021-07-01 16:48:59,2536.860,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25175,513,514,8,16,23,367,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3605,3594,3591,3594,3594,3594,3603,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.7,1063,SUCCESS
    634,2021-07-01 16:49:04,2540.874,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25177,514,514,8,16,23,367,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3605,3594,3591,3594,3595,3595,3603,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1049,SUCCESS
    635,2021-07-01 16:49:08,2544.873,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25178,514,514,8,16,23,368,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3605,3594,3591,3594,3595,3595,3604,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,1067,SUCCESS
    636,2021-07-01 16:49:12,2548.876,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25179,514,514,8,16,23,368,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3606,3594,3592,3594,3595,3596,3604,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.7,1112,SUCCESS
    637,2021-07-01 16:49:16,2552.889,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25184,513,514,8,16,23,369,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3606,3595,3592,3595,3595,3597,3604,0,0,0,0,0,0,0,0,2780,24.3,24.5,-273.2,24.5,-273.2,33.6,972,SUCCESS
    638,2021-07-01 16:49:20,2556.892,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25184,514,514,8,16,23,369,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3606,3595,3592,3595,3595,3597,3604,0,0,0,0,0,0,0,0,2780,24.4,24.5,-273.2,24.5,-273.2,33.6,1002,SUCCESS
    639,2021-07-01 16:49:24,2560.905,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25186,514,514,8,16,23,370,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3606,3595,3593,3595,3595,3597,3605,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.7,1017,SUCCESS
    640,2021-07-01 16:49:28,2564.916,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25189,514,514,8,16,23,371,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3607,3596,3593,3596,3595,3597,3605,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1055,SUCCESS
    641,2021-07-01 16:49:32,2568.930,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25190,515,514,8,16,23,371,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3608,3596,3593,3596,3595,3597,3606,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1009,SUCCESS
    642,2021-07-01 16:49:36,2572.934,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25193,515,515,8,16,23,372,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3608,3596,3594,3597,3595,3598,3606,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,975,SUCCESS
    643,2021-07-01 16:49:40,2576.947,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25196,514,514,8,16,23,372,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3608,3597,3594,3597,3596,3598,3606,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,946,SUCCESS
    644,2021-07-01 16:49:44,2580.956,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25197,515,514,8,16,23,373,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3608,3597,3595,3597,3596,3598,3606,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1000,SUCCESS
    645,2021-07-01 16:49:48,2584.963,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25198,514,514,8,16,23,373,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3608,3597,3595,3598,3596,3598,3607,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.7,1101,SUCCESS
    646,2021-07-01 16:49:52,2588.971,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25202,515,514,8,16,23,374,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3609,3598,3595,3598,3596,3598,3607,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1047,SUCCESS
    647,2021-07-01 16:49:56,2592.976,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25203,515,515,8,16,23,375,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3609,3598,3595,3598,3597,3599,3607,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1059,SUCCESS
    648,2021-07-01 16:50:00,2596.980,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25203,514,514,8,16,23,375,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3610,3598,3595,3598,3597,3599,3608,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,943,SUCCESS
    649,2021-07-01 16:50:04,2600.982,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25208,514,514,8,16,23,376,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3610,3599,3596,3598,3598,3600,3608,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.7,1066,SUCCESS
    650,2021-07-01 16:50:08,2604.994,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25210,514,514,8,16,23,376,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3611,3599,3596,3599,3598,3600,3608,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.7,1040,SUCCESS
    651,2021-07-01 16:50:12,2608.998,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25213,515,514,8,17,23,377,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3611,3599,3597,3599,3598,3600,3609,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1050,SUCCESS
    652,2021-07-01 16:50:16,2613.009,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25217,514,514,8,17,23,377,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3611,3600,3597,3600,3599,3601,3609,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1007,SUCCESS
    653,2021-07-01 16:50:20,2617.023,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25218,514,514,8,17,23,378,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3612,3601,3597,3600,3599,3601,3609,0,0,0,0,0,0,0,0,2785,24.4,24.6,-273.2,24.6,-273.2,33.6,977,SUCCESS
    654,2021-07-01 16:50:24,2621.035,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25220,514,514,8,17,23,379,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3612,3601,3598,3600,3599,3601,3609,0,0,0,0,0,0,0,0,2785,24.4,24.6,-273.2,24.6,-273.2,33.6,1001,SUCCESS
    655,2021-07-01 16:50:28,2625.039,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25223,514,514,8,17,23,379,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3612,3601,3598,3600,3600,3602,3610,0,0,0,0,0,0,0,0,2785,24.4,24.6,-273.2,24.6,-273.2,33.7,998,SUCCESS
    656,2021-07-01 16:50:32,2629.051,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25224,513,514,8,17,23,380,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3612,3601,3598,3601,3600,3602,3610,0,0,0,0,0,0,0,0,2785,24.4,24.6,-273.2,24.6,-273.2,33.6,1092,SUCCESS
    657,2021-07-01 16:50:36,2633.061,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25225,513,514,8,17,23,380,2352,65535,65535,302,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3613,3601,3599,3601,3600,3602,3610,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1018,SUCCESS
    658,2021-07-01 16:50:40,2637.070,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25228,514,514,8,17,23,381,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3613,3601,3599,3601,3601,3603,3611,0,0,0,0,0,0,0,0,2785,24.4,24.5,-273.2,24.5,-273.2,33.6,1009,SUCCESS
    659,2021-07-01 16:50:44,2641.071,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25230,513,514,8,17,23,381,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3613,3601,3599,3602,3601,3603,3611,0,0,0,0,0,0,0,0,2789,24.4,24.5,-273.2,24.5,-273.2,33.0,1032,SUCCESS
    660,2021-07-01 16:50:48,2645.082,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25231,514,514,8,17,23,382,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3613,3602,3600,3602,3601,3603,3611,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.7,1061,SUCCESS
    661,2021-07-01 16:50:52,2649.090,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25232,514,514,8,17,23,383,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3614,3602,3600,3603,3602,3603,3612,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.7,975,SUCCESS
    662,2021-07-01 16:50:56,2653.100,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25234,514,514,8,17,23,383,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3614,3603,3600,3603,3602,3605,3612,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,995,SUCCESS
    663,2021-07-01 16:51:00,2657.106,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25238,515,514,8,17,24,384,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3615,3603,3601,3603,3602,3604,3612,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1037,SUCCESS
    664,2021-07-01 16:51:04,2661.121,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25240,515,514,8,17,24,384,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3615,3603,3601,3603,3602,3604,3612,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.6,981,SUCCESS
    665,2021-07-01 16:51:08,2665.135,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25245,515,514,8,17,24,385,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3615,3604,3601,3604,3603,3605,3613,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.6,1008,SUCCESS
    666,2021-07-01 16:51:12,2669.148,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25247,514,515,8,17,24,385,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3616,3604,3602,3604,3603,3605,3613,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.7,1042,SUCCESS
    667,2021-07-01 16:51:16,2673.148,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25250,514,514,8,17,24,386,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3616,3604,3602,3604,3604,3605,3614,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.7,977,SUCCESS
    668,2021-07-01 16:51:20,2677.158,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25251,515,514,8,17,24,387,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3616,3605,3602,3604,3604,3606,3614,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.6,1117,SUCCESS
    669,2021-07-01 16:51:24,2681.163,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25252,514,514,8,17,24,387,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3616,3605,3603,3605,3604,3606,3614,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.6,1026,SUCCESS
    670,2021-07-01 16:51:28,2685.166,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25254,514,514,8,17,24,388,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3617,3605,3603,3605,3604,3606,3614,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.6,1024,SUCCESS
    671,2021-07-01 16:51:32,2689.177,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25256,514,514,8,17,24,388,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3617,3605,3603,3606,3604,3607,3615,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,995,SUCCESS
    672,2021-07-01 16:51:36,2693.189,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25258,514,514,8,17,24,389,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3617,3606,3603,3606,3605,3606,3615,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1082,SUCCESS
    673,2021-07-01 16:51:40,2697.191,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25261,515,514,8,17,24,390,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3618,3606,3604,3606,3605,3607,3615,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.2,1005,SUCCESS
    674,2021-07-01 16:51:44,2701.193,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25263,515,514,8,17,24,390,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3618,3606,3604,3606,3605,3608,3615,0,0,0,0,0,0,0,0,2790,24.4,24.5,-273.2,24.5,-273.2,33.7,1043,SUCCESS
    675,2021-07-01 16:51:48,2705.208,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25266,514,514,8,17,24,391,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3607,3604,3607,3606,3608,3616,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1027,SUCCESS
    676,2021-07-01 16:51:52,2709.219,0x0701,150,10,0x6001,0,65535,65535,1,24.5,25266,515,515,8,17,24,391,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3607,3605,3607,3606,3608,3616,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1114,SUCCESS
    677,2021-07-01 16:51:56,2713.227,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25269,514,515,8,17,24,392,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3608,3605,3607,3606,3608,3617,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.6,1065,SUCCESS
    678,2021-07-01 16:52:00,2717.228,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25271,514,515,8,17,24,392,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3608,3605,3607,3607,3609,3617,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.6,994,SUCCESS
    679,2021-07-01 16:52:04,2721.278,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25273,515,515,8,17,24,393,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3608,3606,3608,3607,3609,3617,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1009,SUCCESS
    680,2021-07-01 16:52:08,2725.246,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25274,514,515,8,17,24,394,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3619,3608,3606,3608,3607,3609,3617,0,0,0,0,0,0,0,0,2790,24.4,24.6,-273.2,24.6,-273.2,33.7,1022,SUCCESS
    681,2021-07-01 16:52:12,2729.259,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25276,515,515,8,17,24,394,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3620,3608,3606,3608,3608,3610,3618,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.6,1026,SUCCESS
    682,2021-07-01 16:52:16,2733.267,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25279,514,515,8,17,24,395,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3620,3608,3606,3609,3608,3610,3618,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1018,SUCCESS
    683,2021-07-01 16:52:20,2737.274,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25281,514,515,8,17,24,395,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3620,3609,3607,3609,3608,3610,3618,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1023,SUCCESS
    684,2021-07-01 16:52:24,2741.278,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25283,516,515,8,17,24,396,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3621,3609,3607,3609,3609,3610,3618,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.6,1053,SUCCESS
    685,2021-07-01 16:52:28,2745.286,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25286,515,515,8,17,24,396,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3621,3609,3607,3610,3609,3609,3619,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.6,1014,SUCCESS
    686,2021-07-01 16:52:32,2749.297,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25287,514,515,8,17,24,397,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3622,3610,3608,3610,3610,3608,3619,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.6,1001,SUCCESS
    687,2021-07-01 16:52:36,2753.307,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25290,515,515,8,17,24,398,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3622,3610,3608,3610,3610,3610,3619,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1039,SUCCESS
    688,2021-07-01 16:52:40,2757.309,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25294,515,515,8,17,24,398,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3622,3611,3608,3611,3611,3611,3620,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.0,1013,SUCCESS
    689,2021-07-01 16:52:44,2761.316,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25294,513,515,8,17,24,399,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3622,3611,3608,3611,3611,3610,3620,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1079,SUCCESS
    690,2021-07-01 16:52:48,2765.327,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25296,515,515,8,17,24,399,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3622,3611,3609,3611,3611,3612,3620,0,0,0,0,0,0,0,0,2795,24.5,24.6,-273.2,24.6,-273.2,33.7,994,SUCCESS
    691,2021-07-01 16:52:52,2769.341,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25298,515,515,8,18,24,400,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3623,3611,3609,3611,3611,3614,3620,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1035,SUCCESS
    692,2021-07-01 16:52:56,2773.342,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25301,515,515,8,18,24,400,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3623,3612,3609,3612,3611,3615,3621,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.3,1026,SUCCESS
    693,2021-07-01 16:53:00,2777.354,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25301,515,515,8,18,25,401,2352,65535,65535,299,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3624,3612,3609,3612,3611,3616,3621,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.0,976,SUCCESS
    694,2021-07-01 16:53:04,2781.367,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25303,515,515,8,18,25,402,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3624,3612,3610,3612,3611,3618,3621,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,993,SUCCESS
    695,2021-07-01 16:53:08,2785.381,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25303,514,515,8,18,25,402,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3624,3612,3610,3612,3611,3614,3622,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1028,SUCCESS
    696,2021-07-01 16:53:12,2789.380,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25307,515,515,8,18,25,403,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3624,3612,3611,3612,3611,3614,3622,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1030,SUCCESS
    697,2021-07-01 16:53:16,2793.389,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25310,514,515,8,18,25,403,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3625,3613,3611,3613,3612,3614,3622,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1033,SUCCESS
    698,2021-07-01 16:53:20,2797.400,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25311,516,515,8,18,25,404,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3625,3613,3611,3614,3612,3614,3623,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,963,SUCCESS
    699,2021-07-01 16:53:24,2801.410,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25313,514,515,8,18,25,404,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3625,3613,3611,3614,3612,3614,3622,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,998,SUCCESS
    700,2021-07-01 16:53:28,2805.422,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25314,514,515,8,18,25,405,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3625,3614,3612,3614,3613,3614,3623,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1035,SUCCESS
    701,2021-07-01 16:53:32,2809.431,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25317,514,515,8,18,25,406,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3626,3614,3612,3614,3613,3615,3623,0,0,0,0,0,0,0,0,2795,24.4,24.6,-273.2,24.6,-273.2,33.7,1040,SUCCESS
    702,2021-07-01 16:53:36,2813.438,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25318,514,515,8,18,25,406,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3626,3614,3612,3614,3613,3616,3623,0,0,0,0,0,0,0,0,2800,24.4,24.6,-273.2,24.6,-273.2,33.7,1048,SUCCESS
    703,2021-07-01 16:53:40,2817.450,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25321,514,515,8,18,25,407,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3626,3614,3612,3615,3614,3616,3623,0,0,0,0,0,0,0,0,2800,24.4,24.6,-273.2,24.6,-273.2,33.6,1024,SUCCESS
    704,2021-07-01 16:53:44,2821.472,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25323,515,515,8,18,25,407,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3626,3614,3613,3615,3614,3616,3624,0,0,0,0,0,0,0,0,2800,24.4,24.6,-273.2,24.6,-273.2,33.6,1044,SUCCESS
    705,2021-07-01 16:53:48,2825.485,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25324,515,515,8,18,25,408,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3626,3615,3613,3615,3614,3616,3624,0,0,0,0,0,0,0,0,2800,24.4,24.6,-273.2,24.6,-273.2,33.6,1002,SUCCESS
    706,2021-07-01 16:53:52,2829.492,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25326,515,515,8,18,25,409,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3627,3615,3613,3615,3615,3616,3624,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1078,SUCCESS
    707,2021-07-01 16:53:56,2833.497,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25330,515,515,8,18,25,409,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3615,3614,3616,3615,3617,3625,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1006,SUCCESS
    708,2021-07-01 16:54:00,2837.503,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25331,514,515,8,18,25,410,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3616,3614,3616,3615,3617,3625,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,983,SUCCESS
    709,2021-07-01 16:54:04,2841.511,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25332,515,515,8,18,25,410,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3616,3614,3617,3615,3617,3625,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,976,SUCCESS
    710,2021-07-01 16:54:08,2845.514,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25335,515,515,8,18,25,411,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3617,3615,3617,3616,3617,3626,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1019,SUCCESS
    711,2021-07-01 16:54:12,2849.530,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25336,515,515,8,18,25,411,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3617,3615,3617,3616,3618,3626,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,972,SUCCESS
    712,2021-07-01 16:54:16,2853.532,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25337,516,515,8,18,25,412,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3628,3617,3615,3617,3616,3618,3626,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1016,SUCCESS
    713,2021-07-01 16:54:20,2857.534,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25338,515,515,8,18,25,413,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3629,3617,3615,3617,3616,3618,3626,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,999,SUCCESS
    714,2021-07-01 16:54:24,2861.541,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25342,516,515,8,18,25,413,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3629,3617,3615,3618,3617,3618,3626,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1026,SUCCESS
    715,2021-07-01 16:54:28,2865.549,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25342,514,515,8,18,25,414,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3629,3617,3616,3618,3617,3618,3627,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,999,SUCCESS
    716,2021-07-01 16:54:32,2869.550,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25345,515,515,8,18,25,414,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3630,3618,3616,3618,3617,3619,3627,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.0,1052,SUCCESS
    717,2021-07-01 16:54:36,2873.565,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25345,515,515,8,18,25,415,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3630,3618,3616,3618,3617,3620,3627,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1062,SUCCESS
    718,2021-07-01 16:54:40,2877.573,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25348,515,515,8,18,25,415,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3630,3618,3617,3618,3618,3620,3627,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1023,SUCCESS
    719,2021-07-01 16:54:44,2881.583,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25351,515,515,8,18,25,416,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3631,3618,3617,3619,3618,3620,3628,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1029,SUCCESS
    720,2021-07-01 16:54:48,2885.582,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25352,515,515,8,18,26,417,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3631,3619,3617,3619,3618,3620,3628,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,984,SUCCESS
    721,2021-07-01 16:54:52,2889.594,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25354,515,515,8,18,26,417,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3631,3619,3617,3620,3619,3620,3629,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.1,1037,SUCCESS
    722,2021-07-01 16:54:56,2893.606,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25357,515,515,8,18,26,418,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3631,3619,3618,3620,3619,3621,3629,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1068,SUCCESS
    723,2021-07-01 16:55:00,2897.608,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25357,515,515,8,18,26,418,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3632,3620,3618,3620,3619,3621,3629,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1019,SUCCESS
    724,2021-07-01 16:55:04,2901.623,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25359,514,515,8,18,26,419,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3632,3620,3618,3620,3619,3621,3629,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1068,SUCCESS
    725,2021-07-01 16:55:08,2905.629,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25360,515,515,8,18,26,419,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3632,3620,3618,3620,3620,3621,3629,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,997,SUCCESS
    726,2021-07-01 16:55:12,2909.638,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25363,515,515,8,18,26,420,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3632,3620,3619,3621,3620,3622,3630,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,989,SUCCESS
    727,2021-07-01 16:55:16,2913.644,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25366,515,515,8,18,26,421,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3633,3621,3619,3621,3620,3622,3630,0,0,0,0,0,0,0,0,2800,24.5,24.6,-273.2,24.6,-273.2,33.7,1061,SUCCESS
    728,2021-07-01 16:55:20,2917.658,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25367,515,515,8,18,26,421,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3633,3621,3619,3621,3620,3622,3630,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1046,SUCCESS
    729,2021-07-01 16:55:24,2921.662,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25368,516,515,8,18,26,422,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3633,3621,3620,3621,3621,3622,3630,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1026,SUCCESS
    730,2021-07-01 16:55:28,2925.664,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25369,515,515,8,18,26,422,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3634,3621,3620,3622,3621,3623,3631,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1011,SUCCESS
    731,2021-07-01 16:55:32,2929.670,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25372,515,515,8,18,26,423,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3634,3621,3620,3622,3621,3623,3631,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1020,SUCCESS
    732,2021-07-01 16:55:36,2933.671,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25373,515,515,8,18,26,423,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3634,3621,3620,3622,3621,3623,3631,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,971,SUCCESS
    733,2021-07-01 16:55:40,2937.686,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25374,514,515,8,19,26,424,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3634,3622,3621,3623,3621,3623,3631,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,988,SUCCESS
    734,2021-07-01 16:55:44,2941.692,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25378,515,515,8,19,26,425,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3634,3622,3621,3623,3622,3624,3632,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,983,SUCCESS
    735,2021-07-01 16:55:48,2945.697,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25379,516,515,8,19,26,425,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3635,3622,3621,3623,3622,3624,3632,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1009,SUCCESS
    736,2021-07-01 16:55:52,2949.712,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25380,515,515,8,19,26,426,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3635,3623,3621,3623,3622,3624,3632,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,977,SUCCESS
    737,2021-07-01 16:55:56,2953.726,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25381,515,515,8,19,26,426,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3635,3623,3621,3624,3622,3624,3632,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,996,SUCCESS
    738,2021-07-01 16:56:00,2957.733,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25385,515,515,8,19,26,427,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3635,3623,3622,3624,3623,3624,3633,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1037,SUCCESS
    739,2021-07-01 16:56:04,2961.746,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25386,516,515,8,19,26,428,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3635,3623,3622,3624,3623,3624,3633,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,975,SUCCESS
    740,2021-07-01 16:56:08,2965.758,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25387,515,515,8,19,26,428,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3636,3624,3622,3624,3623,3625,3633,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.6,1031,SUCCESS
    741,2021-07-01 16:56:12,2969.760,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25387,515,515,8,19,26,429,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3636,3624,3622,3624,3623,3625,3633,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,961,SUCCESS
    742,2021-07-01 16:56:16,2973.770,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25387,515,515,8,19,26,429,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3636,3624,3623,3624,3623,3625,3633,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1029,SUCCESS
    743,2021-07-01 16:56:20,2977.788,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25388,516,515,8,19,26,430,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3636,3624,3623,3625,3624,3626,3634,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1062,SUCCESS
    744,2021-07-01 16:56:24,2981.783,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25391,516,515,8,19,26,430,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3636,3624,3623,3625,3624,3626,3634,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.8,1070,SUCCESS
    745,2021-07-01 16:56:28,2985.796,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25396,515,515,8,19,26,431,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3637,3625,3624,3626,3625,3626,3634,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1130,SUCCESS
    746,2021-07-01 16:56:32,2989.803,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25398,515,515,8,19,26,432,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3637,3625,3624,3626,3625,3626,3635,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.8,1090,SUCCESS
    747,2021-07-01 16:56:36,2993.816,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25402,514,515,8,19,26,432,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3637,3625,3624,3626,3625,3627,3635,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1045,SUCCESS
    748,2021-07-01 16:56:40,2997.823,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25402,515,515,8,19,26,433,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3638,3626,3624,3626,3625,3627,3635,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.8,1024,SUCCESS
    749,2021-07-01 16:56:44,3001.831,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25401,515,515,8,19,26,433,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3638,3626,3625,3626,3625,3627,3635,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.8,1045,SUCCESS
    750,2021-07-01 16:56:48,3005.843,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25405,514,515,8,19,27,434,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3638,3626,3625,3627,3626,3628,3635,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1049,SUCCESS
    751,2021-07-01 16:56:52,3009.849,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25406,516,515,8,19,27,434,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3639,3626,3625,3627,3626,3628,3636,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.6,1049,SUCCESS
    752,2021-07-01 16:56:56,3013.864,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25407,514,515,8,19,27,435,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3639,3626,3625,3627,3626,3628,3636,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1042,SUCCESS
    753,2021-07-01 16:57:01,3017.888,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25408,515,515,8,19,27,436,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3639,3626,3626,3627,3626,3628,3636,0,0,0,0,0,0,0,0,2805,24.5,24.6,-273.2,24.6,-273.2,33.7,1068,SUCCESS
    754,2021-07-01 16:57:05,3021.904,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25410,515,515,8,19,27,436,2352,65535,65535,295,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3639,3627,3626,3627,3627,3628,3637,0,0,0,0,0,0,0,0,2809,24.5,24.6,-273.2,24.6,-273.2,33.7,1067,SUCCESS
    755,2021-07-01 16:57:09,3025.904,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25412,515,515,8,19,27,437,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3627,3626,3628,3627,3628,3637,0,0,0,0,0,0,0,0,2809,24.5,24.6,-273.2,24.6,-273.2,33.7,1004,SUCCESS
    756,2021-07-01 16:57:13,3029.919,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25415,516,515,8,19,27,437,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3627,3627,3628,3627,3629,3637,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1082,SUCCESS
    757,2021-07-01 16:57:17,3033.931,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25416,515,515,8,19,27,438,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3628,3627,3628,3627,3629,3637,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,960,SUCCESS
    758,2021-07-01 16:57:21,3037.939,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25416,516,515,8,19,27,438,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3628,3627,3628,3628,3629,3637,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1110,SUCCESS
    759,2021-07-01 16:57:25,3041.952,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25420,516,515,8,19,27,439,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3628,3627,3629,3628,3630,3638,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.2,1073,SUCCESS
    760,2021-07-01 16:57:29,3045.956,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25420,515,515,8,19,27,440,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3640,3628,3627,3629,3628,3630,3638,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.8,1005,SUCCESS
    761,2021-07-01 16:57:33,3049.964,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25421,515,515,8,19,27,440,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3641,3628,3627,3629,3628,3630,3638,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,992,SUCCESS
    762,2021-07-01 16:57:37,3053.970,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25423,516,515,8,19,27,441,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3641,3629,3627,3629,3628,3630,3638,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1080,SUCCESS
    763,2021-07-01 16:57:41,3057.969,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25423,515,515,8,19,27,441,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3641,3629,3627,3629,3628,3630,3638,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1018,SUCCESS
    764,2021-07-01 16:57:45,3061.972,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25427,515,515,8,19,27,442,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3642,3629,3627,3630,3629,3631,3639,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1048,SUCCESS
    765,2021-07-01 16:57:49,3065.982,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25428,514,515,8,19,27,442,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3642,3629,3627,3630,3629,3630,3639,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.8,972,SUCCESS
    766,2021-07-01 16:57:53,3069.985,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25428,514,515,8,19,27,443,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3642,3629,3627,3630,3629,3629,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1032,SUCCESS
    767,2021-07-01 16:57:57,3073.986,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25429,515,515,8,19,27,444,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3642,3630,3627,3630,3629,3629,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.8,1048,SUCCESS
    768,2021-07-01 16:58:01,3077.993,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25431,515,515,8,19,27,444,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3642,3630,3628,3630,3629,3627,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,980,SUCCESS
    769,2021-07-01 16:58:05,3082.008,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25433,514,515,8,19,27,445,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3643,3630,3628,3631,3629,3631,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1104,SUCCESS
    770,2021-07-01 16:58:09,3086.013,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25435,516,515,8,19,27,445,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3643,3630,3629,3631,3630,3633,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,989,SUCCESS
    771,2021-07-01 16:58:13,3090.020,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25436,514,515,8,19,27,446,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3643,3631,3629,3631,3630,3632,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1045,SUCCESS
    772,2021-07-01 16:58:17,3094.023,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25438,515,515,8,19,27,446,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3643,3631,3629,3631,3631,3632,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,947,SUCCESS
    773,2021-07-01 16:58:21,3098.024,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25439,515,515,8,20,27,447,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3643,3631,3630,3632,3631,3638,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.1,1064,SUCCESS
    774,2021-07-01 16:58:25,3102.031,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25441,516,515,8,20,27,448,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3644,3631,3630,3632,3631,3633,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1065,SUCCESS
    775,2021-07-01 16:58:29,3106.039,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25441,515,515,8,20,27,448,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3644,3631,3630,3632,3631,3633,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,978,SUCCESS
    776,2021-07-01 16:58:33,3110.053,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25441,516,515,8,20,27,449,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3644,3632,3631,3632,3631,3633,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1043,SUCCESS
    777,2021-07-01 16:58:37,3114.054,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25443,516,515,8,20,27,449,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3644,3632,3631,3632,3632,3633,3641,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,946,SUCCESS
    778,2021-07-01 16:58:41,3118.058,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25446,515,515,8,20,27,450,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3645,3632,3631,3633,3632,3633,3640,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1039,SUCCESS
    779,2021-07-01 16:58:45,3122.069,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25446,516,516,8,20,28,451,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3645,3632,3631,3633,3632,3633,3641,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.8,1032,SUCCESS
    780,2021-07-01 16:58:49,3126.071,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25448,516,515,8,20,28,451,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3645,3632,3631,3633,3632,3634,3641,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,962,SUCCESS
    781,2021-07-01 16:58:53,3130.081,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25448,515,515,8,20,28,452,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3645,3632,3632,3634,3632,3634,3641,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.8,1172,SUCCESS
    782,2021-07-01 16:58:57,3134.080,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25452,516,515,8,20,28,452,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3645,3632,3632,3634,3633,3634,3642,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1047,SUCCESS
    783,2021-07-01 16:59:01,3138.095,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25453,515,515,8,20,28,453,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3646,3633,3632,3635,3633,3634,3642,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1034,SUCCESS
    784,2021-07-01 16:59:05,3142.107,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25456,515,515,8,20,28,453,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3646,3633,3632,3635,3633,3634,3642,0,0,0,0,0,0,0,0,2810,24.5,24.6,-273.2,24.6,-273.2,33.7,1051,SUCCESS
    785,2021-07-01 16:59:09,3146.118,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25456,515,515,8,20,28,454,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3646,3633,3632,3635,3633,3635,3643,0,0,0,0,0,0,0,0,2814,24.5,24.6,-273.2,24.6,-273.2,33.8,1009,SUCCESS
    786,2021-07-01 16:59:13,3150.128,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25457,515,515,8,20,28,455,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3646,3634,3632,3635,3633,3635,3643,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1108,SUCCESS
    787,2021-07-01 16:59:17,3154.141,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25459,516,515,8,20,28,455,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3646,3634,3633,3635,3634,3635,3643,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.3,977,SUCCESS
    788,2021-07-01 16:59:21,3158.156,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25461,516,515,8,20,28,456,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3647,3634,3633,3635,3634,3635,3643,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1066,SUCCESS
    789,2021-07-01 16:59:25,3162.162,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25462,515,515,8,20,28,456,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3647,3634,3633,3635,3634,3636,3643,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1012,SUCCESS
    790,2021-07-01 16:59:29,3166.174,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25463,515,515,8,20,28,457,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3647,3634,3634,3635,3634,3636,3643,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1064,SUCCESS
    791,2021-07-01 16:59:33,3170.179,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25464,516,515,8,20,28,457,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3647,3635,3634,3635,3634,3636,3644,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1013,SUCCESS
    792,2021-07-01 16:59:37,3174.190,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25465,516,515,8,20,28,458,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3648,3635,3634,3635,3634,3636,3644,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1032,SUCCESS
    793,2021-07-01 16:59:41,3178.190,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25466,516,515,8,20,28,459,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3647,3635,3634,3635,3635,3636,3644,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1067,SUCCESS
    794,2021-07-01 16:59:45,3182.200,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25468,516,515,8,20,28,459,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3648,3635,3634,3635,3635,3636,3644,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1067,SUCCESS
    795,2021-07-01 16:59:49,3186.203,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25469,515,515,8,20,28,460,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3648,3635,3634,3635,3635,3637,3644,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1033,SUCCESS
    796,2021-07-01 16:59:53,3190.204,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25469,515,515,8,20,28,460,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3648,3635,3635,3635,3635,3638,3644,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,989,SUCCESS
    797,2021-07-01 16:59:57,3194.207,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25471,516,515,8,20,28,461,2352,65535,65535,292,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3648,3635,3635,3635,3636,3637,3645,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,1030,SUCCESS
    798,2021-07-01 17:00:01,3198.213,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25474,514,515,8,20,28,462,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3636,3635,3636,3636,3637,3645,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1041,SUCCESS
    799,2021-07-01 17:00:05,3202.220,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25475,516,515,8,20,28,462,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3636,3635,3636,3636,3638,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,1047,SUCCESS
    800,2021-07-01 17:00:09,3206.225,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25476,515,515,8,20,28,463,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3636,3635,3636,3636,3638,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,949,SUCCESS
    801,2021-07-01 17:00:13,3210.241,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25477,515,515,8,20,28,463,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3636,3635,3637,3636,3638,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.0,1047,SUCCESS
    802,2021-07-01 17:00:17,3214.253,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25479,516,515,8,20,28,464,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3637,3636,3637,3636,3638,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1034,SUCCESS
    803,2021-07-01 17:00:21,3218.261,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25480,515,515,8,20,28,464,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3637,3636,3637,3637,3639,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,992,SUCCESS
    804,2021-07-01 17:00:25,3222.270,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25482,516,515,8,20,28,465,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3649,3637,3636,3637,3637,3639,3646,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,1030,SUCCESS
    805,2021-07-01 17:00:29,3226.271,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25482,515,515,8,20,28,466,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3650,3637,3637,3638,3637,3639,3647,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1046,SUCCESS
    806,2021-07-01 17:00:33,3230.274,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25485,516,515,8,20,28,466,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3650,3637,3637,3638,3637,3639,3647,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,963,SUCCESS
    807,2021-07-01 17:00:37,3234.285,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25488,516,516,8,20,29,467,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3637,3638,3637,3639,3647,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,999,SUCCESS
    808,2021-07-01 17:00:41,3238.292,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25489,516,516,8,20,29,467,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3637,3638,3637,3640,3647,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,977,SUCCESS
    809,2021-07-01 17:00:45,3242.303,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25489,516,516,8,20,29,468,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3637,3638,3638,3640,3647,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,1058,SUCCESS
    810,2021-07-01 17:00:49,3246.317,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25490,516,516,8,20,29,468,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3637,3638,3638,3640,3647,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.8,1044,SUCCESS
    811,2021-07-01 17:00:53,3250.331,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25491,515,516,8,20,29,469,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3638,3639,3639,3640,3647,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.8,1062,SUCCESS
    812,2021-07-01 17:00:57,3254.334,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25493,516,516,8,20,29,470,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3638,3638,3639,3639,3640,3648,0,0,0,0,0,0,0,0,2815,24.5,24.6,-273.2,24.6,-273.2,33.7,1042,SUCCESS
    813,2021-07-01 17:01:01,3258.335,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25495,516,516,8,20,29,470,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3652,3638,3638,3639,3639,3641,3648,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1076,SUCCESS
    814,2021-07-01 17:01:05,3262.340,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25497,516,516,8,21,29,471,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3651,3639,3638,3640,3639,3641,3648,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.7,1083,SUCCESS
    815,2021-07-01 17:01:09,3266.352,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25498,515,516,8,21,29,471,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3652,3639,3638,3640,3639,3642,3648,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,978,SUCCESS
    816,2021-07-01 17:01:13,3270.366,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25499,516,516,8,21,29,472,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3652,3639,3638,3640,3639,3642,3649,0,0,0,0,0,0,0,0,2815,24.5,24.7,-273.2,24.7,-273.2,33.8,1027,SUCCESS
    817,2021-07-01 17:01:17,3274.367,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25501,515,516,8,21,29,473,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3652,3640,3639,3640,3640,3642,3649,0,0,0,0,0,0,0,0,2819,24.5,24.7,-273.2,24.7,-273.2,33.7,994,SUCCESS
    818,2021-07-01 17:01:21,3278.381,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25502,516,516,8,21,29,473,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3652,3640,3639,3640,3640,3642,3649,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,1028,SUCCESS
    819,2021-07-01 17:01:25,3282.395,0x0701,150,10,0x6001,0,65535,65535,1,24.6,25502,516,516,8,21,29,474,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3653,3640,3639,3640,3640,3642,3649,0,0,0,0,0,0,0,0,2820,24.5,24.6,-273.2,24.6,-273.2,33.7,1125,SUCCESS
    820,2021-07-01 17:01:29,3286.397,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25502,515,516,8,21,29,474,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3653,3640,3640,3641,3640,3642,3649,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1042,SUCCESS
    821,2021-07-01 17:01:33,3290.400,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25504,515,516,8,21,29,475,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3653,3640,3640,3641,3640,3642,3649,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1040,SUCCESS
    822,2021-07-01 17:01:37,3294.415,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25507,516,516,8,21,29,475,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3654,3640,3640,3641,3640,3642,3650,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,963,SUCCESS
    823,2021-07-01 17:01:41,3298.417,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25510,516,516,8,21,29,476,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3654,3641,3640,3641,3640,3642,3650,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,991,SUCCESS
    824,2021-07-01 17:01:45,3302.421,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25509,515,516,8,21,29,477,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3654,3641,3640,3641,3641,3642,3650,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1037,SUCCESS
    825,2021-07-01 17:01:49,3306.425,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25511,515,516,8,21,29,477,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3654,3641,3640,3642,3641,3642,3650,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1078,SUCCESS
    826,2021-07-01 17:01:53,3310.430,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25512,515,516,8,21,29,478,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3654,3641,3640,3642,3641,3642,3650,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,995,SUCCESS
    827,2021-07-01 17:01:57,3314.443,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25517,516,516,8,21,29,478,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3655,3641,3641,3642,3642,3643,3651,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1075,SUCCESS
    828,2021-07-01 17:02:01,3318.444,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25521,516,516,8,21,29,479,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3655,3642,3641,3642,3642,3643,3651,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,1024,SUCCESS
    829,2021-07-01 17:02:05,3322.445,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25519,516,516,8,21,29,479,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3655,3642,3641,3643,3642,3644,3651,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,996,SUCCESS
    830,2021-07-01 17:02:09,3326.449,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25518,516,516,8,21,29,480,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3655,3642,3641,3643,3642,3643,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,943,SUCCESS
    831,2021-07-01 17:02:13,3330.456,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25519,516,516,8,21,29,481,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3656,3643,3641,3643,3642,3643,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1093,SUCCESS
    832,2021-07-01 17:02:17,3334.467,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25521,515,516,8,21,29,481,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3656,3643,3642,3643,3642,3643,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,940,SUCCESS
    833,2021-07-01 17:02:21,3338.476,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25522,516,516,8,21,29,482,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3656,3643,3642,3643,3643,3643,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1011,SUCCESS
    834,2021-07-01 17:02:25,3342.478,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25523,515,516,8,21,29,482,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3643,3642,3643,3643,3643,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.0,1079,SUCCESS
    835,2021-07-01 17:02:29,3346.489,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25525,516,516,8,21,29,483,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3643,3642,3644,3643,3644,3652,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.4,971,SUCCESS
    836,2021-07-01 17:02:33,3350.496,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25526,516,516,8,21,29,483,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3643,3643,3644,3643,3645,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,991,SUCCESS
    837,2021-07-01 17:02:37,3354.506,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25529,515,516,8,21,30,484,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3644,3643,3644,3643,3645,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1122,SUCCESS
    838,2021-07-01 17:02:41,3358.509,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25529,516,516,8,21,30,485,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3644,3643,3644,3643,3645,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1009,SUCCESS
    839,2021-07-01 17:02:45,3362.523,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25530,516,516,8,21,30,485,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3644,3643,3644,3644,3645,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,947,SUCCESS
    840,2021-07-01 17:02:49,3366.529,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25531,517,516,8,21,30,486,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3644,3643,3644,3644,3645,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,1020,SUCCESS
    841,2021-07-01 17:02:53,3370.532,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25532,515,516,8,21,30,486,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3645,3644,3646,3653,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,1033,SUCCESS
    842,2021-07-01 17:02:57,3374.540,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25535,515,516,8,21,30,487,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3645,3645,3646,3654,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.7,998,SUCCESS
    843,2021-07-01 17:03:01,3378.553,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25536,516,516,8,21,30,487,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3645,3645,3646,3654,0,0,0,0,0,0,0,0,2820,24.5,24.7,-273.2,24.7,-273.2,33.8,999,SUCCESS
    844,2021-07-01 17:03:05,3382.555,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25536,515,516,8,21,30,488,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3645,3645,3646,3654,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.8,970,SUCCESS
    845,2021-07-01 17:03:09,3386.563,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25537,515,516,8,21,30,489,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3646,3645,3646,3654,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.8,1051,SUCCESS
    846,2021-07-01 17:03:13,3390.571,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25538,516,516,8,21,30,489,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3646,3645,3646,3655,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.7,1057,SUCCESS
    847,2021-07-01 17:03:17,3394.580,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25538,515,516,8,21,30,490,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3644,3646,3645,3646,3655,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.7,1017,SUCCESS
    848,2021-07-01 17:03:21,3398.582,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25540,516,516,8,21,30,490,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3657,3645,3645,3646,3645,3647,3655,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.3,993,SUCCESS
    849,2021-07-01 17:03:25,3402.591,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25541,516,516,8,21,30,491,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3658,3645,3645,3646,3645,3645,3655,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.8,1007,SUCCESS
    850,2021-07-01 17:03:29,3406.599,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25543,516,516,8,21,30,491,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3658,3645,3645,3646,3645,3648,3655,0,0,0,0,0,0,0,0,2820,24.6,24.7,-273.2,24.7,-273.2,33.8,1059,SUCCESS
    851,2021-07-01 17:03:33,3410.612,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25544,515,516,8,21,30,492,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3658,3645,3646,3647,3647,3648,3655,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,1047,SUCCESS
    852,2021-07-01 17:03:37,3414.628,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25546,516,516,8,21,30,493,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3659,3645,3646,3647,3646,3648,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,1013,SUCCESS
    853,2021-07-01 17:03:41,3418.633,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25547,516,516,8,21,30,493,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3659,3645,3646,3647,3646,3648,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,994,SUCCESS
    854,2021-07-01 17:03:45,3422.641,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25547,516,516,8,22,30,494,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3659,3645,3646,3647,3646,3648,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,986,SUCCESS
    855,2021-07-01 17:03:49,3426.645,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25549,516,516,8,22,30,494,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3659,3646,3646,3647,3647,3648,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,997,SUCCESS
    856,2021-07-01 17:03:53,3430.656,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25550,516,516,8,22,30,495,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3659,3646,3646,3647,3647,3649,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1003,SUCCESS
    857,2021-07-01 17:03:57,3434.667,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25552,517,516,8,22,30,496,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3660,3646,3647,3648,3647,3649,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1053,SUCCESS
    858,2021-07-01 17:04:01,3438.680,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25555,515,516,8,22,30,496,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3660,3647,3647,3648,3647,3649,3656,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1024,SUCCESS
    859,2021-07-01 17:04:05,3442.736,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25555,517,516,8,22,30,497,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3660,3647,3647,3648,3648,3649,3657,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1015,SUCCESS
    860,2021-07-01 17:04:09,3446.702,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25557,517,516,8,22,30,497,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3660,3647,3647,3648,3648,3649,3657,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1035,SUCCESS
    861,2021-07-01 17:04:13,3450.703,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25557,514,516,8,22,30,498,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3660,3647,3647,3649,3648,3649,3657,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1034,SUCCESS
    862,2021-07-01 17:04:17,3454.716,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25560,516,516,8,22,30,498,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3661,3648,3647,3649,3648,3649,3658,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,974,SUCCESS
    863,2021-07-01 17:04:21,3458.730,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25561,515,516,8,22,30,499,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3661,3648,3648,3649,3648,3650,3658,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,989,SUCCESS
    864,2021-07-01 17:04:25,3462.746,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25562,515,516,8,22,30,500,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3661,3648,3648,3649,3648,3650,3658,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,1007,SUCCESS
    865,2021-07-01 17:04:29,3466.758,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25562,515,516,8,22,30,500,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3661,3648,3648,3649,3649,3650,3658,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,962,SUCCESS
    866,2021-07-01 17:04:33,3470.764,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25565,516,516,8,22,31,501,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3648,3649,3649,3650,3658,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,955,SUCCESS
    867,2021-07-01 17:04:37,3474.771,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25568,516,516,8,22,31,501,2352,65535,65535,287,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3648,3650,3649,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.3,1004,SUCCESS
    868,2021-07-01 17:04:41,3478.775,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25569,515,516,8,22,31,502,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3649,3650,3649,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,993,SUCCESS
    869,2021-07-01 17:04:45,3482.782,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25569,516,516,8,22,31,502,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3649,3650,3649,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1020,SUCCESS
    870,2021-07-01 17:04:49,3486.795,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25569,516,516,8,22,31,503,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3649,3650,3649,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1098,SUCCESS
    871,2021-07-01 17:04:53,3490.798,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25569,517,516,8,22,31,504,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3662,3649,3649,3650,3649,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,1033,SUCCESS
    872,2021-07-01 17:04:57,3494.807,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25571,516,516,8,22,31,504,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3663,3650,3649,3650,3650,3651,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.7,1069,SUCCESS
    873,2021-07-01 17:05:01,3498.807,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25574,516,516,8,22,31,505,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3663,3650,3649,3651,3650,3652,3659,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,994,SUCCESS
    874,2021-07-01 17:05:05,3502.813,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25576,515,516,8,22,31,505,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3663,3650,3650,3651,3650,3652,3660,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1004,SUCCESS
    875,2021-07-01 17:05:09,3506.818,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25577,516,516,8,22,31,506,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3663,3650,3650,3651,3651,3652,3660,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,982,SUCCESS
    876,2021-07-01 17:05:13,3510.830,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25577,516,516,8,22,31,506,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3663,3650,3650,3651,3651,3652,3660,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1064,SUCCESS
    877,2021-07-01 17:05:17,3514.842,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25580,516,516,8,22,31,507,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3664,3650,3650,3652,3651,3653,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1019,SUCCESS
    878,2021-07-01 17:05:21,3518.856,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25582,516,516,8,22,31,508,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3664,3651,3650,3652,3651,3653,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,990,SUCCESS
    879,2021-07-01 17:05:25,3522.862,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25583,515,516,8,22,31,508,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3664,3651,3650,3652,3651,3653,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1080,SUCCESS
    880,2021-07-01 17:05:30,3526.873,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25583,516,516,8,22,31,509,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3664,3651,3651,3652,3651,3653,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1002,SUCCESS
    881,2021-07-01 17:05:34,3530.889,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25585,515,516,8,22,31,509,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3651,3652,3652,3653,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.4,1041,SUCCESS
    882,2021-07-01 17:05:38,3534.894,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25587,515,516,8,22,31,510,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3651,3653,3652,3654,3661,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1093,SUCCESS
    883,2021-07-01 17:05:42,3538.899,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25589,517,516,8,22,31,511,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3652,3653,3652,3654,3662,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1089,SUCCESS
    884,2021-07-01 17:05:46,3542.951,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25589,516,516,8,22,31,511,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3652,3653,3652,3654,3662,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1069,SUCCESS
    885,2021-07-01 17:05:50,3546.919,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25590,515,516,8,22,31,512,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3652,3653,3652,3654,3662,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,975,SUCCESS
    886,2021-07-01 17:05:54,3550.934,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25590,516,516,8,22,31,512,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3665,3652,3652,3653,3652,3654,3662,0,0,0,0,0,0,0,0,2825,24.6,24.7,-273.2,24.7,-273.2,33.8,1023,SUCCESS
    887,2021-07-01 17:05:58,3554.944,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25590,516,516,8,22,31,513,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3653,3652,3653,3653,3654,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,980,SUCCESS
    888,2021-07-01 17:06:02,3558.957,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25594,517,516,8,22,31,514,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3653,3652,3653,3653,3654,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.7,1068,SUCCESS
    889,2021-07-01 17:06:06,3562.971,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25595,516,516,8,22,31,514,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3653,3652,3653,3653,3655,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.7,1078,SUCCESS
    890,2021-07-01 17:06:10,3566.985,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25597,515,516,8,22,31,515,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3653,3653,3654,3653,3655,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1062,SUCCESS
    891,2021-07-01 17:06:14,3570.987,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25599,517,516,8,22,31,515,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3654,3653,3654,3654,3655,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1031,SUCCESS
    892,2021-07-01 17:06:18,3575.002,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25599,515,516,8,22,31,516,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3654,3653,3654,3654,3656,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1095,SUCCESS
    893,2021-07-01 17:06:22,3579.011,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25601,517,516,8,22,31,516,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3666,3654,3653,3655,3654,3656,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1087,SUCCESS
    894,2021-07-01 17:06:26,3583.015,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25602,516,516,8,22,32,517,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3667,3654,3653,3655,3654,3656,3663,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1081,SUCCESS
    895,2021-07-01 17:06:30,3587.019,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25603,515,516,8,23,32,518,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3667,3654,3653,3655,3654,3656,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.6,1067,SUCCESS
    896,2021-07-01 17:06:34,3591.023,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25602,516,516,8,23,32,518,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3667,3654,3654,3655,3654,3656,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.5,1048,SUCCESS
    897,2021-07-01 17:06:38,3595.029,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25606,516,516,8,23,32,519,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3654,3654,3655,3655,3656,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1021,SUCCESS
    898,2021-07-01 17:06:42,3599.035,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25607,515,516,8,23,32,519,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3655,3654,3656,3655,3656,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.7,1045,SUCCESS
    899,2021-07-01 17:06:46,3603.047,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25608,515,516,8,23,32,520,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3655,3654,3656,3655,3657,3664,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1003,SUCCESS
    900,2021-07-01 17:06:50,3607.050,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25609,516,516,8,23,32,520,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3655,3655,3656,3655,3656,3665,0,0,0,0,0,0,0,0,2830,24.6,24.8,-273.2,24.8,-273.2,33.8,1030,SUCCESS
    901,2021-07-01 17:06:54,3611.057,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25611,516,516,8,23,32,521,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3655,3655,3656,3655,3656,3665,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1008,SUCCESS
    902,2021-07-01 17:06:58,3615.071,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25610,516,516,8,23,32,522,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3668,3655,3655,3656,3655,3657,3665,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1071,SUCCESS
    903,2021-07-01 17:07:02,3619.084,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25614,515,516,8,23,32,522,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3656,3655,3656,3656,3658,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.7,1106,SUCCESS
    904,2021-07-01 17:07:06,3623.087,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25614,516,516,8,23,32,523,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3656,3655,3656,3656,3658,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.9,984,SUCCESS
    905,2021-07-01 17:07:10,3627.102,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25616,516,516,8,23,32,523,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3656,3655,3657,3656,3658,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1009,SUCCESS
    906,2021-07-01 17:07:14,3631.114,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25619,515,516,8,23,32,524,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3656,3656,3657,3656,3658,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1093,SUCCESS
    907,2021-07-01 17:07:18,3635.114,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25621,515,516,8,23,32,524,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3656,3656,3657,3656,3658,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,964,SUCCESS
    908,2021-07-01 17:07:22,3639.122,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25620,516,516,8,23,32,525,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3669,3657,3656,3657,3657,3660,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1035,SUCCESS
    909,2021-07-01 17:07:26,3643.126,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25622,516,516,8,23,32,526,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3670,3657,3657,3658,3657,3659,3666,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.5,1101,SUCCESS
    910,2021-07-01 17:07:30,3647.130,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25623,516,516,8,23,32,526,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3670,3657,3657,3658,3657,3659,3667,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1029,SUCCESS
    911,2021-07-01 17:07:34,3651.136,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25625,515,516,8,23,32,527,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3670,3657,3657,3658,3657,3659,3667,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,977,SUCCESS
    912,2021-07-01 17:07:38,3655.140,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25625,515,516,8,23,32,527,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3670,3657,3657,3658,3657,3659,3667,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1020,SUCCESS
    913,2021-07-01 17:07:42,3659.147,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25626,515,516,8,23,32,528,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3671,3658,3657,3658,3657,3659,3667,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,1043,SUCCESS
    914,2021-07-01 17:07:46,3663.155,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25628,515,516,8,23,32,528,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3671,3658,3657,3658,3658,3659,3667,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.9,1042,SUCCESS
    915,2021-07-01 17:07:50,3667.161,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25630,516,516,8,23,32,529,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3671,3658,3658,3659,3658,3660,3668,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,981,SUCCESS
    916,2021-07-01 17:07:54,3671.166,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25632,515,516,8,23,32,530,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3671,3658,3658,3659,3658,3660,3668,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.7,1080,SUCCESS
    917,2021-07-01 17:07:58,3675.171,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25633,515,515,8,23,32,530,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3671,3658,3658,3659,3659,3660,3668,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.8,989,SUCCESS
    918,2021-07-01 17:08:02,3679.176,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25634,515,515,8,23,32,531,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3672,3659,3658,3659,3659,3660,3668,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.9,1029,SUCCESS
    919,2021-07-01 17:08:06,3683.200,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25636,515,515,8,23,32,531,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3672,3659,3658,3660,3659,3660,3668,0,0,0,0,0,0,0,0,2830,24.6,24.7,-273.2,24.7,-273.2,33.9,1021,SUCCESS
    920,2021-07-01 17:08:10,3687.201,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25637,515,515,8,23,32,532,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3672,3659,3658,3660,3659,3661,3668,0,0,0,0,0,0,0,0,2831,24.6,24.7,-273.2,24.7,-273.2,33.8,989,SUCCESS
    921,2021-07-01 17:08:14,3691.217,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25639,515,515,8,23,32,533,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3672,3659,3659,3660,3659,3661,3669,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1070,SUCCESS
    922,2021-07-01 17:08:18,3695.218,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25640,515,515,8,23,32,533,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3672,3660,3659,3660,3660,3661,3669,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1034,SUCCESS
    923,2021-07-01 17:08:22,3699.223,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25640,516,515,8,23,33,534,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3673,3660,3659,3660,3660,3661,3669,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.2,1003,SUCCESS
    924,2021-07-01 17:08:26,3703.236,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25643,516,515,8,23,33,534,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3673,3660,3659,3661,3660,3661,3669,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1049,SUCCESS
    925,2021-07-01 17:08:30,3707.246,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25646,515,515,8,23,33,535,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3673,3660,3660,3661,3660,3662,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,992,SUCCESS
    926,2021-07-01 17:08:34,3711.261,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25646,516,515,8,23,33,535,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3673,3660,3660,3661,3660,3662,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1054,SUCCESS
    927,2021-07-01 17:08:38,3715.263,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25646,515,515,8,23,33,536,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3673,3660,3660,3661,3660,3660,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1070,SUCCESS
    928,2021-07-01 17:08:42,3719.266,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25648,516,516,8,23,33,537,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3660,3661,3660,3660,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1051,SUCCESS
    929,2021-07-01 17:08:46,3723.269,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25650,516,516,8,23,33,537,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3660,3661,3661,3663,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.9,1037,SUCCESS
    930,2021-07-01 17:08:50,3727.273,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25651,515,515,8,23,33,538,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3660,3662,3661,3663,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,995,SUCCESS
    931,2021-07-01 17:08:54,3731.278,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25652,516,515,8,23,33,538,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3661,3662,3661,3664,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1037,SUCCESS
    932,2021-07-01 17:08:58,3735.291,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25653,516,516,8,23,33,539,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3661,3662,3661,3663,3670,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,993,SUCCESS
    933,2021-07-01 17:09:02,3739.305,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25653,516,515,8,23,33,539,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3674,3661,3661,3662,3661,3663,3671,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.9,946,SUCCESS
    934,2021-07-01 17:09:06,3743.309,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25657,516,515,8,23,33,540,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3661,3661,3663,3662,3663,3671,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.9,1053,SUCCESS
    935,2021-07-01 17:09:10,3747.313,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25657,515,515,8,24,33,541,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3662,3661,3663,3662,3664,3671,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1017,SUCCESS
    936,2021-07-01 17:09:14,3751.328,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25659,515,515,8,24,33,541,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3662,3662,3663,3662,3664,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1098,SUCCESS
    937,2021-07-01 17:09:18,3755.340,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25660,516,515,8,24,33,542,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3662,3662,3663,3662,3664,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.9,1053,SUCCESS
    938,2021-07-01 17:09:22,3759.355,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25661,515,515,8,24,33,542,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3663,3662,3663,3662,3664,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1148,SUCCESS
    939,2021-07-01 17:09:26,3763.360,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25662,516,515,8,24,33,543,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3675,3663,3662,3663,3663,3664,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1015,SUCCESS
    940,2021-07-01 17:09:30,3767.372,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25664,516,515,8,24,33,543,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3676,3663,3662,3663,3663,3664,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1039,SUCCESS
    941,2021-07-01 17:09:34,3771.382,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25665,515,515,8,24,33,544,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3676,3663,3663,3663,3663,3665,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.9,963,SUCCESS
    942,2021-07-01 17:09:38,3775.385,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25667,516,516,8,24,33,545,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3676,3663,3663,3664,3663,3665,3672,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.1,1062,SUCCESS
    943,2021-07-01 17:09:42,3779.387,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25667,514,516,8,24,33,545,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3676,3663,3663,3664,3663,3665,3673,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1006,SUCCESS
    944,2021-07-01 17:09:46,3783.402,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25668,515,515,8,24,33,546,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3676,3663,3663,3664,3663,3665,3673,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.9,1133,SUCCESS
    945,2021-07-01 17:09:50,3787.407,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25669,515,515,8,24,33,546,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3664,3663,3664,3664,3665,3673,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1082,SUCCESS
    946,2021-07-01 17:09:54,3791.413,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25671,514,515,8,24,33,547,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3664,3664,3664,3664,3666,3673,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.9,981,SUCCESS
    947,2021-07-01 17:09:58,3795.427,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25674,515,515,8,24,33,547,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3664,3664,3665,3665,3666,3673,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1061,SUCCESS
    948,2021-07-01 17:10:02,3799.439,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25675,515,515,8,24,33,548,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3664,3664,3665,3665,3666,3674,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.8,1079,SUCCESS
    949,2021-07-01 17:10:06,3803.440,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25675,516,515,8,24,33,549,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3664,3664,3665,3666,3666,3674,0,0,0,0,0,0,0,0,2835,24.6,24.8,-273.2,24.8,-273.2,33.9,989,SUCCESS
    950,2021-07-01 17:10:10,3807.446,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25676,515,515,8,24,33,549,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3677,3665,3664,3665,3666,3666,3674,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1016,SUCCESS
    951,2021-07-01 17:10:14,3811.456,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25679,515,515,8,24,33,550,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3678,3665,3664,3666,3666,3666,3674,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,1031,SUCCESS
    952,2021-07-01 17:10:18,3815.461,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25681,515,515,8,24,33,550,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3678,3665,3664,3666,3666,3667,3675,0,0,0,0,0,0,0,0,2835,24.6,24.7,-273.2,24.7,-273.2,33.8,981,SUCCESS
    953,2021-07-01 17:10:22,3819.472,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25681,515,515,8,24,34,551,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3678,3665,3665,3666,3666,3667,3675,0,0,0,0,0,0,0,0,2840,24.6,24.7,-273.2,24.7,-273.2,33.9,1063,SUCCESS
    954,2021-07-01 17:10:26,3823.480,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25682,515,515,8,24,34,552,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3678,3665,3665,3666,3666,3667,3675,0,0,0,0,0,0,0,0,2840,24.6,24.7,-273.2,24.7,-273.2,33.8,1037,SUCCESS
    955,2021-07-01 17:10:30,3827.485,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25683,515,515,8,24,34,552,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3678,3666,3665,3666,3666,3667,3675,0,0,0,0,0,0,0,0,2840,24.6,24.7,-273.2,24.7,-273.2,33.7,1053,SUCCESS
    956,2021-07-01 17:10:34,3831.499,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25684,515,515,8,24,34,553,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3679,3666,3666,3667,3666,3667,3675,0,0,0,0,0,0,0,0,2840,24.6,24.7,-273.2,24.7,-273.2,33.5,1072,SUCCESS
    957,2021-07-01 17:10:38,3835.510,0x0701,150,10,0x6001,0,65535,65535,1,24.7,25688,516,515,8,24,34,553,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3679,3666,3666,3667,3666,3668,3675,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.7,-273.2,33.9,962,SUCCESS
    958,2021-07-01 17:10:42,3839.521,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25688,516,515,8,24,34,554,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3679,3666,3666,3667,3666,3668,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,966,SUCCESS
    959,2021-07-01 17:10:46,3843.523,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25688,515,515,8,24,34,554,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3679,3666,3666,3667,3666,3668,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1012,SUCCESS
    960,2021-07-01 17:10:50,3847.535,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25690,515,515,8,24,34,555,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3666,3667,3666,3668,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1078,SUCCESS
    961,2021-07-01 17:10:54,3851.548,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25690,516,515,8,24,34,556,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3666,3667,3666,3668,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1046,SUCCESS
    962,2021-07-01 17:10:58,3855.563,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25692,514,515,8,24,34,556,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3666,3668,3666,3669,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1095,SUCCESS
    963,2021-07-01 17:11:02,3859.570,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25693,515,515,8,24,34,557,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3667,3668,3666,3669,3676,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,963,SUCCESS
    964,2021-07-01 17:11:06,3863.584,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25694,515,515,8,24,34,557,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3667,3668,3666,3669,3677,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1029,SUCCESS
    965,2021-07-01 17:11:10,3867.598,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25694,514,515,8,24,34,558,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3680,3667,3667,3668,3667,3669,3677,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1026,SUCCESS
    966,2021-07-01 17:11:14,3871.604,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25697,514,515,8,24,34,558,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3668,3667,3668,3667,3669,3677,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1036,SUCCESS
    967,2021-07-01 17:11:18,3875.607,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25699,515,515,8,24,34,559,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3668,3667,3669,3667,3669,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1068,SUCCESS
    968,2021-07-01 17:11:22,3879.617,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25701,515,515,8,24,34,560,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3668,3668,3669,3667,3669,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,948,SUCCESS
    969,2021-07-01 17:11:26,3883.623,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25701,516,515,8,24,34,560,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3668,3668,3669,3668,3669,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1036,SUCCESS
    970,2021-07-01 17:11:30,3887.635,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25703,515,515,8,24,34,561,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3669,3668,3669,3668,3670,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,992,SUCCESS
    971,2021-07-01 17:11:34,3891.643,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25703,515,515,8,24,34,561,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3669,3668,3669,3668,3671,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1096,SUCCESS
    972,2021-07-01 17:11:38,3895.647,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25706,515,515,8,24,34,562,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3681,3669,3668,3669,3668,3671,3678,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1060,SUCCESS
    973,2021-07-01 17:11:42,3899.653,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25709,515,515,8,24,34,562,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3682,3669,3669,3670,3669,3671,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1068,SUCCESS
    974,2021-07-01 17:11:46,3903.658,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25709,514,515,8,24,34,563,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3682,3669,3669,3670,3669,3671,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1046,SUCCESS
    975,2021-07-01 17:11:50,3907.663,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25708,515,515,8,24,34,564,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3669,3669,3670,3669,3671,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.7,986,SUCCESS
    976,2021-07-01 17:11:54,3911.666,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25711,515,515,8,24,34,564,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3669,3670,3669,3671,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,944,SUCCESS
    977,2021-07-01 17:11:58,3915.671,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25711,515,515,8,25,34,565,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3669,3670,3669,3671,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,956,SUCCESS
    978,2021-07-01 17:12:02,3919.677,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25713,514,515,8,25,34,565,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3670,3671,3669,3672,3679,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1005,SUCCESS
    979,2021-07-01 17:12:06,3923.687,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25714,514,515,8,25,34,566,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3670,3671,3670,3672,3680,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1143,SUCCESS
    980,2021-07-01 17:12:10,3927.702,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25716,515,515,8,25,34,566,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3670,3671,3670,3672,3680,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1067,SUCCESS
    981,2021-07-01 17:12:14,3931.712,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25716,515,515,8,25,35,567,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3683,3670,3670,3671,3670,3672,3680,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,978,SUCCESS
    982,2021-07-01 17:12:18,3935.722,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25717,515,514,8,25,35,568,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3684,3670,3670,3671,3671,3672,3680,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1047,SUCCESS
    983,2021-07-01 17:12:22,3939.725,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25722,515,514,8,25,35,568,2352,65535,65535,280,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3684,3671,3670,3672,3671,3672,3681,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1123,SUCCESS
    984,2021-07-01 17:12:26,3943.734,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25722,513,514,8,25,35,569,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3684,3671,3671,3672,3671,3673,3681,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1077,SUCCESS
    985,2021-07-01 17:12:30,3947.750,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25725,515,514,8,25,35,569,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3684,3671,3671,3672,3671,3674,3681,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.9,1066,SUCCESS
    986,2021-07-01 17:12:34,3951.755,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25725,514,514,8,25,35,570,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3672,3671,3672,3671,3673,3681,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1043,SUCCESS
    987,2021-07-01 17:12:38,3955.758,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25727,514,514,8,25,35,570,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3672,3672,3672,3672,3674,3681,0,0,0,0,0,0,0,0,2840,24.6,24.8,-273.2,24.8,-273.2,33.8,1009,SUCCESS
    988,2021-07-01 17:12:42,3959.770,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25728,515,514,8,25,35,571,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3672,3672,3673,3672,3674,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1094,SUCCESS
    989,2021-07-01 17:12:46,3963.777,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25730,514,514,8,25,35,572,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3672,3672,3673,3672,3675,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.7,1027,SUCCESS
    990,2021-07-01 17:12:50,3967.783,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25730,514,514,8,25,35,572,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3672,3672,3673,3672,3675,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1019,SUCCESS
    991,2021-07-01 17:12:54,3971.785,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25730,515,514,8,25,35,573,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3672,3672,3673,3672,3674,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1013,SUCCESS
    992,2021-07-01 17:12:58,3975.796,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25731,514,514,8,25,35,573,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3685,3673,3672,3673,3672,3674,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,940,SUCCESS
    993,2021-07-01 17:13:02,3979.799,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25732,515,514,8,25,35,574,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3673,3673,3673,3672,3674,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1046,SUCCESS
    994,2021-07-01 17:13:06,3983.814,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25736,514,514,8,25,35,575,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3673,3673,3674,3673,3675,3682,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1032,SUCCESS
    995,2021-07-01 17:13:10,3987.827,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25737,514,514,8,25,35,575,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3673,3673,3674,3673,3675,3683,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1003,SUCCESS
    996,2021-07-01 17:13:14,3991.835,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25737,515,514,8,25,35,576,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3673,3673,3674,3673,3675,3683,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1043,SUCCESS
    997,2021-07-01 17:13:18,3995.846,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25737,514,514,8,25,35,576,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3686,3673,3673,3675,3673,3675,3683,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1080,SUCCESS
    998,2021-07-01 17:13:22,3999.860,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25741,513,514,8,25,35,577,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3687,3674,3673,3674,3674,3675,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1096,SUCCESS
    999,2021-07-01 17:13:26,4003.864,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25743,514,514,8,25,35,577,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3687,3674,3673,3675,3674,3676,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.8,1046,SUCCESS
    1000,2021-07-01 17:13:31,4007.874,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25743,514,514,8,25,35,578,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3687,3674,3674,3675,3674,3676,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1054,SUCCESS
    1001,2021-07-01 17:13:35,4011.891,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25744,514,514,8,25,35,579,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3687,3674,3674,3675,3674,3676,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1018,SUCCESS
    1002,2021-07-01 17:13:39,4015.905,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25746,514,514,8,25,35,579,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3688,3675,3674,3675,3674,3676,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1050,SUCCESS
    1003,2021-07-01 17:13:43,4019.906,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25748,515,514,8,25,35,580,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3688,3675,3675,3675,3675,3677,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1082,SUCCESS
    1004,2021-07-01 17:13:47,4023.915,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25750,514,514,8,25,35,580,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3688,3675,3675,3676,3675,3677,3684,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1039,SUCCESS
    1005,2021-07-01 17:13:51,4027.925,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25751,514,514,8,25,35,581,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3688,3675,3675,3676,3675,3677,3685,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1093,SUCCESS
    1006,2021-07-01 17:13:55,4031.937,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25751,514,514,8,25,35,581,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3688,3675,3675,3676,3675,3677,3685,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1017,SUCCESS
    1007,2021-07-01 17:13:59,4035.940,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25751,514,514,8,25,35,582,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3675,3675,3676,3675,3677,3685,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,975,SUCCESS
    1008,2021-07-01 17:14:03,4039.944,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25753,514,514,8,25,35,583,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3676,3675,3677,3675,3677,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.6,1003,SUCCESS
    1009,2021-07-01 17:14:07,4043.953,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25757,513,514,8,25,35,583,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3676,3675,3676,3676,3678,3686,0,0,0,0,0,0,0,0,2845,24.6,24.8,-273.2,24.8,-273.2,33.9,1099,SUCCESS
    1010,2021-07-01 17:14:11,4047.956,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25758,514,514,8,25,36,584,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3676,3676,3677,3676,3678,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.8,1115,SUCCESS
    1011,2021-07-01 17:14:15,4051.970,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25758,514,514,8,25,36,584,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3677,3676,3677,3676,3678,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,1098,SUCCESS
    1012,2021-07-01 17:14:19,4055.971,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25759,514,514,8,25,36,585,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3689,3677,3676,3677,3676,3679,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,1060,SUCCESS
    1013,2021-07-01 17:14:23,4059.986,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25763,514,514,8,25,36,585,2352,65535,65535,278,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3690,3677,3676,3678,3677,3679,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,1016,SUCCESS
    1014,2021-07-01 17:14:27,4063.995,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25763,513,514,8,25,36,586,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3690,3677,3676,3678,3677,3679,3686,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,975,SUCCESS
    1015,2021-07-01 17:14:31,4068.009,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25764,515,514,8,25,36,587,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3690,3677,3676,3678,3677,3679,3687,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.8,977,SUCCESS
    1016,2021-07-01 17:14:35,4072.019,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25765,512,514,8,25,36,587,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3690,3677,3677,3678,3677,3679,3687,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,998,SUCCESS
    1017,2021-07-01 17:14:39,4076.028,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25766,514,514,8,25,36,588,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3677,3678,3677,3679,3687,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.8,972,SUCCESS
    1018,2021-07-01 17:14:43,4080.033,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25768,514,514,8,25,36,588,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3677,3678,3677,3680,3687,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.9,1095,SUCCESS
    1019,2021-07-01 17:14:47,4084.037,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25768,514,514,8,26,36,589,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3678,3679,3678,3680,3687,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.7,984,SUCCESS
    1020,2021-07-01 17:14:51,4088.051,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25771,514,514,8,26,36,589,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3678,3679,3678,3680,3688,0,0,0,0,0,0,0,0,2846,24.7,24.8,-273.2,24.8,-273.2,33.8,1030,SUCCESS
    1021,2021-07-01 17:14:55,4092.057,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25772,514,514,8,26,36,590,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3678,3679,3678,3680,3688,0,0,0,0,0,0,0,0,2845,24.7,24.8,-273.2,24.8,-273.2,33.8,1039,SUCCESS
    1022,2021-07-01 17:14:59,4096.071,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25773,514,514,8,26,36,591,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3691,3678,3678,3679,3678,3680,3688,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.5,953,SUCCESS
    1023,2021-07-01 17:15:03,4100.082,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25775,514,514,8,26,36,591,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3692,3679,3678,3679,3678,3680,3688,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1124,SUCCESS
    1024,2021-07-01 17:15:07,4104.097,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25775,515,514,8,26,36,592,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3692,3679,3678,3679,3678,3680,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1046,SUCCESS
    1025,2021-07-01 17:15:11,4108.117,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25777,515,514,8,26,36,592,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3692,3679,3679,3680,3678,3681,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.8,1095,SUCCESS
    1026,2021-07-01 17:15:15,4112.126,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25779,514,514,8,26,36,593,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3692,3679,3679,3680,3679,3681,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1094,SUCCESS
    1027,2021-07-01 17:15:19,4116.136,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25781,513,514,8,26,36,594,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3692,3679,3679,3680,3679,3681,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,959,SUCCESS
    1028,2021-07-01 17:15:23,4120.149,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25782,514,514,8,26,36,594,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3693,3680,3679,3681,3679,3682,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1025,SUCCESS
    1029,2021-07-01 17:15:27,4124.155,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25785,514,514,8,26,36,595,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3693,3680,3680,3681,3680,3682,3689,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.8,1035,SUCCESS
    1030,2021-07-01 17:15:31,4128.164,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25785,514,514,8,26,36,595,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3693,3680,3680,3681,3680,3682,3690,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1010,SUCCESS
    1031,2021-07-01 17:15:35,4132.177,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25786,514,514,8,26,36,596,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3693,3680,3680,3681,3680,3682,3690,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1057,SUCCESS
    1032,2021-07-01 17:15:39,4136.190,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25787,514,514,8,26,36,596,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3681,3680,3681,3680,3682,3690,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1062,SUCCESS
    1033,2021-07-01 17:15:43,4140.203,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25789,514,514,8,26,36,597,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3681,3680,3682,3680,3682,3690,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1064,SUCCESS
    1034,2021-07-01 17:15:47,4144.217,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25791,515,514,8,26,36,598,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3681,3681,3682,3680,3683,3691,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1094,SUCCESS
    1035,2021-07-01 17:15:51,4148.226,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25792,515,514,8,26,36,598,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3681,3681,3682,3681,3683,3691,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1041,SUCCESS
    1036,2021-07-01 17:15:55,4152.237,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25793,515,514,8,26,36,599,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3681,3681,3682,3681,3683,3691,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1047,SUCCESS
    1037,2021-07-01 17:15:59,4156.252,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25795,514,514,8,26,36,599,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3694,3682,3681,3682,3681,3683,3691,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1046,SUCCESS
    1038,2021-07-01 17:16:03,4160.254,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25797,513,514,8,26,36,600,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3682,3681,3683,3682,3683,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,34.0,1052,SUCCESS
    1039,2021-07-01 17:16:07,4164.268,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25798,514,514,8,26,36,600,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3682,3681,3683,3682,3683,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1061,SUCCESS
    1040,2021-07-01 17:16:11,4168.274,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25799,515,514,8,26,37,601,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3682,3682,3683,3682,3684,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1014,SUCCESS
    1041,2021-07-01 17:16:15,4172.289,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25800,514,514,8,26,37,602,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3683,3682,3683,3682,3684,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.8,1048,SUCCESS
    1042,2021-07-01 17:16:19,4176.294,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25801,515,515,8,26,37,602,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3683,3682,3683,3682,3685,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1054,SUCCESS
    1043,2021-07-01 17:16:23,4180.299,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25802,514,514,8,26,37,603,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3695,3683,3682,3683,3682,3685,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1079,SUCCESS
    1044,2021-07-01 17:16:27,4184.307,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25806,514,514,8,26,37,603,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3696,3683,3683,3684,3683,3685,3692,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,961,SUCCESS
    1045,2021-07-01 17:16:31,4188.310,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25808,515,514,8,26,37,604,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3696,3683,3683,3684,3683,3685,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1053,SUCCESS
    1046,2021-07-01 17:16:35,4192.312,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25808,514,514,8,26,37,604,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3696,3683,3683,3684,3683,3685,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1051,SUCCESS
    1047,2021-07-01 17:16:39,4196.326,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25809,515,515,8,26,37,605,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3683,3683,3684,3683,3685,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.8,1038,SUCCESS
    1048,2021-07-01 17:16:43,4200.327,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25810,514,514,8,26,37,606,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3683,3683,3684,3683,3685,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1003,SUCCESS
    1049,2021-07-01 17:16:47,4204.331,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25811,514,514,8,26,37,606,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3684,3683,3684,3684,3686,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,34.0,1117,SUCCESS
    1050,2021-07-01 17:16:51,4208.333,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25812,514,514,8,26,37,607,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3684,3684,3685,3684,3686,3693,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1044,SUCCESS
    1051,2021-07-01 17:16:55,4212.345,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25814,513,514,8,26,37,607,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3684,3684,3685,3684,3686,3694,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,34.0,1051,SUCCESS
    1052,2021-07-01 17:16:59,4216.346,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25814,514,514,8,26,37,608,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3697,3684,3684,3685,3684,3686,3694,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1064,SUCCESS
    1053,2021-07-01 17:17:03,4220.350,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25816,514,514,8,26,37,609,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3684,3684,3686,3685,3686,3695,0,0,0,0,0,0,0,0,2850,24.7,24.8,-273.2,24.8,-273.2,33.9,1106,SUCCESS
    1054,2021-07-01 17:17:07,4224.364,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25820,514,514,8,26,37,609,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3685,3684,3686,3685,3687,3694,0,0,0,0,0,0,0,0,2851,24.7,24.8,-273.2,24.8,-273.2,33.9,983,SUCCESS
    1055,2021-07-01 17:17:11,4228.372,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25821,514,514,8,26,37,610,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3685,3685,3686,3685,3687,3694,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1037,SUCCESS
    1056,2021-07-01 17:17:15,4232.382,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25821,514,514,8,26,37,610,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3685,3685,3686,3685,3687,3695,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,994,SUCCESS
    1057,2021-07-01 17:17:19,4236.388,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25822,514,514,8,26,37,611,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3686,3685,3686,3685,3687,3695,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,990,SUCCESS
    1058,2021-07-01 17:17:23,4240.403,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25824,515,514,8,26,37,611,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3698,3686,3685,3686,3685,3688,3695,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1021,SUCCESS
    1059,2021-07-01 17:17:27,4244.403,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25827,515,514,8,27,37,612,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3699,3686,3686,3687,3686,3688,3695,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.8,1040,SUCCESS
    1060,2021-07-01 17:17:31,4248.417,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25828,514,514,8,27,37,613,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3699,3686,3686,3687,3686,3688,3695,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.5,980,SUCCESS
    1061,2021-07-01 17:17:35,4252.418,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25828,514,514,8,27,37,613,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3699,3686,3686,3687,3686,3688,3695,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1038,SUCCESS
    1062,2021-07-01 17:17:39,4256.428,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25829,514,514,8,27,37,614,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3686,3686,3687,3686,3688,3696,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1013,SUCCESS
    1063,2021-07-01 17:17:43,4260.443,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25830,515,514,8,27,37,614,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3687,3686,3687,3686,3688,3696,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,34.0,987,SUCCESS
    1064,2021-07-01 17:17:47,4264.454,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25831,514,514,8,27,37,615,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3687,3686,3687,3686,3689,3696,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1049,SUCCESS
    1065,2021-07-01 17:17:51,4268.462,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25835,514,514,8,27,37,615,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3687,3687,3688,3687,3689,3696,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.3,969,SUCCESS
    1066,2021-07-01 17:17:55,4272.474,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25835,513,514,8,27,37,616,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3687,3687,3688,3687,3689,3696,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.9,1027,SUCCESS
    1067,2021-07-01 17:17:59,4276.478,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25835,515,514,8,27,38,617,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3700,3687,3687,3688,3687,3689,3697,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.9,1056,SUCCESS
    1068,2021-07-01 17:18:03,4280.491,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25837,514,514,8,27,38,617,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3701,3688,3687,3689,3687,3688,3697,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1014,SUCCESS
    1069,2021-07-01 17:18:07,4284.507,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25841,514,514,8,27,38,618,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3701,3688,3687,3689,3688,3689,3698,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1011,SUCCESS
    1070,2021-07-01 17:18:11,4288.508,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25843,515,514,8,27,38,618,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3701,3688,3687,3689,3688,3689,3698,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1043,SUCCESS
    1071,2021-07-01 17:18:15,4292.520,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25842,514,514,8,27,38,619,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3701,3689,3688,3689,3688,3690,3698,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,34.0,1034,SUCCESS
    1072,2021-07-01 17:18:19,4296.521,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25844,515,514,8,27,38,619,2352,65535,65535,274,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3701,3689,3688,3689,3688,3690,3698,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1021,SUCCESS
    1073,2021-07-01 17:18:23,4300.524,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25846,515,515,8,27,38,620,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3702,3689,3688,3689,3688,3691,3698,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,34.0,1011,SUCCESS
    1074,2021-07-01 17:18:27,4304.529,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25848,514,515,8,27,38,621,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3702,3689,3689,3689,3688,3694,3698,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.9,1036,SUCCESS
    1075,2021-07-01 17:18:31,4308.539,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25849,515,515,8,27,38,621,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3702,3689,3689,3690,3689,3696,3699,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,33.9,962,SUCCESS
    1076,2021-07-01 17:18:35,4312.554,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25849,515,515,8,27,38,622,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3702,3689,3689,3690,3689,3691,3699,0,0,0,0,0,0,0,0,2855,24.7,24.8,-273.2,24.8,-273.2,34.0,1042,SUCCESS
    1077,2021-07-01 17:18:39,4316.564,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25850,514,515,8,27,38,622,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3702,3689,3689,3690,3689,3691,3699,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,34.0,1049,SUCCESS
    1078,2021-07-01 17:18:43,4320.572,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25851,514,515,8,27,38,623,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3690,3689,3690,3689,3691,3699,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,992,SUCCESS
    1079,2021-07-01 17:18:47,4324.582,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25853,514,515,8,27,38,623,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3690,3690,3690,3690,3691,3699,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.1,1098,SUCCESS
    1080,2021-07-01 17:18:51,4328.597,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25855,514,515,8,27,38,624,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3690,3689,3691,3690,3691,3700,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,34.0,1014,SUCCESS
    1081,2021-07-01 17:18:55,4332.598,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25856,515,515,8,27,38,625,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3690,3690,3691,3690,3692,3700,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,999,SUCCESS
    1082,2021-07-01 17:18:59,4336.607,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25856,514,515,8,27,38,625,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3690,3690,3691,3690,3692,3700,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,34.0,1053,SUCCESS
    1083,2021-07-01 17:19:03,4340.609,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25859,514,515,8,27,38,626,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3703,3691,3690,3691,3691,3692,3701,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1035,SUCCESS
    1084,2021-07-01 17:19:07,4344.617,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25862,515,515,8,27,38,626,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3704,3691,3690,3692,3691,3692,3701,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,1025,SUCCESS
    1085,2021-07-01 17:19:11,4348.619,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25862,515,515,8,27,38,627,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3704,3691,3690,3692,3691,3693,3701,0,0,0,0,0,0,0,0,2855,24.7,24.9,-273.2,24.9,-273.2,33.9,949,SUCCESS
    1086,2021-07-01 17:19:15,4352.620,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25863,514,515,8,27,38,627,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3704,3691,3691,3692,3691,3693,3701,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1005,SUCCESS
    1087,2021-07-01 17:19:19,4356.621,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25864,515,515,8,27,38,628,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3704,3692,3691,3692,3691,3693,3701,0,0,0,0,0,0,0,0,2856,24.7,24.9,-273.2,24.9,-273.2,33.9,992,SUCCESS
    1088,2021-07-01 17:19:23,4360.635,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25865,515,515,8,27,38,629,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3705,3692,3692,3692,3691,3694,3701,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1026,SUCCESS
    1089,2021-07-01 17:19:27,4364.640,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25870,514,515,8,27,38,629,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3705,3692,3692,3693,3692,3694,3702,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1035,SUCCESS
    1090,2021-07-01 17:19:31,4368.642,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25870,515,515,8,27,38,630,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3705,3692,3692,3693,3692,3694,3702,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1060,SUCCESS
    1091,2021-07-01 17:19:35,4372.650,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25870,515,515,8,27,38,630,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3705,3692,3692,3693,3692,3694,3702,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1056,SUCCESS
    1092,2021-07-01 17:19:39,4376.662,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25872,515,515,8,27,38,631,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3706,3693,3692,3693,3692,3694,3702,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1043,SUCCESS
    1093,2021-07-01 17:19:43,4380.668,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25872,515,515,8,27,38,632,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3706,3693,3692,3693,3692,3694,3702,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1147,SUCCESS
    1094,2021-07-01 17:19:47,4384.682,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25875,516,515,8,27,38,632,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3706,3693,3692,3694,3693,3694,3703,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1008,SUCCESS
    1095,2021-07-01 17:19:51,4388.693,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25877,515,515,8,27,38,633,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3706,3693,3693,3694,3693,3694,3703,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,963,SUCCESS
    1096,2021-07-01 17:19:55,4392.697,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25877,515,515,8,27,38,633,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3706,3693,3693,3694,3693,3695,3703,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1010,SUCCESS
    1097,2021-07-01 17:19:59,4396.699,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25878,515,515,8,27,39,634,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3707,3694,3693,3694,3693,3695,3703,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1024,SUCCESS
    1098,2021-07-01 17:20:03,4400.705,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25881,516,515,8,27,39,634,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3707,3694,3693,3695,3693,3696,3703,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.1,1054,SUCCESS
    1099,2021-07-01 17:20:07,4404.705,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25884,515,515,8,27,39,635,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3707,3694,3693,3695,3694,3696,3704,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,967,SUCCESS
    1100,2021-07-01 17:20:11,4408.715,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25884,515,515,8,28,39,636,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3707,3694,3694,3695,3694,3696,3704,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,974,SUCCESS
    1101,2021-07-01 17:20:15,4412.720,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25884,516,515,8,28,39,636,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3707,3694,3694,3695,3694,3696,3704,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1097,SUCCESS
    1102,2021-07-01 17:20:19,4416.724,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25886,514,515,8,28,39,637,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3708,3695,3694,3695,3694,3697,3704,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1010,SUCCESS
    1103,2021-07-01 17:20:23,4420.730,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25887,515,515,8,28,39,637,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3708,3695,3695,3695,3694,3697,3704,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,989,SUCCESS
    1104,2021-07-01 17:20:27,4424.740,0x0701,150,10,0x6001,0,65535,65535,1,24.8,25890,515,515,8,28,39,638,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3708,3695,3695,3696,3695,3697,3705,0,0,0,0,0,0,0,0,2860,24.7,24.8,-273.2,24.8,-273.2,33.9,1090,SUCCESS
    1105,2021-07-01 17:20:31,4428.735,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25891,515,515,8,28,39,638,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3708,3695,3695,3696,3695,3697,3705,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1082,SUCCESS
    1106,2021-07-01 17:20:35,4432.747,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25891,515,515,8,28,39,639,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3708,3695,3695,3696,3695,3697,3705,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1069,SUCCESS
    1107,2021-07-01 17:20:39,4436.750,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25892,515,515,8,28,39,640,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3695,3695,3696,3695,3697,3705,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1158,SUCCESS
    1108,2021-07-01 17:20:43,4440.754,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25893,515,515,8,28,39,640,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3696,3695,3696,3695,3697,3705,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,998,SUCCESS
    1109,2021-07-01 17:20:47,4444.767,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25896,515,515,8,28,39,641,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3696,3696,3697,3695,3697,3706,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1063,SUCCESS
    1110,2021-07-01 17:20:51,4448.777,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25898,515,515,8,28,39,641,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3696,3696,3697,3696,3698,3706,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1099,SUCCESS
    1111,2021-07-01 17:20:55,4452.791,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25898,515,515,8,28,39,642,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3696,3696,3697,3696,3698,3706,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1021,SUCCESS
    1112,2021-07-01 17:20:59,4456.793,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25898,514,515,8,28,39,642,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3709,3696,3696,3697,3696,3698,3706,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1006,SUCCESS
    1113,2021-07-01 17:21:03,4460.808,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25903,515,515,8,28,39,643,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3710,3697,3696,3698,3697,3699,3706,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,944,SUCCESS
    1114,2021-07-01 17:21:07,4464.809,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25904,514,515,8,28,39,644,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3710,3697,3696,3698,3697,3699,3707,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1022,SUCCESS
    1115,2021-07-01 17:21:11,4468.823,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25905,514,515,8,28,39,644,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3710,3697,3697,3698,3697,3699,3707,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,34.0,1008,SUCCESS
    1116,2021-07-01 17:21:15,4472.836,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25906,515,515,8,28,39,645,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3711,3697,3697,3698,3697,3700,3707,0,0,0,0,0,0,0,0,2860,24.7,24.9,-273.2,24.9,-273.2,33.9,1041,SUCCESS
    1117,2021-07-01 17:21:19,4476.841,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25908,515,515,8,28,39,645,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3711,3698,3697,3698,3697,3700,3707,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,34.0,1007,SUCCESS
    1118,2021-07-01 17:21:23,4480.851,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25910,515,515,8,28,39,646,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3711,3698,3698,3699,3697,3700,3707,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,33.8,1031,SUCCESS
    1119,2021-07-01 17:21:27,4484.861,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25912,514,515,8,28,39,646,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3711,3698,3698,3699,3698,3700,3708,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,33.9,1064,SUCCESS
    1120,2021-07-01 17:21:32,4488.874,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25912,515,515,8,28,39,647,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3711,3698,3698,3699,3698,3700,3708,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,33.9,1018,SUCCESS
    1121,2021-07-01 17:21:36,4492.892,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25913,515,515,8,28,39,648,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3698,3698,3699,3698,3700,3708,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,34.0,1002,SUCCESS
    1122,2021-07-01 17:21:40,4496.902,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25915,516,515,8,28,39,648,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3699,3698,3699,3698,3700,3709,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,34.0,975,SUCCESS
    1123,2021-07-01 17:21:44,4500.908,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25915,514,515,8,28,39,649,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3699,3698,3700,3699,3701,3709,0,0,0,0,0,0,0,0,2865,24.7,24.9,-273.2,24.9,-273.2,33.9,1063,SUCCESS
    1124,2021-07-01 17:21:48,4504.911,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25915,515,515,8,28,39,649,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3699,3699,3700,3699,3702,3709,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,971,SUCCESS
    1125,2021-07-01 17:21:52,4508.912,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25921,515,515,8,28,39,650,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3700,3699,3700,3699,3702,3709,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1027,SUCCESS
    1126,2021-07-01 17:21:56,4512.924,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25922,516,515,8,28,40,651,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3712,3700,3699,3700,3700,3702,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1172,SUCCESS
    1127,2021-07-01 17:22:00,4516.931,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25925,515,515,8,28,40,651,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3713,3700,3699,3701,3700,3702,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,992,SUCCESS
    1128,2021-07-01 17:22:04,4520.941,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25926,515,515,8,28,40,652,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3713,3700,3699,3701,3700,3702,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,998,SUCCESS
    1129,2021-07-01 17:22:08,4524.944,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25927,515,515,8,28,40,652,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3713,3700,3700,3701,3700,3702,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1026,SUCCESS
    1130,2021-07-01 17:22:12,4528.949,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25929,515,515,8,28,40,653,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3700,3701,3700,3703,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1053,SUCCESS
    1131,2021-07-01 17:22:16,4532.963,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25929,514,515,8,28,40,653,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3700,3701,3700,3703,3710,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1101,SUCCESS
    1132,2021-07-01 17:22:20,4536.972,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25929,515,515,8,28,40,654,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3701,3701,3701,3703,3711,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1014,SUCCESS
    1133,2021-07-01 17:22:24,4540.986,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25931,515,515,8,28,40,655,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3701,3702,3701,3703,3711,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1048,SUCCESS
    1134,2021-07-01 17:22:28,4544.988,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25932,515,515,8,28,40,655,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3701,3701,3701,3703,3711,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1047,SUCCESS
    1135,2021-07-01 17:22:32,4548.997,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25933,515,515,8,28,40,656,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3714,3701,3701,3702,3701,3703,3711,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,32.9,1060,SUCCESS
    1136,2021-07-01 17:22:36,4553.006,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25937,516,515,8,28,40,656,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3715,3702,3701,3702,3701,3704,3712,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1026,SUCCESS
    1137,2021-07-01 17:22:40,4557.015,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25937,515,515,8,28,40,657,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3715,3702,3702,3702,3702,3704,3712,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1082,SUCCESS
    1138,2021-07-01 17:22:44,4561.028,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25939,516,515,8,28,40,658,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3715,3702,3702,3703,3702,3704,3712,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,974,SUCCESS
    1139,2021-07-01 17:22:48,4565.036,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25940,516,515,8,28,40,658,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3715,3702,3702,3703,3702,3704,3712,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1076,SUCCESS
    1140,2021-07-01 17:22:52,4569.047,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25942,516,515,8,29,40,659,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3715,3703,3702,3703,3702,3705,3712,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1034,SUCCESS
    1141,2021-07-01 17:22:56,4573.052,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25943,516,516,8,29,40,659,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3716,3703,3702,3703,3703,3705,3713,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1045,SUCCESS
    1142,2021-07-01 17:23:00,4577.054,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25947,516,516,8,29,40,660,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3716,3703,3703,3704,3703,3705,3713,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1043,SUCCESS
    1143,2021-07-01 17:23:04,4581.057,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25946,517,516,8,29,40,660,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3716,3703,3703,3704,3703,3705,3713,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,1021,SUCCESS
    1144,2021-07-01 17:23:08,4585.066,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25948,515,516,8,29,40,661,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3703,3704,3703,3705,3713,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,998,SUCCESS
    1145,2021-07-01 17:23:12,4589.073,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25950,514,515,8,29,40,662,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3703,3704,3703,3706,3713,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,34.0,991,SUCCESS
    1146,2021-07-01 17:23:16,4593.079,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25951,516,515,8,29,40,662,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3704,3704,3704,3705,3714,0,0,0,0,0,0,0,0,2865,24.8,24.9,-273.2,24.9,-273.2,33.9,1048,SUCCESS
    1147,2021-07-01 17:23:20,4597.081,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25953,516,515,8,29,40,663,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3704,3705,3704,3705,3714,0,0,0,0,0,0,0,0,2869,24.8,24.9,-273.2,24.9,-273.2,33.9,966,SUCCESS
    1148,2021-07-01 17:23:24,4601.082,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25954,515,515,8,29,40,663,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3704,3705,3704,3705,3714,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1015,SUCCESS
    1149,2021-07-01 17:23:28,4605.084,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25954,515,515,8,29,40,664,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3717,3704,3704,3705,3704,3704,3714,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.5,970,SUCCESS
    1150,2021-07-01 17:23:32,4609.100,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25960,515,515,8,29,40,664,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3718,3705,3704,3706,3705,3706,3715,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1074,SUCCESS
    1151,2021-07-01 17:23:36,4613.105,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25960,516,515,8,29,40,665,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3718,3705,3704,3706,3705,3703,3715,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,990,SUCCESS
    1152,2021-07-01 17:23:40,4617.116,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25961,515,515,8,29,40,666,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3718,3705,3705,3706,3705,3707,3715,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,963,SUCCESS
    1153,2021-07-01 17:23:44,4621.127,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25961,516,515,8,29,40,666,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3718,3705,3705,3706,3705,3709,3715,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1079,SUCCESS
    1154,2021-07-01 17:23:48,4625.139,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25963,516,515,8,29,41,667,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3718,3706,3705,3706,3705,3710,3715,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1096,SUCCESS
    1155,2021-07-01 17:23:52,4629.151,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25966,515,516,8,29,41,667,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3719,3706,3705,3706,3706,3711,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,991,SUCCESS
    1156,2021-07-01 17:23:56,4633.153,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25968,516,515,8,29,41,668,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3719,3706,3706,3707,3706,3713,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1036,SUCCESS
    1157,2021-07-01 17:24:00,4637.158,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25968,515,515,8,29,41,668,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3719,3706,3706,3707,3706,3708,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1046,SUCCESS
    1158,2021-07-01 17:24:04,4641.161,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25969,516,515,8,29,41,669,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3720,3707,3706,3707,3706,3708,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1029,SUCCESS
    1159,2021-07-01 17:24:08,4645.164,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25971,516,516,8,29,41,670,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3720,3707,3706,3707,3706,3708,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1024,SUCCESS
    1160,2021-07-01 17:24:12,4649.177,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25972,515,515,8,29,41,670,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3720,3707,3707,3708,3707,3709,3716,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,980,SUCCESS
    1161,2021-07-01 17:24:16,4653.180,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25975,515,516,8,29,41,671,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3720,3707,3707,3708,3707,3708,3717,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,993,SUCCESS
    1162,2021-07-01 17:24:20,4657.186,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25975,516,515,8,29,41,671,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3720,3707,3707,3708,3707,3709,3717,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1114,SUCCESS
    1163,2021-07-01 17:24:24,4661.187,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25977,516,515,8,29,41,672,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3721,3707,3707,3708,3708,3710,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.5,1022,SUCCESS
    1164,2021-07-01 17:24:28,4665.198,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25981,516,515,8,29,41,673,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3721,3708,3707,3709,3708,3710,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,975,SUCCESS
    1165,2021-07-01 17:24:32,4669.213,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25982,515,515,8,29,41,673,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3721,3708,3708,3709,3708,3710,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1101,SUCCESS
    1166,2021-07-01 17:24:36,4673.228,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25982,516,515,8,29,41,674,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3721,3708,3708,3709,3708,3710,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1039,SUCCESS
    1167,2021-07-01 17:24:40,4677.241,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25984,516,515,8,29,41,674,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3721,3709,3708,3709,3708,3711,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1026,SUCCESS
    1168,2021-07-01 17:24:44,4681.245,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25985,516,516,8,29,41,675,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3722,3709,3708,3709,3709,3711,3718,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1024,SUCCESS
    1169,2021-07-01 17:24:48,4685.252,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25989,516,516,8,29,41,675,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3722,3709,3709,3710,3709,3711,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1030,SUCCESS
    1170,2021-07-01 17:24:52,4689.259,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25989,516,516,8,29,41,676,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3722,3709,3709,3710,3709,3711,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1119,SUCCESS
    1171,2021-07-01 17:24:56,4693.267,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25990,516,516,8,29,41,677,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3722,3709,3709,3710,3709,3712,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.9,1067,SUCCESS
    1172,2021-07-01 17:25:00,4697.268,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25991,516,516,8,29,41,677,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3723,3710,3709,3710,3709,3712,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1014,SUCCESS
    1173,2021-07-01 17:25:04,4701.270,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25992,515,516,8,29,41,678,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3723,3710,3709,3710,3710,3712,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1028,SUCCESS
    1174,2021-07-01 17:25:08,4705.285,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25996,516,516,8,29,41,678,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3723,3710,3710,3711,3710,3712,3719,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1077,SUCCESS
    1175,2021-07-01 17:25:12,4709.295,0x0701,150,10,0x6001,0,65535,65535,1,24.9,25996,516,516,8,29,41,679,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3723,3710,3710,3711,3710,3712,3720,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,33.8,1060,SUCCESS
    1176,2021-07-01 17:25:16,4713.308,0x0701,150,10,0x6001,0,65535,65535,1,25.0,25997,517,516,8,29,41,679,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3723,3710,3710,3711,3710,3712,3720,0,0,0,0,0,0,0,0,2870,24.8,24.9,-273.2,24.9,-273.2,34.0,1008,SUCCESS
    1177,2021-07-01 17:25:20,4717.310,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26001,515,516,8,29,41,680,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3724,3711,3710,3712,3711,3713,3720,0,0,0,0,0,0,0,0,2874,24.8,24.9,-273.2,24.9,-273.2,33.9,1020,SUCCESS
    1178,2021-07-01 17:25:24,4721.319,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26003,515,516,8,29,41,681,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3724,3711,3710,3712,3711,3714,3721,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,979,SUCCESS
    1179,2021-07-01 17:25:28,4725.327,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26004,515,516,8,29,41,681,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3724,3711,3711,3712,3711,3713,3721,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1020,SUCCESS
    1180,2021-07-01 17:25:32,4729.338,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26003,515,516,8,29,41,682,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3724,3711,3711,3712,3711,3714,3721,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1038,SUCCESS
    1181,2021-07-01 17:25:36,4733.350,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26005,515,515,8,29,41,682,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3724,3712,3711,3712,3711,3714,3721,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1027,SUCCESS
    1182,2021-07-01 17:25:40,4737.359,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26008,515,515,8,30,41,683,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3725,3712,3712,3713,3712,3714,3721,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.1,1039,SUCCESS
    1183,2021-07-01 17:25:44,4741.373,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26010,515,515,8,30,41,683,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3725,3712,3712,3713,3712,3714,3722,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.1,1020,SUCCESS
    1184,2021-07-01 17:25:48,4745.384,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26010,516,515,8,30,42,684,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3725,3712,3712,3713,3712,3714,3722,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,33.9,946,SUCCESS
    1185,2021-07-01 17:25:52,4749.385,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26011,516,515,8,30,42,685,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3725,3712,3712,3713,3712,3715,3722,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1008,SUCCESS
    1186,2021-07-01 17:25:56,4753.393,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26013,516,515,8,30,42,685,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3726,3713,3713,3713,3712,3715,3722,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,33.9,1094,SUCCESS
    1187,2021-07-01 17:26:00,4757.402,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26016,515,515,8,30,42,686,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3726,3713,3713,3713,3713,3715,3722,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,33.3,1010,SUCCESS
    1188,2021-07-01 17:26:04,4761.415,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26017,516,515,8,30,42,686,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3726,3713,3713,3714,3713,3715,3723,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,979,SUCCESS
    1189,2021-07-01 17:26:08,4765.426,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26017,515,516,8,30,42,687,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3726,3713,3713,3714,3713,3715,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,998,SUCCESS
    1190,2021-07-01 17:26:12,4769.429,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26018,515,516,8,30,42,687,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3726,3713,3713,3714,3714,3715,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,979,SUCCESS
    1191,2021-07-01 17:26:16,4773.444,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26022,516,516,8,30,42,688,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3727,3714,3713,3715,3714,3715,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1027,SUCCESS
    1192,2021-07-01 17:26:20,4777.452,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26024,515,516,8,30,42,689,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3727,3714,3714,3715,3714,3716,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1019,SUCCESS
    1193,2021-07-01 17:26:24,4781.466,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26024,514,515,8,30,42,689,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3727,3714,3714,3715,3714,3717,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1048,SUCCESS
    1194,2021-07-01 17:26:28,4785.480,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26025,515,516,8,30,42,690,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3727,3715,3714,3715,3714,3717,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1116,SUCCESS
    1195,2021-07-01 17:26:32,4789.483,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26028,515,516,8,30,42,690,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3727,3715,3715,3716,3715,3717,3724,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,25.0,-273.2,34.0,1002,SUCCESS
    1196,2021-07-01 17:26:36,4793.492,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26031,516,515,8,30,42,691,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3728,3715,3715,3716,3715,3717,3725,0,0,0,0,0,0,0,0,2875,24.8,25.0,-273.2,25.0,-273.2,34.0,1134,SUCCESS
    1197,2021-07-01 17:26:40,4797.504,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26031,516,516,8,30,42,692,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3728,3715,3715,3716,3715,3717,3725,0,0,0,0,0,0,0,0,2875,24.8,25.0,-273.2,25.0,-273.2,33.9,1146,SUCCESS
    1198,2021-07-01 17:26:44,4801.508,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26031,516,515,8,30,42,692,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3715,3716,3715,3717,3725,0,0,0,0,0,0,0,0,2875,24.8,25.0,-273.2,25.0,-273.2,34.0,1024,SUCCESS
    1199,2021-07-01 17:26:48,4805.510,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26033,516,515,8,30,42,693,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3715,3716,3715,3718,3726,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1821,SUCCESS
    1200,2021-07-01 17:26:52,4809.520,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26037,515,516,8,30,42,693,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3715,3716,3715,3718,3726,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1390,SUCCESS
    1201,2021-07-01 17:26:56,4813.522,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26038,514,516,8,30,42,694,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3716,3717,3716,3718,3726,0,0,0,0,0,0,0,0,2875,24.8,24.9,-273.2,24.9,-273.2,34.0,1057,SUCCESS
    1202,2021-07-01 17:27:00,4817.531,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26038,515,516,8,30,42,694,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3716,3717,3716,3718,3726,0,0,0,0,0,0,0,0,2875,24.8,25.0,-273.2,25.0,-273.2,33.9,1005,SUCCESS
    1203,2021-07-01 17:27:04,4821.546,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26040,516,516,8,30,42,695,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3729,3716,3716,3717,3717,3718,3727,0,0,0,0,0,0,0,0,2875,24.8,25.0,-273.2,25.0,-273.2,34.0,1066,SUCCESS
    1204,2021-07-01 17:27:08,4825.560,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26043,516,516,8,30,42,696,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3730,3716,3716,3718,3717,3719,3727,0,0,0,0,0,0,0,0,2879,24.8,24.9,-273.2,25.0,-273.2,34.0,1008,SUCCESS
    1205,2021-07-01 17:27:12,4829.562,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26043,517,516,8,30,42,696,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3730,3717,3717,3718,3717,3719,3727,0,0,0,0,0,0,0,0,2880,24.8,24.9,-273.2,24.9,-273.2,34.0,1002,SUCCESS
    1206,2021-07-01 17:27:16,4833.575,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26044,516,516,8,30,42,697,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3731,3717,3717,3718,3717,3719,3727,0,0,0,0,0,0,0,0,2880,24.8,24.9,-273.2,24.9,-273.2,34.0,1022,SUCCESS
    1207,2021-07-01 17:27:20,4837.587,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26045,516,516,8,30,42,697,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3731,3718,3717,3718,3718,3720,3727,0,0,0,0,0,0,0,0,2880,24.8,24.9,-273.2,24.9,-273.2,34.0,944,SUCCESS
    1208,2021-07-01 17:27:24,4841.588,0x0701,150,10,0x6001,0,65535,65535,1,24.9,26051,517,516,8,30,42,698,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3731,3718,3718,3718,3718,3720,3728,0,0,0,0,0,0,0,0,2880,24.8,24.9,-273.2,24.9,-273.2,34.0,1039,SUCCESS
    1209,2021-07-01 17:27:28,4845.602,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26051,515,516,8,30,42,698,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3731,3718,3718,3719,3718,3720,3728,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,993,SUCCESS
    1210,2021-07-01 17:27:32,4849.613,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26053,515,516,8,30,42,699,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3731,3718,3718,3719,3718,3720,3728,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1063,SUCCESS
    1211,2021-07-01 17:27:36,4853.617,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26054,517,516,8,30,42,700,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3732,3719,3718,3719,3718,3720,3728,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,33.3,985,SUCCESS
    1212,2021-07-01 17:27:40,4857.622,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26057,516,516,8,30,42,700,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3732,3719,3718,3719,3718,3721,3728,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1004,SUCCESS
    1213,2021-07-01 17:27:44,4861.627,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26062,516,516,8,30,43,701,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3732,3719,3719,3719,3719,3721,3729,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1078,SUCCESS
    1214,2021-07-01 17:27:48,4865.638,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26064,516,516,8,30,43,701,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3732,3719,3719,3720,3719,3721,3729,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,989,SUCCESS
    1215,2021-07-01 17:27:52,4869.652,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26059,516,516,8,30,43,702,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3732,3719,3719,3720,3719,3721,3729,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,992,SUCCESS
    1216,2021-07-01 17:27:56,4873.659,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26059,517,516,8,30,43,702,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3733,3720,3719,3720,3720,3721,3730,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1047,SUCCESS
    1217,2021-07-01 17:28:00,4877.669,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26065,516,516,8,30,43,703,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3733,3720,3719,3721,3720,3722,3730,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1035,SUCCESS
    1218,2021-07-01 17:28:04,4881.675,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26065,516,516,8,30,43,704,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3733,3720,3719,3721,3720,3722,3730,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,33.9,1035,SUCCESS
    1219,2021-07-01 17:28:08,4885.691,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26065,517,516,8,30,43,704,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3733,3720,3720,3721,3720,3722,3730,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1078,SUCCESS
    1220,2021-07-01 17:28:12,4889.698,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26068,515,516,8,30,43,705,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3734,3721,3720,3721,3720,3722,3730,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.1,981,SUCCESS
    1221,2021-07-01 17:28:16,4893.709,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26070,516,516,8,30,43,705,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3734,3721,3720,3721,3721,3723,3731,0,0,0,0,0,0,0,0,2880,24.9,25.0,-273.2,25.0,-273.2,34.0,988,SUCCESS
    1222,2021-07-01 17:28:20,4897.720,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26073,516,516,8,31,43,706,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3734,3721,3721,3722,3721,3723,3731,0,0,0,0,0,0,0,0,2880,24.9,25.0,-273.2,25.0,-273.2,34.0,983,SUCCESS
    1223,2021-07-01 17:28:24,4901.730,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26073,515,516,8,31,43,706,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3734,3721,3721,3722,3721,3723,3731,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1037,SUCCESS
    1224,2021-07-01 17:28:28,4905.739,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26074,515,516,8,31,43,707,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3734,3721,3721,3722,3721,3723,3732,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,997,SUCCESS
    1225,2021-07-01 17:28:32,4909.750,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26077,515,516,8,31,43,708,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3735,3722,3721,3722,3721,3724,3732,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1033,SUCCESS
    1226,2021-07-01 17:28:36,4913.762,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26078,516,516,8,31,43,708,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3735,3722,3721,3722,3722,3724,3732,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,991,SUCCESS
    1227,2021-07-01 17:28:40,4917.763,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26080,516,516,8,31,43,709,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3735,3722,3722,3723,3722,3724,3732,0,0,0,0,0,0,0,0,2880,24.8,25.0,-273.2,25.0,-273.2,34.0,1037,SUCCESS
    1228,2021-07-01 17:28:44,4921.765,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26082,516,516,8,31,43,709,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3735,3723,3722,3723,3722,3725,3732,0,0,0,0,0,0,0,0,2880,24.9,25.0,-273.2,25.0,-273.2,34.0,1112,SUCCESS
    1229,2021-07-01 17:28:48,4925.768,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26083,515,516,8,31,43,710,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3735,3723,3722,3723,3722,3725,3733,0,0,0,0,0,0,0,0,2884,24.9,25.0,-273.2,25.0,-273.2,34.0,1126,SUCCESS
    1230,2021-07-01 17:28:52,4929.814,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26086,516,516,8,31,43,711,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3736,3723,3722,3724,3723,3725,3733,0,0,0,0,0,0,0,0,2880,24.9,25.0,-273.2,25.0,-273.2,33.9,1006,SUCCESS
    1231,2021-07-01 17:28:56,4933.784,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26087,516,516,8,31,43,711,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3736,3723,3722,3724,3723,3725,3733,0,0,0,0,0,0,0,0,2880,24.9,25.0,-273.2,25.0,-273.2,34.0,1031,SUCCESS
    1232,2021-07-01 17:29:00,4937.785,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26088,516,516,8,31,43,712,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3737,3723,3723,3724,3723,3724,3733,0,0,0,0,0,0,0,0,2881,24.9,25.0,-273.2,25.0,-273.2,34.0,997,SUCCESS
    1233,2021-07-01 17:29:04,4941.799,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26089,515,516,8,31,43,712,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3737,3724,3723,3724,3723,3724,3733,0,0,0,0,0,0,0,0,2881,24.9,25.0,-273.2,25.0,-273.2,34.0,1063,SUCCESS
    1234,2021-07-01 17:29:08,4945.800,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26093,516,516,8,31,43,713,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3737,3724,3724,3724,3723,3723,3734,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1109,SUCCESS
    1235,2021-07-01 17:29:12,4949.807,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26094,516,516,8,31,43,713,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3737,3724,3724,3725,3724,3722,3734,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1008,SUCCESS
    1236,2021-07-01 17:29:16,4953.817,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26095,516,516,8,31,43,714,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3737,3724,3724,3725,3724,3727,3734,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1091,SUCCESS
    1237,2021-07-01 17:29:20,4957.817,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26097,516,516,8,31,43,715,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3738,3725,3724,3725,3724,3728,3735,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1076,SUCCESS
    1238,2021-07-01 17:29:24,4961.825,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26098,516,516,8,31,43,715,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3738,3725,3724,3725,3724,3729,3735,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,989,SUCCESS
    1239,2021-07-01 17:29:28,4965.836,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26101,516,516,8,31,43,716,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3738,3725,3725,3726,3725,3727,3735,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.1,985,SUCCESS
    1240,2021-07-01 17:29:32,4969.852,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26103,516,516,8,31,43,716,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3738,3726,3725,3726,3725,3728,3735,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.1,947,SUCCESS
    1241,2021-07-01 17:29:36,4973.852,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26104,516,516,8,31,44,717,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3738,3726,3725,3726,3725,3728,3736,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1024,SUCCESS
    1242,2021-07-01 17:29:41,4977.867,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26108,516,516,8,31,44,718,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3739,3726,3726,3727,3726,3728,3736,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,996,SUCCESS
    1243,2021-07-01 17:29:45,4981.870,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26108,515,516,8,31,44,718,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3739,3726,3726,3727,3726,3728,3736,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1009,SUCCESS
    1244,2021-07-01 17:29:49,4985.889,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26108,516,516,8,31,44,719,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3739,3726,3726,3727,3726,3728,3736,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,33.7,1043,SUCCESS
    1245,2021-07-01 17:29:53,4989.899,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26110,516,516,8,31,44,719,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3740,3727,3726,3727,3726,3728,3736,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,978,SUCCESS
    1246,2021-07-01 17:29:57,4993.913,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26110,516,516,8,31,44,720,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3740,3727,3727,3727,3727,3728,3737,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1028,SUCCESS
    1247,2021-07-01 17:30:01,4997.915,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26114,515,516,8,31,44,720,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3740,3727,3727,3728,3727,3729,3737,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,978,SUCCESS
    1248,2021-07-01 17:30:05,5001.917,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26115,517,516,8,31,44,721,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3740,3727,3727,3728,3727,3729,3737,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.1,1024,SUCCESS
    1249,2021-07-01 17:30:09,5005.917,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26117,516,516,8,31,44,722,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3741,3727,3727,3728,3727,3729,3737,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1022,SUCCESS
    1250,2021-07-01 17:30:13,5009.928,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26120,516,516,8,31,44,722,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3741,3728,3727,3728,3728,3730,3738,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,996,SUCCESS
    1251,2021-07-01 17:30:17,5013.934,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26121,516,516,8,31,44,723,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3741,3728,3728,3729,3728,3730,3738,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1011,SUCCESS
    1252,2021-07-01 17:30:21,5017.951,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26123,517,516,8,31,44,723,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3741,3728,3728,3729,3728,3731,3738,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1051,SUCCESS
    1253,2021-07-01 17:30:25,5021.972,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26124,516,516,8,31,44,724,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3741,3729,3728,3729,3728,3731,3738,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1015,SUCCESS
    1254,2021-07-01 17:30:29,5025.987,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26128,516,516,8,31,44,724,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3742,3729,3728,3729,3729,3731,3739,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.1,1064,SUCCESS
    1255,2021-07-01 17:30:33,5029.998,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26128,516,516,8,31,44,725,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3742,3729,3729,3729,3729,3731,3739,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,33.9,1025,SUCCESS
    1256,2021-07-01 17:30:37,5034.002,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26129,516,516,8,31,44,726,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3742,3729,3729,3730,3729,3731,3739,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1141,SUCCESS
    1257,2021-07-01 17:30:41,5038.005,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26132,516,516,8,31,44,726,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3743,3730,3729,3730,3729,3732,3739,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,34.0,1046,SUCCESS
    1258,2021-07-01 17:30:45,5042.016,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26133,515,516,8,31,44,727,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3743,3730,3730,3730,3730,3732,3739,0,0,0,0,0,0,0,0,2885,24.9,25.0,-273.2,25.0,-273.2,33.5,1022,SUCCESS
    1259,2021-07-01 17:30:49,5046.031,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26135,515,516,8,31,44,727,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3743,3730,3730,3731,3730,3732,3740,0,0,0,0,0,0,0,0,2889,24.9,25.0,-273.2,25.0,-273.2,34.1,1033,SUCCESS
    1260,2021-07-01 17:30:53,5050.039,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26136,516,516,8,31,44,728,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3743,3730,3730,3731,3730,3732,3740,0,0,0,0,0,0,0,0,2886,24.9,25.0,-273.2,25.0,-273.2,34.0,966,SUCCESS
    1261,2021-07-01 17:30:57,5054.041,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26136,516,516,8,31,44,728,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3743,3731,3730,3732,3731,3732,3741,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,961,SUCCESS
    1262,2021-07-01 17:31:01,5058.051,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26142,516,516,8,31,44,729,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3744,3731,3730,3732,3731,3733,3741,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,981,SUCCESS
    1263,2021-07-01 17:31:05,5062.067,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26144,517,516,8,32,44,730,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3744,3731,3731,3732,3731,3734,3741,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1045,SUCCESS
    1264,2021-07-01 17:31:09,5066.081,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26145,516,516,8,32,44,730,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3744,3732,3731,3732,3731,3734,3741,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,998,SUCCESS
    1265,2021-07-01 17:31:13,5070.096,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26145,516,516,8,32,44,731,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3744,3732,3731,3732,3731,3734,3741,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1047,SUCCESS
    1266,2021-07-01 17:31:17,5074.108,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26148,517,516,8,32,44,731,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3745,3732,3732,3732,3732,3734,3742,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1050,SUCCESS
    1267,2021-07-01 17:31:21,5078.111,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26150,515,516,8,32,44,732,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3745,3732,3732,3733,3732,3734,3742,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,1032,SUCCESS
    1268,2021-07-01 17:31:25,5082.121,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26150,515,516,8,32,44,732,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3745,3732,3732,3733,3732,3734,3742,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,991,SUCCESS
    1269,2021-07-01 17:31:29,5086.133,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26152,517,516,8,32,44,733,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3746,3732,3732,3733,3732,3735,3742,0,0,0,0,0,0,0,0,2890,24.9,25.1,-273.2,25.1,-273.2,34.0,967,SUCCESS
    1270,2021-07-01 17:31:33,5090.147,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26154,516,516,8,32,45,734,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3746,3733,3732,3733,3732,3735,3743,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,964,SUCCESS
    1271,2021-07-01 17:31:37,5094.157,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26155,516,516,8,32,45,734,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3746,3733,3733,3733,3733,3735,3743,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,1017,SUCCESS
    1272,2021-07-01 17:31:41,5098.159,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26157,516,516,8,32,45,735,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3746,3733,3733,3734,3733,3735,3743,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1094,SUCCESS
    1273,2021-07-01 17:31:45,5102.174,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26157,515,516,8,32,45,735,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3746,3733,3733,3734,3733,3735,3744,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1049,SUCCESS
    1274,2021-07-01 17:31:49,5106.174,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26162,516,516,8,32,45,736,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3747,3734,3733,3734,3734,3735,3744,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1016,SUCCESS
    1275,2021-07-01 17:31:53,5110.189,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26164,516,516,8,32,45,737,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3747,3734,3734,3735,3734,3736,3744,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1000,SUCCESS
    1276,2021-07-01 17:31:57,5114.189,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26165,515,516,8,32,45,737,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3747,3735,3734,3735,3734,3737,3744,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1031,SUCCESS
    1277,2021-07-01 17:32:01,5118.198,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26166,515,516,8,32,45,738,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3747,3735,3734,3735,3734,3737,3744,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,944,SUCCESS
    1278,2021-07-01 17:32:05,5122.203,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26170,516,516,8,32,45,738,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3748,3735,3735,3736,3735,3737,3745,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,1034,SUCCESS
    1279,2021-07-01 17:32:09,5126.206,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26171,515,516,8,32,45,739,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3748,3735,3735,3736,3735,3737,3745,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1016,SUCCESS
    1280,2021-07-01 17:32:13,5130.221,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26171,517,516,8,32,45,739,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3748,3735,3735,3736,3735,3738,3745,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1031,SUCCESS
    1281,2021-07-01 17:32:17,5134.236,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26173,515,516,8,32,45,740,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3736,3735,3736,3735,3738,3745,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,1078,SUCCESS
    1282,2021-07-01 17:32:21,5138.243,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26176,516,516,8,32,45,741,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3736,3735,3736,3736,3738,3746,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,963,SUCCESS
    1283,2021-07-01 17:32:25,5142.256,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26178,516,516,8,32,45,741,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3736,3736,3737,3736,3738,3746,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1031,SUCCESS
    1284,2021-07-01 17:32:29,5146.269,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26178,515,516,8,32,45,742,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3736,3736,3737,3736,3738,3746,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.1,1154,SUCCESS
    1285,2021-07-01 17:32:33,5150.272,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26180,515,516,8,32,45,742,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3736,3736,3737,3736,3739,3747,0,0,0,0,0,0,0,0,2890,24.9,25.0,-273.2,25.0,-273.2,34.0,1012,SUCCESS
    1286,2021-07-01 17:32:37,5154.286,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26181,516,516,8,32,45,743,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3749,3737,3736,3737,3737,3739,3747,0,0,0,0,0,0,0,0,2894,24.9,25.1,-273.2,25.1,-273.2,34.0,1007,SUCCESS
    1287,2021-07-01 17:32:41,5158.299,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26183,516,516,8,32,45,743,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3750,3738,3736,3738,3737,3739,3747,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.0,1047,SUCCESS
    1288,2021-07-01 17:32:45,5162.306,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26186,515,516,8,32,45,744,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3750,3738,3737,3738,3737,3739,3747,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.1,1040,SUCCESS
    1289,2021-07-01 17:32:49,5166.308,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26187,516,516,8,32,45,745,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3750,3738,3737,3738,3737,3740,3747,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.1,959,SUCCESS
    1290,2021-07-01 17:32:53,5170.313,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26189,517,516,8,32,45,745,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3751,3738,3738,3739,3737,3740,3747,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.1,1033,SUCCESS
    1291,2021-07-01 17:32:57,5174.313,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26187,517,516,8,32,45,746,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3751,3738,3738,3739,3738,3741,3748,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1007,SUCCESS
    1292,2021-07-01 17:33:01,5178.317,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26194,516,516,8,32,45,746,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3751,3738,3738,3739,3738,3741,3748,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1062,SUCCESS
    1293,2021-07-01 17:33:05,5182.329,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26195,516,516,8,32,45,747,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3751,3738,3738,3739,3738,3741,3748,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1049,SUCCESS
    1294,2021-07-01 17:33:09,5186.334,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26198,516,516,8,32,45,747,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3752,3739,3738,3739,3738,3741,3748,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.0,1042,SUCCESS
    1295,2021-07-01 17:33:13,5190.346,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26198,515,516,8,32,45,748,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3752,3739,3739,3740,3739,3741,3749,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.1,1065,SUCCESS
    1296,2021-07-01 17:33:17,5194.360,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26199,515,516,8,32,45,749,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3752,3739,3739,3740,3739,3742,3749,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1048,SUCCESS
    1297,2021-07-01 17:33:21,5198.361,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26202,517,516,8,32,45,749,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3753,3740,3739,3741,3740,3742,3749,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.1,1078,SUCCESS
    1298,2021-07-01 17:33:25,5202.363,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26205,515,516,8,32,45,750,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3753,3740,3740,3741,3740,3742,3750,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.1,1046,SUCCESS
    1299,2021-07-01 17:33:29,5206.363,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26206,517,516,8,32,45,750,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3753,3740,3740,3741,3740,3743,3750,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.1,1140,SUCCESS
    1300,2021-07-01 17:33:33,5210.370,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26208,515,516,8,32,46,751,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3754,3740,3740,3741,3740,3743,3750,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,33.6,1079,SUCCESS
    1301,2021-07-01 17:33:37,5214.377,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26210,515,516,8,32,46,751,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3754,3741,3740,3741,3741,3743,3750,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1033,SUCCESS
    1302,2021-07-01 17:33:41,5218.377,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26212,516,516,8,32,46,752,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3754,3741,3741,3741,3741,3743,3751,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,1032,SUCCESS
    1303,2021-07-01 17:33:45,5222.385,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26213,516,516,8,33,46,753,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3754,3741,3741,3742,3741,3743,3751,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.1,1001,SUCCESS
    1304,2021-07-01 17:33:49,5226.398,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26213,517,516,8,33,46,753,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3754,3741,3741,3742,3741,3743,3751,0,0,0,0,0,0,0,0,2895,24.9,25.1,-273.2,25.1,-273.2,34.0,979,SUCCESS
    1305,2021-07-01 17:33:53,5230.413,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26216,516,516,8,33,46,754,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3755,3742,3741,3742,3741,3744,3751,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.1,1011,SUCCESS
    1306,2021-07-01 17:33:57,5234.419,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26220,516,516,8,33,46,754,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3755,3742,3741,3743,3742,3744,3752,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.0,1037,SUCCESS
    1307,2021-07-01 17:34:01,5238.424,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26221,516,516,8,33,46,755,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3755,3742,3742,3743,3742,3744,3753,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.0,1030,SUCCESS
    1308,2021-07-01 17:34:05,5242.433,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26222,515,516,8,33,46,756,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3755,3742,3742,3743,3743,3745,3753,0,0,0,0,0,0,0,0,2895,24.9,25.0,-273.2,25.0,-273.2,34.0,1095,SUCCESS
    1309,2021-07-01 17:34:09,5246.434,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26224,515,516,8,33,46,756,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3756,3743,3742,3743,3743,3745,3753,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,1022,SUCCESS
    1310,2021-07-01 17:34:13,5250.444,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26227,516,516,8,33,46,757,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3756,3743,3743,3744,3743,3745,3753,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,981,SUCCESS
    1311,2021-07-01 17:34:17,5254.460,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26228,516,516,8,33,46,757,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3756,3743,3743,3744,3743,3746,3753,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,1031,SUCCESS
    1312,2021-07-01 17:34:21,5258.467,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26231,516,516,8,33,46,758,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3757,3744,3743,3744,3743,3746,3753,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,1019,SUCCESS
    1313,2021-07-01 17:34:25,5262.482,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26234,517,516,8,33,46,759,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3757,3744,3744,3745,3744,3746,3754,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,1098,SUCCESS
    1314,2021-07-01 17:34:29,5266.485,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26234,516,516,8,33,46,759,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3757,3744,3744,3745,3744,3746,3754,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,987,SUCCESS
    1315,2021-07-01 17:34:33,5270.500,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26236,517,516,8,33,46,760,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3757,3744,3744,3745,3745,3746,3755,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,971,SUCCESS
    1316,2021-07-01 17:34:37,5274.505,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26238,515,516,8,33,46,760,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3758,3745,3744,3745,3744,3747,3755,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,966,SUCCESS
    1317,2021-07-01 17:34:41,5278.507,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26239,516,516,8,33,46,761,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3758,3745,3745,3745,3744,3748,3756,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,981,SUCCESS
    1318,2021-07-01 17:34:45,5282.513,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26242,516,516,8,33,46,761,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3758,3745,3745,3746,3745,3748,3755,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,1147,SUCCESS
    1319,2021-07-01 17:34:49,5286.526,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26245,516,516,8,33,46,762,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3758,3746,3745,3746,3746,3748,3756,0,0,0,0,0,0,0,0,2900,24.9,25.0,-273.2,25.0,-273.2,34.1,1023,SUCCESS
    1320,2021-07-01 17:34:53,5290.530,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26247,515,516,8,33,46,763,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3759,3746,3745,3746,3746,3748,3756,0,0,0,0,0,0,0,0,2900,24.9,25.0,-273.2,25.0,-273.2,34.1,1003,SUCCESS
    1321,2021-07-01 17:34:57,5294.543,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26247,516,516,8,33,46,763,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3759,3746,3746,3747,3746,3748,3756,0,0,0,0,0,0,0,0,2900,24.9,25.0,-273.2,25.0,-273.2,34.0,960,SUCCESS
    1322,2021-07-01 17:35:01,5298.546,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26249,516,516,8,33,46,764,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3759,3746,3746,3747,3746,3749,3757,0,0,0,0,0,0,0,0,2900,24.9,25.0,-273.2,25.0,-273.2,34.1,1049,SUCCESS
    1323,2021-07-01 17:35:05,5302.559,0x0701,150,10,0x6001,0,65535,65535,1,25.0,26253,516,516,8,33,46,764,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3759,3747,3746,3747,3747,3750,3757,0,0,0,0,0,0,0,0,2900,24.9,25.0,-273.2,25.0,-273.2,34.1,974,SUCCESS
    1324,2021-07-01 17:35:09,5306.559,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26254,517,516,8,33,46,765,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3760,3747,3746,3747,3747,3749,3757,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,33.8,1060,SUCCESS
    1325,2021-07-01 17:35:13,5310.571,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26255,517,516,8,33,46,765,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3760,3747,3747,3748,3747,3749,3757,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,946,SUCCESS
    1326,2021-07-01 17:35:17,5314.572,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26257,516,516,8,33,46,766,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3760,3747,3747,3748,3747,3750,3758,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,1008,SUCCESS
    1327,2021-07-01 17:35:21,5318.575,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26260,516,516,8,33,47,767,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3761,3748,3747,3748,3747,3750,3758,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,1098,SUCCESS
    1328,2021-07-01 17:35:25,5322.591,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26262,516,516,8,33,47,767,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3761,3748,3748,3748,3748,3751,3758,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,1006,SUCCESS
    1329,2021-07-01 17:35:29,5326.599,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26263,516,516,8,33,47,768,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3761,3748,3748,3749,3748,3751,3758,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.0,1081,SUCCESS
    1330,2021-07-01 17:35:33,5330.611,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26265,516,516,8,33,47,768,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3761,3749,3748,3749,3748,3751,3758,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,1080,SUCCESS
    1331,2021-07-01 17:35:37,5334.619,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26268,516,516,8,33,47,769,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3762,3749,3749,3749,3749,3751,3759,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,960,SUCCESS
    1332,2021-07-01 17:35:41,5338.620,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26269,516,516,8,33,47,769,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3762,3749,3749,3750,3749,3751,3759,0,0,0,0,0,0,0,0,2900,24.9,25.1,-273.2,25.1,-273.2,34.1,991,SUCCESS
    1333,2021-07-01 17:35:45,5342.630,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26271,516,516,8,33,47,770,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3762,3749,3749,3750,3749,3752,3759,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,996,SUCCESS
    1334,2021-07-01 17:35:49,5346.642,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26274,516,516,8,33,47,771,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3763,3750,3749,3750,3750,3752,3760,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1015,SUCCESS
    1335,2021-07-01 17:35:53,5350.643,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26276,516,516,8,33,47,771,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3763,3750,3750,3750,3750,3752,3760,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1061,SUCCESS
    1336,2021-07-01 17:35:57,5354.649,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26276,517,516,8,33,47,772,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3763,3750,3750,3751,3750,3753,3760,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1010,SUCCESS
    1337,2021-07-01 17:36:01,5358.652,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26279,516,516,8,33,47,772,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3763,3750,3750,3751,3751,3753,3761,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1053,SUCCESS
    1338,2021-07-01 17:36:05,5362.652,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26282,516,516,8,33,47,773,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3764,3751,3750,3751,3751,3753,3761,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,995,SUCCESS
    1339,2021-07-01 17:36:09,5366.654,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26283,517,516,8,33,47,773,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3764,3751,3751,3752,3751,3753,3761,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.0,1011,SUCCESS
    1340,2021-07-01 17:36:13,5370.665,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26284,515,516,8,33,47,774,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3764,3751,3751,3752,3751,3754,3762,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.0,1009,SUCCESS
    1341,2021-07-01 17:36:17,5374.673,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26286,516,516,8,33,47,775,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3764,3752,3751,3752,3751,3754,3762,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.0,1086,SUCCESS
    1342,2021-07-01 17:36:21,5378.680,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26288,516,516,8,33,47,775,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3765,3752,3752,3752,3752,3754,3762,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1120,SUCCESS
    1343,2021-07-01 17:36:25,5382.695,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26290,515,516,8,33,47,776,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3765,3752,3752,3753,3752,3754,3762,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,980,SUCCESS
    1344,2021-07-01 17:36:29,5386.707,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26291,516,516,8,33,47,776,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3765,3752,3752,3753,3752,3755,3762,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.0,1000,SUCCESS
    1345,2021-07-01 17:36:33,5390.716,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26294,515,516,8,34,47,777,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3766,3753,3752,3753,3753,3755,3763,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1085,SUCCESS
    1346,2021-07-01 17:36:37,5394.722,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26297,515,516,8,34,47,778,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3766,3753,3753,3754,3753,3755,3763,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1085,SUCCESS
    1347,2021-07-01 17:36:41,5398.728,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26298,517,516,8,34,47,778,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3766,3753,3753,3754,3753,3756,3763,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,33.3,1029,SUCCESS
    1348,2021-07-01 17:36:45,5402.735,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26300,516,516,8,34,47,779,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3767,3753,3753,3754,3754,3756,3764,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1111,SUCCESS
    1349,2021-07-01 17:36:49,5406.748,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26302,516,516,8,34,47,779,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3767,3754,3753,3755,3754,3756,3764,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.0,1004,SUCCESS
    1350,2021-07-01 17:36:53,5410.749,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26304,516,516,8,34,47,780,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3767,3754,3754,3755,3754,3757,3764,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1035,SUCCESS
    1351,2021-07-01 17:36:57,5414.763,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26305,516,516,8,34,47,780,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3767,3755,3754,3755,3754,3757,3764,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1116,SUCCESS
    1352,2021-07-01 17:37:01,5418.776,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26309,516,516,8,34,47,781,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3767,3755,3755,3755,3755,3757,3765,0,0,0,0,0,0,0,0,2905,24.9,25.1,-273.2,25.1,-273.2,34.1,1024,SUCCESS
    1353,2021-07-01 17:37:05,5422.776,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26312,516,516,8,34,47,782,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3768,3755,3755,3756,3755,3758,3765,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1039,SUCCESS
    1354,2021-07-01 17:37:09,5426.784,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26313,516,516,8,34,47,782,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3768,3755,3755,3756,3755,3758,3765,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1281,SUCCESS
    1355,2021-07-01 17:37:13,5430.793,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26314,516,516,8,34,47,783,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3769,3756,3755,3756,3755,3758,3766,0,0,0,0,0,0,0,0,2905,25.0,25.1,-273.2,25.1,-273.2,34.1,1007,SUCCESS
    1356,2021-07-01 17:37:17,5434.795,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26318,516,516,8,34,47,783,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3769,3756,3756,3756,3755,3758,3765,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1053,SUCCESS
    1357,2021-07-01 17:37:21,5438.805,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26318,515,516,8,34,48,784,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3769,3756,3756,3757,3756,3758,3766,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,977,SUCCESS
    1358,2021-07-01 17:37:25,5442.818,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26321,516,516,8,34,48,784,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3769,3756,3756,3757,3757,3759,3767,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1028,SUCCESS
    1359,2021-07-01 17:37:29,5446.828,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26320,516,516,8,34,48,785,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3770,3757,3756,3757,3757,3759,3767,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1020,SUCCESS
    1360,2021-07-01 17:37:33,5450.838,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26325,516,516,8,34,48,786,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3770,3757,3757,3758,3757,3759,3767,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,992,SUCCESS
    1361,2021-07-01 17:37:37,5454.852,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26325,516,516,8,34,48,786,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3770,3757,3757,3758,3757,3759,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,994,SUCCESS
    1362,2021-07-01 17:37:41,5458.863,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26329,516,516,8,34,48,787,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3770,3758,3757,3758,3758,3760,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.2,1050,SUCCESS
    1363,2021-07-01 17:37:46,5462.876,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26330,516,516,8,34,48,787,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3770,3758,3758,3758,3758,3760,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.2,1019,SUCCESS
    1364,2021-07-01 17:37:50,5466.881,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26333,516,516,8,34,48,788,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3771,3758,3758,3759,3758,3761,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1043,SUCCESS
    1365,2021-07-01 17:37:54,5470.938,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26333,515,516,8,34,48,788,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3771,3758,3758,3759,3758,3761,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1034,SUCCESS
    1366,2021-07-01 17:37:58,5474.893,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26334,516,516,8,34,48,789,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3772,3759,3758,3759,3758,3761,3768,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,33.4,1117,SUCCESS
    1367,2021-07-01 17:38:02,5478.906,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26337,517,516,8,34,48,790,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3772,3759,3759,3759,3759,3761,3769,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.2,1126,SUCCESS
    1368,2021-07-01 17:38:06,5482.921,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26341,516,516,8,34,48,790,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3772,3759,3759,3760,3760,3762,3770,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1034,SUCCESS
    1369,2021-07-01 17:38:10,5486.924,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26341,516,516,8,34,48,791,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3772,3759,3759,3760,3760,3762,3770,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1063,SUCCESS
    1370,2021-07-01 17:38:14,5490.927,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26345,515,516,8,34,48,791,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3773,3759,3759,3760,3760,3762,3770,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1014,SUCCESS
    1371,2021-07-01 17:38:18,5494.941,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26347,516,516,8,34,48,792,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3773,3760,3760,3761,3760,3763,3770,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.0,1050,SUCCESS
    1372,2021-07-01 17:38:22,5498.943,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26349,516,516,8,34,48,792,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3773,3760,3760,3761,3761,3763,3771,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.2,1103,SUCCESS
    1373,2021-07-01 17:38:26,5502.947,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26352,516,516,8,34,48,793,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3773,3761,3761,3761,3761,3763,3771,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1008,SUCCESS
    1374,2021-07-01 17:38:30,5506.950,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26353,516,516,8,34,48,794,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3774,3761,3761,3762,3761,3763,3771,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,988,SUCCESS
    1375,2021-07-01 17:38:34,5510.960,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26354,516,516,8,34,48,794,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3774,3761,3761,3762,3761,3764,3771,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.0,1027,SUCCESS
    1376,2021-07-01 17:38:38,5514.960,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26356,516,516,8,34,48,795,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3775,3762,3761,3762,3761,3763,3771,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,964,SUCCESS
    1377,2021-07-01 17:38:42,5518.970,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26358,516,516,8,34,48,795,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3775,3762,3761,3762,3762,3764,3772,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1096,SUCCESS
    1378,2021-07-01 17:38:46,5522.971,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26360,516,516,8,34,48,796,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3775,3762,3762,3763,3762,3765,3772,0,0,0,0,0,0,0,0,2910,25.0,25.1,-273.2,25.1,-273.2,34.1,1017,SUCCESS
    1379,2021-07-01 17:38:50,5526.971,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26361,515,516,8,34,48,797,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3775,3762,3762,3763,3763,3765,3773,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1062,SUCCESS
    1380,2021-07-01 17:38:54,5530.987,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26363,516,516,8,34,48,797,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3776,3763,3762,3763,3763,3765,3773,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.0,1061,SUCCESS
    1381,2021-07-01 17:38:58,5534.987,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26368,516,516,8,34,48,798,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3776,3763,3763,3764,3763,3766,3773,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1031,SUCCESS
    1382,2021-07-01 17:39:02,5538.990,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26368,516,516,8,34,48,798,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3776,3763,3763,3764,3763,3767,3773,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,979,SUCCESS
    1383,2021-07-01 17:39:06,5542.995,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26372,516,516,8,34,48,799,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3776,3764,3764,3764,3764,3767,3774,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1056,SUCCESS
    1384,2021-07-01 17:39:10,5546.994,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26373,516,516,8,34,48,800,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3777,3764,3764,3764,3764,3767,3774,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1023,SUCCESS
    1385,2021-07-01 17:39:14,5550.998,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26375,516,516,8,35,48,800,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3777,3764,3764,3765,3764,3767,3774,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,33.5,1041,SUCCESS
    1386,2021-07-01 17:39:18,5555.001,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26377,516,516,8,35,49,801,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3778,3765,3764,3765,3765,3767,3775,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1015,SUCCESS
    1387,2021-07-01 17:39:22,5559.003,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26378,516,516,8,35,49,801,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3778,3765,3764,3765,3765,3767,3775,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1092,SUCCESS
    1388,2021-07-01 17:39:26,5563.013,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26380,516,516,8,35,49,802,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3778,3765,3765,3765,3765,3767,3775,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.2,1010,SUCCESS
    1389,2021-07-01 17:39:30,5567.017,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26383,516,516,8,35,49,802,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3778,3765,3765,3766,3766,3768,3776,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1030,SUCCESS
    1390,2021-07-01 17:39:34,5571.026,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26385,516,516,8,35,49,803,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3779,3766,3765,3766,3766,3768,3776,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,991,SUCCESS
    1391,2021-07-01 17:39:38,5575.028,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26389,515,516,8,35,49,804,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3779,3766,3766,3767,3766,3769,3776,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1099,SUCCESS
    1392,2021-07-01 17:39:42,5579.035,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26389,515,516,8,35,49,804,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3779,3766,3766,3767,3766,3769,3776,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.2,967,SUCCESS
    1393,2021-07-01 17:39:46,5583.042,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26391,515,516,8,35,49,805,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3780,3767,3767,3767,3767,3769,3777,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.2,975,SUCCESS
    1394,2021-07-01 17:39:50,5587.052,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26394,515,516,8,35,49,805,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3780,3767,3767,3767,3767,3769,3777,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,996,SUCCESS
    1395,2021-07-01 17:39:54,5591.064,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26396,516,516,8,35,49,806,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3780,3767,3767,3768,3767,3770,3777,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1045,SUCCESS
    1396,2021-07-01 17:39:58,5595.069,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26397,516,516,8,35,49,806,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3780,3767,3767,3768,3767,3770,3777,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1104,SUCCESS
    1397,2021-07-01 17:40:02,5599.083,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26400,515,516,8,35,49,807,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3781,3768,3767,3768,3767,3770,3778,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.2,980,SUCCESS
    1398,2021-07-01 17:40:06,5603.096,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26402,516,516,8,35,49,808,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3781,3768,3768,3769,3768,3771,3778,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.1,1109,SUCCESS
    1399,2021-07-01 17:40:10,5607.099,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26404,516,516,8,35,49,808,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3781,3768,3768,3769,3769,3771,3778,0,0,0,0,0,0,0,0,2915,25.0,25.1,-273.2,25.1,-273.2,34.2,1010,SUCCESS
    1400,2021-07-01 17:40:14,5611.109,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26406,516,516,8,35,49,809,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3781,3769,3768,3770,3769,3771,3779,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,987,SUCCESS
    1401,2021-07-01 17:40:18,5615.111,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26409,516,516,8,35,49,809,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3782,3769,3769,3770,3769,3771,3779,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1094,SUCCESS
    1402,2021-07-01 17:40:22,5619.111,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26409,516,516,8,35,49,810,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3782,3769,3769,3770,3769,3772,3779,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1093,SUCCESS
    1403,2021-07-01 17:40:26,5623.120,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26412,516,516,8,35,49,810,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3783,3770,3769,3770,3769,3772,3779,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,991,SUCCESS
    1404,2021-07-01 17:40:30,5627.121,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26416,516,516,8,35,49,811,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3783,3770,3770,3770,3770,3773,3780,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1053,SUCCESS
    1405,2021-07-01 17:40:34,5631.122,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26417,515,516,8,35,49,812,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3783,3770,3770,3771,3770,3773,3780,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1003,SUCCESS
    1406,2021-07-01 17:40:38,5635.138,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26418,517,516,8,35,49,812,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3783,3770,3770,3771,3770,3774,3781,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.2,1067,SUCCESS
    1407,2021-07-01 17:40:42,5639.147,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26423,516,516,8,35,49,813,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3784,3771,3770,3771,3770,3774,3781,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1012,SUCCESS
    1408,2021-07-01 17:40:46,5643.160,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26423,515,516,8,35,49,813,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3784,3771,3771,3772,3771,3774,3781,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1028,SUCCESS
    1409,2021-07-01 17:40:50,5647.161,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26427,516,516,8,35,49,814,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3784,3771,3771,3772,3772,3774,3782,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1043,SUCCESS
    1410,2021-07-01 17:40:54,5651.163,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26427,515,516,8,35,49,814,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3784,3772,3771,3773,3772,3775,3782,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1058,SUCCESS
    1411,2021-07-01 17:40:58,5655.175,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26431,515,516,8,35,49,815,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3785,3772,3772,3773,3772,3775,3782,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,966,SUCCESS
    1412,2021-07-01 17:41:02,5659.190,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26431,515,516,8,35,49,816,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3785,3772,3772,3773,3772,3775,3782,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1092,SUCCESS
    1413,2021-07-01 17:41:06,5663.194,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26434,516,516,8,35,49,816,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3786,3773,3773,3773,3773,3775,3783,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,33.4,1019,SUCCESS
    1414,2021-07-01 17:41:10,5667.209,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26437,516,515,8,35,50,817,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3786,3773,3773,3774,3773,3775,3783,0,0,0,0,0,0,0,0,2920,25.0,25.2,-273.2,25.2,-273.2,34.1,1016,SUCCESS
    1415,2021-07-01 17:41:14,5671.211,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26437,516,516,8,35,50,817,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3786,3773,3773,3774,3773,3776,3783,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1088,SUCCESS
    1416,2021-07-01 17:41:18,5675.225,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26439,515,516,8,35,50,818,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3786,3773,3773,3774,3773,3776,3784,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1011,SUCCESS
    1417,2021-07-01 17:41:22,5679.239,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26444,516,516,8,35,50,818,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3787,3774,3774,3774,3774,3777,3784,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1026,SUCCESS
    1418,2021-07-01 17:41:26,5683.242,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26444,516,516,8,35,50,819,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3787,3774,3774,3775,3774,3777,3784,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.2,1048,SUCCESS
    1419,2021-07-01 17:41:30,5687.244,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26446,515,515,8,35,50,820,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3787,3775,3774,3775,3774,3777,3784,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.2,975,SUCCESS
    1420,2021-07-01 17:41:34,5691.246,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26449,516,515,8,35,50,820,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3787,3775,3775,3776,3775,3778,3785,0,0,0,0,0,0,0,0,2920,25.0,25.1,-273.2,25.1,-273.2,34.1,1054,SUCCESS
    1421,2021-07-01 17:41:38,5695.257,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26452,515,515,8,35,50,821,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3788,3775,3775,3776,3775,3778,3785,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1012,SUCCESS
    1422,2021-07-01 17:41:42,5699.269,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26452,515,515,8,35,50,821,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3788,3775,3775,3776,3775,3778,3785,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,1031,SUCCESS
    1423,2021-07-01 17:41:46,5703.279,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26455,515,515,8,35,50,822,2352,65535,65535,250,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3789,3776,3776,3776,3776,3778,3786,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,1068,SUCCESS
    1424,2021-07-01 17:41:50,5707.281,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26458,514,515,8,35,50,823,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3789,3776,3776,3777,3776,3779,3786,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1081,SUCCESS
    1425,2021-07-01 17:41:54,5711.294,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26460,515,515,8,35,50,823,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3789,3776,3777,3777,3776,3779,3787,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1036,SUCCESS
    1426,2021-07-01 17:41:58,5715.303,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26463,515,515,8,36,50,824,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3790,3777,3777,3777,3777,3779,3787,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1027,SUCCESS
    1427,2021-07-01 17:42:02,5719.308,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26465,515,515,8,36,50,824,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3790,3777,3777,3778,3777,3780,3787,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,33.5,1060,SUCCESS
    1428,2021-07-01 17:42:06,5723.315,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26465,516,515,8,36,50,825,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3790,3777,3777,3778,3777,3780,3788,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,1078,SUCCESS
    1429,2021-07-01 17:42:10,5727.320,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26466,514,515,8,36,50,825,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3790,3778,3777,3778,3778,3780,3788,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1011,SUCCESS
    1430,2021-07-01 17:42:14,5731.323,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26468,516,515,8,36,50,826,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3790,3778,3778,3779,3778,3781,3788,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1010,SUCCESS
    1431,2021-07-01 17:42:18,5735.330,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26470,515,515,8,36,50,827,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3791,3778,3778,3779,3778,3781,3789,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1060,SUCCESS
    1432,2021-07-01 17:42:22,5739.334,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26474,515,515,8,36,50,827,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3791,3778,3778,3779,3779,3781,3789,0,0,0,0,0,0,0,0,2925,25.0,25.2,-273.2,25.1,-273.2,34.1,1019,SUCCESS
    1433,2021-07-01 17:42:26,5743.340,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26479,515,515,8,36,50,828,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3792,3779,3778,3779,3779,3781,3789,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,959,SUCCESS
    1434,2021-07-01 17:42:30,5747.345,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26480,514,515,8,36,50,828,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3792,3779,3779,3780,3779,3782,3789,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,1031,SUCCESS
    1435,2021-07-01 17:42:34,5751.359,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26482,515,515,8,36,50,829,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3792,3779,3779,3780,3780,3782,3789,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.2,1034,SUCCESS
    1436,2021-07-01 17:42:38,5755.362,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26488,516,515,8,36,50,829,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3792,3779,3779,3780,3780,3783,3790,0,0,0,0,0,0,0,0,2925,25.1,25.2,-273.2,25.1,-273.2,34.2,1027,SUCCESS
    1437,2021-07-01 17:42:42,5759.370,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26490,515,515,8,36,50,830,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3793,3780,3780,3781,3780,3783,3790,0,0,0,0,0,0,0,0,2925,25.1,25.2,-273.2,25.2,-273.2,34.1,1024,SUCCESS
    1438,2021-07-01 17:42:46,5763.374,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26487,515,515,8,36,50,831,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3793,3780,3780,3781,3780,3783,3790,0,0,0,0,0,0,0,0,2925,25.1,25.2,-273.2,25.2,-273.2,34.2,987,SUCCESS
    1439,2021-07-01 17:42:50,5767.377,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26490,516,515,8,36,50,831,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3793,3781,3781,3781,3781,3783,3791,0,0,0,0,0,0,0,0,2925,25.1,25.2,-273.2,25.2,-273.2,34.2,1046,SUCCESS
    1440,2021-07-01 17:42:54,5771.391,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26494,514,515,8,36,50,832,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3794,3781,3781,3781,3781,3784,3791,0,0,0,0,0,0,0,0,2925,25.1,25.1,-273.2,25.1,-273.2,34.2,1016,SUCCESS
    1441,2021-07-01 17:42:58,5775.399,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26494,516,515,8,36,50,832,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3794,3781,3781,3782,3781,3784,3791,0,0,0,0,0,0,0,0,2925,25.0,25.1,-273.2,25.1,-273.2,34.1,1023,SUCCESS
    1442,2021-07-01 17:43:02,5779.403,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26495,515,515,8,36,50,833,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3795,3781,3781,3782,3782,3784,3792,0,0,0,0,0,0,0,0,2930,25.0,25.1,-273.2,25.1,-273.2,34.1,988,SUCCESS
    1443,2021-07-01 17:43:06,5783.410,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26498,515,515,8,36,50,833,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3795,3782,3782,3782,3782,3785,3792,0,0,0,0,0,0,0,0,2930,25.0,25.1,-273.2,25.1,-273.2,34.2,1059,SUCCESS
    1444,2021-07-01 17:43:10,5787.425,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26502,514,515,8,36,51,834,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3795,3782,3782,3783,3782,3785,3792,0,0,0,0,0,0,0,0,2930,25.1,25.1,-273.2,25.1,-273.2,34.1,1013,SUCCESS
    1445,2021-07-01 17:43:14,5791.438,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26504,514,515,8,36,51,835,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3795,3782,3782,3783,3783,3786,3793,0,0,0,0,0,0,0,0,2930,25.1,25.1,-273.2,25.1,-273.2,34.1,1030,SUCCESS
    1446,2021-07-01 17:43:18,5795.445,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26507,515,514,8,36,51,835,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3796,3783,3782,3784,3783,3786,3793,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,963,SUCCESS
    1447,2021-07-01 17:43:22,5799.445,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26508,514,514,8,36,51,836,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3796,3783,3783,3784,3783,3786,3793,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,962,SUCCESS
    1448,2021-07-01 17:43:26,5803.458,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26510,514,514,8,36,51,836,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3796,3783,3783,3784,3784,3786,3794,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.1,1091,SUCCESS
    1449,2021-07-01 17:43:30,5807.465,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26513,514,514,8,36,51,837,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3796,3784,3784,3784,3784,3787,3794,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,1036,SUCCESS
    1450,2021-07-01 17:43:34,5811.466,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26514,515,514,8,36,51,837,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3797,3784,3784,3784,3784,3787,3794,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.1,1005,SUCCESS
    1451,2021-07-01 17:43:38,5815.469,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26514,515,514,8,36,51,838,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3797,3784,3784,3785,3784,3787,3794,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,1094,SUCCESS
    1452,2021-07-01 17:43:42,5819.479,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26520,514,514,8,36,51,839,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3798,3785,3784,3785,3785,3788,3795,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,993,SUCCESS
    1453,2021-07-01 17:43:46,5823.481,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26521,514,514,8,36,51,839,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3798,3785,3785,3785,3785,3787,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.1,973,SUCCESS
    1454,2021-07-01 17:43:50,5827.480,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26524,515,514,8,36,51,840,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3798,3785,3785,3786,3785,3787,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,943,SUCCESS
    1455,2021-07-01 17:43:54,5831.484,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26526,514,514,8,36,51,840,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3798,3785,3785,3786,3786,3788,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,971,SUCCESS
    1456,2021-07-01 17:43:58,5835.487,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26529,514,515,8,36,51,841,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3799,3786,3786,3787,3786,3789,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,1049,SUCCESS
    1457,2021-07-01 17:44:02,5839.498,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26529,515,514,8,36,51,841,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3799,3786,3786,3787,3787,3787,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,987,SUCCESS
    1458,2021-07-01 17:44:06,5843.503,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26533,514,515,8,36,51,842,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3799,3787,3787,3787,3787,3787,3796,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.1,1014,SUCCESS
    1459,2021-07-01 17:44:10,5847.504,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26535,515,514,8,36,51,843,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3799,3787,3787,3787,3787,3786,3797,0,0,0,0,0,0,0,0,2930,25.1,25.1,-273.2,25.1,-273.2,34.1,997,SUCCESS
    1460,2021-07-01 17:44:14,5851.508,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26537,515,515,8,36,51,843,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3800,3787,3787,3788,3789,3788,3797,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,1010,SUCCESS
    1461,2021-07-01 17:44:18,5855.520,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26538,515,514,8,36,51,844,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3800,3788,3787,3788,3788,3792,3797,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.2,983,SUCCESS
    1462,2021-07-01 17:44:22,5859.528,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26542,515,514,8,36,51,844,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3801,3788,3788,3788,3788,3792,3798,0,0,0,0,0,0,0,0,2930,25.1,25.2,-273.2,25.2,-273.2,34.1,1068,SUCCESS
    1463,2021-07-01 17:44:26,5863.540,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26545,514,515,8,36,51,845,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3801,3788,3788,3789,3789,3793,3798,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1025,SUCCESS
    1464,2021-07-01 17:44:30,5867.547,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26546,515,515,8,36,51,846,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3801,3788,3788,3789,3789,3795,3799,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1095,SUCCESS
    1465,2021-07-01 17:44:34,5871.547,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26550,515,515,8,36,51,846,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3801,3789,3789,3789,3789,3792,3799,0,0,0,0,0,0,0,0,2935,25.1,25.1,-273.2,25.1,-273.2,34.2,1000,SUCCESS
    1466,2021-07-01 17:44:38,5875.550,0x0701,150,10,0x6001,0,65535,65535,1,25.1,26550,515,515,8,37,51,847,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3802,3789,3789,3790,3789,3792,3799,0,0,0,0,0,0,0,0,2935,25.1,25.1,-273.2,25.1,-273.2,34.2,1046,SUCCESS
    1467,2021-07-01 17:44:42,5879.552,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26551,514,515,8,37,51,847,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3802,3790,3789,3790,3790,3792,3800,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.1,1077,SUCCESS
    1468,2021-07-01 17:44:46,5883.566,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26555,516,515,8,37,51,848,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3803,3790,3790,3790,3790,3792,3800,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.1,1062,SUCCESS
    1469,2021-07-01 17:44:50,5887.579,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26557,515,515,8,37,51,848,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3803,3790,3790,3791,3790,3793,3800,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1049,SUCCESS
    1470,2021-07-01 17:44:54,5891.580,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26558,515,515,8,37,51,849,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3803,3790,3790,3791,3791,3793,3800,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,985,SUCCESS
    1471,2021-07-01 17:44:58,5895.584,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26560,513,515,8,37,51,850,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3804,3791,3790,3791,3790,3792,3800,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1045,SUCCESS
    1472,2021-07-01 17:45:02,5899.592,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26563,515,515,8,37,51,850,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3804,3791,3791,3791,3791,3794,3801,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1003,SUCCESS
    1473,2021-07-01 17:45:06,5903.604,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26566,515,515,8,37,52,851,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3804,3791,3791,3792,3792,3794,3802,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.1,976,SUCCESS
    1474,2021-07-01 17:45:10,5907.614,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26569,515,515,8,37,52,851,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3805,3792,3791,3792,3792,3795,3802,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,981,SUCCESS
    1475,2021-07-01 17:45:14,5911.629,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26571,515,515,8,37,52,852,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3805,3792,3792,3793,3792,3795,3802,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,967,SUCCESS
    1476,2021-07-01 17:45:18,5915.640,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26571,514,515,8,37,52,852,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3806,3792,3792,3793,3793,3795,3802,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1113,SUCCESS
    1477,2021-07-01 17:45:22,5919.643,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26576,515,515,8,37,52,853,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3806,3793,3793,3793,3793,3796,3803,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1017,SUCCESS
    1478,2021-07-01 17:45:26,5923.646,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26578,514,515,8,37,52,854,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3806,3793,3793,3794,3793,3796,3804,0,0,0,0,0,0,0,0,2939,25.1,25.2,-273.2,25.2,-273.2,34.3,1034,SUCCESS
    1479,2021-07-01 17:45:30,5927.657,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26582,515,515,8,37,52,854,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3793,3793,3794,3794,3797,3804,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,33.6,1038,SUCCESS
    1480,2021-07-01 17:45:34,5931.668,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26583,515,515,8,37,52,855,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3794,3793,3794,3794,3797,3804,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.3,1086,SUCCESS
    1481,2021-07-01 17:45:38,5935.669,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26584,515,515,8,37,52,855,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3794,3794,3794,3794,3797,3804,0,0,0,0,0,0,0,0,2935,25.1,25.2,-273.2,25.2,-273.2,34.2,1021,SUCCESS
    1482,2021-07-01 17:45:42,5939.678,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26587,516,515,8,37,52,856,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3795,3794,3795,3795,3797,3805,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1104,SUCCESS
    1483,2021-07-01 17:45:46,5943.694,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26588,515,515,8,37,52,856,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3795,3794,3795,3795,3798,3805,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1060,SUCCESS
    1484,2021-07-01 17:45:50,5947.703,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26591,515,515,8,37,52,857,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3807,3795,3795,3796,3795,3798,3805,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.3,1096,SUCCESS
    1485,2021-07-01 17:45:54,5951.717,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26593,516,515,8,37,52,858,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3808,3795,3795,3796,3796,3798,3806,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1036,SUCCESS
    1486,2021-07-01 17:45:58,5955.719,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26594,515,515,8,37,52,858,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3808,3795,3796,3796,3796,3798,3806,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1080,SUCCESS
    1487,2021-07-01 17:46:02,5959.727,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26599,515,515,8,37,52,859,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3809,3796,3796,3797,3796,3799,3806,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1012,SUCCESS
    1488,2021-07-01 17:46:06,5963.737,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26601,514,515,8,37,52,859,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3809,3796,3796,3797,3796,3800,3807,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,33.6,1021,SUCCESS
    1489,2021-07-01 17:46:10,5967.745,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26601,515,515,8,37,52,860,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3809,3796,3796,3797,3797,3800,3807,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.3,1038,SUCCESS
    1490,2021-07-01 17:46:14,5971.750,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26605,514,515,8,37,52,860,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3810,3796,3797,3797,3797,3800,3807,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1049,SUCCESS
    1491,2021-07-01 17:46:18,5975.756,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26607,514,515,8,37,52,861,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3810,3797,3797,3798,3798,3800,3807,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1055,SUCCESS
    1492,2021-07-01 17:46:22,5979.757,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26611,515,515,8,37,52,862,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3810,3798,3798,3798,3798,3801,3808,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1009,SUCCESS
    1493,2021-07-01 17:46:26,5983.770,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26613,515,515,8,37,52,862,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3811,3798,3798,3799,3798,3801,3808,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1077,SUCCESS
    1494,2021-07-01 17:46:30,5987.772,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26613,515,515,8,37,52,863,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3811,3798,3798,3799,3798,3801,3808,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1058,SUCCESS
    1495,2021-07-01 17:46:34,5991.771,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26615,516,515,8,37,52,863,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3811,3799,3798,3799,3799,3801,3809,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,980,SUCCESS
    1496,2021-07-01 17:46:38,5995.773,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26619,515,515,8,37,52,864,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3812,3799,3799,3800,3799,3802,3809,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,978,SUCCESS
    1497,2021-07-01 17:46:42,5999.787,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26622,516,515,8,37,52,865,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3812,3799,3799,3800,3800,3802,3810,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1041,SUCCESS
    1498,2021-07-01 17:46:46,6003.792,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26622,514,515,8,37,52,865,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3812,3799,3799,3800,3800,3803,3810,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.3,1105,SUCCESS
    1499,2021-07-01 17:46:50,6007.795,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26627,515,515,8,37,52,866,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3813,3800,3800,3801,3800,3803,3810,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1049,SUCCESS
    1500,2021-07-01 17:46:54,6011.796,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26629,514,515,8,37,52,866,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3813,3800,3800,3801,3801,3803,3811,0,0,0,0,0,0,0,0,2940,25.1,25.2,-273.2,25.2,-273.2,34.2,1047,SUCCESS
    1501,2021-07-01 17:46:58,6015.801,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26632,514,515,8,37,53,867,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3813,3801,3801,3801,3801,3804,3811,0,0,0,0,0,0,0,0,2944,25.1,25.2,-273.2,25.2,-273.2,34.2,1027,SUCCESS
    1502,2021-07-01 17:47:02,6019.815,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26633,515,515,8,37,53,867,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3814,3801,3801,3802,3802,3804,3811,0,0,0,0,0,0,0,0,2941,25.1,25.2,-273.2,25.2,-273.2,34.3,1092,SUCCESS
    1503,2021-07-01 17:47:06,6023.830,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26636,516,515,8,37,53,868,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3814,3801,3801,3802,3802,3804,3812,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1078,SUCCESS
    1504,2021-07-01 17:47:10,6027.844,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26639,515,515,8,37,53,869,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3815,3802,3802,3802,3802,3805,3812,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1047,SUCCESS
    1505,2021-07-01 17:47:14,6031.845,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26643,515,515,8,37,53,869,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3815,3802,3802,3803,3803,3805,3812,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1063,SUCCESS
    1506,2021-07-01 17:47:18,6035.845,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26640,515,515,8,37,53,870,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3815,3802,3802,3803,3803,3806,3813,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.3,999,SUCCESS
    1507,2021-07-01 17:47:22,6039.851,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26644,514,515,8,37,53,870,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3815,3802,3802,3803,3803,3806,3813,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,994,SUCCESS
    1508,2021-07-01 17:47:26,6043.854,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26648,516,515,8,38,53,871,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3816,3803,3803,3804,3804,3806,3813,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,977,SUCCESS
    1509,2021-07-01 17:47:30,6047.856,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26649,514,515,8,38,53,871,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3816,3803,3803,3804,3804,3807,3814,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1004,SUCCESS
    1510,2021-07-01 17:47:35,6051.871,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26653,515,515,8,38,53,872,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3816,3804,3804,3804,3804,3807,3814,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1145,SUCCESS
    1511,2021-07-01 17:47:39,6055.889,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26653,515,515,8,38,53,873,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3817,3804,3804,3805,3804,3807,3814,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.3,1020,SUCCESS
    1512,2021-07-01 17:47:43,6059.893,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26656,515,515,8,38,53,873,2352,65535,65535,244,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3817,3804,3804,3805,3805,3807,3815,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.3,1094,SUCCESS
    1513,2021-07-01 17:47:47,6063.901,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26657,514,515,8,38,53,874,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3818,3805,3804,3805,3805,3808,3815,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,980,SUCCESS
    1514,2021-07-01 17:47:51,6067.910,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26663,515,515,8,38,53,874,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3818,3805,3805,3806,3806,3808,3815,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.2,1030,SUCCESS
    1515,2021-07-01 17:47:55,6071.917,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26664,515,515,8,38,53,875,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3818,3805,3805,3806,3806,3808,3815,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.3,1085,SUCCESS
    1516,2021-07-01 17:47:59,6075.931,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26666,514,515,8,38,53,875,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3818,3806,3805,3806,3806,3809,3816,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,33.7,1000,SUCCESS
    1517,2021-07-01 17:48:03,6079.939,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26664,513,515,8,38,53,876,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3819,3806,3806,3807,3807,3808,3816,0,0,0,0,0,0,0,0,2945,25.1,25.2,-273.2,25.2,-273.2,34.3,1096,SUCCESS
    1518,2021-07-01 17:48:07,6083.939,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26670,515,515,8,38,53,877,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3819,3806,3806,3807,3807,3810,3817,0,0,0,0,0,0,0,0,2945,25.1,25.3,-273.2,25.3,-273.2,34.2,1111,SUCCESS
    1519,2021-07-01 17:48:11,6087.941,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26675,515,515,8,38,53,877,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3819,3807,3807,3807,3807,3810,3817,0,0,0,0,0,0,0,0,2945,25.1,25.3,-273.2,25.3,-273.2,34.3,1044,SUCCESS
    1520,2021-07-01 17:48:15,6091.946,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26676,515,515,8,38,53,878,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3820,3807,3807,3808,3807,3810,3817,0,0,0,0,0,0,0,0,2949,25.1,25.3,-273.2,25.3,-273.2,34.2,1009,SUCCESS
    1521,2021-07-01 17:48:19,6095.951,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26677,515,515,8,38,53,878,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3820,3807,3807,3808,3808,3810,3817,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,1035,SUCCESS
    1522,2021-07-01 17:48:23,6099.965,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26680,515,515,8,38,53,879,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3820,3808,3808,3808,3808,3811,3818,0,0,0,0,0,0,0,0,2950,25.1,25.2,-273.2,25.2,-273.2,34.3,1071,SUCCESS
    1523,2021-07-01 17:48:27,6103.966,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26683,515,515,8,38,53,879,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3821,3808,3808,3809,3808,3811,3818,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1008,SUCCESS
    1524,2021-07-01 17:48:31,6107.967,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26684,515,515,8,38,53,880,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3821,3808,3808,3809,3809,3811,3819,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,988,SUCCESS
    1525,2021-07-01 17:48:35,6111.975,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26687,514,515,8,38,53,881,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3821,3809,3808,3809,3809,3812,3819,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,33.5,1034,SUCCESS
    1526,2021-07-01 17:48:39,6115.985,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26690,514,515,8,38,53,881,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3822,3809,3809,3810,3809,3812,3819,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1065,SUCCESS
    1527,2021-07-01 17:48:43,6119.987,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26692,515,515,8,38,53,882,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3822,3809,3809,3810,3810,3812,3820,0,0,0,0,0,0,0,0,2950,25.1,25.2,-273.2,25.2,-273.2,34.2,1063,SUCCESS
    1528,2021-07-01 17:48:47,6123.998,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26695,515,515,8,38,53,882,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3822,3810,3810,3810,3810,3813,3820,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1051,SUCCESS
    1529,2021-07-01 17:48:51,6128.012,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26697,516,515,8,38,53,883,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3823,3810,3810,3811,3810,3813,3820,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,975,SUCCESS
    1530,2021-07-01 17:48:55,6132.018,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26698,516,515,8,38,53,883,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3823,3810,3810,3811,3811,3813,3820,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,1036,SUCCESS
    1531,2021-07-01 17:48:59,6136.029,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26701,515,515,8,38,54,884,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3823,3811,3811,3811,3811,3814,3820,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1036,SUCCESS
    1532,2021-07-01 17:49:03,6140.030,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26705,515,515,8,38,54,885,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3824,3811,3811,3812,3812,3814,3821,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,1034,SUCCESS
    1533,2021-07-01 17:49:07,6144.035,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26707,517,515,8,38,54,885,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3824,3811,3811,3812,3812,3814,3822,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,1030,SUCCESS
    1534,2021-07-01 17:49:11,6148.038,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26711,516,515,8,38,54,886,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3825,3812,3812,3812,3812,3815,3822,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1026,SUCCESS
    1535,2021-07-01 17:49:15,6152.052,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26712,516,515,8,38,54,886,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3825,3812,3812,3813,3813,3815,3822,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,981,SUCCESS
    1536,2021-07-01 17:49:19,6156.062,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26716,515,515,8,38,54,887,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3826,3813,3813,3813,3813,3816,3823,0,0,0,0,0,0,0,0,2950,25.1,25.2,-273.2,25.2,-273.2,34.3,1003,SUCCESS
    1537,2021-07-01 17:49:23,6160.072,0x0701,150,10,0x6001,0,65535,65535,1,25.2,26718,515,515,8,38,54,888,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3826,3813,3813,3814,3813,3816,3823,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1084,SUCCESS
    1538,2021-07-01 17:49:27,6164.081,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26718,516,515,8,38,54,888,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3826,3813,3813,3814,3814,3816,3823,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.2,1029,SUCCESS
    1539,2021-07-01 17:49:31,6168.091,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26721,515,515,8,38,54,889,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3826,3814,3814,3814,3814,3815,3823,0,0,0,0,0,0,0,0,2950,25.1,25.3,-273.2,25.3,-273.2,34.3,1052,SUCCESS
    1540,2021-07-01 17:49:35,6172.094,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26725,516,515,8,38,54,889,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3827,3814,3814,3814,3815,3817,3824,0,0,0,0,0,0,0,0,2954,25.1,25.3,-273.2,25.3,-273.2,34.3,1112,SUCCESS
    1541,2021-07-01 17:49:39,6176.109,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26727,515,515,8,38,54,890,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3827,3814,3814,3815,3815,3817,3825,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1095,SUCCESS
    1542,2021-07-01 17:49:43,6180.114,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26728,515,515,8,38,54,891,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3827,3814,3814,3815,3815,3818,3825,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,981,SUCCESS
    1543,2021-07-01 17:49:47,6184.126,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26732,515,515,8,38,54,891,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3828,3815,3815,3816,3815,3819,3825,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,1032,SUCCESS
    1544,2021-07-01 17:49:51,6188.137,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26733,515,515,8,38,54,892,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3828,3815,3815,3816,3816,3818,3825,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1022,SUCCESS
    1545,2021-07-01 17:49:55,6192.151,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26738,515,515,8,38,54,892,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3829,3816,3816,3816,3816,3819,3826,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,975,SUCCESS
    1546,2021-07-01 17:49:59,6196.159,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26739,516,515,8,38,54,893,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3829,3816,3816,3817,3816,3819,3826,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1030,SUCCESS
    1547,2021-07-01 17:50:03,6200.160,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26741,515,515,8,38,54,893,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3829,3817,3816,3817,3816,3820,3827,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,997,SUCCESS
    1548,2021-07-01 17:50:07,6204.164,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26743,515,515,8,39,54,894,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3830,3817,3817,3817,3816,3820,3827,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,950,SUCCESS
    1549,2021-07-01 17:50:11,6208.177,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26746,515,515,8,39,54,895,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3830,3817,3817,3818,3817,3820,3827,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,33.7,1036,SUCCESS
    1550,2021-07-01 17:50:15,6212.180,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26748,515,515,8,39,54,895,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3830,3818,3817,3818,3817,3820,3828,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,993,SUCCESS
    1551,2021-07-01 17:50:19,6216.184,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26752,515,515,8,39,54,896,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3830,3818,3818,3819,3818,3821,3828,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,1035,SUCCESS
    1552,2021-07-01 17:50:23,6220.195,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26753,516,515,8,39,54,896,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3831,3818,3818,3819,3818,3821,3828,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1043,SUCCESS
    1553,2021-07-01 17:50:27,6224.204,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26754,515,515,8,39,54,897,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3831,3819,3819,3819,3819,3821,3828,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,1127,SUCCESS
    1554,2021-07-01 17:50:31,6228.205,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26758,516,515,8,39,54,897,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3832,3819,3819,3820,3819,3821,3829,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,1066,SUCCESS
    1555,2021-07-01 17:50:35,6232.221,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26760,515,515,8,39,54,898,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3832,3819,3819,3820,3819,3822,3829,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.3,1064,SUCCESS
    1556,2021-07-01 17:50:39,6236.228,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26763,515,515,8,39,54,899,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3832,3820,3819,3820,3820,3823,3830,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1056,SUCCESS
    1557,2021-07-01 17:50:43,6240.237,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26766,515,515,8,39,54,899,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3833,3820,3820,3820,3820,3823,3830,0,0,0,0,0,0,0,0,2955,25.1,25.3,-273.2,25.3,-273.2,34.2,1045,SUCCESS
    1558,2021-07-01 17:50:47,6244.243,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26767,516,515,8,39,54,900,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3833,3820,3820,3821,3820,3823,3830,0,0,0,0,0,0,0,0,2959,25.1,25.3,-273.2,25.3,-273.2,34.3,994,SUCCESS
    1559,2021-07-01 17:50:51,6248.258,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26771,515,515,8,39,54,900,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3833,3821,3820,3821,3821,3824,3831,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,1042,SUCCESS
    1560,2021-07-01 17:50:55,6252.272,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26772,515,515,8,39,55,901,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3833,3821,3821,3822,3821,3824,3831,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,980,SUCCESS
    1561,2021-07-01 17:50:59,6256.324,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26774,515,515,8,39,55,901,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3834,3821,3821,3822,3822,3824,3831,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,990,SUCCESS
    1562,2021-07-01 17:51:03,6260.290,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26776,516,515,8,39,55,902,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3834,3821,3821,3822,3822,3824,3832,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,33.7,1061,SUCCESS
    1563,2021-07-01 17:51:07,6264.303,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26780,516,516,8,39,55,903,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3835,3822,3822,3822,3822,3825,3832,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,1000,SUCCESS
    1564,2021-07-01 17:51:11,6268.313,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26782,515,516,8,39,55,903,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3835,3822,3822,3823,3823,3825,3833,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,1046,SUCCESS
    1565,2021-07-01 17:51:15,6272.319,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26784,516,516,8,39,55,904,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3835,3823,3822,3824,3823,3826,3833,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,1028,SUCCESS
    1566,2021-07-01 17:51:19,6276.326,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26787,516,516,8,39,55,904,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3836,3823,3823,3824,3823,3826,3833,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,1082,SUCCESS
    1567,2021-07-01 17:51:23,6280.329,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26788,516,516,8,39,55,905,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3836,3824,3823,3824,3824,3826,3833,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,1141,SUCCESS
    1568,2021-07-01 17:51:27,6284.337,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26792,516,516,8,39,55,905,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3836,3824,3824,3824,3824,3826,3834,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,978,SUCCESS
    1569,2021-07-01 17:51:31,6288.349,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26793,516,516,8,39,55,906,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3836,3824,3824,3824,3824,3827,3834,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.2,1028,SUCCESS
    1570,2021-07-01 17:51:35,6292.364,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26794,516,516,8,39,55,907,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3837,3824,3824,3825,3825,3827,3834,0,0,0,0,0,0,0,0,2960,25.2,25.3,-273.2,25.3,-273.2,34.2,1048,SUCCESS
    1571,2021-07-01 17:51:39,6296.375,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26800,516,516,8,39,55,907,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3837,3825,3824,3825,3825,3829,3835,0,0,0,0,0,0,0,0,2960,25.2,25.3,-273.2,25.3,-273.2,34.3,971,SUCCESS
    1572,2021-07-01 17:51:43,6300.380,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26801,515,516,8,39,55,908,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3838,3825,3825,3825,3826,3828,3835,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,1076,SUCCESS
    1573,2021-07-01 17:51:47,6304.389,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26804,515,516,8,39,55,908,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3838,3825,3825,3826,3826,3829,3836,0,0,0,0,0,0,0,0,2960,25.1,25.3,-273.2,25.3,-273.2,34.3,1033,SUCCESS
    1574,2021-07-01 17:51:51,6308.400,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26806,515,516,8,39,55,909,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3838,3825,3825,3826,3826,3829,3836,0,0,0,0,0,0,0,0,2960,25.2,25.3,-273.2,25.3,-273.2,34.3,1007,SUCCESS
    1575,2021-07-01 17:51:55,6312.406,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26809,515,515,8,39,55,910,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3839,3826,3826,3827,3826,3829,3836,0,0,0,0,0,0,0,0,2960,25.2,25.3,-273.2,25.3,-273.2,34.3,1033,SUCCESS
    1576,2021-07-01 17:51:59,6316.414,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26811,516,515,8,39,55,910,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3839,3826,3826,3827,3827,3830,3837,0,0,0,0,0,0,0,0,2960,25.2,25.3,-273.2,25.3,-273.2,33.8,1049,SUCCESS
    1577,2021-07-01 17:52:03,6320.426,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26813,515,515,8,39,55,911,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3839,3827,3827,3827,3827,3830,3837,0,0,0,0,0,0,0,0,2964,25.2,25.3,-273.2,25.3,-273.2,34.3,982,SUCCESS
    1578,2021-07-01 17:52:07,6324.432,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26816,515,515,8,39,55,911,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3839,3827,3827,3828,3827,3830,3837,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1072,SUCCESS
    1579,2021-07-01 17:52:11,6328.441,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26816,515,515,8,39,55,912,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3840,3828,3827,3828,3827,3830,3837,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.2,1068,SUCCESS
    1580,2021-07-01 17:52:15,6332.455,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26820,515,515,8,39,55,912,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3841,3828,3828,3828,3828,3831,3838,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1030,SUCCESS
    1581,2021-07-01 17:52:19,6336.470,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26822,516,515,8,39,55,913,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3841,3828,3828,3829,3829,3831,3838,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.2,971,SUCCESS
    1582,2021-07-01 17:52:23,6340.485,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26825,515,515,8,39,55,914,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3841,3828,3828,3829,3829,3831,3839,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1018,SUCCESS
    1583,2021-07-01 17:52:27,6344.496,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26829,515,515,8,39,55,914,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3841,3829,3829,3830,3829,3832,3839,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1084,SUCCESS
    1584,2021-07-01 17:52:31,6348.504,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26830,517,515,8,39,55,915,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3842,3829,3829,3830,3829,3832,3839,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1036,SUCCESS
    1585,2021-07-01 17:52:35,6352.506,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26834,516,515,8,39,55,915,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3842,3830,3830,3830,3830,3832,3839,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1044,SUCCESS
    1586,2021-07-01 17:52:39,6356.519,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26835,517,516,8,39,55,916,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3842,3830,3830,3830,3830,3833,3840,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1046,SUCCESS
    1587,2021-07-01 17:52:43,6360.527,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26837,515,516,8,39,55,916,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3843,3830,3830,3831,3830,3833,3840,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1100,SUCCESS
    1588,2021-07-01 17:52:47,6364.536,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26838,515,516,8,39,56,917,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3843,3831,3830,3831,3831,3833,3841,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1029,SUCCESS
    1589,2021-07-01 17:52:51,6368.541,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26842,515,515,8,40,56,918,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3844,3831,3831,3831,3831,3834,3841,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.4,951,SUCCESS
    1590,2021-07-01 17:52:55,6372.552,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26844,515,515,8,40,56,918,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3844,3831,3831,3832,3832,3834,3841,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,33.7,955,SUCCESS
    1591,2021-07-01 17:52:59,6376.563,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26846,515,515,8,40,56,919,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3844,3832,3831,3832,3832,3835,3842,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1032,SUCCESS
    1592,2021-07-01 17:53:03,6380.575,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26850,514,515,8,40,56,919,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3845,3832,3832,3833,3832,3835,3842,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1053,SUCCESS
    1593,2021-07-01 17:53:07,6384.578,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26851,516,515,8,40,56,920,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3845,3833,3832,3833,3833,3835,3843,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,1032,SUCCESS
    1594,2021-07-01 17:53:11,6388.589,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26855,515,515,8,40,56,920,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3845,3833,3833,3833,3833,3835,3843,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.4,1039,SUCCESS
    1595,2021-07-01 17:53:15,6392.603,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26857,515,515,8,40,56,921,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3845,3833,3833,3834,3833,3836,3843,0,0,0,0,0,0,0,0,2965,25.2,25.3,-273.2,25.3,-273.2,34.3,946,SUCCESS
    1596,2021-07-01 17:53:19,6396.609,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26858,516,515,8,40,56,922,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3846,3833,3833,3834,3834,3836,3843,0,0,0,0,0,0,0,0,2969,25.2,25.3,-273.2,25.3,-273.2,34.3,1033,SUCCESS
    1597,2021-07-01 17:53:23,6400.619,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26862,516,516,8,40,56,922,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3846,3834,3833,3834,3834,3836,3844,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,960,SUCCESS
    1598,2021-07-01 17:53:27,6404.626,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26864,516,516,8,40,56,923,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3846,3834,3834,3835,3834,3836,3844,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1001,SUCCESS
    1599,2021-07-01 17:53:31,6408.640,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26867,516,516,8,40,56,923,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3847,3834,3834,3835,3835,3838,3844,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1049,SUCCESS
    1600,2021-07-01 17:53:35,6412.656,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26869,517,516,8,40,56,924,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3847,3835,3834,3836,3835,3838,3845,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,1050,SUCCESS
    1601,2021-07-01 17:53:39,6416.671,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26872,516,516,8,40,56,924,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3848,3835,3835,3836,3835,3838,3845,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1018,SUCCESS
    1602,2021-07-01 17:53:43,6420.673,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26873,516,516,8,40,56,925,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3848,3835,3835,3836,3836,3839,3846,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1061,SUCCESS
    1603,2021-07-01 17:53:47,6424.687,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26878,516,516,8,40,56,926,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3848,3836,3836,3836,3836,3840,3846,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,971,SUCCESS
    1604,2021-07-01 17:53:51,6428.697,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26879,516,516,8,40,56,926,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3849,3836,3836,3837,3836,3840,3846,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,1012,SUCCESS
    1605,2021-07-01 17:53:55,6432.699,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26880,516,516,8,40,56,927,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3849,3836,3836,3837,3837,3840,3847,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,1007,SUCCESS
    1606,2021-07-01 17:53:59,6436.702,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26883,515,516,8,40,56,927,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3849,3837,3837,3837,3837,3840,3847,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1052,SUCCESS
    1607,2021-07-01 17:54:03,6440.704,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26886,517,516,8,40,56,928,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3850,3837,3837,3838,3838,3840,3847,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1092,SUCCESS
    1608,2021-07-01 17:54:07,6444.715,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26887,515,516,8,40,56,929,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3850,3837,3837,3838,3838,3840,3848,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,977,SUCCESS
    1609,2021-07-01 17:54:11,6448.722,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26892,515,516,8,40,56,929,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3850,3838,3838,3839,3838,3841,3848,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,983,SUCCESS
    1610,2021-07-01 17:54:15,6452.737,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26893,516,516,8,40,56,930,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3851,3838,3838,3839,3838,3840,3848,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,1091,SUCCESS
    1611,2021-07-01 17:54:19,6456.745,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26896,516,516,8,40,56,930,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3851,3839,3839,3839,3839,3842,3849,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.3,1022,SUCCESS
    1612,2021-07-01 17:54:23,6460.759,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26899,515,516,8,40,56,931,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3852,3839,3839,3839,3839,3842,3849,0,0,0,0,0,0,0,0,2970,25.2,25.4,-273.2,25.4,-273.2,34.3,1029,SUCCESS
    1613,2021-07-01 17:54:27,6464.763,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26900,516,516,8,40,56,931,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3852,3839,3839,3840,3839,3842,3850,0,0,0,0,0,0,0,0,2970,25.2,25.4,-273.2,25.4,-273.2,33.7,1011,SUCCESS
    1614,2021-07-01 17:54:31,6468.770,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26902,516,516,8,40,56,932,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3852,3840,3840,3840,3840,3843,3850,0,0,0,0,0,0,0,0,2970,25.2,25.3,-273.2,25.3,-273.2,34.4,1107,SUCCESS
    1615,2021-07-01 17:54:35,6472.784,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26907,515,516,8,40,56,933,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3853,3840,3840,3840,3840,3843,3850,0,0,0,0,0,0,0,0,2971,25.2,25.4,-273.2,25.4,-273.2,34.2,1098,SUCCESS
    1616,2021-07-01 17:54:39,6476.793,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26909,516,516,8,40,56,933,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3853,3841,3840,3841,3841,3843,3851,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.3,1020,SUCCESS
    1617,2021-07-01 17:54:43,6480.797,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26911,516,516,8,40,57,934,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3853,3841,3840,3841,3841,3843,3851,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.3,987,SUCCESS
    1618,2021-07-01 17:54:47,6484.810,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26913,515,516,8,40,57,934,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3854,3841,3841,3842,3841,3844,3851,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.4,1035,SUCCESS
    1619,2021-07-01 17:54:51,6488.815,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26915,516,516,8,40,57,935,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3854,3841,3841,3842,3841,3844,3851,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.3,1046,SUCCESS
    1620,2021-07-01 17:54:55,6492.829,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26918,516,516,8,40,57,935,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3854,3842,3842,3842,3842,3844,3852,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,1082,SUCCESS
    1621,2021-07-01 17:54:59,6496.839,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26921,516,516,8,40,57,936,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3855,3842,3842,3842,3842,3845,3852,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,1054,SUCCESS
    1622,2021-07-01 17:55:03,6500.850,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26922,516,516,8,40,57,937,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3855,3842,3842,3843,3843,3845,3853,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,997,SUCCESS
    1623,2021-07-01 17:55:07,6504.865,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26926,516,516,8,40,57,937,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3855,3843,3843,3843,3843,3846,3853,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.4,1028,SUCCESS
    1624,2021-07-01 17:55:12,6508.872,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26928,516,516,8,40,57,938,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3856,3843,3843,3844,3843,3846,3853,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,1052,SUCCESS
    1625,2021-07-01 17:55:16,6512.876,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26931,516,516,8,40,57,938,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3856,3844,3844,3844,3844,3846,3854,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.3,1069,SUCCESS
    1626,2021-07-01 17:55:20,6516.890,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26933,516,516,8,40,57,939,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3856,3844,3844,3844,3844,3847,3854,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.4,1033,SUCCESS
    1627,2021-07-01 17:55:24,6520.897,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26935,517,516,8,40,57,939,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3857,3844,3844,3845,3844,3847,3854,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,33.8,1034,SUCCESS
    1628,2021-07-01 17:55:28,6524.898,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26938,516,516,8,40,57,940,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3857,3845,3844,3845,3844,3847,3854,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.3,993,SUCCESS
    1629,2021-07-01 17:55:32,6528.903,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26939,517,516,8,41,57,941,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3857,3845,3844,3845,3845,3848,3855,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.3,1004,SUCCESS
    1630,2021-07-01 17:55:36,6532.905,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26942,516,516,8,41,57,941,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3858,3845,3845,3846,3846,3848,3855,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,941,SUCCESS
    1631,2021-07-01 17:55:40,6536.912,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26944,516,516,8,41,57,942,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3858,3845,3845,3846,3846,3849,3856,0,0,0,0,0,0,0,0,2975,25.2,25.3,-273.2,25.3,-273.2,34.4,995,SUCCESS
    1632,2021-07-01 17:55:44,6540.925,0x0701,150,10,0x6001,0,65535,65535,1,25.3,26948,516,516,8,41,57,942,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3858,3846,3846,3847,3846,3849,3856,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.3,1030,SUCCESS
    1633,2021-07-01 17:55:48,6544.928,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26949,516,516,8,41,57,943,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3859,3846,3846,3847,3846,3849,3857,0,0,0,0,0,0,0,0,2975,25.2,25.4,-273.2,25.4,-273.2,34.4,1042,SUCCESS
    1634,2021-07-01 17:55:52,6548.939,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26953,516,516,8,41,57,943,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3859,3847,3846,3847,3847,3850,3857,0,0,0,0,0,0,0,0,2980,25.2,25.3,-273.2,25.3,-273.2,34.4,985,SUCCESS
    1635,2021-07-01 17:55:56,6552.951,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26954,516,516,8,41,57,944,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3859,3847,3847,3847,3847,3850,3857,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,988,SUCCESS
    1636,2021-07-01 17:56:00,6556.956,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26955,515,516,8,41,57,945,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3859,3847,3847,3848,3847,3850,3857,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,1046,SUCCESS
    1637,2021-07-01 17:56:04,6560.971,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26957,516,516,8,41,57,945,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3860,3848,3848,3848,3848,3850,3857,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,1094,SUCCESS
    1638,2021-07-01 17:56:08,6564.971,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26961,515,516,8,41,57,946,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3861,3848,3848,3848,3848,3851,3857,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,1046,SUCCESS
    1639,2021-07-01 17:56:12,6568.978,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26964,516,516,8,41,57,947,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3861,3848,3848,3849,3849,3851,3858,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,1008,SUCCESS
    1640,2021-07-01 17:56:16,6572.979,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26965,517,516,8,41,57,947,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3861,3848,3848,3849,3849,3851,3859,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,945,SUCCESS
    1641,2021-07-01 17:56:20,6576.984,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26969,516,516,8,41,57,948,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3861,3849,3849,3850,3849,3852,3859,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,1003,SUCCESS
    1642,2021-07-01 17:56:24,6580.986,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26970,515,516,8,41,57,948,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3862,3849,3849,3850,3850,3852,3859,0,0,0,0,0,0,0,0,2980,25.3,25.4,-273.2,25.4,-273.2,34.4,1086,SUCCESS
    1643,2021-07-01 17:56:28,6585.000,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26971,517,516,8,41,57,949,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3862,3850,3850,3850,3850,3853,3859,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,1064,SUCCESS
    1644,2021-07-01 17:56:32,6589.009,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26976,515,516,8,41,57,949,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3862,3850,3850,3851,3850,3853,3860,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,993,SUCCESS
    1645,2021-07-01 17:56:36,6593.013,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26976,516,516,8,41,57,950,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3863,3850,3850,3851,3851,3853,3860,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,958,SUCCESS
    1646,2021-07-01 17:56:40,6597.023,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26980,517,516,8,41,58,951,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3863,3850,3850,3851,3851,3854,3861,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,994,SUCCESS
    1647,2021-07-01 17:56:44,6601.038,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26983,515,516,8,41,58,951,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3864,3851,3851,3852,3851,3854,3861,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.4,1040,SUCCESS
    1648,2021-07-01 17:56:48,6605.039,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26985,515,516,8,41,58,952,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3864,3851,3851,3852,3852,3854,3861,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,994,SUCCESS
    1649,2021-07-01 17:56:52,6609.048,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26988,516,516,8,41,58,952,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3864,3852,3851,3852,3852,3855,3862,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,1077,SUCCESS
    1650,2021-07-01 17:56:56,6613.059,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26989,516,516,8,41,58,953,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3865,3852,3852,3852,3852,3855,3862,0,0,0,0,0,0,0,0,2980,25.2,25.4,-273.2,25.4,-273.2,34.3,1036,SUCCESS
    1651,2021-07-01 17:57:00,6617.070,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26992,516,516,8,41,58,953,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3865,3853,3852,3853,3853,3855,3862,0,0,0,0,0,0,0,0,2980,25.3,25.4,-273.2,25.4,-273.2,34.3,1016,SUCCESS
    1652,2021-07-01 17:57:04,6621.077,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26995,516,516,8,41,58,954,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3865,3853,3853,3853,3853,3856,3863,0,0,0,0,0,0,0,0,2980,25.3,25.4,-273.2,25.4,-273.2,34.3,1034,SUCCESS
    1653,2021-07-01 17:57:08,6625.080,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26997,516,516,8,41,58,955,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3865,3853,3853,3854,3853,3856,3863,0,0,0,0,0,0,0,0,2985,25.2,25.4,-273.2,25.4,-273.2,34.4,1062,SUCCESS
    1654,2021-07-01 17:57:12,6629.091,0x0701,150,10,0x6001,0,65535,65535,1,25.4,26997,517,516,8,41,58,955,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3866,3854,3853,3854,3853,3856,3863,0,0,0,0,0,0,0,0,2985,25.2,25.4,-273.2,25.4,-273.2,34.3,1097,SUCCESS
    1655,2021-07-01 17:57:16,6633.098,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27001,516,516,8,41,58,956,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3866,3854,3854,3854,3854,3857,3864,0,0,0,0,0,0,0,0,2985,25.2,25.4,-273.2,25.4,-273.2,34.4,983,SUCCESS
    1656,2021-07-01 17:57:20,6637.108,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27004,515,516,8,41,58,956,2352,65535,65535,234,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3867,3854,3854,3854,3855,3858,3864,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.3,1017,SUCCESS
    1657,2021-07-01 17:57:24,6641.110,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27004,516,516,8,41,58,957,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3867,3854,3854,3855,3855,3858,3865,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,969,SUCCESS
    1658,2021-07-01 17:57:28,6645.118,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27010,516,516,8,41,58,957,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3867,3855,3855,3856,3855,3858,3865,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1008,SUCCESS
    1659,2021-07-01 17:57:32,6649.126,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27011,516,516,8,41,58,958,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3868,3855,3855,3856,3855,3858,3865,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1031,SUCCESS
    1660,2021-07-01 17:57:36,6653.130,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27014,516,516,8,41,58,959,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3868,3856,3855,3856,3856,3858,3865,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,33.7,985,SUCCESS
    1661,2021-07-01 17:57:40,6657.146,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27017,516,516,8,41,58,959,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3868,3856,3855,3856,3856,3859,3866,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,981,SUCCESS
    1662,2021-07-01 17:57:44,6661.155,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27019,516,516,8,41,58,960,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3868,3856,3856,3857,3856,3859,3866,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1066,SUCCESS
    1663,2021-07-01 17:57:48,6665.167,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27020,516,516,8,41,58,960,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3868,3856,3856,3857,3857,3859,3866,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.3,960,SUCCESS
    1664,2021-07-01 17:57:52,6669.179,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27022,516,516,8,41,58,961,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3869,3857,3857,3857,3857,3859,3867,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1010,SUCCESS
    1665,2021-07-01 17:57:56,6673.180,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27025,516,516,8,41,58,961,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3870,3857,3857,3857,3858,3859,3867,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.3,1009,SUCCESS
    1666,2021-07-01 17:58:00,6677.181,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27028,517,516,8,41,58,962,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3870,3857,3857,3858,3858,3860,3868,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,978,SUCCESS
    1667,2021-07-01 17:58:04,6681.193,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27028,516,516,8,41,58,963,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3870,3858,3858,3859,3858,3860,3868,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1076,SUCCESS
    1668,2021-07-01 17:58:08,6685.207,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27032,517,516,8,41,58,963,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3870,3858,3858,3859,3858,3860,3868,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1029,SUCCESS
    1669,2021-07-01 17:58:12,6689.209,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27036,517,516,8,41,58,964,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3871,3859,3858,3859,3859,3861,3869,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1075,SUCCESS
    1670,2021-07-01 17:58:16,6693.218,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27038,516,516,8,41,58,964,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3871,3859,3859,3859,3859,3862,3869,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1097,SUCCESS
    1671,2021-07-01 17:58:20,6697.232,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27040,516,516,8,42,58,965,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3872,3859,3859,3860,3859,3862,3869,0,0,0,0,0,0,0,0,2985,25.3,25.4,-273.2,25.4,-273.2,34.4,1049,SUCCESS
    1672,2021-07-01 17:58:24,6701.247,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27041,516,516,8,42,58,965,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3872,3859,3859,3860,3860,3862,3869,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1035,SUCCESS
    1673,2021-07-01 17:58:28,6705.258,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27044,516,516,8,42,58,966,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3872,3860,3860,3860,3860,3862,3870,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.3,1046,SUCCESS
    1674,2021-07-01 17:58:32,6709.270,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27048,516,516,8,42,59,967,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3873,3860,3860,3861,3861,3863,3870,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,33.6,1003,SUCCESS
    1675,2021-07-01 17:58:36,6713.277,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27050,516,516,8,42,59,967,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3873,3860,3860,3861,3861,3863,3871,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,992,SUCCESS
    1676,2021-07-01 17:58:40,6717.287,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27051,516,516,8,42,59,968,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3873,3861,3860,3862,3861,3864,3871,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.3,997,SUCCESS
    1677,2021-07-01 17:58:44,6721.290,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27053,515,516,8,42,59,968,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3873,3861,3861,3862,3861,3864,3871,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1039,SUCCESS
    1678,2021-07-01 17:58:48,6725.294,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27056,517,516,8,42,59,969,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3874,3862,3861,3862,3862,3864,3872,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.3,1082,SUCCESS
    1679,2021-07-01 17:58:52,6729.296,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27059,516,516,8,42,59,970,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3875,3862,3862,3862,3862,3865,3872,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1052,SUCCESS
    1680,2021-07-01 17:58:56,6733.311,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27062,516,516,8,42,59,970,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3875,3862,3862,3863,3863,3865,3873,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,990,SUCCESS
    1681,2021-07-01 17:59:00,6737.315,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27064,516,516,8,42,59,971,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3875,3863,3862,3863,3863,3866,3873,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1045,SUCCESS
    1682,2021-07-01 17:59:04,6741.330,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27066,516,516,8,42,59,971,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3875,3863,3863,3863,3863,3866,3873,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1048,SUCCESS
    1683,2021-07-01 17:59:08,6745.333,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27069,516,516,8,42,59,972,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3875,3864,3863,3864,3864,3866,3874,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,998,SUCCESS
    1684,2021-07-01 17:59:12,6749.338,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27071,516,516,8,42,59,972,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3876,3864,3863,3864,3864,3866,3874,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1103,SUCCESS
    1685,2021-07-01 17:59:16,6753.338,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27072,516,516,8,42,59,973,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3876,3864,3864,3865,3864,3863,3874,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,975,SUCCESS
    1686,2021-07-01 17:59:20,6757.348,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27076,516,516,8,42,59,974,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3876,3864,3864,3865,3865,3867,3874,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1014,SUCCESS
    1687,2021-07-01 17:59:24,6761.360,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27078,515,516,8,42,59,974,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3877,3865,3865,3865,3865,3867,3875,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1080,SUCCESS
    1688,2021-07-01 17:59:28,6765.360,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27080,516,516,8,42,59,975,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3877,3865,3865,3865,3865,3868,3875,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1097,SUCCESS
    1689,2021-07-01 17:59:32,6769.365,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27083,516,516,8,42,59,975,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3878,3865,3865,3866,3865,3869,3876,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1075,SUCCESS
    1690,2021-07-01 17:59:36,6773.364,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27085,516,516,8,42,59,976,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3878,3865,3865,3866,3866,3870,3876,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1075,SUCCESS
    1691,2021-07-01 17:59:40,6777.378,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27087,516,516,8,42,59,976,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3878,3866,3866,3866,3866,3870,3876,0,0,0,0,0,0,0,0,2990,25.3,25.4,-273.2,25.4,-273.2,34.4,1093,SUCCESS
    1692,2021-07-01 17:59:44,6781.383,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27087,516,516,8,42,59,977,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3878,3866,3866,3866,3867,3871,3877,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1042,SUCCESS
    1693,2021-07-01 17:59:48,6785.392,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27092,516,516,8,42,59,978,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3879,3867,3867,3867,3867,3869,3877,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,33.9,992,SUCCESS
    1694,2021-07-01 17:59:52,6789.393,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27094,517,516,8,42,59,978,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3879,3867,3867,3868,3867,3870,3877,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1063,SUCCESS
    1695,2021-07-01 17:59:56,6793.403,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27096,517,516,8,42,59,979,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3879,3867,3867,3868,3868,3870,3877,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1020,SUCCESS
    1696,2021-07-01 18:00:00,6797.403,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27098,517,516,8,42,59,979,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3880,3868,3867,3868,3868,3870,3878,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1022,SUCCESS
    1697,2021-07-01 18:00:04,6801.412,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27101,518,516,8,42,59,980,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3880,3868,3868,3868,3869,3871,3878,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.5,1019,SUCCESS
    1698,2021-07-01 18:00:08,6805.417,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27103,515,516,8,42,59,980,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3880,3868,3868,3869,3869,3871,3879,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,961,SUCCESS
    1699,2021-07-01 18:00:12,6809.418,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27106,516,516,8,42,59,981,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3881,3868,3868,3869,3869,3872,3879,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.3,1058,SUCCESS
    1700,2021-07-01 18:00:16,6813.425,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27108,516,516,8,42,59,982,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3881,3869,3869,3870,3869,3872,3879,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1046,SUCCESS
    1701,2021-07-01 18:00:20,6817.432,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27111,517,516,8,42,59,982,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3881,3869,3869,3870,3870,3872,3879,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1037,SUCCESS
    1702,2021-07-01 18:00:24,6821.440,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27115,516,516,8,42,59,983,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3882,3870,3870,3870,3870,3873,3880,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,33.7,1082,SUCCESS
    1703,2021-07-01 18:00:28,6825.442,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27116,516,516,8,42,59,983,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3882,3870,3870,3871,3870,3873,3880,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,981,SUCCESS
    1704,2021-07-01 18:00:32,6829.442,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27117,516,516,8,42,60,984,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3882,3870,3870,3871,3871,3873,3880,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.5,1019,SUCCESS
    1705,2021-07-01 18:00:36,6833.456,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27119,516,516,8,42,60,984,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3883,3871,3870,3871,3871,3874,3881,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1093,SUCCESS
    1706,2021-07-01 18:00:40,6837.463,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27122,516,516,8,42,60,985,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3883,3871,3871,3871,3872,3874,3881,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1086,SUCCESS
    1707,2021-07-01 18:00:44,6841.464,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27126,515,516,8,42,60,986,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3884,3871,3871,3872,3872,3874,3882,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,991,SUCCESS
    1708,2021-07-01 18:00:48,6845.473,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27127,516,516,8,42,60,986,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3884,3871,3871,3872,3872,3875,3882,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.4,1044,SUCCESS
    1709,2021-07-01 18:00:52,6849.487,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27129,516,516,8,42,60,987,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3884,3871,3872,3873,3872,3875,3882,0,0,0,0,0,0,0,0,2995,25.3,25.4,-273.2,25.4,-273.2,34.3,1051,SUCCESS
    1710,2021-07-01 18:00:56,6853.495,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27131,516,516,8,42,60,987,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3884,3872,3872,3873,3873,3875,3882,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.3,943,SUCCESS
    1711,2021-07-01 18:01:00,6857.501,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27134,517,516,8,43,60,988,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3885,3873,3873,3873,3873,3876,3883,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.5,1131,SUCCESS
    1712,2021-07-01 18:01:04,6861.504,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27136,516,516,8,43,60,989,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3885,3873,3873,3874,3873,3876,3883,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,982,SUCCESS
    1713,2021-07-01 18:01:08,6865.514,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27137,516,516,8,43,60,989,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3885,3873,3873,3874,3874,3876,3883,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,939,SUCCESS
    1714,2021-07-01 18:01:12,6869.531,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27140,516,516,8,43,60,990,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3886,3873,3873,3874,3874,3876,3884,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.5,1112,SUCCESS
    1715,2021-07-01 18:01:16,6873.544,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27144,516,516,8,43,60,990,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3886,3874,3874,3874,3874,3877,3884,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.5,1069,SUCCESS
    1716,2021-07-01 18:01:20,6877.544,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27147,515,516,8,43,60,991,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3887,3874,3874,3875,3875,3878,3884,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1020,SUCCESS
    1717,2021-07-01 18:01:24,6881.546,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27147,517,516,8,43,60,992,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3887,3874,3874,3875,3875,3878,3885,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,986,SUCCESS
    1718,2021-07-01 18:01:28,6885.561,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27151,516,516,8,43,60,992,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3887,3875,3875,3876,3875,3878,3885,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,989,SUCCESS
    1719,2021-07-01 18:01:32,6889.566,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27151,517,516,8,43,60,993,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3887,3875,3875,3876,3876,3878,3885,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1060,SUCCESS
    1720,2021-07-01 18:01:36,6893.570,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27156,516,516,8,43,60,993,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3888,3876,3876,3876,3876,3879,3886,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,997,SUCCESS
    1721,2021-07-01 18:01:40,6897.580,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27158,517,516,8,43,60,994,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3888,3876,3876,3877,3876,3879,3886,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.2,1085,SUCCESS
    1722,2021-07-01 18:01:44,6901.595,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27159,516,516,8,43,60,994,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3888,3876,3876,3877,3877,3879,3886,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1062,SUCCESS
    1723,2021-07-01 18:01:48,6905.605,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27162,516,516,8,43,60,995,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3889,3877,3877,3877,3877,3879,3887,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.5,980,SUCCESS
    1724,2021-07-01 18:01:52,6909.606,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27165,516,516,8,43,60,996,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3890,3877,3877,3877,3877,3880,3887,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1036,SUCCESS
    1725,2021-07-01 18:01:56,6913.611,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27167,516,516,8,43,60,996,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3890,3877,3877,3878,3878,3880,3888,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.5,1031,SUCCESS
    1726,2021-07-01 18:02:00,6917.626,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27168,516,516,8,43,60,997,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3890,3877,3877,3878,3878,3880,3888,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1032,SUCCESS
    1727,2021-07-01 18:02:04,6921.633,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27171,516,516,8,43,60,997,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3890,3878,3878,3879,3878,3881,3888,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1047,SUCCESS
    1728,2021-07-01 18:02:08,6925.645,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27173,517,516,8,43,60,998,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3890,3878,3878,3879,3879,3881,3889,0,0,0,0,0,0,0,0,3000,25.3,25.4,-273.2,25.4,-273.2,34.4,1059,SUCCESS
    1729,2021-07-01 18:02:12,6929.657,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27177,516,516,8,43,60,998,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3891,3879,3879,3879,3879,3881,3889,0,0,0,0,0,0,0,0,3004,25.3,25.4,-273.2,25.4,-273.2,34.4,1143,SUCCESS
    1730,2021-07-01 18:02:16,6933.661,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27178,517,516,8,43,60,999,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3891,3879,3879,3880,3880,3882,3889,0,0,0,0,0,0,0,0,3005,25.3,25.4,-273.2,25.4,-273.2,34.4,1060,SUCCESS
    1731,2021-07-01 18:02:20,6937.673,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27181,517,516,8,43,60,1000,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3892,3879,3879,3880,3879,3882,3889,0,0,0,0,0,0,0,0,3005,25.3,25.4,-273.2,25.4,-273.2,34.4,1092,SUCCESS
    1732,2021-07-01 18:02:24,6941.679,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27183,517,517,8,43,60,1000,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3892,3879,3880,3880,3880,3882,3890,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1043,SUCCESS
    1733,2021-07-01 18:02:28,6945.679,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27185,517,517,8,43,61,1001,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3892,3880,3880,3880,3881,3883,3890,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1009,SUCCESS
    1734,2021-07-01 18:02:32,6949.687,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27188,517,517,8,43,61,1001,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3893,3880,3880,3881,3881,3883,3891,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1127,SUCCESS
    1735,2021-07-01 18:02:36,6953.692,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27189,516,517,8,43,61,1002,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3893,3880,3880,3881,3881,3884,3891,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1060,SUCCESS
    1736,2021-07-01 18:02:40,6957.707,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27193,515,516,8,43,61,1002,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3893,3881,3881,3882,3882,3884,3891,0,0,0,0,0,0,0,0,3005,25.3,25.4,-273.2,25.4,-273.2,34.4,981,SUCCESS
    1737,2021-07-01 18:02:44,6961.713,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27195,516,516,8,43,61,1003,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3894,3881,3881,3882,3882,3884,3891,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1023,SUCCESS
    1738,2021-07-01 18:02:48,6965.720,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27197,516,516,8,43,61,1004,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3894,3881,3882,3882,3882,3884,3892,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1097,SUCCESS
    1739,2021-07-01 18:02:52,6969.732,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27198,516,516,8,43,61,1004,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3894,3882,3882,3882,3882,3885,3892,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,974,SUCCESS
    1740,2021-07-01 18:02:56,6973.736,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27200,516,516,8,43,61,1005,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3894,3882,3882,3883,3882,3885,3892,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1078,SUCCESS
    1741,2021-07-01 18:03:00,6977.742,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27202,516,516,8,43,61,1005,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3895,3882,3882,3883,3883,3885,3893,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.5,1018,SUCCESS
    1742,2021-07-01 18:03:04,6981.753,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27207,515,516,8,43,61,1006,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3895,3883,3883,3883,3884,3886,3893,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1079,SUCCESS
    1743,2021-07-01 18:03:08,6985.759,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27207,516,516,8,43,61,1006,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3896,3883,3883,3884,3884,3885,3894,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1055,SUCCESS
    1744,2021-07-01 18:03:12,6989.763,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27208,516,516,8,43,61,1007,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3896,3883,3883,3884,3884,3886,3894,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,991,SUCCESS
    1745,2021-07-01 18:03:16,6993.764,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27211,517,516,8,43,61,1008,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3896,3884,3884,3885,3885,3887,3894,0,0,0,0,0,0,0,0,3005,25.3,25.4,-273.2,25.4,-273.2,34.4,947,SUCCESS
    1746,2021-07-01 18:03:20,6997.770,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27216,516,516,8,43,61,1008,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3897,3884,3884,3885,3885,3888,3894,0,0,0,0,0,0,0,0,3005,25.4,25.5,-273.2,25.5,-273.2,34.4,1068,SUCCESS
    1747,2021-07-01 18:03:24,7001.779,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27216,516,516,8,43,61,1009,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3897,3885,3885,3885,3885,3887,3895,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.4,1004,SUCCESS
    1748,2021-07-01 18:03:28,7005.793,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27220,517,516,8,43,61,1009,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3897,3885,3885,3885,3885,3888,3895,0,0,0,0,0,0,0,0,3005,25.4,25.4,-273.2,25.4,-273.2,34.5,1037,SUCCESS
    1749,2021-07-01 18:03:32,7009.808,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27224,516,516,8,43,61,1010,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3898,3885,3885,3886,3885,3888,3895,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.0,1060,SUCCESS
    1750,2021-07-01 18:03:36,7013.817,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27226,516,516,8,43,61,1011,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3898,3885,3885,3886,3886,3888,3896,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1059,SUCCESS
    1751,2021-07-01 18:03:40,7017.820,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27230,517,516,8,43,61,1011,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3898,3886,3886,3886,3886,3889,3896,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1009,SUCCESS
    1752,2021-07-01 18:03:44,7021.829,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27234,516,516,8,44,61,1012,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3898,3886,3886,3887,3887,3889,3896,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.4,1048,SUCCESS
    1753,2021-07-01 18:03:48,7025.833,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27231,517,516,8,44,61,1012,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3899,3886,3886,3887,3887,3890,3896,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.4,949,SUCCESS
    1754,2021-07-01 18:03:52,7029.837,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27234,516,516,8,44,61,1013,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3899,3887,3887,3888,3887,3890,3897,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.5,994,SUCCESS
    1755,2021-07-01 18:03:56,7033.843,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27235,516,516,8,44,61,1013,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3899,3887,3887,3888,3888,3890,3897,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1000,SUCCESS
    1756,2021-07-01 18:04:00,7037.857,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27237,516,516,8,44,61,1014,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3900,3887,3887,3888,3888,3890,3897,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1052,SUCCESS
    1757,2021-07-01 18:04:04,7041.862,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27239,516,516,8,44,61,1015,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3900,3888,3888,3888,3888,3890,3898,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1123,SUCCESS
    1758,2021-07-01 18:04:09,7045.869,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27244,516,516,8,44,61,1015,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3901,3888,3888,3889,3888,3890,3898,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.5,964,SUCCESS
    1759,2021-07-01 18:04:13,7049.887,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27245,517,516,8,44,61,1016,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3901,3888,3888,3889,3889,3891,3899,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.5,973,SUCCESS
    1760,2021-07-01 18:04:17,7053.903,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27246,518,516,8,44,61,1016,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3901,3888,3888,3889,3889,3892,3899,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,958,SUCCESS
    1761,2021-07-01 18:04:21,7057.904,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27250,517,516,8,44,62,1017,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3901,3889,3889,3889,3890,3892,3899,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1021,SUCCESS
    1762,2021-07-01 18:04:25,7061.908,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27251,517,516,8,44,62,1017,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3902,3890,3889,3890,3890,3892,3899,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1015,SUCCESS
    1763,2021-07-01 18:04:29,7065.918,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27255,516,517,8,44,62,1018,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3902,3890,3890,3890,3890,3893,3900,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.1,955,SUCCESS
    1764,2021-07-01 18:04:33,7069.918,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27257,517,517,8,44,62,1019,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3902,3890,3890,3891,3891,3893,3900,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.5,1038,SUCCESS
    1765,2021-07-01 18:04:37,7073.923,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27258,517,517,8,44,62,1019,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3903,3890,3891,3891,3891,3893,3900,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1031,SUCCESS
    1766,2021-07-01 18:04:41,7077.938,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27260,518,517,8,44,62,1020,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3903,3891,3891,3891,3891,3893,3901,0,0,0,0,0,0,0,0,3010,25.4,25.4,-273.2,25.4,-273.2,34.4,1064,SUCCESS
    1767,2021-07-01 18:04:45,7081.945,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27263,516,517,8,44,62,1020,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3903,3891,3891,3891,3892,3894,3901,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.5,962,SUCCESS
    1768,2021-07-01 18:04:49,7085.952,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27265,517,517,8,44,62,1021,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3904,3891,3891,3892,3892,3894,3901,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.4,1052,SUCCESS
    1769,2021-07-01 18:04:53,7089.960,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27267,517,517,8,44,62,1021,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3904,3891,3891,3892,3892,3895,3902,0,0,0,0,0,0,0,0,3010,25.4,25.5,-273.2,25.5,-273.2,34.5,1015,SUCCESS
    1770,2021-07-01 18:04:57,7093.960,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27270,516,517,8,44,62,1022,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3904,3892,3892,3892,3892,3894,3902,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1042,SUCCESS
    1771,2021-07-01 18:05:01,7097.966,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27272,517,517,8,44,62,1023,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3905,3892,3892,3893,3893,3895,3902,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1005,SUCCESS
    1772,2021-07-01 18:05:05,7101.975,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27275,515,517,8,44,62,1023,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3905,3893,3893,3893,3893,3893,3903,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1011,SUCCESS
    1773,2021-07-01 18:05:09,7105.988,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27277,516,516,8,44,62,1024,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3905,3893,3893,3894,3893,3894,3903,0,0,0,0,0,0,0,0,3015,25.4,25.4,-273.2,25.4,-273.2,34.4,1060,SUCCESS
    1774,2021-07-01 18:05:13,7109.997,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27279,517,517,8,44,62,1024,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3906,3893,3893,3894,3894,3896,3903,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1067,SUCCESS
    1775,2021-07-01 18:05:17,7114.009,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27280,517,517,8,44,62,1025,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3906,3894,3894,3894,3895,3897,3904,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1009,SUCCESS
    1776,2021-07-01 18:05:21,7118.020,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27284,516,516,8,44,62,1026,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3906,3894,3894,3894,3894,3898,3904,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1107,SUCCESS
    1777,2021-07-01 18:05:25,7122.028,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27287,516,516,8,44,62,1026,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3907,3894,3894,3895,3895,3897,3904,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.3,1060,SUCCESS
    1778,2021-07-01 18:05:29,7126.030,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27288,516,516,8,44,62,1027,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3907,3894,3894,3895,3895,3900,3905,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1112,SUCCESS
    1779,2021-07-01 18:05:33,7130.030,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27290,517,516,8,44,62,1027,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3907,3894,3895,3895,3895,3901,3905,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1033,SUCCESS
    1780,2021-07-01 18:05:37,7134.033,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27292,517,516,8,44,62,1028,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3907,3895,3895,3896,3896,3903,3905,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1109,SUCCESS
    1781,2021-07-01 18:05:41,7138.045,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27296,516,516,8,44,62,1028,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3908,3896,3896,3896,3896,3898,3906,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1035,SUCCESS
    1782,2021-07-01 18:05:45,7142.045,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27296,516,516,8,44,62,1029,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3908,3896,3896,3896,3896,3899,3906,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1049,SUCCESS
    1783,2021-07-01 18:05:49,7146.047,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27298,517,516,8,44,62,1030,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3908,3896,3896,3897,3897,3899,3906,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,1002,SUCCESS
    1784,2021-07-01 18:05:53,7150.053,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27300,516,517,8,44,62,1030,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3909,3896,3897,3897,3897,3899,3906,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1076,SUCCESS
    1785,2021-07-01 18:05:57,7154.063,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27303,517,517,8,44,62,1031,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3909,3897,3897,3897,3897,3899,3907,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1019,SUCCESS
    1786,2021-07-01 18:06:01,7158.072,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27307,516,517,8,44,62,1031,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3910,3897,3897,3897,3898,3900,3907,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.5,977,SUCCESS
    1787,2021-07-01 18:06:05,7162.086,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27308,516,517,8,44,62,1032,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3910,3897,3897,3898,3898,3901,3908,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,1025,SUCCESS
    1788,2021-07-01 18:06:09,7166.088,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27310,516,516,8,44,62,1033,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3910,3897,3898,3898,3898,3901,3908,0,0,0,0,0,0,0,0,3015,25.4,25.5,-273.2,25.5,-273.2,34.4,944,SUCCESS
    1789,2021-07-01 18:06:13,7170.103,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27313,516,516,8,44,62,1033,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3910,3898,3898,3899,3899,3901,3908,0,0,0,0,0,0,0,0,3019,25.4,25.5,-273.2,25.5,-273.2,34.5,961,SUCCESS
    1790,2021-07-01 18:06:17,7174.118,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27315,517,516,8,44,63,1034,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3911,3898,3899,3899,3899,3901,3909,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,993,SUCCESS
    1791,2021-07-01 18:06:21,7178.118,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27316,517,516,8,44,63,1034,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3911,3899,3899,3899,3899,3902,3909,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,962,SUCCESS
    1792,2021-07-01 18:06:25,7182.127,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27319,516,516,8,45,63,1035,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3911,3899,3899,3900,3899,3902,3909,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1078,SUCCESS
    1793,2021-07-01 18:06:29,7186.137,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27321,517,516,8,45,63,1035,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3912,3899,3899,3900,3900,3902,3909,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,1023,SUCCESS
    1794,2021-07-01 18:06:33,7190.147,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27324,516,516,8,45,63,1036,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3912,3900,3900,3900,3900,3902,3910,0,0,0,0,0,0,0,0,3020,25.4,25.4,-273.2,25.5,-273.2,34.5,995,SUCCESS
    1795,2021-07-01 18:06:37,7194.160,0x0701,150,10,0x6001,0,65535,65535,1,25.4,27327,516,516,8,45,63,1037,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3913,3900,3900,3901,3901,3903,3910,0,0,0,0,0,0,0,0,3020,25.4,25.4,-273.2,25.4,-273.2,34.5,1045,SUCCESS
    1796,2021-07-01 18:06:41,7198.172,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27329,517,517,8,45,63,1037,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3913,3900,3900,3901,3901,3903,3911,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1049,SUCCESS
    1797,2021-07-01 18:06:45,7202.181,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27329,517,517,8,45,63,1038,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3913,3900,3900,3901,3901,3903,3911,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,960,SUCCESS
    1798,2021-07-01 18:06:49,7206.195,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27333,517,517,8,45,63,1038,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3913,3901,3901,3902,3902,3904,3911,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1026,SUCCESS
    1799,2021-07-01 18:06:53,7210.205,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27335,516,517,8,45,63,1039,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3914,3901,3901,3902,3902,3904,3911,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1015,SUCCESS
    1800,2021-07-01 18:06:57,7214.220,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27338,517,517,8,45,63,1039,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3914,3902,3902,3902,3902,3905,3912,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,33.7,1039,SUCCESS
    1801,2021-07-01 18:07:01,7218.221,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27339,516,517,8,45,63,1040,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3914,3902,3902,3903,3902,3905,3912,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1124,SUCCESS
    1802,2021-07-01 18:07:05,7222.224,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27341,516,517,8,45,63,1041,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3914,3902,3902,3903,3903,3905,3912,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,1048,SUCCESS
    1803,2021-07-01 18:07:09,7226.237,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27344,518,516,8,45,63,1041,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3915,3902,3903,3903,3903,3905,3913,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,1093,SUCCESS
    1804,2021-07-01 18:07:13,7230.246,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27346,517,517,8,45,63,1042,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3916,3903,3903,3904,3904,3906,3913,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1083,SUCCESS
    1805,2021-07-01 18:07:17,7234.250,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27349,516,516,8,45,63,1042,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3916,3903,3903,3904,3904,3906,3914,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1079,SUCCESS
    1806,2021-07-01 18:07:21,7238.251,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27350,516,516,8,45,63,1043,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3916,3903,3904,3905,3904,3907,3914,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,1093,SUCCESS
    1807,2021-07-01 18:07:25,7242.254,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27354,516,516,8,45,63,1043,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3916,3903,3904,3905,3904,3907,3914,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.5,1044,SUCCESS
    1808,2021-07-01 18:07:29,7246.264,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27354,516,516,8,45,63,1044,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3917,3904,3904,3905,3904,3907,3914,0,0,0,0,0,0,0,0,3020,25.4,25.5,-273.2,25.5,-273.2,34.4,1037,SUCCESS
    1809,2021-07-01 18:07:33,7250.275,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27358,516,516,8,45,63,1045,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3917,3904,3904,3905,3905,3907,3915,0,0,0,0,0,0,0,0,3024,25.4,25.5,-273.2,25.5,-273.2,33.9,998,SUCCESS
    1810,2021-07-01 18:07:37,7254.276,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27359,516,516,8,45,63,1045,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3917,3905,3905,3905,3905,3907,3915,0,0,0,0,0,0,0,0,3024,25.4,25.5,-273.2,25.5,-273.2,34.5,1037,SUCCESS
    1811,2021-07-01 18:07:41,7258.286,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27361,516,516,8,45,63,1046,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3917,3905,3905,3906,3905,3908,3915,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,997,SUCCESS
    1812,2021-07-01 18:07:45,7262.297,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27363,516,516,8,45,63,1046,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3918,3905,3905,3906,3906,3908,3915,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.4,1047,SUCCESS
    1813,2021-07-01 18:07:49,7266.302,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27366,516,516,8,45,63,1047,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3918,3905,3906,3906,3906,3908,3916,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1030,SUCCESS
    1814,2021-07-01 18:07:53,7270.322,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27370,516,516,8,45,63,1047,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3919,3906,3906,3907,3907,3909,3916,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,992,SUCCESS
    1815,2021-07-01 18:07:57,7274.332,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27371,515,516,8,45,63,1048,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3919,3906,3906,3907,3907,3909,3917,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.4,1073,SUCCESS
    1816,2021-07-01 18:08:01,7278.335,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27372,516,516,8,45,63,1049,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3919,3906,3907,3908,3907,3910,3917,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.4,996,SUCCESS
    1817,2021-07-01 18:08:05,7282.342,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27375,517,516,8,45,63,1049,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3919,3907,3907,3908,3907,3910,3917,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1002,SUCCESS
    1818,2021-07-01 18:08:09,7286.345,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27377,516,516,8,45,63,1050,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3920,3907,3907,3908,3908,3910,3917,0,0,0,0,0,0,0,0,3025,25.4,25.6,-273.2,25.6,-273.2,34.6,1069,SUCCESS
    1819,2021-07-01 18:08:13,7290.357,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27380,516,516,8,45,63,1050,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3920,3908,3908,3908,3908,3910,3918,0,0,0,0,0,0,0,0,3025,25.4,25.6,-273.2,25.6,-273.2,34.5,1019,SUCCESS
    1820,2021-07-01 18:08:17,7294.361,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27383,516,516,8,45,64,1051,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3920,3908,3908,3909,3908,3911,3918,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1110,SUCCESS
    1821,2021-07-01 18:08:21,7298.374,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27384,516,516,8,45,64,1052,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3921,3908,3908,3909,3909,3911,3918,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1083,SUCCESS
    1822,2021-07-01 18:08:25,7302.386,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27385,516,516,8,45,64,1052,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3921,3909,3909,3909,3909,3911,3919,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1083,SUCCESS
    1823,2021-07-01 18:08:29,7306.397,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27386,516,516,8,45,64,1053,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3921,3909,3909,3909,3909,3911,3919,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,33.8,1114,SUCCESS
    1824,2021-07-01 18:08:33,7310.400,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27390,516,516,8,45,64,1053,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3922,3909,3909,3910,3910,3912,3920,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,975,SUCCESS
    1825,2021-07-01 18:08:37,7314.416,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27392,517,516,8,45,64,1054,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3922,3909,3909,3910,3910,3912,3920,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1041,SUCCESS
    1826,2021-07-01 18:08:41,7318.428,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27393,516,516,8,45,64,1054,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3922,3909,3910,3911,3910,3912,3920,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1041,SUCCESS
    1827,2021-07-01 18:08:45,7322.431,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27396,517,516,8,45,64,1055,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3923,3910,3910,3911,3911,3913,3920,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,976,SUCCESS
    1828,2021-07-01 18:08:49,7326.440,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27397,516,516,8,45,64,1056,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3923,3910,3910,3911,3911,3913,3921,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.5,1109,SUCCESS
    1829,2021-07-01 18:08:53,7330.444,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27402,516,516,8,45,64,1056,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3923,3911,3911,3911,3911,3913,3921,0,0,0,0,0,0,0,0,3025,25.4,25.5,-273.2,25.5,-273.2,34.4,1034,SUCCESS
    1830,2021-07-01 18:08:57,7334.448,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27404,516,516,8,45,64,1057,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3924,3911,3911,3912,3912,3914,3921,0,0,0,0,0,0,0,0,3029,25.4,25.6,-273.2,25.6,-273.2,34.5,992,SUCCESS
    1831,2021-07-01 18:09:01,7338.455,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27407,517,516,8,45,64,1057,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3924,3911,3911,3912,3912,3914,3922,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.4,1015,SUCCESS
    1832,2021-07-01 18:09:05,7342.458,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27409,516,516,8,45,64,1058,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3924,3912,3912,3912,3912,3915,3922,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,1091,SUCCESS
    1833,2021-07-01 18:09:09,7346.470,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27409,516,516,8,46,64,1059,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3924,3912,3912,3912,3913,3916,3922,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,970,SUCCESS
    1834,2021-07-01 18:09:13,7350.470,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27412,517,516,8,46,64,1059,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3925,3912,3912,3913,3913,3915,3922,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.4,1064,SUCCESS
    1835,2021-07-01 18:09:17,7354.482,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27414,517,516,8,46,64,1060,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3925,3913,3912,3913,3913,3916,3923,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.5,974,SUCCESS
    1836,2021-07-01 18:09:21,7358.487,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27417,516,516,8,46,64,1060,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3925,3913,3913,3913,3913,3916,3923,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.5,1016,SUCCESS
    1837,2021-07-01 18:09:25,7362.492,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27419,516,516,8,46,64,1061,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3925,3913,3913,3914,3914,3916,3923,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.5,976,SUCCESS
    1838,2021-07-01 18:09:29,7366.495,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27419,516,516,8,46,64,1061,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3926,3913,3913,3914,3914,3916,3924,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.4,1022,SUCCESS
    1839,2021-07-01 18:09:33,7370.496,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27421,517,516,8,46,64,1062,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3926,3914,3914,3914,3914,3916,3924,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.4,1038,SUCCESS
    1840,2021-07-01 18:09:37,7374.510,0x0701,150,10,0x6001,0,65535,65535,1,25.5,27425,516,516,8,46,64,1063,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3927,3914,3914,3915,3915,3917,3925,0,0,0,0,0,0,0,0,3030,25.4,25.5,-273.2,25.5,-273.2,34.4,1085,SUCCESS
    1841,2021-07-01 18:09:41,7378.526,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27427,516,516,8,46,64,1063,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3927,3914,3914,3915,3915,3918,3925,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.6,1064,SUCCESS
    1842,2021-07-01 18:09:45,7382.533,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27430,516,516,8,46,64,1064,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3927,3915,3915,3915,3915,3918,3925,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,1050,SUCCESS
    1843,2021-07-01 18:09:49,7386.547,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27432,516,516,8,46,64,1064,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3927,3915,3915,3916,3916,3918,3925,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,1066,SUCCESS
    1844,2021-07-01 18:09:53,7390.551,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27433,516,516,8,46,64,1065,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3928,3915,3916,3916,3916,3918,3926,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.6,1075,SUCCESS
    1845,2021-07-01 18:09:57,7394.555,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27437,515,516,8,46,64,1065,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3928,3916,3916,3916,3916,3918,3926,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.6,1058,SUCCESS
    1846,2021-07-01 18:10:01,7398.566,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27438,516,516,8,46,64,1066,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3928,3916,3916,3917,3917,3919,3926,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.2,1026,SUCCESS
    1847,2021-07-01 18:10:05,7402.571,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27440,516,516,8,46,65,1067,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3929,3916,3916,3917,3917,3919,3926,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,962,SUCCESS
    1848,2021-07-01 18:10:09,7406.585,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27441,516,516,8,46,65,1067,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3929,3916,3917,3917,3917,3919,3927,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,995,SUCCESS
    1849,2021-07-01 18:10:13,7410.597,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27443,516,516,8,46,65,1068,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3930,3917,3917,3918,3918,3919,3927,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.4,1052,SUCCESS
    1850,2021-07-01 18:10:17,7414.608,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27448,515,516,8,46,65,1068,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3930,3917,3917,3918,3917,3919,3928,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,1035,SUCCESS
    1851,2021-07-01 18:10:21,7418.610,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27448,515,516,8,46,65,1069,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3930,3917,3917,3918,3918,3919,3928,0,0,0,0,0,0,0,0,3030,25.4,25.6,-273.2,25.6,-273.2,34.5,1017,SUCCESS
    1852,2021-07-01 18:10:25,7422.619,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27451,517,516,8,46,65,1069,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3930,3918,3918,3919,3918,3920,3928,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1007,SUCCESS
    1853,2021-07-01 18:10:29,7426.632,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27454,515,516,8,46,65,1070,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3930,3918,3918,3919,3919,3921,3928,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,980,SUCCESS
    1854,2021-07-01 18:10:33,7430.640,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27456,515,516,8,46,65,1071,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3931,3919,3919,3919,3919,3922,3929,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,972,SUCCESS
    1855,2021-07-01 18:10:37,7434.643,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27458,516,516,8,46,65,1071,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3931,3919,3919,3919,3919,3922,3929,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.6,1021,SUCCESS
    1856,2021-07-01 18:10:41,7438.648,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27459,515,516,8,46,65,1072,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3931,3919,3919,3920,3919,3922,3929,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1042,SUCCESS
    1857,2021-07-01 18:10:45,7442.656,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27461,517,516,8,46,65,1072,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3932,3919,3919,3920,3920,3924,3929,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1081,SUCCESS
    1858,2021-07-01 18:10:49,7446.659,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27464,515,516,8,46,65,1073,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3932,3919,3920,3920,3920,3922,3930,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.4,988,SUCCESS
    1859,2021-07-01 18:10:53,7450.669,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27467,516,516,8,46,65,1074,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3932,3920,3920,3920,3921,3923,3930,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1049,SUCCESS
    1860,2021-07-01 18:10:57,7454.669,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27469,516,516,8,46,65,1074,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3933,3920,3920,3921,3921,3923,3931,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1134,SUCCESS
    1861,2021-07-01 18:11:01,7458.682,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27469,515,516,8,46,65,1075,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3933,3920,3921,3922,3921,3924,3931,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.4,1006,SUCCESS
    1862,2021-07-01 18:11:05,7462.697,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27473,516,516,8,46,65,1075,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3933,3921,3921,3922,3921,3924,3931,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.6,1037,SUCCESS
    1863,2021-07-01 18:11:09,7466.709,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27474,516,516,8,46,65,1076,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3934,3921,3921,3922,3922,3924,3931,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1028,SUCCESS
    1864,2021-07-01 18:11:13,7470.723,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27477,516,516,8,46,65,1076,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3934,3921,3922,3922,3922,3924,3932,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.6,1013,SUCCESS
    1865,2021-07-01 18:11:17,7474.734,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27478,516,516,8,46,65,1077,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3934,3922,3922,3922,3922,3924,3932,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1126,SUCCESS
    1866,2021-07-01 18:11:21,7478.745,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27479,516,516,8,46,65,1078,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3934,3922,3922,3923,3922,3924,3932,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1052,SUCCESS
    1867,2021-07-01 18:11:25,7482.751,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27482,515,516,8,46,65,1078,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3935,3922,3923,3923,3923,3925,3932,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1048,SUCCESS
    1868,2021-07-01 18:11:29,7486.758,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27485,516,516,8,46,65,1079,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3935,3923,3923,3923,3923,3925,3933,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,978,SUCCESS
    1869,2021-07-01 18:11:33,7490.764,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27488,516,516,8,46,65,1079,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3936,3923,3923,3924,3924,3926,3933,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,33.8,1007,SUCCESS
    1870,2021-07-01 18:11:37,7494.766,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27489,516,516,8,46,65,1080,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3936,3923,3923,3924,3924,3926,3934,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1093,SUCCESS
    1871,2021-07-01 18:11:41,7498.777,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27491,516,516,8,46,65,1080,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3936,3923,3924,3925,3924,3927,3934,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,1008,SUCCESS
    1872,2021-07-01 18:11:45,7502.791,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27494,515,516,8,46,65,1081,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3936,3924,3924,3925,3924,3927,3934,0,0,0,0,0,0,0,0,3035,25.4,25.6,-273.2,25.6,-273.2,34.5,960,SUCCESS
    1873,2021-07-01 18:11:49,7506.796,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27496,516,516,8,47,65,1082,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3937,3924,3924,3925,3925,3927,3934,0,0,0,0,0,0,0,0,3036,25.4,25.6,-273.2,25.6,-273.2,34.6,996,SUCCESS
    1874,2021-07-01 18:11:53,7510.803,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27498,516,516,8,47,65,1082,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3937,3925,3925,3925,3925,3927,3934,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1041,SUCCESS
    1875,2021-07-01 18:11:57,7514.827,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27501,516,516,8,47,65,1083,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3937,3925,3925,3926,3925,3928,3935,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1080,SUCCESS
    1876,2021-07-01 18:12:01,7518.835,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27501,516,516,8,47,65,1083,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3938,3925,3925,3926,3925,3928,3935,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.6,996,SUCCESS
    1877,2021-07-01 18:12:05,7522.844,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27504,516,516,8,47,66,1084,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3938,3925,3926,3926,3926,3928,3935,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1032,SUCCESS
    1878,2021-07-01 18:12:09,7526.845,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27506,516,516,8,47,66,1084,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3938,3926,3926,3926,3926,3928,3935,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1033,SUCCESS
    1879,2021-07-01 18:12:13,7530.859,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27508,516,516,8,47,66,1085,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3939,3926,3926,3927,3927,3928,3936,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1051,SUCCESS
    1880,2021-07-01 18:12:17,7534.865,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27511,516,516,8,47,66,1086,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3939,3926,3926,3927,3927,3929,3936,0,0,0,0,0,0,0,0,3040,25.5,25.6,-273.2,25.6,-273.2,34.5,1019,SUCCESS
    1881,2021-07-01 18:12:22,7538.876,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27512,516,516,8,47,66,1086,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3939,3926,3927,3927,3927,3930,3937,0,0,0,0,0,0,0,0,3040,25.5,25.6,-273.2,25.6,-273.2,34.5,1053,SUCCESS
    1882,2021-07-01 18:12:26,7542.887,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27515,515,516,8,47,66,1087,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3939,3927,3927,3928,3928,3930,3937,0,0,0,0,0,0,0,0,3040,25.5,25.6,-273.2,25.6,-273.2,34.5,943,SUCCESS
    1883,2021-07-01 18:12:30,7546.901,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27516,515,516,8,47,66,1087,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3939,3927,3927,3928,3927,3930,3937,0,0,0,0,0,0,0,0,3040,25.5,25.6,-273.2,25.6,-273.2,34.6,1054,SUCCESS
    1884,2021-07-01 18:12:34,7550.912,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27519,516,516,8,47,66,1088,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3940,3928,3928,3928,3928,3930,3937,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1012,SUCCESS
    1885,2021-07-01 18:12:38,7554.921,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27520,516,516,8,47,66,1089,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3940,3928,3928,3928,3928,3931,3938,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1066,SUCCESS
    1886,2021-07-01 18:12:42,7558.924,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27523,516,516,8,47,66,1089,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3940,3928,3928,3929,3928,3931,3938,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1078,SUCCESS
    1887,2021-07-01 18:12:46,7562.936,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27525,516,516,8,47,66,1090,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3941,3928,3928,3929,3929,3931,3938,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.6,989,SUCCESS
    1888,2021-07-01 18:12:50,7566.936,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27526,516,516,8,47,66,1090,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3941,3928,3929,3929,3929,3931,3938,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1005,SUCCESS
    1889,2021-07-01 18:12:54,7570.937,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27530,516,516,8,47,66,1091,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3942,3929,3929,3930,3930,3932,3939,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,955,SUCCESS
    1890,2021-07-01 18:12:58,7574.938,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27531,516,516,8,47,66,1091,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3942,3929,3929,3930,3930,3932,3940,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.5,1063,SUCCESS
    1891,2021-07-01 18:13:02,7578.948,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27532,516,516,8,47,66,1092,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3942,3929,3930,3930,3930,3932,3940,0,0,0,0,0,0,0,0,3044,25.4,25.6,-273.2,25.6,-273.2,34.5,976,SUCCESS
    1892,2021-07-01 18:13:06,7582.961,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27534,517,516,8,47,66,1093,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3942,3930,3930,3931,3930,3932,3940,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,33.6,1017,SUCCESS
    1893,2021-07-01 18:13:10,7586.975,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27538,516,516,8,47,66,1093,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3943,3930,3930,3931,3931,3933,3940,0,0,0,0,0,0,0,0,3040,25.4,25.6,-273.2,25.6,-273.2,34.6,1060,SUCCESS
    1894,2021-07-01 18:13:14,7590.986,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27540,516,516,8,47,66,1094,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3943,3930,3931,3931,3931,3933,3940,0,0,0,0,0,0,0,0,3041,25.4,25.6,-273.2,25.6,-273.2,34.5,1049,SUCCESS
    1895,2021-07-01 18:13:18,7594.992,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27541,517,516,8,47,66,1094,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3943,3931,3931,3932,3931,3933,3941,0,0,0,0,0,0,0,0,3044,25.4,25.6,-273.2,25.6,-273.2,34.5,978,SUCCESS
    1896,2021-07-01 18:13:22,7599.000,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27543,516,516,8,47,66,1095,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3944,3931,3931,3932,3931,3934,3941,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1100,SUCCESS
    1897,2021-07-01 18:13:26,7603.003,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27545,517,516,8,47,66,1095,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3944,3931,3932,3932,3932,3934,3941,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1013,SUCCESS
    1898,2021-07-01 18:13:30,7607.016,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27547,516,516,8,47,66,1096,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3944,3931,3932,3932,3932,3934,3941,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,1158,SUCCESS
    1899,2021-07-01 18:13:34,7611.019,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27550,516,516,8,47,66,1097,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3944,3932,3932,3932,3933,3934,3942,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1045,SUCCESS
    1900,2021-07-01 18:13:38,7615.019,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27551,516,516,8,47,66,1097,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3945,3932,3932,3933,3933,3935,3942,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1061,SUCCESS
    1901,2021-07-01 18:13:42,7619.034,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27553,516,516,8,47,66,1098,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3945,3932,3932,3933,3933,3935,3943,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.0,1052,SUCCESS
    1902,2021-07-01 18:13:46,7623.035,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27554,516,516,8,47,66,1098,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3945,3932,3932,3934,3933,3936,3943,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,999,SUCCESS
    1903,2021-07-01 18:13:50,7627.044,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27558,516,516,8,47,66,1099,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3946,3933,3933,3934,3933,3936,3943,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1018,SUCCESS
    1904,2021-07-01 18:13:54,7631.056,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27561,516,516,8,47,66,1099,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3946,3933,3934,3934,3934,3936,3943,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,946,SUCCESS
    1905,2021-07-01 18:13:58,7635.058,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27562,516,516,8,47,66,1100,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3946,3934,3934,3934,3934,3936,3944,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,943,SUCCESS
    1906,2021-07-01 18:14:02,7639.059,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27564,516,516,8,47,67,1101,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3947,3934,3934,3935,3934,3936,3944,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1034,SUCCESS
    1907,2021-07-01 18:14:06,7643.061,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27567,516,516,8,47,67,1101,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3947,3934,3934,3935,3935,3936,3945,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,1081,SUCCESS
    1908,2021-07-01 18:14:10,7647.066,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27568,516,516,8,47,67,1102,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3947,3934,3935,3935,3935,3936,3945,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1063,SUCCESS
    1909,2021-07-01 18:14:14,7651.067,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27571,517,516,8,47,67,1102,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3947,3935,3935,3935,3935,3937,3945,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,1029,SUCCESS
    1910,2021-07-01 18:14:18,7655.082,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27573,516,516,8,47,67,1103,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3948,3935,3935,3936,3936,3938,3945,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,1012,SUCCESS
    1911,2021-07-01 18:14:22,7659.087,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27575,517,516,8,47,67,1104,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3948,3936,3935,3936,3936,3938,3946,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1024,SUCCESS
    1912,2021-07-01 18:14:26,7663.099,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27578,515,516,8,47,67,1104,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3948,3936,3936,3937,3936,3939,3946,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1105,SUCCESS
    1913,2021-07-01 18:14:30,7667.104,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27578,516,516,8,47,67,1105,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3948,3936,3936,3937,3936,3939,3946,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,989,SUCCESS
    1914,2021-07-01 18:14:34,7671.118,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27581,516,516,8,47,67,1105,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3949,3936,3937,3937,3937,3940,3946,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.5,1027,SUCCESS
    1915,2021-07-01 18:14:38,7675.129,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27583,516,516,8,48,67,1106,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3949,3937,3937,3937,3937,3940,3947,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.2,1020,SUCCESS
    1916,2021-07-01 18:14:42,7679.130,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27586,516,516,8,48,67,1107,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3950,3937,3937,3938,3937,3940,3947,0,0,0,0,0,0,0,0,3045,25.5,25.6,-273.2,25.6,-273.2,34.6,1060,SUCCESS
    1917,2021-07-01 18:14:46,7683.129,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27586,517,516,8,48,67,1107,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3950,3937,3937,3938,3937,3940,3947,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1027,SUCCESS
    1918,2021-07-01 18:14:50,7687.143,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27588,516,516,8,48,67,1108,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3950,3937,3938,3938,3938,3940,3948,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1062,SUCCESS
    1919,2021-07-01 18:14:54,7691.155,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27590,516,516,8,48,67,1108,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3950,3938,3938,3938,3938,3941,3948,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1020,SUCCESS
    1920,2021-07-01 18:14:58,7695.165,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27593,516,516,8,48,67,1109,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3951,3938,3938,3938,3939,3941,3948,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1009,SUCCESS
    1921,2021-07-01 18:15:02,7699.168,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27596,515,516,8,48,67,1109,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3951,3938,3939,3939,3939,3941,3949,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1068,SUCCESS
    1922,2021-07-01 18:15:06,7703.175,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27597,516,516,8,48,67,1110,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3951,3939,3939,3940,3939,3941,3949,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,997,SUCCESS
    1923,2021-07-01 18:15:10,7707.185,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27599,515,516,8,48,67,1111,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3951,3939,3939,3940,3939,3942,3949,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1021,SUCCESS
    1924,2021-07-01 18:15:14,7711.194,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27601,515,516,8,48,67,1111,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3952,3939,3939,3940,3940,3942,3950,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,33.9,1033,SUCCESS
    1925,2021-07-01 18:15:18,7715.208,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27601,516,516,8,48,67,1112,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3952,3939,3939,3940,3940,3942,3950,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1076,SUCCESS
    1926,2021-07-01 18:15:22,7719.222,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27603,516,516,8,48,67,1112,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3952,3940,3940,3940,3940,3942,3950,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1060,SUCCESS
    1927,2021-07-01 18:15:26,7723.226,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27608,517,516,8,48,67,1113,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3953,3940,3940,3941,3941,3943,3950,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1011,SUCCESS
    1928,2021-07-01 18:15:30,7727.230,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27609,516,516,8,48,67,1113,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3953,3940,3941,3941,3941,3943,3951,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1024,SUCCESS
    1929,2021-07-01 18:15:34,7731.230,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27611,517,516,8,48,67,1114,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3953,3940,3941,3942,3941,3944,3951,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,1037,SUCCESS
    1930,2021-07-01 18:15:38,7735.245,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27614,517,516,8,48,67,1115,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3954,3941,3941,3942,3942,3944,3951,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1099,SUCCESS
    1931,2021-07-01 18:15:42,7739.250,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27617,516,516,8,48,67,1115,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3953,3941,3941,3942,3942,3944,3951,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1083,SUCCESS
    1932,2021-07-01 18:15:46,7743.257,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27617,516,516,8,48,67,1116,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3954,3941,3942,3942,3942,3944,3952,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1001,SUCCESS
    1933,2021-07-01 18:15:50,7747.258,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27619,516,516,8,48,67,1116,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3954,3942,3942,3943,3942,3945,3952,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,33.9,1079,SUCCESS
    1934,2021-07-01 18:15:54,7751.271,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27622,516,516,8,48,68,1117,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3954,3942,3942,3943,3943,3945,3952,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,33.8,1002,SUCCESS
    1935,2021-07-01 18:15:58,7755.274,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27622,517,516,8,48,68,1117,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3955,3942,3943,3943,3943,3945,3952,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.6,945,SUCCESS
    1936,2021-07-01 18:16:02,7759.277,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27624,517,516,8,48,68,1118,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3955,3942,3943,3943,3943,3945,3953,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,988,SUCCESS
    1937,2021-07-01 18:16:06,7763.281,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27628,516,516,8,48,68,1119,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3956,3943,3943,3943,3944,3946,3953,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1033,SUCCESS
    1938,2021-07-01 18:16:10,7767.282,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27629,516,516,8,48,68,1119,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3956,3943,3943,3944,3944,3946,3953,0,0,0,0,0,0,0,0,3050,25.5,25.6,-273.2,25.6,-273.2,34.5,1079,SUCCESS
    1939,2021-07-01 18:16:14,7771.290,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27631,515,516,8,48,68,1120,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3956,3943,3944,3944,3944,3946,3954,0,0,0,0,0,0,0,0,3054,25.5,25.6,-273.2,25.6,-273.2,34.7,1001,SUCCESS
    1940,2021-07-01 18:16:18,7775.297,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27634,516,516,8,48,68,1120,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3956,3944,3944,3945,3944,3947,3954,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.5,1017,SUCCESS
    1941,2021-07-01 18:16:22,7779.308,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27637,515,516,8,48,68,1121,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3957,3944,3945,3945,3945,3947,3954,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1090,SUCCESS
    1942,2021-07-01 18:16:26,7783.307,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27638,516,516,8,48,68,1121,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3957,3945,3945,3945,3945,3947,3955,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,991,SUCCESS
    1943,2021-07-01 18:16:30,7787.316,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27640,516,516,8,48,68,1122,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3957,3945,3945,3946,3945,3947,3955,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.5,1110,SUCCESS
    1944,2021-07-01 18:16:34,7791.331,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27641,516,516,8,48,68,1123,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3957,3945,3945,3946,3945,3948,3955,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.5,1046,SUCCESS
    1945,2021-07-01 18:16:38,7795.338,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27644,516,516,8,48,68,1123,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3958,3945,3946,3946,3946,3948,3955,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.5,1072,SUCCESS
    1946,2021-07-01 18:16:42,7799.342,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27646,517,516,8,48,68,1124,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3958,3945,3946,3946,3946,3948,3956,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.5,972,SUCCESS
    1947,2021-07-01 18:16:46,7803.346,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27649,515,516,8,48,68,1124,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3959,3946,3946,3946,3947,3948,3956,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1062,SUCCESS
    1948,2021-07-01 18:16:50,7807.354,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27650,515,516,8,48,68,1125,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3959,3946,3946,3947,3947,3949,3957,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1039,SUCCESS
    1949,2021-07-01 18:16:54,7811.353,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27652,516,516,8,48,68,1125,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3959,3946,3947,3947,3947,3949,3957,0,0,0,0,0,0,0,0,3055,25.6,25.6,-273.2,25.6,-273.2,34.6,1007,SUCCESS
    1950,2021-07-01 18:16:58,7815.364,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27654,516,516,8,48,68,1126,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3959,3947,3947,3948,3947,3950,3957,0,0,0,0,0,0,0,0,3055,25.6,25.6,-273.2,25.6,-273.2,34.5,996,SUCCESS
    1951,2021-07-01 18:17:02,7819.364,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27657,516,516,8,48,68,1127,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3960,3947,3947,3948,3948,3950,3957,0,0,0,0,0,0,0,0,3055,25.6,25.6,-273.2,25.6,-273.2,34.6,996,SUCCESS
    1952,2021-07-01 18:17:06,7823.372,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27657,517,516,8,48,68,1127,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3960,3947,3948,3948,3948,3950,3958,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,958,SUCCESS
    1953,2021-07-01 18:17:10,7827.383,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27659,515,516,8,48,68,1128,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3960,3947,3948,3948,3948,3950,3958,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1011,SUCCESS
    1954,2021-07-01 18:17:14,7831.386,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27661,515,516,8,48,68,1128,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3960,3948,3948,3949,3948,3950,3958,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.7,1061,SUCCESS
    1955,2021-07-01 18:17:18,7835.398,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27663,516,516,8,49,68,1129,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3961,3948,3949,3949,3948,3951,3958,0,0,0,0,0,0,0,0,3055,25.5,25.7,-273.2,25.7,-273.2,34.5,979,SUCCESS
    1956,2021-07-01 18:17:22,7839.407,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27665,515,516,8,49,68,1130,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3961,3948,3949,3949,3949,3951,3958,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,969,SUCCESS
    1957,2021-07-01 18:17:26,7843.421,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27667,517,516,8,49,68,1130,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3962,3949,3949,3950,3949,3951,3959,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1082,SUCCESS
    1958,2021-07-01 18:17:30,7847.421,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27669,517,516,8,49,68,1131,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3962,3949,3949,3950,3950,3951,3959,0,0,0,0,0,0,0,0,3055,25.5,25.6,-273.2,25.6,-273.2,34.6,1019,SUCCESS
    1959,2021-07-01 18:17:34,7851.428,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27670,518,516,8,49,68,1131,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3962,3949,3949,3950,3950,3952,3960,0,0,0,0,0,0,0,0,3055,25.5,25.7,-273.2,25.7,-273.2,34.6,980,SUCCESS
    1960,2021-07-01 18:17:38,7855.435,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27673,517,516,8,49,68,1132,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3962,3949,3950,3950,3950,3952,3960,0,0,0,0,0,0,0,0,3055,25.6,25.6,-273.2,25.6,-273.2,34.7,1051,SUCCESS
    1961,2021-07-01 18:17:42,7859.450,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27676,517,517,8,49,68,1132,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3962,3950,3950,3951,3950,3953,3960,0,0,0,0,0,0,0,0,3059,25.6,25.6,-273.2,25.6,-273.2,34.6,958,SUCCESS
    1962,2021-07-01 18:17:46,7863.462,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27679,517,517,8,49,68,1133,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3963,3950,3951,3951,3951,3953,3960,0,0,0,0,0,0,0,0,3060,25.5,25.6,-273.2,25.6,-273.2,34.5,997,SUCCESS
    1963,2021-07-01 18:17:50,7867.462,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27679,517,517,8,49,69,1134,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3963,3950,3951,3951,3951,3953,3961,0,0,0,0,0,0,0,0,3060,25.5,25.6,-273.2,25.6,-273.2,34.6,962,SUCCESS
    1964,2021-07-01 18:17:54,7871.477,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27681,518,517,8,49,69,1134,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3963,3951,3951,3951,3951,3954,3961,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1011,SUCCESS
    1965,2021-07-01 18:17:58,7875.480,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27684,515,517,8,49,69,1135,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3963,3951,3951,3952,3951,3954,3961,0,0,0,0,0,0,0,0,3060,25.5,25.6,-273.2,25.6,-273.2,34.6,974,SUCCESS
    1966,2021-07-01 18:18:02,7879.491,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27686,515,516,8,49,69,1135,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3964,3951,3951,3952,3952,3954,3961,0,0,0,0,0,0,0,0,3060,25.5,25.6,-273.2,25.6,-273.2,34.6,978,SUCCESS
    1967,2021-07-01 18:18:06,7883.507,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27688,517,516,8,49,69,1136,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3964,3951,3952,3952,3952,3954,3962,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1010,SUCCESS
    1968,2021-07-01 18:18:10,7887.518,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27688,515,516,8,49,69,1136,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3965,3952,3952,3952,3952,3954,3962,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1046,SUCCESS
    1969,2021-07-01 18:18:14,7891.523,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27693,516,516,8,49,69,1137,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3965,3952,3952,3953,3953,3955,3963,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.7,999,SUCCESS
    1970,2021-07-01 18:18:18,7895.526,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27693,516,516,8,49,69,1138,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3965,3952,3952,3953,3953,3955,3963,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,976,SUCCESS
    1971,2021-07-01 18:18:22,7899.530,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27695,516,516,8,49,69,1138,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3965,3952,3953,3954,3953,3955,3963,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1034,SUCCESS
    1972,2021-07-01 18:18:26,7903.529,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27698,516,516,8,49,69,1139,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3966,3953,3953,3954,3953,3955,3963,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1034,SUCCESS
    1973,2021-07-01 18:18:30,7907.537,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27700,516,516,8,49,69,1139,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3966,3953,3954,3954,3954,3956,3964,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,997,SUCCESS
    1974,2021-07-01 18:18:34,7911.537,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27702,516,516,8,49,69,1140,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3966,3954,3954,3954,3954,3957,3964,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,965,SUCCESS
    1975,2021-07-01 18:18:38,7915.539,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27704,516,516,8,49,69,1141,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3967,3954,3954,3955,3954,3957,3964,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,963,SUCCESS
    1976,2021-07-01 18:18:42,7919.539,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27705,516,516,8,49,69,1141,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3967,3954,3954,3955,3955,3957,3964,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.6,1065,SUCCESS
    1977,2021-07-01 18:18:46,7923.546,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27707,517,516,8,49,69,1142,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3967,3954,3955,3955,3955,3957,3964,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.6,1017,SUCCESS
    1978,2021-07-01 18:18:50,7927.557,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27710,516,516,8,49,69,1142,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3967,3955,3955,3955,3955,3957,3965,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.6,977,SUCCESS
    1979,2021-07-01 18:18:54,7931.557,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27713,517,516,8,49,69,1143,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3968,3955,3955,3956,3956,3958,3965,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.6,944,SUCCESS
    1980,2021-07-01 18:18:58,7935.568,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27714,516,516,8,49,69,1143,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3968,3955,3956,3956,3956,3958,3966,0,0,0,0,0,0,0,0,3060,25.6,25.6,-273.2,25.6,-273.2,34.6,1091,SUCCESS
    1981,2021-07-01 18:19:02,7939.580,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27715,517,516,8,49,69,1144,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3968,3955,3956,3957,3956,3958,3966,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.5,1099,SUCCESS
    1982,2021-07-01 18:19:06,7943.583,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27718,516,516,8,49,69,1145,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3968,3956,3956,3957,3956,3959,3966,0,0,0,0,0,0,0,0,3060,25.6,25.7,-273.2,25.7,-273.2,34.6,1043,SUCCESS
    1983,2021-07-01 18:19:10,7947.584,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27721,516,516,8,49,69,1145,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3969,3956,3957,3957,3957,3959,3966,0,0,0,0,0,0,0,0,3061,25.6,25.7,-273.2,25.7,-273.2,34.6,948,SUCCESS
    1984,2021-07-01 18:19:14,7951.592,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27722,516,516,8,49,69,1146,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3969,3956,3957,3957,3957,3959,3967,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1066,SUCCESS
    1985,2021-07-01 18:19:18,7955.597,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27725,516,516,8,49,69,1146,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3970,3957,3957,3958,3957,3959,3967,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1015,SUCCESS
    1986,2021-07-01 18:19:22,7959.605,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27727,516,516,8,49,69,1147,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3970,3957,3957,3958,3957,3960,3968,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1068,SUCCESS
    1987,2021-07-01 18:19:26,7963.608,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27730,516,516,8,49,69,1148,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3970,3957,3958,3958,3958,3960,3967,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1097,SUCCESS
    1988,2021-07-01 18:19:30,7967.610,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27730,516,516,8,49,69,1148,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3970,3958,3958,3958,3958,3961,3968,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,986,SUCCESS
    1989,2021-07-01 18:19:34,7971.614,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27734,516,516,8,49,69,1149,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3971,3958,3958,3959,3958,3961,3968,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.7,1019,SUCCESS
    1990,2021-07-01 18:19:38,7975.620,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27734,517,516,8,49,69,1149,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3971,3958,3958,3959,3959,3961,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.6,1099,SUCCESS
    1991,2021-07-01 18:19:42,7979.629,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27736,516,516,8,49,69,1150,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3971,3958,3959,3959,3959,3964,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.6,1029,SUCCESS
    1992,2021-07-01 18:19:46,7983.629,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27739,517,516,8,49,69,1150,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3971,3959,3959,3960,3959,3963,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.5,1034,SUCCESS
    1993,2021-07-01 18:19:50,7987.633,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27740,517,517,8,49,70,1151,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3972,3959,3959,3960,3959,3963,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.6,1057,SUCCESS
    1994,2021-07-01 18:19:54,7991.638,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27742,517,517,8,49,70,1152,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3972,3959,3960,3960,3960,3962,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.6,972,SUCCESS
    1995,2021-07-01 18:19:58,7995.653,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27743,518,517,8,49,70,1152,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3972,3960,3960,3960,3960,3962,3969,0,0,0,0,0,0,0,0,3065,25.6,25.6,-273.2,25.6,-273.2,34.6,1035,SUCCESS
    1996,2021-07-01 18:20:02,7999.668,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27746,518,517,8,50,70,1153,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3973,3960,3960,3961,3960,3963,3970,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1431,SUCCESS
    1997,2021-07-01 18:20:06,8003.680,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27748,516,517,8,50,70,1153,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3973,3960,3960,3961,3960,3962,3970,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.7,984,SUCCESS
    1998,2021-07-01 18:20:10,8007.682,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27750,517,517,8,50,70,1154,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3973,3960,3961,3961,3961,3963,3971,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.7,1054,SUCCESS
    1999,2021-07-01 18:20:14,8011.693,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27752,517,517,8,50,70,1154,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3973,3961,3961,3961,3961,3964,3971,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1075,SUCCESS
    2000,2021-07-01 18:20:18,8015.705,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27755,516,517,8,50,70,1155,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3974,3961,3962,3961,3962,3964,3971,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1095,SUCCESS
    2001,2021-07-01 18:20:22,8019.716,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27756,517,517,8,50,70,1156,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3974,3961,3962,3962,3962,3964,3972,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,942,SUCCESS
    2002,2021-07-01 18:20:26,8023.724,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27759,517,517,8,50,70,1156,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3974,3962,3962,3963,3962,3964,3972,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.7,1058,SUCCESS
    2003,2021-07-01 18:20:30,8027.735,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27759,517,517,8,50,70,1157,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3974,3962,3962,3963,3963,3965,3972,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.5,1053,SUCCESS
    2004,2021-07-01 18:20:34,8031.750,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27763,516,516,8,50,70,1157,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3975,3962,3963,3963,3963,3965,3972,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,1093,SUCCESS
    2005,2021-07-01 18:20:38,8035.759,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27764,516,516,8,50,70,1158,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3975,3962,3963,3963,3963,3965,3973,0,0,0,0,0,0,0,0,3065,25.6,25.7,-273.2,25.7,-273.2,34.6,962,SUCCESS
    2006,2021-07-01 18:20:42,8039.762,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27764,516,516,8,50,70,1158,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3975,3963,3963,3963,3963,3965,3973,0,0,0,0,0,0,0,0,3069,25.6,25.7,-273.2,25.7,-273.2,34.7,1070,SUCCESS
    2007,2021-07-01 18:20:46,8043.763,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27767,518,516,8,50,70,1159,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3976,3963,3963,3964,3964,3966,3973,0,0,0,0,0,0,0,0,3066,25.6,25.7,-273.2,25.7,-273.2,34.6,1098,SUCCESS
    2008,2021-07-01 18:20:50,8047.768,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27771,517,516,8,50,70,1160,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3976,3963,3964,3964,3964,3966,3973,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1046,SUCCESS
    2009,2021-07-01 18:20:54,8051.772,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27771,515,516,8,50,70,1160,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3976,3963,3964,3965,3964,3966,3974,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,978,SUCCESS
    2010,2021-07-01 18:20:58,8055.779,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27774,517,516,8,50,70,1161,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3976,3964,3964,3965,3965,3966,3974,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,1019,SUCCESS
    2011,2021-07-01 18:21:02,8059.781,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27776,516,516,8,50,70,1161,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3977,3964,3964,3965,3965,3967,3974,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,953,SUCCESS
    2012,2021-07-01 18:21:06,8063.785,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27778,517,516,8,50,70,1162,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3977,3964,3965,3965,3965,3967,3975,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1059,SUCCESS
    2013,2021-07-01 18:21:10,8067.799,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27781,517,516,8,50,70,1162,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3977,3965,3965,3966,3965,3967,3975,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,1077,SUCCESS
    2014,2021-07-01 18:21:14,8071.813,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27781,515,516,8,50,70,1163,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3977,3965,3965,3966,3965,3968,3975,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,986,SUCCESS
    2015,2021-07-01 18:21:18,8075.821,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27784,517,516,8,50,70,1164,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3978,3965,3966,3966,3966,3968,3975,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1011,SUCCESS
    2016,2021-07-01 18:21:22,8079.834,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27786,516,516,8,50,70,1164,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3979,3966,3966,3966,3966,3968,3976,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,1028,SUCCESS
    2017,2021-07-01 18:21:26,8083.844,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27788,516,516,8,50,70,1165,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3978,3966,3966,3967,3967,3968,3976,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,1095,SUCCESS
    2018,2021-07-01 18:21:30,8087.854,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27791,517,516,8,50,70,1165,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3979,3966,3966,3967,3967,3969,3977,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1100,SUCCESS
    2019,2021-07-01 18:21:34,8091.864,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27791,516,516,8,50,70,1166,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3979,3966,3966,3967,3967,3969,3977,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,980,SUCCESS
    2020,2021-07-01 18:21:39,8095.869,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27793,516,516,8,50,70,1166,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3979,3967,3967,3968,3967,3969,3977,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,991,SUCCESS
    2021,2021-07-01 18:21:43,8099.875,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27795,516,516,8,50,71,1167,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3980,3967,3967,3968,3968,3970,3977,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,1085,SUCCESS
    2022,2021-07-01 18:21:47,8103.880,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27798,517,516,8,50,71,1168,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3980,3967,3968,3968,3968,3970,3977,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,998,SUCCESS
    2023,2021-07-01 18:21:51,8107.890,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27799,517,516,8,50,71,1168,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3980,3968,3968,3968,3968,3970,3978,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,985,SUCCESS
    2024,2021-07-01 18:21:55,8111.895,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27802,517,517,8,50,71,1169,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3980,3968,3968,3969,3968,3971,3978,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.3,1017,SUCCESS
    2025,2021-07-01 18:21:59,8115.899,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27803,517,517,8,50,71,1169,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3980,3968,3968,3969,3969,3971,3978,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.7,981,SUCCESS
    2026,2021-07-01 18:22:03,8119.912,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27805,517,517,8,50,71,1170,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3981,3968,3969,3969,3969,3971,3979,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1073,SUCCESS
    2027,2021-07-01 18:22:07,8123.922,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27806,517,517,8,50,71,1171,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3981,3968,3969,3969,3970,3971,3979,0,0,0,0,0,0,0,0,3070,25.6,25.7,-273.2,25.7,-273.2,34.6,1083,SUCCESS
    2028,2021-07-01 18:22:11,8127.923,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27809,517,517,8,50,71,1171,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3982,3969,3969,3970,3970,3972,3979,0,0,0,0,0,0,0,0,3074,25.6,25.8,-273.2,25.8,-273.2,34.6,1078,SUCCESS
    2029,2021-07-01 18:22:15,8131.936,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27812,516,517,8,50,71,1172,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3982,3969,3969,3970,3970,3972,3980,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,1003,SUCCESS
    2030,2021-07-01 18:22:19,8135.944,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27813,517,517,8,50,71,1172,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3982,3969,3969,3970,3970,3972,3980,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.6,1011,SUCCESS
    2031,2021-07-01 18:22:23,8139.951,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27815,517,517,8,50,71,1173,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3982,3969,3970,3971,3970,3972,3980,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.7,1052,SUCCESS
    2032,2021-07-01 18:22:27,8143.954,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27817,517,517,8,50,71,1174,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3983,3970,3970,3971,3971,3973,3980,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.6,1094,SUCCESS
    2033,2021-07-01 18:22:31,8147.960,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27820,516,517,8,50,71,1174,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3983,3970,3971,3971,3971,3973,3981,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.5,1047,SUCCESS
    2034,2021-07-01 18:22:35,8151.972,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27822,517,517,8,50,71,1175,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3983,3971,3971,3972,3971,3973,3981,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.6,1060,SUCCESS
    2035,2021-07-01 18:22:39,8155.986,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27822,516,517,8,50,71,1175,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3983,3971,3971,3972,3972,3974,3981,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.7,1079,SUCCESS
    2036,2021-07-01 18:22:43,8160.000,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27824,515,516,8,50,71,1176,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3984,3971,3972,3972,3972,3974,3982,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.7,1081,SUCCESS
    2037,2021-07-01 18:22:47,8164.007,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27826,517,516,8,50,71,1176,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3984,3971,3972,3972,3972,3974,3982,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,980,SUCCESS
    2038,2021-07-01 18:22:51,8168.006,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27829,516,516,8,51,71,1177,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3984,3972,3972,3973,3973,3975,3982,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,1011,SUCCESS
    2039,2021-07-01 18:22:55,8172.019,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27833,516,516,8,51,71,1178,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3985,3972,3972,3973,3973,3975,3983,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.7,999,SUCCESS
    2040,2021-07-01 18:22:59,8176.018,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27834,516,516,8,51,71,1178,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3985,3972,3972,3973,3973,3976,3983,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.7,1094,SUCCESS
    2041,2021-07-01 18:23:03,8180.028,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27836,517,516,8,51,71,1179,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3985,3973,3973,3974,3973,3976,3983,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,1035,SUCCESS
    2042,2021-07-01 18:23:07,8184.040,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27839,516,516,8,51,71,1179,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3986,3973,3973,3974,3974,3976,3983,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,1009,SUCCESS
    2043,2021-07-01 18:23:11,8188.041,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27842,515,516,8,51,71,1180,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3986,3973,3973,3974,3974,3976,3984,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,944,SUCCESS
    2044,2021-07-01 18:23:15,8192.056,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27841,516,516,8,51,71,1180,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3986,3973,3974,3974,3974,3976,3984,0,0,0,0,0,0,0,0,3075,25.6,25.8,-273.2,25.8,-273.2,34.6,993,SUCCESS
    2045,2021-07-01 18:23:19,8196.065,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27844,516,516,8,51,71,1181,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3986,3974,3974,3975,3974,3976,3984,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.6,1094,SUCCESS
    2046,2021-07-01 18:23:23,8200.072,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27845,515,516,8,51,71,1182,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3986,3974,3974,3975,3975,3977,3984,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.6,978,SUCCESS
    2047,2021-07-01 18:23:27,8204.079,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27848,517,516,8,51,71,1182,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3987,3974,3975,3975,3975,3977,3985,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.7,1095,SUCCESS
    2048,2021-07-01 18:23:31,8208.082,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27849,516,516,8,51,71,1183,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3987,3974,3975,3976,3975,3977,3985,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.7,998,SUCCESS
    2049,2021-07-01 18:23:35,8212.092,0x0701,150,10,0x6001,0,65535,65535,1,25.6,27851,516,516,8,51,71,1183,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3988,3975,3975,3976,3976,3978,3985,0,0,0,0,0,0,0,0,3075,25.6,25.6,-273.2,25.6,-273.2,34.7,1019,SUCCESS
    2050,2021-07-01 18:23:39,8216.107,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27854,516,516,8,51,72,1184,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3988,3975,3975,3976,3976,3978,3986,0,0,0,0,0,0,0,0,3075,25.6,25.7,-273.2,25.7,-273.2,34.7,1068,SUCCESS
    2051,2021-07-01 18:23:43,8220.109,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27855,517,516,8,51,72,1184,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3988,3975,3976,3976,3976,3978,3986,0,0,0,0,0,0,0,0,3076,25.6,25.7,-273.2,25.7,-273.2,34.7,1095,SUCCESS
    2052,2021-07-01 18:23:47,8224.116,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27858,517,516,8,51,72,1185,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3988,3976,3976,3977,3976,3979,3986,0,0,0,0,0,0,0,0,3079,25.6,25.7,-273.2,25.7,-273.2,34.7,1075,SUCCESS
    2053,2021-07-01 18:23:51,8228.123,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27858,516,516,8,51,72,1186,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3988,3976,3976,3977,3977,3979,3986,0,0,0,0,0,0,0,0,3080,25.6,25.7,-273.2,25.7,-273.2,34.6,1014,SUCCESS
    2054,2021-07-01 18:23:55,8232.122,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27862,516,516,8,51,72,1186,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3989,3976,3977,3977,3977,3979,3987,0,0,0,0,0,0,0,0,3080,25.6,25.7,-273.2,25.7,-273.2,34.7,987,SUCCESS
    2055,2021-07-01 18:23:59,8236.122,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27862,516,516,8,51,72,1187,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3989,3976,3977,3977,3977,3979,3987,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1070,SUCCESS
    2056,2021-07-01 18:24:03,8240.124,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27866,516,516,8,51,72,1187,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3990,3977,3977,3978,3978,3980,3987,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.4,1054,SUCCESS
    2057,2021-07-01 18:24:07,8244.127,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27867,517,516,8,51,72,1188,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3990,3977,3977,3978,3978,3980,3988,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1063,SUCCESS
    2058,2021-07-01 18:24:11,8248.139,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27869,517,516,8,51,72,1189,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3990,3977,3978,3978,3978,3980,3988,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1035,SUCCESS
    2059,2021-07-01 18:24:15,8252.138,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27870,517,516,8,51,72,1189,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3990,3978,3978,3979,3979,3980,3988,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,987,SUCCESS
    2060,2021-07-01 18:24:19,8256.145,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27873,517,516,8,51,72,1190,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3990,3978,3978,3979,3979,3980,3989,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,980,SUCCESS
    2061,2021-07-01 18:24:23,8260.151,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27876,516,516,8,51,72,1190,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3991,3978,3978,3979,3979,3981,3989,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1049,SUCCESS
    2062,2021-07-01 18:24:27,8264.165,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27877,516,516,8,51,72,1191,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3991,3978,3979,3980,3980,3981,3989,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1071,SUCCESS
    2063,2021-07-01 18:24:31,8268.166,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27879,516,516,8,51,72,1191,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3991,3979,3979,3980,3980,3979,3989,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1004,SUCCESS
    2064,2021-07-01 18:24:35,8272.177,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27882,514,516,8,51,72,1192,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3991,3979,3980,3980,3980,3982,3990,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1139,SUCCESS
    2065,2021-07-01 18:24:39,8276.189,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27882,516,516,8,51,72,1193,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3992,3979,3980,3980,3980,3982,3990,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1013,SUCCESS
    2066,2021-07-01 18:24:43,8280.198,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27885,516,516,8,51,72,1193,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3992,3980,3980,3981,3980,3983,3990,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,989,SUCCESS
    2067,2021-07-01 18:24:47,8284.215,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27888,516,516,8,51,72,1194,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3993,3980,3980,3981,3981,3984,3991,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1005,SUCCESS
    2068,2021-07-01 18:24:51,8288.220,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27890,516,516,8,51,72,1194,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3993,3980,3980,3981,3981,3983,3991,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1124,SUCCESS
    2069,2021-07-01 18:24:55,8292.225,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27892,515,516,8,51,72,1195,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3993,3980,3981,3981,3982,3989,3991,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,980,SUCCESS
    2070,2021-07-01 18:24:59,8296.236,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27895,517,516,8,51,72,1195,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3993,3981,3981,3982,3982,3984,3992,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.6,1078,SUCCESS
    2071,2021-07-01 18:25:03,8300.241,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27896,516,516,8,51,72,1196,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3994,3981,3981,3982,3982,3984,3992,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,946,SUCCESS
    2072,2021-07-01 18:25:07,8304.244,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27896,516,516,8,51,72,1197,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3994,3981,3982,3982,3982,3984,3992,0,0,0,0,0,0,0,0,3080,25.6,25.8,-273.2,25.8,-273.2,34.7,1008,SUCCESS
    2073,2021-07-01 18:25:11,8308.243,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27901,515,516,8,51,72,1197,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3994,3982,3982,3983,3983,3985,3993,0,0,0,0,0,0,0,0,3080,25.6,25.7,-273.2,25.7,-273.2,34.7,1023,SUCCESS
    2074,2021-07-01 18:25:15,8312.255,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27903,516,516,8,51,72,1198,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3995,3982,3983,3983,3983,3985,3993,0,0,0,0,0,0,0,0,3085,25.6,25.7,-273.2,25.7,-273.2,34.7,963,SUCCESS
    2075,2021-07-01 18:25:19,8316.262,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27904,516,516,8,51,72,1198,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3995,3982,3983,3983,3983,3985,3993,0,0,0,0,0,0,0,0,3085,25.6,25.7,-273.2,25.7,-273.2,34.7,1037,SUCCESS
    2076,2021-07-01 18:25:23,8320.269,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27908,516,516,8,51,72,1199,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3995,3983,3983,3983,3984,3986,3994,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,966,SUCCESS
    2077,2021-07-01 18:25:27,8324.272,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27909,517,516,8,51,72,1199,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3983,3983,3984,3984,3986,3994,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.6,1015,SUCCESS
    2078,2021-07-01 18:25:31,8328.279,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27912,516,516,8,52,72,1200,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3983,3984,3984,3984,3987,3994,0,0,0,0,0,0,0,0,3085,25.6,25.7,-273.2,25.7,-273.2,34.7,1004,SUCCESS
    2079,2021-07-01 18:25:35,8332.286,0x0701,150,10,0x6001,0,65535,65535,1,25.7,27912,516,516,8,52,73,1201,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3983,3984,3984,3984,3987,3994,0,0,0,0,0,0,0,0,3085,25.6,25.7,-273.2,25.7,-273.2,34.2,1032,SUCCESS
    2080,2021-07-01 18:25:39,8336.297,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27915,516,516,8,52,73,1201,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3996,3984,3984,3984,3985,3987,3994,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1017,SUCCESS
    2081,2021-07-01 18:25:43,8340.298,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27917,516,516,8,52,73,1202,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3997,3984,3985,3985,3985,3987,3995,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1170,SUCCESS
    2082,2021-07-01 18:25:47,8344.301,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27920,516,516,8,52,73,1202,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3997,3985,3985,3985,3985,3987,3995,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.6,1124,SUCCESS
    2083,2021-07-01 18:25:51,8348.315,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27921,516,516,8,52,73,1203,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3997,3985,3985,3986,3986,3988,3995,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1030,SUCCESS
    2084,2021-07-01 18:25:55,8352.330,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27923,516,516,8,52,73,1203,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3998,3985,3986,3986,3986,3988,3996,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1063,SUCCESS
    2085,2021-07-01 18:25:59,8356.330,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27925,516,516,8,52,73,1204,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3998,3985,3986,3986,3986,3988,3996,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.6,1110,SUCCESS
    2086,2021-07-01 18:26:03,8360.329,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27927,515,516,8,52,73,1205,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3998,3986,3986,3987,3987,3988,3996,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1111,SUCCESS
    2087,2021-07-01 18:26:07,8364.339,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27929,516,516,8,52,73,1205,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3999,3986,3986,3987,3987,3988,3997,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1023,SUCCESS
    2088,2021-07-01 18:26:11,8368.349,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27932,516,516,8,52,73,1206,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3999,3986,3987,3987,3987,3989,3997,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,982,SUCCESS
    2089,2021-07-01 18:26:15,8372.355,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27933,516,516,8,52,73,1206,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,3999,3986,3987,3988,3987,3989,3997,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1052,SUCCESS
    2090,2021-07-01 18:26:19,8376.370,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27937,518,516,8,52,73,1207,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4000,3987,3987,3988,3988,3990,3997,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1083,SUCCESS
    2091,2021-07-01 18:26:23,8380.371,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27938,517,516,8,52,73,1207,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4000,3987,3988,3988,3988,3990,3998,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1070,SUCCESS
    2092,2021-07-01 18:26:27,8384.375,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27939,516,516,8,52,73,1208,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4000,3988,3988,3988,3988,3990,3998,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1017,SUCCESS
    2093,2021-07-01 18:26:31,8388.383,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27942,516,516,8,52,73,1209,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4000,3988,3988,3989,3989,3991,3998,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,977,SUCCESS
    2094,2021-07-01 18:26:35,8392.387,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27944,516,516,8,52,73,1209,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4001,3988,3988,3989,3989,3991,3998,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1037,SUCCESS
    2095,2021-07-01 18:26:39,8396.400,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27946,516,516,8,52,73,1210,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4001,3988,3989,3989,3989,3991,3999,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.6,1062,SUCCESS
    2096,2021-07-01 18:26:43,8400.403,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27948,517,516,8,52,73,1211,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4001,3989,3989,3990,3990,3992,3999,0,0,0,0,0,0,0,0,3085,25.6,25.8,-273.2,25.8,-273.2,34.7,1023,SUCCESS
    2097,2021-07-01 18:26:47,8404.413,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27951,516,516,8,52,73,1211,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4002,3989,3989,3990,3990,3992,4000,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1009,SUCCESS
    2098,2021-07-01 18:26:51,8408.428,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27953,516,516,8,52,73,1212,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4002,3989,3989,3991,3990,3992,4000,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1075,SUCCESS
    2099,2021-07-01 18:26:55,8412.439,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27954,517,516,8,52,73,1212,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4002,3989,3990,3991,3991,3992,4000,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1047,SUCCESS
    2100,2021-07-01 18:26:59,8416.447,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27957,516,516,8,52,73,1213,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4002,3990,3990,3991,3991,3993,4001,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1039,SUCCESS
    2101,2021-07-01 18:27:03,8420.458,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27960,517,516,8,52,73,1213,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4003,3990,3991,3991,3991,3993,4001,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1082,SUCCESS
    2102,2021-07-01 18:27:07,8424.461,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27962,516,516,8,52,73,1214,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4003,3991,3991,3992,3991,3993,4001,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,33.9,1048,SUCCESS
    2103,2021-07-01 18:27:11,8428.470,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27964,516,516,8,52,73,1215,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4003,3991,3991,3992,3992,3994,4001,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1063,SUCCESS
    2104,2021-07-01 18:27:15,8432.482,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27965,516,516,8,52,73,1215,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4003,3991,3992,3992,3992,3994,4001,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1068,SUCCESS
    2105,2021-07-01 18:27:19,8436.492,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27967,516,516,8,52,73,1216,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4004,3991,3992,3992,3993,3994,4002,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,1057,SUCCESS
    2106,2021-07-01 18:27:23,8440.498,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27968,515,516,8,52,73,1216,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4004,3992,3992,3993,3993,3995,4002,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,944,SUCCESS
    2107,2021-07-01 18:27:27,8444.504,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27973,516,516,8,52,74,1217,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4005,3992,3992,3993,3993,3995,4003,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.8,1161,SUCCESS
    2108,2021-07-01 18:27:31,8448.513,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27974,516,516,8,52,74,1217,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4005,3992,3992,3993,3993,3995,4003,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.7,978,SUCCESS
    2109,2021-07-01 18:27:35,8452.520,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27976,516,516,8,52,74,1218,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4005,3992,3993,3994,3993,3996,4003,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.6,1082,SUCCESS
    2110,2021-07-01 18:27:39,8456.531,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27979,516,516,8,52,74,1219,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4005,3993,3993,3994,3994,3996,4003,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.7,1022,SUCCESS
    2111,2021-07-01 18:27:43,8460.535,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27981,516,516,8,52,74,1219,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4006,3993,3994,3994,3994,3996,4004,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,981,SUCCESS
    2112,2021-07-01 18:27:47,8464.551,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27983,517,516,8,52,74,1220,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4006,3994,3994,3995,3994,3996,4004,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.6,1014,SUCCESS
    2113,2021-07-01 18:27:51,8468.552,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27984,515,516,8,52,74,1220,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4007,3994,3994,3995,3995,3996,4004,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.7,1058,SUCCESS
    2114,2021-07-01 18:27:55,8472.557,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27987,516,516,8,52,74,1221,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4006,3994,3995,3995,3995,3997,4004,0,0,0,0,0,0,0,0,3090,25.6,25.8,-273.2,25.8,-273.2,34.7,975,SUCCESS
    2115,2021-07-01 18:27:59,8476.558,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27987,516,516,8,52,74,1221,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4007,3994,3995,3995,3995,3997,4005,0,0,0,0,0,0,0,0,3090,25.7,25.8,-273.2,25.8,-273.2,34.6,1007,SUCCESS
    2116,2021-07-01 18:28:03,8480.560,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27992,517,516,8,52,74,1222,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4007,3995,3995,3996,3996,3998,4005,0,0,0,0,0,0,0,0,3094,25.7,25.8,-273.2,25.8,-273.2,34.7,1067,SUCCESS
    2117,2021-07-01 18:28:07,8484.574,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27989,516,516,8,52,74,1223,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4008,3995,3995,3996,3996,3999,4006,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1069,SUCCESS
    2118,2021-07-01 18:28:11,8488.586,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27996,516,516,8,52,74,1223,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4008,3995,3996,3997,3996,3998,4006,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1023,SUCCESS
    2119,2021-07-01 18:28:15,8492.600,0x0701,150,10,0x6001,0,65535,65535,1,25.8,27999,517,516,8,53,74,1224,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4008,3996,3996,3997,3996,3999,4006,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1016,SUCCESS
    2120,2021-07-01 18:28:19,8496.611,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28003,517,516,8,53,74,1224,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4009,3996,3997,3997,3997,3999,4007,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1046,SUCCESS
    2121,2021-07-01 18:28:23,8500.616,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28005,516,516,8,53,74,1225,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4009,3997,3997,3997,3997,3999,4007,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1060,SUCCESS
    2122,2021-07-01 18:28:27,8504.618,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28009,516,516,8,53,74,1225,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4009,3997,3997,3998,3997,4000,4007,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,976,SUCCESS
    2123,2021-07-01 18:28:31,8508.633,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28006,517,516,8,53,74,1226,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4009,3997,3997,3998,3998,4000,4008,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,976,SUCCESS
    2124,2021-07-01 18:28:35,8512.649,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28009,517,516,8,53,74,1227,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4010,3997,3998,3998,3998,4000,4008,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,977,SUCCESS
    2125,2021-07-01 18:28:39,8516.655,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28010,517,516,8,53,74,1227,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4010,3998,3998,3999,3999,4000,4008,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1036,SUCCESS
    2126,2021-07-01 18:28:43,8520.660,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28014,517,516,8,53,74,1228,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4011,3998,3998,3999,3999,4000,4009,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1015,SUCCESS
    2127,2021-07-01 18:28:47,8524.675,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28015,517,516,8,53,74,1228,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4011,3998,3998,3999,3999,4000,4009,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,967,SUCCESS
    2128,2021-07-01 18:28:51,8528.678,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28017,515,516,8,53,74,1229,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4011,3998,3999,4000,3999,4001,4009,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.8,1016,SUCCESS
    2129,2021-07-01 18:28:55,8532.693,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28021,517,516,8,53,74,1230,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4011,3999,4000,4000,4000,4002,4010,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,996,SUCCESS
    2130,2021-07-01 18:28:59,8536.703,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28023,516,516,8,53,74,1230,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4012,3999,4000,4000,4000,4002,4010,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,1017,SUCCESS
    2131,2021-07-01 18:29:03,8540.715,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28023,516,516,8,53,74,1231,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4012,3999,4000,4001,4000,4002,4010,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1021,SUCCESS
    2132,2021-07-01 18:29:07,8544.723,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28026,516,516,8,53,74,1231,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4012,4000,4000,4001,4000,4003,4010,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,1044,SUCCESS
    2133,2021-07-01 18:29:11,8548.734,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28030,515,516,8,53,74,1232,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4013,4000,4001,4001,4001,4003,4011,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,1003,SUCCESS
    2134,2021-07-01 18:29:15,8552.738,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28030,516,516,8,53,74,1232,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4013,4000,4001,4001,4001,4003,4011,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,1092,SUCCESS
    2135,2021-07-01 18:29:19,8556.748,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28034,516,516,8,53,74,1233,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4013,4001,4001,4002,4002,4004,4012,0,0,0,0,0,0,0,0,3095,25.7,25.8,-273.2,25.8,-273.2,34.7,1051,SUCCESS
    2136,2021-07-01 18:29:23,8560.756,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28036,516,516,8,53,75,1234,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4014,4001,4002,4002,4002,4004,4012,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1058,SUCCESS
    2137,2021-07-01 18:29:27,8564.766,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28038,516,516,8,53,75,1234,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4014,4001,4002,4003,4002,4004,4012,0,0,0,0,0,0,0,0,3095,25.6,25.8,-273.2,25.8,-273.2,34.7,1096,SUCCESS
    2138,2021-07-01 18:29:31,8568.778,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28040,516,516,8,53,75,1235,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4014,4001,4002,4003,4003,4005,4013,0,0,0,0,0,0,0,0,3100,25.6,25.8,-273.2,25.8,-273.2,34.7,1082,SUCCESS
    2139,2021-07-01 18:29:35,8572.781,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28043,516,516,8,53,75,1235,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4014,4002,4003,4003,4003,4005,4013,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1097,SUCCESS
    2140,2021-07-01 18:29:39,8576.783,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28044,516,516,8,53,75,1236,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4015,4002,4003,4004,4003,4003,4014,0,0,0,0,0,0,0,0,3100,25.6,25.8,-273.2,25.8,-273.2,34.7,1046,SUCCESS
    2141,2021-07-01 18:29:43,8580.785,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28049,516,516,8,53,75,1236,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4015,4003,4003,4004,4004,4005,4014,0,0,0,0,0,0,0,0,3100,25.6,25.8,-273.2,25.8,-273.2,34.7,1045,SUCCESS
    2142,2021-07-01 18:29:47,8584.793,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28052,516,516,8,53,75,1237,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4016,4003,4003,4004,4004,4002,4014,0,0,0,0,0,0,0,0,3100,25.6,25.8,-273.2,25.8,-273.2,34.7,975,SUCCESS
    2143,2021-07-01 18:29:51,8588.797,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28052,516,516,8,53,75,1238,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4016,4003,4004,4004,4004,4006,4014,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,33.9,1008,SUCCESS
    2144,2021-07-01 18:29:55,8592.813,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28055,517,516,8,53,75,1238,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4016,4004,4004,4005,4005,4007,4015,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1048,SUCCESS
    2145,2021-07-01 18:29:59,8596.817,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28056,517,516,8,53,75,1239,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4017,4004,4004,4005,4005,4007,4015,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1138,SUCCESS
    2146,2021-07-01 18:30:03,8600.819,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28059,517,516,8,53,75,1239,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4017,4005,4005,4006,4005,4008,4015,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1042,SUCCESS
    2147,2021-07-01 18:30:07,8604.820,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28061,516,516,8,53,75,1240,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4017,4005,4005,4006,4006,4012,4016,0,0,0,0,0,0,0,0,3100,25.7,25.9,-273.2,25.9,-273.2,34.7,1057,SUCCESS
    2148,2021-07-01 18:30:11,8608.833,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28064,516,516,8,53,75,1240,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4017,4005,4006,4006,4006,4011,4016,0,0,0,0,0,0,0,0,3100,25.7,25.9,-273.2,25.9,-273.2,34.7,1075,SUCCESS
    2149,2021-07-01 18:30:15,8612.843,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28065,516,516,8,53,75,1241,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4018,4005,4006,4006,4006,4008,4016,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1080,SUCCESS
    2150,2021-07-01 18:30:19,8616.848,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28066,517,516,8,53,75,1242,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4018,4006,4006,4007,4006,4008,4017,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1043,SUCCESS
    2151,2021-07-01 18:30:23,8620.859,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28070,515,516,8,53,75,1242,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4019,4006,4006,4007,4007,4009,4017,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1049,SUCCESS
    2152,2021-07-01 18:30:28,8624.869,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28072,516,516,8,53,75,1243,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4019,4006,4007,4007,4007,4009,4017,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.0,998,SUCCESS
    2153,2021-07-01 18:30:32,8628.873,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28073,516,516,8,53,75,1243,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4019,4007,4007,4007,4007,4009,4018,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1051,SUCCESS
    2154,2021-07-01 18:30:36,8632.889,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28078,515,516,8,53,75,1244,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4019,4006,4007,4008,4008,4010,4018,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1005,SUCCESS
    2155,2021-07-01 18:30:40,8636.891,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28078,516,516,8,53,75,1244,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4019,4007,4008,4008,4008,4011,4018,0,0,0,0,0,0,0,0,3100,25.7,25.8,-273.2,25.8,-273.2,34.7,1143,SUCCESS
    2156,2021-07-01 18:30:44,8640.894,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28081,518,516,8,53,75,1245,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4020,4008,4008,4008,4009,4011,4018,0,0,0,0,0,0,0,0,3101,25.7,25.8,-273.2,25.8,-273.2,34.7,1061,SUCCESS
    2157,2021-07-01 18:30:48,8644.904,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28084,516,516,8,53,75,1246,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4020,4008,4009,4009,4009,4011,4019,0,0,0,0,0,0,0,0,3101,25.7,25.8,-273.2,25.8,-273.2,34.7,1098,SUCCESS
    2158,2021-07-01 18:30:52,8648.918,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28086,517,516,8,53,75,1246,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4020,4008,4009,4009,4009,4011,4019,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1007,SUCCESS
    2159,2021-07-01 18:30:56,8652.928,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28090,517,516,8,54,75,1247,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4021,4009,4009,4010,4010,4012,4020,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1073,SUCCESS
    2160,2021-07-01 18:31:00,8656.942,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28091,517,516,8,54,75,1247,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4021,4009,4009,4010,4010,4012,4020,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.7,1075,SUCCESS
    2161,2021-07-01 18:31:04,8660.955,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28093,516,517,8,54,75,1248,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4022,4009,4010,4010,4010,4012,4020,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.7,1095,SUCCESS
    2162,2021-07-01 18:31:08,8664.958,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28097,515,517,8,54,75,1249,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4022,4009,4010,4011,4011,4013,4021,0,0,0,0,0,0,0,0,3105,25.8,25.8,-273.2,25.8,-273.2,34.7,981,SUCCESS
    2163,2021-07-01 18:31:12,8668.964,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28098,517,516,8,54,75,1249,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4022,4010,4011,4011,4011,4013,4021,0,0,0,0,0,0,0,0,3105,25.8,25.8,-273.2,25.8,-273.2,34.8,948,SUCCESS
    2164,2021-07-01 18:31:16,8672.978,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28100,515,516,8,54,75,1250,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4023,4010,4011,4011,4011,4013,4021,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,990,SUCCESS
    2165,2021-07-01 18:31:20,8676.988,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28102,517,516,8,54,75,1250,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4023,4011,4011,4012,4011,4013,4022,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.7,1045,SUCCESS
    2166,2021-07-01 18:31:24,8680.993,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28106,516,516,8,54,76,1251,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4023,4011,4011,4012,4012,4014,4022,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.8,1008,SUCCESS
    2167,2021-07-01 18:31:28,8685.002,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28106,515,516,8,54,76,1252,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4024,4011,4012,4012,4012,4014,4022,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1156,SUCCESS
    2168,2021-07-01 18:31:32,8689.003,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28110,516,516,8,54,76,1252,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4024,4011,4012,4013,4012,4015,4023,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1030,SUCCESS
    2169,2021-07-01 18:31:36,8693.013,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28113,515,516,8,54,76,1253,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4024,4012,4012,4013,4013,4015,4023,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.7,1004,SUCCESS
    2170,2021-07-01 18:31:40,8697.016,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28114,517,516,8,54,76,1253,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4025,4012,4013,4014,4013,4015,4023,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1095,SUCCESS
    2171,2021-07-01 18:31:44,8701.019,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28117,517,516,8,54,76,1254,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4025,4013,4013,4014,4014,4016,4024,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,1061,SUCCESS
    2172,2021-07-01 18:31:48,8705.031,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28120,516,516,8,54,76,1254,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4025,4013,4014,4014,4014,4016,4024,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.8,1094,SUCCESS
    2173,2021-07-01 18:31:52,8709.039,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28122,516,516,8,54,76,1255,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4026,4013,4014,4015,4014,4017,4024,0,0,0,0,0,0,0,0,3105,25.7,25.8,-273.2,25.8,-273.2,34.7,945,SUCCESS
    2174,2021-07-01 18:31:56,8713.051,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28125,516,516,8,54,76,1256,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4026,4014,4014,4015,4014,4017,4024,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.8,997,SUCCESS
    2175,2021-07-01 18:32:00,8717.054,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28127,516,516,8,54,76,1256,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4026,4014,4015,4015,4015,4017,4025,0,0,0,0,0,0,0,0,3105,25.7,25.9,-273.2,25.9,-273.2,34.2,969,SUCCESS
    2176,2021-07-01 18:32:04,8721.059,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28129,517,516,8,54,76,1257,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4027,4014,4015,4015,4015,4017,4026,0,0,0,0,0,0,0,0,3109,25.7,25.9,-273.2,25.9,-273.2,34.7,1039,SUCCESS
    2177,2021-07-01 18:32:08,8725.066,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28131,516,516,8,54,76,1257,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4027,4015,4015,4016,4016,4017,4026,0,0,0,0,0,0,0,0,3110,25.7,25.9,-273.2,25.9,-273.2,34.7,1060,SUCCESS
    2178,2021-07-01 18:32:12,8729.070,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28133,515,516,8,54,76,1258,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4027,4015,4016,4016,4016,4017,4026,0,0,0,0,0,0,0,0,3110,25.8,25.9,-273.2,25.9,-273.2,34.7,947,SUCCESS
    2179,2021-07-01 18:32:16,8733.074,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28137,517,516,8,54,76,1258,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4028,4015,4016,4016,4016,4019,4027,0,0,0,0,0,0,0,0,3110,25.8,25.9,-273.2,25.9,-273.2,34.7,1054,SUCCESS
    2180,2021-07-01 18:32:20,8737.085,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28139,517,516,8,54,76,1259,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4028,4015,4016,4017,4017,4019,4027,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,993,SUCCESS
    2181,2021-07-01 18:32:24,8741.098,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28140,516,516,8,54,76,1260,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4028,4016,4017,4017,4017,4019,4027,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1033,SUCCESS
    2182,2021-07-01 18:32:28,8745.109,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28142,517,516,8,54,76,1260,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4029,4016,4017,4018,4017,4019,4027,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1018,SUCCESS
    2183,2021-07-01 18:32:32,8749.121,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28146,516,516,8,54,76,1261,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4029,4017,4017,4018,4017,4020,4027,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,958,SUCCESS
    2184,2021-07-01 18:32:36,8753.137,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28148,516,516,8,54,76,1261,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4029,4017,4018,4018,4018,4020,4028,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.3,979,SUCCESS
    2185,2021-07-01 18:32:40,8757.145,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28151,517,516,8,54,76,1262,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4030,4017,4018,4018,4019,4020,4029,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1060,SUCCESS
    2186,2021-07-01 18:32:44,8761.149,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28154,515,516,8,54,76,1262,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4030,4017,4018,4019,4019,4021,4029,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,1009,SUCCESS
    2187,2021-07-01 18:32:48,8765.159,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28155,516,516,8,54,76,1263,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4031,4018,4019,4019,4019,4021,4029,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,1019,SUCCESS
    2188,2021-07-01 18:32:52,8769.171,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28158,517,516,8,54,76,1264,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4031,4018,4019,4020,4019,4022,4030,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1050,SUCCESS
    2189,2021-07-01 18:32:56,8773.178,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28160,516,516,8,54,76,1264,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4031,4018,4019,4020,4020,4022,4030,0,0,0,0,0,0,0,0,3110,25.8,25.9,-273.2,25.9,-273.2,34.7,1011,SUCCESS
    2190,2021-07-01 18:33:00,8777.192,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28162,517,516,8,54,76,1265,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4032,4019,4020,4020,4020,4022,4030,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,1108,SUCCESS
    2191,2021-07-01 18:33:04,8781.199,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28164,516,517,8,54,76,1265,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4032,4019,4020,4021,4020,4022,4031,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1070,SUCCESS
    2192,2021-07-01 18:33:08,8785.212,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28167,517,517,8,54,76,1266,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4032,4020,4021,4021,4021,4023,4031,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.7,1072,SUCCESS
    2193,2021-07-01 18:33:12,8789.219,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28169,518,517,8,54,76,1266,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4032,4020,4021,4021,4021,4024,4032,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,33.9,1100,SUCCESS
    2194,2021-07-01 18:33:16,8793.221,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28172,516,517,8,54,77,1267,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4033,4020,4021,4022,4022,4023,4032,0,0,0,0,0,0,0,0,3110,25.8,25.8,-273.2,25.8,-273.2,34.8,1061,SUCCESS
    2195,2021-07-01 18:33:20,8797.222,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28176,516,517,8,54,77,1268,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4033,4021,4022,4022,4022,4024,4032,0,0,0,0,0,0,0,0,3115,25.8,25.8,-273.2,25.8,-273.2,34.7,1031,SUCCESS
    2196,2021-07-01 18:33:24,8801.224,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28179,517,517,8,54,77,1268,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4034,4021,4023,4023,4022,4024,4033,0,0,0,0,0,0,0,0,3115,25.8,25.8,-273.2,25.8,-273.2,34.7,1044,SUCCESS
    2197,2021-07-01 18:33:28,8805.227,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28184,516,517,8,54,77,1269,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4034,4021,4023,4023,4023,4025,4033,0,0,0,0,0,0,0,0,3115,25.8,25.8,-273.2,25.8,-273.2,34.7,1008,SUCCESS
    2198,2021-07-01 18:33:32,8809.230,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28188,517,517,8,54,77,1269,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4034,4022,4023,4023,4023,4025,4033,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,1037,SUCCESS
    2199,2021-07-01 18:33:36,8813.238,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28183,517,517,8,54,77,1270,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4035,4022,4024,4024,4023,4025,4033,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,1030,SUCCESS
    2200,2021-07-01 18:33:40,8817.247,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28188,517,517,8,55,77,1271,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4035,4023,4025,4024,4024,4026,4034,0,0,0,0,0,0,0,0,3115,25.8,25.8,-273.2,25.8,-273.2,34.7,1037,SUCCESS
    2201,2021-07-01 18:33:44,8821.258,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28191,517,517,8,55,77,1271,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4035,4023,4025,4024,4024,4026,4035,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1057,SUCCESS
    2202,2021-07-01 18:33:48,8825.257,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28193,516,517,8,55,77,1272,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4036,4023,4025,4024,4024,4026,4035,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.0,1031,SUCCESS
    2203,2021-07-01 18:33:52,8829.272,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28197,516,516,8,55,77,1272,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4036,4024,4025,4025,4025,4026,4035,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,1075,SUCCESS
    2204,2021-07-01 18:33:56,8833.287,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28199,516,516,8,55,77,1273,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4037,4024,4025,4026,4025,4027,4036,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1043,SUCCESS
    2205,2021-07-01 18:34:00,8837.291,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28201,516,516,8,55,77,1273,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4037,4024,4025,4026,4025,4028,4036,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1008,SUCCESS
    2206,2021-07-01 18:34:04,8841.303,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28203,517,516,8,55,77,1274,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4037,4025,4025,4026,4026,4028,4037,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,1028,SUCCESS
    2207,2021-07-01 18:34:08,8845.306,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28206,517,516,8,55,77,1275,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4037,4025,4025,4026,4026,4028,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1039,SUCCESS
    2208,2021-07-01 18:34:12,8849.309,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28208,516,516,8,55,77,1275,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4038,4025,4025,4027,4026,4029,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,956,SUCCESS
    2209,2021-07-01 18:34:16,8853.314,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28210,517,516,8,55,77,1276,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4038,4026,4025,4027,4027,4029,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,1064,SUCCESS
    2210,2021-07-01 18:34:20,8857.314,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28211,516,516,8,55,77,1276,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4039,4026,4025,4027,4028,4029,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.7,999,SUCCESS
    2211,2021-07-01 18:34:24,8861.323,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28215,517,517,8,55,77,1277,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4039,4026,4026,4028,4028,4030,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1008,SUCCESS
    2212,2021-07-01 18:34:28,8865.336,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28217,517,517,8,55,77,1277,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4040,4027,4026,4028,4028,4030,4038,0,0,0,0,0,0,0,0,3115,25.8,25.9,-273.2,25.9,-273.2,34.8,1024,SUCCESS
    2213,2021-07-01 18:34:32,8869.339,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28220,516,516,8,55,77,1278,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4040,4027,4027,4029,4028,4030,4038,0,0,0,0,0,0,0,0,3116,25.8,25.9,-273.2,25.9,-273.2,34.7,944,SUCCESS
    2214,2021-07-01 18:34:36,8873.349,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28221,516,516,8,55,77,1279,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4040,4027,4028,4029,4029,4031,4038,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,996,SUCCESS
    2215,2021-07-01 18:34:40,8877.362,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28223,517,516,8,55,77,1279,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4040,4028,4028,4029,4029,4031,4038,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.8,1001,SUCCESS
    2216,2021-07-01 18:34:44,8881.360,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28226,516,516,8,55,77,1280,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4041,4028,4029,4030,4029,4032,4038,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.2,1024,SUCCESS
    2217,2021-07-01 18:34:48,8885.366,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28229,516,516,8,55,77,1280,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4041,4029,4029,4030,4030,4030,4038,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.7,1067,SUCCESS
    2218,2021-07-01 18:34:52,8889.368,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28232,516,516,8,55,77,1281,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4042,4029,4029,4030,4030,4030,4040,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.8,992,SUCCESS
    2219,2021-07-01 18:34:56,8893.374,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28236,516,516,8,55,77,1282,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4042,4029,4030,4031,4031,4033,4040,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.8,1049,SUCCESS
    2220,2021-07-01 18:35:00,8897.375,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28237,516,516,8,55,77,1282,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4042,4030,4030,4031,4031,4029,4039,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,970,SUCCESS
    2221,2021-07-01 18:35:04,8901.380,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28239,517,516,8,55,77,1283,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4043,4030,4030,4032,4031,4034,4040,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.7,996,SUCCESS
    2222,2021-07-01 18:35:08,8905.386,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28242,518,517,8,55,77,1283,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4043,4030,4030,4033,4032,4035,4041,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,942,SUCCESS
    2223,2021-07-01 18:35:12,8909.395,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28246,516,517,8,55,78,1284,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4043,4031,4031,4033,4032,4035,4042,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,1092,SUCCESS
    2224,2021-07-01 18:35:16,8913.405,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28247,516,517,8,55,78,1284,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4043,4031,4032,4033,4032,4038,4042,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.7,1019,SUCCESS
    2225,2021-07-01 18:35:20,8917.408,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28250,517,517,8,55,78,1285,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4044,4031,4032,4033,4032,4040,4043,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.3,1099,SUCCESS
    2226,2021-07-01 18:35:24,8921.417,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28253,517,517,8,55,78,1286,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4045,4032,4032,4033,4033,4039,4043,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,959,SUCCESS
    2227,2021-07-01 18:35:28,8925.430,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28255,517,517,8,55,78,1286,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4045,4032,4033,4033,4033,4036,4043,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.8,977,SUCCESS
    2228,2021-07-01 18:35:32,8929.435,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28258,518,517,8,55,78,1287,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4045,4032,4033,4033,4034,4036,4043,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.7,956,SUCCESS
    2229,2021-07-01 18:35:36,8933.448,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28261,517,517,8,55,78,1287,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4046,4033,4034,4033,4034,4037,4044,0,0,0,0,0,0,0,0,3120,25.8,25.9,-273.2,25.9,-273.2,34.7,1021,SUCCESS
    2230,2021-07-01 18:35:40,8937.463,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28261,516,517,8,55,78,1288,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4046,4034,4034,4033,4035,4037,4044,0,0,0,0,0,0,0,0,3120,25.8,25.8,-273.2,25.8,-273.2,34.8,1084,SUCCESS
    2231,2021-07-01 18:35:44,8941.472,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28263,517,517,8,55,78,1288,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4046,4034,4034,4033,4035,4037,4044,0,0,0,0,0,0,0,0,3125,25.8,25.8,-273.2,25.8,-273.2,34.8,1030,SUCCESS
    2232,2021-07-01 18:35:48,8945.487,0x0701,150,10,0x6001,0,65535,65535,1,25.8,28266,516,517,8,55,78,1289,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4046,4034,4034,4034,4035,4037,4045,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,1047,SUCCESS
    2233,2021-07-01 18:35:52,8949.497,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28271,518,517,8,55,78,1290,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4047,4034,4035,4035,4036,4039,4045,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1053,SUCCESS
    2234,2021-07-01 18:35:56,8953.502,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28273,517,517,8,55,78,1290,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4047,4035,4035,4035,4036,4039,4045,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1079,SUCCESS
    2235,2021-07-01 18:36:00,8957.504,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28276,516,517,8,55,78,1291,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4048,4035,4035,4036,4036,4039,4046,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,1035,SUCCESS
    2236,2021-07-01 18:36:04,8961.509,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28279,517,517,8,55,78,1291,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4048,4035,4036,4036,4037,4040,4046,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,960,SUCCESS
    2237,2021-07-01 18:36:08,8965.516,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28283,516,517,8,55,78,1292,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4048,4036,4037,4037,4037,4041,4047,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1050,SUCCESS
    2238,2021-07-01 18:36:12,8969.517,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28284,517,517,8,55,78,1293,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4049,4036,4037,4037,4037,4041,4047,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,1092,SUCCESS
    2239,2021-07-01 18:36:16,8973.529,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28287,517,517,8,55,78,1293,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4049,4037,4037,4037,4038,4041,4047,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1003,SUCCESS
    2240,2021-07-01 18:36:20,8977.538,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28289,516,517,8,56,78,1294,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4049,4037,4038,4038,4038,4041,4048,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1025,SUCCESS
    2241,2021-07-01 18:36:24,8981.539,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28292,517,517,8,56,78,1294,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4050,4037,4038,4038,4039,4041,4049,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,993,SUCCESS
    2242,2021-07-01 18:36:28,8985.547,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28294,517,517,8,56,78,1295,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4051,4038,4038,4039,4039,4041,4049,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1019,SUCCESS
    2243,2021-07-01 18:36:32,8989.554,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28295,517,517,8,56,78,1295,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4051,4038,4039,4039,4039,4041,4049,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,947,SUCCESS
    2244,2021-07-01 18:36:36,8993.562,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28299,517,517,8,56,78,1296,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4051,4039,4039,4040,4040,4041,4050,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1064,SUCCESS
    2245,2021-07-01 18:36:40,8997.570,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28301,516,517,8,56,78,1297,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4052,4039,4040,4040,4040,4041,4050,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,993,SUCCESS
    2246,2021-07-01 18:36:44,9001.579,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28302,517,517,8,56,78,1297,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4052,4039,4040,4040,4040,4041,4050,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.7,1095,SUCCESS
    2247,2021-07-01 18:36:48,9005.582,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28307,517,517,8,56,78,1298,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4052,4040,4040,4041,4041,4042,4051,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1030,SUCCESS
    2248,2021-07-01 18:36:52,9009.591,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28309,516,517,8,56,78,1298,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4053,4040,4041,4041,4041,4043,4051,0,0,0,0,0,0,0,0,3125,25.8,25.9,-273.2,25.9,-273.2,34.8,1020,SUCCESS
    2249,2021-07-01 18:36:56,9013.599,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28314,517,517,8,56,78,1299,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4053,4041,4041,4041,4042,4044,4051,0,0,0,0,0,0,0,0,3126,25.8,25.9,-273.2,25.9,-273.2,34.7,1013,SUCCESS
    2250,2021-07-01 18:37:00,9017.614,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28315,517,517,8,56,78,1299,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4054,4041,4041,4042,4042,4043,4052,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1046,SUCCESS
    2251,2021-07-01 18:37:04,9021.627,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28317,517,516,8,56,78,1300,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4054,4041,4042,4042,4042,4044,4052,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.7,1078,SUCCESS
    2252,2021-07-01 18:37:08,9025.639,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28320,517,516,8,56,79,1301,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4054,4042,4042,4043,4043,4045,4053,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1050,SUCCESS
    2253,2021-07-01 18:37:12,9029.644,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28324,516,516,8,56,79,1301,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4055,4042,4043,4043,4043,4045,4053,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.7,1075,SUCCESS
    2254,2021-07-01 18:37:16,9033.646,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28326,516,516,8,56,79,1302,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4055,4043,4043,4043,4043,4045,4053,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,965,SUCCESS
    2255,2021-07-01 18:37:20,9037.647,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28330,516,517,8,56,79,1302,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4056,4043,4043,4044,4044,4046,4054,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1025,SUCCESS
    2256,2021-07-01 18:37:24,9041.656,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28332,516,516,8,56,79,1303,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4043,4044,4044,4044,4046,4055,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1048,SUCCESS
    2257,2021-07-01 18:37:28,9045.669,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28335,517,517,8,56,79,1303,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4044,4044,4045,4046,4055,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1084,SUCCESS
    2258,2021-07-01 18:37:32,9049.671,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28338,517,517,8,56,79,1304,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4044,4045,4045,4047,4055,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1003,SUCCESS
    2259,2021-07-01 18:37:36,9053.683,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28339,517,517,8,56,79,1305,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4045,4045,4045,4047,4055,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1036,SUCCESS
    2260,2021-07-01 18:37:40,9057.688,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28343,517,517,8,56,79,1305,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4045,4046,4046,4048,4056,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1034,SUCCESS
    2261,2021-07-01 18:37:44,9061.696,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28344,517,517,8,56,79,1306,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4046,4046,4046,4048,4056,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,961,SUCCESS
    2262,2021-07-01 18:37:48,9065.708,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28344,516,517,8,56,79,1306,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4046,4046,4046,4048,4057,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,980,SUCCESS
    2263,2021-07-01 18:37:52,9069.723,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28348,517,517,8,56,79,1307,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4046,4047,4047,4049,4057,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1060,SUCCESS
    2264,2021-07-01 18:37:56,9073.737,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28349,516,517,8,56,79,1307,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4047,4047,4047,4049,4057,0,0,0,0,0,0,0,0,3130,25.8,25.9,-273.2,25.9,-273.2,34.8,1029,SUCCESS
    2265,2021-07-01 18:38:00,9077.751,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28351,517,517,8,56,79,1308,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4057,4045,4047,4047,4048,4050,4058,0,0,0,0,0,0,0,0,3134,25.8,25.9,-273.2,25.9,-273.2,34.8,1015,SUCCESS
    2266,2021-07-01 18:38:04,9081.762,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28354,517,517,8,56,79,1309,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4058,4045,4048,4048,4048,4050,4058,0,0,0,0,0,0,0,0,3131,25.8,25.9,-273.2,25.9,-273.2,34.9,1088,SUCCESS
    2267,2021-07-01 18:38:08,9085.766,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28357,516,517,8,56,79,1309,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4059,4046,4048,4048,4048,4051,4059,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1063,SUCCESS
    2268,2021-07-01 18:38:12,9089.769,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28362,517,516,8,56,79,1310,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4059,4046,4048,4049,4049,4051,4059,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.7,1003,SUCCESS
    2269,2021-07-01 18:38:16,9093.777,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28364,516,516,8,56,79,1311,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4060,4047,4049,4049,4049,4051,4059,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1022,SUCCESS
    2270,2021-07-01 18:38:20,9097.785,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28367,515,516,8,56,79,1311,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4060,4048,4049,4049,4049,4052,4060,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1027,SUCCESS
    2271,2021-07-01 18:38:24,9101.794,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28370,516,516,8,56,79,1312,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4048,4049,4050,4050,4052,4060,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.2,1006,SUCCESS
    2272,2021-07-01 18:38:28,9105.796,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28373,516,516,8,56,79,1312,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4061,4049,4050,4050,4051,4052,4061,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1081,SUCCESS
    2273,2021-07-01 18:38:32,9109.804,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28375,516,516,8,56,79,1313,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4062,4049,4050,4051,4051,4052,4061,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1010,SUCCESS
    2274,2021-07-01 18:38:36,9113.811,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28375,515,516,8,56,79,1313,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4062,4050,4051,4051,4051,4053,4061,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1050,SUCCESS
    2275,2021-07-01 18:38:40,9117.817,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28377,515,516,8,56,79,1314,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4063,4050,4051,4052,4051,4054,4062,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1075,SUCCESS
    2276,2021-07-01 18:38:44,9121.824,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28380,516,516,8,56,79,1315,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4063,4050,4052,4052,4052,4055,4062,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1051,SUCCESS
    2277,2021-07-01 18:38:48,9125.828,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28387,516,516,8,56,79,1315,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4064,4051,4052,4052,4052,4054,4063,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1064,SUCCESS
    2278,2021-07-01 18:38:52,9129.837,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28391,515,516,8,56,79,1316,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4064,4051,4052,4053,4053,4055,4063,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1057,SUCCESS
    2279,2021-07-01 18:38:56,9133.839,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28394,516,516,8,56,79,1316,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4064,4052,4053,4053,4053,4055,4063,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1085,SUCCESS
    2280,2021-07-01 18:39:00,9137.845,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28397,515,516,8,56,80,1317,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4065,4052,4053,4053,4054,4056,4064,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1079,SUCCESS
    2281,2021-07-01 18:39:04,9141.846,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28402,516,516,8,56,80,1317,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4065,4052,4053,4054,4054,4056,4064,0,0,0,0,0,0,0,0,3135,25.8,25.9,-273.2,25.9,-273.2,34.8,1094,SUCCESS
    2282,2021-07-01 18:39:08,9145.860,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28404,516,516,8,57,80,1318,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4065,4053,4054,4054,4054,4057,4064,0,0,0,0,0,0,0,0,3139,25.8,25.9,-273.2,25.9,-273.2,34.8,1080,SUCCESS
    2283,2021-07-01 18:39:13,9149.870,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28404,516,516,8,57,80,1319,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4066,4053,4054,4055,4055,4057,4065,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,1055,SUCCESS
    2284,2021-07-01 18:39:17,9153.889,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28407,517,516,8,57,80,1319,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4066,4054,4055,4055,4055,4057,4066,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,955,SUCCESS
    2285,2021-07-01 18:39:21,9157.900,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28408,516,516,8,57,80,1320,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4066,4054,4055,4055,4055,4057,4066,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,1070,SUCCESS
    2286,2021-07-01 18:39:25,9161.912,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28411,516,516,8,57,80,1320,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4067,4054,4055,4056,4056,4057,4066,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,964,SUCCESS
    2287,2021-07-01 18:39:29,9165.927,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28412,516,516,8,57,80,1321,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4067,4055,4056,4056,4056,4058,4066,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,996,SUCCESS
    2288,2021-07-01 18:39:33,9169.939,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28417,517,516,8,57,80,1321,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4068,4055,4056,4056,4057,4059,4067,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,1062,SUCCESS
    2289,2021-07-01 18:39:37,9173.954,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28420,516,516,8,57,80,1322,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4068,4055,4057,4057,4057,4059,4067,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.7,1086,SUCCESS
    2290,2021-07-01 18:39:41,9177.961,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28422,517,516,8,57,80,1323,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4068,4056,4057,4057,4057,4060,4067,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,993,SUCCESS
    2291,2021-07-01 18:39:45,9181.962,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28426,517,516,8,57,80,1323,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4069,4056,4057,4058,4058,4060,4068,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.8,977,SUCCESS
    2292,2021-07-01 18:39:49,9185.969,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28428,515,516,8,57,80,1324,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4069,4057,4058,4058,4058,4060,4069,0,0,0,0,0,0,0,0,3140,25.8,25.9,-273.2,25.9,-273.2,34.7,1033,SUCCESS
    2293,2021-07-01 18:39:53,9189.980,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28430,516,516,8,57,80,1324,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4069,4057,4058,4058,4059,4061,4069,0,0,0,0,0,0,0,0,3140,25.9,25.9,-273.2,25.9,-273.2,34.8,1052,SUCCESS
    2294,2021-07-01 18:39:57,9193.986,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28433,516,516,8,57,80,1325,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4070,4057,4059,4059,4059,4061,4069,0,0,0,0,0,0,0,0,3140,25.8,26.0,-273.2,26.0,-273.2,34.8,1126,SUCCESS
    2295,2021-07-01 18:40:01,9198.001,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28439,516,516,8,57,80,1325,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4071,4058,4059,4060,4060,4062,4070,0,0,0,0,0,0,0,0,3140,25.8,26.0,-273.2,26.0,-273.2,34.8,1063,SUCCESS
    2296,2021-07-01 18:40:05,9202.016,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28440,516,516,8,57,80,1326,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4071,4058,4059,4060,4060,4062,4070,0,0,0,0,0,0,0,0,3140,25.9,26.0,-273.2,26.0,-273.2,34.8,1064,SUCCESS
    2297,2021-07-01 18:40:09,9206.019,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28442,515,516,8,57,80,1327,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4071,4059,4060,4060,4060,4062,4070,0,0,0,0,0,0,0,0,3140,25.9,25.9,-273.2,25.9,-273.2,34.8,1014,SUCCESS
    2298,2021-07-01 18:40:13,9210.034,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28446,516,516,8,57,80,1327,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4072,4059,4060,4060,4060,4063,4071,0,0,0,0,0,0,0,0,3141,25.8,25.9,-273.2,25.9,-273.2,34.8,1030,SUCCESS
    2299,2021-07-01 18:40:17,9214.057,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28447,515,516,8,57,80,1328,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4072,4060,4060,4061,4061,4063,4071,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,976,SUCCESS
    2300,2021-07-01 18:40:21,9218.063,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28451,516,516,8,57,80,1328,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4072,4060,4061,4061,4062,4061,4072,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1016,SUCCESS
    2301,2021-07-01 18:40:25,9222.070,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28453,515,516,8,57,80,1329,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4073,4060,4061,4062,4062,4060,4072,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1058,SUCCESS
    2302,2021-07-01 18:40:29,9226.081,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28457,517,516,8,57,80,1330,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4073,4061,4062,4062,4063,4064,4072,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1094,SUCCESS
    2303,2021-07-01 18:40:33,9230.082,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28461,515,516,8,57,80,1330,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4074,4061,4062,4062,4063,4066,4073,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1045,SUCCESS
    2304,2021-07-01 18:40:37,9234.096,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28461,515,516,8,57,80,1331,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4074,4061,4062,4063,4063,4065,4073,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1094,SUCCESS
    2305,2021-07-01 18:40:41,9238.109,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28462,517,516,8,57,80,1331,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4074,4061,4063,4063,4063,4066,4073,0,0,0,0,0,0,0,0,3145,25.8,25.9,-273.2,25.9,-273.2,34.8,1126,SUCCESS
    2306,2021-07-01 18:40:45,9242.109,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28466,517,516,8,57,80,1332,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4075,4062,4063,4063,4064,4067,4074,0,0,0,0,0,0,0,0,3145,25.9,25.9,-273.2,25.9,-273.2,34.8,987,SUCCESS
    2307,2021-07-01 18:40:49,9246.119,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28471,516,516,8,57,80,1332,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4075,4063,4064,4064,4065,4071,4074,0,0,0,0,0,0,0,0,3145,25.9,25.9,-273.2,25.9,-273.2,34.9,1106,SUCCESS
    2308,2021-07-01 18:40:53,9250.133,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28473,516,516,8,57,80,1333,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4075,4063,4064,4064,4065,4067,4075,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.9,947,SUCCESS
    2309,2021-07-01 18:40:57,9254.144,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28476,517,516,8,57,81,1334,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4076,4063,4064,4065,4066,4067,4075,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.8,1094,SUCCESS
    2310,2021-07-01 18:41:01,9258.157,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28479,516,516,8,57,81,1334,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4076,4064,4065,4065,4067,4067,4075,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.9,985,SUCCESS
    2311,2021-07-01 18:41:05,9262.169,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28483,516,516,8,57,81,1335,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4077,4064,4065,4066,4067,4068,4076,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.9,973,SUCCESS
    2312,2021-07-01 18:41:09,9266.180,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28484,515,516,8,57,81,1335,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4077,4064,4066,4066,4067,4068,4076,0,0,0,0,0,0,0,0,3145,25.8,26.0,-273.2,26.0,-273.2,34.8,986,SUCCESS
    2313,2021-07-01 18:41:13,9270.192,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28485,516,516,8,57,81,1336,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4077,4065,4066,4066,4067,4069,4077,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.8,1012,SUCCESS
    2314,2021-07-01 18:41:17,9274.195,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28488,516,516,8,57,81,1336,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4078,4065,4066,4067,4067,4069,4077,0,0,0,0,0,0,0,0,3145,25.9,26.0,-273.2,26.0,-273.2,34.9,963,SUCCESS
    2315,2021-07-01 18:41:21,9278.205,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28492,516,516,8,57,81,1337,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4078,4066,4067,4067,4067,4070,4078,0,0,0,0,0,0,0,0,3150,25.9,26.0,-273.2,26.0,-273.2,34.8,1019,SUCCESS
    2316,2021-07-01 18:41:25,9282.221,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28492,517,516,8,57,81,1338,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4079,4066,4067,4067,4067,4070,4078,0,0,0,0,0,0,0,0,3150,25.9,26.0,-273.2,26.0,-273.2,34.8,1061,SUCCESS
    2317,2021-07-01 18:41:29,9286.221,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28495,515,516,8,57,81,1338,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4079,4067,4068,4068,4067,4070,4078,0,0,0,0,0,0,0,0,3150,25.9,26.0,-273.2,26.0,-273.2,34.7,1072,SUCCESS
    2318,2021-07-01 18:41:33,9290.236,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28500,517,516,8,57,81,1339,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4080,4067,4068,4069,4067,4071,4079,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,1030,SUCCESS
    2319,2021-07-01 18:41:37,9294.244,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28502,516,516,8,57,81,1339,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4080,4067,4069,4069,4067,4071,4079,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,961,SUCCESS
    2320,2021-07-01 18:41:41,9298.249,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28504,516,516,8,57,81,1340,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4080,4068,4069,4069,4068,4071,4079,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.9,1081,SUCCESS
    2321,2021-07-01 18:41:45,9302.252,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28508,516,516,8,57,81,1340,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4081,4068,4069,4070,4069,4072,4080,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,1015,SUCCESS
    2322,2021-07-01 18:41:49,9306.254,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28511,516,516,8,58,81,1341,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4081,4069,4070,4070,4069,4072,4081,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,997,SUCCESS
    2323,2021-07-01 18:41:53,9310.261,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28512,516,516,8,58,81,1342,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4081,4069,4070,4070,4070,4072,4081,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.9,977,SUCCESS
    2324,2021-07-01 18:41:57,9314.266,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28516,516,516,8,58,81,1342,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4082,4069,4070,4071,4071,4073,4081,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.9,1047,SUCCESS
    2325,2021-07-01 18:42:01,9318.275,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28519,515,516,8,58,81,1343,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4082,4070,4071,4071,4071,4073,4081,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,960,SUCCESS
    2326,2021-07-01 18:42:05,9322.286,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28522,515,516,8,58,81,1343,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4083,4070,4071,4072,4071,4074,4082,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.9,1044,SUCCESS
    2327,2021-07-01 18:42:09,9326.296,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28524,517,516,8,58,81,1344,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4083,4070,4071,4072,4072,4074,4082,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.8,1032,SUCCESS
    2328,2021-07-01 18:42:13,9330.309,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28527,517,516,8,58,81,1344,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4083,4071,4072,4072,4072,4075,4083,0,0,0,0,0,0,0,0,3150,25.9,26.0,-273.2,26.0,-273.2,34.8,1004,SUCCESS
    2329,2021-07-01 18:42:17,9334.322,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28530,516,516,8,58,81,1345,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4084,4071,4072,4073,4073,4075,4083,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.9,1025,SUCCESS
    2330,2021-07-01 18:42:21,9338.321,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28533,516,516,8,58,81,1346,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4084,4072,4073,4073,4073,4075,4084,0,0,0,0,0,0,0,0,3150,25.9,25.9,-273.2,25.9,-273.2,34.2,950,SUCCESS
    2331,2021-07-01 18:42:25,9342.333,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28537,517,516,8,58,81,1346,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4085,4072,4073,4073,4073,4076,4084,0,0,0,0,0,0,0,0,3155,25.9,25.9,-273.2,25.9,-273.2,34.8,1027,SUCCESS
    2332,2021-07-01 18:42:29,9346.348,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28538,516,516,8,58,81,1347,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4085,4072,4073,4074,4074,4077,4084,0,0,0,0,0,0,0,0,3155,25.9,25.9,-273.2,25.9,-273.2,34.9,1011,SUCCESS
    2333,2021-07-01 18:42:33,9350.348,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28542,517,516,8,58,81,1347,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4085,4073,4074,4074,4074,4077,4085,0,0,0,0,0,0,0,0,3155,25.9,25.9,-273.2,25.9,-273.2,34.8,1042,SUCCESS
    2334,2021-07-01 18:42:37,9354.358,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28544,516,516,8,58,81,1348,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4086,4073,4074,4075,4074,4077,4085,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1032,SUCCESS
    2335,2021-07-01 18:42:41,9358.372,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28546,516,516,8,58,81,1349,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4086,4074,4075,4075,4075,4077,4086,0,0,0,0,0,0,0,0,3155,25.9,25.9,-273.2,25.9,-273.2,34.9,943,SUCCESS
    2336,2021-07-01 18:42:45,9362.379,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28550,517,516,8,58,81,1349,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4074,4075,4075,4075,4078,4086,0,0,0,0,0,0,0,0,3155,25.9,25.9,-273.2,25.9,-273.2,34.9,997,SUCCESS
    2337,2021-07-01 18:42:49,9366.389,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28553,516,516,8,58,81,1350,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4074,4075,4076,4076,4078,4086,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.9,1052,SUCCESS
    2338,2021-07-01 18:42:53,9370.403,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28556,516,516,8,58,81,1350,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4087,4075,4076,4076,4077,4079,4087,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1037,SUCCESS
    2339,2021-07-01 18:42:57,9374.416,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28558,515,516,8,58,82,1351,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4088,4075,4076,4076,4077,4079,4087,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1038,SUCCESS
    2340,2021-07-01 18:43:01,9378.425,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28560,516,516,8,58,82,1352,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4088,4076,4076,4077,4077,4080,4087,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1046,SUCCESS
    2341,2021-07-01 18:43:05,9382.429,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28565,516,516,8,58,82,1352,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4076,4077,4078,4077,4080,4088,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1042,SUCCESS
    2342,2021-07-01 18:43:09,9386.439,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28567,515,516,8,58,82,1353,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4077,4078,4078,4078,4080,4088,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1080,SUCCESS
    2343,2021-07-01 18:43:13,9390.453,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28570,516,516,8,58,82,1353,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4089,4077,4078,4078,4078,4081,4089,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1080,SUCCESS
    2344,2021-07-01 18:43:17,9394.455,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28572,516,516,8,58,82,1354,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4077,4078,4079,4079,4081,4089,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1048,SUCCESS
    2345,2021-07-01 18:43:21,9398.465,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28577,516,516,8,58,82,1354,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4090,4078,4079,4079,4079,4082,4090,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.8,1009,SUCCESS
    2346,2021-07-01 18:43:25,9402.474,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28579,516,516,8,58,82,1355,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4078,4079,4079,4080,4082,4090,0,0,0,0,0,0,0,0,3155,25.9,26.0,-273.2,26.0,-273.2,34.9,1082,SUCCESS
    2347,2021-07-01 18:43:29,9406.479,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28581,515,516,8,58,82,1356,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4091,4078,4080,4080,4080,4082,4090,0,0,0,0,0,0,0,0,3159,25.9,26.0,-273.2,26.0,-273.2,34.9,975,SUCCESS
    2348,2021-07-01 18:43:33,9410.492,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28584,517,516,8,58,82,1356,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4079,4080,4080,4080,4083,4091,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1041,SUCCESS
    2349,2021-07-01 18:43:37,9414.505,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28587,516,516,8,58,82,1357,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4079,4080,4081,4081,4083,4091,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,1059,SUCCESS
    2350,2021-07-01 18:43:41,9418.512,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28590,516,516,8,58,82,1357,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4080,4081,4081,4081,4083,4092,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1004,SUCCESS
    2351,2021-07-01 18:43:45,9422.517,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28591,516,516,8,58,82,1358,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4092,4080,4081,4081,4082,4084,4092,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1314,SUCCESS
    2352,2021-07-01 18:43:49,9426.527,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28595,515,516,8,58,82,1358,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4093,4080,4081,4082,4082,4084,4092,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1021,SUCCESS
    2353,2021-07-01 18:43:53,9430.529,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28597,517,516,8,58,82,1359,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4081,4082,4083,4082,4085,4093,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.2,947,SUCCESS
    2354,2021-07-01 18:43:57,9434.536,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28600,517,516,8,58,82,1360,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4081,4082,4083,4083,4085,4093,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,1028,SUCCESS
    2355,2021-07-01 18:44:01,9438.536,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28599,516,516,8,58,82,1360,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4094,4082,4083,4083,4083,4086,4093,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,953,SUCCESS
    2356,2021-07-01 18:44:05,9442.541,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28606,517,516,8,58,82,1361,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4082,4083,4084,4084,4086,4094,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1042,SUCCESS
    2357,2021-07-01 18:44:09,9446.543,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28608,517,516,8,58,82,1361,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4082,4083,4084,4084,4086,4094,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,974,SUCCESS
    2358,2021-07-01 18:44:13,9450.544,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28613,516,516,8,58,82,1362,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4095,4083,4084,4084,4084,4087,4095,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,957,SUCCESS
    2359,2021-07-01 18:44:17,9454.551,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28617,517,516,8,58,82,1362,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4083,4084,4085,4085,4087,4095,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.8,1045,SUCCESS
    2360,2021-07-01 18:44:21,9458.557,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28623,516,516,8,58,82,1363,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4096,4084,4085,4085,4085,4088,4095,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,1087,SUCCESS
    2361,2021-07-01 18:44:25,9462.569,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28623,516,516,8,58,82,1364,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4084,4085,4085,4085,4088,4096,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,1013,SUCCESS
    2362,2021-07-01 18:44:29,9466.584,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28623,516,516,8,58,82,1364,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4097,4084,4086,4086,4086,4088,4096,0,0,0,0,0,0,0,0,3160,25.9,25.9,-273.2,25.9,-273.2,34.2,999,SUCCESS
    2363,2021-07-01 18:44:33,9470.586,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28626,515,516,8,59,82,1365,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4085,4086,4086,4086,4089,4096,0,0,0,0,0,0,0,0,3160,25.9,26.0,-273.2,26.0,-273.2,34.9,1041,SUCCESS
    2364,2021-07-01 18:44:37,9474.589,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28629,517,516,8,59,82,1365,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4085,4086,4087,4087,4089,4097,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1037,SUCCESS
    2365,2021-07-01 18:44:41,9478.604,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28632,516,516,8,59,82,1366,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4098,4086,4087,4087,4087,4089,4097,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.8,992,SUCCESS
    2366,2021-07-01 18:44:45,9482.610,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28633,516,516,8,59,83,1367,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4086,4087,4087,4088,4090,4098,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1094,SUCCESS
    2367,2021-07-01 18:44:49,9486.620,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28636,516,516,8,59,83,1367,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4086,4087,4088,4088,4090,4098,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,959,SUCCESS
    2368,2021-07-01 18:44:53,9490.627,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28640,516,516,8,59,83,1368,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4099,4087,4088,4088,4089,4091,4099,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1063,SUCCESS
    2369,2021-07-01 18:44:57,9494.628,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28643,517,516,8,59,83,1368,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4087,4088,4089,4089,4091,4099,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1062,SUCCESS
    2370,2021-07-01 18:45:01,9498.636,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28644,517,516,8,59,83,1369,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4100,4087,4089,4089,4089,4091,4099,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1023,SUCCESS
    2371,2021-07-01 18:45:05,9502.650,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28649,516,516,8,59,83,1369,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4088,4089,4089,4090,4092,4100,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,980,SUCCESS
    2372,2021-07-01 18:45:09,9506.659,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28650,517,516,8,59,83,1370,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4089,4089,4090,4090,4092,4100,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1015,SUCCESS
    2373,2021-07-01 18:45:13,9510.669,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28654,516,516,8,59,83,1371,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4089,4090,4090,4091,4092,4101,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,957,SUCCESS
    2374,2021-07-01 18:45:17,9514.679,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28655,515,516,8,59,83,1371,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4101,4089,4090,4091,4091,4093,4101,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.8,1016,SUCCESS
    2375,2021-07-01 18:45:21,9518.695,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28658,517,516,8,59,83,1372,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4102,4090,4091,4091,4091,4093,4101,0,0,0,0,0,0,0,0,3165,25.9,25.9,-273.2,25.9,-273.2,34.8,1026,SUCCESS
    2376,2021-07-01 18:45:25,9522.706,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28663,516,516,8,59,83,1372,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4090,4091,4092,4092,4094,4102,0,0,0,0,0,0,0,0,3165,25.9,25.9,-273.2,25.9,-273.2,34.3,1052,SUCCESS
    2377,2021-07-01 18:45:29,9526.713,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28664,516,516,8,59,83,1373,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4090,4091,4092,4092,4093,4102,0,0,0,0,0,0,0,0,3165,25.9,25.9,-273.2,25.9,-273.2,34.8,991,SUCCESS
    2378,2021-07-01 18:45:33,9530.717,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28665,517,516,8,59,83,1373,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4103,4091,4092,4092,4092,4093,4103,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1053,SUCCESS
    2379,2021-07-01 18:45:37,9534.731,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28669,516,516,8,59,83,1374,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4091,4092,4093,4092,4094,4102,0,0,0,0,0,0,0,0,3165,25.9,26.0,-273.2,26.0,-273.2,34.9,1100,SUCCESS
    2380,2021-07-01 18:45:41,9538.744,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28673,516,516,8,59,83,1375,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4092,4093,4093,4093,4092,4104,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,991,SUCCESS
    2381,2021-07-01 18:45:45,9542.753,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28675,515,516,8,59,83,1375,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4104,4092,4093,4093,4094,4095,4104,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.8,1048,SUCCESS
    2382,2021-07-01 18:45:49,9546.762,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28678,515,516,8,59,83,1376,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4092,4093,4094,4094,4096,4104,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.8,992,SUCCESS
    2383,2021-07-01 18:45:53,9550.773,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28681,517,516,8,59,83,1376,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4105,4093,4094,4094,4094,4097,4104,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,996,SUCCESS
    2384,2021-07-01 18:45:57,9554.782,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28683,516,516,8,59,83,1377,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4093,4094,4094,4095,4099,4105,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.8,1093,SUCCESS
    2385,2021-07-01 18:46:01,9558.783,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28686,516,516,8,59,83,1377,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4106,4093,4095,4095,4095,4102,4105,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1048,SUCCESS
    2386,2021-07-01 18:46:05,9562.791,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28689,516,516,8,59,83,1378,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4094,4095,4095,4095,4103,4106,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1009,SUCCESS
    2387,2021-07-01 18:46:09,9566.799,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28692,516,516,8,59,83,1379,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4107,4094,4095,4096,4096,4098,4106,0,0,0,0,0,0,0,0,3170,25.9,25.9,-273.2,26.0,-273.2,34.8,1015,SUCCESS
    2388,2021-07-01 18:46:13,9570.802,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28695,516,516,8,59,83,1379,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4095,4096,4096,4096,4098,4107,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1060,SUCCESS
    2389,2021-07-01 18:46:17,9574.816,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28698,517,516,8,59,83,1380,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4095,4096,4096,4097,4099,4107,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1013,SUCCESS
    2390,2021-07-01 18:46:21,9578.818,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28699,517,516,8,59,83,1380,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4108,4095,4096,4097,4097,4099,4107,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.8,1011,SUCCESS
    2391,2021-07-01 18:46:25,9582.833,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28702,517,517,8,59,83,1381,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4109,4096,4097,4097,4097,4099,4108,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1041,SUCCESS
    2392,2021-07-01 18:46:29,9586.844,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28706,515,517,8,59,83,1382,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4109,4096,4097,4098,4098,4100,4108,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1048,SUCCESS
    2393,2021-07-01 18:46:33,9590.853,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28708,517,517,8,59,83,1382,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4109,4096,4098,4098,4098,4101,4109,0,0,0,0,0,0,0,0,3170,25.9,26.0,-273.2,26.0,-273.2,34.9,1025,SUCCESS
    2394,2021-07-01 18:46:37,9594.863,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28711,517,517,8,59,83,1383,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4110,4097,4098,4098,4099,4101,4109,0,0,0,0,0,0,0,0,3170,25.9,25.9,-273.2,25.9,-273.2,34.9,1187,SUCCESS
    2395,2021-07-01 18:46:42,9598.876,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28713,516,516,8,59,83,1383,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4110,4097,4098,4099,4099,4101,4109,0,0,0,0,0,0,0,0,3170,25.9,25.9,-273.2,25.9,-273.2,34.8,1035,SUCCESS
    2396,2021-07-01 18:46:46,9602.884,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28718,517,516,8,59,84,1384,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4111,4098,4099,4099,4099,4102,4109,0,0,0,0,0,0,0,0,3170,25.9,25.9,-273.2,25.9,-273.2,34.9,1018,SUCCESS
    2397,2021-07-01 18:46:50,9606.899,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28719,516,516,8,59,84,1384,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4111,4098,4099,4099,4100,4102,4110,0,0,0,0,0,0,0,0,3171,25.9,25.9,-273.2,25.9,-273.2,34.9,1027,SUCCESS
    2398,2021-07-01 18:46:54,9610.912,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28720,515,516,8,59,84,1385,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4111,4098,4099,4100,4100,4103,4110,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.8,1075,SUCCESS
    2399,2021-07-01 18:46:58,9614.925,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28726,516,516,8,59,84,1386,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4099,4100,4100,4100,4103,4110,0,0,0,0,0,0,0,0,3175,25.9,26.0,-273.2,26.0,-273.2,34.9,1030,SUCCESS
    2400,2021-07-01 18:47:02,9618.937,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28727,516,516,8,59,84,1386,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4099,4100,4101,4101,4103,4111,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,26.0,-273.2,34.9,1048,SUCCESS
    2401,2021-07-01 18:47:06,9622.970,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28730,516,516,8,59,84,1387,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4100,4101,4101,4101,4103,4112,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.9,969,SUCCESS
    2402,2021-07-01 18:47:10,9626.971,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28731,516,516,8,59,84,1387,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4112,4100,4101,4101,4101,4104,4112,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.8,1031,SUCCESS
    2403,2021-07-01 18:47:14,9630.971,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28734,515,516,8,60,84,1388,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4113,4100,4102,4102,4102,4105,4112,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.9,1061,SUCCESS
    2404,2021-07-01 18:47:18,9634.985,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28739,517,516,8,60,84,1389,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4101,4102,4102,4103,4105,4113,0,0,0,0,0,0,0,0,3175,25.9,26.0,-273.2,26.0,-273.2,34.9,1048,SUCCESS
    2405,2021-07-01 18:47:22,9638.987,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28740,516,516,8,60,84,1389,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4101,4102,4102,4103,4105,4113,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.9,1045,SUCCESS
    2406,2021-07-01 18:47:26,9643.000,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28742,515,516,8,60,84,1390,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4114,4102,4103,4103,4103,4105,4113,0,0,0,0,0,0,0,0,3175,26.0,25.9,-273.2,26.0,-273.2,34.9,1032,SUCCESS
    2407,2021-07-01 18:47:30,9647.008,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28747,515,516,8,60,84,1390,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4115,4102,4103,4104,4104,4106,4114,0,0,0,0,0,0,0,0,3175,26.0,25.9,-273.2,26.0,-273.2,34.9,1041,SUCCESS
    2408,2021-07-01 18:47:34,9651.020,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28748,516,516,8,60,84,1391,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4115,4103,4104,4104,4104,4106,4114,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,26.0,-273.2,35.0,1063,SUCCESS
    2409,2021-07-01 18:47:38,9655.030,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28753,516,516,8,60,84,1391,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4115,4103,4104,4104,4105,4107,4115,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.9,1097,SUCCESS
    2410,2021-07-01 18:47:42,9659.030,0x0701,150,10,0x6001,0,65535,65535,1,25.9,28754,515,516,8,60,84,1392,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4116,4103,4104,4105,4105,4107,4115,0,0,0,0,0,0,0,0,3175,25.9,25.9,-273.2,25.9,-273.2,34.8,1072,SUCCESS
    2411,2021-07-01 18:47:46,9663.034,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28757,516,516,8,60,84,1393,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4116,4103,4104,4105,4105,4107,4115,0,0,0,0,0,0,0,0,3175,25.9,26.0,-273.2,26.0,-273.2,34.9,1045,SUCCESS
    2412,2021-07-01 18:47:50,9667.049,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28762,515,516,8,60,84,1393,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4104,4105,4106,4106,4108,4116,0,0,0,0,0,0,0,0,3175,25.9,26.0,-273.2,26.0,-273.2,34.8,1064,SUCCESS
    2413,2021-07-01 18:47:54,9671.053,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28762,515,516,8,60,84,1394,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4104,4105,4106,4106,4108,4116,0,0,0,0,0,0,0,0,3175,26.0,26.0,-273.2,26.0,-273.2,34.9,996,SUCCESS
    2414,2021-07-01 18:47:58,9675.055,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28765,517,516,8,60,84,1394,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4105,4106,4106,4106,4109,4116,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,1009,SUCCESS
    2415,2021-07-01 18:48:02,9679.066,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28768,516,516,8,60,84,1395,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4117,4105,4106,4107,4106,4109,4117,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.8,1045,SUCCESS
    2416,2021-07-01 18:48:06,9683.082,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28769,516,516,8,60,84,1395,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4118,4105,4106,4107,4107,4109,4117,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2417,2021-07-01 18:48:10,9687.083,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28772,515,516,8,60,84,1396,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4118,4106,4107,4107,4107,4109,4118,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.3,1033,SUCCESS
    2418,2021-07-01 18:48:14,9691.094,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28775,515,516,8,60,84,1397,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4106,4107,4108,4108,4110,4118,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,35.0,1023,SUCCESS
    2419,2021-07-01 18:48:18,9695.098,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28776,516,516,8,60,84,1397,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4107,4108,4108,4108,4110,4118,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.8,1013,SUCCESS
    2420,2021-07-01 18:48:22,9699.114,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28781,517,516,8,60,84,1398,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4119,4107,4108,4109,4109,4110,4119,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.8,1107,SUCCESS
    2421,2021-07-01 18:48:26,9703.122,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28784,517,516,8,60,84,1398,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4120,4107,4109,4109,4109,4111,4119,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,989,SUCCESS
    2422,2021-07-01 18:48:30,9707.129,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28786,515,516,8,60,84,1399,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4120,4108,4109,4109,4109,4112,4119,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,1044,SUCCESS
    2423,2021-07-01 18:48:34,9711.136,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28789,515,516,8,60,84,1399,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4108,4109,4110,4109,4112,4120,0,0,0,0,0,0,0,0,3180,26.0,26.0,-273.2,26.0,-273.2,34.9,1070,SUCCESS
    2424,2021-07-01 18:48:38,9715.146,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28790,515,516,8,60,84,1400,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4108,4109,4110,4110,4112,4120,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,997,SUCCESS
    2425,2021-07-01 18:48:42,9719.159,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28793,515,516,8,60,85,1401,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4121,4109,4110,4110,4111,4112,4121,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,35.0,1127,SUCCESS
    2426,2021-07-01 18:48:46,9723.167,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28797,516,516,8,60,85,1401,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4122,4109,4110,4110,4111,4113,4121,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,1013,SUCCESS
    2427,2021-07-01 18:48:50,9727.175,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28798,516,516,8,60,85,1402,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4122,4110,4110,4111,4111,4113,4121,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.8,1038,SUCCESS
    2428,2021-07-01 18:48:54,9731.188,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28803,515,516,8,60,85,1402,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4110,4111,4112,4112,4114,4122,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.8,1015,SUCCESS
    2429,2021-07-01 18:48:58,9735.196,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28805,516,516,8,60,85,1403,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4110,4112,4112,4112,4114,4122,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2430,2021-07-01 18:49:02,9739.199,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28806,515,516,8,60,85,1404,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4123,4110,4112,4112,4112,4114,4122,0,0,0,0,0,0,0,0,3180,26.0,25.9,-273.2,26.0,-273.2,35.0,1039,SUCCESS
    2431,2021-07-01 18:49:06,9743.211,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28810,516,516,8,60,85,1404,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4124,4111,4112,4113,4113,4115,4123,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.9,980,SUCCESS
    2432,2021-07-01 18:49:10,9747.227,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28811,516,516,8,60,85,1405,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4124,4111,4112,4113,4113,4115,4123,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.9,1055,SUCCESS
    2433,2021-07-01 18:49:14,9751.230,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28813,515,516,8,60,85,1405,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4124,4112,4113,4113,4114,4115,4124,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,35.0,1069,SUCCESS
    2434,2021-07-01 18:49:18,9755.232,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28815,516,516,8,60,85,1406,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4112,4113,4113,4114,4115,4124,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,35.0,1052,SUCCESS
    2435,2021-07-01 18:49:22,9759.239,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28817,516,516,8,60,85,1406,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4112,4113,4114,4114,4116,4124,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2436,2021-07-01 18:49:26,9763.246,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28823,516,515,8,60,85,1407,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4125,4113,4114,4115,4115,4117,4125,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,35.0,976,SUCCESS
    2437,2021-07-01 18:49:30,9767.247,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28820,515,515,8,60,85,1408,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4126,4113,4114,4115,4115,4117,4125,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,34.9,1097,SUCCESS
    2438,2021-07-01 18:49:34,9771.247,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28826,514,516,8,60,85,1408,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4126,4113,4115,4115,4115,4117,4125,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,34.9,1021,SUCCESS
    2439,2021-07-01 18:49:38,9775.258,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28829,516,516,8,60,85,1409,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4114,4115,4115,4115,4118,4126,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2440,2021-07-01 18:49:42,9779.263,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28834,516,516,8,60,85,1409,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4114,4115,4116,4116,4118,4126,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,35.0,1050,SUCCESS
    2441,2021-07-01 18:49:46,9783.268,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28837,516,516,8,60,85,1410,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4115,4116,4116,4117,4118,4127,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,35.0,1063,SUCCESS
    2442,2021-07-01 18:49:50,9787.275,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28841,516,516,8,60,85,1410,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4127,4115,4116,4116,4117,4119,4127,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,35.0,993,SUCCESS
    2443,2021-07-01 18:49:54,9791.291,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28844,516,516,8,60,85,1411,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4128,4115,4116,4117,4117,4119,4127,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.9,1077,SUCCESS
    2444,2021-07-01 18:49:58,9795.298,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28841,515,516,8,61,85,1412,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4128,4116,4117,4117,4117,4119,4127,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.4,1022,SUCCESS
    2445,2021-07-01 18:50:02,9799.301,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28844,515,516,8,61,85,1412,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4129,4116,4117,4118,4117,4119,4128,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.9,1044,SUCCESS
    2446,2021-07-01 18:50:06,9803.306,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28847,516,515,8,61,85,1413,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4129,4116,4118,4118,4118,4120,4128,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,35.0,1010,SUCCESS
    2447,2021-07-01 18:50:10,9807.319,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28848,515,515,8,61,85,1413,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4129,4117,4118,4118,4118,4120,4128,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.9,1010,SUCCESS
    2448,2021-07-01 18:50:14,9811.326,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28850,515,515,8,61,85,1414,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4130,4117,4118,4119,4119,4120,4129,0,0,0,0,0,0,0,0,3185,26.0,25.9,-273.2,26.0,-273.2,34.8,1074,SUCCESS
    2449,2021-07-01 18:50:18,9815.328,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28855,515,515,8,61,85,1414,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4130,4118,4119,4119,4119,4121,4129,0,0,0,0,0,0,0,0,3185,26.0,26.0,-273.2,26.0,-273.2,35.0,992,SUCCESS
    2450,2021-07-01 18:50:22,9819.328,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28858,516,515,8,61,85,1415,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4131,4118,4119,4119,4120,4121,4130,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1033,SUCCESS
    2451,2021-07-01 18:50:26,9823.335,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28860,515,515,8,61,85,1416,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4131,4118,4119,4120,4120,4122,4130,0,0,0,0,0,0,0,0,3190,26.0,25.9,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2452,2021-07-01 18:50:30,9827.347,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28862,516,515,8,61,85,1416,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4131,4119,4119,4120,4120,4122,4130,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1015,SUCCESS
    2453,2021-07-01 18:50:34,9831.354,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28865,515,515,8,61,86,1417,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4132,4119,4120,4121,4120,4122,4130,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1008,SUCCESS
    2454,2021-07-01 18:50:38,9835.366,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28867,515,515,8,61,86,1417,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4132,4119,4120,4121,4121,4123,4131,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1011,SUCCESS
    2455,2021-07-01 18:50:42,9839.379,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28868,515,515,8,61,86,1418,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4132,4120,4121,4121,4121,4123,4131,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1076,SUCCESS
    2456,2021-07-01 18:50:46,9843.393,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28870,516,515,8,61,86,1418,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4132,4120,4121,4122,4121,4123,4132,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1045,SUCCESS
    2457,2021-07-01 18:50:50,9847.403,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28874,516,515,8,61,86,1419,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4133,4121,4121,4122,4122,4124,4132,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1069,SUCCESS
    2458,2021-07-01 18:50:54,9851.409,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28877,515,515,8,61,86,1420,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4134,4121,4122,4122,4122,4124,4132,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1048,SUCCESS
    2459,2021-07-01 18:50:58,9855.409,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28880,515,516,8,61,86,1420,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4134,4121,4122,4123,4123,4124,4133,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1027,SUCCESS
    2460,2021-07-01 18:51:02,9859.423,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28881,515,516,8,61,86,1421,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4134,4121,4122,4123,4122,4124,4133,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1015,SUCCESS
    2461,2021-07-01 18:51:06,9863.427,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28883,515,516,8,61,86,1421,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4134,4122,4123,4124,4123,4124,4133,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1062,SUCCESS
    2462,2021-07-01 18:51:10,9867.441,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28887,516,516,8,61,86,1422,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4135,4122,4123,4124,4123,4124,4134,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1016,SUCCESS
    2463,2021-07-01 18:51:14,9871.456,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28888,514,515,8,61,86,1423,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4135,4123,4124,4124,4124,4124,4134,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1015,SUCCESS
    2464,2021-07-01 18:51:18,9875.469,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28891,515,515,8,61,86,1423,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4135,4123,4124,4124,4124,4124,4134,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1017,SUCCESS
    2465,2021-07-01 18:51:22,9879.477,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28894,514,515,8,61,86,1424,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4136,4123,4124,4125,4125,4122,4135,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,35.0,1041,SUCCESS
    2466,2021-07-01 18:51:26,9883.485,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28896,516,515,8,61,86,1424,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4136,4124,4124,4125,4126,4125,4135,0,0,0,0,0,0,0,0,3190,26.0,26.0,-273.2,26.0,-273.2,34.9,1003,SUCCESS
    2467,2021-07-01 18:51:30,9887.491,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28898,516,515,8,61,86,1425,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4137,4124,4125,4125,4125,4128,4135,0,0,0,0,0,0,0,0,3194,26.0,26.0,-273.2,26.0,-273.2,34.3,1047,SUCCESS
    2468,2021-07-01 18:51:34,9891.500,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28901,516,515,8,61,86,1425,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4137,4124,4125,4125,4126,4129,4136,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,35.0,1094,SUCCESS
    2469,2021-07-01 18:51:38,9895.503,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28903,516,515,8,61,86,1426,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4137,4124,4126,4126,4126,4130,4136,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.8,1034,SUCCESS
    2470,2021-07-01 18:51:42,9899.514,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28904,515,515,8,61,86,1427,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4137,4125,4126,4126,4126,4131,4136,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.8,1002,SUCCESS
    2471,2021-07-01 18:51:46,9903.524,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28909,515,515,8,61,86,1427,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4125,4126,4127,4126,4129,4137,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.8,963,SUCCESS
    2472,2021-07-01 18:51:50,9907.529,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28911,515,515,8,61,86,1428,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4126,4127,4127,4127,4129,4137,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.8,956,SUCCESS
    2473,2021-07-01 18:51:54,9911.536,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28911,516,515,8,61,86,1428,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4126,4127,4127,4127,4129,4138,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.9,1015,SUCCESS
    2474,2021-07-01 18:51:58,9915.536,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28915,516,515,8,61,86,1429,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4126,4127,4128,4128,4129,4138,0,0,0,0,0,0,0,0,3195,25.9,26.0,-273.2,26.0,-273.2,35.0,1002,SUCCESS
    2475,2021-07-01 18:52:02,9919.544,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28917,515,515,8,61,86,1429,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4127,4127,4128,4128,4130,4138,0,0,0,0,0,0,0,0,3195,25.9,26.0,-273.2,26.0,-273.2,35.0,1021,SUCCESS
    2476,2021-07-01 18:52:06,9923.558,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28919,516,515,8,61,86,1430,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4127,4128,4129,4128,4130,4138,0,0,0,0,0,0,0,0,3195,25.9,26.0,-273.2,26.0,-273.2,35.0,1024,SUCCESS
    2477,2021-07-01 18:52:10,9927.565,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28922,516,515,8,61,86,1431,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4127,4128,4129,4129,4130,4139,0,0,0,0,0,0,0,0,3195,25.9,26.0,-273.2,26.0,-273.2,35.0,1017,SUCCESS
    2478,2021-07-01 18:52:14,9931.581,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28924,516,516,8,61,86,1431,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4127,4129,4129,4129,4131,4139,0,0,0,0,0,0,0,0,3195,25.9,26.0,-273.2,26.0,-273.2,34.9,1110,SUCCESS
    2479,2021-07-01 18:52:18,9935.585,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28926,515,516,8,61,86,1432,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4128,4129,4130,4129,4131,4139,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,35.0,993,SUCCESS
    2480,2021-07-01 18:52:22,9939.600,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28929,515,516,8,61,86,1432,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4128,4129,4130,4130,4132,4140,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.9,1010,SUCCESS
    2481,2021-07-01 18:52:26,9943.606,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28931,515,515,8,61,86,1433,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4129,4130,4130,4130,4132,4140,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.3,1090,SUCCESS
    2482,2021-07-01 18:52:30,9947.616,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28932,515,515,8,61,86,1433,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4129,4130,4130,4130,4132,4140,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,35.0,965,SUCCESS
    2483,2021-07-01 18:52:34,9951.628,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28936,515,516,8,61,87,1434,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4129,4130,4131,4131,4132,4140,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.9,1031,SUCCESS
    2484,2021-07-01 18:52:38,9955.639,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28937,515,516,8,62,87,1435,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4130,4130,4131,4131,4133,4141,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.9,1051,SUCCESS
    2485,2021-07-01 18:52:42,9959.648,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28939,517,516,8,62,87,1435,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4130,4131,4131,4131,4133,4141,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,34.9,1012,SUCCESS
    2486,2021-07-01 18:52:46,9963.662,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28943,516,516,8,62,87,1436,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4130,4131,4132,4131,4134,4141,0,0,0,0,0,0,0,0,3195,26.0,26.0,-273.2,26.0,-273.2,35.0,981,SUCCESS
    2487,2021-07-01 18:52:50,9967.673,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28946,516,516,8,62,87,1436,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4131,4132,4132,4132,4134,4142,0,0,0,0,0,0,0,0,3196,25.9,26.0,-273.2,26.0,-273.2,34.9,1117,SUCCESS
    2488,2021-07-01 18:52:54,9971.676,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28947,516,516,8,62,87,1437,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4131,4132,4132,4132,4134,4142,0,0,0,0,0,0,0,0,3199,25.9,26.0,-273.2,26.0,-273.2,35.0,1090,SUCCESS
    2489,2021-07-01 18:52:58,9975.678,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28949,515,516,8,62,87,1437,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4131,4132,4133,4133,4134,4142,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1057,SUCCESS
    2490,2021-07-01 18:53:02,9979.680,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28951,515,516,8,62,87,1438,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4132,4132,4133,4133,4134,4142,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1012,SUCCESS
    2491,2021-07-01 18:53:06,9983.680,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28953,516,516,8,62,87,1439,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4132,4132,4133,4133,4135,4143,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1041,SUCCESS
    2492,2021-07-01 18:53:10,9987.693,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28953,516,516,8,62,87,1439,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4132,4133,4133,4133,4135,4143,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1058,SUCCESS
    2493,2021-07-01 18:53:14,9991.704,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28958,516,516,8,62,87,1440,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4133,4133,4134,4134,4135,4144,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1188,SUCCESS
    2494,2021-07-01 18:53:18,9995.713,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28959,516,516,8,62,87,1441,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4133,4133,4134,4134,4136,4144,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,977,SUCCESS
    2495,2021-07-01 18:53:22,9999.722,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28963,516,516,8,62,87,1441,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4133,4134,4135,4134,4137,4144,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1078,SUCCESS
    2496,2021-07-01 18:53:26,10003.724,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28964,516,516,8,62,87,1442,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4133,4134,4135,4135,4137,4144,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,998,SUCCESS
    2497,2021-07-01 18:53:30,10007.739,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28966,515,516,8,62,87,1442,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4133,4135,4135,4135,4137,4144,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1056,SUCCESS
    2498,2021-07-01 18:53:34,10011.753,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28968,516,516,8,62,87,1443,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4134,4135,4136,4135,4137,4145,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1045,SUCCESS
    2499,2021-07-01 18:53:38,10015.754,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28970,515,516,8,62,87,1443,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4135,4135,4136,4136,4137,4145,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1062,SUCCESS
    2500,2021-07-01 18:53:42,10019.761,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28972,516,516,8,62,87,1444,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4135,4135,4136,4136,4138,4145,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1009,SUCCESS
    2501,2021-07-01 18:53:46,10023.771,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28974,516,516,8,62,87,1445,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4135,4136,4136,4136,4138,4146,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1029,SUCCESS
    2502,2021-07-01 18:53:50,10027.778,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28976,516,516,8,62,87,1445,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4135,4136,4137,4137,4138,4146,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1146,SUCCESS
    2503,2021-07-01 18:53:54,10031.789,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28978,516,516,8,62,87,1446,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4135,4136,4137,4137,4138,4147,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1041,SUCCESS
    2504,2021-07-01 18:53:58,10035.804,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28979,515,516,8,62,87,1446,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4136,4137,4137,4137,4138,4147,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,1044,SUCCESS
    2505,2021-07-01 18:54:02,10039.810,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28982,515,516,8,62,87,1447,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4136,4137,4138,4137,4138,4147,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,1034,SUCCESS
    2506,2021-07-01 18:54:06,10043.818,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28983,516,515,8,62,87,1447,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4136,4137,4138,4137,4138,4147,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,35.0,998,SUCCESS
    2507,2021-07-01 18:54:10,10047.828,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28987,516,516,8,62,87,1448,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4136,4137,4138,4138,4140,4147,0,0,0,0,0,0,0,0,3200,25.9,26.0,-273.2,26.0,-273.2,34.9,970,SUCCESS
    2508,2021-07-01 18:54:14,10051.830,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28988,515,516,8,62,87,1449,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4137,4138,4138,4138,4140,4148,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,34.9,1046,SUCCESS
    2509,2021-07-01 18:54:18,10055.833,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28990,515,516,8,62,87,1449,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4138,4138,4139,4138,4140,4148,0,0,0,0,0,0,0,0,3200,26.0,26.1,-273.2,26.1,-273.2,35.0,1113,SUCCESS
    2510,2021-07-01 18:54:22,10059.840,0x0701,150,10,0x6001,0,65535,65535,1,26.1,28991,516,516,8,62,87,1450,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4138,4138,4139,4139,4140,4148,0,0,0,0,0,0,0,0,3200,26.0,26.1,-273.2,26.1,-273.2,35.0,944,SUCCESS
    2511,2021-07-01 18:54:26,10063.852,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28994,517,516,8,62,87,1450,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4138,4139,4139,4139,4141,4149,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1072,SUCCESS
    2512,2021-07-01 18:54:30,10067.863,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28997,516,516,8,62,88,1451,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4138,4139,4140,4139,4141,4149,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1061,SUCCESS
    2513,2021-07-01 18:54:35,10071.874,0x0701,150,10,0x6001,0,65535,65535,1,26.0,28999,516,516,8,62,88,1451,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4139,4139,4140,4140,4141,4150,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,34.9,1067,SUCCESS
    2514,2021-07-01 18:54:39,10075.887,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29000,516,516,8,62,88,1452,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4139,4139,4140,4140,4141,4150,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1069,SUCCESS
    2515,2021-07-01 18:54:43,10079.907,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29003,515,516,8,62,88,1453,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4139,4140,4141,4140,4142,4150,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,968,SUCCESS
    2516,2021-07-01 18:54:47,10083.908,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29003,516,516,8,62,88,1453,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4139,4140,4141,4140,4142,4150,0,0,0,0,0,0,0,0,3205,26.0,26.1,-273.2,26.0,-273.2,34.9,1012,SUCCESS
    2517,2021-07-01 18:54:51,10087.916,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29006,515,516,8,62,88,1454,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4140,4140,4141,4141,4142,4151,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.1,-273.2,35.0,975,SUCCESS
    2518,2021-07-01 18:54:55,10091.929,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29007,515,516,8,62,88,1454,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4140,4141,4141,4141,4143,4151,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1025,SUCCESS
    2519,2021-07-01 18:54:59,10095.936,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29008,516,516,8,62,88,1455,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4140,4141,4142,4141,4142,4151,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,34.9,978,SUCCESS
    2520,2021-07-01 18:55:03,10099.950,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29008,516,516,8,62,88,1455,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4141,4141,4142,4142,4143,4151,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1038,SUCCESS
    2521,2021-07-01 18:55:07,10103.951,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29009,516,516,8,62,88,1456,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4141,4141,4142,4142,4144,4152,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,988,SUCCESS
    2522,2021-07-01 18:55:11,10107.956,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29015,515,516,8,62,88,1457,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4141,4142,4142,4142,4144,4152,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,34.9,1012,SUCCESS
    2523,2021-07-01 18:55:15,10111.959,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29018,516,516,8,62,88,1457,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4141,4142,4143,4142,4144,4152,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,964,SUCCESS
    2524,2021-07-01 18:55:19,10115.972,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29021,516,516,8,62,88,1458,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4142,4142,4143,4143,4144,4152,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1045,SUCCESS
    2525,2021-07-01 18:55:23,10119.976,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29024,516,516,8,62,88,1458,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4142,4142,4143,4143,4144,4153,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,35.0,1072,SUCCESS
    2526,2021-07-01 18:55:27,10123.989,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29029,516,516,8,63,88,1459,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4142,4143,4144,4143,4144,4153,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,35.0,980,SUCCESS
    2527,2021-07-01 18:55:31,10127.996,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29024,516,516,8,63,88,1459,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4142,4143,4144,4143,4144,4153,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,35.0,959,SUCCESS
    2528,2021-07-01 18:55:35,10132.004,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29026,515,516,8,63,88,1460,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4143,4143,4144,4143,4145,4153,0,0,0,0,0,0,0,0,3205,25.9,26.0,-273.2,26.0,-273.2,34.9,1013,SUCCESS
    2529,2021-07-01 18:55:39,10136.006,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29029,516,516,8,63,88,1461,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4143,4144,4144,4144,4145,4154,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1043,SUCCESS
    2530,2021-07-01 18:55:43,10140.020,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29030,516,516,8,63,88,1461,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4143,4144,4145,4144,4145,4154,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1059,SUCCESS
    2531,2021-07-01 18:55:47,10144.026,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29033,516,516,8,63,88,1462,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4143,4144,4145,4144,4145,4154,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1038,SUCCESS
    2532,2021-07-01 18:55:51,10148.027,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29034,516,516,8,63,88,1462,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4144,4144,4145,4145,4146,4154,0,0,0,0,0,0,0,0,3205,26.0,26.0,-273.2,26.0,-273.2,35.0,1040,SUCCESS
    2533,2021-07-01 18:55:55,10152.031,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29034,516,516,8,63,88,1463,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4144,4144,4145,4145,4146,4155,0,0,0,0,0,0,0,0,3206,26.0,26.0,-273.2,26.0,-273.2,35.1,1084,SUCCESS
    2534,2021-07-01 18:55:59,10156.032,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29038,516,516,8,63,88,1464,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4144,4145,4146,4145,4147,4155,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1093,SUCCESS
    2535,2021-07-01 18:56:03,10160.044,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29040,515,516,8,63,88,1464,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4145,4145,4146,4145,4147,4155,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,34.9,1042,SUCCESS
    2536,2021-07-01 18:56:07,10164.050,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29041,515,516,8,63,88,1465,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4145,4145,4146,4146,4147,4155,0,0,0,0,0,0,0,0,3210,25.9,26.0,-273.2,26.0,-273.2,35.0,1070,SUCCESS
    2537,2021-07-01 18:56:11,10168.065,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29043,516,516,8,63,88,1465,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4145,4145,4147,4146,4147,4155,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1029,SUCCESS
    2538,2021-07-01 18:56:15,10172.076,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29044,516,516,8,63,88,1466,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4145,4145,4147,4146,4147,4156,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1035,SUCCESS
    2539,2021-07-01 18:56:19,10176.086,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29045,516,516,8,63,88,1466,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4145,4146,4147,4147,4148,4156,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1040,SUCCESS
    2540,2021-07-01 18:56:23,10180.092,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29047,515,516,8,63,89,1467,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4146,4146,4147,4146,4148,4156,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1080,SUCCESS
    2541,2021-07-01 18:56:27,10184.104,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29049,516,516,8,63,89,1468,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4146,4146,4147,4147,4148,4156,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1056,SUCCESS
    2542,2021-07-01 18:56:31,10188.119,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29052,516,516,8,63,89,1468,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4146,4146,4147,4147,4147,4157,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,34.7,951,SUCCESS
    2543,2021-07-01 18:56:35,10192.134,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29053,515,516,8,63,89,1469,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4146,4147,4148,4147,4147,4157,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1008,SUCCESS
    2544,2021-07-01 18:56:39,10196.140,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29054,516,516,8,63,89,1469,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4147,4147,4148,4147,4147,4158,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1066,SUCCESS
    2545,2021-07-01 18:56:43,10200.151,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29056,516,516,8,63,89,1470,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4147,4147,4148,4147,4145,4158,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.1,1044,SUCCESS
    2546,2021-07-01 18:56:47,10204.167,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29058,515,516,8,63,89,1470,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4147,4147,4148,4149,4146,4158,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,993,SUCCESS
    2547,2021-07-01 18:56:51,10208.173,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29059,516,516,8,63,89,1471,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4147,4148,4149,4148,4149,4158,0,0,0,0,0,0,0,0,3210,26.0,26.1,-273.2,26.1,-273.2,35.1,1096,SUCCESS
    2548,2021-07-01 18:56:55,10212.174,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29062,516,516,8,63,89,1472,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4148,4148,4149,4149,4152,4158,0,0,0,0,0,0,0,0,3210,26.0,26.1,-273.2,26.1,-273.2,35.0,1033,SUCCESS
    2549,2021-07-01 18:56:59,10216.186,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29063,515,516,8,63,89,1472,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4148,4148,4149,4149,4150,4159,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,34.9,1056,SUCCESS
    2550,2021-07-01 18:57:03,10220.200,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29065,516,516,8,63,89,1473,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4148,4148,4149,4149,4151,4159,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.1,978,SUCCESS
    2551,2021-07-01 18:57:07,10224.212,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29067,515,516,8,63,89,1473,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4149,4149,4150,4149,4156,4159,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1009,SUCCESS
    2552,2021-07-01 18:57:11,10228.213,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29068,516,516,8,63,89,1474,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4149,4149,4150,4149,4151,4159,0,0,0,0,0,0,0,0,3210,26.0,26.1,-273.2,26.1,-273.2,35.1,1054,SUCCESS
    2553,2021-07-01 18:57:15,10232.226,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29069,516,516,8,63,89,1474,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4149,4149,4150,4150,4151,4159,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1074,SUCCESS
    2554,2021-07-01 18:57:19,10236.228,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29070,515,516,8,63,89,1475,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4149,4149,4150,4150,4151,4160,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,34.9,1065,SUCCESS
    2555,2021-07-01 18:57:23,10240.232,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29071,515,516,8,63,89,1476,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4149,4149,4151,4150,4151,4160,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1022,SUCCESS
    2556,2021-07-01 18:57:27,10244.243,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29074,515,516,8,63,89,1476,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4150,4150,4151,4150,4151,4160,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1072,SUCCESS
    2557,2021-07-01 18:57:31,10248.254,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29076,516,516,8,63,89,1477,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4150,4150,4151,4150,4151,4161,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.1,1047,SUCCESS
    2558,2021-07-01 18:57:35,10252.255,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29078,516,516,8,63,89,1477,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4150,4150,4151,4151,4152,4161,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1108,SUCCESS
    2559,2021-07-01 18:57:39,10256.270,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29080,516,516,8,63,89,1478,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4150,4151,4152,4151,4152,4161,0,0,0,0,0,0,0,0,3210,26.0,26.0,-273.2,26.0,-273.2,35.0,1000,SUCCESS
    2560,2021-07-01 18:57:43,10260.271,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29080,515,516,8,63,89,1478,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4150,4151,4152,4151,4152,4161,0,0,0,0,0,0,0,0,3214,26.0,26.0,-273.2,26.0,-273.2,35.1,1092,SUCCESS
    2561,2021-07-01 18:57:47,10264.284,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29082,516,516,8,63,89,1479,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4150,4151,4152,4152,4153,4161,0,0,0,0,0,0,0,0,3211,26.0,26.1,-273.2,26.1,-273.2,35.0,1045,SUCCESS
    2562,2021-07-01 18:57:51,10268.284,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29084,516,516,8,63,89,1480,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4151,4151,4153,4152,4153,4162,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,998,SUCCESS
    2563,2021-07-01 18:57:55,10272.299,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29085,516,516,8,63,89,1480,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4151,4152,4153,4152,4153,4162,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1093,SUCCESS
    2564,2021-07-01 18:57:59,10276.310,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29089,516,516,8,63,89,1481,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4152,4152,4153,4152,4153,4162,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.0,1068,SUCCESS
    2565,2021-07-01 18:58:03,10280.317,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29089,517,516,8,63,89,1481,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4152,4152,4153,4152,4154,4162,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.1,1029,SUCCESS
    2566,2021-07-01 18:58:07,10284.328,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29089,516,516,8,64,89,1482,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4152,4152,4153,4152,4154,4162,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.0,1095,SUCCESS
    2567,2021-07-01 18:58:11,10288.332,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29091,515,516,8,64,89,1483,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4152,4152,4153,4153,4154,4163,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,34.9,1018,SUCCESS
    2568,2021-07-01 18:58:15,10292.341,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29092,515,516,8,64,89,1483,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4152,4152,4154,4153,4154,4163,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.1,1037,SUCCESS
    2569,2021-07-01 18:58:19,10296.349,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29094,516,516,8,64,90,1484,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4153,4153,4154,4153,4154,4163,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.0,1044,SUCCESS
    2570,2021-07-01 18:58:23,10300.352,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29095,516,516,8,64,90,1484,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4153,4153,4154,4154,4154,4163,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1040,SUCCESS
    2571,2021-07-01 18:58:27,10304.367,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29098,516,516,8,64,90,1485,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4153,4153,4154,4154,4155,4164,0,0,0,0,0,0,0,0,3215,26.0,26.0,-273.2,26.0,-273.2,35.1,1025,SUCCESS
    2572,2021-07-01 18:58:31,10308.380,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29100,517,516,8,64,90,1485,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4153,4153,4155,4154,4155,4164,0,0,0,0,0,0,0,0,3215,26.0,26.0,-273.2,26.0,-273.2,35.1,981,SUCCESS
    2573,2021-07-01 18:58:35,10312.382,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29099,516,516,8,64,90,1486,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4153,4154,4155,4154,4155,4164,0,0,0,0,0,0,0,0,3215,26.0,26.0,-273.2,26.0,-273.2,35.0,1025,SUCCESS
    2574,2021-07-01 18:58:39,10316.397,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29100,516,516,8,64,90,1487,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4154,4154,4155,4154,4155,4164,0,0,0,0,0,0,0,0,3215,26.0,26.0,-273.2,26.0,-273.2,35.1,979,SUCCESS
    2575,2021-07-01 18:58:43,10320.396,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29103,516,516,8,64,90,1487,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4154,4154,4155,4155,4156,4164,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1120,SUCCESS
    2576,2021-07-01 18:58:47,10324.400,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29103,516,516,8,64,90,1488,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4154,4154,4156,4155,4156,4164,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,944,SUCCESS
    2577,2021-07-01 18:58:51,10328.414,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29105,517,516,8,64,90,1488,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4154,4154,4156,4155,4156,4165,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,994,SUCCESS
    2578,2021-07-01 18:58:55,10332.431,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29106,515,516,8,64,90,1489,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4154,4154,4156,4155,4156,4165,0,0,0,0,0,0,0,0,3215,26.0,26.0,-273.2,26.0,-273.2,35.1,963,SUCCESS
    2579,2021-07-01 18:58:59,10336.440,0x0701,150,10,0x6001,0,65535,65535,1,26.0,29110,517,516,8,64,90,1490,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4155,4155,4156,4155,4156,4165,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,34.9,1053,SUCCESS
    2580,2021-07-01 18:59:03,10340.453,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29110,517,516,8,64,90,1490,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4155,4155,4156,4155,4157,4165,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.1,1116,SUCCESS
    2581,2021-07-01 18:59:07,10344.464,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29110,516,516,8,64,90,1491,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4155,4155,4156,4156,4157,4165,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1039,SUCCESS
    2582,2021-07-01 18:59:11,10348.475,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29111,516,516,8,64,90,1491,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4155,4155,4157,4156,4157,4165,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1028,SUCCESS
    2583,2021-07-01 18:59:15,10352.488,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29112,515,516,8,64,90,1492,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4156,4155,4157,4156,4157,4166,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.1,1000,SUCCESS
    2584,2021-07-01 18:59:19,10356.492,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29115,516,516,8,64,90,1492,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4156,4156,4157,4156,4158,4166,0,0,0,0,0,0,0,0,3215,26.0,26.2,-273.2,26.2,-273.2,35.0,962,SUCCESS
    2585,2021-07-01 18:59:23,10360.506,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29115,516,516,8,64,90,1493,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4156,4156,4157,4157,4158,4166,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1080,SUCCESS
    2586,2021-07-01 18:59:27,10364.508,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29119,516,516,8,64,90,1494,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4156,4156,4158,4157,4158,4166,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.1,994,SUCCESS
    2587,2021-07-01 18:59:31,10368.515,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29119,517,516,8,64,90,1494,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4156,4156,4158,4157,4158,4167,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.1,1036,SUCCESS
    2588,2021-07-01 18:59:35,10372.520,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29121,517,516,8,64,90,1495,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4156,4156,4158,4157,4158,4167,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,998,SUCCESS
    2589,2021-07-01 18:59:39,10376.529,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29121,516,516,8,64,90,1495,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4157,4156,4158,4157,4158,4167,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1116,SUCCESS
    2590,2021-07-01 18:59:43,10380.537,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29124,517,516,8,64,90,1496,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4157,4157,4158,4158,4158,4167,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1028,SUCCESS
    2591,2021-07-01 18:59:47,10384.549,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29125,516,516,8,64,90,1496,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4157,4157,4158,4158,4159,4168,0,0,0,0,0,0,0,0,3219,26.0,26.1,-273.2,26.1,-273.2,34.4,1036,SUCCESS
    2592,2021-07-01 18:59:51,10388.564,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29127,516,516,8,64,90,1497,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4157,4157,4159,4158,4159,4168,0,0,0,0,0,0,0,0,3215,26.0,26.1,-273.2,26.1,-273.2,35.0,1063,SUCCESS
    2593,2021-07-01 18:59:55,10392.564,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29128,517,516,8,64,90,1498,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4157,4158,4159,4158,4159,4168,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1017,SUCCESS
    2594,2021-07-01 18:59:59,10396.568,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29129,516,516,8,64,90,1498,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4158,4158,4159,4158,4159,4168,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,1045,SUCCESS
    2595,2021-07-01 19:00:03,10400.567,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29129,516,516,8,64,90,1499,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4158,4158,4159,4158,4160,4168,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1001,SUCCESS
    2596,2021-07-01 19:00:07,10404.582,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29130,516,516,8,64,90,1499,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4158,4158,4159,4158,4159,4168,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,999,SUCCESS
    2597,2021-07-01 19:00:11,10408.584,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29131,516,516,8,64,90,1500,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4158,4158,4160,4159,4160,4169,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1011,SUCCESS
    2598,2021-07-01 19:00:15,10412.589,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29130,516,516,8,64,91,1501,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4158,4158,4160,4159,4160,4169,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,1008,SUCCESS
    2599,2021-07-01 19:00:19,10416.593,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29137,517,516,8,64,91,1501,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4159,4159,4160,4160,4160,4169,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1035,SUCCESS
    2600,2021-07-01 19:00:23,10420.599,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29139,515,516,8,64,91,1502,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4159,4159,4160,4160,4160,4169,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,34.5,1066,SUCCESS
    2601,2021-07-01 19:00:27,10424.607,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29142,516,516,8,64,91,1502,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4159,4159,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1031,SUCCESS
    2602,2021-07-01 19:00:31,10428.614,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29143,515,516,8,64,91,1503,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4159,4159,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1136,SUCCESS
    2603,2021-07-01 19:00:35,10432.628,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29142,515,516,8,64,91,1503,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4159,4159,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1061,SUCCESS
    2604,2021-07-01 19:00:39,10436.633,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29143,516,516,8,64,91,1504,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4160,4159,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,993,SUCCESS
    2605,2021-07-01 19:00:43,10440.647,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29143,516,516,8,64,91,1505,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4160,4160,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,1013,SUCCESS
    2606,2021-07-01 19:00:47,10444.657,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29145,516,516,8,64,91,1505,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4160,4160,4161,4160,4161,4170,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1033,SUCCESS
    2607,2021-07-01 19:00:51,10448.666,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29146,517,516,8,65,91,1506,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4160,4160,4162,4161,4162,4170,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,978,SUCCESS
    2608,2021-07-01 19:00:55,10452.669,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29146,517,516,8,65,91,1506,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4160,4160,4162,4161,4161,4171,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1067,SUCCESS
    2609,2021-07-01 19:00:59,10456.679,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29150,516,516,8,65,91,1507,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4161,4161,4162,4161,4161,4171,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1009,SUCCESS
    2610,2021-07-01 19:01:03,10460.693,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29152,515,516,8,65,91,1507,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4161,4161,4162,4161,4163,4171,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,1061,SUCCESS
    2611,2021-07-01 19:01:07,10464.703,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29152,516,516,8,65,91,1508,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4161,4161,4162,4161,4163,4171,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.0,1002,SUCCESS
    2612,2021-07-01 19:01:11,10468.716,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29153,515,516,8,65,91,1509,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4161,4161,4162,4162,4163,4171,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1035,SUCCESS
    2613,2021-07-01 19:01:15,10472.719,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29153,516,516,8,65,91,1509,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4161,4161,4162,4162,4163,4171,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1036,SUCCESS
    2614,2021-07-01 19:01:19,10476.730,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29156,516,516,8,65,91,1510,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4162,4161,4163,4162,4163,4171,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1009,SUCCESS
    2615,2021-07-01 19:01:23,10480.743,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29156,517,516,8,65,91,1510,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4162,4161,4163,4163,4163,4172,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1087,SUCCESS
    2616,2021-07-01 19:01:27,10484.755,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29159,517,516,8,65,91,1511,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4162,4162,4163,4163,4163,4172,0,0,0,0,0,0,0,0,3220,26.0,26.1,-273.2,26.1,-273.2,35.1,1012,SUCCESS
    2617,2021-07-01 19:01:31,10488.759,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29161,516,516,8,65,91,1511,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4162,4162,4164,4163,4164,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,976,SUCCESS
    2618,2021-07-01 19:01:35,10492.771,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29162,516,516,8,65,91,1512,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4162,4162,4164,4163,4164,4172,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1027,SUCCESS
    2619,2021-07-01 19:01:39,10496.782,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29162,517,516,8,65,91,1513,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4162,4162,4164,4163,4164,4173,0,0,0,0,0,0,0,0,3220,26.1,26.2,-273.2,26.2,-273.2,35.1,1094,SUCCESS
    2620,2021-07-01 19:01:43,10500.787,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29163,517,516,8,65,91,1513,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4162,4162,4164,4163,4163,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1057,SUCCESS
    2621,2021-07-01 19:01:47,10504.799,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29165,516,517,8,65,91,1514,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4163,4163,4164,4163,4163,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1031,SUCCESS
    2622,2021-07-01 19:01:51,10508.808,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29166,517,517,8,65,91,1514,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4163,4163,4164,4164,4162,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.0,1039,SUCCESS
    2623,2021-07-01 19:01:55,10512.811,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29167,517,517,8,65,91,1515,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4163,4163,4164,4164,4164,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1080,SUCCESS
    2624,2021-07-01 19:01:59,10516.816,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29171,517,517,8,65,91,1515,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4163,4163,4165,4164,4161,4173,0,0,0,0,0,0,0,0,3220,26.0,26.2,-273.2,26.2,-273.2,35.1,1060,SUCCESS
    2625,2021-07-01 19:02:03,10520.817,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29171,517,517,8,65,91,1516,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4164,4164,4165,4164,4165,4174,0,0,0,0,0,0,0,0,3224,26.0,26.2,-273.2,26.2,-273.2,35.0,1027,SUCCESS
    2626,2021-07-01 19:02:07,10524.828,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29172,515,517,8,65,92,1517,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4164,4164,4165,4164,4165,4174,0,0,0,0,0,0,0,0,3224,26.0,26.2,-273.2,26.2,-273.2,35.0,1081,SUCCESS
    2627,2021-07-01 19:02:11,10528.837,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29172,516,516,8,65,92,1517,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4164,4164,4165,4164,4167,4174,0,0,0,0,0,0,0,0,3225,26.0,26.1,-273.2,26.1,-273.2,35.1,995,SUCCESS
    2628,2021-07-01 19:02:15,10532.850,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29175,516,517,8,65,92,1518,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4164,4164,4165,4165,4170,4174,0,0,0,0,0,0,0,0,3225,26.0,26.1,-273.2,26.1,-273.2,35.1,1027,SUCCESS
    2629,2021-07-01 19:02:19,10536.865,0x0701,150,10,0x6001,0,65535,65535,1,26.1,29175,516,516,8,65,92,1518,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4164,4164,4166,4165,4170,4174,0,0,0,0,0,0,0,0,3225,26.0,26.2,-273.2,26.2,-273.2,35.0,1041,SUCCESS
    2630,2021-07-01 19:02:23,10540.865,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29177,517,516,8,65,92,1519,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4165,4164,4166,4165,4166,4175,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1041,SUCCESS
    2631,2021-07-01 19:02:28,10544.874,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29176,517,517,8,65,92,1520,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4165,4164,4166,4165,4166,4175,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,974,SUCCESS
    2632,2021-07-01 19:02:32,10548.875,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29179,517,517,8,65,92,1520,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4165,4164,4166,4166,4166,4175,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1032,SUCCESS
    2633,2021-07-01 19:02:36,10552.881,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29181,516,516,8,65,92,1521,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4165,4165,4166,4166,4166,4176,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,994,SUCCESS
    2634,2021-07-01 19:02:40,10556.887,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29182,516,516,8,65,92,1521,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4165,4165,4167,4166,4166,4176,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1004,SUCCESS
    2635,2021-07-01 19:02:44,10560.888,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29183,516,516,8,65,92,1522,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4166,4165,4167,4166,4167,4176,0,0,0,0,0,0,0,0,3225,26.0,26.2,-273.2,26.2,-273.2,35.1,1117,SUCCESS
    2636,2021-07-01 19:02:48,10564.906,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29185,517,516,8,65,92,1522,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4166,4165,4167,4166,4167,4176,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1062,SUCCESS
    2637,2021-07-01 19:02:52,10568.912,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29185,516,516,8,65,92,1523,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4166,4165,4167,4167,4167,4176,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,950,SUCCESS
    2638,2021-07-01 19:02:56,10572.919,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29186,517,516,8,65,92,1524,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4166,4166,4168,4167,4167,4176,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1022,SUCCESS
    2639,2021-07-01 19:03:00,10576.920,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29189,517,517,8,65,92,1524,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4166,4166,4168,4167,4167,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1018,SUCCESS
    2640,2021-07-01 19:03:04,10580.934,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29190,516,517,8,65,92,1525,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4167,4166,4168,4167,4168,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1067,SUCCESS
    2641,2021-07-01 19:03:08,10584.940,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29191,517,517,8,65,92,1525,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4167,4166,4168,4167,4168,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1031,SUCCESS
    2642,2021-07-01 19:03:12,10588.950,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29191,516,517,8,65,92,1526,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4167,4166,4168,4167,4168,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1005,SUCCESS
    2643,2021-07-01 19:03:16,10592.950,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29193,517,517,8,65,92,1527,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4167,4167,4168,4167,4168,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1020,SUCCESS
    2644,2021-07-01 19:03:20,10596.965,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29196,516,517,8,65,92,1527,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4167,4167,4168,4168,4168,4177,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1084,SUCCESS
    2645,2021-07-01 19:03:24,10600.979,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29196,516,516,8,65,92,1528,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4167,4167,4169,4168,4169,4178,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1023,SUCCESS
    2646,2021-07-01 19:03:28,10604.985,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29198,516,516,8,65,92,1528,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4167,4169,4168,4169,4178,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1064,SUCCESS
    2647,2021-07-01 19:03:32,10609.000,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29199,516,516,8,66,92,1529,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4167,4169,4168,4169,4178,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1033,SUCCESS
    2648,2021-07-01 19:03:36,10613.002,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29201,517,516,8,66,92,1529,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4168,4170,4169,4169,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1033,SUCCESS
    2649,2021-07-01 19:03:40,10617.017,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29204,516,516,8,66,92,1530,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4168,4169,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1032,SUCCESS
    2650,2021-07-01 19:03:44,10621.017,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29204,516,516,8,66,92,1531,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4168,4170,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,34.2,1038,SUCCESS
    2651,2021-07-01 19:03:48,10625.018,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29204,517,517,8,66,92,1531,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4169,4168,4170,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1046,SUCCESS
    2652,2021-07-01 19:03:52,10629.030,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29204,517,517,8,66,92,1532,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4168,4168,4170,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,987,SUCCESS
    2653,2021-07-01 19:03:56,10633.045,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29206,517,517,8,66,92,1532,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4169,4168,4170,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1051,SUCCESS
    2654,2021-07-01 19:04:00,10637.051,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29207,518,517,8,66,92,1533,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4169,4168,4170,4169,4170,4179,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1012,SUCCESS
    2655,2021-07-01 19:04:04,10641.065,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29210,518,517,8,66,92,1533,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4169,4169,4171,4170,4170,4180,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1108,SUCCESS
    2656,2021-07-01 19:04:08,10645.071,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29212,517,517,8,66,93,1534,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4170,4169,4171,4170,4170,4180,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,978,SUCCESS
    2657,2021-07-01 19:04:12,10649.084,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29212,517,517,8,66,93,1535,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4170,4169,4171,4170,4171,4180,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1030,SUCCESS
    2658,2021-07-01 19:04:16,10653.089,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29213,517,517,8,66,93,1535,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4170,4169,4171,4170,4171,4180,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1070,SUCCESS
    2659,2021-07-01 19:04:20,10657.101,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29215,516,517,8,66,93,1536,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4170,4170,4171,4170,4171,4181,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,1041,SUCCESS
    2660,2021-07-01 19:04:24,10661.109,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29216,517,517,8,66,93,1536,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4170,4170,4171,4171,4171,4181,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.1,1020,SUCCESS
    2661,2021-07-01 19:04:28,10665.121,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29218,517,517,8,66,93,1537,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4170,4170,4172,4171,4172,4181,0,0,0,0,0,0,0,0,3225,26.1,26.2,-273.2,26.2,-273.2,35.0,948,SUCCESS
    2662,2021-07-01 19:04:32,10669.128,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29218,517,517,8,66,93,1538,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4170,4170,4172,4171,4172,4181,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1093,SUCCESS
    2663,2021-07-01 19:04:36,10673.137,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29219,516,517,8,66,93,1538,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4171,4170,4172,4171,4172,4181,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,943,SUCCESS
    2664,2021-07-01 19:04:40,10677.149,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29221,515,516,8,66,93,1539,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4171,4171,4172,4172,4172,4182,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1011,SUCCESS
    2665,2021-07-01 19:04:44,10681.161,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29223,516,516,8,66,93,1539,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4171,4171,4173,4172,4172,4182,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1015,SUCCESS
    2666,2021-07-01 19:04:48,10685.176,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29225,517,516,8,66,93,1540,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4171,4171,4173,4172,4173,4182,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.0,968,SUCCESS
    2667,2021-07-01 19:04:52,10689.190,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29226,518,516,8,66,93,1540,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4172,4171,4173,4172,4173,4182,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.0,1060,SUCCESS
    2668,2021-07-01 19:04:56,10693.200,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29226,517,517,8,66,93,1541,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4172,4171,4173,4172,4173,4182,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1051,SUCCESS
    2669,2021-07-01 19:05:00,10697.208,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29226,516,516,8,66,93,1542,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4172,4171,4173,4172,4173,4182,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.0,1043,SUCCESS
    2670,2021-07-01 19:05:04,10701.213,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29228,516,516,8,66,93,1542,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4172,4171,4173,4172,4174,4183,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1023,SUCCESS
    2671,2021-07-01 19:05:08,10705.228,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29232,517,516,8,66,93,1543,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4172,4172,4174,4173,4173,4183,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,991,SUCCESS
    2672,2021-07-01 19:05:12,10709.228,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29232,518,516,8,66,93,1543,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4173,4172,4174,4173,4174,4183,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,977,SUCCESS
    2673,2021-07-01 19:05:16,10713.231,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29233,517,517,8,66,93,1544,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4173,4172,4174,4173,4174,4183,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1006,SUCCESS
    2674,2021-07-01 19:05:20,10717.239,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29233,517,517,8,66,93,1544,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4173,4172,4174,4173,4174,4184,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1106,SUCCESS
    2675,2021-07-01 19:05:24,10721.241,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29231,516,516,8,66,93,1545,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4173,4172,4174,4174,4175,4184,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.0,1073,SUCCESS
    2676,2021-07-01 19:05:28,10725.250,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29234,517,517,8,66,93,1546,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4173,4173,4174,4174,4175,4184,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1096,SUCCESS
    2677,2021-07-01 19:05:32,10729.254,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29239,516,517,8,66,93,1546,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4173,4173,4174,4174,4175,4184,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1062,SUCCESS
    2678,2021-07-01 19:05:36,10733.267,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29240,516,517,8,66,93,1547,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4174,4173,4175,4174,4175,4184,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.2,1065,SUCCESS
    2679,2021-07-01 19:05:40,10737.268,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29241,516,517,8,66,93,1547,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4173,4173,4175,4174,4175,4185,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1080,SUCCESS
    2680,2021-07-01 19:05:44,10741.278,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29244,516,517,8,66,93,1548,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4174,4173,4175,4175,4175,4185,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1036,SUCCESS
    2681,2021-07-01 19:05:48,10745.288,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29249,517,517,8,66,93,1548,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4174,4174,4176,4175,4176,4185,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1042,SUCCESS
    2682,2021-07-01 19:05:52,10749.304,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29247,517,517,8,66,93,1549,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4174,4174,4176,4175,4176,4185,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,34.9,953,SUCCESS
    2683,2021-07-01 19:05:56,10753.306,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29247,517,517,8,66,93,1550,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4175,4174,4176,4175,4176,4185,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1040,SUCCESS
    2684,2021-07-01 19:06:00,10757.314,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29248,518,517,8,66,93,1550,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4175,4174,4176,4175,4176,4185,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1032,SUCCESS
    2685,2021-07-01 19:06:04,10761.322,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29249,517,517,8,66,94,1551,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4175,4175,4176,4175,4176,4186,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1040,SUCCESS
    2686,2021-07-01 19:06:08,10765.330,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29251,517,517,8,66,94,1551,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4175,4175,4176,4176,4176,4186,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1081,SUCCESS
    2687,2021-07-01 19:06:12,10769.343,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29253,517,517,8,66,94,1552,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4176,4175,4177,4176,4176,4186,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1003,SUCCESS
    2688,2021-07-01 19:06:16,10773.354,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29254,517,517,8,66,94,1552,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4176,4175,4177,4176,4177,4186,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1007,SUCCESS
    2689,2021-07-01 19:06:20,10777.365,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29256,518,517,8,67,94,1553,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4176,4175,4177,4177,4177,4187,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1075,SUCCESS
    2690,2021-07-01 19:06:24,10781.380,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29257,516,517,8,67,94,1554,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4176,4176,4177,4177,4177,4187,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1044,SUCCESS
    2691,2021-07-01 19:06:28,10785.392,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29259,517,517,8,67,94,1554,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4176,4176,4178,4177,4177,4187,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,34.3,1135,SUCCESS
    2692,2021-07-01 19:06:32,10789.404,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29260,518,517,8,67,94,1555,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4176,4176,4178,4177,4178,4187,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1082,SUCCESS
    2693,2021-07-01 19:06:36,10793.415,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29260,517,517,8,67,94,1556,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4176,4176,4178,4177,4178,4187,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1044,SUCCESS
    2694,2021-07-01 19:06:40,10797.415,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29262,517,517,8,67,94,1556,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4177,4176,4178,4177,4178,4188,0,0,0,0,0,0,0,0,3230,26.1,26.2,-273.2,26.2,-273.2,35.1,1010,SUCCESS
    2695,2021-07-01 19:06:44,10801.422,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29263,516,517,8,67,94,1557,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4177,4177,4178,4178,4178,4188,0,0,0,0,0,0,0,0,3234,26.1,26.2,-273.2,26.2,-273.2,35.1,1079,SUCCESS
    2696,2021-07-01 19:06:48,10805.426,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29265,516,517,8,67,94,1557,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4177,4177,4179,4178,4178,4188,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.2,1082,SUCCESS
    2697,2021-07-01 19:06:52,10809.439,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29267,517,517,8,67,94,1558,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4178,4176,4179,4178,4178,4188,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1048,SUCCESS
    2698,2021-07-01 19:06:56,10813.448,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29268,517,517,8,67,94,1558,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4178,4177,4179,4178,4179,4188,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1039,SUCCESS
    2699,2021-07-01 19:07:00,10817.449,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29268,516,517,8,67,94,1559,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4178,4177,4179,4178,4179,4189,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1022,SUCCESS
    2700,2021-07-01 19:07:04,10821.453,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29271,517,517,8,67,94,1560,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4178,4178,4179,4179,4179,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    2701,2021-07-01 19:07:08,10825.466,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29272,517,517,8,67,94,1560,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4178,4178,4180,4179,4179,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    2702,2021-07-01 19:07:12,10829.477,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29274,516,517,8,67,94,1561,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4178,4178,4180,4179,4177,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    2703,2021-07-01 19:07:16,10833.483,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29275,516,517,8,67,94,1561,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4179,4178,4180,4179,4176,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.0,1026,SUCCESS
    2704,2021-07-01 19:07:20,10837.484,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29278,517,517,8,67,94,1562,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4179,4178,4180,4181,4178,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    2705,2021-07-01 19:07:24,10841.485,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29277,517,517,8,67,94,1562,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4179,4178,4180,4180,4181,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    2706,2021-07-01 19:07:28,10845.488,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29280,518,517,8,67,94,1563,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4179,4178,4181,4180,4183,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    2707,2021-07-01 19:07:32,10849.503,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29281,517,517,8,67,94,1564,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4179,4179,4181,4180,4183,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1016,SUCCESS
    2708,2021-07-01 19:07:36,10853.509,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29282,516,517,8,67,94,1564,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4180,4179,4181,4180,4182,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1026,SUCCESS
    2709,2021-07-01 19:07:40,10857.520,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29282,517,517,8,67,94,1565,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4180,4179,4181,4181,4184,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1029,SUCCESS
    2710,2021-07-01 19:07:44,10861.531,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29285,517,517,8,67,94,1565,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4180,4179,4181,4181,4181,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.2,1034,SUCCESS
    2711,2021-07-01 19:07:48,10865.536,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29287,516,517,8,67,94,1566,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4180,4180,4182,4181,4181,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.2,1028,SUCCESS
    2712,2021-07-01 19:07:52,10869.548,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29289,515,517,8,67,94,1566,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4181,4180,4182,4181,4182,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.2,1065,SUCCESS
    2713,2021-07-01 19:07:56,10873.566,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29289,517,517,8,67,95,1567,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4181,4180,4182,4181,4182,4191,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,1030,SUCCESS
    2714,2021-07-01 19:08:00,10877.573,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29289,517,517,8,67,95,1568,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4181,4180,4182,4181,4182,4192,0,0,0,0,0,0,0,0,3235,26.2,26.2,-273.2,26.2,-273.2,35.1,991,SUCCESS
    2715,2021-07-01 19:08:04,10881.586,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29290,516,517,8,67,95,1568,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4181,4180,4182,4182,4182,4192,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    2716,2021-07-01 19:08:08,10885.596,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29292,517,517,8,67,95,1569,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4181,4181,4182,4182,4183,4192,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    2717,2021-07-01 19:08:12,10889.607,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29295,517,517,8,67,95,1569,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4182,4181,4183,4182,4183,4193,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,957,SUCCESS
    2718,2021-07-01 19:08:16,10893.621,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29298,518,517,8,67,95,1570,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4182,4181,4183,4183,4183,4193,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    2719,2021-07-01 19:08:20,10897.623,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29298,518,517,8,67,95,1570,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4182,4181,4183,4183,4183,4193,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    2720,2021-07-01 19:08:24,10901.631,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29299,517,517,8,67,95,1571,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4182,4181,4183,4183,4184,4193,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    2721,2021-07-01 19:08:28,10905.631,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29301,516,517,8,67,95,1572,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4182,4182,4184,4183,4184,4194,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    2722,2021-07-01 19:08:32,10909.642,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29303,516,517,8,67,95,1572,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4183,4182,4184,4183,4184,4194,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    2723,2021-07-01 19:08:36,10913.644,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29305,517,517,8,67,95,1573,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4183,4182,4184,4183,4184,4194,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    2724,2021-07-01 19:08:40,10917.650,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29305,517,517,8,67,95,1573,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4183,4182,4184,4184,4184,4194,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    2725,2021-07-01 19:08:44,10921.651,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29307,517,517,8,67,95,1574,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4184,4183,4185,4184,4185,4194,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,947,SUCCESS
    2726,2021-07-01 19:08:48,10925.662,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29311,516,517,8,67,95,1574,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4184,4183,4185,4184,4185,4195,0,0,0,0,0,0,0,0,3239,26.2,26.3,-273.2,26.3,-273.2,35.2,1012,SUCCESS
    2727,2021-07-01 19:08:52,10929.678,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29311,517,517,8,67,95,1575,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4184,4183,4185,4184,4185,4195,0,0,0,0,0,0,0,0,3239,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    2728,2021-07-01 19:08:56,10933.684,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29312,516,517,8,68,95,1576,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4184,4183,4185,4184,4185,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    2729,2021-07-01 19:09:00,10937.695,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29312,517,516,8,68,95,1576,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4184,4183,4186,4185,4186,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    2730,2021-07-01 19:09:04,10941.705,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29316,516,516,8,68,95,1577,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4184,4184,4186,4185,4186,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    2731,2021-07-01 19:09:08,10945.713,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29318,516,516,8,68,95,1577,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4185,4184,4186,4186,4187,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1007,SUCCESS
    2732,2021-07-01 19:09:12,10949.718,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29320,516,516,8,68,95,1578,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4185,4184,4186,4186,4187,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1097,SUCCESS
    2733,2021-07-01 19:09:16,10953.722,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29320,516,516,8,68,95,1579,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4185,4184,4186,4186,4187,4196,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.1,1061,SUCCESS
    2734,2021-07-01 19:09:20,10957.722,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29322,518,516,8,68,95,1579,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4185,4185,4187,4186,4187,4196,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.1,1060,SUCCESS
    2735,2021-07-01 19:09:24,10961.727,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29325,516,516,8,68,95,1580,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4185,4185,4187,4186,4187,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    2736,2021-07-01 19:09:28,10965.739,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29326,515,516,8,68,95,1580,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4186,4185,4187,4187,4187,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    2737,2021-07-01 19:09:32,10969.752,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29327,517,516,8,68,95,1581,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4186,4185,4187,4187,4188,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    2738,2021-07-01 19:09:36,10973.768,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29327,515,516,8,68,95,1581,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4198,4186,4185,4188,4187,4188,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    2739,2021-07-01 19:09:40,10977.769,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29332,516,516,8,68,95,1582,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4198,4187,4186,4188,4187,4188,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    2740,2021-07-01 19:09:44,10981.786,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29332,516,516,8,68,95,1583,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4198,4187,4186,4188,4187,4188,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    2741,2021-07-01 19:09:48,10985.798,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29334,516,516,8,68,95,1583,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4198,4187,4187,4188,4188,4189,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    2742,2021-07-01 19:09:52,10989.802,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29336,516,516,8,68,96,1584,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4198,4187,4187,4188,4188,4189,4199,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,34.4,1111,SUCCESS
    2743,2021-07-01 19:09:56,10993.808,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29337,516,516,8,68,96,1584,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4187,4187,4189,4188,4189,4199,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,991,SUCCESS
    2744,2021-07-01 19:10:00,10997.811,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29339,515,516,8,68,96,1585,2352,65535,65535,160,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4187,4189,4188,4189,4199,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.2,1035,SUCCESS
    2745,2021-07-01 19:10:04,11001.817,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29340,516,516,8,68,96,1586,2352,65535,65535,160,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4187,4189,4189,4190,4199,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.2,1079,SUCCESS
    2746,2021-07-01 19:10:08,11005.833,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29341,515,516,8,68,96,1586,2352,65535,65535,160,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4187,4190,4189,4190,4199,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.2,1029,SUCCESS
    2747,2021-07-01 19:10:12,11009.836,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29343,513,515,8,68,96,1587,2352,65535,65535,160,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4187,4190,4189,4190,4199,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,979,SUCCESS
    2748,2021-07-01 19:10:16,11013.839,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29343,513,515,8,68,96,1587,2352,65535,65535,160,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4188,4190,4189,4190,4199,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1008,SUCCESS
    2749,2021-07-01 19:10:20,11017.848,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29344,512,514,8,68,96,1588,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4188,4190,4189,4190,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1077,SUCCESS
    2750,2021-07-01 19:10:24,11021.857,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29346,511,513,8,68,96,1588,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4188,4188,4190,4189,4190,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1036,SUCCESS
    2751,2021-07-01 19:10:29,11025.867,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29346,509,512,8,68,96,1589,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4189,4188,4190,4190,4190,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,34.9,968,SUCCESS
    2752,2021-07-01 19:10:33,11029.880,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29347,506,511,8,68,96,1589,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4189,4188,4190,4190,4190,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1091,SUCCESS
    2753,2021-07-01 19:10:37,11033.881,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29347,505,510,8,68,96,1590,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4189,4188,4190,4190,4190,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1012,SUCCESS
    2754,2021-07-01 19:10:41,11037.884,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29346,505,509,8,68,96,1591,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.2,1056,SUCCESS
    2755,2021-07-01 19:10:45,11041.899,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29348,502,507,8,68,96,1591,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.2,-273.2,26.2,-273.2,35.1,993,SUCCESS
    2756,2021-07-01 19:10:49,11045.909,0x0701,150,10,0x6001,0,65535,65535,1,26.2,29347,500,506,8,68,96,1592,2352,65535,65535,161,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1109,SUCCESS
    2757,2021-07-01 19:10:53,11049.913,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29347,499,504,8,68,96,1592,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    2758,2021-07-01 19:10:57,11053.915,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29346,498,503,8,68,96,1593,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    2759,2021-07-01 19:11:01,11057.929,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29345,497,501,8,68,96,1593,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4189,4188,4190,4190,4191,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    2760,2021-07-01 19:11:05,11061.932,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29346,492,500,8,68,96,1594,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4189,4189,4190,4190,4192,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1071,SUCCESS
    2761,2021-07-01 19:11:09,11065.933,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29348,491,498,8,68,96,1594,2352,65535,65535,162,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,941,SUCCESS
    2762,2021-07-01 19:11:13,11069.945,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29352,490,496,8,68,96,1595,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4200,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    2763,2021-07-01 19:11:17,11073.960,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29352,490,494,8,68,96,1596,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,963,SUCCESS
    2764,2021-07-01 19:11:21,11077.969,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,488,493,8,68,96,1596,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4191,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    2765,2021-07-01 19:11:25,11081.982,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,486,491,8,68,96,1597,2352,65535,65535,163,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.0,978,SUCCESS
    2766,2021-07-01 19:11:29,11085.989,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29357,484,490,8,68,96,1597,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    2767,2021-07-01 19:11:33,11090.000,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,482,488,8,68,96,1598,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    2768,2021-07-01 19:11:37,11094.006,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29353,481,487,8,68,96,1598,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4190,4192,4201,0,0,0,0,0,0,0,0,3241,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    2769,2021-07-01 19:11:41,11098.009,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,480,485,8,68,96,1599,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    2770,2021-07-01 19:11:45,11102.016,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,479,484,8,68,96,1599,2352,65535,65535,164,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3244,26.2,26.3,-273.2,26.3,-273.2,35.1,1110,SUCCESS
    2771,2021-07-01 19:11:49,11106.029,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,476,482,8,69,96,1600,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4191,4191,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    2772,2021-07-01 19:11:53,11110.030,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29354,477,481,8,69,97,1601,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3241,26.2,26.3,-273.2,26.3,-273.2,35.1,1083,SUCCESS
    2773,2021-07-01 19:11:57,11114.043,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,474,480,8,69,97,1601,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4189,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3244,26.2,26.3,-273.2,26.3,-273.2,35.1,975,SUCCESS
    2774,2021-07-01 19:12:01,11118.056,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,472,478,8,69,97,1602,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3241,26.2,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    2775,2021-07-01 19:12:05,11122.067,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,472,477,8,69,97,1602,2352,65535,65535,165,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    2776,2021-07-01 19:12:09,11126.081,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,470,475,8,69,97,1603,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    2777,2021-07-01 19:12:13,11130.081,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,468,474,8,69,97,1603,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1091,SUCCESS
    2778,2021-07-01 19:12:17,11134.091,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,467,472,8,69,97,1604,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    2779,2021-07-01 19:12:21,11138.093,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,465,471,8,69,97,1604,2352,65535,65535,166,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1034,SUCCESS
    2780,2021-07-01 19:12:25,11142.100,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29356,463,469,8,69,97,1605,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    2781,2021-07-01 19:12:29,11146.111,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29355,463,468,8,69,97,1605,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4192,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1111,SUCCESS
    2782,2021-07-01 19:12:33,11150.124,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29356,461,466,8,69,97,1606,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1128,SUCCESS
    2783,2021-07-01 19:12:37,11154.127,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29358,459,465,8,69,97,1606,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4191,4192,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,34.7,1084,SUCCESS
    2784,2021-07-01 19:12:41,11158.133,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29359,458,463,8,69,97,1607,2352,65535,65535,167,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4190,4190,4191,4192,4192,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    2785,2021-07-01 19:12:45,11162.135,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29357,457,462,8,69,97,1607,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4191,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    2786,2021-07-01 19:12:49,11166.144,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29358,455,460,8,69,97,1608,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4190,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    2787,2021-07-01 19:12:53,11170.155,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29359,452,459,8,69,97,1608,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4191,4192,4189,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    2788,2021-07-01 19:12:57,11174.166,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,452,457,8,69,97,1609,2352,65535,65535,168,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4188,4201,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    2789,2021-07-01 19:13:01,11178.176,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,451,456,8,69,97,1609,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    2790,2021-07-01 19:13:05,11182.182,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,450,455,8,69,97,1610,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1069,SUCCESS
    2791,2021-07-01 19:13:09,11186.193,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,449,453,8,69,97,1610,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4195,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    2792,2021-07-01 19:13:13,11190.206,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,448,452,8,69,97,1611,2352,65535,65535,169,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4195,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    2793,2021-07-01 19:13:17,11194.207,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,445,451,8,69,97,1611,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4197,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    2794,2021-07-01 19:13:21,11198.207,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,445,449,8,69,97,1612,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4198,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    2795,2021-07-01 19:13:25,11202.221,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29361,442,448,8,69,97,1612,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    2796,2021-07-01 19:13:29,11206.231,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,441,446,8,69,97,1613,2352,65535,65535,170,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1007,SUCCESS
    2797,2021-07-01 19:13:33,11210.245,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29361,439,444,8,69,97,1613,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    2798,2021-07-01 19:13:37,11214.250,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,438,443,8,69,97,1614,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1127,SUCCESS
    2799,2021-07-01 19:13:41,11218.252,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,437,442,8,69,97,1614,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    2800,2021-07-01 19:13:45,11222.251,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29361,435,440,8,69,97,1615,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    2801,2021-07-01 19:13:49,11226.258,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,434,439,8,69,97,1615,2352,65535,65535,171,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    2802,2021-07-01 19:13:53,11230.265,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,433,437,8,69,97,1616,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,971,SUCCESS
    2803,2021-07-01 19:13:57,11234.272,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29360,431,436,8,69,97,1616,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.4,-273.2,26.4,-273.2,35.2,1137,SUCCESS
    2804,2021-07-01 19:14:01,11238.281,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29360,429,434,8,69,98,1617,2352,65535,65535,172,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4190,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1102,SUCCESS
    2805,2021-07-01 19:14:05,11242.293,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29361,428,433,8,69,98,1617,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    2806,2021-07-01 19:14:09,11246.305,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29361,426,432,8,69,98,1618,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,946,SUCCESS
    2807,2021-07-01 19:14:13,11250.307,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29362,426,430,8,69,98,1618,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    2808,2021-07-01 19:14:17,11254.315,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29363,423,429,8,69,98,1619,2352,65535,65535,173,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1094,SUCCESS
    2809,2021-07-01 19:14:21,11258.325,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29363,422,427,8,69,98,1619,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,959,SUCCESS
    2810,2021-07-01 19:14:25,11262.334,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29362,421,426,8,69,98,1620,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4192,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    2811,2021-07-01 19:14:29,11266.340,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,420,424,8,69,98,1620,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.3,1105,SUCCESS
    2812,2021-07-01 19:14:33,11270.354,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29363,418,423,8,69,98,1621,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    2813,2021-07-01 19:14:37,11274.368,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,417,422,8,69,98,1621,2352,65535,65535,174,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4193,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    2814,2021-07-01 19:14:41,11278.377,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,415,420,8,69,98,1621,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,983,SUCCESS
    2815,2021-07-01 19:14:45,11282.382,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29363,414,419,8,69,98,1622,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,34.6,1002,SUCCESS
    2816,2021-07-01 19:14:49,11286.391,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,414,418,8,69,98,1622,2352,65535,65535,175,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4195,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    2817,2021-07-01 19:14:53,11290.400,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,411,416,8,70,98,1623,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    2818,2021-07-01 19:14:57,11294.401,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,409,415,8,70,98,1623,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    2819,2021-07-01 19:15:01,11298.411,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,407,413,8,70,98,1624,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1058,SUCCESS
    2820,2021-07-01 19:15:05,11302.424,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,406,412,8,70,98,1624,2352,65535,65535,176,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    2821,2021-07-01 19:15:09,11306.425,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,405,410,8,70,98,1625,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4191,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    2822,2021-07-01 19:15:13,11310.429,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,403,409,8,70,98,1625,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4191,4191,4193,4193,4195,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1042,SUCCESS
    2823,2021-07-01 19:15:17,11314.443,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29364,401,407,8,70,98,1626,2352,65535,65535,177,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,982,SUCCESS
    2824,2021-07-01 19:15:21,11318.444,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29365,401,406,8,70,98,1626,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,947,SUCCESS
    2825,2021-07-01 19:15:25,11322.456,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29366,400,404,8,70,98,1626,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4195,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1029,SUCCESS
    2826,2021-07-01 19:15:29,11326.457,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29366,399,403,8,70,98,1627,2352,65535,65535,178,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    2827,2021-07-01 19:15:33,11330.466,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,397,402,8,70,98,1627,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4192,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    2828,2021-07-01 19:15:37,11334.472,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29366,396,401,8,70,98,1628,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4194,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    2829,2021-07-01 19:15:41,11338.473,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,394,399,8,70,98,1628,2352,65535,65535,179,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    2830,2021-07-01 19:15:45,11342.473,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,392,397,8,70,98,1629,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4195,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    2831,2021-07-01 19:15:49,11346.485,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,391,396,8,70,98,1629,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    2832,2021-07-01 19:15:53,11350.500,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,389,394,8,70,98,1630,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    2833,2021-07-01 19:15:57,11354.508,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,388,393,8,70,98,1630,2352,65535,65535,180,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    2834,2021-07-01 19:16:01,11358.512,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29366,387,392,8,70,98,1630,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4192,4191,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    2835,2021-07-01 19:16:05,11362.523,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,384,390,8,70,98,1631,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,1073,SUCCESS
    2836,2021-07-01 19:16:09,11366.524,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29367,384,389,8,70,98,1631,2352,65535,65535,181,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    2837,2021-07-01 19:16:13,11370.537,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29368,383,387,8,70,98,1632,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4191,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    2838,2021-07-01 19:16:17,11374.547,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29368,381,386,8,70,98,1632,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.5,1091,SUCCESS
    2839,2021-07-01 19:16:21,11378.561,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29368,380,385,8,70,98,1633,2352,65535,65535,182,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1037,SUCCESS
    2840,2021-07-01 19:16:25,11382.575,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29367,379,383,8,70,98,1633,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,989,SUCCESS
    2841,2021-07-01 19:16:29,11386.582,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29366,376,382,8,70,98,1633,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1060,SUCCESS
    2842,2021-07-01 19:16:33,11390.591,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29366,375,380,8,70,99,1634,2352,65535,65535,183,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4193,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    2843,2021-07-01 19:16:37,11394.603,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29365,374,379,8,70,99,1634,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,985,SUCCESS
    2844,2021-07-01 19:16:41,11398.609,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29371,372,378,8,70,99,1635,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4194,4193,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    2845,2021-07-01 19:16:45,11402.618,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29371,373,376,8,70,99,1635,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4192,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1012,SUCCESS
    2846,2021-07-01 19:16:49,11406.629,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29371,369,375,8,70,99,1636,2352,65535,65535,184,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1094,SUCCESS
    2847,2021-07-01 19:16:53,11410.628,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29371,369,373,8,70,99,1636,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1015,SUCCESS
    2848,2021-07-01 19:16:57,11414.631,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29373,367,372,8,70,99,1636,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1106,SUCCESS
    2849,2021-07-01 19:17:01,11418.636,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,365,371,8,70,99,1637,2352,65535,65535,185,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    2850,2021-07-01 19:17:05,11422.647,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29370,364,369,8,70,99,1637,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,983,SUCCESS
    2851,2021-07-01 19:17:09,11426.662,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29370,363,368,8,70,99,1638,2352,65535,65535,186,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,997,SUCCESS
    2852,2021-07-01 19:17:13,11430.664,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29370,360,366,8,70,99,1638,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4192,4194,4193,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1011,SUCCESS
    2853,2021-07-01 19:17:17,11434.668,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29370,360,365,8,70,99,1638,2352,65535,65535,187,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    2854,2021-07-01 19:17:21,11438.681,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29371,358,363,8,70,99,1639,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4193,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,994,SUCCESS
    2855,2021-07-01 19:17:25,11442.684,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29371,357,362,8,70,99,1639,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,959,SUCCESS
    2856,2021-07-01 19:17:29,11446.692,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29373,357,361,8,70,99,1640,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4193,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1014,SUCCESS
    2857,2021-07-01 19:17:33,11450.701,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29372,354,360,8,70,99,1640,2352,65535,65535,188,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    2858,2021-07-01 19:17:37,11454.711,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29371,353,358,8,70,99,1640,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1010,SUCCESS
    2859,2021-07-01 19:17:41,11458.721,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29372,351,357,8,70,99,1641,2352,65535,65535,189,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    2860,2021-07-01 19:17:45,11462.732,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29372,351,355,8,70,99,1641,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1096,SUCCESS
    2861,2021-07-01 19:17:49,11466.744,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29373,350,354,8,70,99,1642,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.7,1013,SUCCESS
    2862,2021-07-01 19:17:53,11470.744,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29372,348,353,8,70,99,1642,2352,65535,65535,190,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1038,SUCCESS
    2863,2021-07-01 19:17:57,11474.749,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29372,346,351,8,70,99,1642,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1033,SUCCESS
    2864,2021-07-01 19:18:01,11478.751,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29372,345,350,8,70,99,1643,2352,65535,65535,191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    2865,2021-07-01 19:18:05,11482.766,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29373,343,348,8,70,99,1643,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    2866,2021-07-01 19:18:09,11486.770,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,342,347,8,70,99,1644,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    2867,2021-07-01 19:18:13,11490.784,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29373,340,346,8,70,99,1644,2352,65535,65535,192,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4195,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    2868,2021-07-01 19:18:17,11494.787,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,338,344,8,70,99,1644,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    2869,2021-07-01 19:18:21,11498.797,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,339,343,8,70,99,1645,2352,65535,65535,193,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4196,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,969,SUCCESS
    2870,2021-07-01 19:18:25,11502.811,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,337,341,8,70,99,1645,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4192,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.3,1008,SUCCESS
    2871,2021-07-01 19:18:29,11506.819,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,336,340,8,70,99,1645,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4195,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    2872,2021-07-01 19:18:33,11510.827,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,335,339,8,70,99,1646,2352,65535,65535,194,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4198,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1072,SUCCESS
    2873,2021-07-01 19:18:37,11514.831,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,333,338,8,70,99,1646,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4198,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1077,SUCCESS
    2874,2021-07-01 19:18:41,11518.831,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,332,336,8,71,99,1647,2352,65535,65535,195,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    2875,2021-07-01 19:18:45,11522.839,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,330,335,8,71,99,1647,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.6,1013,SUCCESS
    2876,2021-07-01 19:18:49,11526.852,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,328,334,8,71,99,1647,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    2877,2021-07-01 19:18:53,11530.865,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,326,332,8,71,99,1648,2352,65535,65535,196,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    2878,2021-07-01 19:18:58,11534.868,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,326,331,8,71,99,1648,2352,65535,65535,197,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    2879,2021-07-01 19:19:02,11538.881,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,323,329,8,71,99,1648,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.2,26.3,-273.2,26.3,-273.2,35.2,987,SUCCESS
    2880,2021-07-01 19:19:06,11542.892,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,322,328,8,71,99,1649,2352,65535,65535,198,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    2881,2021-07-01 19:19:10,11546.905,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29376,322,326,8,71,99,1649,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4193,4194,4195,4196,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1039,SUCCESS
    2882,2021-07-01 19:19:14,11550.914,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,320,325,8,71,99,1649,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4193,4194,4194,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    2883,2021-07-01 19:19:18,11554.929,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29376,319,324,8,71,99,1650,2352,65535,65535,199,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4194,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.1,1090,SUCCESS
    2884,2021-07-01 19:19:22,11558.938,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,318,322,8,71,99,1650,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4194,4194,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    2885,2021-07-01 19:19:26,11562.942,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29374,316,321,8,71,99,1650,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4194,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1075,SUCCESS
    2886,2021-07-01 19:19:30,11566.944,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29375,314,320,8,71,100,1651,2352,65535,65535,200,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4194,4195,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,996,SUCCESS
    2887,2021-07-01 19:19:34,11570.957,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,313,318,8,71,100,1651,2352,65535,65535,201,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4194,4195,4197,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1066,SUCCESS
    2888,2021-07-01 19:19:38,11574.961,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29377,313,317,8,71,100,1652,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4194,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1024,SUCCESS
    2889,2021-07-01 19:19:42,11578.962,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29377,311,316,8,71,100,1652,2352,65535,65535,202,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1039,SUCCESS
    2890,2021-07-01 19:19:46,11582.972,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29376,309,314,8,71,100,1652,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4193,4194,4194,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1046,SUCCESS
    2891,2021-07-01 19:19:50,11586.983,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29375,307,313,8,71,100,1653,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4194,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,971,SUCCESS
    2892,2021-07-01 19:19:54,11590.996,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29376,306,312,8,71,100,1653,2352,65535,65535,203,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4193,4194,4194,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.4,-273.2,35.2,1070,SUCCESS
    2893,2021-07-01 19:19:58,11595.002,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,306,310,8,71,100,1653,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.6,1100,SUCCESS
    2894,2021-07-01 19:20:02,11599.008,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29378,303,309,8,71,100,1654,2352,65535,65535,204,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    2895,2021-07-01 19:20:06,11603.021,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29378,301,307,8,71,100,1654,2352,65535,65535,205,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4194,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    2896,2021-07-01 19:20:10,11607.030,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,301,306,8,71,100,1654,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    2897,2021-07-01 19:20:14,11611.039,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,301,305,8,71,100,1655,2352,65535,65535,206,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1046,SUCCESS
    2898,2021-07-01 19:20:18,11615.047,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29378,299,303,8,71,100,1655,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1082,SUCCESS
    2899,2021-07-01 19:20:22,11619.055,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29380,298,302,8,71,100,1655,2352,65535,65535,207,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,994,SUCCESS
    2900,2021-07-01 19:20:26,11623.055,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,297,301,8,71,100,1656,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1058,SUCCESS
    2901,2021-07-01 19:20:30,11627.065,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29380,296,300,8,71,100,1656,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1140,SUCCESS
    2902,2021-07-01 19:20:34,11631.065,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,294,299,8,71,100,1656,2352,65535,65535,208,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.5,1086,SUCCESS
    2903,2021-07-01 19:20:38,11635.078,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,292,297,8,71,100,1657,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1081,SUCCESS
    2904,2021-07-01 19:20:42,11639.090,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29380,291,296,8,71,100,1657,2352,65535,65535,209,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1100,SUCCESS
    2905,2021-07-01 19:20:46,11643.104,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,289,294,8,71,100,1657,2352,65535,65535,210,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,998,SUCCESS
    2906,2021-07-01 19:20:50,11647.103,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29379,288,293,8,71,100,1658,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    2907,2021-07-01 19:20:54,11651.113,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29378,288,292,8,71,100,1658,2352,65535,65535,211,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4194,4194,4195,4195,4197,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    2908,2021-07-01 19:20:58,11655.127,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29380,284,290,8,71,100,1658,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    2909,2021-07-01 19:21:02,11659.134,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,286,289,8,71,100,1659,2352,65535,65535,212,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,993,SUCCESS
    2910,2021-07-01 19:21:06,11663.141,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,282,288,8,71,100,1659,2352,65535,65535,213,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,970,SUCCESS
    2911,2021-07-01 19:21:10,11667.157,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,280,286,8,71,100,1659,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1001,SUCCESS
    2912,2021-07-01 19:21:14,11671.164,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,281,285,8,71,100,1660,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.6,969,SUCCESS
    2913,2021-07-01 19:21:18,11675.168,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29381,279,284,8,71,100,1660,2352,65535,65535,214,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1005,SUCCESS
    2914,2021-07-01 19:21:22,11679.175,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29380,277,283,8,71,100,1660,2352,65535,65535,215,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    2915,2021-07-01 19:21:26,11683.187,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29383,277,281,8,71,100,1660,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4195,4195,4195,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    2916,2021-07-01 19:21:30,11687.206,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29381,275,280,8,71,100,1661,2352,65535,65535,216,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    2917,2021-07-01 19:21:34,11691.211,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29380,273,279,8,71,100,1661,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4194,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,946,SUCCESS
    2918,2021-07-01 19:21:38,11695.227,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29379,273,278,8,71,100,1661,2352,65535,65535,217,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1055,SUCCESS
    2919,2021-07-01 19:21:42,11699.229,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29380,271,276,8,71,100,1662,2352,65535,65535,218,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1042,SUCCESS
    2920,2021-07-01 19:21:46,11703.242,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29380,271,275,8,71,100,1662,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,979,SUCCESS
    2921,2021-07-01 19:21:50,11707.252,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29378,269,274,8,71,100,1662,2352,65535,65535,219,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4198,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1070,SUCCESS
    2922,2021-07-01 19:21:54,11711.253,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29380,269,273,8,71,100,1663,2352,65535,65535,220,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1061,SUCCESS
    2923,2021-07-01 19:21:58,11715.267,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29378,266,271,8,71,100,1663,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4194,4195,4195,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1080,SUCCESS
    2924,2021-07-01 19:22:02,11719.281,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29382,265,270,8,71,100,1663,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1047,SUCCESS
    2925,2021-07-01 19:22:06,11723.291,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29385,265,269,8,71,100,1663,2352,65535,65535,221,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.7,1030,SUCCESS
    2926,2021-07-01 19:22:10,11727.302,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29385,264,268,8,71,100,1664,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,980,SUCCESS
    2927,2021-07-01 19:22:14,11731.312,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,265,267,8,71,100,1664,2352,65535,65535,222,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1033,SUCCESS
    2928,2021-07-01 19:22:18,11735.324,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29388,262,266,8,71,100,1664,2352,65535,65535,223,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4195,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,959,SUCCESS
    2929,2021-07-01 19:22:22,11739.331,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29384,261,264,8,71,100,1665,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1077,SUCCESS
    2930,2021-07-01 19:22:26,11743.333,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29385,258,263,8,71,100,1665,2352,65535,65535,224,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1032,SUCCESS
    2931,2021-07-01 19:22:30,11747.342,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29385,257,262,8,71,100,1665,2352,65535,65535,225,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,958,SUCCESS
    2932,2021-07-01 19:22:34,11751.348,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29384,255,260,8,71,100,1666,2352,65535,65535,226,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1061,SUCCESS
    2933,2021-07-01 19:22:38,11755.360,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29383,256,259,8,71,100,1666,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1131,SUCCESS
    2934,2021-07-01 19:22:42,11759.368,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29385,255,258,8,71,100,1666,2352,65535,65535,227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.9,998,SUCCESS
    2935,2021-07-01 19:22:46,11763.377,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29386,253,257,8,71,100,1666,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,968,SUCCESS
    2936,2021-07-01 19:22:50,11767.392,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29385,251,256,8,71,100,1667,2352,65535,65535,228,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1062,SUCCESS
    2937,2021-07-01 19:22:54,11771.399,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29385,251,255,8,71,100,1667,2352,65535,65535,229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4195,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1009,SUCCESS
    2938,2021-07-01 19:22:58,11775.406,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,249,253,8,71,100,1667,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,985,SUCCESS
    2939,2021-07-01 19:23:02,11779.411,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,248,252,8,71,101,1668,2352,65535,65535,230,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,996,SUCCESS
    2940,2021-07-01 19:23:06,11783.424,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,247,251,8,71,101,1668,2352,65535,65535,231,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    2941,2021-07-01 19:23:10,11787.432,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,246,250,8,71,101,1668,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1023,SUCCESS
    2942,2021-07-01 19:23:14,11791.437,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,244,249,8,71,101,1668,2352,65535,65535,232,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1097,SUCCESS
    2943,2021-07-01 19:23:18,11795.452,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,244,248,8,71,101,1669,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1033,SUCCESS
    2944,2021-07-01 19:23:22,11799.464,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,242,247,8,71,101,1669,2352,65535,65535,233,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1007,SUCCESS
    2945,2021-07-01 19:23:26,11803.465,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,241,245,8,71,101,1669,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,974,SUCCESS
    2946,2021-07-01 19:23:30,11807.467,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,239,244,8,71,101,1669,2352,65535,65535,235,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1001,SUCCESS
    2947,2021-07-01 19:23:34,11811.470,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29386,240,243,8,72,101,1670,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4195,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.1,1050,SUCCESS
    2948,2021-07-01 19:23:38,11815.483,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29388,237,242,8,72,101,1670,2352,65535,65535,236,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1066,SUCCESS
    2949,2021-07-01 19:23:42,11819.496,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29388,237,241,8,72,101,1670,2352,65535,65535,237,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4196,4196,4196,4198,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1130,SUCCESS
    2950,2021-07-01 19:23:46,11823.504,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29388,234,240,8,72,101,1670,2352,65535,65535,238,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1106,SUCCESS
    2951,2021-07-01 19:23:50,11827.517,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29388,234,238,8,72,101,1671,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4195,4196,4196,4196,4198,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1046,SUCCESS
    2952,2021-07-01 19:23:54,11831.530,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29389,233,237,8,72,101,1671,2352,65535,65535,239,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4196,4196,4196,4196,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1065,SUCCESS
    2953,2021-07-01 19:23:58,11835.534,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29390,232,236,8,72,101,1671,2352,65535,65535,240,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4196,4196,4197,4199,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1046,SUCCESS
    2954,2021-07-01 19:24:02,11839.542,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,231,235,8,72,101,1672,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1084,SUCCESS
    2955,2021-07-01 19:24:06,11843.543,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,230,234,8,72,101,1672,2352,65535,65535,241,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,988,SUCCESS
    2956,2021-07-01 19:24:10,11847.554,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,229,233,8,72,101,1672,2352,65535,65535,242,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,963,SUCCESS
    2957,2021-07-01 19:24:14,11851.562,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,228,232,8,72,101,1672,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1018,SUCCESS
    2958,2021-07-01 19:24:18,11855.571,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,228,231,8,72,101,1673,2352,65535,65535,243,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4203,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1071,SUCCESS
    2959,2021-07-01 19:24:22,11859.582,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29387,224,229,8,72,101,1673,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4195,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1060,SUCCESS
    2960,2021-07-01 19:24:26,11863.597,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29388,224,228,8,72,101,1673,2352,65535,65535,245,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1061,SUCCESS
    2961,2021-07-01 19:24:30,11867.610,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29388,223,227,8,72,101,1673,2352,65535,65535,246,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    2962,2021-07-01 19:24:34,11871.624,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29388,222,226,8,72,101,1674,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1035,SUCCESS
    2963,2021-07-01 19:24:38,11875.629,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29388,221,225,8,72,101,1674,2352,65535,65535,247,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4196,4197,4197,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1002,SUCCESS
    2964,2021-07-01 19:24:42,11879.643,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29389,219,224,8,72,101,1674,2352,65535,65535,248,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4200,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1063,SUCCESS
    2965,2021-07-01 19:24:46,11883.659,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29389,219,223,8,72,101,1674,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1000,SUCCESS
    2966,2021-07-01 19:24:50,11887.659,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29389,218,222,8,72,101,1675,2352,65535,65535,249,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.6,1036,SUCCESS
    2967,2021-07-01 19:24:54,11891.661,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29391,216,220,8,72,101,1675,2352,65535,65535,251,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4197,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    2968,2021-07-01 19:24:58,11895.670,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29390,217,219,8,72,101,1675,2352,65535,65535,252,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1051,SUCCESS
    2969,2021-07-01 19:25:02,11899.685,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29391,214,218,8,72,101,1675,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1069,SUCCESS
    2970,2021-07-01 19:25:06,11903.687,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29391,215,217,8,72,101,1676,2352,65535,65535,253,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4196,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1033,SUCCESS
    2971,2021-07-01 19:25:10,11907.698,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29391,212,216,8,72,101,1676,2352,65535,65535,254,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1021,SUCCESS
    2972,2021-07-01 19:25:14,11911.703,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29391,212,215,8,72,101,1676,2352,65535,65535,255,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4196,4197,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1017,SUCCESS
    2973,2021-07-01 19:25:18,11915.708,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29390,209,214,8,72,101,1676,2352,65535,65535,256,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1123,SUCCESS
    2974,2021-07-01 19:25:22,11919.712,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,211,213,8,72,101,1676,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1023,SUCCESS
    2975,2021-07-01 19:25:26,11923.711,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29391,207,212,8,72,101,1677,2352,65535,65535,257,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    2976,2021-07-01 19:25:30,11927.713,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29393,209,211,8,72,101,1677,2352,65535,65535,258,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,993,SUCCESS
    2977,2021-07-01 19:25:34,11931.722,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29392,206,210,8,72,101,1677,2352,65535,65535,259,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    2978,2021-07-01 19:25:38,11935.735,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29392,206,209,8,72,101,1677,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1065,SUCCESS
    2979,2021-07-01 19:25:42,11939.741,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,204,208,8,72,101,1678,2352,65535,65535,260,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    2980,2021-07-01 19:25:46,11943.754,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,204,207,8,72,101,1678,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    2981,2021-07-01 19:25:50,11947.763,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,201,206,8,72,101,1678,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1068,SUCCESS
    2982,2021-07-01 19:25:54,11951.765,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,202,205,8,72,101,1678,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1064,SUCCESS
    2983,2021-07-01 19:25:58,11955.775,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,200,204,8,72,101,1679,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1057,SUCCESS
    2984,2021-07-01 19:26:02,11959.787,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,200,203,8,72,101,1679,2352,65535,65535,265,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4196,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    2985,2021-07-01 19:26:06,11963.801,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,199,202,8,72,101,1679,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1092,SUCCESS
    2986,2021-07-01 19:26:10,11967.804,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,198,201,8,72,101,1679,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1014,SUCCESS
    2987,2021-07-01 19:26:14,11971.817,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,197,200,8,72,101,1679,2352,65535,65535,267,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1028,SUCCESS
    2988,2021-07-01 19:26:18,11975.820,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29392,194,199,8,72,101,1680,2352,65535,65535,261,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4201,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1010,SUCCESS
    2989,2021-07-01 19:26:22,11979.836,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,193,198,8,72,101,1680,2352,65535,65535,262,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4201,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.8,1000,SUCCESS
    2990,2021-07-01 19:26:26,11983.848,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29394,193,197,8,72,101,1680,2352,65535,65535,263,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,981,SUCCESS
    2991,2021-07-01 19:26:30,11987.854,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29393,192,196,8,72,101,1680,2352,65535,65535,264,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4201,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,990,SUCCESS
    2992,2021-07-01 19:26:34,11991.854,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,191,195,8,72,101,1680,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4197,4197,4197,4202,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1055,SUCCESS
    2993,2021-07-01 19:26:38,11995.858,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29394,190,194,8,72,101,1681,2352,65535,65535,266,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4202,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1036,SUCCESS
    2994,2021-07-01 19:26:43,11999.867,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,189,192,8,72,101,1681,2352,65535,65535,268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4198,4197,4197,4202,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,990,SUCCESS
    2995,2021-07-01 19:26:47,12003.867,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,190,192,8,72,101,1681,2352,65535,65535,269,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4197,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,962,SUCCESS
    2996,2021-07-01 19:26:51,12007.867,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29396,188,191,8,72,101,1681,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4196,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1040,SUCCESS
    2997,2021-07-01 19:26:55,12011.875,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,187,190,8,72,101,1682,2352,65535,65535,270,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4196,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1083,SUCCESS
    2998,2021-07-01 19:26:59,12015.876,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29397,186,189,8,72,101,1682,2352,65535,65535,271,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    2999,2021-07-01 19:27:03,12019.877,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29396,185,188,8,72,101,1682,2352,65535,65535,272,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3000,2021-07-01 19:27:07,12023.883,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29397,183,187,8,72,101,1682,2352,65535,65535,273,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,948,SUCCESS
    3001,2021-07-01 19:27:11,12027.896,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,184,186,8,72,101,1682,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4197,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1012,SUCCESS
    3002,2021-07-01 19:27:15,12031.909,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29398,182,185,8,72,101,1683,2352,65535,65535,275,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,993,SUCCESS
    3003,2021-07-01 19:27:19,12035.916,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29396,182,184,8,72,101,1683,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,961,SUCCESS
    3004,2021-07-01 19:27:23,12039.925,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29398,181,184,8,72,101,1683,2352,65535,65535,276,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,999,SUCCESS
    3005,2021-07-01 19:27:27,12043.940,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29396,178,183,8,72,101,1683,2352,65535,65535,277,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4197,4198,4202,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1045,SUCCESS
    3006,2021-07-01 19:27:31,12047.942,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29397,178,182,8,72,101,1683,2352,65535,65535,279,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,972,SUCCESS
    3007,2021-07-01 19:27:35,12051.952,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29398,175,180,8,72,102,1684,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,972,SUCCESS
    3008,2021-07-01 19:27:39,12055.954,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29395,176,179,8,72,102,1684,2352,65535,65535,282,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1064,SUCCESS
    3009,2021-07-01 19:27:43,12059.964,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,175,178,8,72,102,1684,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1039,SUCCESS
    3010,2021-07-01 19:27:47,12063.976,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,174,177,8,72,102,1684,2352,65535,65535,284,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,978,SUCCESS
    3011,2021-07-01 19:27:51,12067.978,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,174,176,8,72,102,1684,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1072,SUCCESS
    3012,2021-07-01 19:27:55,12071.983,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,172,175,8,72,102,1685,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.7,1057,SUCCESS
    3013,2021-07-01 19:27:59,12075.985,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,171,174,8,72,102,1685,2352,65535,65535,281,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1064,SUCCESS
    3014,2021-07-01 19:28:03,12079.990,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,170,173,8,72,102,1685,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1012,SUCCESS
    3015,2021-07-01 19:28:07,12083.990,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29398,169,173,8,72,102,1685,2352,65535,65535,283,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1011,SUCCESS
    3016,2021-07-01 19:28:11,12088.000,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29398,168,171,8,72,102,1685,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1080,SUCCESS
    3017,2021-07-01 19:28:15,12092.004,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,168,171,8,72,102,1686,2352,65535,65535,285,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1091,SUCCESS
    3018,2021-07-01 19:28:19,12096.004,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,168,170,8,72,102,1686,2352,65535,65535,286,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,996,SUCCESS
    3019,2021-07-01 19:28:23,12100.019,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,166,169,8,72,102,1686,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4202,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1029,SUCCESS
    3020,2021-07-01 19:28:27,12104.031,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,165,169,8,72,102,1686,2352,65535,65535,288,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4197,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,955,SUCCESS
    3021,2021-07-01 19:28:31,12108.035,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,166,168,8,72,102,1686,2352,65535,65535,289,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.5,1018,SUCCESS
    3022,2021-07-01 19:28:35,12112.047,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,165,167,8,72,102,1686,2352,65535,65535,290,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1049,SUCCESS
    3023,2021-07-01 19:28:39,12116.062,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,163,166,8,72,102,1687,2352,65535,65535,291,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1018,SUCCESS
    3024,2021-07-01 19:28:43,12120.068,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,163,165,8,72,102,1687,2352,65535,65535,293,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,965,SUCCESS
    3025,2021-07-01 19:28:47,12124.079,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,160,164,8,72,102,1687,2352,65535,65535,294,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4197,4198,4203,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1000,SUCCESS
    3026,2021-07-01 19:28:51,12128.087,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,159,163,8,72,102,1687,2352,65535,65535,296,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.3,1040,SUCCESS
    3027,2021-07-01 19:28:55,12132.094,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29401,160,162,8,72,102,1687,2352,65535,65535,297,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1004,SUCCESS
    3028,2021-07-01 19:28:59,12136.109,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,158,161,8,72,102,1688,2352,65535,65535,298,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1049,SUCCESS
    3029,2021-07-01 19:29:03,12140.109,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,156,160,8,72,102,1688,2352,65535,65535,300,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1080,SUCCESS
    3030,2021-07-01 19:29:07,12144.122,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,156,159,8,72,102,1688,2352,65535,65535,301,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3249,26.3,26.4,-273.2,26.4,-273.2,35.2,1036,SUCCESS
    3031,2021-07-01 19:29:11,12148.126,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29401,156,159,8,72,102,1688,2352,65535,65535,303,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    3032,2021-07-01 19:29:15,12152.131,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,155,157,8,72,102,1688,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4203,4207,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1042,SUCCESS
    3033,2021-07-01 19:29:19,12156.138,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29399,153,157,8,72,102,1688,2352,65535,65535,304,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1052,SUCCESS
    3034,2021-07-01 19:29:23,12160.142,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,153,156,8,72,102,1689,2352,65535,65535,305,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3035,2021-07-01 19:29:27,12164.151,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,153,155,8,72,102,1689,2352,65535,65535,307,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.1,1011,SUCCESS
    3036,2021-07-01 19:29:31,12168.165,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,151,154,8,72,102,1689,2352,65535,65535,309,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4197,4198,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1117,SUCCESS
    3037,2021-07-01 19:29:35,12172.178,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29400,150,153,8,72,102,1689,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4198,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,979,SUCCESS
    3038,2021-07-01 19:29:39,12176.191,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29401,150,152,8,72,102,1689,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1077,SUCCESS
    3039,2021-07-01 19:29:43,12180.202,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29401,148,152,8,72,102,1689,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4203,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1095,SUCCESS
    3040,2021-07-01 19:29:47,12184.217,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,148,151,8,72,102,1690,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1114,SUCCESS
    3041,2021-07-01 19:29:51,12188.231,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,148,150,8,72,102,1690,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4197,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.2,1084,SUCCESS
    3042,2021-07-01 19:29:55,12192.234,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,146,149,8,72,102,1690,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3249,26.3,26.4,-273.2,26.4,-273.2,35.2,1018,SUCCESS
    3043,2021-07-01 19:29:59,12196.241,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,145,149,8,72,102,1690,2352,65535,65535,310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1026,SUCCESS
    3044,2021-07-01 19:30:03,12200.253,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,146,148,8,72,102,1690,2352,65535,65535,312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3045,2021-07-01 19:30:07,12204.259,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,143,147,8,72,102,1690,2352,65535,65535,313,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4198,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1007,SUCCESS
    3046,2021-07-01 19:30:11,12208.264,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,142,146,8,72,102,1691,2352,65535,65535,315,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3047,2021-07-01 19:30:15,12212.269,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,144,145,8,72,102,1691,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1045,SUCCESS
    3048,2021-07-01 19:30:19,12216.280,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,141,145,8,72,102,1691,2352,65535,65535,317,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3249,26.3,26.4,-273.2,26.4,-273.2,35.2,1065,SUCCESS
    3049,2021-07-01 19:30:23,12220.294,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,141,144,8,72,102,1691,2352,65535,65535,319,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4203,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1004,SUCCESS
    3050,2021-07-01 19:30:27,12224.300,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,140,143,8,72,102,1691,2352,65535,65535,321,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4203,4207,0,0,0,0,0,0,0,0,3249,26.3,26.4,-273.2,26.4,-273.2,35.3,1060,SUCCESS
    3051,2021-07-01 19:30:31,12228.303,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,140,142,8,72,102,1691,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1060,SUCCESS
    3052,2021-07-01 19:30:35,12232.314,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,139,142,8,72,102,1692,2352,65535,65535,322,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1079,SUCCESS
    3053,2021-07-01 19:30:39,12236.324,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,139,141,8,72,102,1692,2352,65535,65535,324,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.6,994,SUCCESS
    3054,2021-07-01 19:30:43,12240.337,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,138,140,8,72,102,1692,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1022,SUCCESS
    3055,2021-07-01 19:30:47,12244.346,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,137,140,8,72,102,1692,2352,65535,65535,326,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1031,SUCCESS
    3056,2021-07-01 19:30:51,12248.349,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,136,139,8,72,102,1692,2352,65535,65535,328,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1058,SUCCESS
    3057,2021-07-01 19:30:55,12252.359,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,135,138,8,72,102,1692,2352,65535,65535,330,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.2,1040,SUCCESS
    3058,2021-07-01 19:30:59,12256.374,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,134,137,8,72,102,1692,2352,65535,65535,332,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1083,SUCCESS
    3059,2021-07-01 19:31:03,12260.374,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,135,137,8,72,102,1693,2352,65535,65535,332,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1049,SUCCESS
    3060,2021-07-01 19:31:07,12264.384,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,133,136,8,72,102,1693,2352,65535,65535,334,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,959,SUCCESS
    3061,2021-07-01 19:31:11,12268.384,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,133,135,8,72,102,1693,2352,65535,65535,336,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    3062,2021-07-01 19:31:15,12272.390,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,133,134,8,72,102,1693,2352,65535,65535,338,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.8,1057,SUCCESS
    3063,2021-07-01 19:31:19,12276.400,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,131,134,8,72,102,1693,2352,65535,65535,338,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.2,1071,SUCCESS
    3064,2021-07-01 19:31:23,12280.408,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,130,133,8,72,102,1693,2352,65535,65535,340,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1002,SUCCESS
    3065,2021-07-01 19:31:27,12284.407,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,131,133,8,72,102,1693,2352,65535,65535,340,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.3,1062,SUCCESS
    3066,2021-07-01 19:31:31,12288.411,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,129,132,8,73,102,1694,2352,65535,65535,341,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    3067,2021-07-01 19:31:35,12292.421,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,128,131,8,73,102,1694,2352,65535,65535,344,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1035,SUCCESS
    3068,2021-07-01 19:31:39,12296.423,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,127,130,8,73,102,1694,2352,65535,65535,346,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1062,SUCCESS
    3069,2021-07-01 19:31:43,12300.442,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,126,129,8,73,102,1694,2352,65535,65535,348,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1012,SUCCESS
    3070,2021-07-01 19:31:47,12304.451,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,126,129,8,73,102,1694,2352,65535,65535,348,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1082,SUCCESS
    3071,2021-07-01 19:31:51,12308.453,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,125,128,8,73,102,1694,2352,65535,65535,351,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3246,26.3,26.4,-273.2,26.4,-273.2,35.3,1049,SUCCESS
    3072,2021-07-01 19:31:55,12312.456,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,124,127,8,73,102,1694,2352,65535,65535,353,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1047,SUCCESS
    3073,2021-07-01 19:31:59,12316.459,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,124,126,8,73,102,1695,2352,65535,65535,355,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,995,SUCCESS
    3074,2021-07-01 19:32:03,12320.473,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,124,125,8,73,102,1695,2352,65535,65535,357,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1014,SUCCESS
    3075,2021-07-01 19:32:07,12324.487,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29402,122,125,8,73,102,1695,2352,65535,65535,357,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1061,SUCCESS
    3076,2021-07-01 19:32:11,12328.499,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,122,124,8,73,102,1695,2352,65535,65535,354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1017,SUCCESS
    3077,2021-07-01 19:32:15,12332.503,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,121,124,8,73,102,1695,2352,65535,65535,354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1078,SUCCESS
    3078,2021-07-01 19:32:19,12336.514,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,121,123,8,73,102,1695,2352,65535,65535,356,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1033,SUCCESS
    3079,2021-07-01 19:32:23,12340.526,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,120,122,8,73,102,1695,2352,65535,65535,359,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4205,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1038,SUCCESS
    3080,2021-07-01 19:32:27,12344.526,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,117,122,8,73,102,1696,2352,65535,65535,358,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4204,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,946,SUCCESS
    3081,2021-07-01 19:32:31,12348.536,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,118,121,8,73,102,1696,2352,65535,65535,361,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,995,SUCCESS
    3082,2021-07-01 19:32:35,12352.536,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,118,120,8,73,102,1696,2352,65535,65535,364,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1012,SUCCESS
    3083,2021-07-01 19:32:39,12356.542,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,119,120,8,73,102,1696,2352,65535,65535,364,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,945,SUCCESS
    3084,2021-07-01 19:32:43,12360.554,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,117,119,8,73,102,1696,2352,65535,65535,366,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,979,SUCCESS
    3085,2021-07-01 19:32:47,12364.557,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,116,119,8,73,102,1696,2352,65535,65535,366,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,958,SUCCESS
    3086,2021-07-01 19:32:51,12368.567,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,116,118,8,73,102,1696,2352,65535,65535,369,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,981,SUCCESS
    3087,2021-07-01 19:32:55,12372.576,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,115,117,8,73,102,1696,2352,65535,65535,372,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,989,SUCCESS
    3088,2021-07-01 19:32:59,12376.586,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,114,117,8,73,102,1697,2352,65535,65535,371,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1040,SUCCESS
    3089,2021-07-01 19:33:03,12380.591,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29404,115,116,8,73,102,1697,2352,65535,65535,374,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1073,SUCCESS
    3090,2021-07-01 19:33:07,12384.606,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,114,116,8,73,102,1697,2352,65535,65535,374,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1036,SUCCESS
    3091,2021-07-01 19:33:11,12388.608,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,113,115,8,73,102,1697,2352,65535,65535,377,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1049,SUCCESS
    3092,2021-07-01 19:33:15,12392.608,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29403,113,115,8,73,102,1697,2352,65535,65535,377,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1099,SUCCESS
    3093,2021-07-01 19:33:19,12396.612,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,112,114,8,73,102,1697,2352,65535,65535,379,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1031,SUCCESS
    3094,2021-07-01 19:33:23,12400.618,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,112,113,8,73,102,1697,2352,65535,65535,383,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1007,SUCCESS
    3095,2021-07-01 19:33:27,12404.626,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,110,113,8,73,102,1697,2352,65535,65535,383,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1033,SUCCESS
    3096,2021-07-01 19:33:31,12408.636,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,109,112,8,73,102,1698,2352,65535,65535,385,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,943,SUCCESS
    3097,2021-07-01 19:33:35,12412.636,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,108,111,8,73,102,1698,2352,65535,65535,388,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1068,SUCCESS
    3098,2021-07-01 19:33:39,12416.637,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,108,110,8,73,102,1698,2352,65535,65535,391,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1068,SUCCESS
    3099,2021-07-01 19:33:43,12420.642,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,107,110,8,73,102,1698,2352,65535,65535,391,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3100,2021-07-01 19:33:47,12424.654,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,107,109,8,73,102,1698,2352,65535,65535,395,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1036,SUCCESS
    3101,2021-07-01 19:33:51,12428.668,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,105,108,8,73,102,1698,2352,65535,65535,398,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1092,SUCCESS
    3102,2021-07-01 19:33:55,12432.682,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,107,108,8,73,102,1698,2352,65535,65535,398,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4198,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3249,26.3,26.4,-273.2,26.4,-273.2,35.3,977,SUCCESS
    3103,2021-07-01 19:33:59,12436.682,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,105,107,8,73,102,1698,2352,65535,65535,401,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4198,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1072,SUCCESS
    3104,2021-07-01 19:34:03,12440.691,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29405,105,107,8,73,102,1699,2352,65535,65535,400,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4199,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1028,SUCCESS
    3105,2021-07-01 19:34:07,12444.701,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,105,106,8,73,102,1699,2352,65535,65535,404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1021,SUCCESS
    3106,2021-07-01 19:34:11,12448.716,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,103,106,8,73,102,1699,2352,65535,65535,404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1098,SUCCESS
    3107,2021-07-01 19:34:15,12452.719,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,103,105,8,73,102,1699,2352,65535,65535,407,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1032,SUCCESS
    3108,2021-07-01 19:34:19,12456.729,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,102,105,8,73,102,1699,2352,65535,65535,407,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,993,SUCCESS
    3109,2021-07-01 19:34:23,12460.731,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29406,102,104,8,73,102,1699,2352,65535,65535,411,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4199,4199,4198,4205,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.1,1060,SUCCESS
    3110,2021-07-01 19:34:27,12464.738,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,102,104,8,73,102,1699,2352,65535,65535,411,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1077,SUCCESS
    3111,2021-07-01 19:34:31,12468.752,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,101,103,8,73,102,1699,2352,65535,65535,414,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4199,4205,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1141,SUCCESS
    3112,2021-07-01 19:34:35,12472.767,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,101,103,8,73,102,1700,2352,65535,65535,414,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.8,1067,SUCCESS
    3113,2021-07-01 19:34:39,12476.780,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,101,102,8,73,102,1700,2352,65535,65535,417,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4199,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1081,SUCCESS
    3114,2021-07-01 19:34:43,12480.794,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,100,102,8,73,102,1700,2352,65535,65535,417,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1021,SUCCESS
    3115,2021-07-01 19:34:47,12484.803,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,100,101,8,73,102,1700,2352,65535,65535,421,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,998,SUCCESS
    3116,2021-07-01 19:34:51,12488.816,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,99,101,8,73,102,1700,2352,65535,65535,421,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1108,SUCCESS
    3117,2021-07-01 19:34:55,12492.827,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,98,100,8,73,102,1700,2352,65535,65535,425,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1067,SUCCESS
    3118,2021-07-01 19:34:59,12496.843,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,97,100,8,73,102,1700,2352,65535,65535,425,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,972,SUCCESS
    3119,2021-07-01 19:35:03,12500.846,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,98,99,8,73,102,1700,2352,65535,65535,423,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1078,SUCCESS
    3120,2021-07-01 19:35:07,12504.848,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,97,99,8,73,102,1700,2352,65535,65535,423,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1093,SUCCESS
    3121,2021-07-01 19:35:11,12508.862,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,97,98,8,73,102,1700,2352,65535,65535,427,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,984,SUCCESS
    3122,2021-07-01 19:35:15,12512.861,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,97,98,8,73,103,1701,2352,65535,65535,426,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1047,SUCCESS
    3123,2021-07-01 19:35:20,12516.874,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,95,97,8,73,103,1701,2352,65535,65535,431,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4198,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1068,SUCCESS
    3124,2021-07-01 19:35:24,12520.884,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,94,97,8,73,103,1701,2352,65535,65535,431,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1087,SUCCESS
    3125,2021-07-01 19:35:28,12524.888,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,93,96,8,73,103,1701,2352,65535,65535,434,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,957,SUCCESS
    3126,2021-07-01 19:35:32,12528.889,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,94,96,8,73,103,1701,2352,65535,65535,434,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1050,SUCCESS
    3127,2021-07-01 19:35:36,12532.907,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,95,95,8,73,103,1701,2352,65535,65535,438,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,954,SUCCESS
    3128,2021-07-01 19:35:40,12536.910,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,94,95,8,73,103,1701,2352,65535,65535,438,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1062,SUCCESS
    3129,2021-07-01 19:35:44,12540.920,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,92,94,8,73,103,1701,2352,65535,65535,443,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,955,SUCCESS
    3130,2021-07-01 19:35:48,12544.928,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,92,93,8,73,103,1701,2352,65535,65535,447,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.1,986,SUCCESS
    3131,2021-07-01 19:35:52,12548.931,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,91,93,8,73,103,1702,2352,65535,65535,446,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,961,SUCCESS
    3132,2021-07-01 19:35:56,12552.944,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,91,93,8,73,103,1702,2352,65535,65535,451,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1011,SUCCESS
    3133,2021-07-01 19:36:00,12556.956,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,90,92,8,73,103,1702,2352,65535,65535,451,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1062,SUCCESS
    3134,2021-07-01 19:36:04,12560.970,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29407,90,91,8,73,103,1702,2352,65535,65535,456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1031,SUCCESS
    3135,2021-07-01 19:36:08,12564.980,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,89,91,8,73,103,1702,2352,65535,65535,456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1008,SUCCESS
    3136,2021-07-01 19:36:12,12568.987,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,89,90,8,73,103,1702,2352,65535,65535,460,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1014,SUCCESS
    3137,2021-07-01 19:36:16,12573.002,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,89,90,8,73,103,1702,2352,65535,65535,460,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4206,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1019,SUCCESS
    3138,2021-07-01 19:36:20,12577.004,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,89,90,8,73,103,1702,2352,65535,65535,460,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1015,SUCCESS
    3139,2021-07-01 19:36:24,12581.015,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,88,89,8,73,103,1702,2352,65535,65535,465,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.8,959,SUCCESS
    3140,2021-07-01 19:36:28,12585.020,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,87,89,8,73,103,1702,2352,65535,65535,465,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,966,SUCCESS
    3141,2021-07-01 19:36:32,12589.027,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,88,88,8,73,103,1703,2352,65535,65535,469,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,989,SUCCESS
    3142,2021-07-01 19:36:36,12593.035,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,86,88,8,73,103,1703,2352,65535,65535,469,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1029,SUCCESS
    3143,2021-07-01 19:36:40,12597.046,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,87,87,8,73,103,1703,2352,65535,65535,474,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,987,SUCCESS
    3144,2021-07-01 19:36:44,12601.059,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,85,87,8,73,103,1703,2352,65535,65535,474,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,958,SUCCESS
    3145,2021-07-01 19:36:48,12605.071,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,84,86,8,73,103,1703,2352,65535,65535,479,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,977,SUCCESS
    3146,2021-07-01 19:36:52,12609.080,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,84,86,8,73,103,1703,2352,65535,65535,479,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1093,SUCCESS
    3147,2021-07-01 19:36:56,12613.095,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,85,85,8,73,103,1703,2352,65535,65535,484,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1049,SUCCESS
    3148,2021-07-01 19:37:00,12617.109,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,83,85,8,73,103,1703,2352,65535,65535,484,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4198,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1001,SUCCESS
    3149,2021-07-01 19:37:04,12621.109,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,83,85,8,73,103,1703,2352,65535,65535,484,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3150,2021-07-01 19:37:08,12625.120,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,83,84,8,73,103,1703,2352,65535,65535,489,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,975,SUCCESS
    3151,2021-07-01 19:37:12,12629.126,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,82,84,8,73,103,1703,2352,65535,65535,489,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1002,SUCCESS
    3152,2021-07-01 19:37:16,12633.128,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,82,84,8,73,103,1704,2352,65535,65535,489,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1029,SUCCESS
    3153,2021-07-01 19:37:20,12637.142,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,82,83,8,73,103,1704,2352,65535,65535,494,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1066,SUCCESS
    3154,2021-07-01 19:37:24,12641.156,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,82,83,8,73,103,1704,2352,65535,65535,494,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3155,2021-07-01 19:37:28,12645.167,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,80,82,8,73,103,1704,2352,65535,65535,500,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1038,SUCCESS
    3156,2021-07-01 19:37:32,12649.173,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,82,82,8,73,103,1704,2352,65535,65535,500,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,987,SUCCESS
    3157,2021-07-01 19:37:36,12653.185,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,81,82,8,73,103,1704,2352,65535,65535,500,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1020,SUCCESS
    3158,2021-07-01 19:37:40,12657.189,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,80,81,8,73,103,1704,2352,65535,65535,506,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    3159,2021-07-01 19:37:44,12661.190,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,79,81,8,73,103,1704,2352,65535,65535,506,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1015,SUCCESS
    3160,2021-07-01 19:37:48,12665.193,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,78,81,8,73,103,1704,2352,65535,65535,506,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,998,SUCCESS
    3161,2021-07-01 19:37:52,12669.202,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,80,80,8,73,103,1704,2352,65535,65535,512,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1067,SUCCESS
    3162,2021-07-01 19:37:56,12673.201,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,79,80,8,73,103,1704,2352,65535,65535,512,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1037,SUCCESS
    3163,2021-07-01 19:38:00,12677.213,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,79,80,8,73,103,1705,2352,65535,65535,511,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1008,SUCCESS
    3164,2021-07-01 19:38:04,12681.224,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,78,79,8,73,103,1705,2352,65535,65535,516,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1011,SUCCESS
    3165,2021-07-01 19:38:08,12685.228,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,78,79,8,73,103,1705,2352,65535,65535,516,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1056,SUCCESS
    3166,2021-07-01 19:38:12,12689.228,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29408,77,79,8,73,103,1705,2352,65535,65535,516,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1010,SUCCESS
    3167,2021-07-01 19:38:16,12693.232,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,78,78,8,73,103,1705,2352,65535,65535,523,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1035,SUCCESS
    3168,2021-07-01 19:38:20,12697.247,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,77,78,8,73,103,1705,2352,65535,65535,523,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1019,SUCCESS
    3169,2021-07-01 19:38:24,12701.262,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,75,77,8,73,103,1705,2352,65535,65535,529,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,990,SUCCESS
    3170,2021-07-01 19:38:28,12705.276,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,76,77,8,73,103,1705,2352,65535,65535,529,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,991,SUCCESS
    3171,2021-07-01 19:38:32,12709.283,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,75,77,8,73,103,1705,2352,65535,65535,529,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3172,2021-07-01 19:38:36,12713.291,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,75,76,8,73,103,1705,2352,65535,65535,535,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1008,SUCCESS
    3173,2021-07-01 19:38:40,12717.303,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29409,75,76,8,73,103,1705,2352,65535,65535,535,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,981,SUCCESS
    3174,2021-07-01 19:38:44,12721.313,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,74,75,8,73,103,1706,2352,65535,65535,542,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4200,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1001,SUCCESS
    3175,2021-07-01 19:38:48,12725.316,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,73,75,8,73,103,1706,2352,65535,65535,542,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1031,SUCCESS
    3176,2021-07-01 19:38:52,12729.327,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,73,75,8,73,103,1706,2352,65535,65535,542,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1064,SUCCESS
    3177,2021-07-01 19:38:56,12733.337,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,73,74,8,73,103,1706,2352,65535,65535,543,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,977,SUCCESS
    3178,2021-07-01 19:39:00,12737.344,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,72,74,8,73,103,1706,2352,65535,65535,543,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1017,SUCCESS
    3179,2021-07-01 19:39:04,12741.359,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,72,73,8,73,103,1706,2352,65535,65535,551,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    3180,2021-07-01 19:39:08,12745.367,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,72,73,8,73,103,1706,2352,65535,65535,551,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4200,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,950,SUCCESS
    3181,2021-07-01 19:39:12,12749.382,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,72,73,8,73,103,1706,2352,65535,65535,551,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.8,1000,SUCCESS
    3182,2021-07-01 19:39:16,12753.397,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,71,73,8,73,103,1706,2352,65535,65535,551,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,965,SUCCESS
    3183,2021-07-01 19:39:20,12757.398,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,72,72,8,73,103,1706,2352,65535,65535,558,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1009,SUCCESS
    3184,2021-07-01 19:39:24,12761.402,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,71,72,8,73,103,1706,2352,65535,65535,558,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4212,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1037,SUCCESS
    3185,2021-07-01 19:39:28,12765.417,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,71,72,8,73,103,1706,2352,65535,65535,558,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4211,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    3186,2021-07-01 19:39:32,12769.423,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,70,71,8,73,103,1706,2352,65535,65535,565,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1015,SUCCESS
    3187,2021-07-01 19:39:36,12773.436,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,69,71,8,73,103,1707,2352,65535,65535,565,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1005,SUCCESS
    3188,2021-07-01 19:39:40,12777.465,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,68,70,8,73,103,1707,2352,65535,65535,572,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1006,SUCCESS
    3189,2021-07-01 19:39:44,12781.446,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,70,70,8,73,103,1707,2352,65535,65535,572,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,962,SUCCESS
    3190,2021-07-01 19:39:48,12785.448,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,69,70,8,73,103,1707,2352,65535,65535,572,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,961,SUCCESS
    3191,2021-07-01 19:39:52,12789.460,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,68,70,8,73,103,1707,2352,65535,65535,572,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1012,SUCCESS
    3192,2021-07-01 19:39:56,12793.473,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,68,69,8,73,103,1707,2352,65535,65535,580,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,980,SUCCESS
    3193,2021-07-01 19:40:00,12797.484,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,69,69,8,73,103,1707,2352,65535,65535,580,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1001,SUCCESS
    3194,2021-07-01 19:40:04,12801.493,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,68,69,8,73,103,1707,2352,65535,65535,580,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.1,1013,SUCCESS
    3195,2021-07-01 19:40:08,12805.501,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29410,66,68,8,73,103,1707,2352,65535,65535,588,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.4,26.4,-273.2,26.4,-273.2,35.3,1003,SUCCESS
    3196,2021-07-01 19:40:12,12809.500,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,67,68,8,73,103,1707,2352,65535,65535,588,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3197,2021-07-01 19:40:16,12813.505,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,67,68,8,73,103,1707,2352,65535,65535,588,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,995,SUCCESS
    3198,2021-07-01 19:40:20,12817.516,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,67,68,8,73,103,1707,2352,65535,65535,588,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1051,SUCCESS
    3199,2021-07-01 19:40:24,12821.515,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,66,67,8,73,103,1707,2352,65535,65535,596,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,972,SUCCESS
    3200,2021-07-01 19:40:28,12825.518,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,67,67,8,73,103,1708,2352,65535,65535,596,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1017,SUCCESS
    3201,2021-07-01 19:40:32,12829.532,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,66,67,8,73,103,1708,2352,65535,65535,596,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1036,SUCCESS
    3202,2021-07-01 19:40:36,12833.537,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,65,67,8,73,103,1708,2352,65535,65535,596,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,970,SUCCESS
    3203,2021-07-01 19:40:40,12837.538,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,65,66,8,73,103,1708,2352,65535,65535,604,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,996,SUCCESS
    3204,2021-07-01 19:40:44,12841.543,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,65,66,8,73,103,1708,2352,65535,65535,604,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,947,SUCCESS
    3205,2021-07-01 19:40:48,12845.549,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,65,66,8,73,103,1708,2352,65535,65535,604,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1015,SUCCESS
    3206,2021-07-01 19:40:52,12849.554,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,64,66,8,73,103,1708,2352,65535,65535,604,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1011,SUCCESS
    3207,2021-07-01 19:40:56,12853.557,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,64,65,8,73,103,1708,2352,65535,65535,613,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1045,SUCCESS
    3208,2021-07-01 19:41:00,12857.568,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,64,65,8,73,103,1708,2352,65535,65535,613,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1015,SUCCESS
    3209,2021-07-01 19:41:04,12861.583,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,64,65,8,73,103,1708,2352,65535,65535,613,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.4,26.4,-273.2,26.4,-273.2,35.3,1030,SUCCESS
    3210,2021-07-01 19:41:08,12865.589,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,63,64,8,73,103,1708,2352,65535,65535,622,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1071,SUCCESS
    3211,2021-07-01 19:41:12,12869.592,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,63,64,8,73,103,1708,2352,65535,65535,622,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1020,SUCCESS
    3212,2021-07-01 19:41:16,12873.603,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,63,64,8,73,103,1708,2352,65535,65535,622,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,977,SUCCESS
    3213,2021-07-01 19:41:20,12877.615,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,62,64,8,73,103,1708,2352,65535,65535,622,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,996,SUCCESS
    3214,2021-07-01 19:41:24,12881.624,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,62,63,8,73,103,1709,2352,65535,65535,630,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1004,SUCCESS
    3215,2021-07-01 19:41:28,12885.631,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,63,63,8,73,103,1709,2352,65535,65535,630,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1030,SUCCESS
    3216,2021-07-01 19:41:32,12889.642,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,62,63,8,73,103,1709,2352,65535,65535,630,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1047,SUCCESS
    3217,2021-07-01 19:41:36,12893.647,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,62,63,8,73,103,1709,2352,65535,65535,630,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3218,2021-07-01 19:41:40,12897.648,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,61,62,8,73,103,1709,2352,65535,65535,640,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1011,SUCCESS
    3219,2021-07-01 19:41:44,12901.662,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,60,62,8,73,103,1709,2352,65535,65535,640,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,981,SUCCESS
    3220,2021-07-01 19:41:48,12905.664,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,62,62,8,73,103,1709,2352,65535,65535,640,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1028,SUCCESS
    3221,2021-07-01 19:41:52,12909.677,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,61,62,8,73,103,1709,2352,65535,65535,640,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,984,SUCCESS
    3222,2021-07-01 19:41:56,12913.686,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,61,61,8,73,103,1709,2352,65535,65535,650,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.5,993,SUCCESS
    3223,2021-07-01 19:42:00,12917.686,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,59,61,8,73,103,1709,2352,65535,65535,650,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1050,SUCCESS
    3224,2021-07-01 19:42:04,12921.687,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,61,61,8,73,103,1709,2352,65535,65535,650,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1020,SUCCESS
    3225,2021-07-01 19:42:08,12925.692,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,60,61,8,73,103,1709,2352,65535,65535,650,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,981,SUCCESS
    3226,2021-07-01 19:42:12,12929.700,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,61,61,8,73,103,1709,2352,65535,65535,650,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,989,SUCCESS
    3227,2021-07-01 19:42:16,12933.707,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,58,60,8,73,103,1709,2352,65535,65535,660,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4199,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3228,2021-07-01 19:42:20,12937.711,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,60,60,8,73,103,1709,2352,65535,65535,660,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,980,SUCCESS
    3229,2021-07-01 19:42:24,12941.714,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,58,59,8,73,103,1710,2352,65535,65535,670,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,961,SUCCESS
    3230,2021-07-01 19:42:28,12945.715,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,58,59,8,73,103,1710,2352,65535,65535,670,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,962,SUCCESS
    3231,2021-07-01 19:42:32,12949.725,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,58,59,8,73,103,1710,2352,65535,65535,670,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.7,955,SUCCESS
    3232,2021-07-01 19:42:36,12953.737,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,57,58,8,73,103,1710,2352,65535,65535,681,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1045,SUCCESS
    3233,2021-07-01 19:42:40,12957.742,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,57,58,8,73,103,1710,2352,65535,65535,681,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,963,SUCCESS
    3234,2021-07-01 19:42:44,12961.750,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,56,58,8,73,103,1710,2352,65535,65535,693,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4199,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3235,2021-07-01 19:42:48,12965.756,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,56,57,8,73,103,1710,2352,65535,65535,693,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4199,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,965,SUCCESS
    3236,2021-07-01 19:42:52,12969.764,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,57,57,8,73,103,1710,2352,65535,65535,693,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1038,SUCCESS
    3237,2021-07-01 19:42:56,12973.778,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29411,56,57,8,73,103,1710,2352,65535,65535,693,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,990,SUCCESS
    3238,2021-07-01 19:43:00,12977.784,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,55,56,8,73,103,1710,2352,65535,65535,704,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1125,SUCCESS
    3239,2021-07-01 19:43:04,12981.786,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,56,56,8,73,103,1710,2352,65535,65535,704,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1059,SUCCESS
    3240,2021-07-01 19:43:08,12985.792,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,56,56,8,73,103,1710,2352,65535,65535,704,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,959,SUCCESS
    3241,2021-07-01 19:43:12,12989.805,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,54,56,8,73,103,1710,2352,65535,65535,704,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,994,SUCCESS
    3242,2021-07-01 19:43:16,12993.808,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,55,56,8,73,103,1710,2352,65535,65535,704,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1016,SUCCESS
    3243,2021-07-01 19:43:20,12997.818,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,54,55,8,73,103,1710,2352,65535,65535,717,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,981,SUCCESS
    3244,2021-07-01 19:43:24,13001.822,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,54,55,8,73,103,1711,2352,65535,65535,716,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1023,SUCCESS
    3245,2021-07-01 19:43:28,13005.833,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,54,55,8,73,103,1711,2352,65535,65535,716,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.4,1035,SUCCESS
    3246,2021-07-01 19:43:32,13009.846,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,53,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,969,SUCCESS
    3247,2021-07-01 19:43:36,13013.848,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,53,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,998,SUCCESS
    3248,2021-07-01 19:43:40,13017.852,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,53,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,962,SUCCESS
    3249,2021-07-01 19:43:44,13021.865,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,53,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,980,SUCCESS
    3250,2021-07-01 19:43:49,13025.867,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,53,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,978,SUCCESS
    3251,2021-07-01 19:43:53,13029.875,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,54,54,8,73,103,1711,2352,65535,65535,728,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1003,SUCCESS
    3252,2021-07-01 19:43:57,13033.879,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,53,53,8,73,103,1711,2352,65535,65535,742,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,999,SUCCESS
    3253,2021-07-01 19:44:01,13037.884,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,53,53,8,73,103,1711,2352,65535,65535,742,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1012,SUCCESS
    3254,2021-07-01 19:44:05,13041.885,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,53,53,8,73,103,1711,2352,65535,65535,742,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1023,SUCCESS
    3255,2021-07-01 19:44:09,13045.891,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,52,53,8,73,103,1711,2352,65535,65535,742,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1097,SUCCESS
    3256,2021-07-01 19:44:13,13049.910,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,52,53,8,73,103,1711,2352,65535,65535,742,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1079,SUCCESS
    3257,2021-07-01 19:44:17,13053.924,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,51,52,8,73,103,1711,2352,65535,65535,755,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1062,SUCCESS
    3258,2021-07-01 19:44:21,13057.938,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,53,52,8,73,103,1711,2352,65535,65535,755,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1017,SUCCESS
    3259,2021-07-01 19:44:25,13061.942,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,51,52,8,73,103,1711,2352,65535,65535,755,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1049,SUCCESS
    3260,2021-07-01 19:44:29,13065.947,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,51,52,8,73,103,1711,2352,65535,65535,755,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,946,SUCCESS
    3261,2021-07-01 19:44:33,13069.961,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,51,52,8,73,103,1712,2352,65535,65535,753,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4206,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,979,SUCCESS
    3262,2021-07-01 19:44:37,13073.976,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,51,51,8,73,103,1712,2352,65535,65535,768,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4199,4199,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,994,SUCCESS
    3263,2021-07-01 19:44:41,13077.991,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,51,51,8,73,103,1712,2352,65535,65535,768,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4199,4199,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.9,1019,SUCCESS
    3264,2021-07-01 19:44:45,13082.005,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,50,51,8,73,103,1712,2352,65535,65535,768,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4200,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1014,SUCCESS
    3265,2021-07-01 19:44:49,13086.009,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,50,51,8,73,103,1712,2352,65535,65535,768,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,992,SUCCESS
    3266,2021-07-01 19:44:53,13090.015,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,49,51,8,73,103,1712,2352,65535,65535,768,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1020,SUCCESS
    3267,2021-07-01 19:44:57,13094.021,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,50,50,8,73,103,1712,2352,65535,65535,782,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4210,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1094,SUCCESS
    3268,2021-07-01 19:45:01,13098.022,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,50,50,8,73,103,1712,2352,65535,65535,782,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4212,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,996,SUCCESS
    3269,2021-07-01 19:45:05,13102.023,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,49,50,8,73,103,1712,2352,65535,65535,782,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4213,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,979,SUCCESS
    3270,2021-07-01 19:45:09,13106.037,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,50,50,8,73,103,1712,2352,65535,65535,782,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,980,SUCCESS
    3271,2021-07-01 19:45:13,13110.038,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,49,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,962,SUCCESS
    3272,2021-07-01 19:45:17,13114.047,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,50,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1005,SUCCESS
    3273,2021-07-01 19:45:21,13118.057,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,48,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,990,SUCCESS
    3274,2021-07-01 19:45:25,13122.060,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,48,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,973,SUCCESS
    3275,2021-07-01 19:45:29,13126.071,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,48,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,964,SUCCESS
    3276,2021-07-01 19:45:33,13130.079,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,48,49,8,73,103,1712,2352,65535,65535,791,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3277,2021-07-01 19:45:37,13134.085,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,47,48,8,73,103,1712,2352,65535,65535,806,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,981,SUCCESS
    3278,2021-07-01 19:45:41,13138.099,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,48,48,8,73,103,1712,2352,65535,65535,806,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1003,SUCCESS
    3279,2021-07-01 19:45:45,13142.104,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,48,48,8,73,103,1713,2352,65535,65535,805,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,993,SUCCESS
    3280,2021-07-01 19:45:49,13146.110,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,47,48,8,73,103,1713,2352,65535,65535,805,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,984,SUCCESS
    3281,2021-07-01 19:45:53,13150.116,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,47,48,8,73,103,1713,2352,65535,65535,805,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,949,SUCCESS
    3282,2021-07-01 19:45:57,13154.125,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,47,48,8,73,103,1713,2352,65535,65535,805,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3283,2021-07-01 19:46:01,13158.127,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,47,48,8,73,103,1713,2352,65535,65535,805,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1015,SUCCESS
    3284,2021-07-01 19:46:05,13162.150,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,47,47,8,73,103,1713,2352,65535,65535,822,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1039,SUCCESS
    3285,2021-07-01 19:46:09,13166.153,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,47,47,8,73,103,1713,2352,65535,65535,822,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,990,SUCCESS
    3286,2021-07-01 19:46:13,13170.167,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,47,47,8,73,103,1713,2352,65535,65535,822,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.6,1013,SUCCESS
    3287,2021-07-01 19:46:17,13174.182,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,46,47,8,73,103,1713,2352,65535,65535,822,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,976,SUCCESS
    3288,2021-07-01 19:46:21,13178.197,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,46,47,8,73,103,1713,2352,65535,65535,822,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,976,SUCCESS
    3289,2021-07-01 19:46:25,13182.202,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,46,46,8,73,103,1713,2352,65535,65535,840,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,970,SUCCESS
    3290,2021-07-01 19:46:29,13186.203,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,46,46,8,73,103,1713,2352,65535,65535,840,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1018,SUCCESS
    3291,2021-07-01 19:46:33,13190.205,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,45,46,8,73,103,1713,2352,65535,65535,840,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1014,SUCCESS
    3292,2021-07-01 19:46:37,13194.214,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,45,46,8,73,103,1713,2352,65535,65535,840,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1021,SUCCESS
    3293,2021-07-01 19:46:41,13198.214,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,46,8,73,103,1713,2352,65535,65535,840,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    3294,2021-07-01 19:46:45,13202.229,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,45,45,8,73,103,1713,2352,65535,65535,859,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,994,SUCCESS
    3295,2021-07-01 19:46:49,13206.238,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,45,8,73,103,1713,2352,65535,65535,859,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3296,2021-07-01 19:46:53,13210.247,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,45,8,73,103,1713,2352,65535,65535,859,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1098,SUCCESS
    3297,2021-07-01 19:46:57,13214.261,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,44,44,8,73,103,1713,2352,65535,65535,877,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1023,SUCCESS
    3298,2021-07-01 19:47:01,13218.276,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,43,44,8,73,103,1713,2352,65535,65535,877,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,993,SUCCESS
    3299,2021-07-01 19:47:05,13222.286,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1012,SUCCESS
    3300,2021-07-01 19:47:09,13226.300,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.6,996,SUCCESS
    3301,2021-07-01 19:47:13,13230.312,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,43,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1001,SUCCESS
    3302,2021-07-01 19:47:17,13234.325,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,44,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,990,SUCCESS
    3303,2021-07-01 19:47:21,13238.330,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,42,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1047,SUCCESS
    3304,2021-07-01 19:47:25,13242.333,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,44,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,997,SUCCESS
    3305,2021-07-01 19:47:29,13246.342,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,43,44,8,73,103,1714,2352,65535,65535,875,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1021,SUCCESS
    3306,2021-07-01 19:47:33,13250.351,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,43,43,8,73,103,1714,2352,65535,65535,896,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1090,SUCCESS
    3307,2021-07-01 19:47:37,13254.358,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,41,43,8,73,103,1714,2352,65535,65535,896,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1051,SUCCESS
    3308,2021-07-01 19:47:41,13258.365,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,41,43,8,73,103,1714,2352,65535,65535,896,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,997,SUCCESS
    3309,2021-07-01 19:47:45,13262.367,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,43,42,8,73,103,1714,2352,65535,65535,917,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1010,SUCCESS
    3310,2021-07-01 19:47:49,13266.378,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,41,42,8,73,103,1714,2352,65535,65535,917,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1033,SUCCESS
    3311,2021-07-01 19:47:53,13270.378,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,41,42,8,73,103,1714,2352,65535,65535,917,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1078,SUCCESS
    3312,2021-07-01 19:47:57,13274.381,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,43,42,8,73,103,1714,2352,65535,65535,917,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,963,SUCCESS
    3313,2021-07-01 19:48:01,13278.389,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,41,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1020,SUCCESS
    3314,2021-07-01 19:48:05,13282.404,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,40,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1003,SUCCESS
    3315,2021-07-01 19:48:09,13286.414,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,41,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,978,SUCCESS
    3316,2021-07-01 19:48:13,13290.417,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,39,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1037,SUCCESS
    3317,2021-07-01 19:48:17,13294.420,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,40,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1038,SUCCESS
    3318,2021-07-01 19:48:21,13298.433,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29413,40,41,8,73,103,1714,2352,65535,65535,940,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1008,SUCCESS
    3319,2021-07-01 19:48:25,13302.443,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29412,39,40,8,73,103,1714,2352,65535,65535,962,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,966,SUCCESS
    3320,2021-07-01 19:48:29,13306.457,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29415,41,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1046,SUCCESS
    3321,2021-07-01 19:48:33,13310.457,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,39,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1060,SUCCESS
    3322,2021-07-01 19:48:37,13314.461,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,40,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,994,SUCCESS
    3323,2021-07-01 19:48:41,13318.474,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,40,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,982,SUCCESS
    3324,2021-07-01 19:48:45,13322.476,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,39,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1041,SUCCESS
    3325,2021-07-01 19:48:49,13326.484,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,40,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,986,SUCCESS
    3326,2021-07-01 19:48:53,13330.493,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,39,40,8,73,103,1715,2352,65535,65535,960,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,977,SUCCESS
    3327,2021-07-01 19:48:57,13334.507,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,39,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1030,SUCCESS
    3328,2021-07-01 19:49:01,13338.514,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,39,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1003,SUCCESS
    3329,2021-07-01 19:49:05,13342.518,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,38,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1000,SUCCESS
    3330,2021-07-01 19:49:09,13346.520,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29414,39,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1029,SUCCESS
    3331,2021-07-01 19:49:13,13350.527,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,38,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,992,SUCCESS
    3332,2021-07-01 19:49:17,13354.534,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,38,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1045,SUCCESS
    3333,2021-07-01 19:49:21,13358.549,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,38,39,8,73,103,1715,2352,65535,65535,985,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4201,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1049,SUCCESS
    3334,2021-07-01 19:49:25,13362.553,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,38,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,981,SUCCESS
    3335,2021-07-01 19:49:29,13366.568,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,38,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,949,SUCCESS
    3336,2021-07-01 19:49:33,13370.580,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,38,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1035,SUCCESS
    3337,2021-07-01 19:49:37,13374.593,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29416,37,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1002,SUCCESS
    3338,2021-07-01 19:49:41,13378.600,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29416,36,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,978,SUCCESS
    3339,2021-07-01 19:49:45,13382.614,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29415,37,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,985,SUCCESS
    3340,2021-07-01 19:49:49,13386.626,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29416,38,38,8,73,103,1715,2352,65535,65535,1011,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    3341,2021-07-01 19:49:53,13390.629,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29416,38,37,8,73,103,1715,2352,65535,65535,1038,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4198,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,997,SUCCESS
    3342,2021-07-01 19:49:57,13394.640,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,36,37,8,73,103,1715,2352,65535,65535,1038,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3343,2021-07-01 19:50:01,13398.647,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,37,37,8,73,103,1716,2352,65535,65535,1036,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4206,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,963,SUCCESS
    3344,2021-07-01 19:50:05,13402.654,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,36,37,8,73,103,1716,2352,65535,65535,1036,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4202,4200,4199,4205,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,976,SUCCESS
    3345,2021-07-01 19:50:09,13406.666,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,37,8,73,103,1716,2352,65535,65535,1036,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4204,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1023,SUCCESS
    3346,2021-07-01 19:50:13,13410.668,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4200,4207,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1037,SUCCESS
    3347,2021-07-01 19:50:17,13414.671,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,36,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1035,SUCCESS
    3348,2021-07-01 19:50:21,13418.671,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,36,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4210,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1019,SUCCESS
    3349,2021-07-01 19:50:25,13422.681,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,975,SUCCESS
    3350,2021-07-01 19:50:29,13426.696,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,962,SUCCESS
    3351,2021-07-01 19:50:33,13430.700,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4201,4200,4199,4210,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,973,SUCCESS
    3352,2021-07-01 19:50:37,13434.713,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,36,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4200,4202,4199,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    3353,2021-07-01 19:50:41,13438.715,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29416,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1053,SUCCESS
    3354,2021-07-01 19:50:45,13442.723,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    3355,2021-07-01 19:50:49,13446.737,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,35,36,8,73,103,1716,2352,65535,65535,1063,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,34.9,1023,SUCCESS
    3356,2021-07-01 19:50:53,13450.748,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,36,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    3357,2021-07-01 19:50:57,13454.757,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29415,36,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1011,SUCCESS
    3358,2021-07-01 19:51:01,13458.771,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1012,SUCCESS
    3359,2021-07-01 19:51:05,13462.782,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1003,SUCCESS
    3360,2021-07-01 19:51:09,13466.797,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,36,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1019,SUCCESS
    3361,2021-07-01 19:51:13,13470.807,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1007,SUCCESS
    3362,2021-07-01 19:51:17,13474.822,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,34,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4198,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1023,SUCCESS
    3363,2021-07-01 19:51:21,13478.829,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1033,SUCCESS
    3364,2021-07-01 19:51:25,13482.841,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.7,1043,SUCCESS
    3365,2021-07-01 19:51:29,13486.842,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1068,SUCCESS
    3366,2021-07-01 19:51:33,13490.848,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1046,SUCCESS
    3367,2021-07-01 19:51:37,13494.861,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,984,SUCCESS
    3368,2021-07-01 19:51:42,13498.867,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,35,35,8,73,103,1716,2352,65535,65535,1094,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4200,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1028,SUCCESS
    3369,2021-07-01 19:51:46,13502.878,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,35,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,999,SUCCESS
    3370,2021-07-01 19:51:50,13506.889,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,34,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,973,SUCCESS
    3371,2021-07-01 19:51:54,13510.892,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,36,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1035,SUCCESS
    3372,2021-07-01 19:51:58,13514.899,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,34,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,946,SUCCESS
    3373,2021-07-01 19:52:02,13518.904,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,35,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.4,1059,SUCCESS
    3374,2021-07-01 19:52:06,13522.915,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,34,35,8,74,103,1717,2352,65535,65535,1092,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,963,SUCCESS
    3375,2021-07-01 19:52:10,13526.924,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,34,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1047,SUCCESS
    3376,2021-07-01 19:52:14,13530.929,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,34,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1029,SUCCESS
    3377,2021-07-01 19:52:18,13534.929,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1027,SUCCESS
    3378,2021-07-01 19:52:22,13538.930,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1027,SUCCESS
    3379,2021-07-01 19:52:26,13542.932,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,959,SUCCESS
    3380,2021-07-01 19:52:30,13546.933,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,33,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,960,SUCCESS
    3381,2021-07-01 19:52:34,13550.946,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,33,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,962,SUCCESS
    3382,2021-07-01 19:52:38,13554.955,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,34,34,8,74,103,1717,2352,65535,65535,1124,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1033,SUCCESS
    3383,2021-07-01 19:52:42,13558.962,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,34,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,992,SUCCESS
    3384,2021-07-01 19:52:46,13562.974,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1013,SUCCESS
    3385,2021-07-01 19:52:50,13566.981,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1005,SUCCESS
    3386,2021-07-01 19:52:54,13570.988,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1013,SUCCESS
    3387,2021-07-01 19:52:58,13575.002,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.9,984,SUCCESS
    3388,2021-07-01 19:53:02,13579.015,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,32,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,972,SUCCESS
    3389,2021-07-01 19:53:06,13583.019,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,982,SUCCESS
    3390,2021-07-01 19:53:10,13587.019,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    3391,2021-07-01 19:53:14,13591.020,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29417,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    3392,2021-07-01 19:53:18,13595.025,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1101,SUCCESS
    3393,2021-07-01 19:53:22,13599.036,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,31,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,965,SUCCESS
    3394,2021-07-01 19:53:26,13603.047,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,33,33,8,74,103,1717,2352,65535,65535,1158,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1002,SUCCESS
    3395,2021-07-01 19:53:30,13607.060,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,33,33,8,74,104,1718,2352,65535,65535,1156,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,973,SUCCESS
    3396,2021-07-01 19:53:34,13611.062,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29416,32,33,8,74,104,1718,2352,65535,65535,1156,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1035,SUCCESS
    3397,2021-07-01 19:53:38,13615.072,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,31,33,8,74,104,1718,2352,65535,65535,1156,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1010,SUCCESS
    3398,2021-07-01 19:53:42,13619.081,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29415,32,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1062,SUCCESS
    3399,2021-07-01 19:53:46,13623.083,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,32,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1014,SUCCESS
    3400,2021-07-01 19:53:50,13627.085,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,31,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,995,SUCCESS
    3401,2021-07-01 19:53:54,13631.098,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29421,33,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1029,SUCCESS
    3402,2021-07-01 19:53:58,13635.110,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29422,32,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1047,SUCCESS
    3403,2021-07-01 19:54:02,13639.118,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29423,31,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1040,SUCCESS
    3404,2021-07-01 19:54:06,13643.126,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,32,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1024,SUCCESS
    3405,2021-07-01 19:54:10,13647.139,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,31,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,987,SUCCESS
    3406,2021-07-01 19:54:14,13651.148,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,31,32,8,74,104,1718,2352,65535,65535,1191,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,979,SUCCESS
    3407,2021-07-01 19:54:18,13655.151,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    3408,2021-07-01 19:54:22,13659.166,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29417,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1039,SUCCESS
    3409,2021-07-01 19:54:26,13663.177,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4201,4202,4201,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,984,SUCCESS
    3410,2021-07-01 19:54:30,13667.192,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.5,1019,SUCCESS
    3411,2021-07-01 19:54:34,13671.203,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    3412,2021-07-01 19:54:38,13675.210,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    3413,2021-07-01 19:54:42,13679.218,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1034,SUCCESS
    3414,2021-07-01 19:54:46,13683.225,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,997,SUCCESS
    3415,2021-07-01 19:54:50,13687.234,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1002,SUCCESS
    3416,2021-07-01 19:54:54,13691.235,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4200,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    3417,2021-07-01 19:54:58,13695.236,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    3418,2021-07-01 19:55:02,13699.248,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,30,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,972,SUCCESS
    3419,2021-07-01 19:55:06,13703.254,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4198,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1013,SUCCESS
    3420,2021-07-01 19:55:10,13707.265,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,32,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1034,SUCCESS
    3421,2021-07-01 19:55:14,13711.265,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3422,2021-07-01 19:55:18,13715.280,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4201,4202,4201,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1047,SUCCESS
    3423,2021-07-01 19:55:22,13719.283,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,31,31,8,74,104,1718,2352,65535,65535,1229,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4205,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,998,SUCCESS
    3424,2021-07-01 19:55:26,13723.285,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,32,31,8,74,104,1719,2352,65535,65535,1227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4204,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1028,SUCCESS
    3425,2021-07-01 19:55:30,13727.291,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,30,31,8,74,104,1719,2352,65535,65535,1227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,994,SUCCESS
    3426,2021-07-01 19:55:34,13731.301,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,31,8,74,104,1719,2352,65535,65535,1227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4210,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1016,SUCCESS
    3427,2021-07-01 19:55:38,13735.310,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,30,31,8,74,104,1719,2352,65535,65535,1227,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4211,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,971,SUCCESS
    3428,2021-07-01 19:55:42,13739.310,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,31,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4211,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1034,SUCCESS
    3429,2021-07-01 19:55:46,13743.322,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4214,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,960,SUCCESS
    3430,2021-07-01 19:55:50,13747.324,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4198,4213,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1038,SUCCESS
    3431,2021-07-01 19:55:54,13751.325,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1034,SUCCESS
    3432,2021-07-01 19:55:58,13755.340,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1005,SUCCESS
    3433,2021-07-01 19:56:02,13759.351,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.1,955,SUCCESS
    3434,2021-07-01 19:56:06,13763.360,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1064,SUCCESS
    3435,2021-07-01 19:56:10,13767.370,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,31,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4208,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1036,SUCCESS
    3436,2021-07-01 19:56:14,13771.382,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,968,SUCCESS
    3437,2021-07-01 19:56:18,13775.389,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3438,2021-07-01 19:56:22,13779.394,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,966,SUCCESS
    3439,2021-07-01 19:56:26,13783.398,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,994,SUCCESS
    3440,2021-07-01 19:56:30,13787.399,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4199,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    3441,2021-07-01 19:56:34,13791.405,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1038,SUCCESS
    3442,2021-07-01 19:56:38,13795.411,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.4,1006,SUCCESS
    3443,2021-07-01 19:56:42,13799.422,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1019,SUCCESS
    3444,2021-07-01 19:56:46,13803.428,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,30,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1026,SUCCESS
    3445,2021-07-01 19:56:50,13807.437,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1026,SUCCESS
    3446,2021-07-01 19:56:54,13811.441,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,29,30,8,74,104,1719,2352,65535,65535,1268,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1062,SUCCESS
    3447,2021-07-01 19:56:58,13815.450,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,29,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4200,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1051,SUCCESS
    3448,2021-07-01 19:57:02,13819.454,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3449,2021-07-01 19:57:06,13823.465,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,988,SUCCESS
    3450,2021-07-01 19:57:10,13827.473,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,28,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,986,SUCCESS
    3451,2021-07-01 19:57:14,13831.478,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,30,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1006,SUCCESS
    3452,2021-07-01 19:57:18,13835.488,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4210,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1043,SUCCESS
    3453,2021-07-01 19:57:22,13839.498,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,29,8,74,104,1719,2352,65535,65535,1312,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,990,SUCCESS
    3454,2021-07-01 19:57:26,13843.512,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,29,29,8,74,104,1720,2352,65535,65535,1310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1036,SUCCESS
    3455,2021-07-01 19:57:30,13847.522,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,29,8,74,104,1720,2352,65535,65535,1310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,965,SUCCESS
    3456,2021-07-01 19:57:34,13851.535,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,29,8,74,104,1720,2352,65535,65535,1310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3457,2021-07-01 19:57:38,13855.550,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,29,8,74,104,1720,2352,65535,65535,1310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1033,SUCCESS
    3458,2021-07-01 19:57:42,13859.560,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,29,8,74,104,1720,2352,65535,65535,1310,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1004,SUCCESS
    3459,2021-07-01 19:57:46,13863.563,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1064,SUCCESS
    3460,2021-07-01 19:57:50,13867.571,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,977,SUCCESS
    3461,2021-07-01 19:57:54,13871.578,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,29,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4200,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    3462,2021-07-01 19:57:58,13875.578,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1079,SUCCESS
    3463,2021-07-01 19:58:02,13879.589,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,991,SUCCESS
    3464,2021-07-01 19:58:06,13883.591,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1005,SUCCESS
    3465,2021-07-01 19:58:10,13887.594,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,29,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1034,SUCCESS
    3466,2021-07-01 19:58:14,13891.602,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,992,SUCCESS
    3467,2021-07-01 19:58:18,13895.603,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1040,SUCCESS
    3468,2021-07-01 19:58:22,13899.610,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,27,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3469,2021-07-01 19:58:26,13903.617,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,27,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1025,SUCCESS
    3470,2021-07-01 19:58:30,13907.631,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,997,SUCCESS
    3471,2021-07-01 19:58:34,13911.645,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1013,SUCCESS
    3472,2021-07-01 19:58:38,13915.655,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,28,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1002,SUCCESS
    3473,2021-07-01 19:58:42,13919.656,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,27,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    3474,2021-07-01 19:58:46,13923.660,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,27,28,8,74,104,1720,2352,65535,65535,1354,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1046,SUCCESS
    3475,2021-07-01 19:58:50,13927.661,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29418,26,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    3476,2021-07-01 19:58:54,13931.669,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29419,29,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    3477,2021-07-01 19:58:58,13935.671,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,27,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3478,2021-07-01 19:59:02,13939.679,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29418,28,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1057,SUCCESS
    3479,2021-07-01 19:59:06,13943.689,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29421,27,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1048,SUCCESS
    3480,2021-07-01 19:59:10,13947.704,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29421,25,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1000,SUCCESS
    3481,2021-07-01 19:59:14,13951.715,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29422,27,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,959,SUCCESS
    3482,2021-07-01 19:59:18,13955.722,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29424,27,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1019,SUCCESS
    3483,2021-07-01 19:59:22,13959.737,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29423,28,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1079,SUCCESS
    3484,2021-07-01 19:59:26,13963.737,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,28,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    3485,2021-07-01 19:59:30,13967.749,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,27,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1002,SUCCESS
    3486,2021-07-01 19:59:34,13971.763,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,27,8,74,104,1720,2352,65535,65535,1404,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1004,SUCCESS
    3487,2021-07-01 19:59:38,13975.778,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,27,8,74,104,1721,2352,65535,65535,1402,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,973,SUCCESS
    3488,2021-07-01 19:59:42,13979.788,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,25,27,8,74,104,1721,2352,65535,65535,1402,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    3489,2021-07-01 19:59:46,13983.801,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1028,SUCCESS
    3490,2021-07-01 19:59:50,13987.809,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,973,SUCCESS
    3491,2021-07-01 19:59:54,13991.818,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,985,SUCCESS
    3492,2021-07-01 19:59:58,13995.820,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1074,SUCCESS
    3493,2021-07-01 20:00:02,13999.821,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,24,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,978,SUCCESS
    3494,2021-07-01 20:00:06,14003.834,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,995,SUCCESS
    3495,2021-07-01 20:00:10,14007.849,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,24,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1042,SUCCESS
    3496,2021-07-01 20:00:14,14011.859,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,972,SUCCESS
    3497,2021-07-01 20:00:19,14015.870,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    3498,2021-07-01 20:00:23,14019.883,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1010,SUCCESS
    3499,2021-07-01 20:00:27,14023.884,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,25,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4198,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    3500,2021-07-01 20:00:31,14027.886,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    3501,2021-07-01 20:00:35,14031.890,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,24,26,8,74,104,1721,2352,65535,65535,1456,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    3502,2021-07-01 20:00:39,14035.892,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,25,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4207,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1002,SUCCESS
    3503,2021-07-01 20:00:43,14039.907,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1001,SUCCESS
    3504,2021-07-01 20:00:47,14043.914,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4200,4208,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1025,SUCCESS
    3505,2021-07-01 20:00:51,14047.916,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,960,SUCCESS
    3506,2021-07-01 20:00:55,14051.918,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4211,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.1,996,SUCCESS
    3507,2021-07-01 20:00:59,14055.929,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4212,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1056,SUCCESS
    3508,2021-07-01 20:01:03,14059.942,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4214,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1029,SUCCESS
    3509,2021-07-01 20:01:07,14063.944,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4211,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1025,SUCCESS
    3510,2021-07-01 20:01:11,14067.946,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,26,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,978,SUCCESS
    3511,2021-07-01 20:01:15,14071.960,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1057,SUCCESS
    3512,2021-07-01 20:01:19,14075.971,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1062,SUCCESS
    3513,2021-07-01 20:01:23,14079.976,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,962,SUCCESS
    3514,2021-07-01 20:01:27,14083.980,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,991,SUCCESS
    3515,2021-07-01 20:01:31,14087.990,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,34.6,987,SUCCESS
    3516,2021-07-01 20:01:35,14091.991,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,995,SUCCESS
    3517,2021-07-01 20:01:39,14095.995,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1038,SUCCESS
    3518,2021-07-01 20:01:43,14100.000,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29419,26,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4207,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3519,2021-07-01 20:01:47,14104.014,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,25,8,74,104,1721,2352,65535,65535,1514,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,1036,SUCCESS
    3520,2021-07-01 20:01:51,14108.025,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,25,24,8,74,104,1721,2352,65535,65535,1578,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    3521,2021-07-01 20:01:55,14112.033,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,25,24,8,74,104,1721,2352,65535,65535,1578,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1032,SUCCESS
    3522,2021-07-01 20:01:59,14116.047,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,24,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    3523,2021-07-01 20:02:03,14120.060,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.3,959,SUCCESS
    3524,2021-07-01 20:02:07,14124.065,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,26,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,34.9,1113,SUCCESS
    3525,2021-07-01 20:02:11,14128.075,0x0701,150,10,0x6001,0,65535,65535,1,26.3,29420,24,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.3,-273.2,26.3,-273.2,35.3,1006,SUCCESS
    3526,2021-07-01 20:02:15,14132.083,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,25,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x02,0x410,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1078,SUCCESS
    3527,2021-07-01 20:02:19,14136.095,0x0701,150,10,0x6001,0,65535,65535,1,26.4,29420,24,24,8,74,104,1722,2352,65535,65535,1575,1000,28875,0x0080,4103,2552,100,0x0107,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4200,4201,4202,4201,4199,4209,4208,0,0,0,0,0,0,0,0,3250,26.3,26.4,-273.2,26.4,-273.2,35.2,1047,SUCCESS
    3528,2021-07-01 20:02:23,14140.099,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29403,0,20,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4199,4200,4198,4196,4207,4205,0,0,0,0,0,0,0,0,3246,26.3,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3529,2021-07-01 20:02:27,14144.107,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29402,0,15,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4199,4200,4198,4196,4207,4205,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    3530,2021-07-01 20:02:31,14148.110,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29402,0,12,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4197,4198,4199,4198,4196,4207,4205,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1031,SUCCESS
    3531,2021-07-01 20:02:35,14152.114,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29397,0,9,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4198,4196,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1077,SUCCESS
    3532,2021-07-01 20:02:39,14156.123,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29396,0,7,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4196,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,987,SUCCESS
    3533,2021-07-01 20:02:43,14160.132,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29396,0,5,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4196,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.6,991,SUCCESS
    3534,2021-07-01 20:02:47,14164.141,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29396,0,4,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4196,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1015,SUCCESS
    3535,2021-07-01 20:02:51,14168.155,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29396,0,3,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4196,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    3536,2021-07-01 20:02:55,14172.169,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29396,0,2,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4195,4206,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1050,SUCCESS
    3537,2021-07-01 20:02:59,14176.184,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29393,0,2,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4197,4198,4197,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1035,SUCCESS
    3538,2021-07-01 20:03:03,14180.200,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29393,0,1,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4198,4199,4197,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1080,SUCCESS
    3539,2021-07-01 20:03:07,14184.214,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29392,0,1,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4196,4197,4199,4197,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1037,SUCCESS
    3540,2021-07-01 20:03:11,14188.228,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29392,0,1,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4197,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1039,SUCCESS
    3541,2021-07-01 20:03:15,14192.238,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29390,0,1,8,100,142,2352,2352,65535,65535,0,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4196,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1044,SUCCESS
    3542,2021-07-01 20:03:19,14196.252,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29391,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4197,4195,4205,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.1,1053,SUCCESS
    3543,2021-07-01 20:03:23,14200.267,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29391,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4196,4195,4205,4204,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1034,SUCCESS
    3544,2021-07-01 20:03:27,14204.282,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29389,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4196,4195,4205,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1034,SUCCESS
    3545,2021-07-01 20:03:31,14208.290,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29389,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4196,4195,4205,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1008,SUCCESS
    3546,2021-07-01 20:03:35,14212.298,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29389,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4197,4198,4196,4195,4205,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    3547,2021-07-01 20:03:39,14216.303,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29387,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4195,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3548,2021-07-01 20:03:43,14220.313,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29387,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4195,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    3549,2021-07-01 20:03:47,14224.323,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29387,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4195,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1023,SUCCESS
    3550,2021-07-01 20:03:51,14228.339,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29387,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4194,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,976,SUCCESS
    3551,2021-07-01 20:03:55,14232.349,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29385,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4195,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.5,1035,SUCCESS
    3552,2021-07-01 20:03:59,14236.361,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29387,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4195,4204,4203,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1032,SUCCESS
    3553,2021-07-01 20:04:03,14240.360,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29384,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1000,SUCCESS
    3554,2021-07-01 20:04:07,14244.374,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29383,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4198,4196,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1051,SUCCESS
    3555,2021-07-01 20:04:11,14248.378,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29380,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4197,4196,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1081,SUCCESS
    3556,2021-07-01 20:04:15,14252.390,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29381,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4197,4196,4194,4205,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1014,SUCCESS
    3557,2021-07-01 20:04:19,14256.400,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29382,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40A0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x41A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4195,4196,4197,4196,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1026,SUCCESS
    3558,2021-07-01 20:04:23,14260.413,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29383,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,995,SUCCESS
    3559,2021-07-01 20:04:27,14264.427,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29383,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1042,SUCCESS
    3560,2021-07-01 20:04:31,14268.428,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29384,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,34.9,971,SUCCESS
    3561,2021-07-01 20:04:35,14272.433,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29386,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,945,SUCCESS
    3562,2021-07-01 20:04:39,14276.436,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29386,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4195,4197,4195,4193,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    3563,2021-07-01 20:04:43,14280.436,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29381,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1066,SUCCESS
    3564,2021-07-01 20:04:47,14284.440,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29381,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4196,4197,4195,4194,4204,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,968,SUCCESS
    3565,2021-07-01 20:04:51,14288.450,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29379,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4195,4196,4195,4193,4203,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1037,SUCCESS
    3566,2021-07-01 20:04:55,14292.453,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29378,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4195,4196,4195,4193,4203,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1047,SUCCESS
    3567,2021-07-01 20:04:59,14296.458,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29378,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4195,4193,4203,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    3568,2021-07-01 20:05:03,14300.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29376,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4194,4195,4196,4194,4193,4203,4202,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1082,SUCCESS
    3569,2021-07-01 20:05:07,14304.469,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29377,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    3570,2021-07-01 20:05:11,14308.479,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29377,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4202,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1007,SUCCESS
    3571,2021-07-01 20:05:15,14312.491,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29375,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1060,SUCCESS
    3572,2021-07-01 20:05:19,14316.496,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29374,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1084,SUCCESS
    3573,2021-07-01 20:05:23,14320.512,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29375,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1008,SUCCESS
    3574,2021-07-01 20:05:27,14324.522,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29375,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1026,SUCCESS
    3575,2021-07-01 20:05:31,14328.535,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29375,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1200,SUCCESS
    3576,2021-07-01 20:05:35,14332.548,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29373,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1078,SUCCESS
    3577,2021-07-01 20:05:39,14336.555,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29375,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1025,SUCCESS
    3578,2021-07-01 20:05:43,14340.561,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29374,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4203,4200,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,955,SUCCESS
    3579,2021-07-01 20:05:47,14344.572,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29374,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4193,4202,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,993,SUCCESS
    3580,2021-07-01 20:05:51,14348.574,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29374,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4194,4192,4202,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1023,SUCCESS
    3581,2021-07-01 20:05:55,14352.588,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29372,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4194,4196,4194,4193,4202,4201,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1007,SUCCESS
    3582,2021-07-01 20:05:59,14356.595,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29373,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4195,4196,4193,4193,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.1,1088,SUCCESS
    3583,2021-07-01 20:06:03,14360.608,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29373,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4194,4196,4194,4193,4200,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3584,2021-07-01 20:06:07,14364.615,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29370,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4194,4195,4194,4192,4202,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    3585,2021-07-01 20:06:11,14368.627,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29371,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4194,4195,4194,4192,4202,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    3586,2021-07-01 20:06:15,14372.637,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29370,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4193,4203,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    3587,2021-07-01 20:06:19,14376.652,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29369,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4194,4192,4202,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    3588,2021-07-01 20:06:23,14380.666,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29370,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4193,4194,4195,4193,4192,4203,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,977,SUCCESS
    3589,2021-07-01 20:06:27,14384.670,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29370,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4204,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,972,SUCCESS
    3590,2021-07-01 20:06:31,14388.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29369,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4204,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    3591,2021-07-01 20:06:35,14392.695,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29368,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4204,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1120,SUCCESS
    3592,2021-07-01 20:06:39,14396.710,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29368,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4202,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.8,1046,SUCCESS
    3593,2021-07-01 20:06:43,14400.722,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29368,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4207,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    3594,2021-07-01 20:06:47,14404.734,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29368,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4195,4193,4192,4202,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    3595,2021-07-01 20:06:51,14408.743,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29367,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    3596,2021-07-01 20:06:55,14412.752,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29367,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4195,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1000,SUCCESS
    3597,2021-07-01 20:06:59,14416.767,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29367,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4194,4194,4193,4192,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    3598,2021-07-01 20:07:03,14420.782,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29367,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4195,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1078,SUCCESS
    3599,2021-07-01 20:07:07,14424.795,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29366,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1034,SUCCESS
    3600,2021-07-01 20:07:11,14428.799,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29365,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    3601,2021-07-01 20:07:15,14432.807,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29365,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,34.7,998,SUCCESS
    3602,2021-07-01 20:07:19,14436.822,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4200,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    3603,2021-07-01 20:07:23,14440.827,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29364,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    3604,2021-07-01 20:07:27,14444.842,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29364,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,972,SUCCESS
    3605,2021-07-01 20:07:31,14448.852,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1041,SUCCESS
    3606,2021-07-01 20:07:36,14452.868,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29364,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4192,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1038,SUCCESS
    3607,2021-07-01 20:07:40,14456.868,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    3608,2021-07-01 20:07:44,14460.879,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1044,SUCCESS
    3609,2021-07-01 20:07:48,14464.892,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1048,SUCCESS
    3610,2021-07-01 20:07:52,14468.940,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1064,SUCCESS
    3611,2021-07-01 20:07:56,14472.909,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29361,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4192,4193,4194,4193,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.3,1045,SUCCESS
    3612,2021-07-01 20:08:00,14476.916,0x0541,150,10,0x6001,0,65535,65535,1,26.4,29360,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4191,4201,4199,0,0,0,0,0,0,0,0,3245,26.3,26.4,-273.2,26.4,-273.2,35.2,1024,SUCCESS
    3613,2021-07-01 20:08:04,14480.921,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29361,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4193,4191,4200,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1112,SUCCESS
    3614,2021-07-01 20:08:08,14484.934,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29363,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4191,4200,4198,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1037,SUCCESS
    3615,2021-07-01 20:08:12,14488.942,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29362,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4191,4201,4198,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1014,SUCCESS
    3616,2021-07-01 20:08:16,14492.953,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29361,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3241,26.3,26.3,-273.2,26.3,-273.2,35.3,1033,SUCCESS
    3617,2021-07-01 20:08:20,14496.966,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29360,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4191,4200,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    3618,2021-07-01 20:08:24,14500.981,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29360,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    3619,2021-07-01 20:08:28,14504.982,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29359,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4193,4194,4192,4190,4200,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.3,1035,SUCCESS
    3620,2021-07-01 20:08:32,14508.995,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29357,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4193,4192,4190,4200,4199,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    3621,2021-07-01 20:08:36,14513.004,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29357,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4194,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3245,26.3,26.3,-273.2,26.3,-273.2,35.2,998,SUCCESS
    3622,2021-07-01 20:08:40,14517.012,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29356,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4194,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3241,26.3,26.3,-273.2,26.3,-273.2,35.2,1069,SUCCESS
    3623,2021-07-01 20:08:44,14521.015,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29356,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4193,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3241,26.3,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    3624,2021-07-01 20:08:48,14525.025,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29356,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4193,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3241,26.3,26.3,-273.2,26.3,-273.2,34.6,985,SUCCESS
    3625,2021-07-01 20:08:52,14529.034,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29356,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4193,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1047,SUCCESS
    3626,2021-07-01 20:08:56,14533.038,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29356,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4191,4192,4193,4192,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.1,1001,SUCCESS
    3627,2021-07-01 20:09:00,14537.039,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4192,4190,4199,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    3628,2021-07-01 20:09:04,14541.047,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29355,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4192,4190,4200,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1050,SUCCESS
    3629,2021-07-01 20:09:08,14545.061,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29355,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1005,SUCCESS
    3630,2021-07-01 20:09:12,14549.076,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29355,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    3631,2021-07-01 20:09:16,14553.081,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4192,4190,4200,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    3632,2021-07-01 20:09:20,14557.082,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    3633,2021-07-01 20:09:24,14561.082,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1093,SUCCESS
    3634,2021-07-01 20:09:28,14565.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29353,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1057,SUCCESS
    3635,2021-07-01 20:09:32,14569.098,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    3636,2021-07-01 20:09:36,14573.101,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29354,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4200,4198,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1055,SUCCESS
    3637,2021-07-01 20:09:40,14577.114,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29352,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4199,4198,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    3638,2021-07-01 20:09:44,14581.115,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29352,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,34.5,1064,SUCCESS
    3639,2021-07-01 20:09:48,14585.127,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29352,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4192,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,998,SUCCESS
    3640,2021-07-01 20:09:52,14589.128,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29350,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1123,SUCCESS
    3641,2021-07-01 20:09:56,14593.134,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29350,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    3642,2021-07-01 20:10:00,14597.146,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29349,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1058,SUCCESS
    3643,2021-07-01 20:10:04,14601.149,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29347,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    3644,2021-07-01 20:10:08,14605.151,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29351,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    3645,2021-07-01 20:10:12,14609.155,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29350,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4190,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    3646,2021-07-01 20:10:16,14613.158,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29351,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3647,2021-07-01 20:10:20,14617.162,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29352,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4193,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1028,SUCCESS
    3648,2021-07-01 20:10:24,14621.168,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29349,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1084,SUCCESS
    3649,2021-07-01 20:10:28,14625.181,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29349,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    3650,2021-07-01 20:10:32,14629.194,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29349,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1028,SUCCESS
    3651,2021-07-01 20:10:36,14633.194,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29348,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4200,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    3652,2021-07-01 20:10:40,14637.206,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29347,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,34.9,1050,SUCCESS
    3653,2021-07-01 20:10:44,14641.206,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29348,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4190,4191,4192,4191,4189,4199,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    3654,2021-07-01 20:10:48,14645.210,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29347,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4191,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    3655,2021-07-01 20:10:52,14649.210,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29347,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4191,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1075,SUCCESS
    3656,2021-07-01 20:10:56,14653.219,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29346,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    3657,2021-07-01 20:11:00,14657.221,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29346,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1128,SUCCESS
    3658,2021-07-01 20:11:04,14661.236,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29345,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1062,SUCCESS
    3659,2021-07-01 20:11:08,14665.246,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29345,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1008,SUCCESS
    3660,2021-07-01 20:11:12,14669.258,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29345,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1027,SUCCESS
    3661,2021-07-01 20:11:16,14673.262,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29346,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4191,4192,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    3662,2021-07-01 20:11:20,14677.271,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29345,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    3663,2021-07-01 20:11:24,14681.286,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    3664,2021-07-01 20:11:28,14685.301,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1141,SUCCESS
    3665,2021-07-01 20:11:32,14689.304,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3666,2021-07-01 20:11:36,14693.306,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,34.8,1013,SUCCESS
    3667,2021-07-01 20:11:40,14697.316,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    3668,2021-07-01 20:11:44,14701.322,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    3669,2021-07-01 20:11:48,14705.323,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29342,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    3670,2021-07-01 20:11:52,14709.337,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4198,4197,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1071,SUCCESS
    3671,2021-07-01 20:11:56,14713.346,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4189,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1095,SUCCESS
    3672,2021-07-01 20:12:00,14717.351,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29343,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4198,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1044,SUCCESS
    3673,2021-07-01 20:12:04,14721.363,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29341,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    3674,2021-07-01 20:12:08,14725.375,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29342,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    3675,2021-07-01 20:12:12,14729.375,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29342,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1110,SUCCESS
    3676,2021-07-01 20:12:16,14733.382,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29341,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4198,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,948,SUCCESS
    3677,2021-07-01 20:12:20,14737.390,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29341,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4198,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1033,SUCCESS
    3678,2021-07-01 20:12:24,14741.392,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29340,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4190,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1060,SUCCESS
    3679,2021-07-01 20:12:28,14745.400,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29339,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1041,SUCCESS
    3680,2021-07-01 20:12:32,14749.401,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29341,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,34.6,966,SUCCESS
    3681,2021-07-01 20:12:36,14753.406,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29339,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1081,SUCCESS
    3682,2021-07-01 20:12:40,14757.418,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29341,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4189,4190,4191,4190,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    3683,2021-07-01 20:12:44,14761.422,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29339,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1036,SUCCESS
    3684,2021-07-01 20:12:48,14765.436,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29339,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1081,SUCCESS
    3685,2021-07-01 20:12:52,14769.449,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29337,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4187,4197,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    3686,2021-07-01 20:12:56,14773.450,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29337,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4188,4197,4196,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,991,SUCCESS
    3687,2021-07-01 20:13:00,14777.465,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29336,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4191,4189,4188,4197,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1022,SUCCESS
    3688,2021-07-01 20:13:04,14781.478,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29337,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4190,4189,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,992,SUCCESS
    3689,2021-07-01 20:13:08,14785.483,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29338,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4190,4189,4188,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3690,2021-07-01 20:13:12,14789.488,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29338,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4190,4191,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    3691,2021-07-01 20:13:16,14793.491,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4190,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    3692,2021-07-01 20:13:20,14797.500,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4190,4189,4188,4197,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3693,2021-07-01 20:13:24,14801.512,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4190,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    3694,2021-07-01 20:13:28,14805.517,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4190,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    3695,2021-07-01 20:13:32,14809.522,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29334,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4188,4189,4190,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    3696,2021-07-01 20:13:36,14813.535,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4189,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    3697,2021-07-01 20:13:40,14817.537,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29333,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    3698,2021-07-01 20:13:44,14821.547,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29332,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.0,1071,SUCCESS
    3699,2021-07-01 20:13:48,14825.550,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29332,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    3700,2021-07-01 20:13:52,14829.557,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1037,SUCCESS
    3701,2021-07-01 20:13:56,14833.565,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1107,SUCCESS
    3702,2021-07-01 20:14:00,14837.566,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29332,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    3703,2021-07-01 20:14:04,14841.579,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.1,1046,SUCCESS
    3704,2021-07-01 20:14:08,14845.594,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4195,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3705,2021-07-01 20:14:12,14849.596,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4197,4195,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1108,SUCCESS
    3706,2021-07-01 20:14:16,14853.599,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4197,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,967,SUCCESS
    3707,2021-07-01 20:14:20,14857.603,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4189,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1071,SUCCESS
    3708,2021-07-01 20:14:24,14861.613,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1062,SUCCESS
    3709,2021-07-01 20:14:28,14865.617,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    3710,2021-07-01 20:14:32,14869.629,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29331,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    3711,2021-07-01 20:14:36,14873.642,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29335,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    3712,2021-07-01 20:14:40,14877.646,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,997,SUCCESS
    3713,2021-07-01 20:14:44,14881.659,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29329,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    3714,2021-07-01 20:14:48,14885.663,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,947,SUCCESS
    3715,2021-07-01 20:14:52,14889.670,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29330,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1034,SUCCESS
    3716,2021-07-01 20:14:56,14893.677,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29329,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4190,4188,4187,4195,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1112,SUCCESS
    3717,2021-07-01 20:15:00,14897.691,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29328,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4187,4195,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1061,SUCCESS
    3718,2021-07-01 20:15:04,14901.691,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29329,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4187,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    3719,2021-07-01 20:15:08,14905.693,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29327,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4186,4196,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.3,1029,SUCCESS
    3720,2021-07-01 20:15:12,14909.693,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29327,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    3721,2021-07-01 20:15:16,14913.699,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29328,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.3,26.3,-273.2,26.3,-273.2,34.3,998,SUCCESS
    3722,2021-07-01 20:15:20,14917.708,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29326,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    3723,2021-07-01 20:15:24,14921.722,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29327,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4187,4188,4189,4188,4186,4196,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    3724,2021-07-01 20:15:28,14925.722,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29326,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4188,4189,4188,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1170,SUCCESS
    3725,2021-07-01 20:15:32,14929.737,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29325,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4188,4189,4187,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1032,SUCCESS
    3726,2021-07-01 20:15:36,14933.752,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29325,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    3727,2021-07-01 20:15:40,14937.752,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29323,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4189,4187,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1108,SUCCESS
    3728,2021-07-01 20:15:44,14941.762,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29323,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4189,4187,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,974,SUCCESS
    3729,2021-07-01 20:15:48,14945.777,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29325,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4189,4187,4186,4195,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1039,SUCCESS
    3730,2021-07-01 20:15:52,14949.777,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29325,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4188,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.0,1053,SUCCESS
    3731,2021-07-01 20:15:56,14953.783,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29325,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4188,4188,4187,4186,4194,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    3732,2021-07-01 20:16:00,14957.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29323,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4189,4187,4186,4194,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    3733,2021-07-01 20:16:04,14961.800,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29323,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4194,4194,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1096,SUCCESS
    3734,2021-07-01 20:16:08,14965.802,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    3735,2021-07-01 20:16:12,14969.809,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3736,2021-07-01 20:16:16,14973.820,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,980,SUCCESS
    3737,2021-07-01 20:16:20,14977.834,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4196,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    3738,2021-07-01 20:16:24,14981.845,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4196,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1030,SUCCESS
    3739,2021-07-01 20:16:28,14985.849,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4199,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    3740,2021-07-01 20:16:32,14989.853,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    3741,2021-07-01 20:16:36,14993.862,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,984,SUCCESS
    3742,2021-07-01 20:16:41,14997.873,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    3743,2021-07-01 20:16:45,15001.873,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    3744,2021-07-01 20:16:49,15005.880,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29321,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,34.8,1006,SUCCESS
    3745,2021-07-01 20:16:53,15009.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29321,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1066,SUCCESS
    3746,2021-07-01 20:16:57,15013.910,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29322,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    3747,2021-07-01 20:17:01,15017.924,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29320,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    3748,2021-07-01 20:17:05,15021.936,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29320,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4187,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    3749,2021-07-01 20:17:09,15025.947,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29321,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4186,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1038,SUCCESS
    3750,2021-07-01 20:17:13,15029.950,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29321,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1099,SUCCESS
    3751,2021-07-01 20:17:17,15033.956,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29321,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4185,4195,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    3752,2021-07-01 20:17:21,15037.959,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4186,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1012,SUCCESS
    3753,2021-07-01 20:17:25,15041.968,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4195,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,34.6,1025,SUCCESS
    3754,2021-07-01 20:17:29,15045.982,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29319,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.1,1069,SUCCESS
    3755,2021-07-01 20:17:33,15049.996,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    3756,2021-07-01 20:17:37,15054.008,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    3757,2021-07-01 20:17:41,15058.019,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    3758,2021-07-01 20:17:45,15062.022,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,996,SUCCESS
    3759,2021-07-01 20:17:49,15066.023,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4187,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1058,SUCCESS
    3760,2021-07-01 20:17:53,15070.032,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29317,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4185,4194,4193,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1111,SUCCESS
    3761,2021-07-01 20:17:57,15074.034,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29318,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4188,4186,4185,4195,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1108,SUCCESS
    3762,2021-07-01 20:18:01,15078.039,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29316,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4187,4186,4185,4194,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    3763,2021-07-01 20:18:05,15082.050,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29316,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4187,4187,4186,4185,4194,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    3764,2021-07-01 20:18:09,15086.050,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29315,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4185,4194,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3765,2021-07-01 20:18:13,15090.057,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29315,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4185,4194,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    3766,2021-07-01 20:18:17,15094.061,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29315,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4185,4194,4192,0,0,0,0,0,0,0,0,3239,26.2,26.3,-273.2,26.3,-273.2,35.3,957,SUCCESS
    3767,2021-07-01 20:18:21,15098.064,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29315,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4184,4194,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    3768,2021-07-01 20:18:25,15102.077,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29314,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4184,4194,4191,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    3769,2021-07-01 20:18:29,15106.090,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29314,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,994,SUCCESS
    3770,2021-07-01 20:18:33,15110.102,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29314,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4185,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    3771,2021-07-01 20:18:37,15114.114,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29313,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1012,SUCCESS
    3772,2021-07-01 20:18:41,15118.128,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29313,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4185,4186,4187,4186,4185,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    3773,2021-07-01 20:18:45,15122.136,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29313,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3236,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    3774,2021-07-01 20:18:49,15126.144,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29312,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.3,1078,SUCCESS
    3775,2021-07-01 20:18:53,15130.155,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29312,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4185,4184,4193,4192,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,956,SUCCESS
    3776,2021-07-01 20:18:57,15134.156,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29311,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4191,0,0,0,0,0,0,0,0,3236,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    3777,2021-07-01 20:19:01,15138.167,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3239,26.2,26.3,-273.2,26.3,-273.2,35.3,1054,SUCCESS
    3778,2021-07-01 20:19:05,15142.175,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29312,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3240,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3779,2021-07-01 20:19:09,15146.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4186,4184,4193,4192,0,0,0,0,0,0,0,0,3239,26.2,26.3,-273.2,26.3,-273.2,35.2,1113,SUCCESS
    3780,2021-07-01 20:19:13,15150.194,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4186,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1016,SUCCESS
    3781,2021-07-01 20:19:17,15154.196,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4192,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1007,SUCCESS
    3782,2021-07-01 20:19:21,15158.206,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3783,2021-07-01 20:19:25,15162.206,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1187,SUCCESS
    3784,2021-07-01 20:19:29,15166.218,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    3785,2021-07-01 20:19:33,15170.233,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1082,SUCCESS
    3786,2021-07-01 20:19:37,15174.240,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29308,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1028,SUCCESS
    3787,2021-07-01 20:19:41,15178.253,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29305,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3788,2021-07-01 20:19:45,15182.261,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1039,SUCCESS
    3789,2021-07-01 20:19:49,15186.268,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3790,2021-07-01 20:19:53,15190.270,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29309,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    3791,2021-07-01 20:19:57,15194.282,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3792,2021-07-01 20:20:01,15198.283,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29310,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    3793,2021-07-01 20:20:05,15202.288,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29313,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4187,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3794,2021-07-01 20:20:09,15206.297,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29308,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.4,977,SUCCESS
    3795,2021-07-01 20:20:13,15210.304,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3796,2021-07-01 20:20:17,15214.318,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29308,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1027,SUCCESS
    3797,2021-07-01 20:20:21,15218.332,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1012,SUCCESS
    3798,2021-07-01 20:20:25,15222.345,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    3799,2021-07-01 20:20:29,15226.347,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1060,SUCCESS
    3800,2021-07-01 20:20:33,15230.357,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4184,4193,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    3801,2021-07-01 20:20:37,15234.373,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29306,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4186,4185,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3802,2021-07-01 20:20:41,15238.385,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29306,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4186,4185,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1054,SUCCESS
    3803,2021-07-01 20:20:45,15242.394,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29307,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4184,4185,4186,4185,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.6,1022,SUCCESS
    3804,2021-07-01 20:20:49,15246.397,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29306,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4185,4184,4184,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,996,SUCCESS
    3805,2021-07-01 20:20:53,15250.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29306,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4186,4185,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    3806,2021-07-01 20:20:57,15254.413,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29305,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4186,4185,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1029,SUCCESS
    3807,2021-07-01 20:21:01,15258.420,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29304,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4185,4186,4184,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    3808,2021-07-01 20:21:05,15262.431,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29304,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4186,4184,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1012,SUCCESS
    3809,2021-07-01 20:21:09,15266.435,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29304,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    3810,2021-07-01 20:21:13,15270.440,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29302,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4186,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    3811,2021-07-01 20:21:17,15274.446,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29303,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4186,4184,4183,4190,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    3812,2021-07-01 20:21:21,15278.454,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29303,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4186,4184,4183,4191,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    3813,2021-07-01 20:21:25,15282.460,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4191,4191,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    3814,2021-07-01 20:21:29,15286.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4188,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,972,SUCCESS
    3815,2021-07-01 20:21:33,15290.471,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    3816,2021-07-01 20:21:37,15294.475,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4193,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    3817,2021-07-01 20:21:41,15298.488,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4186,4184,4183,4194,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    3818,2021-07-01 20:21:45,15302.498,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4193,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    3819,2021-07-01 20:21:49,15306.501,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4193,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    3820,2021-07-01 20:21:53,15310.502,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    3821,2021-07-01 20:21:57,15314.508,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1074,SUCCESS
    3822,2021-07-01 20:22:01,15318.518,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1062,SUCCESS
    3823,2021-07-01 20:22:05,15322.532,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    3824,2021-07-01 20:22:09,15326.543,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,960,SUCCESS
    3825,2021-07-01 20:22:13,15330.557,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    3826,2021-07-01 20:22:17,15334.567,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29301,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3827,2021-07-01 20:22:21,15338.571,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,962,SUCCESS
    3828,2021-07-01 20:22:25,15342.585,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,997,SUCCESS
    3829,2021-07-01 20:22:29,15346.596,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3830,2021-07-01 20:22:33,15350.602,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29299,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4183,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1056,SUCCESS
    3831,2021-07-01 20:22:37,15354.604,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29299,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1118,SUCCESS
    3832,2021-07-01 20:22:41,15358.604,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29300,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    3833,2021-07-01 20:22:45,15362.632,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29297,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1073,SUCCESS
    3834,2021-07-01 20:22:49,15366.634,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29297,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    3835,2021-07-01 20:22:53,15370.637,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29298,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4184,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.7,1011,SUCCESS
    3836,2021-07-01 20:22:57,15374.639,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29299,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4183,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1020,SUCCESS
    3837,2021-07-01 20:23:01,15378.648,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29296,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4185,4183,4183,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1086,SUCCESS
    3838,2021-07-01 20:23:05,15382.655,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29295,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    3839,2021-07-01 20:23:09,15386.669,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29297,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4185,4183,4182,4192,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    3840,2021-07-01 20:23:13,15390.671,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29296,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4184,4185,4183,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    3841,2021-07-01 20:23:17,15394.679,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29295,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    3842,2021-07-01 20:23:21,15398.691,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29295,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1079,SUCCESS
    3843,2021-07-01 20:23:25,15402.699,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29294,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1115,SUCCESS
    3844,2021-07-01 20:23:29,15406.702,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29294,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4190,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    3845,2021-07-01 20:23:33,15410.708,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29294,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    3846,2021-07-01 20:23:37,15414.722,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29294,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4191,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3847,2021-07-01 20:23:41,15418.733,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29294,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3848,2021-07-01 20:23:45,15422.735,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1080,SUCCESS
    3849,2021-07-01 20:23:49,15426.736,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    3850,2021-07-01 20:23:53,15430.743,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    3851,2021-07-01 20:23:57,15434.759,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    3852,2021-07-01 20:24:01,15438.772,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1075,SUCCESS
    3853,2021-07-01 20:24:05,15442.786,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1108,SUCCESS
    3854,2021-07-01 20:24:09,15446.794,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29292,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1069,SUCCESS
    3855,2021-07-01 20:24:13,15450.798,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4183,4182,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    3856,2021-07-01 20:24:17,15454.809,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29293,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4183,4184,4183,4181,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1130,SUCCESS
    3857,2021-07-01 20:24:21,15458.818,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29291,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4182,4183,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    3858,2021-07-01 20:24:25,15462.826,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29290,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4183,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.0,980,SUCCESS
    3859,2021-07-01 20:24:29,15466.838,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29291,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4183,4184,4183,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,960,SUCCESS
    3860,2021-07-01 20:24:33,15470.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29288,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    3861,2021-07-01 20:24:37,15474.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29289,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4183,4184,4182,4181,4190,4189,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    3862,2021-07-01 20:24:42,15478.868,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29288,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4183,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    3863,2021-07-01 20:24:46,15482.874,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29288,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    3864,2021-07-01 20:24:50,15486.881,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1042,SUCCESS
    3865,2021-07-01 20:24:54,15490.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,969,SUCCESS
    3866,2021-07-01 20:24:58,15494.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29287,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,998,SUCCESS
    3867,2021-07-01 20:25:02,15498.917,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29287,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.8,949,SUCCESS
    3868,2021-07-01 20:25:06,15502.928,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29287,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,964,SUCCESS
    3869,2021-07-01 20:25:10,15506.943,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29288,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    3870,2021-07-01 20:25:14,15510.957,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29288,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    3871,2021-07-01 20:25:18,15514.957,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29290,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,980,SUCCESS
    3872,2021-07-01 20:25:22,15518.970,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29290,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1063,SUCCESS
    3873,2021-07-01 20:25:26,15522.971,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29292,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4184,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    3874,2021-07-01 20:25:30,15526.984,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29290,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4190,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,987,SUCCESS
    3875,2021-07-01 20:25:34,15530.993,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29287,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    3876,2021-07-01 20:25:38,15535.003,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.8,1029,SUCCESS
    3877,2021-07-01 20:25:42,15539.006,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3878,2021-07-01 20:25:46,15543.006,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    3879,2021-07-01 20:25:50,15547.013,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    3880,2021-07-01 20:25:54,15551.013,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1096,SUCCESS
    3881,2021-07-01 20:25:58,15555.019,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3882,2021-07-01 20:26:02,15559.034,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1014,SUCCESS
    3883,2021-07-01 20:26:06,15563.035,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,998,SUCCESS
    3884,2021-07-01 20:26:10,15567.039,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    3885,2021-07-01 20:26:14,15571.045,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3886,2021-07-01 20:26:18,15575.047,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29284,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.8,1081,SUCCESS
    3887,2021-07-01 20:26:22,15579.048,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29285,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    3888,2021-07-01 20:26:26,15583.060,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29286,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    3889,2021-07-01 20:26:30,15587.072,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29285,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4181,4182,4183,4182,4181,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,975,SUCCESS
    3890,2021-07-01 20:26:34,15591.076,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29284,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4182,4183,4182,4180,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    3891,2021-07-01 20:26:38,15595.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29285,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4182,4183,4182,4180,4188,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1043,SUCCESS
    3892,2021-07-01 20:26:42,15599.098,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29284,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4182,4183,4182,4180,4188,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,966,SUCCESS
    3893,2021-07-01 20:26:46,15603.112,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29283,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4183,4181,4180,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1202,SUCCESS
    3894,2021-07-01 20:26:50,15607.113,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29281,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,34.8,1059,SUCCESS
    3895,2021-07-01 20:26:54,15611.122,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3896,2021-07-01 20:26:58,15615.128,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4189,4188,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    3897,2021-07-01 20:27:02,15619.137,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4189,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    3898,2021-07-01 20:27:06,15623.150,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4190,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1084,SUCCESS
    3899,2021-07-01 20:27:10,15627.165,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4190,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    3900,2021-07-01 20:27:14,15631.178,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4191,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1074,SUCCESS
    3901,2021-07-01 20:27:18,15635.186,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4193,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3902,2021-07-01 20:27:22,15639.195,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4193,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    3903,2021-07-01 20:27:26,15643.199,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4189,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.0,1008,SUCCESS
    3904,2021-07-01 20:27:30,15647.212,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,975,SUCCESS
    3905,2021-07-01 20:27:34,15651.221,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1124,SUCCESS
    3906,2021-07-01 20:27:38,15655.226,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29278,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    3907,2021-07-01 20:27:42,15659.240,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    3908,2021-07-01 20:27:46,15663.241,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4189,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    3909,2021-07-01 20:27:50,15667.246,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29280,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1084,SUCCESS
    3910,2021-07-01 20:27:54,15671.261,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    3911,2021-07-01 20:27:58,15675.276,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    3912,2021-07-01 20:28:02,15679.276,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29278,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    3913,2021-07-01 20:28:06,15683.291,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,962,SUCCESS
    3914,2021-07-01 20:28:10,15687.299,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,984,SUCCESS
    3915,2021-07-01 20:28:14,15691.304,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29278,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    3916,2021-07-01 20:28:18,15695.314,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29279,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    3917,2021-07-01 20:28:22,15699.327,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29278,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    3918,2021-07-01 20:28:26,15703.327,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29277,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4187,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    3919,2021-07-01 20:28:30,15707.333,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29276,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3920,2021-07-01 20:28:34,15711.333,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29277,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4180,4187,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    3921,2021-07-01 20:28:38,15715.338,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29275,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4182,4180,4180,4187,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1006,SUCCESS
    3922,2021-07-01 20:28:42,15719.352,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29278,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4180,4181,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1055,SUCCESS
    3923,2021-07-01 20:28:46,15723.354,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29277,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4182,4181,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,957,SUCCESS
    3924,2021-07-01 20:28:50,15727.355,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29277,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4181,4179,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,975,SUCCESS
    3925,2021-07-01 20:28:54,15731.367,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29275,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4182,4180,4180,4188,4187,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1039,SUCCESS
    3926,2021-07-01 20:28:58,15735.370,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29275,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4182,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1117,SUCCESS
    3927,2021-07-01 20:29:02,15739.382,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29273,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4181,4181,4181,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,995,SUCCESS
    3928,2021-07-01 20:29:06,15743.387,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29273,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3929,2021-07-01 20:29:10,15747.401,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29273,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4180,4188,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1005,SUCCESS
    3930,2021-07-01 20:29:14,15751.405,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29273,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4188,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    3931,2021-07-01 20:29:18,15755.418,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    3932,2021-07-01 20:29:22,15759.419,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,958,SUCCESS
    3933,2021-07-01 20:29:26,15763.421,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    3934,2021-07-01 20:29:30,15767.434,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,974,SUCCESS
    3935,2021-07-01 20:29:34,15771.436,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,938,SUCCESS
    3936,2021-07-01 20:29:38,15775.443,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4186,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3937,2021-07-01 20:29:42,15779.450,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29271,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    3938,2021-07-01 20:29:46,15783.459,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29270,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,997,SUCCESS
    3939,2021-07-01 20:29:50,15787.470,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29270,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    3940,2021-07-01 20:29:54,15791.481,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29270,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,972,SUCCESS
    3941,2021-07-01 20:29:58,15795.490,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29271,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4179,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,995,SUCCESS
    3942,2021-07-01 20:30:02,15799.499,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29272,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3943,2021-07-01 20:30:06,15803.510,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29271,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    3944,2021-07-01 20:30:10,15807.525,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29271,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,959,SUCCESS
    3945,2021-07-01 20:30:14,15811.533,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29270,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1000,SUCCESS
    3946,2021-07-01 20:30:18,15815.548,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29270,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4180,4178,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    3947,2021-07-01 20:30:22,15819.564,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29269,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4179,4178,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3948,2021-07-01 20:30:26,15823.563,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29269,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4179,4179,4187,4186,0,0,0,0,0,0,0,0,3234,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    3949,2021-07-01 20:30:30,15827.567,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29268,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4180,4181,4179,4179,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,995,SUCCESS
    3950,2021-07-01 20:30:34,15831.571,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29267,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4179,4187,4186,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    3951,2021-07-01 20:30:38,15835.572,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29267,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4179,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,975,SUCCESS
    3952,2021-07-01 20:30:42,15839.577,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29264,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1066,SUCCESS
    3953,2021-07-01 20:30:46,15843.585,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29263,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4179,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3954,2021-07-01 20:30:50,15847.594,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29263,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1125,SUCCESS
    3955,2021-07-01 20:30:54,15851.607,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29266,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3234,26.2,26.3,-273.2,26.3,-273.2,35.3,1020,SUCCESS
    3956,2021-07-01 20:30:58,15855.612,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29268,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    3957,2021-07-01 20:31:02,15859.626,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29268,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    3958,2021-07-01 20:31:06,15863.640,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29266,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4181,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3231,26.2,26.3,-273.2,26.3,-273.2,34.4,1086,SUCCESS
    3959,2021-07-01 20:31:10,15867.652,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29266,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3231,26.2,26.3,-273.2,26.3,-273.2,35.2,1099,SUCCESS
    3960,2021-07-01 20:31:14,15871.657,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29271,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4187,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1017,SUCCESS
    3961,2021-07-01 20:31:18,15875.667,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29267,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.1,944,SUCCESS
    3962,2021-07-01 20:31:22,15879.674,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1092,SUCCESS
    3963,2021-07-01 20:31:26,15883.682,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.2,1069,SUCCESS
    3964,2021-07-01 20:31:30,15887.687,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3235,26.2,26.3,-273.2,26.3,-273.2,35.3,1096,SUCCESS
    3965,2021-07-01 20:31:34,15891.691,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3231,26.2,26.3,-273.2,26.3,-273.2,35.1,1092,SUCCESS
    3966,2021-07-01 20:31:38,15895.692,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3234,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    3967,2021-07-01 20:31:42,15899.707,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1046,SUCCESS
    3968,2021-07-01 20:31:46,15903.718,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    3969,2021-07-01 20:31:50,15907.728,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    3970,2021-07-01 20:31:54,15911.728,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3231,26.2,26.3,-273.2,26.3,-273.2,35.2,947,SUCCESS
    3971,2021-07-01 20:31:58,15915.743,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4184,0,0,0,0,0,0,0,0,3234,26.2,26.3,-273.2,26.3,-273.2,35.1,992,SUCCESS
    3972,2021-07-01 20:32:02,15919.743,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.0,1046,SUCCESS
    3973,2021-07-01 20:32:06,15923.757,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    3974,2021-07-01 20:32:10,15927.758,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1024,SUCCESS
    3975,2021-07-01 20:32:14,15931.768,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29264,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1090,SUCCESS
    3976,2021-07-01 20:32:18,15935.781,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    3977,2021-07-01 20:32:22,15939.781,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4178,4179,4180,4179,4178,4186,4185,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1080,SUCCESS
    3978,2021-07-01 20:32:26,15943.788,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4179,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,995,SUCCESS
    3979,2021-07-01 20:32:30,15947.788,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29264,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4179,4177,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,962,SUCCESS
    3980,2021-07-01 20:32:34,15951.803,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29263,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    3981,2021-07-01 20:32:38,15955.812,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.8,1084,SUCCESS
    3982,2021-07-01 20:32:42,15959.817,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29265,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4179,4179,4178,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    3983,2021-07-01 20:32:46,15963.816,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29263,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4179,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    3984,2021-07-01 20:32:50,15967.829,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29263,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,978,SUCCESS
    3985,2021-07-01 20:32:54,15971.833,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29260,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1012,SUCCESS
    3986,2021-07-01 20:32:58,15975.835,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4179,4180,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1026,SUCCESS
    3987,2021-07-01 20:33:02,15979.845,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29261,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1076,SUCCESS
    3988,2021-07-01 20:33:06,15983.859,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4188,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    3989,2021-07-01 20:33:10,15987.860,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29260,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4178,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    3990,2021-07-01 20:33:15,15991.872,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    3991,2021-07-01 20:33:19,15995.887,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1054,SUCCESS
    3992,2021-07-01 20:33:23,15999.899,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    3993,2021-07-01 20:33:27,16003.905,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    3994,2021-07-01 20:33:31,16007.912,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    3995,2021-07-01 20:33:35,16011.924,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29258,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1108,SUCCESS
    3996,2021-07-01 20:33:39,16015.929,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29258,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4178,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1026,SUCCESS
    3997,2021-07-01 20:33:43,16019.937,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29259,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    3998,2021-07-01 20:33:47,16023.950,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    3999,2021-07-01 20:33:51,16027.956,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29258,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4000,2021-07-01 20:33:55,16031.968,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29258,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1021,SUCCESS
    4001,2021-07-01 20:33:59,16035.982,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29258,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1114,SUCCESS
    4002,2021-07-01 20:34:03,16039.994,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    4003,2021-07-01 20:34:07,16043.994,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4177,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    4004,2021-07-01 20:34:11,16048.009,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    4005,2021-07-01 20:34:15,16052.012,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    4006,2021-07-01 20:34:19,16056.019,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    4007,2021-07-01 20:34:23,16060.032,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1127,SUCCESS
    4008,2021-07-01 20:34:27,16064.042,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,973,SUCCESS
    4009,2021-07-01 20:34:31,16068.051,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1080,SUCCESS
    4010,2021-07-01 20:34:35,16072.053,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29256,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,965,SUCCESS
    4011,2021-07-01 20:34:39,16076.065,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29256,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1093,SUCCESS
    4012,2021-07-01 20:34:43,16080.070,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29257,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4186,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    4013,2021-07-01 20:34:47,16084.078,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29255,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4177,4176,4185,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.8,985,SUCCESS
    4014,2021-07-01 20:34:51,16088.082,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29256,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1075,SUCCESS
    4015,2021-07-01 20:34:55,16092.094,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29256,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1079,SUCCESS
    4016,2021-07-01 20:34:59,16096.102,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29254,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4178,4177,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,961,SUCCESS
    4017,2021-07-01 20:35:03,16100.113,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29254,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4179,4178,4177,4184,4184,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1060,SUCCESS
    4018,2021-07-01 20:35:07,16104.114,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29255,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4177,4177,4185,4184,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.3,980,SUCCESS
    4019,2021-07-01 20:35:11,16108.126,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29254,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4177,4185,4183,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1110,SUCCESS
    4020,2021-07-01 20:35:15,16112.131,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29254,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4178,4177,4185,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1074,SUCCESS
    4021,2021-07-01 20:35:19,16116.140,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29252,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4177,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    4022,2021-07-01 20:35:23,16120.152,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29252,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4177,4177,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1034,SUCCESS
    4023,2021-07-01 20:35:27,16124.153,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4178,4178,4177,4177,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,973,SUCCESS
    4024,2021-07-01 20:35:31,16128.163,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4177,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    4025,2021-07-01 20:35:35,16132.168,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29252,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4177,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    4026,2021-07-01 20:35:39,16136.182,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1007,SUCCESS
    4027,2021-07-01 20:35:43,16140.184,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    4028,2021-07-01 20:35:47,16144.185,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,940,SUCCESS
    4029,2021-07-01 20:35:51,16148.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    4030,2021-07-01 20:35:55,16152.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    4031,2021-07-01 20:35:59,16156.195,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,993,SUCCESS
    4032,2021-07-01 20:36:03,16160.201,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    4033,2021-07-01 20:36:07,16164.211,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29250,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    4034,2021-07-01 20:36:11,16168.225,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    4035,2021-07-01 20:36:15,16172.225,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1015,SUCCESS
    4036,2021-07-01 20:36:19,16176.225,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.7,1032,SUCCESS
    4037,2021-07-01 20:36:23,16180.228,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29251,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4177,4178,4177,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    4038,2021-07-01 20:36:27,16184.232,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29248,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4176,4176,4178,4177,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1128,SUCCESS
    4039,2021-07-01 20:36:31,16188.232,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29248,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4184,4183,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4040,2021-07-01 20:36:35,16192.236,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29248,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4177,4178,4176,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    4041,2021-07-01 20:36:39,16196.249,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29248,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4177,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    4042,2021-07-01 20:36:43,16200.263,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29248,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    4043,2021-07-01 20:36:47,16204.278,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4177,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    4044,2021-07-01 20:36:51,16208.285,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    4045,2021-07-01 20:36:55,16212.288,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29246,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4177,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,34.7,1042,SUCCESS
    4046,2021-07-01 20:36:59,16216.288,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,995,SUCCESS
    4047,2021-07-01 20:37:03,16220.292,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29246,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,962,SUCCESS
    4048,2021-07-01 20:37:07,16224.304,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    4049,2021-07-01 20:37:11,16228.314,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4186,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1000,SUCCESS
    4050,2021-07-01 20:37:15,16232.325,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4185,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1036,SUCCESS
    4051,2021-07-01 20:37:19,16236.335,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29247,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    4052,2021-07-01 20:37:23,16240.343,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4175,4184,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    4053,2021-07-01 20:37:27,16244.358,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1002,SUCCESS
    4054,2021-07-01 20:37:31,16248.371,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,989,SUCCESS
    4055,2021-07-01 20:37:35,16252.383,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,960,SUCCESS
    4056,2021-07-01 20:37:39,16256.388,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    4057,2021-07-01 20:37:43,16260.399,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4176,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    4058,2021-07-01 20:37:47,16264.402,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4178,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    4059,2021-07-01 20:37:51,16268.405,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4060,2021-07-01 20:37:55,16272.414,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29245,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    4061,2021-07-01 20:37:59,16276.424,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    4062,2021-07-01 20:38:03,16280.428,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4063,2021-07-01 20:38:07,16284.429,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    4064,2021-07-01 20:38:11,16288.440,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4065,2021-07-01 20:38:15,16292.447,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    4066,2021-07-01 20:38:19,16296.456,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    4067,2021-07-01 20:38:23,16300.470,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4068,2021-07-01 20:38:27,16304.474,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4069,2021-07-01 20:38:31,16308.477,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1077,SUCCESS
    4070,2021-07-01 20:38:35,16312.491,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    4071,2021-07-01 20:38:39,16316.503,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4182,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1107,SUCCESS
    4072,2021-07-01 20:38:43,16320.517,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29244,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1031,SUCCESS
    4073,2021-07-01 20:38:47,16324.524,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1071,SUCCESS
    4074,2021-07-01 20:38:51,16328.524,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29242,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,961,SUCCESS
    4075,2021-07-01 20:38:55,16332.528,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4176,4177,4176,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    4076,2021-07-01 20:38:59,16336.533,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29242,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4175,4175,4183,4182,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4077,2021-07-01 20:39:03,16340.547,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29243,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4175,4176,4177,4176,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,1065,SUCCESS
    4078,2021-07-01 20:39:07,16344.557,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29239,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    4079,2021-07-01 20:39:11,16348.564,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29240,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4176,4176,4175,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    4080,2021-07-01 20:39:15,16352.577,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29241,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4176,4177,4176,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    4081,2021-07-01 20:39:19,16356.579,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29239,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4176,4177,4175,4175,4183,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4082,2021-07-01 20:39:23,16360.581,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29239,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4176,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.3,953,SUCCESS
    4083,2021-07-01 20:39:27,16364.586,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29238,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    4084,2021-07-01 20:39:31,16368.590,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29238,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4085,2021-07-01 20:39:35,16372.589,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,988,SUCCESS
    4086,2021-07-01 20:39:39,16376.601,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29238,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,34.9,984,SUCCESS
    4087,2021-07-01 20:39:43,16380.614,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4175,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,948,SUCCESS
    4088,2021-07-01 20:39:47,16384.620,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    4089,2021-07-01 20:39:51,16388.622,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1068,SUCCESS
    4090,2021-07-01 20:39:55,16392.633,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1055,SUCCESS
    4091,2021-07-01 20:39:59,16396.639,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1002,SUCCESS
    4092,2021-07-01 20:40:03,16400.646,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    4093,2021-07-01 20:40:07,16404.655,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1034,SUCCESS
    4094,2021-07-01 20:40:11,16408.667,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1084,SUCCESS
    4095,2021-07-01 20:40:15,16412.676,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.6,1067,SUCCESS
    4096,2021-07-01 20:40:19,16416.684,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29238,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    4097,2021-07-01 20:40:23,16420.695,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,948,SUCCESS
    4098,2021-07-01 20:40:27,16424.708,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29235,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,965,SUCCESS
    4099,2021-07-01 20:40:31,16428.717,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    4100,2021-07-01 20:40:35,16432.725,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29235,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4174,4175,4176,4175,4174,4182,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    4101,2021-07-01 20:40:39,16436.736,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4175,4174,4182,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4102,2021-07-01 20:40:43,16440.742,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4175,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    4103,2021-07-01 20:40:47,16444.746,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4182,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    4104,2021-07-01 20:40:51,16448.761,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29237,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4175,4174,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.6,1036,SUCCESS
    4105,2021-07-01 20:40:55,16452.767,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4175,4174,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    4106,2021-07-01 20:40:59,16456.769,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29236,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    4107,2021-07-01 20:41:03,16460.782,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29234,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    4108,2021-07-01 20:41:07,16464.793,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29234,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4181,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,942,SUCCESS
    4109,2021-07-01 20:41:11,16468.811,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29234,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1065,SUCCESS
    4110,2021-07-01 20:41:15,16472.823,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29233,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1070,SUCCESS
    4111,2021-07-01 20:41:19,16476.827,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29233,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    4112,2021-07-01 20:41:23,16480.828,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29233,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1111,SUCCESS
    4113,2021-07-01 20:41:27,16484.842,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29234,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4181,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.8,1024,SUCCESS
    4114,2021-07-01 20:41:31,16488.846,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29231,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4174,4181,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4115,2021-07-01 20:41:35,16492.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29231,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4176,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    4116,2021-07-01 20:41:40,16496.867,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29231,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1103,SUCCESS
    4117,2021-07-01 20:41:44,16500.880,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1088,SUCCESS
    4118,2021-07-01 20:41:48,16504.894,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4176,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    4119,2021-07-01 20:41:52,16508.905,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    4120,2021-07-01 20:41:56,16512.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1076,SUCCESS
    4121,2021-07-01 20:42:00,16516.920,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4175,4176,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1001,SUCCESS
    4122,2021-07-01 20:42:04,16520.925,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29231,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1061,SUCCESS
    4123,2021-07-01 20:42:08,16524.927,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.3,963,SUCCESS
    4124,2021-07-01 20:42:12,16528.938,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1063,SUCCESS
    4125,2021-07-01 20:42:16,16532.942,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4179,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.2,-273.2,35.2,978,SUCCESS
    4126,2021-07-01 20:42:20,16536.943,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4178,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4127,2021-07-01 20:42:24,16540.951,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,34.9,1035,SUCCESS
    4128,2021-07-01 20:42:28,16544.966,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,941,SUCCESS
    4129,2021-07-01 20:42:32,16548.979,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4180,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4130,2021-07-01 20:42:36,16552.994,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29229,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4181,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,989,SUCCESS
    4131,2021-07-01 20:42:40,16557.002,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29230,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4182,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    4132,2021-07-01 20:42:44,16561.015,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29228,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4185,4180,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,987,SUCCESS
    4133,2021-07-01 20:42:48,16565.018,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29229,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4182,4179,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.3,1060,SUCCESS
    4134,2021-07-01 20:42:52,16569.030,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29229,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1032,SUCCESS
    4135,2021-07-01 20:42:56,16573.031,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29228,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.1,1017,SUCCESS
    4136,2021-07-01 20:43:00,16577.033,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29229,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.0,1023,SUCCESS
    4137,2021-07-01 20:43:04,16581.033,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    4138,2021-07-01 20:43:08,16585.034,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4173,4174,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4139,2021-07-01 20:43:12,16589.038,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4174,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    4140,2021-07-01 20:43:16,16593.053,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29228,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4174,4175,4174,4173,4181,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,995,SUCCESS
    4141,2021-07-01 20:43:20,16597.068,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    4142,2021-07-01 20:43:24,16601.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    4143,2021-07-01 20:43:28,16605.087,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29226,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4174,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    4144,2021-07-01 20:43:32,16609.087,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,960,SUCCESS
    4145,2021-07-01 20:43:36,16613.089,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29227,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4174,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1054,SUCCESS
    4146,2021-07-01 20:43:40,16617.095,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4147,2021-07-01 20:43:44,16621.096,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29226,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    4148,2021-07-01 20:43:48,16625.097,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1075,SUCCESS
    4149,2021-07-01 20:43:52,16629.111,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    4150,2021-07-01 20:43:56,16633.122,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    4151,2021-07-01 20:44:00,16637.137,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    4152,2021-07-01 20:44:04,16641.147,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    4153,2021-07-01 20:44:08,16645.161,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4154,2021-07-01 20:44:12,16649.173,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4173,4181,4179,0,0,0,0,0,0,0,0,3230,26.2,26.2,-273.2,26.2,-273.2,35.2,1078,SUCCESS
    4155,2021-07-01 20:44:16,16653.183,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4173,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4156,2021-07-01 20:44:20,16657.198,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,990,SUCCESS
    4157,2021-07-01 20:44:24,16661.209,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29225,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4175,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    4158,2021-07-01 20:44:28,16665.216,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    4159,2021-07-01 20:44:32,16669.228,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2352,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    4160,2021-07-01 20:44:36,16673.231,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    4161,2021-07-01 20:44:40,16677.244,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29224,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,944,SUCCESS
    4162,2021-07-01 20:44:44,16681.257,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    4163,2021-07-01 20:44:48,16685.257,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,998,SUCCESS
    4164,2021-07-01 20:44:52,16689.262,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1004,SUCCESS
    4165,2021-07-01 20:44:56,16693.272,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    4166,2021-07-01 20:45:00,16697.283,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    4167,2021-07-01 20:45:04,16701.298,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3226,26.2,26.3,-273.2,26.3,-273.2,35.2,1143,SUCCESS
    4168,2021-07-01 20:45:08,16705.312,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4179,0,0,0,0,0,0,0,0,3230,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    4169,2021-07-01 20:45:12,16709.315,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29221,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4178,0,0,0,0,0,0,0,0,3226,26.2,26.3,-273.2,26.3,-273.2,35.2,1107,SUCCESS
    4170,2021-07-01 20:45:16,16713.329,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3229,26.2,26.2,-273.2,26.2,-273.2,35.2,1017,SUCCESS
    4171,2021-07-01 20:45:20,16717.344,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    4172,2021-07-01 20:45:24,16721.354,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,991,SUCCESS
    4173,2021-07-01 20:45:28,16725.359,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29221,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1002,SUCCESS
    4174,2021-07-01 20:45:32,16729.370,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,959,SUCCESS
    4175,2021-07-01 20:45:36,16733.375,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29221,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4173,4174,4173,4172,4179,4179,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1085,SUCCESS
    4176,2021-07-01 20:45:40,16737.385,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29222,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,947,SUCCESS
    4177,2021-07-01 20:45:44,16741.384,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29221,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,943,SUCCESS
    4178,2021-07-01 20:45:48,16745.389,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29220,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3229,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    4179,2021-07-01 20:45:52,16749.397,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29219,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    4180,2021-07-01 20:45:56,16753.398,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29220,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4173,4173,4173,4172,4180,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,992,SUCCESS
    4181,2021-07-01 20:46:00,16757.403,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29220,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4174,4173,4172,4180,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    4182,2021-07-01 20:46:04,16761.407,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29219,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4173,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4183,2021-07-01 20:46:08,16765.417,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29218,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4184,2021-07-01 20:46:12,16769.427,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29218,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,ERROR : Please check C:\ti\BatteryManagementStudio\charge test 20210701.log.err
    4185,2021-07-01 20:46:16,16773.436,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29220,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4172,4173,4173,4172,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1049,SUCCESS
    4186,2021-07-01 20:46:20,16777.435,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29223,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4173,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1098,SUCCESS
    4187,2021-07-01 20:46:24,16781.444,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29217,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1011,SUCCESS
    4188,2021-07-01 20:46:28,16785.448,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29215,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1006,SUCCESS
    4189,2021-07-01 20:46:32,16789.449,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29216,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1036,SUCCESS
    4190,2021-07-01 20:46:36,16793.462,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4178,4178,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    4191,2021-07-01 20:46:40,16797.471,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4178,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1030,SUCCESS
    4192,2021-07-01 20:46:44,16801.482,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29215,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4179,4178,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1095,SUCCESS
    4193,2021-07-01 20:46:48,16805.487,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29217,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1061,SUCCESS
    4194,2021-07-01 20:46:52,16809.497,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29216,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4172,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1036,SUCCESS
    4195,2021-07-01 20:46:56,16813.504,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29215,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    4196,2021-07-01 20:47:00,16817.516,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29215,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1019,SUCCESS
    4197,2021-07-01 20:47:04,16821.531,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1081,SUCCESS
    4198,2021-07-01 20:47:08,16825.539,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,995,SUCCESS
    4199,2021-07-01 20:47:12,16829.550,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29215,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,34.8,1006,SUCCESS
    4200,2021-07-01 20:47:16,16833.551,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1014,SUCCESS
    4201,2021-07-01 20:47:20,16837.564,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1126,SUCCESS
    4202,2021-07-01 20:47:24,16841.580,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1039,SUCCESS
    4203,2021-07-01 20:47:28,16845.592,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    4204,2021-07-01 20:47:32,16849.593,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4177,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4205,2021-07-01 20:47:36,16853.594,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4174,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.3,1038,SUCCESS
    4206,2021-07-01 20:47:40,16857.610,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4172,4171,4175,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    4207,2021-07-01 20:47:44,16861.624,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    4208,2021-07-01 20:47:48,16865.625,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29214,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4172,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1082,SUCCESS
    4209,2021-07-01 20:47:52,16869.626,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29211,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    4210,2021-07-01 20:47:56,16873.640,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4171,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    4211,2021-07-01 20:48:00,16877.646,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29213,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4172,4171,4179,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    4212,2021-07-01 20:48:04,16881.654,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,973,SUCCESS
    4213,2021-07-01 20:48:08,16885.661,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29213,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4214,2021-07-01 20:48:12,16889.670,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29213,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1012,SUCCESS
    4215,2021-07-01 20:48:16,16893.671,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29213,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    4216,2021-07-01 20:48:20,16897.678,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4217,2021-07-01 20:48:24,16901.688,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,34.4,1072,SUCCESS
    4218,2021-07-01 20:48:28,16905.691,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4172,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1123,SUCCESS
    4219,2021-07-01 20:48:32,16909.692,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29211,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4173,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1045,SUCCESS
    4220,2021-07-01 20:48:36,16913.699,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29210,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4172,4173,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,974,SUCCESS
    4221,2021-07-01 20:48:40,16917.708,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29212,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4171,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,980,SUCCESS
    4222,2021-07-01 20:48:44,16921.715,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1099,SUCCESS
    4223,2021-07-01 20:48:48,16925.724,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29210,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4171,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1059,SUCCESS
    4224,2021-07-01 20:48:52,16929.739,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29210,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1075,SUCCESS
    4225,2021-07-01 20:48:56,16933.749,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1046,SUCCESS
    4226,2021-07-01 20:49:00,16937.753,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29210,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,34.9,1099,SUCCESS
    4227,2021-07-01 20:49:04,16941.764,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1080,SUCCESS
    4228,2021-07-01 20:49:08,16945.775,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,963,SUCCESS
    4229,2021-07-01 20:49:12,16949.784,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1044,SUCCESS
    4230,2021-07-01 20:49:16,16953.785,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4177,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,997,SUCCESS
    4231,2021-07-01 20:49:20,16957.796,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29208,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1033,SUCCESS
    4232,2021-07-01 20:49:24,16961.805,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4233,2021-07-01 20:49:28,16965.806,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29208,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4234,2021-07-01 20:49:32,16969.817,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29208,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4178,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    4235,2021-07-01 20:49:36,16973.826,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29209,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,34.7,993,SUCCESS
    4236,2021-07-01 20:49:40,16977.832,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    4237,2021-07-01 20:49:44,16981.841,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29208,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    4238,2021-07-01 20:49:48,16985.849,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    4239,2021-07-01 20:49:52,16989.857,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4177,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1081,SUCCESS
    4240,2021-07-01 20:49:57,16993.871,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    4241,2021-07-01 20:50:01,16997.880,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4171,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    4242,2021-07-01 20:50:05,17001.888,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,970,SUCCESS
    4243,2021-07-01 20:50:09,17005.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,970,SUCCESS
    4244,2021-07-01 20:50:13,17009.918,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1084,SUCCESS
    4245,2021-07-01 20:50:17,17013.934,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,958,SUCCESS
    4246,2021-07-01 20:50:21,17017.938,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4170,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1016,SUCCESS
    4247,2021-07-01 20:50:25,17021.942,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29207,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1062,SUCCESS
    4248,2021-07-01 20:50:29,17025.944,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29206,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4170,4171,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1026,SUCCESS
    4249,2021-07-01 20:50:33,17029.955,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29206,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4172,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1078,SUCCESS
    4250,2021-07-01 20:50:37,17033.965,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1114,SUCCESS
    4251,2021-07-01 20:50:41,17037.978,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,945,SUCCESS
    4252,2021-07-01 20:50:45,17041.985,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    4253,2021-07-01 20:50:49,17045.989,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,34.6,1145,SUCCESS
    4254,2021-07-01 20:50:53,17050.002,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1014,SUCCESS
    4255,2021-07-01 20:50:57,17054.017,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29202,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.2,-273.2,35.1,1014,SUCCESS
    4256,2021-07-01 20:51:01,17058.021,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29202,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4171,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.2,-273.2,35.2,980,SUCCESS
    4257,2021-07-01 20:51:05,17062.034,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4258,2021-07-01 20:51:09,17066.038,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29202,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    4259,2021-07-01 20:51:13,17070.045,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    4260,2021-07-01 20:51:17,17074.048,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29199,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4261,2021-07-01 20:51:21,17078.059,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4170,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    4262,2021-07-01 20:51:25,17082.062,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29204,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1034,SUCCESS
    4263,2021-07-01 20:51:29,17086.071,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29202,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1022,SUCCESS
    4264,2021-07-01 20:51:33,17090.076,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29205,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1004,SUCCESS
    4265,2021-07-01 20:51:37,17094.082,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29203,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1046,SUCCESS
    4266,2021-07-01 20:51:41,17098.084,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29206,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1042,SUCCESS
    4267,2021-07-01 20:51:45,17102.095,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29202,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1109,SUCCESS
    4268,2021-07-01 20:51:49,17106.099,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29201,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1027,SUCCESS
    4269,2021-07-01 20:51:53,17110.112,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4177,4176,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1078,SUCCESS
    4270,2021-07-01 20:51:57,17114.116,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4271,2021-07-01 20:52:01,17118.118,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29201,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    4272,2021-07-01 20:52:05,17122.126,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29199,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    4273,2021-07-01 20:52:09,17126.133,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4274,2021-07-01 20:52:13,17130.138,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    4275,2021-07-01 20:52:17,17134.139,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29201,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    4276,2021-07-01 20:52:21,17138.146,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    4277,2021-07-01 20:52:25,17142.151,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29199,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1037,SUCCESS
    4278,2021-07-01 20:52:29,17146.156,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    4279,2021-07-01 20:52:33,17150.158,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    4280,2021-07-01 20:52:37,17154.159,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1043,SUCCESS
    4281,2021-07-01 20:52:41,17158.167,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,975,SUCCESS
    4282,2021-07-01 20:52:45,17162.172,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4170,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1110,SUCCESS
    4283,2021-07-01 20:52:49,17166.187,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29200,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4171,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,938,SUCCESS
    4284,2021-07-01 20:52:53,17170.201,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29199,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4171,4169,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1097,SUCCESS
    4285,2021-07-01 20:52:57,17174.203,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29199,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4169,4170,4170,4170,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1080,SUCCESS
    4286,2021-07-01 20:53:01,17178.217,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29198,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4170,4169,4169,4174,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1081,SUCCESS
    4287,2021-07-01 20:53:05,17182.219,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29197,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4170,4170,4169,4173,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1096,SUCCESS
    4288,2021-07-01 20:53:09,17186.223,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29198,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4170,4170,4169,4172,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1073,SUCCESS
    4289,2021-07-01 20:53:13,17190.233,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29198,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4170,4169,4169,4175,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1048,SUCCESS
    4290,2021-07-01 20:53:17,17194.235,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29197,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4170,4170,4169,4169,4177,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.3,1087,SUCCESS
    4291,2021-07-01 20:53:21,17198.248,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29197,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4178,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1081,SUCCESS
    4292,2021-07-01 20:53:25,17202.249,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29197,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4178,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1066,SUCCESS
    4293,2021-07-01 20:53:29,17206.257,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29197,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4176,4175,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1026,SUCCESS
    4294,2021-07-01 20:53:33,17210.263,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29196,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4180,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1068,SUCCESS
    4295,2021-07-01 20:53:37,17214.268,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4177,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1013,SUCCESS
    4296,2021-07-01 20:53:41,17218.280,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1080,SUCCESS
    4297,2021-07-01 20:53:45,17222.281,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,971,SUCCESS
    4298,2021-07-01 20:53:49,17226.289,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,992,SUCCESS
    4299,2021-07-01 20:53:53,17230.301,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1089,SUCCESS
    4300,2021-07-01 20:53:57,17234.302,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1043,SUCCESS
    4301,2021-07-01 20:54:01,17238.308,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1007,SUCCESS
    4302,2021-07-01 20:54:05,17242.320,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1071,SUCCESS
    4303,2021-07-01 20:54:09,17246.326,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1003,SUCCESS
    4304,2021-07-01 20:54:13,17250.329,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4169,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1049,SUCCESS
    4305,2021-07-01 20:54:17,17254.340,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1037,SUCCESS
    4306,2021-07-01 20:54:21,17258.354,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29192,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1101,SUCCESS
    4307,2021-07-01 20:54:25,17262.356,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29194,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,974,SUCCESS
    4308,2021-07-01 20:54:29,17266.361,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4309,2021-07-01 20:54:33,17270.373,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1128,SUCCESS
    4310,2021-07-01 20:54:37,17274.377,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4311,2021-07-01 20:54:41,17278.393,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1015,SUCCESS
    4312,2021-07-01 20:54:45,17282.407,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1048,SUCCESS
    4313,2021-07-01 20:54:49,17286.414,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29193,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4168,4169,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,994,SUCCESS
    4314,2021-07-01 20:54:53,17290.421,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1114,SUCCESS
    4315,2021-07-01 20:54:57,17294.435,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1099,SUCCESS
    4316,2021-07-01 20:55:01,17298.445,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4169,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    4317,2021-07-01 20:55:05,17302.448,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1084,SUCCESS
    4318,2021-07-01 20:55:09,17306.452,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4169,4168,4176,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1082,SUCCESS
    4319,2021-07-01 20:55:13,17310.461,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4169,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1009,SUCCESS
    4320,2021-07-01 20:55:17,17314.464,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29191,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,990,SUCCESS
    4321,2021-07-01 20:55:21,17318.465,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1021,SUCCESS
    4322,2021-07-01 20:55:25,17322.468,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1037,SUCCESS
    4323,2021-07-01 20:55:29,17326.478,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,978,SUCCESS
    4324,2021-07-01 20:55:33,17330.487,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1093,SUCCESS
    4325,2021-07-01 20:55:37,17334.499,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1049,SUCCESS
    4326,2021-07-01 20:55:41,17338.513,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29189,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4170,4168,4168,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.3,1035,SUCCESS
    4327,2021-07-01 20:55:45,17342.521,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29189,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4168,4175,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,963,SUCCESS
    4328,2021-07-01 20:55:49,17346.529,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29189,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4168,4174,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1003,SUCCESS
    4329,2021-07-01 20:55:53,17350.531,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29188,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4168,4174,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4330,2021-07-01 20:55:57,17354.535,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29188,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4175,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    4331,2021-07-01 20:56:01,17358.551,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29189,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4175,4174,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4332,2021-07-01 20:56:05,17362.564,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29188,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1046,SUCCESS
    4333,2021-07-01 20:56:09,17366.570,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    4334,2021-07-01 20:56:13,17370.581,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4175,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    4335,2021-07-01 20:56:17,17374.591,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,34.8,947,SUCCESS
    4336,2021-07-01 20:56:21,17378.597,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.3,1061,SUCCESS
    4337,2021-07-01 20:56:25,17382.611,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1062,SUCCESS
    4338,2021-07-01 20:56:29,17386.617,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    4339,2021-07-01 20:56:33,17390.625,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    4340,2021-07-01 20:56:37,17394.636,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1003,SUCCESS
    4341,2021-07-01 20:56:41,17398.649,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,960,SUCCESS
    4342,2021-07-01 20:56:45,17402.662,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4343,2021-07-01 20:56:49,17406.672,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29184,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1143,SUCCESS
    4344,2021-07-01 20:56:53,17410.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29184,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,34.5,1029,SUCCESS
    4345,2021-07-01 20:56:57,17414.689,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29183,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1061,SUCCESS
    4346,2021-07-01 20:57:01,17418.701,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1082,SUCCESS
    4347,2021-07-01 20:57:05,17422.708,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29187,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,996,SUCCESS
    4348,2021-07-01 20:57:09,17426.721,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29185,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4168,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1091,SUCCESS
    4349,2021-07-01 20:57:13,17430.730,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1037,SUCCESS
    4350,2021-07-01 20:57:17,17434.742,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29188,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1024,SUCCESS
    4351,2021-07-01 20:57:21,17438.758,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29189,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1087,SUCCESS
    4352,2021-07-01 20:57:25,17442.764,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29190,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4168,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,987,SUCCESS
    4353,2021-07-01 20:57:29,17446.776,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29186,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4169,4168,4167,4175,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,991,SUCCESS
    4354,2021-07-01 20:57:33,17450.785,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29185,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1075,SUCCESS
    4355,2021-07-01 20:57:37,17454.792,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29185,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4167,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    4356,2021-07-01 20:57:41,17458.797,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29184,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4168,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    4357,2021-07-01 20:57:45,17462.806,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29183,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1054,SUCCESS
    4358,2021-07-01 20:57:49,17466.811,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29185,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1003,SUCCESS
    4359,2021-07-01 20:57:53,17470.813,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29184,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4167,4168,4168,4168,4167,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1079,SUCCESS
    4360,2021-07-01 20:57:57,17474.825,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29183,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1021,SUCCESS
    4361,2021-07-01 20:58:01,17478.826,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29184,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4168,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1034,SUCCESS
    4362,2021-07-01 20:58:05,17482.829,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1096,SUCCESS
    4363,2021-07-01 20:58:09,17486.834,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29183,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4168,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,980,SUCCESS
    4364,2021-07-01 20:58:13,17490.837,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1042,SUCCESS
    4365,2021-07-01 20:58:17,17494.849,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,997,SUCCESS
    4366,2021-07-01 20:58:21,17498.849,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.2,-273.2,35.2,1043,SUCCESS
    4367,2021-07-01 20:58:25,17502.851,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.3,1058,SUCCESS
    4368,2021-07-01 20:58:29,17506.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4369,2021-07-01 20:58:34,17510.869,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29180,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    4370,2021-07-01 20:58:38,17514.876,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1126,SUCCESS
    4371,2021-07-01 20:58:42,17518.892,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    4372,2021-07-01 20:58:46,17522.906,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29182,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1034,SUCCESS
    4373,2021-07-01 20:58:50,17526.920,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29181,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1052,SUCCESS
    4374,2021-07-01 20:58:54,17530.930,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29181,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,952,SUCCESS
    4375,2021-07-01 20:58:58,17534.935,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4173,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1021,SUCCESS
    4376,2021-07-01 20:59:02,17538.935,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29180,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1034,SUCCESS
    4377,2021-07-01 20:59:06,17542.939,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29180,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4174,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    4378,2021-07-01 20:59:10,17546.955,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29180,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4167,4172,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1125,SUCCESS
    4379,2021-07-01 20:59:14,17550.963,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    4380,2021-07-01 20:59:18,17554.976,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    4381,2021-07-01 20:59:22,17558.981,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    4382,2021-07-01 20:59:26,17562.988,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.1,1122,SUCCESS
    4383,2021-07-01 20:59:30,17567.002,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1045,SUCCESS
    4384,2021-07-01 20:59:34,17571.003,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1044,SUCCESS
    4385,2021-07-01 20:59:38,17575.014,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,970,SUCCESS
    4386,2021-07-01 20:59:42,17579.019,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1028,SUCCESS
    4387,2021-07-01 20:59:46,17583.020,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.2,-273.2,26.2,-273.2,35.2,1093,SUCCESS
    4388,2021-07-01 20:59:50,17587.035,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3224,26.2,26.2,-273.2,26.2,-273.2,35.1,1013,SUCCESS
    4389,2021-07-01 20:59:54,17591.036,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4172,4172,0,0,0,0,0,0,0,0,3224,26.2,26.2,-273.2,26.2,-273.2,35.1,949,SUCCESS
    4390,2021-07-01 20:59:58,17595.045,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4172,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    4391,2021-07-01 21:00:02,17599.046,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    4392,2021-07-01 21:00:06,17603.057,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    4393,2021-07-01 21:00:10,17607.069,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    4394,2021-07-01 21:00:14,17611.084,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,979,SUCCESS
    4395,2021-07-01 21:00:18,17615.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3221,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    4396,2021-07-01 21:00:22,17619.098,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29179,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4166,4167,4167,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    4397,2021-07-01 21:00:26,17623.108,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4167,4168,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1065,SUCCESS
    4398,2021-07-01 21:00:30,17627.114,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4167,4166,4172,4172,0,0,0,0,0,0,0,0,3224,26.2,26.2,-273.2,26.2,-273.2,35.1,964,SUCCESS
    4399,2021-07-01 21:00:34,17631.116,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29178,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4167,4167,4167,4166,4173,4172,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,946,SUCCESS
    4400,2021-07-01 21:00:38,17635.118,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29176,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4167,4167,4167,4166,4172,4172,0,0,0,0,0,0,0,0,3221,26.2,26.2,-273.2,26.2,-273.2,35.2,1056,SUCCESS
    4401,2021-07-01 21:00:42,17639.133,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29176,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4167,4166,4172,4172,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1026,SUCCESS
    4402,2021-07-01 21:00:46,17643.134,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29175,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4172,0,0,0,0,0,0,0,0,3225,26.2,26.3,-273.2,26.3,-273.2,35.1,992,SUCCESS
    4403,2021-07-01 21:00:50,17647.147,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29174,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4172,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    4404,2021-07-01 21:00:54,17651.158,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1029,SUCCESS
    4405,2021-07-01 21:00:58,17655.171,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4172,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1080,SUCCESS
    4406,2021-07-01 21:01:02,17659.176,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1092,SUCCESS
    4407,2021-07-01 21:01:06,17663.179,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4173,4171,0,0,0,0,0,0,0,0,3224,26.2,26.2,-273.2,26.2,-273.2,35.2,1026,SUCCESS
    4408,2021-07-01 21:01:10,17667.191,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4173,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,996,SUCCESS
    4409,2021-07-01 21:01:14,17671.193,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,980,SUCCESS
    4410,2021-07-01 21:01:18,17675.198,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1054,SUCCESS
    4411,2021-07-01 21:01:22,17679.198,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4173,4172,0,0,0,0,0,0,0,0,3221,26.2,26.2,-273.2,26.2,-273.2,35.2,1007,SUCCESS
    4412,2021-07-01 21:01:26,17683.204,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29174,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,986,SUCCESS
    4413,2021-07-01 21:01:30,17687.212,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29174,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    4414,2021-07-01 21:01:34,17691.225,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29174,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    4415,2021-07-01 21:01:38,17695.234,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1034,SUCCESS
    4416,2021-07-01 21:01:42,17699.245,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1085,SUCCESS
    4417,2021-07-01 21:01:46,17703.259,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1071,SUCCESS
    4418,2021-07-01 21:01:50,17707.273,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1028,SUCCESS
    4419,2021-07-01 21:01:54,17711.279,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1052,SUCCESS
    4420,2021-07-01 21:01:58,17715.286,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1092,SUCCESS
    4421,2021-07-01 21:02:02,17719.300,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29173,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1124,SUCCESS
    4422,2021-07-01 21:02:06,17723.311,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.6,1041,SUCCESS
    4423,2021-07-01 21:02:10,17727.326,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1004,SUCCESS
    4424,2021-07-01 21:02:14,17731.328,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29172,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4165,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4425,2021-07-01 21:02:18,17735.344,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29171,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4166,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1036,SUCCESS
    4426,2021-07-01 21:02:22,17739.357,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29171,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4165,4166,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4427,2021-07-01 21:02:26,17743.363,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29171,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4166,4167,4166,4166,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    4428,2021-07-01 21:02:30,17747.363,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29170,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1016,SUCCESS
    4429,2021-07-01 21:02:34,17751.375,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29171,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1080,SUCCESS
    4430,2021-07-01 21:02:38,17755.378,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29169,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4167,4165,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1061,SUCCESS
    4431,2021-07-01 21:02:42,17759.392,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29171,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4167,4166,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.9,1006,SUCCESS
    4432,2021-07-01 21:02:46,17763.393,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1047,SUCCESS
    4433,2021-07-01 21:02:50,17767.408,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4166,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1077,SUCCESS
    4434,2021-07-01 21:02:54,17771.411,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29169,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4167,4165,4165,4170,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1089,SUCCESS
    4435,2021-07-01 21:02:58,17775.426,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29169,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4436,2021-07-01 21:03:02,17779.435,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4437,2021-07-01 21:03:06,17783.442,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    4438,2021-07-01 21:03:10,17787.450,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4172,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1037,SUCCESS
    4439,2021-07-01 21:03:14,17791.459,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4173,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1042,SUCCESS
    4440,2021-07-01 21:03:18,17795.465,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4173,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1036,SUCCESS
    4441,2021-07-01 21:03:22,17799.464,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29168,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4173,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1036,SUCCESS
    4442,2021-07-01 21:03:26,17803.476,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29167,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1043,SUCCESS
    4443,2021-07-01 21:03:30,17807.485,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29167,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1096,SUCCESS
    4444,2021-07-01 21:03:34,17811.491,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29167,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,995,SUCCESS
    4445,2021-07-01 21:03:38,17815.499,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29166,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1050,SUCCESS
    4446,2021-07-01 21:03:42,17819.502,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29167,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1014,SUCCESS
    4447,2021-07-01 21:03:46,17823.513,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29166,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1083,SUCCESS
    4448,2021-07-01 21:03:50,17827.528,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29166,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1006,SUCCESS
    4449,2021-07-01 21:03:54,17831.531,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29167,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1065,SUCCESS
    4450,2021-07-01 21:03:58,17835.541,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29166,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4165,4171,4171,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1028,SUCCESS
    4451,2021-07-01 21:04:02,17839.545,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29166,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    4452,2021-07-01 21:04:06,17843.551,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    4453,2021-07-01 21:04:10,17847.566,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29164,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    4454,2021-07-01 21:04:14,17851.577,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.6,1018,SUCCESS
    4455,2021-07-01 21:04:18,17855.586,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    4456,2021-07-01 21:04:22,17859.592,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    4457,2021-07-01 21:04:26,17863.595,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    4458,2021-07-01 21:04:30,17867.598,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    4459,2021-07-01 21:04:34,17871.599,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    4460,2021-07-01 21:04:38,17875.610,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1064,SUCCESS
    4461,2021-07-01 21:04:42,17879.612,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29164,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1092,SUCCESS
    4462,2021-07-01 21:04:46,17883.614,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29163,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4166,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4463,2021-07-01 21:04:50,17887.617,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4165,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    4464,2021-07-01 21:04:54,17891.631,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29162,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4165,4164,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,949,SUCCESS
    4465,2021-07-01 21:04:58,17895.643,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29164,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.0,973,SUCCESS
    4466,2021-07-01 21:05:02,17899.647,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29162,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    4467,2021-07-01 21:05:06,17903.650,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29165,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4166,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    4468,2021-07-01 21:05:10,17907.658,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29163,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.5,1051,SUCCESS
    4469,2021-07-01 21:05:14,17911.664,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29164,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4171,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,977,SUCCESS
    4470,2021-07-01 21:05:18,17915.679,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29162,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1041,SUCCESS
    4471,2021-07-01 21:05:22,17919.691,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29162,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1062,SUCCESS
    4472,2021-07-01 21:05:26,17923.690,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29163,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,983,SUCCESS
    4473,2021-07-01 21:05:30,17927.691,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29161,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1029,SUCCESS
    4474,2021-07-01 21:05:34,17931.701,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29163,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4164,4165,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1065,SUCCESS
    4475,2021-07-01 21:05:38,17935.712,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29161,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,978,SUCCESS
    4476,2021-07-01 21:05:42,17939.717,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29161,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1019,SUCCESS
    4477,2021-07-01 21:05:46,17943.724,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,966,SUCCESS
    4478,2021-07-01 21:05:50,17947.729,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1037,SUCCESS
    4479,2021-07-01 21:05:54,17951.741,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1010,SUCCESS
    4480,2021-07-01 21:05:58,17955.755,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29161,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4165,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4481,2021-07-01 21:06:02,17959.759,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x44A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    4482,2021-07-01 21:06:06,17963.768,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1093,SUCCESS
    4483,2021-07-01 21:06:10,17967.770,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    4484,2021-07-01 21:06:14,17971.780,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29159,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1096,SUCCESS
    4485,2021-07-01 21:06:18,17975.785,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1015,SUCCESS
    4486,2021-07-01 21:06:22,17979.793,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1101,SUCCESS
    4487,2021-07-01 21:06:26,17983.806,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1088,SUCCESS
    4488,2021-07-01 21:06:30,17987.816,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29159,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1059,SUCCESS
    4489,2021-07-01 21:06:34,17991.826,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1019,SUCCESS
    4490,2021-07-01 21:06:38,17995.833,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29159,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4170,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,996,SUCCESS
    4491,2021-07-01 21:06:42,17999.836,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.7,954,SUCCESS
    4492,2021-07-01 21:06:46,18003.838,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29159,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1009,SUCCESS
    4493,2021-07-01 21:06:50,18007.844,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29159,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1019,SUCCESS
    4494,2021-07-01 21:06:54,18011.852,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29160,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1025,SUCCESS
    4495,2021-07-01 21:06:58,18015.857,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29162,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1021,SUCCESS
    4496,2021-07-01 21:07:03,18019.871,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29164,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1083,SUCCESS
    4497,2021-07-01 21:07:07,18023.872,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29161,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1068,SUCCESS
    4498,2021-07-01 21:07:11,18027.885,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,961,SUCCESS
    4499,2021-07-01 21:07:15,18031.900,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4164,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1055,SUCCESS
    4500,2021-07-01 21:07:19,18035.906,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29157,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1019,SUCCESS
    4501,2021-07-01 21:07:23,18039.918,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,990,SUCCESS
    4502,2021-07-01 21:07:27,18043.926,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29156,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4163,4165,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1092,SUCCESS
    4503,2021-07-01 21:07:31,18047.938,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29157,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1065,SUCCESS
    4504,2021-07-01 21:07:35,18051.951,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29157,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4165,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1051,SUCCESS
    4505,2021-07-01 21:07:39,18055.956,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29158,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.8,1086,SUCCESS
    4506,2021-07-01 21:07:43,18059.965,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29157,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1053,SUCCESS
    4507,2021-07-01 21:07:47,18063.979,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29156,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4163,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1039,SUCCESS
    4508,2021-07-01 21:07:51,18067.983,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29157,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    4509,2021-07-01 21:07:55,18071.987,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4170,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    4510,2021-07-01 21:07:59,18075.999,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4511,2021-07-01 21:08:03,18080.011,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29156,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4512,2021-07-01 21:08:07,18084.017,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    4513,2021-07-01 21:08:11,18088.029,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    4514,2021-07-01 21:08:15,18092.039,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29156,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4163,4164,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,979,SUCCESS
    4515,2021-07-01 21:08:19,18096.052,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29154,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4164,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.6,1011,SUCCESS
    4516,2021-07-01 21:08:23,18100.065,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4164,4163,4168,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1155,SUCCESS
    4517,2021-07-01 21:08:27,18104.073,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29155,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4165,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1022,SUCCESS
    4518,2021-07-01 21:08:31,18108.087,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29153,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4164,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1025,SUCCESS
    4519,2021-07-01 21:08:35,18112.089,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4170,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,973,SUCCESS
    4520,2021-07-01 21:08:39,18116.100,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1027,SUCCESS
    4521,2021-07-01 21:08:43,18120.102,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4170,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1101,SUCCESS
    4522,2021-07-01 21:08:47,18124.106,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4170,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1020,SUCCESS
    4523,2021-07-01 21:08:51,18128.120,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4174,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.3,1060,SUCCESS
    4524,2021-07-01 21:08:55,18132.123,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    4525,2021-07-01 21:08:59,18136.137,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1070,SUCCESS
    4526,2021-07-01 21:09:03,18140.147,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,979,SUCCESS
    4527,2021-07-01 21:09:07,18144.148,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4169,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,977,SUCCESS
    4528,2021-07-01 21:09:11,18148.148,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.4,1032,SUCCESS
    4529,2021-07-01 21:09:15,18152.158,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1029,SUCCESS
    4530,2021-07-01 21:09:19,18156.170,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1082,SUCCESS
    4531,2021-07-01 21:09:23,18160.178,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1058,SUCCESS
    4532,2021-07-01 21:09:27,18164.181,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    4533,2021-07-01 21:09:31,18168.196,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    4534,2021-07-01 21:09:35,18172.200,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    4535,2021-07-01 21:09:39,18176.214,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    4536,2021-07-01 21:09:43,18180.227,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4537,2021-07-01 21:09:47,18184.235,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    4538,2021-07-01 21:09:51,18188.249,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29152,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    4539,2021-07-01 21:09:55,18192.250,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29150,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4162,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1127,SUCCESS
    4540,2021-07-01 21:09:59,18196.259,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29151,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,976,SUCCESS
    4541,2021-07-01 21:10:03,18200.260,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29151,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    4542,2021-07-01 21:10:07,18204.274,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29151,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.7,1028,SUCCESS
    4543,2021-07-01 21:10:11,18208.286,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29150,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4162,4163,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4544,2021-07-01 21:10:15,18212.290,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29150,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4164,4163,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    4545,2021-07-01 21:10:19,18216.292,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29148,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4164,4163,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1007,SUCCESS
    4546,2021-07-01 21:10:23,18220.292,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29148,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4164,4163,4163,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,976,SUCCESS
    4547,2021-07-01 21:10:27,18224.298,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29149,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4164,4163,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1096,SUCCESS
    4548,2021-07-01 21:10:31,18228.313,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29147,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1065,SUCCESS
    4549,2021-07-01 21:10:35,18232.327,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29148,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,954,SUCCESS
    4550,2021-07-01 21:10:39,18236.335,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29148,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    4551,2021-07-01 21:10:43,18240.337,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4169,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    4552,2021-07-01 21:10:47,18244.337,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    4553,2021-07-01 21:10:51,18248.347,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    4554,2021-07-01 21:10:55,18252.362,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    4555,2021-07-01 21:10:59,18256.377,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1082,SUCCESS
    4556,2021-07-01 21:11:03,18260.381,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,34.6,1091,SUCCESS
    4557,2021-07-01 21:11:07,18264.395,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1045,SUCCESS
    4558,2021-07-01 21:11:11,18268.395,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4168,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1029,SUCCESS
    4559,2021-07-01 21:11:15,18272.406,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1066,SUCCESS
    4560,2021-07-01 21:11:19,18276.417,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1035,SUCCESS
    4561,2021-07-01 21:11:23,18280.424,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1094,SUCCESS
    4562,2021-07-01 21:11:27,18284.429,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    4563,2021-07-01 21:11:31,18288.441,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    4564,2021-07-01 21:11:35,18292.447,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    4565,2021-07-01 21:11:39,18296.456,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.3,1145,SUCCESS
    4566,2021-07-01 21:11:43,18300.463,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1008,SUCCESS
    4567,2021-07-01 21:11:47,18304.476,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29144,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    4568,2021-07-01 21:11:51,18308.485,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29144,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1000,SUCCESS
    4569,2021-07-01 21:11:55,18312.491,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29145,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1059,SUCCESS
    4570,2021-07-01 21:11:59,18316.498,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29144,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1067,SUCCESS
    4571,2021-07-01 21:12:03,18320.513,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    4572,2021-07-01 21:12:07,18324.520,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29141,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    4573,2021-07-01 21:12:11,18328.521,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29141,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    4574,2021-07-01 21:12:15,18332.531,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1065,SUCCESS
    4575,2021-07-01 21:12:19,18336.533,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1030,SUCCESS
    4576,2021-07-01 21:12:23,18340.545,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4162,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1067,SUCCESS
    4577,2021-07-01 21:12:27,18344.558,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    4578,2021-07-01 21:12:31,18348.570,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29149,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4168,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1008,SUCCESS
    4579,2021-07-01 21:12:35,18352.581,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29146,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.3,1060,SUCCESS
    4580,2021-07-01 21:12:39,18356.583,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    4581,2021-07-01 21:12:43,18360.585,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29143,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,984,SUCCESS
    4582,2021-07-01 21:12:47,18364.587,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4163,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    4583,2021-07-01 21:12:51,18368.595,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1127,SUCCESS
    4584,2021-07-01 21:12:55,18372.598,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,966,SUCCESS
    4585,2021-07-01 21:12:59,18376.613,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,990,SUCCESS
    4586,2021-07-01 21:13:03,18380.623,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29141,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1081,SUCCESS
    4587,2021-07-01 21:13:07,18384.626,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29140,3,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    4588,2021-07-01 21:13:11,18388.627,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4168,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1124,SUCCESS
    4589,2021-07-01 21:13:15,18392.639,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29142,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    4590,2021-07-01 21:13:19,18396.653,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29141,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,957,SUCCESS
    4591,2021-07-01 21:13:23,18400.659,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29140,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4162,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1143,SUCCESS
    4592,2021-07-01 21:13:27,18404.673,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29141,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1065,SUCCESS
    4593,2021-07-01 21:13:31,18408.679,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1104,SUCCESS
    4594,2021-07-01 21:13:35,18412.686,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29140,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1097,SUCCESS
    4595,2021-07-01 21:13:39,18416.691,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29140,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1108,SUCCESS
    4596,2021-07-01 21:13:43,18420.705,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4597,2021-07-01 21:13:47,18424.712,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4162,4161,4167,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1071,SUCCESS
    4598,2021-07-01 21:13:51,18428.713,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29140,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4161,4161,4162,4162,4161,4166,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4599,2021-07-01 21:13:55,18432.727,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4165,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4600,2021-07-01 21:13:59,18436.728,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4165,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    4601,2021-07-01 21:14:03,18440.730,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29140,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4163,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.2,1051,SUCCESS
    4602,2021-07-01 21:14:07,18444.744,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4162,4164,4167,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.0,1046,SUCCESS
    4603,2021-07-01 21:14:11,18448.752,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.2,-273.2,26.2,-273.2,35.1,1143,SUCCESS
    4604,2021-07-01 21:14:15,18452.766,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.2,-273.2,35.2,1064,SUCCESS
    4605,2021-07-01 21:14:19,18456.768,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1095,SUCCESS
    4606,2021-07-01 21:14:23,18460.773,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,964,SUCCESS
    4607,2021-07-01 21:14:27,18464.778,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29139,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4171,4167,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.8,1044,SUCCESS
    4608,2021-07-01 21:14:31,18468.782,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4172,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    4609,2021-07-01 21:14:35,18472.783,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1078,SUCCESS
    4610,2021-07-01 21:14:39,18476.793,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1055,SUCCESS
    4611,2021-07-01 21:14:43,18480.796,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    4612,2021-07-01 21:14:47,18484.805,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.0,1056,SUCCESS
    4613,2021-07-01 21:14:51,18488.818,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    4614,2021-07-01 21:14:55,18492.820,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1024,SUCCESS
    4615,2021-07-01 21:14:59,18496.830,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    4616,2021-07-01 21:15:03,18500.835,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4617,2021-07-01 21:15:07,18504.845,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    4618,2021-07-01 21:15:11,18508.856,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    4619,2021-07-01 21:15:16,18512.871,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4167,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4620,2021-07-01 21:15:20,18516.879,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1120,SUCCESS
    4621,2021-07-01 21:15:24,18520.892,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.8,1024,SUCCESS
    4622,2021-07-01 21:15:28,18524.907,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29138,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4161,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1111,SUCCESS
    4623,2021-07-01 21:15:32,18528.913,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,996,SUCCESS
    4624,2021-07-01 21:15:36,18532.927,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29137,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1075,SUCCESS
    4625,2021-07-01 21:15:40,18536.932,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29135,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    4626,2021-07-01 21:15:44,18540.936,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1081,SUCCESS
    4627,2021-07-01 21:15:48,18544.947,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4161,4161,4161,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    4628,2021-07-01 21:15:52,18548.949,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4161,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1003,SUCCESS
    4629,2021-07-01 21:15:56,18552.956,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4161,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1016,SUCCESS
    4630,2021-07-01 21:16:00,18556.970,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29135,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4162,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    4631,2021-07-01 21:16:04,18560.984,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29135,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4161,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    4632,2021-07-01 21:16:08,18564.985,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29134,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4160,4161,4161,4160,4167,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,998,SUCCESS
    4633,2021-07-01 21:16:12,18568.995,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29134,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1071,SUCCESS
    4634,2021-07-01 21:16:16,18573.001,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29134,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4161,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1065,SUCCESS
    4635,2021-07-01 21:16:20,18577.011,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4161,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    4636,2021-07-01 21:16:24,18581.026,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29134,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4160,4161,4161,4160,4166,4166,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    4637,2021-07-01 21:16:28,18585.041,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29134,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4160,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1008,SUCCESS
    4638,2021-07-01 21:16:32,18589.042,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    4639,2021-07-01 21:16:36,18593.049,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1124,SUCCESS
    4640,2021-07-01 21:16:40,18597.051,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1000,SUCCESS
    4641,2021-07-01 21:16:44,18601.066,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4642,2021-07-01 21:16:48,18605.073,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,960,SUCCESS
    4643,2021-07-01 21:16:52,18609.079,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    4644,2021-07-01 21:16:56,18613.090,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    4645,2021-07-01 21:17:00,18617.096,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3216,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    4646,2021-07-01 21:17:04,18621.111,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4161,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    4647,2021-07-01 21:17:08,18625.118,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    4648,2021-07-01 21:17:12,18629.131,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    4649,2021-07-01 21:17:16,18633.138,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,34.9,1012,SUCCESS
    4650,2021-07-01 21:17:20,18637.144,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    4651,2021-07-01 21:17:24,18641.159,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3219,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    4652,2021-07-01 21:17:28,18645.163,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.2,1089,SUCCESS
    4653,2021-07-01 21:17:32,18649.171,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29132,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    4654,2021-07-01 21:17:36,18653.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.0,1053,SUCCESS
    4655,2021-07-01 21:17:40,18657.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    4656,2021-07-01 21:17:44,18661.199,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29129,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3220,26.2,26.3,-273.2,26.3,-273.2,35.1,1101,SUCCESS
    4657,2021-07-01 21:17:48,18665.212,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29129,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3219,26.2,26.3,-273.2,26.3,-273.2,35.1,1072,SUCCESS
    4658,2021-07-01 21:17:52,18669.223,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29129,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3216,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    4659,2021-07-01 21:17:56,18673.224,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29126,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    4660,2021-07-01 21:18:00,18677.230,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29129,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4159,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3216,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    4661,2021-07-01 21:18:04,18681.241,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    4662,2021-07-01 21:18:08,18685.247,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    4663,2021-07-01 21:18:12,18689.253,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29133,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    4664,2021-07-01 21:18:16,18693.264,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29136,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    4665,2021-07-01 21:18:20,18697.267,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29131,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4159,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    4666,2021-07-01 21:18:24,18701.280,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29130,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4160,4161,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4667,2021-07-01 21:18:28,18705.286,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29130,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4159,4161,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.2,-273.2,26.2,-273.2,35.1,981,SUCCESS
    4668,2021-07-01 21:18:32,18709.297,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29127,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    4669,2021-07-01 21:18:36,18713.304,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29128,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4159,4159,4160,4160,4159,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    4670,2021-07-01 21:18:40,18717.316,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29128,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4161,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4671,2021-07-01 21:18:44,18721.330,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29128,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4161,4160,4160,4166,4165,0,0,0,0,0,0,0,0,3216,26.2,26.3,-273.2,26.3,-273.2,35.1,983,SUCCESS
    4672,2021-07-01 21:18:48,18725.331,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29128,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4161,4159,4160,4166,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.5,1053,SUCCESS
    4673,2021-07-01 21:18:52,18729.332,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29126,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4160,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,983,SUCCESS
    4674,2021-07-01 21:18:56,18733.333,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29127,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4160,4159,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1073,SUCCESS
    4675,2021-07-01 21:19:00,18737.336,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    4676,2021-07-01 21:19:04,18741.352,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29126,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,963,SUCCESS
    4677,2021-07-01 21:19:08,18745.353,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29126,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4678,2021-07-01 21:19:12,18749.359,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29126,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    4679,2021-07-01 21:19:16,18753.364,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29125,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4160,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    4680,2021-07-01 21:19:20,18757.378,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29125,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4681,2021-07-01 21:19:24,18761.379,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1092,SUCCESS
    4682,2021-07-01 21:19:28,18765.389,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1111,SUCCESS
    4683,2021-07-01 21:19:32,18769.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1014,SUCCESS
    4684,2021-07-01 21:19:36,18773.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4685,2021-07-01 21:19:40,18777.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4161,4165,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    4686,2021-07-01 21:19:44,18781.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29125,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4160,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1093,SUCCESS
    4687,2021-07-01 21:19:48,18785.400,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,959,SUCCESS
    4688,2021-07-01 21:19:52,18789.410,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4167,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    4689,2021-07-01 21:19:56,18793.411,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4168,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4690,2021-07-01 21:20:00,18797.424,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1141,SUCCESS
    4691,2021-07-01 21:20:04,18801.426,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1077,SUCCESS
    4692,2021-07-01 21:20:08,18805.429,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1089,SUCCESS
    4693,2021-07-01 21:20:12,18809.438,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4694,2021-07-01 21:20:16,18813.450,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,973,SUCCESS
    4695,2021-07-01 21:20:20,18817.459,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.4,989,SUCCESS
    4696,2021-07-01 21:20:24,18821.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29123,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1035,SUCCESS
    4697,2021-07-01 21:20:28,18825.476,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29123,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4698,2021-07-01 21:20:32,18829.483,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    4699,2021-07-01 21:20:36,18833.485,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    4700,2021-07-01 21:20:40,18837.500,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29124,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4159,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    4701,2021-07-01 21:20:44,18841.507,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    4702,2021-07-01 21:20:48,18845.506,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4158,4160,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,997,SUCCESS
    4703,2021-07-01 21:20:52,18849.515,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29120,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1081,SUCCESS
    4704,2021-07-01 21:20:56,18853.522,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,996,SUCCESS
    4705,2021-07-01 21:21:00,18857.537,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29121,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4159,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1090,SUCCESS
    4706,2021-07-01 21:21:04,18861.539,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1039,SUCCESS
    4707,2021-07-01 21:21:08,18865.548,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29121,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4160,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1095,SUCCESS
    4708,2021-07-01 21:21:12,18869.550,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4159,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    4709,2021-07-01 21:21:16,18873.553,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29121,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4159,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    4710,2021-07-01 21:21:20,18877.569,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29121,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4159,4159,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1091,SUCCESS
    4711,2021-07-01 21:21:24,18881.571,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29121,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4158,4159,4159,4159,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    4712,2021-07-01 21:21:28,18885.586,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4165,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    4713,2021-07-01 21:21:32,18889.589,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29122,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4158,4158,4159,4159,4159,4165,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    4714,2021-07-01 21:21:36,18893.600,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    4715,2021-07-01 21:21:40,18897.615,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29120,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    4716,2021-07-01 21:21:44,18901.615,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1058,SUCCESS
    4717,2021-07-01 21:21:48,18905.626,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29120,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    4718,2021-07-01 21:21:52,18909.638,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.0,1010,SUCCESS
    4719,2021-07-01 21:21:56,18913.642,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1017,SUCCESS
    4720,2021-07-01 21:22:00,18917.644,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29120,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    4721,2021-07-01 21:22:04,18921.659,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    4722,2021-07-01 21:22:08,18925.663,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,979,SUCCESS
    4723,2021-07-01 21:22:12,18929.674,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4164,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    4724,2021-07-01 21:22:16,18933.675,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,998,SUCCESS
    4725,2021-07-01 21:22:20,18937.687,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29119,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4159,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    4726,2021-07-01 21:22:24,18941.689,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    4727,2021-07-01 21:22:28,18945.702,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.6,1072,SUCCESS
    4728,2021-07-01 21:22:32,18949.706,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1091,SUCCESS
    4729,2021-07-01 21:22:36,18953.708,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    4730,2021-07-01 21:22:40,18957.709,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    4731,2021-07-01 21:22:44,18961.717,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    4732,2021-07-01 21:22:48,18965.732,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    4733,2021-07-01 21:22:52,18969.739,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,982,SUCCESS
    4734,2021-07-01 21:22:56,18973.752,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29118,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1000,SUCCESS
    4735,2021-07-01 21:23:00,18977.759,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,944,SUCCESS
    4736,2021-07-01 21:23:04,18981.760,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4737,2021-07-01 21:23:08,18985.773,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29114,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    4738,2021-07-01 21:23:12,18989.773,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    4739,2021-07-01 21:23:16,18993.773,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1089,SUCCESS
    4740,2021-07-01 21:23:20,18997.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    4741,2021-07-01 21:23:24,19001.794,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    4742,2021-07-01 21:23:28,19005.803,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    4743,2021-07-01 21:23:32,19009.805,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    4744,2021-07-01 21:23:36,19013.816,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29117,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4745,2021-07-01 21:23:40,19017.831,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4746,2021-07-01 21:23:44,19021.838,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,946,SUCCESS
    4747,2021-07-01 21:23:48,19025.849,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,981,SUCCESS
    4748,2021-07-01 21:23:52,19029.862,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    4749,2021-07-01 21:23:57,19033.876,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    4750,2021-07-01 21:24:01,19037.892,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29116,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.7,1090,SUCCESS
    4751,2021-07-01 21:24:05,19041.904,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29113,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4157,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,971,SUCCESS
    4752,2021-07-01 21:24:09,19045.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29113,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4157,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4753,2021-07-01 21:24:13,19049.913,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29114,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,950,SUCCESS
    4754,2021-07-01 21:24:17,19053.926,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,996,SUCCESS
    4755,2021-07-01 21:24:21,19057.940,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29114,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4159,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1078,SUCCESS
    4756,2021-07-01 21:24:25,19061.950,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    4757,2021-07-01 21:24:29,19065.964,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29115,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    4758,2021-07-01 21:24:33,19069.967,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29113,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    4759,2021-07-01 21:24:37,19073.969,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29114,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4158,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.3,1118,SUCCESS
    4760,2021-07-01 21:24:41,19077.977,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    4761,2021-07-01 21:24:45,19081.989,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29113,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    4762,2021-07-01 21:24:49,19086.000,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1077,SUCCESS
    4763,2021-07-01 21:24:53,19090.001,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4764,2021-07-01 21:24:57,19094.015,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4160,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    4765,2021-07-01 21:25:01,19098.029,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4158,4164,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    4766,2021-07-01 21:25:05,19102.039,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4767,2021-07-01 21:25:09,19106.054,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4158,4158,4158,4157,4164,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    4768,2021-07-01 21:25:13,19110.056,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4157,4158,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    4769,2021-07-01 21:25:17,19114.062,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.2,-273.2,26.2,-273.2,35.1,1050,SUCCESS
    4770,2021-07-01 21:25:21,19118.075,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    4771,2021-07-01 21:25:25,19122.078,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    4772,2021-07-01 21:25:29,19126.086,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    4773,2021-07-01 21:25:33,19130.100,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    4774,2021-07-01 21:25:37,19134.110,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29112,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4163,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    4775,2021-07-01 21:25:41,19138.122,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    4776,2021-07-01 21:25:45,19142.123,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,941,SUCCESS
    4777,2021-07-01 21:25:49,19146.127,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4778,2021-07-01 21:25:53,19150.137,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    4779,2021-07-01 21:25:57,19154.141,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    4780,2021-07-01 21:26:01,19158.150,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    4781,2021-07-01 21:26:05,19162.152,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    4782,2021-07-01 21:26:09,19166.152,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.5,1029,SUCCESS
    4783,2021-07-01 21:26:13,19170.153,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    4784,2021-07-01 21:26:17,19174.160,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    4785,2021-07-01 21:26:21,19178.162,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29111,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4158,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    4786,2021-07-01 21:26:25,19182.169,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29109,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    4787,2021-07-01 21:26:29,19186.177,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1075,SUCCESS
    4788,2021-07-01 21:26:33,19190.182,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29109,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,961,SUCCESS
    4789,2021-07-01 21:26:37,19194.202,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29109,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4156,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    4790,2021-07-01 21:26:41,19198.215,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29109,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1083,SUCCESS
    4791,2021-07-01 21:26:45,19202.223,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29110,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,951,SUCCESS
    4792,2021-07-01 21:26:49,19206.235,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29108,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    4793,2021-07-01 21:26:53,19210.245,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29107,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1037,SUCCESS
    4794,2021-07-01 21:26:57,19214.250,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29107,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4158,4157,4157,4163,4162,0,0,0,0,0,0,0,0,3215,26.2,26.2,-273.2,26.2,-273.2,35.2,1080,SUCCESS
    4795,2021-07-01 21:27:01,19218.252,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29108,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4156,4157,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.2,-273.2,26.2,-273.2,35.1,1079,SUCCESS
    4796,2021-07-01 21:27:05,19222.256,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29108,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    4797,2021-07-01 21:27:09,19226.260,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    4798,2021-07-01 21:27:13,19230.268,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1015,SUCCESS
    4799,2021-07-01 21:27:17,19234.281,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29107,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4158,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1017,SUCCESS
    4800,2021-07-01 21:27:21,19238.287,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29107,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    4801,2021-07-01 21:27:25,19242.291,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29105,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    4802,2021-07-01 21:27:29,19246.296,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    4803,2021-07-01 21:27:33,19250.301,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,996,SUCCESS
    4804,2021-07-01 21:27:37,19254.313,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29105,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4157,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    4805,2021-07-01 21:27:41,19258.317,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29105,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1059,SUCCESS
    4806,2021-07-01 21:27:45,19262.329,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    4807,2021-07-01 21:27:49,19266.344,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29106,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4157,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    4808,2021-07-01 21:27:53,19270.355,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29105,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    4809,2021-07-01 21:27:57,19274.362,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    4810,2021-07-01 21:28:01,19278.378,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29103,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4157,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4811,2021-07-01 21:28:05,19282.378,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4157,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1172,SUCCESS
    4812,2021-07-01 21:28:09,19286.389,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4157,4162,4162,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1098,SUCCESS
    4813,2021-07-01 21:28:13,19290.402,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1022,SUCCESS
    4814,2021-07-01 21:28:17,19294.405,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.0,1042,SUCCESS
    4815,2021-07-01 21:28:21,19298.406,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29099,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    4816,2021-07-01 21:28:25,19302.422,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29105,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    4817,2021-07-01 21:28:29,19306.421,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,956,SUCCESS
    4818,2021-07-01 21:28:33,19310.431,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    4819,2021-07-01 21:28:37,19314.438,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    4820,2021-07-01 21:28:41,19318.451,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29104,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    4821,2021-07-01 21:28:45,19322.461,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29103,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,961,SUCCESS
    4822,2021-07-01 21:28:49,19326.470,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    4823,2021-07-01 21:28:53,19330.473,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4824,2021-07-01 21:28:57,19334.479,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.6,1077,SUCCESS
    4825,2021-07-01 21:29:01,19338.489,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1058,SUCCESS
    4826,2021-07-01 21:29:05,19342.503,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4157,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    4827,2021-07-01 21:29:09,19346.518,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1046,SUCCESS
    4828,2021-07-01 21:29:13,19350.523,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    4829,2021-07-01 21:29:17,19354.535,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    4830,2021-07-01 21:29:21,19358.550,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    4831,2021-07-01 21:29:25,19362.565,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29099,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    4832,2021-07-01 21:29:29,19366.577,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    4833,2021-07-01 21:29:33,19370.581,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4155,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    4834,2021-07-01 21:29:37,19374.583,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    4835,2021-07-01 21:29:41,19378.596,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    4836,2021-07-01 21:29:45,19382.609,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4155,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    4837,2021-07-01 21:29:49,19386.616,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4160,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1072,SUCCESS
    4838,2021-07-01 21:29:53,19390.628,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4839,2021-07-01 21:29:57,19394.634,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4155,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4840,2021-07-01 21:30:01,19398.643,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    4841,2021-07-01 21:30:05,19402.654,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29102,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4156,4156,4156,4156,4157,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    4842,2021-07-01 21:30:09,19406.669,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29101,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4162,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    4843,2021-07-01 21:30:13,19410.675,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4156,4156,4156,4156,4163,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    4844,2021-07-01 21:30:17,19414.690,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29099,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4163,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    4845,2021-07-01 21:30:21,19418.692,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4156,4156,4156,4155,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1091,SUCCESS
    4846,2021-07-01 21:30:25,19422.705,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29100,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4156,4156,4156,4156,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.6,1078,SUCCESS
    4847,2021-07-01 21:30:29,19426.711,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,992,SUCCESS
    4848,2021-07-01 21:30:33,19430.723,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    4849,2021-07-01 21:30:37,19434.732,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1146,SUCCESS
    4850,2021-07-01 21:30:41,19438.737,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4156,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    4851,2021-07-01 21:30:45,19442.747,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4160,4161,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,973,SUCCESS
    4852,2021-07-01 21:30:49,19446.762,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29096,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4155,4155,4156,4156,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1085,SUCCESS
    4853,2021-07-01 21:30:53,19450.763,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    4854,2021-07-01 21:30:57,19454.769,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29098,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1024,SUCCESS
    4855,2021-07-01 21:31:01,19458.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4856,2021-07-01 21:31:05,19462.799,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,981,SUCCESS
    4857,2021-07-01 21:31:09,19466.799,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    4858,2021-07-01 21:31:13,19470.809,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1115,SUCCESS
    4859,2021-07-01 21:31:17,19474.810,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29096,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1066,SUCCESS
    4860,2021-07-01 21:31:21,19478.821,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    4861,2021-07-01 21:31:25,19482.823,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    4862,2021-07-01 21:31:29,19486.831,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1044,SUCCESS
    4863,2021-07-01 21:31:33,19490.842,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29097,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4864,2021-07-01 21:31:37,19494.853,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    4865,2021-07-01 21:31:41,19498.866,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29096,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4866,2021-07-01 21:31:46,19502.876,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4867,2021-07-01 21:31:50,19506.887,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29096,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4156,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,957,SUCCESS
    4868,2021-07-01 21:31:54,19510.892,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29096,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    4869,2021-07-01 21:31:58,19514.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,986,SUCCESS
    4870,2021-07-01 21:32:02,19518.920,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    4871,2021-07-01 21:32:06,19522.931,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    4872,2021-07-01 21:32:10,19526.946,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,978,SUCCESS
    4873,2021-07-01 21:32:14,19530.956,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4161,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    4874,2021-07-01 21:32:18,19534.961,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,947,SUCCESS
    4875,2021-07-01 21:32:22,19538.972,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1092,SUCCESS
    4876,2021-07-01 21:32:26,19542.984,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    4877,2021-07-01 21:32:30,19546.988,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    4878,2021-07-01 21:32:34,19550.997,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4154,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.6,989,SUCCESS
    4879,2021-07-01 21:32:38,19555.002,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1099,SUCCESS
    4880,2021-07-01 21:32:42,19559.003,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29095,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1075,SUCCESS
    4881,2021-07-01 21:32:46,19563.005,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29093,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    4882,2021-07-01 21:32:50,19567.005,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29094,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4156,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1090,SUCCESS
    4883,2021-07-01 21:32:54,19571.016,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29094,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4884,2021-07-01 21:32:58,19575.019,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1059,SUCCESS
    4885,2021-07-01 21:33:02,19579.027,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29094,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1038,SUCCESS
    4886,2021-07-01 21:33:06,19583.028,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29094,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4156,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1005,SUCCESS
    4887,2021-07-01 21:33:10,19587.041,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29093,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1070,SUCCESS
    4888,2021-07-01 21:33:14,19591.053,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4889,2021-07-01 21:33:18,19595.058,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    4890,2021-07-01 21:33:22,19599.070,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29093,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    4891,2021-07-01 21:33:26,19603.070,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    4892,2021-07-01 21:33:30,19607.081,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,34.8,1069,SUCCESS
    4893,2021-07-01 21:33:34,19611.094,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4155,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    4894,2021-07-01 21:33:38,19615.100,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    4895,2021-07-01 21:33:42,19619.115,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1042,SUCCESS
    4896,2021-07-01 21:33:46,19623.117,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,979,SUCCESS
    4897,2021-07-01 21:33:50,19627.117,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    4898,2021-07-01 21:33:54,19631.131,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1012,SUCCESS
    4899,2021-07-01 21:33:58,19635.137,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29092,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    4900,2021-07-01 21:34:02,19639.147,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    4901,2021-07-01 21:34:06,19643.156,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4161,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,955,SUCCESS
    4902,2021-07-01 21:34:10,19647.170,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29091,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4155,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    4903,2021-07-01 21:34:14,19651.181,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    4904,2021-07-01 21:34:18,19655.190,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1109,SUCCESS
    4905,2021-07-01 21:34:22,19659.199,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1038,SUCCESS
    4906,2021-07-01 21:34:26,19663.213,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1064,SUCCESS
    4907,2021-07-01 21:34:30,19667.229,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    4908,2021-07-01 21:34:34,19671.234,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    4909,2021-07-01 21:34:38,19675.245,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    4910,2021-07-01 21:34:42,19679.251,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    4911,2021-07-01 21:34:46,19683.258,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1024,SUCCESS
    4912,2021-07-01 21:34:50,19687.259,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4155,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    4913,2021-07-01 21:34:54,19691.259,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    4914,2021-07-01 21:34:58,19695.273,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    4915,2021-07-01 21:35:02,19699.277,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29090,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4160,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    4916,2021-07-01 21:35:06,19703.282,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.0,1007,SUCCESS
    4917,2021-07-01 21:35:10,19707.288,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4160,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    4918,2021-07-01 21:35:14,19711.299,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4158,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4919,2021-07-01 21:35:18,19715.306,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4157,4159,0,0,0,0,0,0,0,0,3211,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    4920,2021-07-01 21:35:22,19719.308,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29089,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    4921,2021-07-01 21:35:26,19723.315,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,953,SUCCESS
    4922,2021-07-01 21:35:30,19727.325,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4155,4158,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1115,SUCCESS
    4923,2021-07-01 21:35:34,19731.336,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    4924,2021-07-01 21:35:38,19735.339,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29087,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,944,SUCCESS
    4925,2021-07-01 21:35:42,19739.341,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29087,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,989,SUCCESS
    4926,2021-07-01 21:35:46,19743.342,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    4927,2021-07-01 21:35:50,19747.350,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    4928,2021-07-01 21:35:54,19751.363,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29088,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4153,4154,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3214,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    4929,2021-07-01 21:35:58,19755.375,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29085,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4153,4154,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    4930,2021-07-01 21:36:02,19759.383,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29086,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,946,SUCCESS
    4931,2021-07-01 21:36:06,19763.395,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29086,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    4932,2021-07-01 21:36:10,19767.396,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29085,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4153,4154,4155,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4933,2021-07-01 21:36:14,19771.404,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29086,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3214,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    4934,2021-07-01 21:36:18,19775.416,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29087,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4159,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    4935,2021-07-01 21:36:22,19779.431,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3214,26.2,26.3,-273.2,26.3,-273.2,35.1,1087,SUCCESS
    4936,2021-07-01 21:36:26,19783.440,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4155,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3214,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    4937,2021-07-01 21:36:30,19787.445,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    4938,2021-07-01 21:36:34,19791.455,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29085,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    4939,2021-07-01 21:36:38,19795.464,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29083,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3211,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    4940,2021-07-01 21:36:42,19799.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3211,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    4941,2021-07-01 21:36:46,19803.483,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3211,26.2,26.3,-273.2,26.3,-273.2,35.2,973,SUCCESS
    4942,2021-07-01 21:36:50,19807.492,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29084,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4159,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    4943,2021-07-01 21:36:54,19811.506,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29083,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4158,4158,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.1,948,SUCCESS
    4944,2021-07-01 21:36:58,19815.507,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4154,4158,4158,0,0,0,0,0,0,0,0,3211,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    4945,2021-07-01 21:37:02,19819.520,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4946,2021-07-01 21:37:06,19823.532,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29083,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4154,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,969,SUCCESS
    4947,2021-07-01 21:37:10,19827.540,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29083,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4159,4158,0,0,0,0,0,0,0,0,3215,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    4948,2021-07-01 21:37:14,19831.553,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4154,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1104,SUCCESS
    4949,2021-07-01 21:37:18,19835.559,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4154,4159,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    4950,2021-07-01 21:37:22,19839.565,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,983,SUCCESS
    4951,2021-07-01 21:37:26,19843.578,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4159,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    4952,2021-07-01 21:37:30,19847.589,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4154,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1007,SUCCESS
    4953,2021-07-01 21:37:34,19851.601,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.2,-273.2,26.2,-273.2,35.1,1026,SUCCESS
    4954,2021-07-01 21:37:38,19855.611,0x0541,150,10,0x6001,0,65535,65535,1,26.2,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4955,2021-07-01 21:37:42,19859.623,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.0,1114,SUCCESS
    4956,2021-07-01 21:37:46,19863.627,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1097,SUCCESS
    4957,2021-07-01 21:37:50,19867.640,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    4958,2021-07-01 21:37:54,19871.643,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1000,SUCCESS
    4959,2021-07-01 21:37:58,19875.658,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    4960,2021-07-01 21:38:02,19879.666,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4154,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,962,SUCCESS
    4961,2021-07-01 21:38:06,19883.674,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    4962,2021-07-01 21:38:10,19887.679,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1090,SUCCESS
    4963,2021-07-01 21:38:14,19891.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    4964,2021-07-01 21:38:18,19895.691,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    4965,2021-07-01 21:38:22,19899.695,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    4966,2021-07-01 21:38:26,19903.706,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    4967,2021-07-01 21:38:30,19907.715,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    4968,2021-07-01 21:38:34,19911.727,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29078,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    4969,2021-07-01 21:38:38,19915.742,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    4970,2021-07-01 21:38:42,19919.743,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1104,SUCCESS
    4971,2021-07-01 21:38:46,19923.753,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4154,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4972,2021-07-01 21:38:50,19927.754,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4159,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1095,SUCCESS
    4973,2021-07-01 21:38:54,19931.760,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1074,SUCCESS
    4974,2021-07-01 21:38:58,19935.768,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    4975,2021-07-01 21:39:02,19939.775,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1055,SUCCESS
    4976,2021-07-01 21:39:06,19943.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29082,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1093,SUCCESS
    4977,2021-07-01 21:39:10,19947.791,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29081,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    4978,2021-07-01 21:39:14,19951.799,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1110,SUCCESS
    4979,2021-07-01 21:39:18,19955.807,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29078,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,943,SUCCESS
    4980,2021-07-01 21:39:22,19959.819,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1088,SUCCESS
    4981,2021-07-01 21:39:26,19963.829,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29079,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1096,SUCCESS
    4982,2021-07-01 21:39:30,19967.836,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29080,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    4983,2021-07-01 21:39:34,19971.842,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29078,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4153,4153,4153,4153,4157,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    4984,2021-07-01 21:39:38,19975.850,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29078,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4153,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    4985,2021-07-01 21:39:42,19979.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29079,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4153,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,961,SUCCESS
    4986,2021-07-01 21:39:47,19983.869,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29077,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4158,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    4987,2021-07-01 21:39:51,19987.870,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4152,4158,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    4988,2021-07-01 21:39:55,19991.875,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4152,4158,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    4989,2021-07-01 21:39:59,19995.881,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    4990,2021-07-01 21:40:03,19999.898,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4158,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1057,SUCCESS
    4991,2021-07-01 21:40:07,20003.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    4992,2021-07-01 21:40:11,20007.911,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,950,SUCCESS
    4993,2021-07-01 21:40:15,20011.924,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4152,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    4994,2021-07-01 21:40:19,20015.932,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.0,962,SUCCESS
    4995,2021-07-01 21:40:23,20019.945,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4157,4158,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    4996,2021-07-01 21:40:27,20023.956,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    4997,2021-07-01 21:40:31,20027.969,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4156,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    4998,2021-07-01 21:40:35,20031.979,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1006,SUCCESS
    4999,2021-07-01 21:40:39,20035.990,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29076,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1012,SUCCESS
    5000,2021-07-01 21:40:43,20040.000,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4153,4153,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1110,SUCCESS
    5001,2021-07-01 21:40:47,20044.009,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    5002,2021-07-01 21:40:51,20048.023,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4153,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    5003,2021-07-01 21:40:55,20052.023,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,947,SUCCESS
    5004,2021-07-01 21:40:59,20056.028,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4161,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    5005,2021-07-01 21:41:03,20060.036,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1014,SUCCESS
    5006,2021-07-01 21:41:07,20064.037,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,995,SUCCESS
    5007,2021-07-01 21:41:11,20068.044,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    5008,2021-07-01 21:41:15,20072.057,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    5009,2021-07-01 21:41:19,20076.072,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1025,SUCCESS
    5010,2021-07-01 21:41:23,20080.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29075,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    5011,2021-07-01 21:41:27,20084.085,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,980,SUCCESS
    5012,2021-07-01 21:41:31,20088.095,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1096,SUCCESS
    5013,2021-07-01 21:41:35,20092.102,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    5014,2021-07-01 21:41:39,20096.115,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1200,SUCCESS
    5015,2021-07-01 21:41:43,20100.119,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1086,SUCCESS
    5016,2021-07-01 21:41:47,20104.121,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29074,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4152,4152,4152,4157,4157,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1070,SUCCESS
    5017,2021-07-01 21:41:51,20108.127,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    5018,2021-07-01 21:41:55,20112.137,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1006,SUCCESS
    5019,2021-07-01 21:41:59,20116.148,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.8,1049,SUCCESS
    5020,2021-07-01 21:42:03,20120.162,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5021,2021-07-01 21:42:07,20124.177,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    5022,2021-07-01 21:42:11,20128.191,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1107,SUCCESS
    5023,2021-07-01 21:42:15,20132.196,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    5024,2021-07-01 21:42:19,20136.211,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1088,SUCCESS
    5025,2021-07-01 21:42:23,20140.223,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1123,SUCCESS
    5026,2021-07-01 21:42:27,20144.226,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29072,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5027,2021-07-01 21:42:31,20148.256,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29071,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4153,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    5028,2021-07-01 21:42:35,20152.270,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29071,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4151,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.4,1036,SUCCESS
    5029,2021-07-01 21:42:39,20156.281,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29072,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1065,SUCCESS
    5030,2021-07-01 21:42:43,20160.290,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29073,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    5031,2021-07-01 21:42:47,20164.295,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29071,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    5032,2021-07-01 21:42:51,20168.295,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29071,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    5033,2021-07-01 21:42:55,20172.310,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29071,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1035,SUCCESS
    5034,2021-07-01 21:42:59,20176.323,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    5035,2021-07-01 21:43:03,20180.337,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1008,SUCCESS
    5036,2021-07-01 21:43:07,20184.342,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4152,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1113,SUCCESS
    5037,2021-07-01 21:43:11,20188.346,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4152,4152,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.9,1132,SUCCESS
    5038,2021-07-01 21:43:15,20192.361,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29070,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    5039,2021-07-01 21:43:19,20196.373,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4152,4151,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    5040,2021-07-01 21:43:23,20200.379,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    5041,2021-07-01 21:43:27,20204.380,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29070,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4152,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    5042,2021-07-01 21:43:31,20208.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4152,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1046,SUCCESS
    5043,2021-07-01 21:43:35,20212.402,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29070,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1069,SUCCESS
    5044,2021-07-01 21:43:39,20216.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4152,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1124,SUCCESS
    5045,2021-07-01 21:43:43,20220.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4152,4152,4152,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5046,2021-07-01 21:43:47,20224.411,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5047,2021-07-01 21:43:51,20228.410,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,964,SUCCESS
    5048,2021-07-01 21:43:55,20232.424,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,969,SUCCESS
    5049,2021-07-01 21:43:59,20236.427,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29066,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5050,2021-07-01 21:44:03,20240.435,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29065,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,987,SUCCESS
    5051,2021-07-01 21:44:07,20244.439,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29063,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,985,SUCCESS
    5052,2021-07-01 21:44:11,20248.443,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4157,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,951,SUCCESS
    5053,2021-07-01 21:44:15,20252.454,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29068,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5054,2021-07-01 21:44:19,20256.465,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29069,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1069,SUCCESS
    5055,2021-07-01 21:44:23,20260.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    5056,2021-07-01 21:44:27,20264.479,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    5057,2021-07-01 21:44:31,20268.490,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5058,2021-07-01 21:44:35,20272.501,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    5059,2021-07-01 21:44:39,20276.508,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    5060,2021-07-01 21:44:43,20280.522,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.0,1015,SUCCESS
    5061,2021-07-01 21:44:47,20284.523,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29066,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4155,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    5062,2021-07-01 21:44:51,20288.535,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29066,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4155,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1030,SUCCESS
    5063,2021-07-01 21:44:55,20292.537,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    5064,2021-07-01 21:44:59,20296.551,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,982,SUCCESS
    5065,2021-07-01 21:45:03,20300.558,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    5066,2021-07-01 21:45:07,20304.571,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4156,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    5067,2021-07-01 21:45:11,20308.586,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29066,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4152,4151,4151,4156,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5068,2021-07-01 21:45:15,20312.591,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1100,SUCCESS
    5069,2021-07-01 21:45:19,20316.595,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29067,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4152,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1158,SUCCESS
    5070,2021-07-01 21:45:23,20320.609,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29066,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4151,4151,4151,4156,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    5071,2021-07-01 21:45:27,20324.620,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29062,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4151,4152,4151,4151,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    5072,2021-07-01 21:45:31,20328.629,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4152,4151,4150,4155,4156,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,983,SUCCESS
    5073,2021-07-01 21:45:35,20332.629,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4151,4151,4151,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1123,SUCCESS
    5074,2021-07-01 21:45:39,20336.640,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4151,4151,4151,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1111,SUCCESS
    5075,2021-07-01 21:45:43,20340.655,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29062,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4151,4151,4151,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    5076,2021-07-01 21:45:47,20344.665,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29063,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4152,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    5077,2021-07-01 21:45:51,20348.678,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29064,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4156,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    5078,2021-07-01 21:45:55,20352.692,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29063,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4151,4153,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.3,988,SUCCESS
    5079,2021-07-01 21:45:59,20356.707,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29062,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4157,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1000,SUCCESS
    5080,2021-07-01 21:46:03,20360.711,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4157,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,978,SUCCESS
    5081,2021-07-01 21:46:07,20364.726,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29062,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4151,4158,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,966,SUCCESS
    5082,2021-07-01 21:46:11,20368.738,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5083,2021-07-01 21:46:15,20372.752,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29062,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4151,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    5084,2021-07-01 21:46:19,20376.761,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    5085,2021-07-01 21:46:23,20380.766,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1082,SUCCESS
    5086,2021-07-01 21:46:27,20384.766,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5087,2021-07-01 21:46:31,20388.775,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    5088,2021-07-01 21:46:35,20392.781,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4150,4150,4151,4151,4150,4154,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5089,2021-07-01 21:46:39,20396.795,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    5090,2021-07-01 21:46:43,20400.804,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    5091,2021-07-01 21:46:47,20404.816,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    5092,2021-07-01 21:46:51,20408.829,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.5,1087,SUCCESS
    5093,2021-07-01 21:46:55,20412.843,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,957,SUCCESS
    5094,2021-07-01 21:46:59,20416.846,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1124,SUCCESS
    5095,2021-07-01 21:47:03,20420.860,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    5096,2021-07-01 21:47:07,20424.863,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    5097,2021-07-01 21:47:12,20428.870,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1072,SUCCESS
    5098,2021-07-01 21:47:16,20432.884,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    5099,2021-07-01 21:47:20,20436.906,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5100,2021-07-01 21:47:24,20440.913,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,993,SUCCESS
    5101,2021-07-01 21:47:28,20444.916,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.5,959,SUCCESS
    5102,2021-07-01 21:47:32,20448.929,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,962,SUCCESS
    5103,2021-07-01 21:47:36,20452.943,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29061,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    5104,2021-07-01 21:47:40,20456.957,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29059,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    5105,2021-07-01 21:47:44,20460.962,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    5106,2021-07-01 21:47:48,20464.971,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4155,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5107,2021-07-01 21:47:52,20468.985,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29059,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4151,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5108,2021-07-01 21:47:56,20472.998,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5109,2021-07-01 21:48:00,20477.005,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29059,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5110,2021-07-01 21:48:04,20481.014,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29059,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1081,SUCCESS
    5111,2021-07-01 21:48:08,20485.025,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,975,SUCCESS
    5112,2021-07-01 21:48:12,20489.032,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29059,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4151,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1001,SUCCESS
    5113,2021-07-01 21:48:16,20493.042,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1100,SUCCESS
    5114,2021-07-01 21:48:20,20497.052,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5115,2021-07-01 21:48:24,20501.054,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.3,979,SUCCESS
    5116,2021-07-01 21:48:28,20505.063,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1065,SUCCESS
    5117,2021-07-01 21:48:32,20509.065,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5118,2021-07-01 21:48:36,20513.077,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5119,2021-07-01 21:48:40,20517.081,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1077,SUCCESS
    5120,2021-07-01 21:48:44,20521.089,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    5121,2021-07-01 21:48:48,20525.097,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5122,2021-07-01 21:48:52,20529.108,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1130,SUCCESS
    5123,2021-07-01 21:48:56,20533.119,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,992,SUCCESS
    5124,2021-07-01 21:49:00,20537.119,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,974,SUCCESS
    5125,2021-07-01 21:49:04,20541.127,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    5126,2021-07-01 21:49:08,20545.141,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    5127,2021-07-01 21:49:12,20549.155,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    5128,2021-07-01 21:49:16,20553.170,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    5129,2021-07-01 21:49:20,20557.178,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29056,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1012,SUCCESS
    5130,2021-07-01 21:49:24,20561.187,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29058,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    5131,2021-07-01 21:49:28,20565.195,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29057,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    5132,2021-07-01 21:49:32,20569.194,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    5133,2021-07-01 21:49:36,20573.209,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29060,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4150,4150,4150,4150,4155,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.6,1036,SUCCESS
    5134,2021-07-01 21:49:40,20577.222,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1108,SUCCESS
    5135,2021-07-01 21:49:44,20581.226,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29056,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1103,SUCCESS
    5136,2021-07-01 21:49:48,20585.227,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    5137,2021-07-01 21:49:52,20589.229,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4150,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    5138,2021-07-01 21:49:56,20593.237,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    5139,2021-07-01 21:50:00,20597.255,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29056,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4149,4150,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,997,SUCCESS
    5140,2021-07-01 21:50:04,20601.259,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1039,SUCCESS
    5141,2021-07-01 21:50:08,20605.267,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1000,SUCCESS
    5142,2021-07-01 21:50:12,20609.277,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1005,SUCCESS
    5143,2021-07-01 21:50:16,20613.287,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5144,2021-07-01 21:50:20,20617.297,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29055,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    5145,2021-07-01 21:50:24,20621.307,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4150,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,990,SUCCESS
    5146,2021-07-01 21:50:28,20625.313,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1017,SUCCESS
    5147,2021-07-01 21:50:32,20629.321,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,948,SUCCESS
    5148,2021-07-01 21:50:36,20633.328,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1016,SUCCESS
    5149,2021-07-01 21:50:40,20637.330,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4150,4149,4153,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    5150,2021-07-01 21:50:44,20641.337,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4152,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1006,SUCCESS
    5151,2021-07-01 21:50:48,20645.341,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4151,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    5152,2021-07-01 21:50:52,20649.343,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29054,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    5153,2021-07-01 21:50:56,20653.355,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29052,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1038,SUCCESS
    5154,2021-07-01 21:51:00,20657.365,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    5155,2021-07-01 21:51:04,20661.375,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29052,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4156,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    5156,2021-07-01 21:51:08,20665.388,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4158,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.8,997,SUCCESS
    5157,2021-07-01 21:51:12,20669.402,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29052,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4158,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    5158,2021-07-01 21:51:16,20673.404,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    5159,2021-07-01 21:51:20,20677.407,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    5160,2021-07-01 21:51:24,20681.419,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1005,SUCCESS
    5161,2021-07-01 21:51:28,20685.433,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29053,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4153,4154,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    5162,2021-07-01 21:51:32,20689.442,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5163,2021-07-01 21:51:36,20693.447,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29052,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,991,SUCCESS
    5164,2021-07-01 21:51:40,20697.453,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29052,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,954,SUCCESS
    5165,2021-07-01 21:51:44,20701.455,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.5,1063,SUCCESS
    5166,2021-07-01 21:51:48,20705.466,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    5167,2021-07-01 21:51:52,20709.472,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4150,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5168,2021-07-01 21:51:56,20713.484,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1001,SUCCESS
    5169,2021-07-01 21:52:00,20717.494,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    5170,2021-07-01 21:52:04,20721.495,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1069,SUCCESS
    5171,2021-07-01 21:52:08,20725.496,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29051,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,958,SUCCESS
    5172,2021-07-01 21:52:12,20729.499,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5173,2021-07-01 21:52:16,20733.504,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29049,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5174,2021-07-01 21:52:20,20737.511,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29049,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1099,SUCCESS
    5175,2021-07-01 21:52:24,20741.515,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4148,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1016,SUCCESS
    5176,2021-07-01 21:52:28,20745.522,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5177,2021-07-01 21:52:32,20749.533,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    5178,2021-07-01 21:52:36,20753.545,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29050,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1035,SUCCESS
    5179,2021-07-01 21:52:40,20757.549,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29049,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.6,1046,SUCCESS
    5180,2021-07-01 21:52:44,20761.559,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4149,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    5181,2021-07-01 21:52:48,20765.560,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,971,SUCCESS
    5182,2021-07-01 21:52:52,20769.575,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,959,SUCCESS
    5183,2021-07-01 21:52:56,20773.580,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1127,SUCCESS
    5184,2021-07-01 21:53:00,20777.592,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4149,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,956,SUCCESS
    5185,2021-07-01 21:53:04,20781.594,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    5186,2021-07-01 21:53:08,20785.605,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    5187,2021-07-01 21:53:12,20789.611,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    5188,2021-07-01 21:53:16,20793.615,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,995,SUCCESS
    5189,2021-07-01 21:53:20,20797.627,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,967,SUCCESS
    5190,2021-07-01 21:53:24,20801.631,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,964,SUCCESS
    5191,2021-07-01 21:53:28,20805.639,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,987,SUCCESS
    5192,2021-07-01 21:53:32,20809.646,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29048,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1090,SUCCESS
    5193,2021-07-01 21:53:36,20813.653,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4149,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.3,990,SUCCESS
    5194,2021-07-01 21:53:40,20817.663,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    5195,2021-07-01 21:53:44,20821.676,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4149,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5196,2021-07-01 21:53:48,20825.677,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29046,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    5197,2021-07-01 21:53:52,20829.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29046,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4152,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    5198,2021-07-01 21:53:56,20833.690,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29045,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5199,2021-07-01 21:54:00,20837.705,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    5200,2021-07-01 21:54:04,20841.714,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4154,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    5201,2021-07-01 21:54:08,20845.725,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    5202,2021-07-01 21:54:12,20849.726,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29046,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,34.5,948,SUCCESS
    5203,2021-07-01 21:54:16,20853.730,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29045,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1006,SUCCESS
    5204,2021-07-01 21:54:20,20857.736,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29046,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5205,2021-07-01 21:54:24,20861.740,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29046,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,978,SUCCESS
    5206,2021-07-01 21:54:28,20865.751,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29047,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4153,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    5207,2021-07-01 21:54:32,20869.762,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29045,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4149,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1068,SUCCESS
    5208,2021-07-01 21:54:36,20873.764,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29044,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,972,SUCCESS
    5209,2021-07-01 21:54:40,20877.770,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    5210,2021-07-01 21:54:44,20881.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29044,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    5211,2021-07-01 21:54:48,20885.784,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29045,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1109,SUCCESS
    5212,2021-07-01 21:54:52,20889.787,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29045,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    5213,2021-07-01 21:54:56,20893.800,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1032,SUCCESS
    5214,2021-07-01 21:55:00,20897.807,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1085,SUCCESS
    5215,2021-07-01 21:55:04,20901.818,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.2,1042,SUCCESS
    5216,2021-07-01 21:55:08,20905.832,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.0,1085,SUCCESS
    5217,2021-07-01 21:55:12,20909.838,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1056,SUCCESS
    5218,2021-07-01 21:55:16,20913.839,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    5219,2021-07-01 21:55:20,20917.849,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    5220,2021-07-01 21:55:24,20921.863,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    5221,2021-07-01 21:55:28,20925.866,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1073,SUCCESS
    5222,2021-07-01 21:55:33,20929.881,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,998,SUCCESS
    5223,2021-07-01 21:55:37,20933.905,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    5224,2021-07-01 21:55:41,20937.915,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    5225,2021-07-01 21:55:45,20941.916,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4148,4151,4152,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.2,1023,SUCCESS
    5226,2021-07-01 21:55:49,20945.929,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29044,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    5227,2021-07-01 21:55:53,20949.940,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29043,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4148,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,984,SUCCESS
    5228,2021-07-01 21:55:57,20953.954,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4148,4148,4148,4148,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    5229,2021-07-01 21:56:01,20957.965,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4148,4154,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    5230,2021-07-01 21:56:05,20961.972,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4148,4148,4148,4147,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5231,2021-07-01 21:56:09,20965.976,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29041,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4148,4156,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,968,SUCCESS
    5232,2021-07-01 21:56:13,20969.982,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4153,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    5233,2021-07-01 21:56:17,20973.997,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1004,SUCCESS
    5234,2021-07-01 21:56:21,20978.007,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29041,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5235,2021-07-01 21:56:25,20982.010,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29042,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1087,SUCCESS
    5236,2021-07-01 21:56:29,20986.010,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29041,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    5237,2021-07-01 21:56:33,20990.025,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,946,SUCCESS
    5238,2021-07-01 21:56:37,20994.031,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    5239,2021-07-01 21:56:41,20998.033,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    5240,2021-07-01 21:56:45,21002.048,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.2,1094,SUCCESS
    5241,2021-07-01 21:56:49,21006.055,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4147,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    5242,2021-07-01 21:56:53,21010.059,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5243,2021-07-01 21:56:57,21014.066,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29039,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4151,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.2,1029,SUCCESS
    5244,2021-07-01 21:57:01,21018.071,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4152,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.1,976,SUCCESS
    5245,2021-07-01 21:57:05,21022.076,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29039,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.1,1048,SUCCESS
    5246,2021-07-01 21:57:09,21026.084,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29039,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,979,SUCCESS
    5247,2021-07-01 21:57:13,21030.091,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29039,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3210,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    5248,2021-07-01 21:57:17,21034.094,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1081,SUCCESS
    5249,2021-07-01 21:57:21,21038.096,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4151,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    5250,2021-07-01 21:57:25,21042.105,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    5251,2021-07-01 21:57:29,21046.113,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4151,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    5252,2021-07-01 21:57:33,21050.128,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,998,SUCCESS
    5253,2021-07-01 21:57:37,21054.129,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29040,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4148,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1077,SUCCESS
    5254,2021-07-01 21:57:41,21058.144,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29039,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3209,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5255,2021-07-01 21:57:45,21062.146,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    5256,2021-07-01 21:57:49,21066.156,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1019,SUCCESS
    5257,2021-07-01 21:57:53,21070.169,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4152,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    5258,2021-07-01 21:57:57,21074.176,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    5259,2021-07-01 21:58:01,21078.177,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    5260,2021-07-01 21:58:05,21082.190,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    5261,2021-07-01 21:58:09,21086.200,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1099,SUCCESS
    5262,2021-07-01 21:58:13,21090.208,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    5263,2021-07-01 21:58:17,21094.218,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    5264,2021-07-01 21:58:21,21098.219,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,987,SUCCESS
    5265,2021-07-01 21:58:25,21102.223,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4148,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,999,SUCCESS
    5266,2021-07-01 21:58:29,21106.233,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1050,SUCCESS
    5267,2021-07-01 21:58:33,21110.243,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    5268,2021-07-01 21:58:37,21114.252,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1015,SUCCESS
    5269,2021-07-01 21:58:41,21118.263,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1021,SUCCESS
    5270,2021-07-01 21:58:45,21122.268,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1047,SUCCESS
    5271,2021-07-01 21:58:49,21126.271,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1042,SUCCESS
    5272,2021-07-01 21:58:53,21130.284,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    5273,2021-07-01 21:58:57,21134.286,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    5274,2021-07-01 21:59:01,21138.288,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    5275,2021-07-01 21:59:05,21142.300,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    5276,2021-07-01 21:59:09,21146.312,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29035,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5277,2021-07-01 21:59:13,21150.315,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1078,SUCCESS
    5278,2021-07-01 21:59:17,21154.326,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29035,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5279,2021-07-01 21:59:21,21158.327,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1019,SUCCESS
    5280,2021-07-01 21:59:25,21162.340,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.6,1029,SUCCESS
    5281,2021-07-01 21:59:29,21166.354,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4152,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    5282,2021-07-01 21:59:33,21170.359,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29035,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1097,SUCCESS
    5283,2021-07-01 21:59:37,21174.367,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1072,SUCCESS
    5284,2021-07-01 21:59:41,21178.377,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29036,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4147,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1065,SUCCESS
    5285,2021-07-01 21:59:45,21182.392,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29037,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,954,SUCCESS
    5286,2021-07-01 21:59:49,21186.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29038,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    5287,2021-07-01 21:59:53,21190.396,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29035,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    5288,2021-07-01 21:59:57,21194.398,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    5289,2021-07-01 22:00:01,21198.401,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.7,1020,SUCCESS
    5290,2021-07-01 22:00:05,21202.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29035,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    5291,2021-07-01 22:00:09,21206.410,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1109,SUCCESS
    5292,2021-07-01 22:00:13,21210.419,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    5293,2021-07-01 22:00:17,21214.426,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1092,SUCCESS
    5294,2021-07-01 22:00:21,21218.425,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3206,26.2,26.3,-273.2,26.3,-273.2,35.2,1092,SUCCESS
    5295,2021-07-01 22:00:25,21222.434,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1051,SUCCESS
    5296,2021-07-01 22:00:29,21226.448,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    5297,2021-07-01 22:00:33,21230.450,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29034,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,972,SUCCESS
    5298,2021-07-01 22:00:37,21234.465,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4146,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1069,SUCCESS
    5299,2021-07-01 22:00:41,21238.466,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4147,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    5300,2021-07-01 22:00:45,21242.467,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,956,SUCCESS
    5301,2021-07-01 22:00:49,21246.475,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1042,SUCCESS
    5302,2021-07-01 22:00:53,21250.479,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4150,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,993,SUCCESS
    5303,2021-07-01 22:00:57,21254.486,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    5304,2021-07-01 22:01:01,21258.486,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4149,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5305,2021-07-01 22:01:05,21262.500,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29033,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4148,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5306,2021-07-01 22:01:09,21266.515,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4147,4147,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1065,SUCCESS
    5307,2021-07-01 22:01:13,21270.519,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4152,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.7,1029,SUCCESS
    5308,2021-07-01 22:01:17,21274.532,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4152,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1037,SUCCESS
    5309,2021-07-01 22:01:21,21278.539,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4153,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,946,SUCCESS
    5310,2021-07-01 22:01:25,21282.552,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4155,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    5311,2021-07-01 22:01:29,21286.562,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4155,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1114,SUCCESS
    5312,2021-07-01 22:01:33,21290.571,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4151,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,962,SUCCESS
    5313,2021-07-01 22:01:37,21294.586,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,979,SUCCESS
    5314,2021-07-01 22:01:41,21298.595,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    5315,2021-07-01 22:01:45,21302.597,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29030,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    5316,2021-07-01 22:01:49,21306.611,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29030,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.5,1038,SUCCESS
    5317,2021-07-01 22:01:53,21310.614,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29030,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    5318,2021-07-01 22:01:57,21314.615,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5319,2021-07-01 22:02:01,21318.628,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5320,2021-07-01 22:02:05,21322.639,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1004,SUCCESS
    5321,2021-07-01 22:02:09,21326.643,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29030,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4147,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    5322,2021-07-01 22:02:13,21330.653,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5323,2021-07-01 22:02:17,21334.655,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29032,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1081,SUCCESS
    5324,2021-07-01 22:02:21,21338.669,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4147,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1020,SUCCESS
    5325,2021-07-01 22:02:25,21342.678,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29031,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.8,979,SUCCESS
    5326,2021-07-01 22:02:29,21346.687,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4146,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    5327,2021-07-01 22:02:33,21350.698,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,991,SUCCESS
    5328,2021-07-01 22:02:37,21354.705,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1016,SUCCESS
    5329,2021-07-01 22:02:41,21358.709,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5330,2021-07-01 22:02:45,21362.718,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1067,SUCCESS
    5331,2021-07-01 22:02:49,21366.733,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,956,SUCCESS
    5332,2021-07-01 22:02:53,21370.748,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5333,2021-07-01 22:02:57,21374.761,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4145,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    5334,2021-07-01 22:03:01,21378.768,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29028,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4151,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.6,1110,SUCCESS
    5335,2021-07-01 22:03:05,21382.774,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1041,SUCCESS
    5336,2021-07-01 22:03:09,21386.783,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    5337,2021-07-01 22:03:13,21390.793,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1101,SUCCESS
    5338,2021-07-01 22:03:17,21394.800,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1061,SUCCESS
    5339,2021-07-01 22:03:21,21398.809,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1052,SUCCESS
    5340,2021-07-01 22:03:25,21402.814,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4149,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5341,2021-07-01 22:03:29,21406.820,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29026,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4149,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,994,SUCCESS
    5342,2021-07-01 22:03:33,21410.822,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    5343,2021-07-01 22:03:37,21414.828,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29026,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.3,1102,SUCCESS
    5344,2021-07-01 22:03:41,21418.832,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4146,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    5345,2021-07-01 22:03:45,21422.833,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5346,2021-07-01 22:03:49,21426.840,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    5347,2021-07-01 22:03:53,21430.853,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29026,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1102,SUCCESS
    5348,2021-07-01 22:03:58,21434.867,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4146,4146,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,978,SUCCESS
    5349,2021-07-01 22:04:02,21438.873,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29026,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    5350,2021-07-01 22:04:06,21442.882,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29025,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    5351,2021-07-01 22:04:10,21446.897,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29026,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4146,4149,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    5352,2021-07-01 22:04:14,21450.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29024,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    5353,2021-07-01 22:04:18,21454.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29024,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4146,4149,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5354,2021-07-01 22:04:22,21458.924,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4149,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5355,2021-07-01 22:04:26,21462.935,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5356,2021-07-01 22:04:30,21466.946,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    5357,2021-07-01 22:04:34,21470.959,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29025,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5358,2021-07-01 22:04:38,21474.973,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29023,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4146,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    5359,2021-07-01 22:04:42,21478.977,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29024,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5360,2021-07-01 22:04:46,21482.983,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29025,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4146,4145,4145,4150,4150,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1094,SUCCESS
    5361,2021-07-01 22:04:50,21486.999,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29027,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1049,SUCCESS
    5362,2021-07-01 22:04:54,21491.007,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29023,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1009,SUCCESS
    5363,2021-07-01 22:04:58,21495.022,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    5364,2021-07-01 22:05:02,21499.027,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1039,SUCCESS
    5365,2021-07-01 22:05:06,21503.031,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1034,SUCCESS
    5366,2021-07-01 22:05:10,21507.044,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,974,SUCCESS
    5367,2021-07-01 22:05:14,21511.051,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    5368,2021-07-01 22:05:18,21515.058,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5369,2021-07-01 22:05:22,21519.067,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5370,2021-07-01 22:05:26,21523.082,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    5371,2021-07-01 22:05:30,21527.083,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,982,SUCCESS
    5372,2021-07-01 22:05:34,21531.097,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1014,SUCCESS
    5373,2021-07-01 22:05:38,21535.102,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1054,SUCCESS
    5374,2021-07-01 22:05:42,21539.117,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    5375,2021-07-01 22:05:46,21543.119,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4144,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.5,1025,SUCCESS
    5376,2021-07-01 22:05:50,21547.123,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1019,SUCCESS
    5377,2021-07-01 22:05:54,21551.129,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1062,SUCCESS
    5378,2021-07-01 22:05:58,21555.134,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    5379,2021-07-01 22:06:02,21559.143,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5380,2021-07-01 22:06:06,21563.148,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    5381,2021-07-01 22:06:10,21567.151,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29022,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4147,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1055,SUCCESS
    5382,2021-07-01 22:06:14,21571.162,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4145,4145,4145,4145,4146,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    5383,2021-07-01 22:06:18,21575.175,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29023,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4145,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1078,SUCCESS
    5384,2021-07-01 22:06:22,21579.190,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.5,1030,SUCCESS
    5385,2021-07-01 22:06:26,21583.200,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4150,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,942,SUCCESS
    5386,2021-07-01 22:06:30,21587.207,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1110,SUCCESS
    5387,2021-07-01 22:06:34,21591.210,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4150,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    5388,2021-07-01 22:06:38,21595.225,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4145,4153,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1076,SUCCESS
    5389,2021-07-01 22:06:42,21599.221,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29021,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4144,4144,4145,4145,4145,4153,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1046,SUCCESS
    5390,2021-07-01 22:06:46,21603.223,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1106,SUCCESS
    5391,2021-07-01 22:06:50,21607.237,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1123,SUCCESS
    5392,2021-07-01 22:06:54,21611.247,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1035,SUCCESS
    5393,2021-07-01 22:06:58,21615.262,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    5394,2021-07-01 22:07:02,21619.277,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4148,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    5395,2021-07-01 22:07:06,21623.292,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4148,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,991,SUCCESS
    5396,2021-07-01 22:07:10,21627.299,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5397,2021-07-01 22:07:14,21631.301,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29020,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1075,SUCCESS
    5398,2021-07-01 22:07:18,21635.309,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,988,SUCCESS
    5399,2021-07-01 22:07:22,21639.317,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4149,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1013,SUCCESS
    5400,2021-07-01 22:07:26,21643.324,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1004,SUCCESS
    5401,2021-07-01 22:07:30,21647.324,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1031,SUCCESS
    5402,2021-07-01 22:07:34,21651.331,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4145,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1031,SUCCESS
    5403,2021-07-01 22:07:38,21655.339,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1115,SUCCESS
    5404,2021-07-01 22:07:42,21659.344,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5405,2021-07-01 22:07:46,21663.357,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1035,SUCCESS
    5406,2021-07-01 22:07:50,21667.372,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5407,2021-07-01 22:07:54,21671.382,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4145,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.8,994,SUCCESS
    5408,2021-07-01 22:07:58,21675.395,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4145,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1063,SUCCESS
    5409,2021-07-01 22:08:02,21679.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1109,SUCCESS
    5410,2021-07-01 22:08:06,21683.412,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,981,SUCCESS
    5411,2021-07-01 22:08:10,21687.413,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1026,SUCCESS
    5412,2021-07-01 22:08:14,21691.428,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29016,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    5413,2021-07-01 22:08:18,21695.442,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29018,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5414,2021-07-01 22:08:22,21699.456,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29016,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1012,SUCCESS
    5415,2021-07-01 22:08:26,21703.462,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,944,SUCCESS
    5416,2021-07-01 22:08:30,21707.468,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29016,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1034,SUCCESS
    5417,2021-07-01 22:08:34,21711.482,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1004,SUCCESS
    5418,2021-07-01 22:08:38,21715.487,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29016,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    5419,2021-07-01 22:08:42,21719.501,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5420,2021-07-01 22:08:46,21723.511,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1039,SUCCESS
    5421,2021-07-01 22:08:50,21727.520,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4145,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    5422,2021-07-01 22:08:54,21731.526,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29016,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,976,SUCCESS
    5423,2021-07-01 22:08:58,21735.534,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    5424,2021-07-01 22:09:02,21739.546,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1095,SUCCESS
    5425,2021-07-01 22:09:06,21743.562,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.6,1049,SUCCESS
    5426,2021-07-01 22:09:10,21747.570,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,948,SUCCESS
    5427,2021-07-01 22:09:14,21751.584,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1074,SUCCESS
    5428,2021-07-01 22:09:18,21755.598,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1063,SUCCESS
    5429,2021-07-01 22:09:22,21759.605,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    5430,2021-07-01 22:09:26,21763.612,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5431,2021-07-01 22:09:30,21767.624,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29014,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    5432,2021-07-01 22:09:34,21771.628,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5433,2021-07-01 22:09:38,21775.631,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29014,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1074,SUCCESS
    5434,2021-07-01 22:09:42,21779.644,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29014,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1076,SUCCESS
    5435,2021-07-01 22:09:46,21783.647,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29014,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4149,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5436,2021-07-01 22:09:50,21787.659,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    5437,2021-07-01 22:09:54,21791.675,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29015,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1048,SUCCESS
    5438,2021-07-01 22:09:58,21795.678,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,996,SUCCESS
    5439,2021-07-01 22:10:02,21799.683,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29017,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    5440,2021-07-01 22:10:06,21803.697,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29019,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,960,SUCCESS
    5441,2021-07-01 22:10:10,21807.699,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29013,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1117,SUCCESS
    5442,2021-07-01 22:10:14,21811.706,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29013,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5443,2021-07-01 22:10:18,21815.716,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    5444,2021-07-01 22:10:22,21819.721,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29013,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4144,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    5445,2021-07-01 22:10:26,21823.726,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29014,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1011,SUCCESS
    5446,2021-07-01 22:10:30,21827.738,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29013,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5447,2021-07-01 22:10:34,21831.742,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4143,4148,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    5448,2021-07-01 22:10:38,21835.757,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4144,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,963,SUCCESS
    5449,2021-07-01 22:10:42,21839.766,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1098,SUCCESS
    5450,2021-07-01 22:10:46,21843.767,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5451,2021-07-01 22:10:50,21847.772,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,962,SUCCESS
    5452,2021-07-01 22:10:54,21851.787,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4143,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.5,964,SUCCESS
    5453,2021-07-01 22:10:58,21855.799,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1094,SUCCESS
    5454,2021-07-01 22:11:02,21859.802,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    5455,2021-07-01 22:11:06,21863.816,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4147,4148,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5456,2021-07-01 22:11:10,21867.825,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    5457,2021-07-01 22:11:14,21871.832,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29012,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4144,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1013,SUCCESS
    5458,2021-07-01 22:11:18,21875.832,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1078,SUCCESS
    5459,2021-07-01 22:11:22,21879.847,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4143,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1031,SUCCESS
    5460,2021-07-01 22:11:26,21883.847,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29011,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4148,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1077,SUCCESS
    5461,2021-07-01 22:11:30,21887.849,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4144,4149,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.7,1003,SUCCESS
    5462,2021-07-01 22:11:34,21891.853,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4149,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5463,2021-07-01 22:11:38,21895.859,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4148,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1018,SUCCESS
    5464,2021-07-01 22:11:42,21899.859,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4148,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    5465,2021-07-01 22:11:47,21903.874,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1066,SUCCESS
    5466,2021-07-01 22:11:51,21907.882,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,975,SUCCESS
    5467,2021-07-01 22:11:55,21911.905,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5468,2021-07-01 22:11:59,21915.911,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5469,2021-07-01 22:12:03,21919.912,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4144,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5470,2021-07-01 22:12:07,21923.926,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.4,1053,SUCCESS
    5471,2021-07-01 22:12:11,21927.934,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1068,SUCCESS
    5472,2021-07-01 22:12:15,21931.943,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1026,SUCCESS
    5473,2021-07-01 22:12:19,21935.955,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1079,SUCCESS
    5474,2021-07-01 22:12:23,21939.969,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,969,SUCCESS
    5475,2021-07-01 22:12:27,21943.976,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    5476,2021-07-01 22:12:31,21947.978,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1009,SUCCESS
    5477,2021-07-01 22:12:35,21951.990,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29010,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4144,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5478,2021-07-01 22:12:39,21956.004,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5479,2021-07-01 22:12:43,21960.018,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    5480,2021-07-01 22:12:47,21964.021,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    5481,2021-07-01 22:12:51,21968.022,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5482,2021-07-01 22:12:55,21972.035,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1093,SUCCESS
    5483,2021-07-01 22:12:59,21976.036,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4144,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1029,SUCCESS
    5484,2021-07-01 22:13:03,21980.038,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29009,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,980,SUCCESS
    5485,2021-07-01 22:13:07,21984.052,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5486,2021-07-01 22:13:11,21988.062,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,970,SUCCESS
    5487,2021-07-01 22:13:15,21992.075,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1036,SUCCESS
    5488,2021-07-01 22:13:19,21996.074,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29008,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.8,1007,SUCCESS
    5489,2021-07-01 22:13:23,22000.089,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29007,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4143,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1007,SUCCESS
    5490,2021-07-01 22:13:27,22004.097,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29007,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1093,SUCCESS
    5491,2021-07-01 22:13:31,22008.099,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29007,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,965,SUCCESS
    5492,2021-07-01 22:13:35,22012.114,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1124,SUCCESS
    5493,2021-07-01 22:13:39,22016.113,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29007,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5494,2021-07-01 22:13:43,22020.128,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29007,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    5495,2021-07-01 22:13:47,22024.141,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5496,2021-07-01 22:13:51,22028.143,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1046,SUCCESS
    5497,2021-07-01 22:13:55,22032.159,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4142,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1060,SUCCESS
    5498,2021-07-01 22:13:59,22036.160,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5499,2021-07-01 22:14:03,22040.167,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1053,SUCCESS
    5500,2021-07-01 22:14:07,22044.182,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,959,SUCCESS
    5501,2021-07-01 22:14:11,22048.196,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1007,SUCCESS
    5502,2021-07-01 22:14:15,22052.201,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1096,SUCCESS
    5503,2021-07-01 22:14:19,22056.203,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1142,SUCCESS
    5504,2021-07-01 22:14:23,22060.216,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29004,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5505,2021-07-01 22:14:27,22064.221,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    5506,2021-07-01 22:14:31,22068.240,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5507,2021-07-01 22:14:35,22072.242,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1024,SUCCESS
    5508,2021-07-01 22:14:39,22076.252,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29003,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1093,SUCCESS
    5509,2021-07-01 22:14:43,22080.252,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4147,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5510,2021-07-01 22:14:47,22084.266,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29006,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1002,SUCCESS
    5511,2021-07-01 22:14:51,22088.276,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,975,SUCCESS
    5512,2021-07-01 22:14:55,22092.280,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29005,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4143,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5513,2021-07-01 22:14:59,22096.295,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29004,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    5514,2021-07-01 22:15:03,22100.299,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29004,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4143,4146,4147,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    5515,2021-07-01 22:15:07,22104.302,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29003,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5516,2021-07-01 22:15:11,22108.316,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1157,SUCCESS
    5517,2021-07-01 22:15:15,22112.319,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29003,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1028,SUCCESS
    5518,2021-07-01 22:15:19,22116.325,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29003,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,958,SUCCESS
    5519,2021-07-01 22:15:23,22120.331,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29003,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5520,2021-07-01 22:15:27,22124.343,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.6,973,SUCCESS
    5521,2021-07-01 22:15:31,22128.355,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4143,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,990,SUCCESS
    5522,2021-07-01 22:15:35,22132.367,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4143,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    5523,2021-07-01 22:15:39,22136.377,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5524,2021-07-01 22:15:43,22140.384,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1047,SUCCESS
    5525,2021-07-01 22:15:47,22144.393,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4143,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,999,SUCCESS
    5526,2021-07-01 22:15:51,22148.399,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29002,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1040,SUCCESS
    5527,2021-07-01 22:15:55,22152.409,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5528,2021-07-01 22:15:59,22156.410,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4145,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5529,2021-07-01 22:16:03,22160.421,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4145,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,987,SUCCESS
    5530,2021-07-01 22:16:07,22164.425,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5531,2021-07-01 22:16:11,22168.434,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    5532,2021-07-01 22:16:15,22172.442,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1077,SUCCESS
    5533,2021-07-01 22:16:19,22176.455,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4147,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1079,SUCCESS
    5534,2021-07-01 22:16:23,22180.463,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4147,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    5535,2021-07-01 22:16:27,22184.466,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1037,SUCCESS
    5536,2021-07-01 22:16:31,22188.466,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1066,SUCCESS
    5537,2021-07-01 22:16:35,22192.474,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,948,SUCCESS
    5538,2021-07-01 22:16:39,22196.475,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,965,SUCCESS
    5539,2021-07-01 22:16:43,22200.486,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4145,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5540,2021-07-01 22:16:47,22204.487,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    5541,2021-07-01 22:16:51,22208.493,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1057,SUCCESS
    5542,2021-07-01 22:16:55,22212.501,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5543,2021-07-01 22:16:59,22216.512,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1010,SUCCESS
    5544,2021-07-01 22:17:03,22220.517,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,984,SUCCESS
    5545,2021-07-01 22:17:07,22224.523,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1122,SUCCESS
    5546,2021-07-01 22:17:11,22228.524,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29001,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1008,SUCCESS
    5547,2021-07-01 22:17:15,22232.531,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1050,SUCCESS
    5548,2021-07-01 22:17:19,22236.532,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4142,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,972,SUCCESS
    5549,2021-07-01 22:17:23,22240.533,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1094,SUCCESS
    5550,2021-07-01 22:17:27,22244.541,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    5551,2021-07-01 22:17:31,22248.552,0x0541,150,10,0x6001,0,65535,65535,1,26.3,29000,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4145,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.2,1015,SUCCESS
    5552,2021-07-01 22:17:35,22252.567,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.4,1013,SUCCESS
    5553,2021-07-01 22:17:39,22256.579,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28998,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1016,SUCCESS
    5554,2021-07-01 22:17:43,22260.592,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4141,4141,4142,4142,4141,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5555,2021-07-01 22:17:47,22264.606,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28998,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4147,4146,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    5556,2021-07-01 22:17:51,22268.620,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1023,SUCCESS
    5557,2021-07-01 22:17:55,22272.634,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28997,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,992,SUCCESS
    5558,2021-07-01 22:17:59,22276.639,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28999,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1033,SUCCESS
    5559,2021-07-01 22:18:03,22280.640,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28998,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5560,2021-07-01 22:18:07,22284.652,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4142,4146,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.2,1083,SUCCESS
    5561,2021-07-01 22:18:11,22288.655,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,34.8,971,SUCCESS
    5562,2021-07-01 22:18:15,22292.657,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28997,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    5563,2021-07-01 22:18:19,22296.664,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28997,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    5564,2021-07-01 22:18:23,22300.666,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28998,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,976,SUCCESS
    5565,2021-07-01 22:18:27,22304.674,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28997,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1084,SUCCESS
    5566,2021-07-01 22:18:31,22308.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28997,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,993,SUCCESS
    5567,2021-07-01 22:18:35,22312.680,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,994,SUCCESS
    5568,2021-07-01 22:18:39,22316.694,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1027,SUCCESS
    5569,2021-07-01 22:18:43,22320.703,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28995,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    5570,2021-07-01 22:18:47,22324.716,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.0,1036,SUCCESS
    5571,2021-07-01 22:18:51,22328.720,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1017,SUCCESS
    5572,2021-07-01 22:18:55,22332.731,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1052,SUCCESS
    5573,2021-07-01 22:18:59,22336.744,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1038,SUCCESS
    5574,2021-07-01 22:19:03,22340.745,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28995,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,991,SUCCESS
    5575,2021-07-01 22:19:07,22344.746,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,975,SUCCESS
    5576,2021-07-01 22:19:11,22348.751,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4141,4141,4146,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5577,2021-07-01 22:19:15,22352.760,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28996,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4142,4142,4141,4146,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    5578,2021-07-01 22:19:19,22356.774,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28995,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,1056,SUCCESS
    5579,2021-07-01 22:19:23,22360.777,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,34.8,1070,SUCCESS
    5580,2021-07-01 22:19:27,22364.788,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1040,SUCCESS
    5581,2021-07-01 22:19:31,22368.795,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28995,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.2,1020,SUCCESS
    5582,2021-07-01 22:19:35,22372.800,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5583,2021-07-01 22:19:39,22376.813,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28995,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    5584,2021-07-01 22:19:43,22380.822,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,35.2,977,SUCCESS
    5585,2021-07-01 22:19:47,22384.827,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1035,SUCCESS
    5586,2021-07-01 22:19:51,22388.842,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,958,SUCCESS
    5587,2021-07-01 22:19:55,22392.845,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1110,SUCCESS
    5588,2021-07-01 22:19:59,22396.847,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.5,1098,SUCCESS
    5589,2021-07-01 22:20:03,22400.854,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4144,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1022,SUCCESS
    5590,2021-07-01 22:20:08,22404.869,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,35.1,1073,SUCCESS
    5591,2021-07-01 22:20:12,22408.873,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,35.2,973,SUCCESS
    5592,2021-07-01 22:20:16,22412.873,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,973,SUCCESS
    5593,2021-07-01 22:20:20,22416.876,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.2,1080,SUCCESS
    5594,2021-07-01 22:20:24,22420.888,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1051,SUCCESS
    5595,2021-07-01 22:20:28,22424.894,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,1011,SUCCESS
    5596,2021-07-01 22:20:32,22428.903,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,990,SUCCESS
    5597,2021-07-01 22:20:36,22432.909,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5598,2021-07-01 22:20:40,22436.924,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28992,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1061,SUCCESS
    5599,2021-07-01 22:20:44,22440.939,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28992,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5600,2021-07-01 22:20:48,22444.950,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4143,4145,0,0,0,0,0,0,0,0,3201,26.2,26.3,-273.2,26.3,-273.2,35.1,943,SUCCESS
    5601,2021-07-01 22:20:52,22448.958,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3205,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5602,2021-07-01 22:20:56,22452.973,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1059,SUCCESS
    5603,2021-07-01 22:21:00,22456.981,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1036,SUCCESS
    5604,2021-07-01 22:21:04,22460.992,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28994,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4145,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,978,SUCCESS
    5605,2021-07-01 22:21:08,22465.001,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28998,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1016,SUCCESS
    5606,2021-07-01 22:21:12,22469.003,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1062,SUCCESS
    5607,2021-07-01 22:21:16,22473.011,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4141,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1005,SUCCESS
    5608,2021-07-01 22:21:20,22477.018,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28992,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5609,2021-07-01 22:21:24,22481.032,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28991,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    5610,2021-07-01 22:21:28,22485.036,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28991,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1059,SUCCESS
    5611,2021-07-01 22:21:32,22489.043,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28992,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1006,SUCCESS
    5612,2021-07-01 22:21:36,22493.055,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28993,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1010,SUCCESS
    5613,2021-07-01 22:21:40,22497.069,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,993,SUCCESS
    5614,2021-07-01 22:21:44,22501.072,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28991,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,977,SUCCESS
    5615,2021-07-01 22:21:48,22505.085,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28991,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1026,SUCCESS
    5616,2021-07-01 22:21:52,22509.097,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4141,4144,4145,0,0,0,0,0,0,0,0,3204,26.2,26.3,-273.2,26.3,-273.2,35.1,1093,SUCCESS
    5617,2021-07-01 22:21:56,22513.109,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1096,SUCCESS
    5618,2021-07-01 22:22:00,22517.120,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1053,SUCCESS
    5619,2021-07-01 22:22:04,22521.130,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    5620,2021-07-01 22:22:08,22525.132,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4140,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.5,1011,SUCCESS
    5621,2021-07-01 22:22:12,22529.136,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28991,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1100,SUCCESS
    5622,2021-07-01 22:22:16,22533.149,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1010,SUCCESS
    5623,2021-07-01 22:22:20,22537.160,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4142,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1097,SUCCESS
    5624,2021-07-01 22:22:24,22541.173,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4142,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1019,SUCCESS
    5625,2021-07-01 22:22:28,22545.185,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4141,4140,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1083,SUCCESS
    5626,2021-07-01 22:22:32,22549.194,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    5627,2021-07-01 22:22:36,22553.198,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4145,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,993,SUCCESS
    5628,2021-07-01 22:22:40,22557.209,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28990,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,997,SUCCESS
    5629,2021-07-01 22:22:44,22561.214,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4141,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.5,1038,SUCCESS
    5630,2021-07-01 22:22:48,22565.218,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4149,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1066,SUCCESS
    5631,2021-07-01 22:22:52,22569.227,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1043,SUCCESS
    5632,2021-07-01 22:22:56,22573.228,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1025,SUCCESS
    5633,2021-07-01 22:23:00,22577.242,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,996,SUCCESS
    5634,2021-07-01 22:23:04,22581.256,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1028,SUCCESS
    5635,2021-07-01 22:23:08,22585.257,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,979,SUCCESS
    5636,2021-07-01 22:23:12,22589.265,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5637,2021-07-01 22:23:16,22593.269,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1032,SUCCESS
    5638,2021-07-01 22:23:20,22597.270,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1091,SUCCESS
    5639,2021-07-01 22:23:24,22601.271,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1060,SUCCESS
    5640,2021-07-01 22:23:28,22605.277,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1070,SUCCESS
    5641,2021-07-01 22:23:32,22609.285,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1078,SUCCESS
    5642,2021-07-01 22:23:36,22613.287,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,981,SUCCESS
    5643,2021-07-01 22:23:40,22617.295,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.9,1058,SUCCESS
    5644,2021-07-01 22:23:44,22621.300,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1063,SUCCESS
    5645,2021-07-01 22:23:48,22625.314,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28989,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1064,SUCCESS
    5646,2021-07-01 22:23:52,22629.321,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28987,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4141,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5647,2021-07-01 22:23:56,22633.328,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    5648,2021-07-01 22:24:00,22637.332,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1094,SUCCESS
    5649,2021-07-01 22:24:04,22641.340,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28986,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    5650,2021-07-01 22:24:08,22645.351,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1043,SUCCESS
    5651,2021-07-01 22:24:12,22649.363,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1045,SUCCESS
    5652,2021-07-01 22:24:16,22653.365,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28988,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4141,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.7,1069,SUCCESS
    5653,2021-07-01 22:24:20,22657.370,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28987,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,961,SUCCESS
    5654,2021-07-01 22:24:24,22661.380,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28986,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1027,SUCCESS
    5655,2021-07-01 22:24:28,22665.391,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28987,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1018,SUCCESS
    5656,2021-07-01 22:24:32,22669.404,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28987,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,988,SUCCESS
    5657,2021-07-01 22:24:36,22673.407,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28986,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,986,SUCCESS
    5658,2021-07-01 22:24:40,22677.419,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28987,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    5659,2021-07-01 22:24:44,22681.421,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1037,SUCCESS
    5660,2021-07-01 22:24:48,22685.426,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4140,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1014,SUCCESS
    5661,2021-07-01 22:24:52,22689.433,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,974,SUCCESS
    5662,2021-07-01 22:24:56,22693.433,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28986,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1021,SUCCESS
    5663,2021-07-01 22:25:00,22697.437,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28986,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1034,SUCCESS
    5664,2021-07-01 22:25:04,22701.449,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,974,SUCCESS
    5665,2021-07-01 22:25:08,22705.454,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28984,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1080,SUCCESS
    5666,2021-07-01 22:25:12,22709.466,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1082,SUCCESS
    5667,2021-07-01 22:25:16,22713.468,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1067,SUCCESS
    5668,2021-07-01 22:25:20,22717.476,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28984,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1041,SUCCESS
    5669,2021-07-01 22:25:24,22721.487,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28985,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1049,SUCCESS
    5670,2021-07-01 22:25:28,22725.502,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4144,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1094,SUCCESS
    5671,2021-07-01 22:25:32,22729.503,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1044,SUCCESS
    5672,2021-07-01 22:25:36,22733.516,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1033,SUCCESS
    5673,2021-07-01 22:25:40,22737.521,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28984,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1058,SUCCESS
    5674,2021-07-01 22:25:44,22741.535,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28981,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1030,SUCCESS
    5675,2021-07-01 22:25:48,22745.548,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28981,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1094,SUCCESS
    5676,2021-07-01 22:25:52,22749.554,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28980,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,995,SUCCESS
    5677,2021-07-01 22:25:56,22753.559,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,960,SUCCESS
    5678,2021-07-01 22:26:00,22757.565,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4139,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1047,SUCCESS
    5679,2021-07-01 22:26:04,22761.567,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4139,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5680,2021-07-01 22:26:08,22765.581,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4144,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,983,SUCCESS
    5681,2021-07-01 22:26:12,22769.592,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28984,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1003,SUCCESS
    5682,2021-07-01 22:26:16,22773.598,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28984,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1092,SUCCESS
    5683,2021-07-01 22:26:20,22777.609,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28982,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4139,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1002,SUCCESS
    5684,2021-07-01 22:26:24,22781.610,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,34.5,1080,SUCCESS
    5685,2021-07-01 22:26:28,22785.623,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28982,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4139,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,1126,SUCCESS
    5686,2021-07-01 22:26:32,22789.631,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28983,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4140,4140,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.1,981,SUCCESS
    5687,2021-07-01 22:26:36,22793.644,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28982,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,4138,4139,4139,4139,4140,4143,4143,0,0,0,0,0,0,0,0,3200,26.2,26.3,-273.2,26.3,-273.2,35.2,1045,SUCCESS
    5688,2021-07-01 22:26:40,22797.651,0x0541,150,10,0x6001,0,65535,65535,1,26.3,28981,0,0,8,100,142,2351,2352,65535,65535,65535,0,0,0x40E0,4103,2552,100,0x4105,0x0000,0x04,0x82,0x54A,0x0030,0x0000,0x0000,0x000
