Slide 10 you might want to look more into the first time VDD reaches VDDon. There are most likely three gate driver and CS pulses you are not seeing doing to scope resolution. The device may not be starting up because input under voltage lockout or OVP is falsely being triggered.
I have attached a preliminary application note that discusses the most common issues with PSR fault sensing and how to resolve them. I believe that this application not should help you to resolve the issues you are seeing with the UCC28631.
This is on line technical support and I believe the application note that I sent you should help you resolve your startup issues.
Please note we will continue to support this issue online until your issues is resolved.
