Other Parts Discussed in Thread: TPS3851
Dear Teams,
My customer wants to change from TPS3851 to TPS3852. However, they found that TPS3852 actually is a window watchdog timer, while TPS3851 is an independent watchdog timer. Refer to 8.1.1.2 on TPS3851 and TPS3852 datasheet, they need to adjust their code on programming to set not only the upper boundary of watchdog, but also the lower boundary. Did I understood the difference between TPS3851 and TPS3852 correct?
Thus, customer not necessary to change their hardware design circuit due to TPS3851 and TPS3852 are P2P. But, they need to re-program it, am I right?
Could you help tell us are there any other difference between TPS3851 and TPS3852?
Thanks!
Dylan
