Hi Team,
Our customer wants to know if the TLV62569 SW pin has the negative current capability to handle some reverse current in some cases, can you help to check how much negative current can be allowed?
Thanks.
Hi Team,
Thanks.
Hi Farheen,
I mean the low side MOSFET negative current from load to inductor->low side MOSFET->to ground, in customer's board, they can observe about -300mA~-400mA during some use cases, not sure it is allowed by our device or not.
Thanks.
Hi Jacky,
As it is non-A version. When current reaches zero, device should enter into Power Save Mode (PSM) mode. Can you pleas show me the waveforms where it is hitting this 300-400mA current peak? and for SW node waveforms, location of ground is very important. Can you share you measurement technique that how you are measuring it?
Thanks and Best Regards,
Farheen
Hi Farheen,
Please refer to below waveform we measured, please help to check if we have any specifications about this negative current handling. Thanks.
Hi Jacky,
How you are measuring your SW node voltage if it is possible to tell?
Farheen
Hi Farheen,
We suggested customer to measure the SW voltage using probe grounding spring to minimum ground loop. Can you help to check the current spec for low side MOSFET capability to negative as I shown in the picture? Thanks a lot!
Hi Jacky,
We do not have any available validation data about this negative spec for LS MOSFET. As I have said earlier, this device has zero current detection, after that device goes/should go into PSM mode. What I see in your shared waveforms is similar to what we have in our datasheet which is normal and intended behavior. You see a tiny delay after it hits zero current and before the disabling of power stage.
Farheen
