Other Parts Discussed in Thread: TPS62291,
Hello team,
Customer use TPS62291 which abs max is 7V and 20V is accidently applied to the device.
Can eFuse protect the device from the voltage?
As datasheet described, response time of OVLO is 1.2us and "TI recommends to add a TVS diode from OUT to IN to clamp the voltage to a safe level".
Due to the above reason, I thought eFuse can't protect the device because 20V is applied to the DCDC for 1.2us and I couldn't find a device which can clamp at below than 7V.
If you have any solution except using a device which has 20V abs. max, please let me know.
Koyo
