Other Parts Discussed in Thread: TPS65261, TPS65263
Hi team
Customer finds the device TPS65261-1 works normal at 25℃, but the output start to jitter when IC works at -10 to -40℃. Then we tested the control loop, found the curve of the control loop has changed.
Which parameter will be affected by temperature cause to TPS65261-1 control loop change.
