Team,
Would you be able to elaborate on the Y axis label in figures 2 and 3 of the datasheet?
Can you walk through how to read the graphs? wondering how to interpret +/-100+% of the values.
appreciate your help!
Team,
Hi Michael,
Thank you for pointing this out, clearly the Y-axis labels on Figures 2&3 are incorrect and will need to be fixed. I will need the help of the validation team for this, which will, unfortunately, have to wait till Jan 2022. Please use the Line and load regulation spec's provided in the EC table for your design calculations. Like the graphs, they also represent typical data over temperature. Thanks!
Srikanth
Srikanth,
Thanks! Appreciate the quick response! I will work to circle back with the team after the holidays.
Best Regards
Michael Schneider
Hi Michael,
As we discussed earlier, the axes are labelled incorrectly in the EP release datasheet. The original release (https://www.ti.com/lit/ds/symlink/tps7a47.pdf) has the correct axes label. We will work on fixing the labels in the EP version. Thanks!
Srikanth
