I am testing by applying TLC59581 to the new project.
Depending on the input data, LED control operates correctly.
I set the IREF resistor value by referring to item 9.3.4.1 of the datasheet.(example1)
I use one type of LED, and the target current is 20 mA.
The register setting value is as follows.
CCR, CCG, CCB : 511d
BC : 7h
IREF resistor : 1.209/20mA * 157.4 = 9.5K
However, measuring the current supplied to the LED consumes about 10 mA.
I want to target the maximum current of 20 mA and adjust the brightness through BC.
thanks.
