Hi TI,
If my design is Vin=3.135V to 3.465V and set Vout=3.5V and the max. consumed current is 2A, can TPS61230 work normally without issue and side effect? What is the suggest Cin/Cout/Inductance?
If not, what is the workable gap between Vin and Vout? I cannot find this mentioned in your datasheet.
If not ,do you have the pin2pin compatible solution for this requirement?
Thanks!
Parker
