Other Parts Discussed in Thread: TPS61259, TPS612592, TPS61251, TPS61253A
Hi Power Folks,
Does TI have p2p device to TPS61252DSGR? Otherwise, could you also suggest any similar device even though it's not p2p? Thank you for your help.
Hi Ella,
Let me check the background first. If customer choose TPS61252, why not they keep using it? TPS61252 has max 6.5V output voltage which is a little different from other low voltage boost converters, which normally have max 5.5V output voltage.
Please kindly specify what is customer's input voltage, output voltage and current.
-Wenhao
Hi Wenhao,
Customer is looking for p2p solution due to the supply issue. I do not have much detail on their design yet. They first request for p2p solution and might consider non-p2p device later. Do we have p2p device even though Vout_max is 5.5V?
