TPS65185: TPS65185
Part Number: TPS65185
Hi E2E,
May I ask for an E2E design review of this TPS65185?
This is intended for a 4-layer, single-sided PCB.
Review requested:
* Any errors, omissions, duplicates?
* Sources - 3.7V LiPo VBAT source, and 3.3V source from load switches.  All okay?
* Values - cap voltages, inductors, etc
* Cap types - caps mlcc vs tantalum?
* Power plane stack-up suggestions (constrained to single-sided only)
Many thanks!
Will
    Regarding your questions:
    1. See schematic review comments below.
    2. A battery is acceptable for VIN and load switches for supply delivery is acceptable. I suggest checking if the load switches recommend input/output capacitors.
    3. See schematic review comments below.
    4. MLCC capacitors are recommended for this device.
    5. The stackup for a 4-layer single-sided board should be similar to the EVM.
      • Top layer: components
      • Mid layer 1: continuous GND plane
      • Mid layer 2: power planes and routing
      • Bottom layer: GND and routing
    Comments on the schematic:
    • nINT is open-drain and requires a pull-up resistor
    • 10 uF decoupling capacitor is recommended close to the VIN pin
    • 4.7 uF decoupling capacitor is recommended close to the VCOM_PWR pin
    • PWR_GOOD is open-drain and requires a pull-up resistor
    • 10 uF decoupling capacitor is recommended close to the VIN_P pin
    • AGND and DGND are not connected on this sheet
  • Yes, thank you E2E.  I did have the pullups and decoupling on another page - I have since relocated those on the schematic to improve readability.  I'm good here. Thank you E2Eers!
