Dear Team,
TPS92682EVM-069 is this Eval kit that can be used for Peak current mode control.
is sample code for peak current mode control is available for this Eval kit?
Pratyay
Dear Team,
Pratyay
Hello Pratyay,
There is a GUI software that you need to load with the evaluation board and Launch Pad. This will let you control all the registers to do what you need to control the TPS92682 as a constant current mode controller or a constant voltage mode controller.
Thanks Tuan
Hi Tuan,
Thank you for your replay.
My concern is ..Is there any Eval kit dedicated for Peak current mode control converter?
if available please share the part no of that Eval kit.
thanks,
Pratyay
Hi Pratyay,
They are all on TI.com. Use the link below, under design and development you see that there are two evaluation boards for constant current control and constant voltage mode control. You mention Peak current mode control...Here, I hope you understand that the part uses peak current mode control to control either a constant current output or a constant voltage output.
Thanks Tuan
