Hi, I'm testing the BQ24038 EVM. I wonder what value of battery voltage causes Q2 goes off ... Can you set the cutoff voltage for Q2 goes off?
Thank you very much.
Not clear what your question is. The Q2 FET turns on when charging and when supplementing current to the OUT pin.
When in termination, if the input source is available, then Q2 will be off.
Hi Charles,
Maybe, I have not explained well. We start from the state in which the battery is fully charged, then off the power input and the battery begins to discharge and the system continues to function properly, because the Q2 is on... What voltage of battery makes Q2 go off?
