Customer would like to use TPS61161A as voltage regulator.
Voltage regulation is normal but under 0.1A load, voltage is decreased.
Could you check this and review the schematic for 0.5A load with 5V?
Thanks.
Thanks.
hi David
The schematic configuration is ok. One thing needs to notice is the current rating of diode D16. It would be better to leave some margin based on Io=0.5A for thermal consideration.
