Other Parts Discussed in Thread: TPS74701
Hi Team,
I have received the TPS7A1110PDRVT part. The P denotes that the active discharge circuit is enabled. Looking at the ordering info of the TPS7A11 parts, it seems that it is only possible to get the P-version? Can you please check if the version without the P will be “special” (not the volume part) and also check if it will be available at all?
RJ
