What are the differences between the BQ24072 battery charger and the BQ24072T ?
The BQ24072 uses a current source to drive the NTC Thermistor connected to the TS pin. The bq24072T uses a voltage source to drive the NTC Thermistor connected to the TS pin. The end result is the same however, the voltage source gives you more flexibility.
