Hi Team,
Regarding TPS3420, understand from the datasheet that this reset IC monitors 2 inputs when simultaneously held low and output an active-low reset pulse signal.
If we were to connect the 2 inputs together to a switch, which the PB1 and PB2 will go low together at the same time to assert the reset output. And, de-asserts the reset output when both inputs are released together.
Kindly advise if there will be any implication if both inputs are connected together. We believe there should be no issue, but we still want double confirm with the BU team. Thank you.
Mike
