Other Parts Discussed in Thread: USB2ANY
I have a problem where communication is not working on my stack devices.
I had it working before but suddenly some stack modules are only listening to wake tone and then wont turn off again until i fully disconnect them from the battery.
I have the evaluation board and usb2any connector. I checked connections and have the correct voltage on the LDOIN pin, on VC pins I also have the correct voltage.
My setup i use to connect comm high and comm low are with isolation capacitors and 2 common mode chokes in series.
Do you guys have any tips to solve or find the problem. because i already have 3 chips with not fully working communication it seems like.
Edit:
Normally I leave the UART unconnected (RX connected with CVDD and TX floating). Now i tried to debug the module by connecting the UART again and everything seems to work fine again after i connected the the UART. even the differential communication suddenly started workign again on the different modules. Is here an explanation for? Is there something I am missing from the datasheet?
