Other Parts Discussed in Thread: PMP, TPSM63606, LM61460
Hi team,
Here is several application details of TPSM63603 want to confirm with you.
Q1: if we want to achieve a adjsutable output based on TPSM63603, if it's accepatable we add a addtional adjustment voltage on the FB pin? Or if extra external voltage loop is needed here?
Q2: what is the control algorithm when we decrease the Vout setting suddenly? for example, change the Vout setup from 10V to 5V. Will our part still work under the FPWM with the minimum on time or directly OFF the switching?
Thanks.
Best regards
Mia Ma
