Hi we are working with a device that have Li-Po battery, and the termination voltage should be ~4.2 Volts.
The information on the datasheet its a bit confused if you compare it with the web information of the device. So i need to confirm if this IC or some of the BQ2407X family could be use to charge a Li-Po battery with a termination of 4.2Volts.
Regards, Carlos.
