I tested TPS54202EVM today, and I changed the output voltage from 5V to 3.3V by adjusting the feedback resistance. . I don't understand where I circled out with a red line because not every square waves have spikes .
Hi Skylar,
I suppose you must want to know why the marked ringing appears every 3 cycles.
This is related with load current. For extreme low current, single pulse will charge enough energy for load, meaning that there exists time for shutdown of High Side FET, Low Side FET and body diode of Low Side FET. This will cause ringing in each switching period.
However, when load current increases to some value, single pulse would not provide enough energy to load, which make several consecutive pulses to provide enough energy and then the inductor would have time for no current flowing through. This is the reason behind shown waveform.
Hope my explanation would be helpful!
BRs
Zixu
