Other Parts Discussed in Thread: TLC5971,
Team,
TLC59711 and TLC5971 (HTSSOP-20) seems to be very close (same package, same pinout):
www.ti.com/.../compare.html
I have found the below post but it does not give 100% the confidence that those two IC are P2P drop-in:
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/493843/are-tlc59711-and-tlc5971-protocol-compatible?
-Can you please confirm if they are P2P drop-in?
-TLC59711 has a WDT. What register setup is required on TLC59711 so that its outputs OUTxxx behaves exactly like a TLC5971?
-Is the LED current control mechanism compatible between the two?
-Any other differences that need to be taken into account?
Thanks in advance,
A.
