Other Parts Discussed in Thread: BQ76940,
Hi Guys,
I'm designing a 15-S BMS with BQ76940 battery monitor that has to supply 100A continuous discharge current at 48 Volts nominal.
i was planning on using the CSD19532KTTT in a back-to-back configuration with 12 Nos in parallel for each direction
is it better to use the TPS22959s load switches in parallel ? There is a significant reduction in cost and size
pls advice, this is my first time posting in the forum
