Hi
We use the TPS65320D-Q1 Buck-Regulator output to transfer 3.3v to the MCU, and the MCU will turn on the LDO enable pin and mosfet to transfer 1.2 and 1.5v. The current problem is
When the MCU turns on the MOS and LDO enable, there will be a voltage drop at the Buck-Regulator 3.3v output terminal, about 0.5v, which will cause the MCU restart. Do you have any suggestions to solve this voltage drop?
Block diagram
CH1: Regulator output vdd3p3_MCU
CH2: mos output VDD3p3
CH3:3v3_mos_control
CH4:MCU reset pin
