Hi Team,
Can you please clarify if there are any internal pull up on the fault pin of PTPS1HC100BQPWPRQ1?'
is this internal pull up for output open load or internal pullup on the fault pin ?
Thank you in advance.
Marvin
Hi Team,
Marvin
Hi Marvin,
There is no pull up on the fault pin. This is an open drain pin.
The pull up resistor here is the one used for open load detection.
Shreyas
