Other Parts Discussed in Thread: TLV61046, , TLV61046A
I designed a board based on TPS61022RWUR, TPS61022RWUR,BQ24075QRGTRQ1 and TLV61046ADBVT.
The schematic is attached below.
I did testing of battery charging IC, fuel gauge , and buck boost TPS61022RWUR. In this case everything is working except TLV61046 IC inductor wasn't solder on the board because we need that buzzer in later stage after verification of other IC's.
Everything was working perfectly fine but as soon, we solder the inductor L2 for buzzer circuit. The circuit run for a moment and started showing shortage. After analysis, we found that TPS61022RWUR has been damaged.
I want to know what is the possible issue that can cause it to damage?
Is it possible some negative voltage from buzzer circuit feed to the 5V buck/boost circuit and cause it damage?
8877.a.pdfb.pdf
