UCC28513: The PFC function design review
Genius 16330 points
Part Number: UCC28513
Other Parts Discussed in Thread: UC3854, , UCC2818, UCC28064
Hi Experts,
Customer would like to continue this thread for additional request:
Customer reviewed the last feedback from Harish. Asking to review the notes below with the attached file (see below):
1) The schematic is based on UC3854. The connection around this chip is slightly different than UCC28513.
2) I tried to "translate" the values for UCC28513; the number in yellow boxes refers to critical values and the numbers in gray boxes are intended to stay as is in the current design.
3) Can you please review and let me know if I captured right the intended values for UCC28513 chip?
Thank you.
Archie A.
  • Hi ARchie,
    Thank you for posting the query on UCC28513. I will go over the query and get back by tomorrow.
    Harish
  • Hi Archie,
    I was trying to do more analysis and found that the PFC controller in UCC28513 is almot same as UCC2818 and I thought it would be good use this as reference. Based on this I have attached the MATHCAD calculations file which can be directly used. Please try the attached and let us know your observations.
    Mathcad - UCC3817-UCC28513 Design Procedure.pdf
    Since you do not have Simplis, we have a good news for you is we have a UCC2818 TINA/PSPICE model. But the model is unencrypted. So if you have an NDA we would be able to share this for simulation and evaluation purpose. Please let us know your inputs.
    Thank you
    Harish
  • Hello Harish,
    I am the Hardware Engineering Manager at Listen. Alex Wood, who has been corresponding with Archie, is working for us a consultant on this project.
    Would it be possible for TI to initiate the NDA between TI and Listen so we can get the UCC2818 TINA/PSPICE model?
    Al Flint
  • Hi Mr. Flint,
    Thank you for the reply.
    I will be sharing the TINA/PSPICE model with Archie.
    Harish
  • Hello Harish,
    Alex responded:
    I have done additional tests based on the latest feedback from Harish. I really appreciate his help!
    Attached file summarizes the results on pages 93-106. I am very interested to hear about his feedback.
    Archie/Alex
    PS: I didn't try out TINA models yet, but I will do that and thank you for getting them to us.
  • Hi Archie, Alex
    Thank you for the reply with the new results.
    The following component designators are based on UCC28513.
    R2 can be kept at 0.43ohms
    R8/R12 be 3kohms
    R13 and C6 at 3.23k and 4.9nF
    All others look fine. But the change in frequency seems strange to me and happens irrespective of inductor. I will have to look into it further before commenting on it. I will get back on this issue after consulting the team.
    Can you please update based on the above component values? Also for the 220V can you try increasing the load from 25W to 60W or higher?
    Also is it poosible to feed IAC directly from  AC supply as shown below:
    Between what does Q5 and Q6 in PSB refer to in the board / results document?
    Harish
  • Thank you, Harish.
    Our customer, Alex, will implement the recommendations and report back. Refer below for this response to your follow up:
    Q5 and Q6 refer to transistors used on downstream of PFC stage. Currently they are removed, and resistors are connected to PFC output as load. Sorry for confusion. They will be removed from the report.
    Thank you.
    73,
    Alex/Archie
  • Hi Alex/ Archie
    Makes sense now. Please let us know your findings on the latest suggestions.
    Harish
  • Hello Harish,
    Happy Monday.
    I have done additional tests per the latest feedback from Harish. The latest test results are on p107-p131.
    Thank you and regards,
    Alex/Archie
  • Hi Archie,
    I am going through the results and will get back to you by tomorrow.
    Thank you
    Harish
  • Hi Alex/Archie
    Thank you for sending the detailed results. Sorry that moving the sensing circuit for Iac before rectifier did not work, I was suggesting this as the input current seemed to have some phase difference.
    The results look interesting. I have been trying to look into this yesterday and here are my initial comments:
    1. The converter clearly transitions into DCM mode at a certain voltage above 200Vac as shown above which probably explains the reason for switching at lower Fsw and the over shoot we see is when this comes out of this mode and controller tries to regulate/correct current immediately. What I suspect is when input voltage changes (close to peak ~200V), there is a a change in critical conductance factor (kc) which is causing the mode change. I expect the waveforms to be not good at 25w, but definitely expected better results at 60W. I am not doubting the control loop parameters for now because you are getting good regulation at 85V/max power where bandwidth would matter the most. Is it possible for you to increase the inductance say double it from the existing value to around 1.3mH and let me know your observations. I apologize for this inconvenience of burdening you with  testing using a new inductor.
    2. The Vff is ideally supposed to be around 4.6V at max line voltage and 1.4V at 85V. If there is any distortion here it can affect results. Can you please check if Vff is getting clamped while you increase the voltage?
    3. Can you also measure the results at 120W & 200Vac and compare it with 200Vac and 60W case to see if the distortions arise at close to the same point of peak voltage? I probably suspect the distortion of current at peak might increase but just wanted to have this data point. Lastly can you check it at 220Vac and 60W.
    I have been trying to work on the TINA model of UCC2818 but I am not able to replicate this issue, but will keep you informed if I am able to make any progress.
    Harish
  • Hi Harish,
    Thank you very much for your usual support.
    The latest test results per Harish's feedback are on p132-161. Look forward to his review.
    Alex/Archie.
  • Hi Alex/Archie
    Thank you again for the detailed analysis again.
    From the waveforms we can clearly conclude there is a minimum on time limit reached, which causes this pulse dropping/frequency reduction resulting in mode change as you have clearly pointed in the conclusion slide point 6. Ideally these controllers are optimized for best performance in CCM mode. On time, ton = LI/Vin
    This is probably the reason why the waveforms are better when the inductance is doubled at 120W power where the distortion starts to creep in at 250Vac but the same distortion appears much earlier at around 200Vac when the inductor is less.
    At 30W, the curents are very less and I do not expect improvement in performance at higher input voltages which matches with the simulation results.
    Ideally for these power levels we would recommend going with a transition mode PFC controller like UCC28064/65/56 for better performance. But I understand in your case that you might require a combo PFC/flyback for a reason. I think you will have choose the inductor, to ensure 120W performance at 85V/265V is acceptable and 30W at high line would be difficult to meet with this controller. Please let us know if you have any questions.
    Harish
    Your guidance have been very helpful. Alex team noted, that they will increase the inductance, maintain the other changes as you recommended and repeat the test at various loads and input voltages.
    They intend to prepare one shorter report before sending it here, to wrap this up.
    We keep you posted here.
    Archie A.
  • Hi Alex/Archie,
    Thank you for your constant feedback and testing. It really helped. Please feel free to post your report here or through private email. We can review them and close this.
    Harish
