Hi team,
This is Jayden. My customer wants to use TPS2359 to monitor and control dual-channel 12V/40A circuit. I just want to check can this part support 40A current limit? If not, do you have a socket to recommend? Many thanks.
Brs
Jayden
Hi team,
Brs
Jayden
Hi Jayden,
Thanks for reaching out to us. Do the customer need oring functionality? Could you please share the customer block diagram?
Hi Avishek,
Sorry, I do not have the customer block diagram now because it is new application for our field team. They just want to check whether it can support 50A current limit because as described in DS "The 12-V channels use external sense resistors that typically lie in the range of 4 - 10 mΩ. ".
So I think the device is recommended to support 10A-25A, right?
Brs
Jayden
Hi Avishek,
Sincerely remind you any comments for that? Thanks.
Brs
Jayden
Hi Jayden,
Extremely sorry for the delay in getting back to you. TPS2359 can be used in 50 A/12 V system. It has enough gate pull down strength to turn off two (2) MOSFETs in parallel during any fault.
RSNS can be reduced to have 50 A of current limit. Please let me know if you have any more query.
