Power Stage has Analog Temperature Output.
Where is the temperature sensor in Power Stage?
What kind of temperature sensor is used?
Nagai
https://e2e.ti.com/blogs_/b/powerhouse/posts/what-does-a-lead-free-power-mosfet-really-mean
Nagai
Hi Nagai,
The power stage's temperature is measured from its lead-frame. The source junction of the sync FET sits right on top of the lead-frame of the power stage which is why the output can be used as an accurate measurement of the junction temperature of the sync FET.
Ryan
Hi Nagai,
The temperature sensor is located on the driver IC which is adjacent to the low side FET on the leadframe. The sensor is a diode-based circuit that is calibrated at final test.
Ryan
