Other Parts Discussed in Thread: TPS27SA08-Q1, TPS27SA08, TPS2HB16-Q1, TPS1HB08-Q1,
Hi all, I want to check if copying the datasheet example is that is needed?
I have diodes on the power supply entering the board so I assume I don't need the ground protect?
Also, how do the SEL's and DIA_EN work? Can I just pull them up or down and still have diagnostics instead of routing to uC? Thanks!
