Hi team,
Customer want to use TPS92633-Q1. In design, each PCB requires a 2pcs chip, for the ICTR pins, can I connect the two chip pins together to share the thermal derating circuit? There are no corresponding application examples in the data table. The left and right IC sets the same LED current, same input voltage, same the number of LED strings.
my concern is that if two NTC's are separated, the temperature inconsistency will cause the LED current of the two chips to be inconsistent.
thanks
