I have a clearly marked bq25622 IC mounted on my PCBs.
I suspect these are actually bq25620 parts due to the following behaviors:
1. REG_038H reads 0x02
2. ILIM external resistor set for 470mA is ignored and inout current goes past that value (I am reading 5.1V @ 1.1A externally and through the bq25622 ADC
3. TS_STAT reads as TS_HOT. Utilizing TS_BIAS circuit with 103AT 3380B resistor with RT1=5.23K and RT2=30.1K.
I would suspect this result from a bq25620.
Parts were purchased from Digikey recently.
Once you realize you have a mislabeling issue, I assume you will send out replacement parts to each affected customer?
Cheers,
Matt
It happened to me as well, please refer to this post in forum: https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1235771/bq25622-schematic-check/4683128?tisearch=e2e-sitesearch&keymatch=BQ25622#4683128
What should we do?
My board supplier bought it directly from TI.
I would like to understand if an entire batch was deemed faulty and how this will impact the availability of the parts. Additionally, I am concerned about the possibility of a similar occurrence happening again in the future.
As I am currently in the process of developing a product centered around this particular part, it is crucial for me to assess whether switching to a more reliable alternative is necessary at this stage. Ensuring a smooth production line is of utmost importance to me.
I strongly believe that addressing this issue on a one-on-one basis is crucial, considering its significant impact. It is my conviction that small messages in a forum may not effectively tackle the magnitude of the problem at hand.
Thank you very much
Some units have the improper marking. If you purchase from TI, please visit https://www.ti.com/productreturns/docs/createReturn.tsp for TI store return process.
Thank you very much,
Ning.
