TLV70033
We are currently having problems with the voltage regulator and suspect that this is caused by a too low slew rate on the EN pin. Since the output of the reset IC is pulled up directly to the VIN pin with a pull-up, the EN pin is not switched on cleanly in the first phase.
Unfortunately, there is no information on this in the data sheet. Can you please provide it?
