Other Parts Discussed in Thread: UCC28700
Requesting to provide UCC28700-Q1 IC, CS pin input leakage current, which will help in our design.
Hi Vamsi,
Thank you for the query on UCC28700.
The CS pin directly accepts voltage from the external current sense resistor. There is no leakage parameter specified here. Can you please clarify on what you exactly lloking into?
Harish
Hi Harish,
I can directly see, there is no cs pin leakage current from datasheet. However, I require cs pin leakage current which will be helpful in my design. Can you please help me with it.
Kind regards,
Vamsi Bankuru
Hi Vamsi,
I will see if any such parameter is mentioned/ recorded. It will take a couple of days to check and come back.
Harish
Hi Vamsi,
I have checked with the product team and do not have any update from them yet about this parameter. I will keep you posted if I have an update from them.
Thank you
Harish
Hi Vamsi,
We do not have any update on this parameter. Probably not available with the team.
Harish
Hi Harish,
Can I expect any further update regarding the requirement. As CS pin input leakage current is required, which will help in our design.
Kind regards,
Vamsi Bankuru
