Other Parts Discussed in Thread: BQ79616
Hello! I am working with a BQ79600 bridge IC and a stack of BQ79606A monitoring ICs.
I am trying to figure out the correct auto-addressing procedure. The datasheet for the BQ79600 lists an example for an auto address procedure using the BQ79616 chips, but no the 79606 chips.
There are a few conflicts which aren't clear. For example, in both datasheets, it says to set the CONTROL1 register to 0x01 to enable auto-addressing.
However, CONTROL1 has a different value on the BQ79606 vs the BQ79600, so I am a bit confused. Do I use a broadcast command for both values?
Any clarifications and an example procedure would help.
